path: root/kernel/cpuset.c
2008-09-13cpuset: avoid changing cpuset's cpus when -errno returnedLi Zefan
After the patch: commit 0b2f630a28d53b5a2082a5275bc3334b10373508 Author: Miao Xie <miaox@cn.fujitsu.com> Date: Fri Jul 25 01:47:21 2008 -0700 cpusets: restructure the function update_cpumask() and update_nodemask() It might happen that 'echo 0 > /cpuset/sub/cpus' returned failure but 'cpus' has been changed, because cpus was changed before calling heap_init() which may return -ENOMEM. This patch restores the orginal behavior. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-14sched, cpuset: rework sched domains and CPU hotplug handling (v4)Max Krasnyansky
This is an updated version of my previous cpuset patch on top of the latest mainline git. The patch fixes CPU hotplug handling issues in the current cpusets code. Namely circular locking in rebuild_sched_domains() and unsafe access to the cpu_online_map in the cpuset cpu hotplug handler. This version includes changes suggested by Paul Jackson (naming, comments, style, etc). I also got rid of the separate workqueue thread because it is now safe to call get_online_cpus() from workqueue callbacks. Here are some more details: rebuild_sched_domains() is the only way to rebuild sched domains correctly based on the current cpuset settings. What this means is that we need to be able to call it from different contexts, like cpu hotplug for example. Also latest scheduler code in -tip now calls rebuild_sched_domains() directly from functions like arch_reinit_sched_domains(). In order to support that properly we need to rework cpuset locking rules to avoid circular dependencies, which is what this patch does. New lock nesting rules are explained in the comments. We can now safely call rebuild_sched_domains() from virtually any context. The only requirement is that it needs to be called under get_online_cpus(). This allows cpu hotplug handlers and the scheduler to call rebuild_sched_domains() directly. The rest of the cpuset code now offloads sched domains rebuilds to a workqueue (async_rebuild_sched_domains()). This version of the patch addresses comments from the previous review. I fixed all miss-formated comments and trailing spaces. I also factored out the code that builds domain masks and split up CPU and memory hotplug handling. This was needed to simplify locking, to avoid unsafe access to the cpu_online_map from mem hotplug handler, and in general to make things cleaner. The patch passes moderate testing (building kernel with -j 16, creating & removing domains and bringing cpus off/online at the same time) on the quad-core2 based machine. It passes lockdep checks, even with preemptable RCU enabled. This time I also tested in with suspend/resume path and everything is working as expected. Signed-off-by: Max Krasnyansky <maxk@qualcomm.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: menage@google.com Cc: a.p.zijlstra@chello.nl Cc: vegard.nossum@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-30cpuset: clean up cpuset hierarchy traversal codeLi Zefan
Use cpuset.stack_list rather than kfifo, so we avoid memory allocation for kfifo. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30cpuset: fix wrong calculation of relax domain levelLi Zefan
When multiple cpusets are overlapping in their 'cpus' and hence they form a single sched domain, the largest sched_relax_domain_level among those should be used. But when top_cpuset's sched_load_balance is set, its sched_relax_domain_level is used regardless other sub-cpusets'. This patch fixes it by walking the cpuset hierarchy to find the largest sched_relax_domain_level. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30cpuset: speed up sched domain partitionLai Jiangshan
All child cpusets contain a subset of the parent's cpus, so we can skip them when partitioning sched domains. This decreases 'csa' greately for cpusets with multi-level hierarchy. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30cpuset: a bit cleanup for scan_for_empty_cpusets()Li Zefan
clean up hierarchy traversal code Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Cliff Wickman <cpw@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpuset: two minor code-cleanupsLai Jiangshan
In cpuset_update_task_memory_state() local variable struct task_struct *tsk = current; And local variable tsk is used 14 times and statement task_cs(tsk) is used twice in this function. So using task_cs(tsk) instead of task_cs(current) is better for readability. And "(struct cgroup_scanner *)&scan" is not good for readability also. (and "container_of" is used in cpuset_do_move_task(), not "(cpuset_hotplug_scanner *)scan") Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpuset: code-cleanup for started_afterLai Jiangshan
cgroup(cgroup_scan_tasks) will initialize heap->gt for us. This patch removes started_after() and its helper-function. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpuset: don't pass empty cpumasks to partition_sched_domains()Lai Jiangshan
I create lots of empty cpusets(empty cpumasks) and turn off the "sched_load_balance" in top cpuset. I found that all these empty cpumasks are passed to partition_sched_domains() in rebuild_sched_domains(), it's very time-consuming for partition_sched_domains() and it's not need. It also reduce memory consumed and some works in rebuild_sched_domains() too. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpuset: avoid unnecessary sched domains rebuildingLi Zefan
When changing 'sched_relax_domain_level', don't rebuild sched domains if 'cpus' is empty or 'sched_load_balance' is not set. Also make the comments of rebuild_sched_domains() more readable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpusets: update task's cpus_allowed and mems_allowed after CPU/NODE ↵Miao Xie
offline/online The bug is that a task may run on the cpu/node which is not in its cpuset.cpus/ cpuset.mems. It can be reproduced by the following commands: ----------------------------------- # mkdir /dev/cpuset # mount -t cpuset xxx /dev/cpuset # mkdir /dev/cpuset/0 # echo 0-1 > /dev/cpuset/0/cpus # echo 0 > /dev/cpuset/0/mems # echo $$ > /dev/cpuset/0/tasks # echo 0 > /sys/devices/system/cpu/cpu1/online # echo 1 > /sys/devices/system/cpu/cpu1/online ----------------------------------- There is only CPU0 in cpuset.cpus, but the task in this cpuset runs on both CPU0 and CPU1. It is because the task's cpu_allowed didn't get updated after we did CPU offline/online manipulation. Similar for mem_allowed. This patch fixes this bug expect for root cpuset. Because there is a problem about root cpuset, in that whether it is necessary to update all the tasks in root cpuset or not after cpu/node offline/online. If updating, some kernel threads which is bound into a specified cpu will be unbound. If not updating, there is a bug in root cpuset. This bug is also caused by offline/online manipulation. For example, there is a dual-cpu machine. we create a sub cpuset in root cpuset and assign 1 to its cpus. And then we attach some tasks into this sub cpuset. After this, we offline CPU1. Now, the tasks in this new cpuset are moved into root cpuset automatically because there is no cpu in sub cpuset. Then we online CPU1, we find all the tasks which doesn't belong to root cpuset originally just run on CPU0. Maybe we need to add a flag in the task_struct to mark which task can't be unbound? Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cpusets: restructure the function update_cpumask() and update_nodemask()Miao Xie
Extract two functions from update_cpumask() and update_nodemask().They will be used later for updating tasks' cpus_allowed and mems_allowed after CPU/NODE offline/online. [lizf@cn.fujitsu.com: build fix] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cgroup files: remove cpuset_common_file_write()Paul Menage
This patch tweaks the signatures of the update_cpumask() and update_nodemask() functions so that they can be called directly as handlers for the new cgroups write_string() method. This allows cpuset_common_file_write() to be removed. Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23Merge branch 'sched/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: hrtick_enabled() should use cpu_active() sched, x86: clean up hrtick implementation sched: fix build error, provide partition_sched_domains() unconditionally sched: fix warning in inc_rt_tasks() to not declare variable 'rq' if it's not needed cpu hotplug: Make cpu_active_map synchronization dependency clear cpu hotplug, sched: Introduce cpu_active_map and redo sched domain managment (take 2) sched: rework of "prioritize non-migratable tasks over migratable ones" sched: reduce stack size in isolated_cpu_setup() Revert parts of "ftrace: do not trace scheduler functions" Fixed up conflicts in include/asm-x86/thread_info.h (due to the TIF_SINGLESTEP unification vs TIF_HRTICK_RESCHED removal) and kernel/sched_fair.c (due to cpu_active_map vs for_each_cpu_mask_nr() introduction).
2008-07-22cpusets: fix wrong domain attr updatesMiao Xie
Fix wrong domain attr updates, or we will always update the first sched domain attr. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> [2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-18cpu hotplug, sched: Introduce cpu_active_map and redo sched domain managment ↵Max Krasnyansky
(take 2) This is based on Linus' idea of creating cpu_active_map that prevents scheduler load balancer from migrating tasks to the cpu that is going down. It allows us to simplify domain management code and avoid unecessary domain rebuilds during cpu hotplug event handling. Please ignore the cpusets part for now. It needs some more work in order to avoid crazy lock nesting. Although I did simplfy and unify domain reinitialization logic. We now simply call partition_sched_domains() in all the cases. This means that we're using exact same code paths as in cpusets case and hence the test below cover cpusets too. Cpuset changes to make rebuild_sched_domains() callable from various contexts are in the separate patch (right next after this one). This not only boots but also easily handles while true; do make clean; make -j 8; done and while true; do on-off-cpu 1; done at the same time. (on-off-cpu 1 simple does echo 0/1 > /sys/.../cpu1/online thing). Suprisingly the box (dual-core Core2) is quite usable. In fact I'm typing this on right now in gnome-terminal and things are moving just fine. Also this is running with most of the debug features enabled (lockdep, mutex, etc) no BUG_ONs or lockdep complaints so far. I believe I addressed all of the Dmitry's comments for original Linus' version. I changed both fair and rt balancer to mask out non-active cpus. And replaced cpu_is_offline() with !cpu_active() in the main scheduler code where it made sense (to me). Signed-off-by: Max Krasnyanskiy <maxk@qualcomm.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Gregory Haskins <ghaskins@novell.com> Cc: dmitry.adamushko@gmail.com Cc: pj@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14Merge commit 'v2.6.26' into sched/develIngo Molnar
2008-07-13cpusets, hotplug, scheduler: fix scheduler domain breakageDmitry Adamushko
Commit f18f982ab ("sched: CPU hotplug events must not destroy scheduler domains created by the cpusets") introduced a hotplug-related problem as described below: Upon CPU_DOWN_PREPARE, update_sched_domains() -> detach_destroy_domains(&cpu_online_map) does the following: /* * Force a reinitialization of the sched domains hierarchy. The domains * and groups cannot be updated in place without racing with the balancing * code, so we temporarily attach all running cpus to the NULL domain * which will prevent rebalancing while the sched domains are recalculated. */ The sched-domains should be rebuilt when a CPU_DOWN ops. has been completed, effectively either upon CPU_DEAD{_FROZEN} (upon success) or CPU_DOWN_FAILED{_FROZEN} (upon failure -- restore the things to their initial state). That's what update_sched_domains() also does but only for !CPUSETS case. With f18f982ab, sched-domains' reinitialization is delegated to CPUSETS code: cpuset_handle_cpuhp() -> common_cpu_mem_hotplug_unplug() -> rebuild_sched_domains() Being called for CPU_UP_PREPARE and if its callback is called after update_sched_domains()), it just negates all the work done by update_sched_domains() -- i.e. a soon-to-be-offline cpu is included in the sched-domains and that makes it visible for the load-balancer while the CPU_DOWN ops. is in progress. __migrate_live_tasks() moves the tasks off a 'dead' cpu (it's already "offline" when this function is called). try_to_wake_up() is called for one of these tasks from another CPU -> the load-balancer (wake_idle()) picks up a "dead" CPU and places the task on it. Then e.g. BUG_ON(rq->nr_running) detects this a bit later -> oops. Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: miaox@cn.fujitsu.com Cc: rostedt@goodmis.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-23Merge branch 'linus' into sched/develtip-sched-devel-2008-06-23_09.30_MonIngo Molnar
2008-06-20Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: fix NMI hangs due to lock race - 2.6.26-rc regression rcupreempt: remove export of rcu_batches_completed_bh cpuset: limit the input of cpuset.sched_relax_domain_level
2008-06-19cpuset: limit the input of cpuset.sched_relax_domain_levelLi Zefan
We allow the inputs to be [-1 ... SD_LV_MAX), and return -EINVAL for inputs outside this range. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Acked-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-19sched: CPU hotplug events must not destroy scheduler domains created by the ↵Max Krasnyansky
cpusets First issue is not related to the cpusets. We're simply leaking doms_cur. It's allocated in arch_init_sched_domains() which is called for every hotplug event. So we just keep reallocation doms_cur without freeing it. I introduced free_sched_domains() function that cleans things up. Second issue is that sched domains created by the cpusets are completely destroyed by the CPU hotplug events. For all CPU hotplug events scheduler attaches all CPUs to the NULL domain and then puts them all into the single domain thereby destroying domains created by the cpusets (partition_sched_domains). The solution is simple, when cpusets are enabled scheduler should not create default domain and instead let cpusets do that. Which is exactly what the patch does. Signed-off-by: Max Krasnyansky <maxk@qualcomm.com> Cc: pj@sgi.com Cc: menage@google.com Cc: rostedt@goodmis.org Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-16Merge branch 'linus' into sched-develtip-sched-devel-2008-06-16_09.15_MonIngo Molnar
2008-06-10sched: prevent bound kthreads from changing cpus_allowedDavid Rientjes
Kthreads that have called kthread_bind() are bound to specific cpus, so other tasks should not be able to change their cpus_allowed from under them. Otherwise, it is possible to move kthreads, such as the migration or software watchdog threads, so they are not allowed access to the cpu they work on. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-06cpusets: fix bug when adding nonexistent cpu or memLai Jiangshan
Adding a nonexistent cpu to a cpuset will be omitted quietly. It should return -EINVAL. Example: (real_nr_cpus <= 4 < NR_CPUS or cpu#4 was just offline) # cat cpus 0-1 # /bin/echo 4 > cpus # /bin/echo $? 0 # cat cpus # The same occurs when add a nonexistent mem. This patch will fix this bug. And when *buf == "", the check is unneeded. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06sched: CPU hotplug events must not destroy scheduler domains created by the ↵Max Krasnyansky
cpusets First issue is not related to the cpusets. We're simply leaking doms_cur. It's allocated in arch_init_sched_domains() which is called for every hotplug event. So we just keep reallocation doms_cur without freeing it. I introduced free_sched_domains() function that cleans things up. Second issue is that sched domains created by the cpusets are completely destroyed by the CPU hotplug events. For all CPU hotplug events scheduler attaches all CPUs to the NULL domain and then puts them all into the single domain thereby destroying domains created by the cpusets (partition_sched_domains). The solution is simple, when cpusets are enabled scheduler should not create default domain and instead let cpusets do that. Which is exactly what the patch does. Signed-off-by: Max Krasnyansky <maxk@qualcomm.com> Cc: pj@sgi.com Cc: menage@google.com Cc: rostedt@goodmis.org Cc: mingo@elte.hu Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-08Fix cpuset sched_relax_domain_level control filePaul Menage
Due to a merge conflict, the sched_relax_domain_level control file was marked as being handled by cpuset_read/write_u64, but the code to handle it was actually in cpuset_common_file_read/write. Since the value being written/read is in fact a signed integer, it should be treated as such; this patch adds cpuset_read/write_s64 functions, and uses them to handle the sched_relax_domain_level file. With this patch, the sched_relax_domain_level can be read and written, and the correct contents seen/updated. Signed-off-by: Paul Menage <menage@google.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Cpuset hardwall flag: add a mem_hardwall flag to cpusetsPaul Menage
This flag provides the hardwalling properties of mem_exclusive, without enforcing the exclusivity. Either mem_hardwall or mem_exclusive is sufficient to prevent GFP_KERNEL allocations from passing outside the cpuset's assigned nodes. Signed-off-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Cpuset hardwall flag: switch cpusets to use the bulk cgroup_add_files() APIPaul Menage
Currently the cpusets mem_exclusive flag is overloaded to mean both "no-overlapping" and "no GFP_KERNEL allocations outside this cpuset". These patches add a new mem_hardwall flag with just the allocation restriction part of the mem_exclusive semantics, without breaking backwards-compatibility for those who continue to use just mem_exclusive. Additionally, the cgroup control file registration for cpusets is cleaned up to reduce boilerplate. This patch: This change tidies up the cpusets control file definitions, and reduces the amount of boilerplate required to add/change control files in the future. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel/cpuset.c: make 3 functions staticAdrian Bunk
Make the following needlessly global functions static: - cpuset_test_cpumask() - cpuset_change_cpumask() - cpuset_do_move_task() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29CGroup API files: update cpusets to use cgroup structured file APIPaul Menage
Many of the cpusets control files are simple integer values, which don't require the overhead of memory allocations for reads and writes. Move the handlers for these control files into cpuset_read_u64() and cpuset_write_u64(). [akpm@linux-foundation.org: ad dmissing `break'] Signed-off-by: Paul Menage <menage@google.com> Cc: "Li Zefan" <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "YAMAMOTO Takashi" <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kernel: fix integer as NULL pointer warningsHarvey Harrison
kernel/cpuset.c:1268:52: warning: Using plain integer as NULL pointer kernel/pid_namespace.c:95:24: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_copy to mpol_dupLee Schermerhorn
This patch renames mpol_copy() to mpol_dup() because, well, that's what it does. Like, e.g., strdup() for strings, mpol_dup() takes a pointer to an existing mempolicy, allocates a new one and copies the contents. In a later patch, I want to use the name mpol_copy() to copy the contents from one mempolicy to another like, e.g., strcpy() does for strings. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: have zonelist contains structs with both a zone pointer and zone_idxMel Gorman
Filtering zonelists requires very frequent use of zone_idx(). This is costly as it involves a lookup of another structure and a substraction operation. As the zone_idx is often required, it should be quickly accessible. The node idx could also be stored here if it was found that accessing zone->node is significant which may be the case on workloads where nodemasks are heavily used. This patch introduces a struct zoneref to store a zone pointer and a zone index. The zonelist then consists of an array of these struct zonerefs which are looked up as necessary. Helpers are given for accessing the zone index as well as the node index. [kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers] [hugh@veritas.com: mm-have-zonelist: fix memcg ooms] [hugh@veritas.com: just return do_try_to_free_pages] [hugh@veritas.com: do_try_to_free_pages gfp_mask redundant] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19sched, cpuset: customize sched domains, coreHidetoshi Seto
[rebased for sched-devel/latest] - Add a new cpuset file, having levels: sched_relax_domain_level - Modify partition_sched_domains() and build_sched_domains() to take attributes parameter passed from cpuset. - Fill newidle_idx for node domains which currently unused but might be required if sched_relax_domain_level become higher. - We can change the default level by boot option 'relax_domain_level='. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpumask: use new cpus_scnprintf functionMike Travis
* Cleaned up references to cpumask_scnprintf() and added new cpulist_scnprintf() interfaces where appropriate. * Fix some small bugs (or code efficiency improvments) for various uses of cpumask_scnprintf. * Clean up some checkpatch errors. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpuset: modify cpuset_set_cpus_allowed to use cpumask pointerMike Travis
* Modify cpuset_cpus_allowed to return the currently allowed cpuset via a pointer argument instead of as the function return value. * Use new set_cpus_allowed_ptr function. * Cleanup CPU_MASK_ALL and NODE_MASK_ALL uses. Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-05cpusets: fix obsolete commentDavid Rientjes
mm migration is no longer done in cpuset_update_task_memory_state() so it can no longer take current->mm->mmap_sem, so fix the obsolete comment. [ This changed in commit 04c19fa6f16047abff2288ddbc1f0798ede5a849 ("cpuset: migrate all tasks in cpuset at once") when the mm migration was moved from cpuset_update_task_memory_state() to update_nodemask() ] Signed-off-by: David Rientjes <rientjes@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu move tasks in empty cpusets - refinementsPaul Jackson
- Narrow the scope of callback_mutex in scan_for_empty_cpusets(). - Avoid rewriting the cpus, mems of cpusets except when it is likely that we'll be changing them. - Have remove_tasks_in_empty_cpuset() also check for empty mems. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Cliff Wickman <cpw@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu: move tasks in empty cpusets to parent various other fixesPaul Jackson
Various minor formatting and comment tweaks to Cliff Wickman's [PATCH_3_of_3]_cpusets__update_cpumask_revision.patch I had had "iff", meaning "if and only if" in a comment. However, except for ancient mathematicians, the abbreviation "iff" was a tad too cryptic. Cliff changed it to "if", presumably figuring that the "iff" was a typo. However, it was the "only if" half of the conjunction that was most interesting. Reword to emphasis the "only if" aspect. The locking comment for remove_tasks_in_empty_cpuset() was wrong; it said callback_mutex had to be held on entry. The opposite is true. Several mentions of attach_task() in comments needed to be changed to cgroup_attach_task(). A comment about notify_on_release was no longer relevant, as the line of code it had commented, namely: set_bit(CS_RELEASED_RESOURCE, &parent->flags); is no longer present in that place in the cpuset.c code. Similarly a comment about notify_on_release before the scan_for_empty_cpusets() routine was no longer relevant. Removed extra parentheses and unnecessary return statement. Renamed attach_task() to cpuset_attach() in various comments. Removed comment about not needing memory migration, as it seems the migration is done anyway, via the cpuset_attach() callback from cgroup_attach_task(). Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Cliff Wickman <cpw@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07cgroups: update comments in cpuset.cPaul Menage
Some of the comments in kernel/cpuset.c were stale following the transition to control groups; this patch updates them to more closely match reality. Signed-off-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07cpusets: update_cpumask revisionCliff Wickman
Use the new function cgroup_scan_tasks() to step through all tasks in a cpuset. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu: move tasks in empty cpusets to parentCliff Wickman
This patch corrects a situation that occurs when one disables all the cpus in a cpuset. Currently, the disabled (cpu-less) cpuset inherits the cpus of its parent, which is incorrect because it may then overlap its cpu-exclusive sibling. Tasks of an empty cpuset should be moved to the cpuset which is the parent of their current cpuset. Or if the parent cpuset has no cpus, to its parent, etc. And the empty cpuset should be released (if it is flagged notify_on_release). Depends on the cgroup_scan_tasks() function (proposed by David Rientjes) to iterate through all tasks in the cpu-less cpuset. We are deliberately avoiding a walk of the tasklist. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19hotplug cpu: migrate a task within its cpusetCliff Wickman
When a cpu is disabled, move_task_off_dead_cpu() is called for tasks that have been running on that cpu. Currently, such a task is migrated: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any cpu which is both online and among that task's cpus_allowed It is typical of a multithreaded application running on a large NUMA system to have its tasks confined to a cpuset so as to cluster them near the memory that they share. Furthermore, it is typical to explicitly place such a task on a specific cpu in that cpuset. And in that case the task's cpus_allowed includes only a single cpu. This patch would insert a preference to migrate such a task to some cpu within its cpuset (and set its cpus_allowed to its entire cpuset). With this patch, migrate the task to: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any online cpu within the task's cpuset 3) to any cpu which is both online and among that task's cpus_allowed In order to do this, move_task_off_dead_cpu() must make a call to cpuset_cpus_allowed_locked(), a new subset of cpuset_cpus_allowed(), that will not block. (name change - per Oleg's suggestion) Calls are made to cpuset_lock() and cpuset_unlock() in migration_call() to set the cpuset mutex during the whole migrate_live_tasks() and migrate_dead_tasks() procedure. [akpm@linux-foundation.org: build fix] [pj@sgi.com: Fix indentation and spacing] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix cpusets update_cpumaskPaul Menage
Cause writes to cpuset "cpus" file to update cpus_allowed for member tasks: - collect batches of tasks under tasklist_lock and then call set_cpus_allowed() on them outside the lock (since this can sleep). - add a simple generic priority heap type to allow efficient collection of batches of tasks to be processed without duplicating or missing any tasks in subsequent batches. - make "cpus" file update a no-op if the mask hasn't changed - fix race between update_cpumask() and sched_setaffinity() by making sched_setaffinity() post-check that it's not running on any cpus outside cpuset_cpus_allowed(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cpusets: decrustify cpuset mask update codePaul Jackson
Decrustify the kernel/cpuset.c 'cpus' and 'mems' updating code. Other than subtle improvements in the consistency of identifying white space at the beginning and end of passed in masks, this doesn't make any visible difference in behaviour. But it's one or two hundred kernel text bytes smaller, and easier to understand. [akpm@linux-foundation.org: coding-style fix] Signed-off-by: Paul Jackson <pj@sgi.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cpuset sched_load_balance flagPaul Jackson
Add a new per-cpuset flag called 'sched_load_balance'. When enabled in a cpuset (the default value) it tells the kernel scheduler that the scheduler should provide the normal load balancing on the CPUs in that cpuset, sometimes moving tasks from one CPU to a second CPU if the second CPU is less loaded and if that task is allowed to run there. When disabled (write "0" to the file) then it tells the kernel scheduler that load balancing is not required for the CPUs in that cpuset. Now even if this flag is disabled for some cpuset, the kernel may still have to load balance some or all the CPUs in that cpuset, if some overlapping cpuset has its sched_load_balance flag enabled. If there are some CPUs that are not in any cpuset whose sched_load_balance flag is enabled, the kernel scheduler will not load balance tasks to those CPUs. Moreover the kernel will partition the 'sched domains' (non-overlapping sets of CPUs over which load balancing is attempted) into the finest granularity partition that it can find, while still keeping any two CPUs that are in the same shed_load_balance enabled cpuset in the same element of the partition. This serves two purposes: 1) It provides a mechanism for real time isolation of some CPUs, and 2) it can be used to improve performance on systems with many CPUs by supporting configurations in which load balancing is not done across all CPUs at once, but rather only done in several smaller disjoint sets of CPUs. This mechanism replaces the earlier overloading of the per-cpuset flag 'cpu_exclusive', which overloading was removed in an earlier patch: cpuset-remove-sched-domain-hooks-from-cpusets See further the Documentation and comments in the code itself. [akpm@linux-foundation.org: don't be weird] Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
