path: root/kernel/cpuset.c
2014-08-04Merge branch 'for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "Mostly changes to get the v2 interface ready. The core features are mostly ready now and I think it's reasonable to expect to drop the devel mask in one or two devel cycles at least for a subset of controllers. - cgroup added a controller dependency mechanism so that block cgroup can depend on memory cgroup. This will be used to finally support IO provisioning on the writeback traffic, which is currently being implemented. - The v2 interface now uses a separate table so that the interface files for the new interface are explicitly declared in one place. Each controller will explicitly review and add the files for the new interface. - cpuset is getting ready for the hierarchical behavior which is in the similar style with other controllers so that an ancestor's configuration change doesn't change the descendants' configurations irreversibly and processes aren't silently migrated when a CPU or node goes down. All the changes are to the new interface and no behavior changed for the multiple hierarchies" * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (29 commits) cpuset: fix the WARN_ON() in update_nodemasks_hier() cgroup: initialize cgrp_dfl_root_inhibit_ss_mask from !->dfl_files test cgroup: make CFTYPE_ONLY_ON_DFL and CFTYPE_NO_ internal to cgroup core cgroup: distinguish the default and legacy hierarchies when handling cftypes cgroup: replace cgroup_add_cftypes() with cgroup_add_legacy_cftypes() cgroup: rename cgroup_subsys->base_cftypes to ->legacy_cftypes cgroup: split cgroup_base_files[] into cgroup_{dfl|legacy}_base_files[] cpuset: export effective masks to userspace cpuset: allow writing offlined masks to cpuset.cpus/mems cpuset: enable onlined cpu/node in effective masks cpuset: refactor cpuset_hotplug_update_tasks() cpuset: make cs->{cpus, mems}_allowed as user-configured masks cpuset: apply cs->effective_{cpus,mems} cpuset: initialize top_cpuset's configured masks at mount cpuset: use effective cpumask to build sched domains cpuset: inherit ancestor's masks if effective_{cpus, mems} becomes empty cpuset: update cs->effective_{cpus, mems} when config changes cpuset: update cpuset->effective_{cpus,mems} at hotplug cpuset: add cs->effective_cpus and cs->effective_mems cgroup: clean up sane_behavior handling ...
2014-07-30cpuset: fix the WARN_ON() in update_nodemasks_hier()Li Zefan
The WARN_ON() is used to check if we break the legal hierarchy, on which the effective mems should be equal to configured mems. Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com> Tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com> Signed-off-by: Li Zefan <lizefan@huawei.com>
2014-07-15cgroup: rename cgroup_subsys->base_cftypes to ->legacy_cftypesTejun Heo
Currently, cgroup_subsys->base_cftypes is used for both the unified default hierarchy and legacy ones and subsystems can mark each file with either CFTYPE_ONLY_ON_DFL or CFTYPE_INSANE if it has to appear only on one of them. This is quite hairy and error-prone. Also, we may end up exposing interface files to the default hierarchy without thinking it through. cgroup_subsys will grow two separate cftype arrays and apply each only on the hierarchies of the matching type. This will allow organizing cftypes in a lot clearer way and encourage subsystems to scrutinize the interface which is being exposed in the new default hierarchy. In preparation, this patch renames cgroup_subsys->base_cftypes to cgroup_subsys->legacy_cftypes. This patch is pure rename. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2014-07-09cpuset: export effective masks to userspaceLi Zefan
cpuset.cpus and cpuset.mems are the configured masks, and we need to export effective masks to userspace, so users know the real cpus_allowed and mems_allowed that apply to the tasks in a cpuset. v2: - export those masks unconditionally, suggested by Tejun. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: allow writing offlined masks to cpuset.cpus/memsLi Zefan
As the configured masks won't be limited by its parent, and the top cpuset's masks won't change when hotplug happens, it's natural to allow writing offlined masks to the configured masks. If on default hierarchy: # echo 0 > /sys/devices/system/cpu/cpu1/online # mkdir /cpuset/sub # echo 1 > /cpuset/sub/cpuset.cpus # cat /cpuset/sub/cpuset.cpus 1 If on legacy hierarchy: # echo 0 > /sys/devices/system/cpu/cpu1/online # mkdir /cpuset/sub # echo 1 > /cpuset/sub/cpuset.cpus -bash: echo: write error: Invalid argument Note the checks don't need to be gated by cgroup_on_dfl, because we've initialized top_cpuset.{cpus,mems}_allowed accordingly in cpuset_bind(). Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: enable onlined cpu/node in effective masksLi Zefan
Firstly offline cpu1: # echo 0-1 > cpuset.cpus # echo 0 > /sys/devices/system/cpu/cpu1/online # cat cpuset.cpus 0-1 # cat cpuset.effective_cpus 0 Then online it: # echo 1 > /sys/devices/system/cpu/cpu1/online # cat cpuset.cpus 0-1 # cat cpuset.effective_cpus 0-1 And cpuset will bring it back to the effective mask. The implementation is quite straightforward. Instead of calculating the offlined cpus/mems and do updates, we just set the new effective_mask to online_mask & congifured_mask. This is a behavior change for default hierarchy, so legacy hierarchy won't be affected. v2: - make refactoring of cpuset_hotplug_update_tasks() as seperate patch, suggested by Tejun. - make hotplug_update_tasks_insane() use @new_cpus and @new_mems as hotplug_update_tasks_sane() does. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: refactor cpuset_hotplug_update_tasks()Li Zefan
We mix the handling for both default hierarchy and legacy hierarchy in the same function, and it's quite messy, so split into two functions. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: make cs->{cpus, mems}_allowed as user-configured masksLi Zefan
Now we've used effective cpumasks to enforce hierarchical manner, we can use cs->{cpus,mems}_allowed as configured masks. Configured masks can be changed by writing cpuset.cpus and cpuset.mems only. The new behaviors are: - They won't be changed by hotplug anymore. - They won't be limited by its parent's masks. This ia a behavior change, but won't take effect unless mount with sane_behavior. v2: - Add comments to explain the differences between configured masks and effective masks. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: apply cs->effective_{cpus,mems}Li Zefan
Now we can use cs->effective_{cpus,mems} as effective masks. It's used whenever: - we update tasks' cpus_allowed/mems_allowed, - we want to retrieve tasks_cs(tsk)'s cpus_allowed/mems_allowed. They actually replace effective_{cpu,node}mask_cpuset(). effective_mask == configured_mask & parent effective_mask except when the reault is empty, in which case it inherits parent effective_mask. The result equals the mask computed from effective_{cpu,node}mask_cpuset(). This won't affect the original legacy hierarchy, because in this case we make sure the effective masks are always the same with user-configured masks. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: initialize top_cpuset's configured masks at mountLi Zefan
We now have to support different behaviors for default hierachy and legacy hiearchy, top_cpuset's configured masks need to be initialized accordingly. Suppose we've offlined cpu1. On default hierarchy: # mount -t cgroup -o __DEVEL__sane_behavior xxx /cpuset # cat /cpuset/cpuset.cpus 0-15 On legacy hierarchy: # mount -t cgroup xxx /cpuset # cat /cpuset/cpuset.cpus 0,2-15 Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: use effective cpumask to build sched domainsLi Zefan
We're going to have separate user-configured masks and effective ones. Eventually configured masks can only be changed by writing cpuset.cpus and cpuset.mems, and they won't be restricted by parent cpuset. While effective masks reflect cpu/memory hotplug and hierachical restriction, and these are the real masks that apply to the tasks in the cpuset. We calculate effective mask this way: - top cpuset's effective_mask == online_mask, otherwise - cpuset's effective_mask == configured_mask & parent effective_mask, if the result is empty, it inherits parent effective mask. Those behavior changes are for default hierarchy only. For legacy hierarchy, effective_mask and configured_mask are the same, so we won't break old interfaces. We should partition sched domains according to effective_cpus, which is the real cpulist that takes effects on tasks in the cpuset. This won't introduce behavior change. v2: - Add a comment for the call of rebuild_sched_domains(), suggested by Tejun. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: inherit ancestor's masks if effective_{cpus, mems} becomes emptyLi Zefan
We're going to have separate user-configured masks and effective ones. Eventually configured masks can only be changed by writing cpuset.cpus and cpuset.mems, and they won't be restricted by parent cpuset. While effective masks reflect cpu/memory hotplug and hierachical restriction, and these are the real masks that apply to the tasks in the cpuset. We calculate effective mask this way: - top cpuset's effective_mask == online_mask, otherwise - cpuset's effective_mask == configured_mask & parent effective_mask, if the result is empty, it inherits parent effective mask. Those behavior changes are for default hierarchy only. For legacy hierarchy, effective_mask and configured_mask are the same, so we won't break old interfaces. To make cs->effective_{cpus,mems} to be effective masks, we need to - update the effective masks at hotplug - update the effective masks at config change - take on ancestor's mask when the effective mask is empty The last item is done here. This won't introduce behavior change. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: update cs->effective_{cpus, mems} when config changesLi Zefan
We're going to have separate user-configured masks and effective ones. Eventually configured masks can only be changed by writing cpuset.cpus and cpuset.mems, and they won't be restricted by parent cpuset. While effective masks reflect cpu/memory hotplug and hierachical restriction, and these are the real masks that apply to the tasks in the cpuset. We calculate effective mask this way: - top cpuset's effective_mask == online_mask, otherwise - cpuset's effective_mask == configured_mask & parent effective_mask, if the result is empty, it inherits parent effective mask. Those behavior changes are for default hierarchy only. For legacy hierarchy, effective_mask and configured_mask are the same, so we won't break old interfaces. To make cs->effective_{cpus,mems} to be effective masks, we need to - update the effective masks at hotplug - update the effective masks at config change - take on ancestor's mask when the effective mask is empty The second item is done here. We don't need to treat root_cs specially in update_cpumasks_hier(). This won't introduce behavior change. v3: - add a WARN_ON() to check if effective masks are the same with configured masks on legacy hierarchy. - pass trialcs->cpus_allowed to update_cpumasks_hier() and add a comment for it. Similar change for update_nodemasks_hier(). Suggested by Tejun. v2: - revise the comment in update_{cpu,node}masks_hier(), suggested by Tejun. - fix to use @cp instead of @cs in these two functions. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: update cpuset->effective_{cpus,mems} at hotplugLi Zefan
We're going to have separate user-configured masks and effective ones. Eventually configured masks can only be changed by writing cpuset.cpus and cpuset.mems, and they won't be restricted by parent cpuset. While effective masks reflect cpu/memory hotplug and hierachical restriction, and these are the real masks that apply to the tasks in the cpuset. We calculate effective mask this way: - top cpuset's effective_mask == online_mask, otherwise - cpuset's effective_mask == configured_mask & parent effective_mask, if the result is empty, it inherits parent effective mask. Those behavior changes are for default hierarchy only. For legacy hierarchy, effective_mask and configured_mask are the same, so we won't break old interfaces. To make cs->effective_{cpus,mems} to be effective masks, we need to - update the effective masks at hotplug - update the effective masks at config change - take on ancestor's mask when the effective mask is empty The first item is done here. This won't introduce behavior change. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cpuset: add cs->effective_cpus and cs->effective_memsLi Zefan
We're going to have separate user-configured masks and effective ones. Eventually configured masks can only be changed by writing cpuset.cpus and cpuset.mems, and they won't be restricted by parent cpuset. While effective masks reflect cpu/memory hotplug and hierachical restriction, and these are the real masks that apply to the tasks in the cpuset. We calculate effective mask this way: - top cpuset's effective_mask == online_mask, otherwise - cpuset's effective_mask == configured_mask & parent effective_mask, if the result is empty, it inherits parent effective mask. Those behavior changes are for default hierarchy only. For legacy hierachy, effective_mask and configured_mask are the same, so we won't break old interfaces. This patch adds the effective masks to struct cpuset and initializes them. The effective masks of the top cpuset is the same with configured masks, and a child cpuset inherits its parent's effective masks. This won't introduce behavior change. v2: - s/real_{mems,cpus}_allowed/effective_{mems,cpus}, suggested by Tejun. - don't init effective masks in cpuset_css_online() if !cgroup_on_dfl. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-09cgroup: remove sane_behavior support on non-default hierarchiesTejun Heo
sane_behavior has been used as a development vehicle for the default unified hierarchy. Now that the default hierarchy is in place, the flag became redundant and confusing as its usage is allowed on all hierarchies. There are gonna be either the default hierarchy or legacy ones. Let's make that clear by removing sane_behavior support on non-default hierarchies. This patch replaces cgroup_sane_behavior() with cgroup_on_dfl(). The comment on top of CGRP_ROOT_SANE_BEHAVIOR is moved to on top of cgroup_on_dfl() with sane_behavior specific part dropped. On the default and legacy hierarchies w/o sane_behavior, this shouldn't cause any behavior differences. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz>
2014-07-01cpuset: break kernfs active protection in cpuset_write_resmask()Tejun Heo
Writing to either "cpuset.cpus" or "cpuset.mems" file flushes cpuset_hotplug_work so that cpu or memory hotunplug doesn't end up migrating tasks off a cpuset after new resources are added to it. As cpuset_hotplug_work calls into cgroup core via cgroup_transfer_tasks(), this flushing adds the dependency to cgroup core locking from cpuset_write_resmak(). This used to be okay because cgroup interface files were protected by a different mutex; however, 8353da1f91f1 ("cgroup: remove cgroup_tree_mutex") simplified the cgroup core locking and this dependency became a deadlock hazard - cgroup file removal performed under cgroup core lock tries to drain on-going file operation which is trying to flush cpuset_hotplug_work blocked on the same cgroup core lock. The locking simplification was done because kernfs added an a lot easier way to deal with circular dependencies involving kernfs active protection. Let's use the same strategy in cpuset and break active protection in cpuset_write_resmask(). While it isn't the prettiest, this is a very rare, likely unique, situation which also goes away on the unified hierarchy. The commands to trigger the deadlock warning without the patch and the lockdep output follow. localhost:/ # mount -t cgroup -o cpuset xxx /cpuset localhost:/ # mkdir /cpuset/tmp localhost:/ # echo 1 > /cpuset/tmp/cpuset.cpus localhost:/ # echo 0 > cpuset/tmp/cpuset.mems localhost:/ # echo $$ > /cpuset/tmp/tasks localhost:/ # echo 0 > /sys/devices/system/cpu/cpu1/online ====================================================== [ INFO: possible circular locking dependency detected ] 3.16.0-rc1-0.1-default+ #7 Not tainted ------------------------------------------------------- kworker/1:0/32649 is trying to acquire lock: (cgroup_mutex){+.+.+.}, at: [<ffffffff8110e3d7>] cgroup_transfer_tasks+0x37/0x150 but task is already holding lock: (cpuset_hotplug_work){+.+...}, at: [<ffffffff81085412>] process_one_work+0x192/0x520 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (cpuset_hotplug_work){+.+...}: ... -> #1 (s_active#175){++++.+}: ... -> #0 (cgroup_mutex){+.+.+.}: ... other info that might help us debug this: Chain exists of: cgroup_mutex --> s_active#175 --> cpuset_hotplug_work Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(cpuset_hotplug_work); lock(s_active#175); lock(cpuset_hotplug_work); lock(cgroup_mutex); *** DEADLOCK *** 2 locks held by kworker/1:0/32649: #0: ("events"){.+.+.+}, at: [<ffffffff81085412>] process_one_work+0x192/0x520 #1: (cpuset_hotplug_work){+.+...}, at: [<ffffffff81085412>] process_one_work+0x192/0x520 stack backtrace: CPU: 1 PID: 32649 Comm: kworker/1:0 Not tainted 3.16.0-rc1-0.1-default+ #7 ... Call Trace: [<ffffffff815a5f78>] dump_stack+0x72/0x8a [<ffffffff810c263f>] print_circular_bug+0x10f/0x120 [<ffffffff810c481e>] check_prev_add+0x43e/0x4b0 [<ffffffff810c4ee6>] validate_chain+0x656/0x7c0 [<ffffffff810c53d2>] __lock_acquire+0x382/0x660 [<ffffffff810c57a9>] lock_acquire+0xf9/0x170 [<ffffffff815aa13f>] mutex_lock_nested+0x6f/0x380 [<ffffffff8110e3d7>] cgroup_transfer_tasks+0x37/0x150 [<ffffffff811129c0>] hotplug_update_tasks_insane+0x110/0x1d0 [<ffffffff81112bbd>] cpuset_hotplug_update_tasks+0x13d/0x180 [<ffffffff811148ec>] cpuset_hotplug_workfn+0x18c/0x630 [<ffffffff810854d4>] process_one_work+0x254/0x520 [<ffffffff810875dd>] worker_thread+0x13d/0x3d0 [<ffffffff8108e0c8>] kthread+0xf8/0x100 [<ffffffff815acaec>] ret_from_fork+0x7c/0xb0 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Li Zefan <lizefan@huawei.com> Tested-by: Li Zefan <lizefan@huawei.com>
2014-06-25cpuset,mempolicy: fix sleeping function called from invalid contextGu Zheng
When runing with the kernel(3.15-rc7+), the follow bug occurs: [ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586 [ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python [ 9969.441175] INFO: lockdep is turned off. [ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85 [ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012 [ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18 [ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c [ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000 [ 9969.974071] Call Trace: [ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66 [ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130 [ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0 [ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210 [ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140 [ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150 [ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40 [ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10 [ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50 [ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40 [ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380 [ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0 [ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20 [ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90 [ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b The cause is that cpuset_mems_allowed() try to take mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in __mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock protection region to protect the access to cpuset only in current_cpuset_is_being_rebound(). So that we can avoid this bug. This patch is a temporary solution that just addresses the bug mentioned above, can not fix the long-standing issue about cpuset.mems rebinding on fork(): "When the forker's task_struct is duplicated (which includes ->mems_allowed) and it races with an update to cpuset_being_rebound in update_tasks_nodemask() then the task's mems_allowed doesn't get updated. And the child task's mems_allowed can be wrong if the cpuset's nodemask changes before the child has been added to the cgroup's tasklist." Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable <stable@vger.kernel.org>
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on cgroup side. Heavy restructuring including locking simplification took place to improve the code base and enable implementation of the unified hierarchy, which currently exists behind a __DEVEL__ mount option. The core support is mostly complete but individual controllers need further work. To explain the design and rationales of the the unified hierarchy Documentation/cgroups/unified-hierarchy.txt is added. Another notable change is css (cgroup_subsys_state - what each controller uses to identify and interact with a cgroup) iteration update. This is part of continuing updates on css object lifetime and visibility. cgroup started with reference count draining on removal way back and is now reaching a point where csses behave and are iterated like normal refcnted objects albeit with some complexities to allow distinguishing the state where they're being deleted. The css iteration update isn't taken advantage of yet but is planned to be used to simplify memcg significantly" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (77 commits) cgroup: disallow disabled controllers on the default hierarchy cgroup: don't destroy the default root cgroup: disallow debug controller on the default hierarchy cgroup: clean up MAINTAINERS entries cgroup: implement css_tryget() device_cgroup: use css_has_online_children() instead of has_children() cgroup: convert cgroup_has_live_children() into css_has_online_children() cgroup: use CSS_ONLINE instead of CGRP_DEAD cgroup: iterate cgroup_subsys_states directly cgroup: introduce CSS_RELEASED and reduce css iteration fallback window cgroup: move cgroup->serial_nr into cgroup_subsys_state cgroup: link all cgroup_subsys_states in their sibling lists cgroup: move cgroup->sibling and ->children into cgroup_subsys_state cgroup: remove cgroup->parent device_cgroup: remove direct access to cgroup->children memcg: update memcg_has_children() to use css_next_child() memcg: remove tasks/children test from mem_cgroup_force_empty() cgroup: remove css_parent() cgroup: skip refcnting on normal root csses and cgrp_dfl_root self css cgroup: use cgroup->self.refcnt for cgroup refcnting ...
2014-06-04mm: page_alloc: use jump labels to avoid checking number_of_cpusetsMel Gorman
If cpusets are not in use then we still check a global variable on every page allocation. Use jump labels to avoid the overhead. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-16cgroup: remove css_parent()Tejun Heo
cgroup in general is moving towards using cgroup_subsys_state as the fundamental structural component and css_parent() was introduced to convert from using cgroup->parent to css->parent. It was quite some time ago and we're moving forward with making css more prominent. This patch drops the trivial wrapper css_parent() and let the users dereference css->parent. While at it, explicitly mark fields of css which are public and immutable. v2: New usage from device_cgroup.c converted. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Johannes Weiner <hannes@cmpxchg.org>
2014-05-13cgroup: replace cftype->write_string() with cftype->write()Tejun Heo
Convert all cftype->write_string() users to the new cftype->write() which maps directly to kernfs write operation and has full access to kernfs and cgroup contexts. The conversions are mostly mechanical. * @css and @cft are accessed using of_css() and of_cft() accessors respectively instead of being specified as arguments. * Should return @nbytes on success instead of 0. * @buf is not trimmed automatically. Trim if necessary. Note that blkcg and netprio don't need this as the parsers already handle whitespaces. cftype->write_string() has no user left after the conversions and removed. While at it, remove unnecessary local variable @p in cgroup_subtree_control_write() and stale comment about CGROUP_LOCAL_BUFFER_SIZE in cgroup_freezer.c. This patch doesn't introduce any visible behavior changes. v2: netprio was missing from conversion. Converted. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: "David S. Miller" <davem@davemloft.net>
2014-05-13cgroup: rename css_tryget*() to css_tryget_online*()Tejun Heo
Unlike the more usual refcnting, what css_tryget() provides is the distinction between online and offline csses instead of protection against upping a refcnt which already reached zero. cgroup is planning to provide actual tryget which fails if the refcnt already reached zero. Let's rename the existing trygets so that they clearly indicate that they're onliness. I thought about keeping the existing names as-are and introducing new names for the planned actual tryget; however, given that each controller participates in the synchronization of the online state, it seems worthwhile to make it explicit that these functions are about on/offline state. Rename css_tryget() to css_tryget_online() and css_tryget_from_dir() to css_tryget_online_from_dir(). This is pure rename. v2: cgroup_freezer grew new usages of css_tryget(). Update accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
2014-05-06kernel/cpuset.c: convert printk to pr_foo()Fabian Frederick
Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-06kernel/cpuset.c: kernel-doc fixesFabian Frederick
This patch also converts seq_printf to seq_puts Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-04-03Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - Various misc bits - kmemleak fixes - small befs, codafs, cifs, efs, freexxfs, hfsplus, minixfs, reiserfs things - fanotify - I appear to have become SuperH maintainer - ocfs2 updates - direct-io tweaks - a bit of the MM queue - printk updates - MAINTAINERS maintenance - some backlight things - lib/ updates - checkpatch updates - the rtc queue - nilfs2 updates - Small Documentation/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (237 commits) Documentation/SubmittingPatches: remove references to patch-scripts Documentation/SubmittingPatches: update some dead URLs Documentation/filesystems/ntfs.txt: remove changelog reference Documentation/kmemleak.txt: updates fs/reiserfs/super.c: add __init to init_inodecache fs/reiserfs: move prototype declaration to header file fs/hfsplus/attributes.c: add __init to hfsplus_create_attr_tree_cache() fs/hfsplus/extents.c: fix concurrent acess of alloc_blocks fs/hfsplus/extents.c: remove unused variable in hfsplus_get_block nilfs2: update project's web site in nilfs2.txt nilfs2: update MAINTAINERS file entries fix nilfs2: verify metadata sizes read from disk nilfs2: add FITRIM ioctl support for nilfs2 nilfs2: add nilfs_sufile_trim_fs to trim clean segs nilfs2: implementation of NILFS_IOCTL_SET_SUINFO ioctl nilfs2: add nilfs_sufile_set_suinfo to update segment usage nilfs2: add struct nilfs_suinfo_update and flags nilfs2: update MAINTAINERS file entries fs/coda/inode.c: add __init to init_inodecache() BEFS: logging cleanup ...
2014-04-03mm: optimize put_mems_allowed() usageMel Gorman
Since put_mems_allowed() is strictly optional, its a seqcount retry, we don't need to evaluate the function if the allocation was in fact successful, saving a smp_rmb some loads and comparisons on some relative fast-paths. Since the naming, get/put_mems_allowed() does suggest a mandatory pairing, rename the interface, as suggested by Mel, to resemble the seqcount interface. This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(), where it is important to note that the return value of the latter call is inverted from its previous incarnation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03Merge branch 'for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot updates for cgroup: - The biggest one is cgroup's conversion to kernfs. cgroup took after the long abandoned vfs-entangled sysfs implementation and made it even more convoluted over time. cgroup's internal objects were fused with vfs objects which also brought in vfs locking and object lifetime rules. Naturally, there are places where vfs rules don't fit and nasty hacks, such as credential switching or lock dance interleaving inode mutex and cgroup_mutex with object serial number comparison thrown in to decide whether the operation is actually necessary, needed to be employed. After conversion to kernfs, internal object lifetime and locking rules are mostly isolated from vfs interactions allowing shedding of several nasty hacks and overall simplification. This will also allow implmentation of operations which may affect multiple cgroups which weren't possible before as it would have required nesting i_mutexes. - Various simplifications including dropping of module support, easier cgroup name/path handling, simplified cgroup file type handling and task_cg_lists optimization. - Prepatory changes for the planned unified hierarchy, which is still a patchset away from being actually operational. The dummy hierarchy is updated to serve as the default unified hierarchy. Controllers which aren't claimed by other hierarchies are associated with it, which BTW was what the dummy hierarchy was for anyway. - Various fixes from Li and others. This pull request includes some patches to add missing slab.h to various subsystems. This was triggered xattr.h include removal from cgroup.h. cgroup.h indirectly got included a lot of files which brought in xattr.h which brought in slab.h. There are several merge commits - one to pull in kernfs updates necessary for converting cgroup (already in upstream through driver-core), others for interfering changes in the fixes branch" * 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (74 commits) cgroup: remove useless argument from cgroup_exit() cgroup: fix spurious lockdep warning in cgroup_exit() cgroup: Use RCU_INIT_POINTER(x, NULL) in cgroup.c cgroup: break kernfs active_ref protection in cgroup directory operations cgroup: fix cgroup_taskset walking order cgroup: implement CFTYPE_ONLY_ON_DFL cgroup: make cgrp_dfl_root mountable cgroup: drop const from @buffer of cftype->write_string() cgroup: rename cgroup_dummy_root and related names cgroup: move ->subsys_mask from cgroupfs_root to cgroup cgroup: treat cgroup_dummy_root as an equivalent hierarchy during rebinding cgroup: remove NULL checks from [pr_cont_]cgroup_{name|path}() cgroup: use cgroup_setup_root() to initialize cgroup_dummy_root cgroup: reorganize cgroup bootstrapping cgroup: relocate setting of CGRP_DEAD cpuset: use rcu_read_lock() to protect task_cs() cgroup_freezer: document freezer_fork() subtleties cgroup: update cgroup_transfer_tasks() to either succeed or fail cgroup: drop task_lock() protection around task->cgroups cgroup: update how a newly forked task gets associated with css_set ...
2014-03-19cgroup: drop const from @buffer of cftype->write_string()Tejun Heo
cftype->write_string() just passes on the writeable buffer from kernfs and there's no reason to add const restriction on the buffer. The only thing const achieves is unnecessarily complicating parsing of the buffer. Drop const from @buffer. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
2014-03-03cpuset: use rcu_read_lock() to protect task_cs()Li Zefan
We no longer use task_lock() to protect tsk->cgroups. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-27cpuset: fix a race condition in __cpuset_node_allowed_softwall()Li Zefan
It's not safe to access task's cpuset after releasing task_lock(). Holding callback_mutex won't help. Cc: <stable@vger.kernel.org> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-27cpuset: fix a locking issue in cpuset_migrate_mm()Li Zefan
I can trigger a lockdep warning: # mount -t cgroup -o cpuset xxx /cgroup # mkdir /cgroup/cpuset # mkdir /cgroup/tmp # echo 0 > /cgroup/tmp/cpuset.cpus # echo 0 > /cgroup/tmp/cpuset.mems # echo 1 > /cgroup/tmp/cpuset.memory_migrate # echo $$ > /cgroup/tmp/tasks # echo 1 > /cgruop/tmp/cpuset.mems =============================== [ INFO: suspicious RCU usage. ] 3.14.0-rc1-0.1-default+ #32 Not tainted ------------------------------- include/linux/cgroup.h:682 suspicious rcu_dereference_check() usage! ... [<ffffffff81582174>] dump_stack+0x72/0x86 [<ffffffff810b8f01>] lockdep_rcu_suspicious+0x101/0x140 [<ffffffff81105ba1>] cpuset_migrate_mm+0xb1/0xe0 ... We used to hold cgroup_mutex when calling cpuset_migrate_mm(), but now we hold cpuset_mutex, which causes task_css() to complain. This is not a false-positive but a real issue. Holding cpuset_mutex won't prevent a task from migrating to another cpuset, and it won't prevent the original task->cgroup from destroying during this change. Fixes: 5d21cc2db040 (cpuset: replace cgroup_mutex locking with cpuset internal locking) Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Li Zefan <lizefan@huawei.com> Sigend-off-by: Tejun Heo <tj@kernel.org>
2014-02-13cpuset: don't use cgroup_taskset_cur_css()Tejun Heo
cgroup_taskset_cur_css() will be removed during the planned resturcturing of migration path. The only use of cgroup_taskset_cur_css() is finding out the old cgroup_subsys_state of the leader in cpuset_attach(). This usage can easily be removed by remembering the old value from cpuset_can_attach(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2014-02-13cgroup: drop @skip_css from cgroup_taskset_for_each()Tejun Heo
If !NULL, @skip_css makes cgroup_taskset_for_each() skip the matching css. The intention of the interface is to make it easy to skip css's (cgroup_subsys_states) which already match the migration target; however, this is entirely unnecessary as migration taskset doesn't include tasks which are already in the target cgroup. Drop @skip_css from cgroup_taskset_for_each(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Daniel Borkmann <dborkman@redhat.com>
2014-02-13cpuset: use css_task_iter_start/next/end() instead of css_scan_tasks()Tejun Heo
Now that css_task_iter_start/next_end() supports blocking while iterating, there's no reason to use css_scan_tasks() which is more cumbersome to use and scheduled to be removed. Convert all css_scan_tasks() usages in cpuset to css_task_iter_start/next/end(). This simplifies the code by removing heap allocation and callbacks. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2014-02-13cgroup: implement cgroup_has_tasks() and unexport cgroup_task_count()Tejun Heo
cgroup_task_count() read-locks css_set_lock and walks all tasks to count them and then returns the result. The only thing all the users want is determining whether the cgroup is empty or not. This patch implements cgroup_has_tasks() which tests whether cgroup->cset_links is empty, replaces all cgroup_task_count() usages and unexports it. Note that the test isn't synchronized. This is the same as before. The test has always been racy. This will help planned css_set locking update. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
2014-02-12cgroup: remove cgroup->nameTejun Heo
cgroup->name handling became quite complicated over time involving dedicated struct cgroup_name for RCU protection. Now that cgroup is on kernfs, we can drop all of it and simply use kernfs_name/path() and friends. Replace cgroup->name and all related code with kernfs name/path constructs. * Reimplement cgroup_name() and cgroup_path() as thin wrappers on top of kernfs counterparts, which involves semantic changes. pr_cont_cgroup_name() and pr_cont_cgroup_path() added. * cgroup->name handling dropped from cgroup_rename(). * All users of cgroup_name/path() updated to the new semantics. Users which were formatting the string just to printk them are converted to use pr_cont_cgroup_name/path() instead, which simplifies things quite a bit. As cgroup_name() no longer requires RCU read lock around it, RCU lockings which were protecting only cgroup_name() are removed. v2: Comment above oom_info_lock updated as suggested by Michal. v3: dummy_top doesn't have a kn associated and pr_cont_cgroup_name/path() ended up calling the matching kernfs functions with NULL kn leading to oops. Test for NULL kn and print "/" if so. This issue was reported by Fengguang Wu. v4: Rebased on top of 0ab02ca8f887 ("cgroup: protect modifications to cgroup_idr with cgroup_mutex"). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
2014-02-08cgroup: clean up cgroup_subsys names and initializationTejun Heo
cgroup_subsys is a bit messier than it needs to be. * The name of a subsys can be different from its internal identifier defined in cgroup_subsys.h. Most subsystems use the matching name but three - cpu, memory and perf_event - use different ones. * cgroup_subsys_id enums are postfixed with _subsys_id and each cgroup_subsys is postfixed with _subsys. cgroup.h is widely included throughout various subsystems, it doesn't and shouldn't have claim on such generic names which don't have any qualifier indicating that they belong to cgroup. * cgroup_subsys->subsys_id should always equal the matching cgroup_subsys_id enum; however, we require each controller to initialize it and then BUG if they don't match, which is a bit silly. This patch cleans up cgroup_subsys names and initialization by doing the followings. * cgroup_subsys_id enums are now postfixed with _cgrp_id, and each cgroup_subsys with _cgrp_subsys. * With the above, renaming subsys identifiers to match the userland visible names doesn't cause any naming conflicts. All non-matching identifiers are renamed to match the official names. cpu_cgroup -> cpu mem_cgroup -> memory perf -> perf_event * controllers no longer need to initialize ->subsys_id and ->name. They're generated in cgroup core and set automatically during boot. * Redundant cgroup_subsys declarations removed. * While updating BUG_ON()s in cgroup_init_early(), convert them to WARN()s. BUGging that early during boot is stupid - the kernel can't print anything, even through serial console and the trap handler doesn't even link stack frame properly for back-tracing. This patch doesn't introduce any behavior changes. v2: Rebased on top of fe1217c4f3f7 ("net: net_cls: move cgroupfs classid handling into core"). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Ingo Molnar <mingo@redhat.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Thomas Graf <tgraf@suug.ch>
2013-12-05cgroup: replace cftype->read_seq_string() with cftype->seq_show()Tejun Heo
In preparation of conversion to kernfs, cgroup file handling is updated so that it can be easily mapped to kernfs. This patch replaces cftype->read_seq_string() with cftype->seq_show() which is not limited to single_open() operation and will map directcly to kernfs seq_file interface. The conversions are mechanical. As ->seq_show() doesn't have @css and @cft, the functions which make use of them are converted to use seq_css() and seq_cft() respectively. In several occassions, e.f. if it has seq_string in its name, the function name is updated to fit the new method better. This patch does not introduce any behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Neil Horman <nhorman@tuxdriver.com>
2013-12-05cpuset: convert away from cftype->read()Tejun Heo
In preparation of conversion to kernfs, cgroup file handling is being consolidated so that it can be easily mapped to the seq_file based interface of kernfs. All users of cftype->read() can be easily served, usually better, by seq_file and other methods. Rename cpuset_common_file_read() to cpuset_common_read_seq_string() and convert it to use read_seq_string() interface instead. This not only simplifies the code but also makes it more versatile. Before, the file couldn't output if the result is longer than PAGE_SIZE. After the conversion, seq_file automatically grows the buffer until the output can fit. This patch doesn't make any visible behavior changes except for being able to handle output larger than PAGE_SIZE. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-11-27cpuset: Fix memory allocator deadlockPeter Zijlstra
Juri hit the below lockdep report: [ 4.303391] ====================================================== [ 4.303392] [ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ] [ 4.303394] 3.12.0-dl-peterz+ #144 Not tainted [ 4.303395] ------------------------------------------------------ [ 4.303397] kworker/u4:3/689 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: [ 4.303399] (&p->mems_allowed_seq){+.+...}, at: [<ffffffff8114e63c>] new_slab+0x6c/0x290 [ 4.303417] [ 4.303417] and this task is already holding: [ 4.303418] (&(&q->__queue_lock)->rlock){..-...}, at: [<ffffffff812d2dfb>] blk_execute_rq_nowait+0x5b/0x100 [ 4.303431] which would create a new lock dependency: [ 4.303432] (&(&q->__queue_lock)->rlock){..-...} -> (&p->mems_allowed_seq){+.+...} [ 4.303436] [ 4.303898] the dependencies between the lock to be acquired and SOFTIRQ-irq-unsafe lock: [ 4.303918] -> (&p->mems_allowed_seq){+.+...} ops: 2762 { [ 4.303922] HARDIRQ-ON-W at: [ 4.303923] [<ffffffff8108ab9a>] __lock_acquire+0x65a/0x1ff0 [ 4.303926] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303929] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303931] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303933] SOFTIRQ-ON-W at: [ 4.303933] [<ffffffff8108abcc>] __lock_acquire+0x68c/0x1ff0 [ 4.303935] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303940] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303955] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303959] INITIAL USE at: [ 4.303960] [<ffffffff8108a884>] __lock_acquire+0x344/0x1ff0 [ 4.303963] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303966] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303969] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303972] } Which reports that we take mems_allowed_seq with interrupts enabled. A little digging found that this can only be from cpuset_change_task_nodemask(). This is an actual deadlock because an interrupt doing an allocation will hit get_mems_allowed()->...->__read_seqcount_begin(), which will spin forever waiting for the write side to complete. Cc: John Stultz <john.stultz@linaro.org> Cc: Mel Gorman <mgorman@suse.de> Reported-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Juri Lelli <juri.lelli@gmail.com> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-09-03Merge branch 'for-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on the cgroup front. Most changes aren't visible to userland at all at this point and are laying foundation for the planned unified hierarchy. - The biggest change is decoupling the lifetime management of css (cgroup_subsys_state) from that of cgroup's. Because controllers (cpu, memory, block and so on) will need to be dynamically enabled and disabled, css which is the association point between a cgroup and a controller may come and go dynamically across the lifetime of a cgroup. Till now, css's were created when the associated cgroup was created and stayed till the cgroup got destroyed. Assumptions around this tight coupling permeated through cgroup core and controllers. These assumptions are gradually removed, which consists bulk of patches, and css destruction path is completely decoupled from cgroup destruction path. Note that decoupling of creation path is relatively easy on top of these changes and the patchset is pending for the next window. - cgroup has its own event mechanism cgroup.event_control, which is only used by memcg. It is overly complex trying to achieve high flexibility whose benefits seem dubious at best. Going forward, new events will simply generate file modified event and the existing mechanism is being made specific to memcg. This pull request contains prepatory patches for such change. - Various fixes and cleanups" Fixed up conflict in kernel/cgroup.c as per Tejun. * 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (69 commits) cgroup: fix cgroup_css() invocation in css_from_id() cgroup: make cgroup_write_event_control() use css_from_dir() instead of __d_cgrp() cgroup: make cgroup_event hold onto cgroup_subsys_state instead of cgroup cgroup: implement CFTYPE_NO_PREFIX cgroup: make cgroup_css() take cgroup_subsys * instead and allow NULL subsys cgroup: rename cgroup_css_from_dir() to css_from_dir() and update its syntax cgroup: fix cgroup_write_event_control() cgroup: fix subsystem file accesses on the root cgroup cgroup: change cgroup_from_id() to css_from_id() cgroup: use css_get() in cgroup_create() to check CSS_ROOT cpuset: remove an unncessary forward declaration cgroup: RCU protect each cgroup_subsys_state release cgroup: move subsys file removal to kill_css() cgroup: factor out kill_css() cgroup: decouple cgroup_subsys_state destruction from cgroup destruction cgroup: replace cgroup->css_kill_cnt with ->nr_css cgroup: bounce cgroup_subsys_state ref kill confirmation to a work item cgroup: move cgroup->subsys[] assignment to online_css() cgroup: reorganize css init / exit paths cgroup: add __rcu modifier to cgroup->subsys[] ...
2013-08-21cpuset: fix a regression in validating config changeLi Zefan
It's not allowed to clear masks of a cpuset if there're tasks in it, but it's broken: # mkdir /cgroup/sub # echo 0 > /cgroup/sub/cpuset.cpus # echo 0 > /cgroup/sub/cpuset.mems # echo $$ > /cgroup/sub/tasks # echo > /cgroup/sub/cpuset.cpus (should fail) This bug was introduced by commit 88fa523bff295f1d60244a54833480b02f775152 ("cpuset: allow to move tasks to empty cpusets"). tj: Dropped temp bool variables and nestes the conditionals directly. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-13cpuset: remove an unncessary forward declarationLi Zefan
2013-08-13cpuset: fix the return value of cpuset_write_u64()Li Zefan
Writing to this file always returns -ENODEV: # echo 1 > cpuset.memory_pressure_enabled -bash: echo: write error: No such device Signed-off-by: Li Zefan <lizefan@huawei.com> Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-08cgroup: make css_for_each_descendant() and friends include the origin css in ↵Tejun Heo
the iteration Previously, all css descendant iterators didn't include the origin (root of subtree) css in the iteration. The reasons were maintaining consistency with css_for_each_child() and that at the time of introduction more use cases needed skipping the origin anyway; however, given that css_is_descendant() considers self to be a descendant, omitting the origin css has become more confusing and looking at the accumulated use cases rather clearly indicates that including origin would result in simpler code overall. While this is a change which can easily lead to subtle bugs, cgroup API including the iterators has recently gone through major restructuring and no out-of-tree changes will be applicable without adjustments making this a relatively acceptable opportunity for this type of change. The conversions are mostly straight-forward. If the iteration block had explicit origin handling before or after, it's moved inside the iteration. If not, if (pos == origin) continue; is added. Some conversions add extra reference get/put around origin handling by consolidating origin handling and the rest. While the extra ref operations aren't strictly necessary, this shouldn't cause any noticeable difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com>
2013-08-08cgroup: make cgroup_taskset deal with cgroup_subsys_state instead of cgroupTejun Heo
cgroup is in the process of converting to css (cgroup_subsys_state) from cgroup as the principal subsystem interface handle. This is mostly to prepare for the unified hierarchy support where css's will be created and destroyed dynamically but also helps cleaning up subsystem implementations as css is usually what they are interested in anyway. cgroup_taskset which is used by the subsystem attach methods is the last cgroup subsystem API which isn't using css as the handle. Update cgroup_taskset_cur_cgroup() to cgroup_taskset_cur_css() and cgroup_taskset_for_each() to take @skip_css instead of @skip_cgrp. The conversions are pretty mechanical. One exception is cpuset::cgroup_cs(), which lost its last user and got removed. This patch shouldn't introduce any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: make task iterators deal with cgroup_subsys_state instead of cgroupTejun Heo
cgroup is in the process of converting to css (cgroup_subsys_state) from cgroup as the principal subsystem interface handle. This is mostly to prepare for the unified hierarchy support where css's will be created and destroyed dynamically but also helps cleaning up subsystem implementations as css is usually what they are interested in anyway. This patch converts task iterators to deal with css instead of cgroup. Note that under unified hierarchy, different sets of tasks will be considered belonging to a given cgroup depending on the subsystem in question and making the iterators deal with css instead cgroup provides them with enough information about the iteration. While at it, fix several function comment formats in cpuset.c. This patch doesn't introduce any behavior differences. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com>
2013-08-08cgroup: remove struct cgroup_scannerTejun Heo
cgroup_scan_tasks() takes a pointer to struct cgroup_scanner as its sole argument and the only function of that struct is packing the arguments of the function call which are consisted of five fields. It's not too unusual to pack parameters into a struct when the number of arguments gets excessive or the whole set needs to be passed around a lot, but neither holds here making it just weird. Drop struct cgroup_scanner and pass the params directly to cgroup_scan_tasks(). Note that struct cpuset_change_nodemask_arg was added to cpuset.c to pass both ->cs and ->newmems pointer to cpuset_change_nodemask() using single data pointer. This doesn't make any functional differences. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-08cgroup: make hierarchy iterators deal with cgroup_subsys_state instead of cgroupTejun Heo
cgroup is currently in the process of transitioning to using css (cgroup_subsys_state) as the primary handle instead of cgroup in subsystem API. For hierarchy iterators, this is beneficial because * In most cases, css is the only thing subsystems care about anyway. * On the planned unified hierarchy, iterations for different subsystems will need to skip over different subtrees of the hierarchy depending on which subsystems are enabled on each cgroup. Passing around css makes it unnecessary to explicitly specify the subsystem in question as css is intersection between cgroup and subsystem * For the planned unified hierarchy, css's would need to be created and destroyed dynamically independent from cgroup hierarchy. Having cgroup core manage css iteration makes enforcing deref rules a lot easier. Most subsystem conversions are straight-forward. Noteworthy changes are * blkio: cgroup_to_blkcg() is no longer used. Removed. * freezer: cgroup_freezer() is no longer used. Removed. * devices: cgroup_to_devcgroup() is no longer used. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk>
