path: root/kernel/compat.c
2006-06-25[PATCH] N32 sigset and __COMPAT_ENDIAN_SWAP__akpm@osdl.org
I'm testing glibc on MIPS64, little-endian, N32, O32 and N64 multilibs. Among the NPTL test failures seen are some arising from sigsuspend problems for N32: it blocks the wrong signals, so SIGCANCEL (SIGRTMIN) is blocked despite glibc's carefully excluding it from sets of signals to block. Specifically, testing suggests it blocks signal N^32 instead of signal N, so (in the example tested) blocking SIGUSR1 (17) blocks signal 49 instead. glibc's sigset_t uses an array of unsigned long, as does the kernel. In both cases, signal N+1 is represented as (1UL << (N % (8 * sizeof (unsigned long)))) in word number (N / (8 * sizeof (unsigned long))). Thus the N32 glibc uses an array of 32-bit words and the N64 kernel uses an array of 64-bit words. For little-endian, the layout is the same, with signals 1-32 in the first 4 bytes, signals 33-64 in the second, etc.; for big-endian, userspace has that layout while in the kernel each 8 bytes have the two halves swapped from the userspace layout. The N32 sigsuspend syscall uses sigset_from_compat to convert the userspace sigset to kernel format. If __COMPAT_ENDIAN_SWAP__ is *not* set, this uses logic of the form set->sig[0] = compat->sig[0] | (((long)compat->sig[1]) << 32 ) to convert the userspace sigset to a kernel one. This looks correct to me for both big and little endian, given that in userspace compat->sig[1] will represent signals 33-64, and so will the high 32 bits of set->sig[0] in the kernel. If however __COMPAT_ENDIAN_SWAP__ *is* set, as it is for __MIPSEL__, it uses set->sig[0] = compat->sig[1] | (((long)compat->sig[0]) << 32 ); which seems incorrect for both big and little endian, and would explain the observed symptoms. This code is the only use of __COMPAT_ENDIAN_SWAP__, so if incorrect then that macro serves no purpose, in which case something like the following patch would seem appropriate to remove it. Signed-off-by: Joseph Myers <joseph@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] move_pages: fix 32 -> 64 bit compat functionChristoph Lameter
The definition of the third parameter is a pointer to an array of virtual addresses which give us some trouble. The existing code calculated the wrong address in the array since I used void to avoid having to specify a type. I now use the correct type "compat_uptr_t __user *" in the definition of the function in kernel/compat.c. However, I used __u32 in syscalls.h. Would have to include compat.h there in order to provide the same definition which would generate an ugly include situation. On both ia64 and x86_64 compat_uptr_t is u32. So this works although parameter declarations differ. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] sys_move_pages: 32bit support (i386, x86_64)Christoph Lameter
sys_move_pages() support for 32bit (i386 plus x86_64 compat layer) Add support for move_pages() on i386 and also add the compat functions necessary to run 32 bit binaries on x86_64. Add compat_sys_move_pages to the x86_64 32bit binary layer. Note that it is not up to date so I added the missing pieces. Not sure if this is done the right way. [akpm@osdl.org: compile fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: compatIngo Molnar
32-bit syscall compatibility support. (This patch also moves all futex related compat functionality into kernel/futex_compat.c.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] consolidate sys32/compat_adjtimexStephen Rothwell
Create compat_sys_adjtimex and use it an all appropriate places. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-18[PATCH] Generic sys_rt_sigsuspend()David Woodhouse
The TIF_RESTORE_SIGMASK flag allows us to have a generic implementation of sys_rt_sigsuspend() instead of duplicating it for each architecture. This provides such an implementation and makes arch/powerpc use it. It also tidies up the ppc32 sys_sigsuspend() to use TIF_RESTORE_SIGMASK. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] common compat_sys_timer_createChristoph Hellwig
The comment in compat.c is wrong, every architecture provides a get_compat_sigevent() for the IPC compat code already. This basically moves the x86_64 version to common code and removes all the others. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] kernel: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix get_compat_sigevent()David S. Miller
I have no idea how a bug like this lasted so long. Anyways, obvious memset()'ing of incorrect pointer. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
