upstream commit: 5c02b575780d0d785815a1e7b79a98edddee895a
This is a slight change in the namespace cgroup subsystem api.
The change is that previously when cgroup_clone() was called (currently
only from the unshare path in ns_proxy cgroup, you'd get a new group named
"node_$pid" whereas now you'll get a group named after just your pid.)
The only users who would notice it are those who are using the ns_proxy
cgroup subsystem to auto-create cgroups when namespaces are unshared -
something of an experimental feature, which I think really needs more
complete container/namespace support in order to be useful. I suspect the
only users are Cedric and Serge, or maybe a few others on
containers@lists.linux-foundation.org. And in fact it would only be
noticed by the users who make the assumption about how the name is
generated, rather than getting it from the /proc/<pid>/cgroups file for
the process in question.
Whether the change is actually needed or not I'm fairly agnostic on, but I
guess it is more elegant to just use the pid as the new group name rather
than adding a fairly arbitrary "node_" prefix on the front.
[menage@google.com: provided changelog]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: "Paul Menage" <menage@google.com>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: <stable@kernel.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
commit: 0e04388f0189fa1f6812a8e1cb6172136eada87e
When I ran a test program to fork mass processes and at the same time
'cat /cgroup/tasks', I got the following oops:
kernel BUG at lib/list_debug.c:72!
invalid opcode: 0000 [#1] SMP
Pid: 4178, comm: a.out Not tainted (2.6.25-rc9 #72)
Call Trace:
[<c044a5f9>] ? cgroup_exit+0x55/0x94
[<c0427acf>] ? do_exit+0x217/0x5ba
[<c0427ed7>] ? do_group_exit+0.65/0x7c
[<c0427efd>] ? sys_exit_group+0xf/0x11
[<c0404842>] ? syscall_call+0x7/0xb
[<c05e0000>] ? init_cyrix+0x2fa/0x479
EIP: [<c04df671>] list_del+0x35/0x53 SS:ESP 0068:ebc7df4
---[ end trace caffb7332252612b ]---
Fixing recursive fault but reboot is needed!
After digging into the code and debugging, I finlly found out a race
situation:
do_exit()
->cgroup_exit()
->if (!list_empty(&tsk->cg_list))
list_del(&tsk->cg_list);
cgroup_iter_start()
->cgroup_enable_task_cg_list()
->list_add(&tsk->cg_list, ..);
In this case the list won't be deleted though the process has exited.
We got two bug reports in the past, which seem to be the same bug as
this one:
http://lkml.org/lkml/2008/3/5/332
http://lkml.org/lkml/2007/10/17/224
Actually sometimes I got oops on list_del, sometimes oops on list_add.
And I can change my test program a bit to trigger other oops.
The patch has been tested both on x86_32 and x86_64.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Extend the /proc/<pid>/cgroup file to include the appropriate hierarchy ID on
each line.
Currently this ID isn't really needed since a hierarchy can be completely
identified by the set of subsystems bound to it, but this is likely to change
in the near future in order to support stateless subsystems and
merging/rebinding of subsystems. Getting this change into 2.6.25 reduces the
need for an API change later.
Signed-off-by: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
The effects of cgroup_disable=foo are:
- foo isn't auto-mounted if you mount all cgroups in a single hierarchy
- foo isn't visible as an individually mountable subsystem
As a result there will only ever be one call to foo->create(), at init time;
all processes will stay in this group, and the group will never be mounted on
a visible hierarchy. Any additional effects (e.g. not allocating metadata)
are up to the foo subsystem.
This doesn't handle early_init subsystems (their "disabled" bit isn't set be,
but it could easily be extended to do so if any of the early_init systems
wanted it - I think it would just involve some nastier parameter processing
since it would occur before the command-line argument parser had been run.
Hugh said:
Ballpark figures, I'm trying to get this question out rather than
processing the exact numbers: CONFIG_CGROUP_MEM_RES_CTLR adds 15% overhead
to the affected paths, booting with cgroup_disable=memory cuts that back to
1% overhead (due to slightly bigger struct page).
I'm no expert on distros, they may have no interest whatever in
CONFIG_CGROUP_MEM_RES_CTLR=y; and the rest of us can easily build with or
without it, or apply the cgroup_disable=memory patches.
Unix bench's execl test result on x86_64 was
== just after boot without mounting any cgroup fs.==
mem_cgorup=off : Execl Throughput 43.0 3150.1 732.6
mem_cgroup=on : Execl Throughput 43.0 2932.6 682.0
[lizf@cn.fujitsu.com: fix boot option parsing]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Sudhir Kumar <skumar@linux.vnet.ibm.com>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
The documentation says the default value of notify_on_release of a child
cgroup is inherited from its parent, which is reasonable, but the
implementation just sets the flag disabled.
The list head res->tasks gets initialized twice in find_css_set().
Cgroup uses unsigned long for subsys bitops, not unsigned long long.
opts.release_agent is not kfree()ed in all necessary places.
fix:
- comments about need_forkexit_callback
- comments about release agent
- typo and comment style, etc.
There's one place that works with task pids - its the "tasks" file in cgroups.
The read/write handlers assume, that the pid values go to/come from the user
space and thus it is a virtual pid, i.e. the pid as it is seen from inside a
namespace.
Tune the code accordingly.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
This patch corrects a situation that occurs when one disables all the cpus in
a cpuset.
Currently, the disabled (cpu-less) cpuset inherits the cpus of its parent,
which is incorrect because it may then overlap its cpu-exclusive sibling.
Tasks of an empty cpuset should be moved to the cpuset which is the parent of
their current cpuset. Or if the parent cpuset has no cpus, to its parent,
etc.
And the empty cpuset should be released (if it is flagged notify_on_release).
Depends on the cgroup_scan_tasks() function (proposed by David Rientjes) to
iterate through all tasks in the cpu-less cpuset. We are deliberately
avoiding a walk of the tasklist.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: Paul Jackson <pj@sgi.com>
Provide cgroup_scan_tasks(), which iterates through every task in a cgroup,
calling a test function and a process function for each. And call the process
function without holding the css_set_lock lock.
The idea is David Rientjes', predicting that such a function will make it much
easier in the future to extend things that require access to each task in a
cgroup without holding the lock,
[akpm@linux-foundation.org: cleanup]
Acked-by: David Rientjes <rientjes@google.com>
Add a handler "pre_destroy" to cgroup_subsys. It is called before
cgroup_rmdir() checks all subsys's refcnt.
I think this is useful for subsys which have some extra refs even if there
are no tasks in cgroup. By adding pre_destroy(), the kernel keeps the rule
"destroy() against subsystem is called only when refcnt=0." and allows css
ref to be used by other objects than tasks.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Pavel Emelianov <xemul@openvz.org>
Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
cgroup_is_releasable() and notify_on_release() should be static,
not global inline.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Move the calls to the cgroup subsystem destroy() methods from
cgroup_rmdir() to cgroup_diput(). This allows control file reads and
writes to access their subsystem state without having to be concerned with
locking against cgroup destruction - the control file dentry will keep the
cgroup and its subsystem state objects alive until the file is closed.
The documentation is updated to reflect the changed semantics of destroy();
additionally the locking comments for destroy() and some other methods were
clarified and decrustified.
Simplify the space stripping code in cgroup file write.
[akpm@linux-foundation.org: s/BUG_ON/BUILD_BUG_ON/]
Signed-off-by: Paul Jackson <pj@sgi.com>
Coding style fix - one line conditionals don't get braces.
This patch removes dead code spotted by the Coverity checker
(look at the "(nbytes >= PATH_MAX)" check).
When I boot with the 'quiet' parameter, I see on the screen:
[ 0.000000] Initializing cgroup subsys cpuset
[ 39.036026] Initializing cgroup subsys cpuacct
[ 39.036080] Initializing cgroup subsys debug
[ 39.036118] Initializing cgroup subsys ns
This patch lowers the priority of those messages, adds a "cgroup: " prefix
to another couple of printks and kills the useless reference to the source
file.
Signed-off-by: Diego Calleja <diegocg@gmail.com>
Replace "cont" with "cgrp" and other misc renaming
This patch finishes some of the names that got missed in the great
"task containers" -> "control groups" rename. Primarily it renames
the local variable "cont" to "cgrp" in a number of places, and renames
the CONT_* enum members to CGRP_*.
This patch is not intended to have any effect on the generated code;
the output of "objdump -d kernel/cgroup.o" is unchanged.
Acked-by: Paul Jackson <pj@sgi.com>
There are two places that do so - the cgroups subsystem and the autofs
code.
Cc: Ian Kent <raven@themaw.net>
This patch is inspired by the discussion at
http://lkml.org/lkml/2007/4/11/187 and implements per cgroup statistics
as suggested by Andrew Morton in http://lkml.org/lkml/2007/4/11/263. The
patch is on top of 2.6.21-mm1 with Paul's cgroups v9 patches (forward
ported)
This patch implements per cgroup statistics infrastructure and re-uses
code from the taskstats interface. A new set of cgroup operations are
registered with commands and attributes. It should be very easy to
*extend* per cgroup statistics, by adding members to the cgroupstats
structure.
The current model for cgroupstats is a pull, a push model (to post
statistics on interesting events), should be very easy to add. Currently
user space requests for statistics by passing the cgroup file
descriptor. Statistics about the state of all the tasks in the cgroup
is returned to user space.
TODO's/NOTE:
This patch provides an infrastructure for implementing cgroup statistics.
Based on the needs of each controller, we can incrementally add more statistics,
event based support for notification of statistics, accumulation of taskstats
into cgroup statistics in the future.
Sample output
# ./cgroupstats -C /cgroup/a
sleeping 2, blocked 0, running 1, stopped 0, uninterruptible 0
sleeping 154, blocked 0, running 0, stopped 0, uninterruptible 0
If the approach looks good, I'll enhance and post the user space utility for
the same
Feedback, comments, test results are always welcome!
[akpm@linux-foundation.org: build fix]
Cc: Jay Lan <jlan@engr.sgi.com>
Add the following files to the cgroup filesystem:
notify_on_release - configures/reports whether the cgroup subsystem should
attempt to run a release script when this cgroup becomes unused
release_agent - configures/reports the release agent to be used for this
hierarchy (top level in each hierarchy only)
releasable - reports whether this cgroup would have been auto-released if
notify_on_release was true and a release agent was configured (mainly useful
for debugging)
To avoid locking issues, invoking the userspace release agent is done via a
workqueue task; cgroups that need to have their release agents invoked by
the workqueue task are linked on to a list.
[pj@sgi.com: Need to include kmod.h]
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Replace the struct css_set embedded in task_struct with a pointer; all tasks
that have the same set of memberships across all hierarchies will share a
css_set object, and will be linked via their css_sets field to the "tasks"
list_head in the css_set.
Assuming that many tasks share the same cgroup assignments, this reduces
overall space usage and keeps the size of the task_struct down (three pointers
added to task_struct compared to a non-cgroups kernel, no matter how many
subsystems are registered).
[akpm@linux-foundation.org: fix a printk]
Add:
/proc/cgroups - general system info
/proc/*/cgroup - per-task cgroup membership info
[a.p.zijlstra@chello.nl: cgroups: bdi init hooks]
Add support for cgroup_clone(), a way to create new cgroups intended to
be used for systems such as namespace unsharing. A new subsystem callback,
post_clone(), is added to allow subsystems to automatically configure cloned
cgroups.
This adds the necessary hooks to the fork() and exit() paths to ensure
that new children inherit their parent's cgroup assignments, and that
exiting processes release reference counts on their cgroups.
Add write_uint() helper method for cgroup subsystems
This helper is analagous to the read_uint() helper method for
reporting u64 values to userspace. It's designed to reduce the amount
of boilerplate requierd for creating new cgroup subsystems.
Add the per-directory "tasks" file for cgroupfs mounts; this allows the
user to determine which tasks are members of a cgroup by reading a
cgroup's "tasks", and to move a task into a cgroup by writing its pid to
its "tasks".
Generic Process Control Groups
There have recently been various proposals floating around for
resource management/accounting and other task grouping subsystems in
the kernel, including ResGroups, User BeanCounters, NSProxy
cgroups, and others. These all need the basic abstraction of being
able to group together multiple processes in an aggregate, in order to
track/limit the resources permitted to those processes, or control
other behaviour of the processes, and all implement this grouping in
different ways.
This patchset provides a framework for tracking and grouping processes
into arbitrary "cgroups" and assigning arbitrary state to those
groupings, in order to control the behaviour of the cgroup as an
aggregate.
The intention is that the various resource management and
virtualization/cgroup efforts can also become task cgroup
clients, with the result that:
- the userspace APIs are (somewhat) normalised
- it's easier to test e.g. the ResGroups CPU controller in
conjunction with the BeanCounters memory controller, or use either of
them as the resource-control portion of a virtual server system.
- the additional kernel footprint of any of the competing resource
management systems is substantially reduced, since it doesn't need
to provide process grouping/containment, hence improving their
chances of getting into the kernel
This patch:
Add the main task cgroups framework - the cgroup filesystem, and the
basic structures for tracking membership and associating subsystem state
objects to tasks.
