commit d3aea84a4ace5ff9ce7fb7714cee07bebef681c2 upstream.
...to make it clear what the intent behind each record's operation was.
In many cases you can infer this, based on the context of the syscall
and the result. In other cases it's not so obvious. For instance, in
the case where you have a file being renamed over another, you'll have
two different records with the same filename but different inode info.
By logging this information we can clearly tell which one was created
and which was deleted.
This fixes what was broken in commit bfcec708.
Commit 79f6530c should also be backported to stable v3.7+.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
commit 64fbff9ae0a0a843365d922e0057fc785f23f0e3 upstream.
We leak 4 bytes of kernel stack in response to an AUDIT_GET request as
we miss to initialize the mask member of status_set. Fix that.
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4d8fe7376a12bf4524783dd95cbc00f1fece6232 upstream.
Using the nlmsg_len member of the netlink header to test if the message
is valid is wrong as it includes the size of the netlink header itself.
Thereby allowing to send short netlink messages that pass those checks.
Use nlmsg_len() instead to test for the right message length. The result
of nlmsg_len() is guaranteed to be non-negative as the netlink message
already passed the checks of nlmsg_ok().
Also switch to min_t() to please checkpatch.pl.
commit 0868a5e150bc4c47e7a003367cd755811eb41e0b upstream.
When the audit=1 kernel parameter is absent and auditd is not running,
AUDIT_USER_AVC messages are being silently discarded.
AUDIT_USER_AVC messages should be sent to userspace using printk(), as
mentioned in the commit message of 4a4cd633 ("AUDIT: Optimise the
audit-disabled case for discarding user messages").
When audit_enabled is 0, audit_receive_msg() discards all user messages
except for AUDIT_USER_AVC messages. However, audit_log_common_recv_msg()
refuses to allocate an audit_buffer if audit_enabled is 0. The fix is to
special case AUDIT_USER_AVC messages in both functions.
It looks like commit 50397bd1 ("[AUDIT] clean up audit_receive_msg()")
introduced this bug.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Cc: linux-audit@redhat.com
After commit 829199197a43 ("kernel/audit.c: avoid negative sleep
durations") audit emitters will block forever if userspace daemon cannot
handle backlog.
After the timeout the waiting loop turns into busy loop and runs until
daemon dies or returns back to work. This is a minimal patch for that
bug.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Richard Guy Briggs <rgb@redhat.com>
Cc: Chuck Anderson <chuck.anderson@oracle.com>
Cc: Dan Duval <dan.duval@oracle.com>
Cc: Dave Kleikamp <dave.kleikamp@oracle.com>
audit_log_start() does wait_for_auditd() in a loop until
audit_backlog_wait_time passes or audit_skb_queue has a room.
If signal_pending() is true this becomes a busy-wait loop, schedule() in
TASK_INTERRUPTIBLE won't block.
Thanks to Guy for fully investigating and explaining the problem.
(akpm: that'll cause the system to lock up on a non-preemptible
uniprocessor kernel)
(Guy: "Our customer was in fact running a uniprocessor machine, and they
reported a system hang.")
Reported-by: Guy Streeter <streeter@redhat.com>
Cc: <stable@vger.kernel.org>
Pull audit changes from Eric Paris:
"Al used to send pull requests every couple of years but he told me to
just start pushing them to you directly.
Our touching outside of core audit code is pretty straight forward. A
couple of interface changes which hit net/. A simple argument bug
calling audit functions in namei.c and the removal of some assembly
branch prediction code on ppc"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: fix message spacing printing auid
Revert "audit: move kaudit thread start from auditd registration to kaudit init"
audit: vfs: fix audit_inode call in O_CREAT case of do_last
audit: Make testing for a valid loginuid explicit.
audit: fix event coverage of AUDIT_ANOM_LINK
audit: use spin_lock in audit_receive_msg to process tty logging
audit: do not needlessly take a lock in tty_audit_exit
audit: do not needlessly take a spinlock in copy_signal
audit: add an option to control logging of passwords with pam_tty_audit
audit: use spin_lock_irqsave/restore in audit tty code
helper for some session id stuff
audit: use a consistent audit helper to log lsm information
audit: push loginuid and sessionid processing down
audit: stop pushing loginid, uid, sessionid as arguments
audit: remove the old depricated kernel interface
audit: make validity checking generic
audit: allow checking the type of audit message in the user filter
audit: fix build break when AUDIT_DEBUG == 2
audit: remove duplicate export of audit_enabled
Audit: do not print error when LSMs disabled
The helper function didn't include a leading space, so it was jammed
against the previous text in the audit record.
This reverts commit 6ff5e45985c2fcb97947818f66d1eeaf9d6600b2.
kernel/audit.c
This patch was starting a kthread for all the time. Since the follow on
patches that required it didn't get finished in 3.10 time, we shouldn't
ship this change in 3.10.
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
The userspace audit tools didn't like the existing formatting of the
AUDIT_ANOM_LINK event. It needed to be expanded to emit an AUDIT_PATH
event as well, so this implements the change. The bulk of the patch is
moving code out of auditsc.c into audit.c and audit.h for general use.
It expands audit_log_name to include an optional "struct path" argument
for the simple case of just needing to report a pathname. This also
makes
audit_log_task_info available when syscall auditing is not enabled,
since
it is needed in either case for process details.
Reported-by: Steve Grubb <sgrubb@redhat.com>
This function is called when we receive a netlink message from
userspace. We don't need to worry about it coming from irq context or
irqs making it re-entrant.
Most commands are entered one line at a time and processed as complete lines
in non-canonical mode. Commands that interactively require a password, enter
canonical mode to do this while shutting off echo. This pair of features
(icanon and !echo) can be used to avoid logging passwords by audit while still
logging the rest of the command.
Adding a member (log_passwd) to the struct audit_tty_status passed in by
pam_tty_audit allows control of canonical mode without echo per task.
Some of the callers of the audit tty function use spin_lock_irqsave/restore.
We were using the forced always enable version, which seems really bad.
Since I don't know every one of these code paths well enough, it makes
sense to just switch everything to the safe version. Maybe it's a
little overzealous, but it's a lot better than an unlucky deadlock when
we return to a caller with irq enabled and they expect it to be
disabled.
We have a number of places we were reimplementing the same code to write
out lsm labels. Just do it one darn place.
Since we are always current, we can push a lot of this stuff to the
bottom and get rid of useless interfaces and arguments.
We always use current. Stop pulling this when the skb comes in and
pushing it around as arguments. Just get it at the end when you need
it.
We used to have an inflexible mechanism to add audit rules to the
kernel. It hasn't been used in a long time. Get rid of that stuff.
We only need to check if kauditd is valid after we start it, if kauditd
is invalid, we will set kauditd_task to NULL. So next time, we will
start kauditd again.
It means if kauditd_task is not NULL,it must be valid.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
When userspace sends messages to the audit system it includes a type.
We want to be able to filter messages based on that type without have to
do the all or nothing option currently available on the
AUDIT_FILTER_TYPE filter list. Instead we should be able to use the
AUDIT_FILTER_USER filter list and just use the message type as one part
of the matching decision.
Userspace parsing libraries assume that msg= is only for userspace audit
records, not for user tty records. Make this consistent with the other
tty records.
The kauditd_thread() task was started only after the auditd userspace daemon
registers itself with kaudit. This was fine when only auditd consumed messages
from the kaudit netlink unicast socket. With the addition of a multicast group
to that socket it is more convenient to have the thread start on init of the
kaudit kernel subsystem.
Signed-off-by: Richard Guy Briggs <rbriggs@redhat.com>
The wait queue control code in kauditd_thread() was nested deeper than
necessary. The function has been flattened for better legibility.
The hold queue flush code is an autonomous chunk of code that can be
refactored, removed from kauditd_thread() into flush_hold_queue() and
flattenned for better legibility.
Commit 941912133025926307c7a65b203fa38403b1063a replaced the macros
NLMSG_NEXT with calls to nlmsg_next which produces this warning:
kernel/audit.c: In function ‘audit_receive_skb’:
kernel/audit.c:928:3: warning: passing argument 2 of ‘nlmsg_next’ makes pointer from integer without a cast
In file included from include/net/rtnetlink.h:5:0,
from include/net/neighbour.h:28,
from include/net/dst.h:17,
from include/net/sock.h:68,
from kernel/audit.c:55:
include/net/netlink.h:359:1: note: expected ‘int *’ but argument is of type ‘int’
Fix this by sending the intended pointer.
Signed-off-by: Alexandru Copot <alex.mihai.c@gmail.com>
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
audit_log_start() performs the same jiffies comparison in two places.
If sufficient time has elapsed between the two comparisons, the second
one produces a negative sleep duration:
schedule_timeout: wrong timeout value fffffffffffffff0
Pid: 6606, comm: trinity-child1 Not tainted 3.8.0-rc1+ #43
Call Trace:
schedule_timeout+0x305/0x340
audit_log_start+0x311/0x470
audit_log_exit+0x4b/0xfb0
__audit_syscall_exit+0x25f/0x2c0
sysret_audit+0x17/0x21
Fix it by performing the comparison a single time.
Reported-by: Dave Jones <davej@redhat.com>
It's possible for audit_log_start() to return NULL. Handle it in the
various callers.
Cc: Jeff Layton <jlayton@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Julien Tinnes <jln@google.com>
Cc: Will Drewry <wad@google.com>
Cc: Steve Grubb <sgrubb@redhat.com>
audit_log_start() may return NULL, this is unchecked by the caller in
audit_log_link_denied() and could cause a NULL ptr deref.
Introduced by commit a51d9eaa ("fs: add link restriction audit reporting").
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
- Explicitly format uids gids in audit messges in the initial user
namespace. This is safe because auditd is restrected to be in
the initial user namespace.
- Convert audit_sig_uid into a kuid_t.
- Enable building the audit code and user namespaces at the same time.
The net result is that the audit subsystem now uses kuid_t and kgid_t whenever
possible making it almost impossible to confuse a raw uid_t with a kuid_t
preventing bugs.
Always store audit loginuids in type kuid_t.
Print loginuids by converting them into uids in the appropriate user
namespace, and then printing the resulting uid.
Modify audit_get_loginuid to return a kuid_t.
Modify audit_set_loginuid to take a kuid_t.
Modify /proc/<pid>/loginuid on read to convert the loginuid into the
user namespace of the opener of the file.
Modify /proc/<pid>/loginud on write to convert the loginuid
rom the user namespace of the opener of the file.
Cc: Paul Moore <paul@paul-moore.com> ?
The only place we use the uid and the pid that we calculate in
audit_receive_msg is in audit_log_common_recv_msg so move the
calculation of these values into the audit_log_common_recv_msg.
Simplify the calcuation of the current pid and uid by
reading them from current instead of reading them from
NETLINK_CREDS.
For user generated audit messages set the portid field in the netlink
header to the netlink port where the user generated audit message came
from. Reporting the process id in a port id field was just nonsense.
Use current instead of looking up the current up the current task by
process identifier. Netlink requests are processed in trhe context of
the sending task so this is safe.
Now that netlink messages are processed in the context of the sender
tty_audit_push_task can be called directly and audit_prepare_user_tty
which only added looking up the task of the tty by process id is
not needed.
Get caller process uid and gid and pid values from the current task
instead of the NETLINK_CB. This is simpler than passing NETLINK_CREDS
from from audit_receive_msg to audit_filter_user_rules and avoid the
chance of being hit by the occassional bugs in netlink uid/gid
credential passing. This is a safe changes because all netlink
requests are processed in the task of the sending process.
This allows the code to safely make the assumption that all of the
uids gids and pids that need to be send in audit messages are in the
initial namespaces.
If someone cares we may lift this restriction someday but start with
limiting access so at least the code is always correct.
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
This patch defines netlink_kernel_create as a wrapper function of
__netlink_kernel_create to hide the struct module *me parameter
(which seems to be THIS_MODULE in all existing netlink subsystems).
Suggested by David S. Miller.
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
Adds audit messages for unexpected link restriction violations so that
system owners will have some sort of potentially actionable information
about misbehaving processes.
This patch adds the following structure:
struct netlink_kernel_cfg {
unsigned int groups;
void (*input)(struct sk_buff *skb);
struct mutex *cb_mutex;
That can be passed to netlink_kernel_create to set optional configurations
for netlink kernel sockets.
I've populated this structure by looking for NULL and zero parameters at the
existing code. The remaining parameters that always need to be set are still
left in the original interface.
That includes optional parameters for the netlink socket creation. This allows
easy extensibility of this interface in the future.
This patch also adapts all callers to use this new interface.
And use nlmsg_data() while we're here too.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits)
audit: no leading space in audit_log_d_path prefix
audit: treat s_id as an untrusted string
audit: fix signedness bug in audit_log_execve_info()
audit: comparison on interprocess fields
audit: implement all object interfield comparisons
audit: allow interfield comparison between gid and ogid
audit: complex interfield comparison helper
audit: allow interfield comparison in audit rules
Kernel: Audit Support For The ARM Platform
audit: do not call audit_getname on error
audit: only allow tasks to set their loginuid if it is -1
audit: remove task argument to audit_set_loginuid
audit: allow audit matching on inode gid
audit: allow matching on obj_uid
audit: remove audit_finish_fork as it can't be called
audit: reject entry,always rules
audit: inline audit_free to simplify the look of generic code
audit: drop audit_set_macxattr as it doesn't do anything
audit: inline checks for not needing to collect aux records
audit: drop some potentially inadvisable likely notations
Use evil merge to fix up grammar mistakes in Kconfig file.
Bad speling and horrible grammar (and copious swearing) is to be
expected, but let's keep it to commit messages and comments, rather than
expose it to users in config help texts or printouts.
audit_log_d_path() injects an additional space before the prefix,
which serves no purpose and doesn't mix well with other audit_log*()
functions that do not sneak extra characters into the log.
userspace audit messages look like so:
type=USER msg=audit(1271170549.415:24710): user pid=14722 uid=0 auid=500 ses=1 subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 msg=''
That third field just says 'user'. That's useless and doesn't follow the
key=value pair we are trying to enforce. We already know it came from the
user based on the record type. Kill that word. Die.
