path: root/kernel/Makefile
2010-03-06elf coredump: replace ELF_CORE_EXTRA_* macros by functionsDaisuke HATAYAMA
elf_core_dump() and elf_fdpic_core_dump() use #ifdef and the corresponding macro for hiding _multiline_ logics in functions. This patch removes #ifdef and replaces ELF_CORE_EXTRA_* by corresponding functions. For architectures not implemeonting ELF_CORE_EXTRA_*, we use weak functions in order to reduce a range of modification. This cleanup is for my next patches, but I think this cleanup itself is worth doing regardless of my firnal purpose. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Merge branch 'x86-bootmem-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-bootmem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) early_res: Need to save the allocation name in drop_range_partial() sparsemem: Fix compilation on PowerPC early_res: Add free_early_partial() x86: Fix non-bootmem compilation on PowerPC core: Move early_res from arch/x86 to kernel/ x86: Add find_fw_memmap_area Move round_up/down to kernel.h x86: Make 32bit support NO_BOOTMEM early_res: Enhance check_and_double_early_res x86: Move back find_e820_area to e820.c x86: Add find_early_area_size x86: Separate early_res related code from e820.c x86: Move bios page reserve early to head32/64.c sparsemem: Put mem map for one node together. sparsemem: Put usemap for one node together x86: Make 64 bit use early_res instead of bootmem before slab x86: Only call dma32_reserve_bootmem 64bit !CONFIG_NUMA x86: Make early_node_mem get mem > 4 GB if possible x86: Dynamically increase early_res array size x86: Introduce max_early_res and early_res_count ...
2010-02-16core: Move early_res from arch/x86 to kernel/Yinghai Lu
This makes the range reservation feature available to other architectures. -v2: add get_max_mapped, max_pfn_mapped only defined in x86... to fix PPC compiling -v3: according to hpa, add CONFIG_HAVE_EARLY_RES -v4: fix typo about EARLY_RES in config Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B7B5723.4070009@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-10x86: Move range related operation to one fileYinghai Lu
We have almost the same code for mtrr cleanup and amd_bus checkup, and this code will also be used in replacing bootmem with early_res, so try to move them together and reuse it from different parts. Also rename update_range to subtract_range as that is what the function is actually doing. -v2: update comments as Christoph requested Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-4-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-06padata: Generic parallelization/serialization interfaceSteffen Klassert
This patch introduces an interface to process data objects in parallel. The parallelized objects return after serialization in the same order as they were before the parallelization. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-08Merge branch 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (84 commits) KVM: VMX: Fix comparison of guest efer with stale host value KVM: s390: Fix prefix register checking in arch/s390/kvm/sigp.c KVM: Drop user return notifier when disabling virtualization on a cpu KVM: VMX: Disable unrestricted guest when EPT disabled KVM: x86 emulator: limit instructions to 15 bytes KVM: s390: Make psw available on all exits, not just a subset KVM: x86: Add KVM_GET/SET_VCPU_EVENTS KVM: VMX: Report unexpected simultaneous exceptions as internal errors KVM: Allow internal errors reported to userspace to carry extra data KVM: Reorder IOCTLs in main kvm.h KVM: x86: Polish exception injection via KVM_SET_GUEST_DEBUG KVM: only clear irq_source_id if irqchip is present KVM: x86: disallow KVM_{SET,GET}_LAPIC without allocated in-kernel lapic KVM: x86: disallow multiple KVM_CREATE_IRQCHIP KVM: VMX: Remove vmx->msr_offset_efer KVM: MMU: update invlpg handler comment KVM: VMX: move CR3/PDPTR update to vmx_set_cr3 KVM: remove duplicated task_switch check KVM: powerpc: Fix BUILD_BUG_ON condition KVM: VMX: Use shared msr infrastructure ... Trivial conflicts due to new Kconfig options in arch/Kconfig and kernel/Makefile
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-05Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits) x86: Fix comments of register/stack access functions perf tools: Replace %m with %a in sscanf hw-breakpoints: Keep track of user disabled breakpoints tracing/syscalls: Make syscall events print callbacks static tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook perf: Don't free perf_mmap_data until work has been done perf_event: Fix compile error perf tools: Fix _GNU_SOURCE macro related strndup() build error trace_syscalls: Remove unused syscall_name_to_nr() trace_syscalls: Simplify syscall profile trace_syscalls: Remove duplicate init_enter_##sname() trace_syscalls: Add syscall_nr field to struct syscall_metadata trace_syscalls: Remove enter_id exit_id trace_syscalls: Set event_enter_##sname->data to its metadata trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit perf_event: Initialize data.period in perf_swevent_hrtimer() perf probe: Simplify event naming perf probe: Add --list option for listing current probe events perf probe: Add argv_split() from lib/argv_split.c perf probe: Move probe event utility functions to probe-event.c ...
2009-12-05Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) rcu: Make RCU's CPU-stall detector be default rcu: Add expedited grace-period support for preemptible RCU rcu: Enable fourth level of TREE_RCU hierarchy rcu: Rename "quiet" functions rcu: Re-arrange code to reduce #ifdef pain rcu: Eliminate unneeded function wrapping rcu: Fix grace-period-stall bug on large systems with CPU hotplug rcu: Eliminate __rcu_pending() false positives rcu: Further cleanups of use of lastcomp rcu: Simplify association of forced quiescent states with grace periods rcu: Accelerate callback processing on CPUs not detecting GP end rcu: Mark init-time-only rcu_bootup_announce() as __init rcu: Simplify association of quiescent states with grace periods rcu: Rename dynticks_completed to completed_fqs rcu: Enable synchronize_sched_expedited() fastpath rcu: Remove inline from forward-referenced functions rcu: Fix note_new_gpnum() uses of ->gpnum rcu: Fix synchronization for rcu_process_gp_end() uses of ->completed counter rcu: Prepare for synchronization fixes: clean up for non-NO_HZ handling of ->completed counter rcu: Cleanup: balance rcu_irq_enter()/rcu_irq_exit() calls ...
2009-12-03Merge remote branch 'tip/x86/entry' into kvm-updates/2.6.33Avi Kivity
Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-01SLOW_WORK: Move slow_work's proc file to debugfsDavid Howells
Move slow_work's debugging proc file to debugfs. Signed-off-by: David Howells <dhowells@redhat.com> Requested-and-acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-23perf events: Do not generate function trace entries in perf codeIngo Molnar
Decreases perf overhead when function tracing is enabled, by about 50%. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-19SLOW_WORK: Allow the work items to be viewed through a /proc fileDavid Howells
Allow the executing and queued work items to be viewed through a /proc file for debugging purposes. The contents look something like the following: THR PID ITEM ADDR FL MARK DESC === ===== ================ == ===== ========== 0 3005 ffff880023f52348 a 952ms FSC: OBJ17d3: LOOK 1 3006 ffff880024e33668 2 160ms FSC: OBJ17e5 OP60d3b: Write1/Store fl=2 2 3165 ffff8800296dd180 a 424ms FSC: OBJ17e4: LOOK 3 4089 ffff8800262c8d78 a 212ms FSC: OBJ17ea: CRTN 4 4090 ffff88002792bed8 2 388ms FSC: OBJ17e8 OP60d36: Write1/Store fl=2 5 4092 ffff88002a0ef308 2 388ms FSC: OBJ17e7 OP60d2e: Write1/Store fl=2 6 4094 ffff88002abaf4b8 2 132ms FSC: OBJ17e2 OP60d4e: Write1/Store fl=2 7 4095 ffff88002bb188e0 a 388ms FSC: OBJ17e9: CRTN vsq - ffff880023d99668 1 308ms FSC: OBJ17e0 OP60f91: Write1/EnQ fl=2 vsq - ffff8800295d1740 1 212ms FSC: OBJ16be OP4d4b6: Write1/EnQ fl=2 vsq - ffff880025ba3308 1 160ms FSC: OBJ179a OP58dec: Write1/EnQ fl=2 vsq - ffff880024ec83e0 1 160ms FSC: OBJ17ae OP599f2: Write1/EnQ fl=2 vsq - ffff880026618e00 1 160ms FSC: OBJ17e6 OP60d33: Write1/EnQ fl=2 vsq - ffff880025a2a4b8 1 132ms FSC: OBJ16a2 OP4d583: Write1/EnQ fl=2 vsq - ffff880023cbe6d8 9 212ms FSC: OBJ17eb: LOOK vsq - ffff880024d37590 9 212ms FSC: OBJ17ec: LOOK vsq - ffff880027746cb0 9 212ms FSC: OBJ17ed: LOOK vsq - ffff880024d37ae8 9 212ms FSC: OBJ17ee: LOOK vsq - ffff880024d37cb0 9 212ms FSC: OBJ17ef: LOOK vsq - ffff880025036550 9 212ms FSC: OBJ17f0: LOOK vsq - ffff8800250368e0 9 212ms FSC: OBJ17f1: LOOK vsq - ffff880025036aa8 9 212ms FSC: OBJ17f2: LOOK In the 'THR' column, executing items show the thread they're occupying and queued threads indicate which queue they're on. 'PID' shows the process ID of a slow-work thread that's executing something. 'FL' shows the work item flags. 'MARK' indicates how long since an item was queued or began executing. Lastly, the 'DESC' column permits the owner of an item to give some information. Signed-off-by: David Howells <dhowells@redhat.com>
2009-11-06sysctl: Separate the binary sysctl logic into it's own file.Eric W. Biederman
In preparation for more invasive cleanups separate the core binary sysctl logic into it's own file. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-25x86: Fix user return notifier buildAvi Kivity
When CONFIG_USER_RETURN_NOTIFIER is set, we need to link kernel/user-return-notifier.o. Signed-off-by: Avi Kivity <avi@redhat.com> LKML-Reference: <1256473485-23109-1-git-send-email-avi@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-18Merge commit 'perf/core' into perf/hw-breakpointFrederic Weisbecker
Conflicts: kernel/Makefile kernel/trace/Makefile kernel/trace/trace.h samples/Makefile Merge reason: We need to be uptodate with the perf events development branch because we plan to rewrite the breakpoints API on top of perf events.
2009-09-24cgroups: move the cgroup debug subsys into cgroup.c to access internal statePaul Menage
While it's architecturally clean to have the cgroup debug subsystem be completely independent of the cgroups framework, it limits its usefulness for debugging the contents of internal data structures. Move the debug subsystem code into the scope of all the cgroups data structures to make more detailed debugging possible. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Merge branch 'perfcounters-rename-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-rename-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Tidy up after the big rename perf: Do the big rename: Performance Counters -> Performance Events perf_counter: Rename 'event' to event_id/hw_event perf_counter: Rename list_entry -> group_entry, counter_list -> group_list Manually resolved some fairly trivial conflicts with the tracing tree in include/trace/ftrace.h and kernel/trace/trace_syscalls.c.
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18tracing: Remove markersChristoph Hellwig
Now that the last users of markers have migrated to the event tracer we can kill off the (now orphan) support code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090917173527.GA1699@lst.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15driver-core: move dma-coherent.c from kernel to driver/baseMing Lei
Placing dma-coherent.c in driver/base is better than in kernel, since it contains code to do per-device coherent dma memory handling. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/kernel/process_64.c Semantic conflict fixed in: arch/x86/kvm/x86.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig: kconfig: add missing dependency of conf to localyesconfig kconfig: test if a .config already exists kconfig: make local .config default for streamline_config kconfig: test for /boot/config-uname after /proc/config.gz in localconfig kconfig: unset IKCONFIG_PROC and clean up nesting kconfig: search for a config to base the local(mod|yes)config on kconfig: keep config.gz around even if CONFIG_IKCONFIG_PROC is not set kconfig: have extract-ikconfig read ELF files kconfig: add check if end exists in extract-ikconfig kconfig: enable CONFIG_IKCONFIG from streamline_config.pl kconfig: do not warn about modules built in kconfig: streamline_config.pl do not stop with no depends kconfig: add make localyesconfig option kconfig: make localmodconfig to run streamline_config.pl kconfig: add streamline_config.pl to scripts
2009-09-07Merge branch 'tracing/core' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/Kconfig kernel/trace/trace.h Merge reason: resolve the conflicts, plus adopt to the new ring-buffer APIs. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-18kconfig: keep config.gz around even if CONFIG_IKCONFIG_PROC is not setSteven Rostedt
If CONFIG_IKCONFIG is set but CONFIG_IKCONFIG_PROC is not, then gcc will optimize the config.gz out, because nobody uses it. This patch adds "__used" to the config.gz data to keep it around so that code like extract-ikconfig can still find it. [ Impact: allow extract-ikconfig to find config.gz ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-15Merge commit 'v2.6.31-rc6' into core/rcuIngo Molnar
Merge reason: the branch was on pre-rc1 .30, update to latest. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-28Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ftrace: Fix the output of profile ring-buffer: Make it generally available ftrace: Remove duplicate newline tracing: Fix trace_buf_size boot option ftrace: Fix t_hash_start() ftrace: Don't manipulate @pos in t_start() ftrace: Don't increment @pos in g_start() tracing: Reset iterator in t_start() trace_stat: Don't increment @pos in seq start() tracing_bprintk: Don't increment @pos in t_start() tracing/events: Don't increment @pos in s_start()
2009-06-25ring-buffer: Make it generally availablePaul Mundt
In hunting down the cause for the hwlat_detector ring buffer spew in my failed -next builds it became obvious that folks are now treating ring_buffer as something that is generic independent of tracing and thus, suitable for public driver consumption. Given that there are only a few minor areas in ring_buffer that have any reliance on CONFIG_TRACING or CONFIG_FUNCTION_TRACER, provide stubs for those and make it generally available. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Jon Masters <jcm@jonmasters.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20090625053012.GB19944@linux-sh.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-24audit: inode watches depend on CONFIG_AUDIT not CONFIG_AUDIT_SYSCALLEric Paris
Even though one cannot make use of the audit watch code without CONFIG_AUDIT_SYSCALL the spaghetti nature of the audit code means that the audit rule filtering requires that it at least be compiled. Thus build the audit_watch code when we build auditfilter like it was before cfcad62c74abfef83762dc05a556d21bdf3980a2 Clearly this is a point of potential future cleanup.. Reported-by: Frans Pop <elendil@planet.nl> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24rcu: Remove Classic RCUPaul E. McKenney
Remove Classic RCU, given that the combination of Tree RCU and the proposed Bloatwatch RCU do everything that Classic RCU can with fewer bugs. Tree RCU has been default in x86 builds for almost six months, and seems to be quite reliable, so there does not seem to be much justification for keeping the Classic RCU code and config complexity around anymore. Signed-off-by: Paul E. McKenney <paulmck@linux.ibm.com> Cc: akpm@linux-foundation.org Cc: niv@us.ibm.com Cc: dvhltc@us.ibm.com Cc: dipankar@in.ibm.com Cc: dhowells@redhat.com Cc: lethal@linux-sh.org Cc: kernel@wantstofly.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-23audit: seperate audit inode watches into a subfileEric Paris
In preparation for converting audit to use fsnotify instead of inotify we seperate the inode watching code into it's own file. This is similar to how the audit tree watching code is already seperated into audit_tree.c Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-18gcov: add gcov profiling infrastructurePeter Oberparleiter
Enable the use of GCC's coverage testing tool gcov [1] with the Linux kernel. gcov may be useful for: * debugging (has this code been reached at all?) * test improvement (how do I change my test to cover these lines?) * minimizing kernel configurations (do I need this option if the associated code is never run?) The profiling patch incorporates the following changes: * change kbuild to include profiling flags * provide functions needed by profiling code * present profiling data as files in debugfs Note that on some architectures, enabling gcc's profiling option "-fprofile-arcs" for the entire kernel may trigger compile/link/ run-time problems, some of which are caused by toolchain bugs and others which require adjustment of architecture code. For this reason profiling the entire kernel is initially restricted to those architectures for which it is known to work without changes. This restriction can be lifted once an architecture has been tested and found compatible with gcc's profiling. Profiling of single files or directories is still available on all platforms (see config help text). [1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/traps.c arch/x86/power/cpu.c arch/x86/power/cpu_32.c kernel/Makefile Semantic conflict: arch/x86/kernel/hw_breakpoint.c Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to put_cpu() in arch/x86/kernel/hw_breakpoint.c. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-16groups: move code to kernel/groups.cAlexey Dobriyan
Move supplementary groups implementation to kernel/groups.c . kernel/sys.c already accumulated quite a few random stuff. Do strictly copy/paste + add required headers to compile. Compile-tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-02hw-breakpoints: introducing generic hardware breakpoint handler interfacesK.Prasad
This patch introduces the generic Hardware Breakpoint interfaces for both user and kernel space requests. This core Api handles the hardware breakpoints through new helpers. It handles the user-space breakpoints and kernel breakpoints in front of arch implementation. One can choose kernel wide breakpoints using the following helpers and passing them a generic struct hw_breakpoint: - register_kernel_hw_breakpoint() - unregister_kernel_hw_breakpoint() - modify_kernel_hw_breakpoint() On the other side, you can choose per task breakpoints. - register_user_hw_breakpoint() - unregister_user_hw_breakpoint() - modify_user_hw_breakpoint() [ fweisbec@gmail.com: fix conflict against perfcounter ] Original-patch-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Reviewed-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-04-24Merge commit 'v2.6.30-rc3' into tracing/hw-branch-tracingIngo Molnar
Conflicts: arch/x86/kernel/ptrace.c Merge reason: fix the conflict above, and also pick up the CONFIG_BROKEN dependency change from upstream so that we can remove it here. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing: make the trace clocks available generallyIngo Molnar
Jeremy Fitzhardinge reported this build failure: LD .tmp_vmlinux1 arch/x86/kernel/built-in.o: In function `ds_take_timestamp': git/linux/arch/x86/kernel/ds.c:1380: undefined reference to `trace_clock_global' git/linux/arch/x86/kernel/ds.c:1380: undefined reference to `trace_clock_global' Which is due to !CONFIG_TRACING && CONFIG_X86_DS=y. Expose the trace clock code to CONFIG_X86_DS as well. [ Unfortunately librarizing doesnt work well - ancient architectures with no raw_local_irq_save() primitive break the build. ] Reported-by: Jeremy Fitzhardinge <jeremy@goop.org> LKML-Reference: <49E4413F.7070700@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08Merge commit 'v2.6.30-rc1' into perfcounters/coreIngo Molnar
Conflicts: arch/powerpc/include/asm/systbl.h arch/powerpc/include/asm/unistd.h include/linux/init_task.h Merge reason: the conflicts are non-trivial: PowerPC placement of sys_perf_counter_open has to be mixed with the new preadv/pwrite syscalls. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'linus' into core/softlockupIngo Molnar
Conflicts: kernel/sysctl.c
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03Create a dynamically sized pool of threads for doing very slow work itemsDavid Howells
Create a dynamically sized pool of threads for doing very slow work items, such as invoking mkdir() or rmdir() - things that may take a long time and may sleep, holding mutexes/semaphores and hogging a thread, and are thus unsuitable for workqueues. The number of threads is always at least a settable minimum, but more are started when there's more work to do, up to a limit. Because of the nature of the load, it's not suitable for a 1-thread-per-CPU type pool. A system with one CPU may well want several threads. This is used by FS-Cache to do slow caching operations in the background, such as looking up, creating or deleting cache objects. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-02-26Merge branch 'x86/core' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/apic/apic.c arch/x86/kernel/irqinit_32.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-18pm: fix build for CONFIG_PM unsetRafael J. Wysocki
Compilation of kprobes.c with CONFIG_PM unset is broken due to some broken config dependncies. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Ingo Molnar <mingo@elte.hu> Tested-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Len Brown <lenb@kernel.org> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-12Merge branch 'linus' into core/softlockupIngo Molnar
2009-01-21Merge commit 'v2.6.29-rc2' into perfcounters/coreIngo Molnar
Conflicts: include/linux/syscalls.h
2009-01-18Merge branch 'core/percpu' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/include/asm/pda.h We merge tip/core/percpu into tip/perfcounters/core because of a semantic and contextual conflict: the former eliminates the PDA, while the latter extends it with apic_perf_irqs field. Resolve the conflict by moving the new field to the irq_cpustat structure on 64-bit too. Signed-off-by: Ingo Molnar <mingo@elte.hu>
