commit 07a46ed27dc6344de831a450df82336270a157a9 upstream.
Andrew Morton noted
http://lkml.kernel.org/r/20141104142027.a7a0d010772d84560b445f59@linux-foundation.org
that the shmdt uses inode->i_size outside of i_mutex being held.
There is one more case in shm.c in shm_destroy(). This converts
both users over to use i_size_read().
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
commit d3c97900b427b8d5a476fdfe484267f09df418d6 upstream.
This is a highly-contrived scenario. But, a single shmdt() call can be
induced in to unmapping memory from mulitple shm segments. Example code
is here:
http://www.sr71.net/~dave/intel/shmfun.c
The fix is pretty simple: Record the 'struct file' for the first VMA we
encounter and then stick to it. Decline to unmap anything not from the
same file and thus the same segment.
I found this by inspection and the odds of anyone hitting this in practice
are pretty darn small.
Lightly tested, but it's a pretty small patch.
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
commit e8577d1f0329d4842e8302e289fb2c22156abef4 upstream.
ipc_addid() makes a new ipc identifier visible to everyone. New objects
start as locked, so that the caller can complete the initialization
after the call. Within struct sem_array, at least sma->sem_base and
sma->sem_nsems are accessed without any locks, therefore this approach
doesn't work.
Thus: Move the ipc_addid() to the end of the initialization.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Reported-by: Rik van Riel <riel@redhat.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Acked-by: Rafael Aquini <aquini@redhat.com>
commit 2e094abfd1f29a08a60523b42d4508281b8dee0e upstream.
When I fixed bugs in the sem_lock() logic, I was more conservative than
necessary. Therefore it is safe to replace the smp_mb() with smp_rmb().
And: With smp_rmb(), semop() syscalls are up to 10% faster.
The race we must protect against is:
sem->lock is free
sma->complex_count = 0
sma->sem_perm.lock held by thread B
thread A:
A: spin_lock(&sem->lock)
B: sma->complex_count++; (now 1)
B: spin_unlock(&sma->sem_perm.lock);
A: spin_is_locked(&sma->sem_perm.lock);
A: XXXXX memory barrier
A: if (sma->complex_count == 0)
Thread A must read the increased complex_count value, i.e. the read must
not be reordered with the read of sem_perm.lock done by spin_is_locked().
Since it's about ordering of reads, smp_rmb() is sufficient.
[akpm@linux-foundation.org: update sem_lock() comment, from Davidlohr]
commit 291fdb0bcebd5e8db6af767c1fdc522167dad73d upstream.
Change the type of compat_sys_msgrcv's msgtyp parameter from long
to compat_long_t, since compat user space passes only a 32 bit signed
value.
Let the compat wrapper do proper sign extension to 64 bit of this
parameter.
commit e7ca2552369c1dfe0216c626baf82c3d83ec36bb upstream.
Compat function takes msgtyp argument as u32 and passes it down to
do_msgrcv which results in casting to long, thus the sign is lost and we
get a big positive number instead.
Cast the argument to signed type before passing it down.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Reported-by: Gabriellla Schmidt <gsc@bruker.de>
Cc: Davidlohr Bueso <davidlohr@hp.com>
commit 1195d94e006b23c6292e78857e154872e33b6d7e upstream.
proc_dointvec_minmax() returns zero if a new value has been set. So we
don't need to check all charecters have been handled.
Below you can find two examples. In the new value has not been handled
properly.
$ strace ./a.out
open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3
write(3, "0\n\0", 3) = 2
close(3) = 0
exit_group(0)
$ cat /sys/kernel/debug/tracing/trace
$strace ./a.out
write(3, "0\n", 2) = 2
close(3) = 0
a.out-697 [000] .... 3280.998235: unregister_ipcns_notifier <-proc_ipcauto_dointvec_minmax
Fixes: 9eefe520c814 ("ipc: do not use a negative value to re-enable msgmni automatic recomputin")
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Joe Perches <joe@perches.com>
commit 4f87dac386cc43d5525da7a939d4b4e7edbea22c upstream.
While testing and documenting the msgrcv() MSG_COPY flag that Stanislav
Kinsbursky added in commit 4a674f34ba04 ("ipc: introduce message queue
copy feature" => kernel 3.8), I discovered a couple of bugs in the
implementation. The two bugs concern MSG_COPY interactions with other
msgrcv() flags, namely:
(A) MSG_COPY + MSG_EXCEPT
(B) MSG_COPY + !IPC_NOWAIT
The bugs are distinct (and the fix for the first one is obvious),
however my fix for both is a single-line patch, which is why I'm
combining them in a single mail, rather than writing two mails+patches.
===== (A) MSG_COPY + MSG_EXCEPT =====
With the addition of the MSG_COPY flag, there are now two msgrcv()
flags--MSG_COPY and MSG_EXCEPT--that modify the meaning of the 'msgtyp'
argument in unrelated ways. Specifying both in the same call is a
logical error that is currently permitted, with the effect that MSG_COPY
has priority and MSG_EXCEPT is ignored. The call should give an error
if both flags are specified. The patch below implements that behavior.
===== (B) (B) MSG_COPY + !IPC_NOWAIT =====
The test code that was submitted in commit 3a665531a3b7 ("selftests: IPC
message queue copy feature test") shows MSG_COPY being used in
conjunction with IPC_NOWAIT. In other words, if there is no message at
the position 'msgtyp'. return immediately with the error in ENOMSG.
What was not (fully) tested is the behavior if MSG_COPY is specified
*without* IPC_NOWAIT, and there is an odd behavior. If the queue
contains less than 'msgtyp' messages, then the call blocks until the
next message is written to the queue. At that point, the msgrcv() call
returns a copy of the newly added message, regardless of whether that
message is at the ordinal position 'msgtyp'. This is clearly bogus, and
problematic for applications that might want to make use of the MSG_COPY
flag.
I considered the following possible solutions to this problem:
(1) Force the call to block until a message *does* appear at the
position 'msgtyp'.
(2) If the MSG_COPY flag is specified, the kernel should implicitly add
IPC_NOWAIT, so that the call fails with ENOMSG for this case.
(3) If the MSG_COPY flag is specified, but IPC_NOWAIT is not, generate
an error (probably, EINVAL is the right one).
I do not know if any application would really want to have the
functionality of solution (1), especially since an application can
determine in advance the number of messages in the queue using msgctl()
IPC_STAT. Obviously, this solution would be the most work to implement.
Solution (2) would have the effect of silently fixing any applications
that tried to employ broken behavior. However, it would mean that if we
later decided to implement solution (1), then user-space could not
easily detect what the kernel supports (but, since I'm somewhat doubtful
that solution (1) is needed, I'm not sure that this is much of a
problem).
Solution (3) would have the effect of informing broken applications that
they are doing something broken. The downside is that this would cause
a ABI breakage for any applications that are currently employing the
broken behavior. However:
a) Those applications are almost certainly not getting the results they
expect.
b) Possibly, those applications don't even exist, because MSG_COPY is
currently hidden behind CONFIG_CHECKPOINT_RESTORE.
The upside of solution (3) is that if we later decided to implement
solution (1), user-space could determine what the kernel supports, via
the error return.
In my view, solution (3) is mildly preferable to solution (2), and
solution (1) could still be done later if anyone really cares. The
patch below implements solution (3).
PS. For anyone out there still listening, it's the usual story:
documenting an API (and the thinking about, and the testing of the API,
that documentation entails) is the one of the single best ways of
finding bugs in the API, as I've learned from a lot of experience. Best
to do that documentation before releasing the API.
Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
commit f3713fd9cff733d9df83116422d8e4af6e86b2bb upstream.
Commit 93e6f119c0ce ("ipc/mqueue: cleanup definition names and
locations") added global hardcoded limits to the amount of message
queues that can be created. While these limits are per-namespace,
reality is that it ends up breaking userspace applications.
Historically users have, at least in theory, been able to create up to
INT_MAX queues, and limiting it to just 1024 is way too low and dramatic
for some workloads and use cases. For instance, Madars reports:
"This update imposes bad limits on our multi-process application. As
our app uses approaches that each process opens its own set of queues
(usually something about 3-5 queues per process). In some scenarios
we might run up to 3000 processes or more (which of-course for linux
is not a problem). Thus we might need up to 9000 queues or more. All
processes run under one user."
Other affected users can be found in launchpad bug #1155695:
https://bugs.launchpad.net/ubuntu/+source/manpages/+bug/1155695
Instead of increasing this limit, revert it entirely and fallback to the
original way of dealing queue limits -- where once a user's resource
limit is reached, and all memory is used, new queues cannot be created.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Reported-by: Madars Vitolins <m@silodev.com>
Acked-by: Doug Ledford <dledford@redhat.com>
commit 4e9b45a19241354daec281d7a785739829b52359 upstream.
On 64 bit systems the test for negative message sizes is bogus as the
size, which may be positive when evaluated as a long, will get truncated
to an int when passed to load_msg(). So a long might very well contain a
positive value but when truncated to an int it would become negative.
That in combination with a small negative value of msg_ctlmax (which will
be promoted to an unsigned type for the comparison against msgsz, making
it a big positive value and therefore make it pass the check) will lead to
two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too
small buffer as the addition of alen is effectively a subtraction. 2/ The
copy_from_user() call in load_msg() will first overflow the buffer with
userland data and then, when the userland access generates an access
violation, the fixup handler copy_user_handle_tail() will try to fill the
remainder with zeros -- roughly 4GB. That almost instantly results in a
system crash or reset.
,-[ Reproducer (needs to be run as root) ]--
| #include <sys/stat.h>
| #include <sys/msg.h>
| #include <unistd.h>
| #include <fcntl.h>
| int main(void) {
| long msg = 1;
| int fd;
| fd = open("/proc/sys/kernel/msgmax", O_WRONLY);
| write(fd, "-1", 2);
| close(fd);
| msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT);
| return 0;
Fix the issue by preventing msgsz from getting truncated by consistently
using size_t for the message length. This way the size checks in
do_msgsnd() could still be passed with a negative value for msg_ctlmax but
we would fail on the buffer allocation in that case and error out.
Also change the type of m_ts from int to size_t to avoid similar nastiness
in other code paths -- it is used in similar constructs, i.e. signed vs.
unsigned checks. It should never become negative under normal
circumstances, though.
Setting msg_ctlmax to a negative value is an odd configuration and should
be prevented. As that might break existing userland, it will be handled
in a separate commit so it could easily be reverted and reworked without
reintroducing the above described bug.
Hardening mechanisms for user copy operations would have catched that bug
early -- e.g. checking slab object sizes on user copy operations as the
usercopy feature of the PaX patch does. Or, for that matter, detect the
long vs. int sign change due to truncation, as the size overflow plugin
of the very same patch does.
[akpm@linux-foundation.org: fix i386 min() warnings]
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Brad Spengler <spender@grsecurity.net>
commit a399b29dfbaaaf91162b2dc5a5875dd51bbfa2a1 upstream.
When IPC_RMID races with other shm operations there's potential for
use-after-free of the shm object's associated file (shm_file).
Here's the race before this patch:
TASK 1 TASK 2
shm_rmid()
ipc_lock_object()
shmctl()
shp = shm_obtain_object_check()
shm_destroy()
shum_unlock()
fput(shp->shm_file)
ipc_lock_object()
shmem_lock(shp->shm_file)
<OOPS>
The oops is caused because shm_destroy() calls fput() after dropping the
ipc_lock. fput() clears the file's f_inode, f_path.dentry, and
f_path.mnt, which causes various NULL pointer references in task 2. I
reliably see the oops in task 2 if with shmlock, shmu
This patch fixes the races by:
1) set shm_file=NULL in shm_destroy() while holding ipc_object_lock().
2) modify at risk operations to check shm_file while holding
ipc_object_lock().
Example workloads, which each trigger oops...
Workload 1:
while true; do
id=$(shmget 1 4096)
shm_rmid $id &
shmlock $id &
wait
done
The oops stack shows accessing NULL f_inode due to racing fput:
_raw_spin_lock
shmem_lock
SyS_shmctl
Workload 2:
while true; do
id=$(shmget 1 4096)
shmat $id 4096 &
shm_rmid $id &
wait
done
The oops stack is similar to workload 1 due to NULL f_inode:
touch_atime
shmem_mmap
shm_mmap
mmap_region
do_mmap_pgoff
do_shmat
SyS_shmat
Workload 3:
while true; do
id=$(shmget 1 4096)
shmlock $id
shm_rmid $id &
shmunlock $id &
wait
done
The oops stack shows second fput tripping on an NULL f_inode. The
first fput() completed via from shm_destroy(), but a racing thread did
a get_file() and queued this fput():
locks_remove_flock
__fput
____fput
task_work_run
do_notify_resume
int_signal
Fixes: c2c737a0461e ("ipc,shm: shorten critical region for shmat")
Fixes: 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl")
Signed-off-by: Greg Thelen <gthelen@google.com>
commit 3a72660b07d86d60457ca32080b1ce8c2b628ee2 upstream.
Commit 2caacaa82a51 ("ipc,shm: shorten critical region for shmctl")
restructured the ipc shm to shorten critical region, but introduced a
path where the return value could be -EPERM, even if the operation
actually was performed.
Before the commit, the err return value was reset by the return value
from security_shm_shmctl() after the if (!ns_capable(...)) statement.
Now, we still exit the if statement with err set to -EPERM, and in the
case of SHM_UNLOCK, it is not reset at all, and used as the return value
from shmctl.
To fix this, we only set err when errors occur, leaving the fallthrough
case alone.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Michel Lespinasse <walken@google.com>
Negative message lengths make no sense -- so don't do negative queue
lenghts or identifier counts. Prevent them from getting negative.
Also change the underlying data types to be unsigned to avoid hairy
surprises with sign extensions in cases where those variables get
evaluated in unsigned expressions with bigger data types, e.g size_t.
In case a user still wants to have "unlimited" sizes she could just use
INT_MAX instead.
After acquiring the semlock spinlock, operations must test that the
array is still valid.
- semctl() and exit_sem() would walk stale linked lists (ugly, but
should be ok: all lists are empty)
- semtimedop() would sleep forever - and if woken up due to a signal -
access memory after free.
The patch also:
- standardizes the tests for .deleted, so that all tests in one
function leave the function with the same approach.
- unconditionally tests for .deleted immediately after every call to
sem_lock - even it it means that for semctl(GETALL), .deleted will be
tested twice.
Both changes make the review simpler: After every sem_lock, there must
be a test of .deleted, followed by a goto to the cleanup code (if the
function uses "goto cleanup").
The only exception is semctl_down(): If sem_ids().rwsem is locked, then
the presence in ids->ipcs_idr is equivalent to !.deleted, thus no
additional test is required.
Acked-by: Davidlohr Bueso <davidlohr@hp.com>
The initial documentation was a bit incomplete, update accordingly.
[akpm@linux-foundation.org: make it more readable in 80 columns]
Acked-by: Manfred Spraul <manfred@colorfullife.com>
This fixes a race in both msgrcv() and msgsnd() between finding the msg
and actually dealing with the queue, as another thread can delete shmid
underneath us if we are preempted before acquiring the
kern_ipc_perm.lock.
Manfred illustrates this nicely:
Assume a preemptible kernel that is preempted just after
msq = msq_obtain_object_check(ns, msqid)
in do_msgrcv(). The only lock that is held is rcu_read_lock().
Now the other thread processes IPC_RMID. When the first task is
resumed, then it will happily wait for messages on a deleted queue.
Fix this by checking for if the queue has been deleted after taking the
lock.
Reported-by: Manfred Spraul <manfred@colorfullife.com>
Cc: <stable@vger.kernel.org> [3.11]
In commit 0a2b9d4c7967 ("ipc/sem.c: move wake_up_process out of the
spinlock section"), the update of semaphore's sem_otime(last semop time)
was moved to one central position (do_smart_update).
But since do_smart_update() is only called for operations that modify
the array, this means that wait-for-zero semops do not update sem_otime
anymore.
The fix is simple:
Non-alter operations must update sem_otime.
Reported-by: Jia He <jiakernel@gmail.com>
Tested-by: Jia He <jiakernel@gmail.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
The proc interface is not aware of sem_lock(), it instead calls
ipc_lock_object() directly. This means that simple semop() operations
can run in parallel with the proc interface. Right now, this is
uncritical, because the implementation doesn't do anything that requires
a proper synchronization.
But it is dangerous and therefore should be fixed.
Operations that need access to the whole array must guarantee that there
are no simple operations ongoing. Right now this is achieved by
spin_unlock_wait(sem->lock) on all semaphores.
If complex_count is nonzero, then this spin_unlock_wait() is not
necessary, because it was already performed in the past by the thread
that increased complex_count and even though sem_perm.lock was dropped
inbetween, no simple operation could have started, because simple
operations cannot start when complex_count is non-zero.
Cc: Mike Galbraith <bitbucket@online.de>
Reviewed-by: Davidlohr Bueso <davidlohr@hp.com>
The exclusion of complex operations in sem_lock() is insufficient: after
acquiring the per-semaphore lock, a simple op must first check that
sem_perm.lock is not locked and only after that test check
complex_count. The current code does it the other way around - and that
creates a race. Details are below.
The patch is a complete rewrite of sem_lock(), based in part on the code
from Mike Galbraith. It removes all gotos and all loops and thus the
risk of livelocks.
I have tested the patch (together with the next one) on my i3 laptop and
it didn't cause any problems.
The bug is probably also present in 3.10 and 3.11, but for these kernels
it might be simpler just to move the test of sma->complex_count after
the spin_is_locked() test.
Details of the bug:
Assume:
- sma->complex_count = 0.
- Thread 1: semtimedop(complex op that must sleep)
- Thread 2: semtimedop(simple op).
Pseudo-Trace:
Thread 1: sem_lock(): acquire sem_perm.lock
Thread 1: sem_lock(): check for ongoing simple ops
Nothing ongoing, thread 2 is still before sem_lock().
Thread 1: try_atomic_semop()
<<< preempted.
Thread 2: sem_lock():
static inline int sem_lock(struct sem_array *sma, struct sembuf *sops,
int nsops)
int locknum;
again:
if (nsops == 1 && !sma->complex_count) {
struct sem *sem = sma->sem_base + sops->sem_num;
/* Lock just the semaphore we are interested in. */
spin_lock(&sem->lock);
* If sma->complex_count was set while we were spinning,
* we may need to look at things we did not lock here.
if (unlikely(sma->complex_count)) {
spin_unlock(&sem->lock);
goto lock_array;
<<< complex_count is still 0.
<<< Here it is preempted
Thread 1: try_atomic_semop() returns, notices that it must sleep.
Thread 1: increases sma->complex_count.
Thread 1: drops sem_perm.lock
Thread 2:
* Another process is holding the global lock on the
* sem_array; we cannot enter our critical section,
* but have to wait for the global lock to be released.
if (unlikely(spin_is_locked(&sma->sem_perm.lock))) {
spin_unlock_wait(&sma->sem_perm.lock);
goto again;
<<< sem_perm.lock already dropped, thus no "goto again;"
locknum = sops->sem_num;
Cc: <stable@vger.kernel.org> [3.10+]
Currently, IPC mechanisms do security and auditing related checks under
RCU. However, since security modules can free the security structure,
for example, through selinux_[sem,msg_queue,shm]_free_security(), we can
race if the structure is freed before other tasks are done with it,
creating a use-after-free condition. Manfred illustrates this nicely,
for instance with shared mem and selinux:
-> do_shmat calls rcu_read_lock()
-> do_shmat calls shm_object_check().
Checks that the object is still valid - but doesn't acquire any locks.
Then it returns.
-> do_shmat calls security_shm_shmat (e.g. selinux_shm_shmat)
-> selinux_shm_shmat calls ipc_has_perm()
-> ipc_has_perm accesses ipc_perms->security
shm_close()
-> shm_close acquires rw_mutex & shm_lock
-> shm_close calls shm_destroy
-> shm_destroy calls security_shm_free (e.g. selinux_shm_free_security)
-> selinux_shm_free_security calls ipc_free_security(&shp->shm_perm)
-> ipc_free_security calls kfree(ipc_perms->security)
This patch delays the freeing of the security structures after all RCU
readers are done. Furthermore it aligns the security life cycle with
that of the rest of IPC - freeing them based on the reference counter.
For situations where we need not free security, the current behavior is
kept. Linus states:
"... the old behavior was suspect for another reason too: having the
security blob go away from under a user sounds like it could cause
various other problems anyway, so I think the old code was at least
_prone_ to bugs even if it didn't have catastrophic behavior."
I have tested this patch with IPC testcases from LTP on both my
quad-core laptop and on a 64 core NUMA server. In both cases selinux is
enabled, and tests pass for both voluntary and forced preemption models.
While the mentioned races are theoretical (at least no one as reported
them), I wanted to make sure that this new logic doesn't break anything
we weren't aware of.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
No remaining users, we now use ipc_obtain_object_check().
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
This function was replaced by a the lockless shm_obtain_object_check(),
and no longer has any users.
After previous cleanups and optimizations, this function is no longer
heavily used and we don't have a good reason to keep it. Update the few
remaining callers and get rid of it.
When !CONFIG_MMU there's a chance we can derefence a NULL pointer when the
VM area isn't found - check the return value of find_vma().
Also, remove the redundant -EINVAL return: retval is set to the proper
return code and *only* changed to 0, when we actually unmap the segments.
As suggested by Andrew, add a generic initial locking scheme used
throughout all sysv ipc mechanisms. Documenting the ids rwsem, how rcu
can be enough to do the initial checks and when to actually acquire the
kern_ipc_perm.lock spinlock.
I found that adding it to util.c was generic enough.
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
There is only one user left, drop this function and just call
ipc_unlock_object() and rcu_read_unlock().
Since in some situations the lock can be shared for readers, we shouldn't
be calling it a mutex, rename it to rwsem.
Similar to other system calls, acquire the kern_ipc_perm lock after doing
the initial permission and security checks.
[sasha.levin@oracle.com: dont leave do_shmat with rcu lock held]
Clean up some of the messy do_shmat() spaghetti code, getting rid of
out_free and out_put_dentry labels. This makes shortening the critical
region of this function in the next patch a little easier to do and read.
With the *_INFO, *_STAT, IPC_RMID and IPC_SET commands already optimized,
deal with the remaining SHM_LOCK and SHM_UNLOCK commands. Take the
shm_perm lock after doing the initial auditing and security checks. The
rest of the logic remains unchanged.
While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire
it unnecessarily. We can do the permissions and security checks only
holding the rcu lock.
Similar to semctl and msgctl, when calling msgctl, the *_INFO and *_STAT
commands can be performed without acquiring the ipc object.
Add a shmctl_nolock() function and move the logic of *_INFO and *_STAT out
of msgctl(). Since we are just moving functionality, this change still
takes the lock and it will be properly lockless in the next patch.
Now that sem, msgque and shm, through *_down(), all use the lockless
variant of ipcctl_pre_down(), go ahead and delete it.
[akpm@linux-foundation.org: fix function name in kerneldoc, cleanups]
Instead of holding the ipc lock for the entire function, use the
ipcctl_pre_down_nolock and only acquire the lock for specific commands:
RMID and SET.
This is the third and final patchset that deals with reducing the amount
of contention we impose on the ipc lock (kern_ipc_perm.lock). These
changes mostly deal with shared memory, previous work has already been
done for semaphores and message queues:
http://lkml.org/lkml/2013/3/20/546 (sems)
http://lkml.org/lkml/2013/5/15/584 (mqueues)
With these patches applied, a custom shm microbenchmark stressing shmctl
doing IPC_STAT with 4 threads a million times, reduces the execution
time by 50%. A similar run, this time with IPC_SET, reduces the
execution time from 3 mins and 35 secs to 27 seconds.
Patches 1-8: replaces blindly taking the ipc lock for a smarter
combination of rcu and ipc_obtain_object, only acquiring the spinlock
when updating.
Patch 9: renames the ids rw_mutex to rwsem, which is what it already was.
Patch 10: is a trivial mqueue leftover cleanup
Patch 11: adds a brief lock scheme description, requested by Andrew.
This patch:
Add shm_obtain_object() and shm_obtain_object_check(), which will allow us
to get the ipc object without acquiring the lock. Just as with other
forms of ipc, these functions are basically wrappers around
ipc_obtain_object*().
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace changes from Eric Biederman:
"This is an assorted mishmash of small cleanups, enhancements and bug
fixes.
The major theme is user namespace mount restrictions. nsown_capable
is killed as it encourages not thinking about details that need to be
considered. A very hard to hit pid namespace exiting bug was finally
tracked and fixed. A couple of cleanups to the basic namespace
infrastructure.
Finally there is an enhancement that makes per user namespace
capabilities usable as capabilities, and an enhancement that allows
the per userns root to nice other processes in the user namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
userns: Kill nsown_capable it makes the wrong thing easy
capabilities: allow nice if we are privileged
pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD
userns: Allow PR_CAPBSET_DROP in a user namespace.
namespaces: Simplify copy_namespaces so it is clear what is going on.
pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup
sysfs: Restrict mounting sysfs
userns: Better restrictions on when proc and sysfs can be mounted
vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces
kernel/nsproxy.c: Improving a snippet of code.
proc: Restrict mounting the proc filesystem
vfs: Lock in place mounts from more privileged users
The check if the queue is full and adding current to the wait queue of
pending msgsnd() operations (ss_add()) must be atomic.
Otherwise:
- the thread that performs msgsnd() finds a full queue and decides to
sleep.
- the thread that performs msgrcv() first reads all messages from the
queue and then sleeps, because the queue is empty.
- the msgrcv() calls do not perform any wakeups, because the msgsnd()
task has not yet called ss_add().
- then the msgsnd()-thread first calls ss_add() and then sleeps.
Net result: msgsnd() and msgrcv() both sleep forever.
Observed with msgctl08 from ltp with a preemptible kernel.
Fix: Call ipc_lock_object() before performing the check.
The patch also moves security_msg_queue_msgsnd() under ipc_lock_object:
- msgctl(IPC_SET) explicitely mentions that it tries to expunge any
pending operations that are not allowed anymore with the new
permissions. If security_msg_queue_msgsnd() is called without locks,
then there might be races.
- it makes the patch much simpler.
Reported-and-tested-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: stable@vger.kernel.org # for 3.11
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and
CAP_SETGID. For the existing users it doesn't noticably simplify things and
from the suggested patches I have seen it encourages people to do the wrong
thing. So remove nsown_capable.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
According to 'man msgrcv': "If msgtyp is less than 0, the first message of
the lowest type that is less than or equal to the absolute value of msgtyp
shall be received."
Bug: The kernel only returns a message if its type is 1; other messages
with type < abs(msgtype) will never get returned.
Fix: After having traversed the list to find the first message with the
lowest type, we need to actually return that message.
This regression was introduced by commit daaf74cf0867 ("ipc: refactor
msg list search into separate function")
Signed-off-by: Svenning Soerensen <sss@secomea.dk>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Cleanup: Some minor points that I noticed while writing the previous
patches
1) The name try_atomic_semop() is misleading: The function performs the
operation (if it is possible).
2) Some documentation updates.
No real code change, a rename and documentation changes.
sem_otime contains the time of the last semaphore operation that
completed successfully. Every operation updates this value, thus access
from multiple cpus can cause thrashing.
Therefore the patch replaces the variable with a per-semaphore variable.
The per-array sem_otime is only calculated when required.
No performance improvement on a single-socket i3 - only important for
larger systems.
There are two places that can contain alter operations:
- the global queue: sma->pending_alter
- the per-semaphore queues: sma->sem_base[].pending_alter.
Since one of the queues must be processed first, this causes an odd
priorization of the wakeups: complex operations have priority over
simple ops.
The patch restores the behavior of linux <=3.0.9: The longest waiting
operation has the highest priority.
This is done by using only one queue:
- if there are complex ops, then sma->pending_alter is used.
- otherwise, the per-semaphore queues are used.
As a side effect, do_smart_update_queue() becomes much simpler: no more
goto logic.
Introduce separate queues for operations that do not modify the
semaphore values. Advantages:
- Simpler logic in check_restart().
- Faster update_queue(): Right now, all wait-for-zero operations are
always tested, even if the semaphore value is not 0.
- wait-for-zero gets again priority, as in linux <=3.0.9
As now each semaphore has its own spinlock and parallel operations are
possible, give each semaphore its own cacheline.
On a i3 laptop, this gives up to 28% better performance:
#semscale 10 | grep "interleave 2"
- before:
Cpus 1, interleave 2 delay 0: 36109234 in 10 secs
Cpus 2, interleave 2 delay 0: 55276317 in 10 secs
Cpus 3, interleave 2 delay 0: 62411025 in 10 secs
Cpus 4, interleave 2 delay 0: 81963928 in 10 secs
-after:
Cpus 1, interleave 2 delay 0: 35527306 in 10 secs
Cpus 2, interleave 2 delay 0: 70922909 in 10 secs <<< + 28%
Cpus 3, interleave 2 delay 0: 80518538 in 10 secs
Cpus 4, interleave 2 delay 0: 89115148 in 10 secs <<< + 8.7%
i3, with 2 cores and with hyperthreading enabled. Interleave 2 in order
use first the full cores. HT partially hides the delay from cacheline
trashing, thus the improvement is "only" 8.7% if 4 threads are running.
Enforce that ipc_rcu_alloc returns a cacheline aligned pointer on SMP.
Rationale:
The SysV sem code tries to move the main spinlock into a seperate
cacheline (____cacheline_aligned_in_smp). This works only if
ipc_rcu_alloc returns cacheline aligned pointers. vmalloc and kmalloc
return cacheline algined pointers, the implementation of ipc_rcu_alloc
breaks that.
We can now drop the msg_lock and msg_lock_check functions along with a
bogus comment introduced previously in semctl_down.
do_msgrcv() is the last msg queue function that abuses the ipc lock Take
it only when needed when actually updating msq.
do_msgsnd() is another function that does too many things with the ipc
object lock acquired. Take it only when needed when actually updating
msq.
acquire it unnecessarily. We can do the permissions and security checks
only holding the rcu lock.
This function now mimics semctl_nolock().
