Add calibration_delay_done() call and dummy implementation. This allows
architectures to stop accepting registrations for new timer based delay
functions.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Most of this is cleaning up various driver sysfs permissions so we can
re-add the perm check (we unified the module param and sysfs checks,
but the module ones were stronger so we weakened them temporarily).
Param parsing gets documented, and also "--" now forces args to be
handed to init (and ignored by the kernel).
Module NX/RO protections get tightened: we now set them before calling
parse_args()"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: set nx before marking module MODULE_STATE_COMING.
samples/kobject/: avoid world-writable sysfs files.
drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files.
drivers/staging/speakup/: avoid world-writable sysfs files.
drivers/regulator/virtual: avoid world-writable sysfs files.
drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files.
drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files.
drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files.
drivers/mtd/devices/docg3.c: avoid world-writable sysfs files.
speakup: fix incorrect perms on speakup_acntsa.c
cpumask.h: silence warning with -Wsign-compare
Documentation: Update kernel-parameters.tx
param: hand arguments after -- straight to init
modpost: Fix resource leak in read_dump()
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86-64 espfix changes from Peter Anvin:
"This is the espfix64 code, which fixes the IRET information leak as
well as the associated functionality problem. With this code applied,
16-bit stack segments finally work as intended even on a 64-bit
kernel.
Consequently, this patchset also removes the runtime option that we
added as an interim measure.
To help the people working on Linux kernels for very small systems,
this patchset also makes these compile-time configurable features"
* 'x86/espfix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "x86-64, modify_ldt: Make support for 16-bit segments a runtime option"
x86, espfix: Make it possible to disable 16-bit support
x86, espfix: Make espfix64 a Kconfig option, fix UML
x86, espfix: Fix broken header guard
x86, espfix: Move espfix definitions into a separate header file
x86-32, espfix: Remove filter for espfix32 due to race
x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stack
CLONE_SIGHAND
1. Remove CLONE_KERNEL, it has no users and it is dangerous.
The (old) comment says "List of flags we want to share for kernel
threads" but this is not true, we do not want to share ->sighand by
default. This flag can only be used if the caller is sure that both
parent/child will never play with signals (say, allow_signal/etc).
2. Change rest_init() to clone kernel_init() without CLONE_SIGHAND.
In this case CLONE_SIGHAND does not really hurt, and it looks like
optimization because copy_sighand() can avoid kmem_cache_alloc().
But in fact this only adds the minor pessimization. kernel_init()
is going to exec the init process, and de_thread() will need to
unshare ->sighand and do kmem_cache_alloc(sighand_cachep) anyway,
but it needs to do more work and take tasklist_lock and siglock.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
When a module is built into the kernel the module_init() function
becomes an initcall. Sometimes debugging through dynamic debug can
help, however, debugging built in kernel modules is typically done by
changing the .config, recompiling, and booting the new kernel in an
effort to determine exactly which module caused a problem.
This patchset can be useful stand-alone or combined with initcall_debug.
There are cases where some initcalls can hang the machine before the
console can be flushed, which can make initcall_debug output inaccurate.
Having the ability to skip initcalls can help further debugging of these
scenarios.
Usage: initcall_blacklist=<list of comma separated initcalls>
ex) added "initcall_blacklist=sgi_uv_sysfs_init" as a kernel parameter and
the log contains:
blacklisting initcall sgi_uv_sysfs_init
initcall sgi_uv_sysfs_init blacklisted
ex) added "initcall_blacklist=foo_bar,sgi_uv_sysfs_init" as a kernel parameter
and the log contains:
blacklisting initcall foo_bar
[akpm@linux-foundation.org: tweak printk text]
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Weinberger <richard.weinberger@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Rob Landley <rob@landley.net>
Pertially revert commit ea676e846a81 ("init/main.c: convert to
pr_foo()").
Unbeknownst to me, pr_debug() is different from the other pr_foo()
levels: pr_debug() is a no-op when DEBUG is not defined.
Happily, init/main.c does have a #define DEBUG so we didn't break
initcall_debug. But the functioning of initcall_debug should not be
dependent upon the presence of that #define DEBUG.
Reported-by: Russell King <rmk@arm.linux.org.uk>
Cc: Joe Perches <joe@perches.com>
... instead of naked numbers.
Stuff in sysrq.c used to set it to 8 which is supposed to mean above
default level so set it to DEBUG instead as we're terminating/killing all
tasks and we want to be verbose there.
Also, correct the check in x86_64_start_kernel which should be >= as
we're clearly issuing the string there for all debug levels, not only
the magical 10.
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
sys_sgetmask and sys_ssetmask are obsolete system calls no longer
supported in libc.
This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert
mode configuration.That option is enabled by default for those
architectures.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Greg Ungerer <gerg@uclinux.org>
CONFIG_CROSS_MEMORY_ATTACH adds couple syscalls: process_vm_readv and
process_vm_writev, it's a kind of IPC for copying data between processes.
Currently this option is placed inside "Processor type and features".
This patch moves it into "General setup" (where all other arch-independed
syscalls and ipc features are placed) and changes prompt string to less
cryptic.
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Christopher Yeoh <cyeoh@au1.ibm.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Remove start_kernel()->mm_init_owner(&init_mm, &init_task).
This doesn't really hurt but unnecessary and misleading. init_task is the
"swapper" thread == current, its ->mm is always NULL. And init_mm can
only be used as ->active_mm, not as ->mm.
mm_init_owner() has a single caller with this patch, perhaps it should
die. mm_init() can initialize ->owner under #ifdef.
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Peter Chiang <pchiang@nvidia.com>
CONFIG_MM_OWNER makes no sense. It is not user-selectable, it is only
selected by CONFIG_MEMCG automatically. So we can kill this option in
init/Kconfig and do s/CONFIG_MM_OWNER/CONFIG_MEMCG/ globally.
Acked-by: Michal Hocko <mhocko@suse.cz>
Kmemcg is currently under development and lacks some important features.
In particular, it does not have support of kmem reclaim on memory pressure
inside cgroup, which practically makes it unusable in real life. Let's
warn about it in both Kconfig and Documentation to prevent complaints
arising.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Merge in Linus' tree with:
fa81511bb0bb x86-64, modify_ldt: Make support for 16-bit segments a runtime option
... reverted, to avoid a conflict. This commit is no longer necessary
with the proper fix in place.
As requested by Linus add explicit __visible to the asmlinkage users.
This marks functions visible to assembler.
Tree sweep for rest of tree.
Link: http://lkml.kernel.org/r/1398984278-29319-4-git-send-email-andi@firstfloor.org
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML
build which had broken due to the non-existence of init_espfix_bsp()
in UML: since UML uses its own Kconfig, this option does not appear in
the UML build.
This also makes it possible to make support for 16-bit segments a
configuration option, for the people who want to minimize the size of
the kernel.
Reported-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Richard Weinberger <richard@nod.at>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <stable@vger.kernel.org> # consider after upstream merge
The kernel passes any args it doesn't need through to init, except it
assumes anything containing '.' belongs to the kernel (for a module).
This change means all users can clearly distinguish which arguments
are for init.
For example, the kernel uses debug ("dee-bug") to mean log everything to
the console, where systemd uses the debug from the Scandinavian "day-boog"
meaning "fail to boot". If a future versions uses argv[] instead of
reading /proc/cmdline, this confusion will be avoided.
eg: test 'FOO="this is --foo"' -- 'systemd.debug="true true true"'
Gives:
argv[0] = '/debug-init'
argv[1] = 'test'
argv[2] = 'systemd.debug=true true true'
envp[0] = 'HOME=/'
envp[1] = 'TERM=linux'
envp[2] = 'FOO=this is --foo'
The SYSTEM_TRUSTED_KEYRING config option is not in any menu, causing it
to show up in the toplevel of the kernel configuration. Fix this by
moving it under the General Setup menu.
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
This can greatly aid in narrowing down the real source of initramfs
problems such as failures related to the compression of the in-kernel
initramfs when an external initramfs is in use as well. Existing errors
are ambiguous as to which initramfs is a problem and why.
[akpm@linux-foundation.org: use pr_debug()]
Signed-off-by: Daniel M. Weeks <dan@danweeks.net>
"make allnoconfig" exists to ease testing of minimal configurations.
Documentation/SubmitChecklist includes a note to test with allnoconfig.
This helps catch missing dependencies on common-but-not-required
functionality, which might otherwise go unnoticed.
However, allnoconfig still leaves many symbols enabled, because they're
hidden behind CONFIG_EMBEDDED or CONFIG_EXPERT. For instance, allnoconfig
still has CONFIG_PRINTK and CONFIG_BLOCK enabled, so drivers don't
typically get build-tested with those disabled.
To address this, introduce a new Kconfig option "allnoconfig_y", used on
symbols which only exist to hide other symbols. Set it on CONFIG_EMBEDDED
(which then selects CONFIG_EXPERT). allnoconfig will then disable all the
symbols hidden behind those.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michal Marek <mmarek@suse.cz>
Merge first patch-bomb from Andrew Morton:
- Various misc bits
- kmemleak fixes
- small befs, codafs, cifs, efs, freexxfs, hfsplus, minixfs, reiserfs things
- fanotify
- I appear to have become SuperH maintainer
- ocfs2 updates
- direct-io tweaks
- a bit of the MM queue
- printk updates
- MAINTAINERS maintenance
- some backlight things
- lib/ updates
- checkpatch updates
- the rtc queue
- nilfs2 updates
- Small Documentation/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (237 commits)
Documentation/SubmittingPatches: remove references to patch-scripts
Documentation/SubmittingPatches: update some dead URLs
Documentation/filesystems/ntfs.txt: remove changelog reference
Documentation/kmemleak.txt: updates
fs/reiserfs/super.c: add __init to init_inodecache
fs/reiserfs: move prototype declaration to header file
fs/hfsplus/attributes.c: add __init to hfsplus_create_attr_tree_cache()
fs/hfsplus/extents.c: fix concurrent acess of alloc_blocks
fs/hfsplus/extents.c: remove unused variable in hfsplus_get_block
nilfs2: update project's web site in nilfs2.txt
nilfs2: update MAINTAINERS file entries fix
nilfs2: verify metadata sizes read from disk
nilfs2: add FITRIM ioctl support for nilfs2
nilfs2: add nilfs_sufile_trim_fs to trim clean segs
nilfs2: implementation of NILFS_IOCTL_SET_SUINFO ioctl
nilfs2: add nilfs_sufile_set_suinfo to update segment usage
nilfs2: add struct nilfs_suinfo_update and flags
fs/coda/inode.c: add __init to init_inodecache()
BEFS: logging cleanup
Signed-off-by: chishanmingshen <chishanmingshen@gmail.com>
uselib hasn't been used since libc5; glibc does not use it. Support
turning it off.
When disabled, also omit the load_elf_library implementation from
binfmt_elf.c, which only uselib invokes.
bloat-o-meter:
add/remove: 0/4 grow/shrink: 0/1 up/down: 0/-785 (-785)
function old new delta
padzero 39 36 -3
uselib_flags 20 - -20
sys_uselib 168 - -168
SyS_uselib 168 - -168
load_elf_library 426 - -426
The new CONFIG_USELIB defaults to `y'.
sys_sysfs is an obsolete system call no longer supported by libc.
- This patch adds a default CONFIG_SYSFS_SYSCALL=y
- Option can be turned off in expert mode.
- cond_syscall added to kernel/sys_ni.c
[akpm@linux-foundation.org: tweak Kconfig help text]
Cc: Randy Dunlap <rdunlap@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"A lot updates for cgroup:
- The biggest one is cgroup's conversion to kernfs. cgroup took
after the long abandoned vfs-entangled sysfs implementation and
made it even more convoluted over time. cgroup's internal objects
were fused with vfs objects which also brought in vfs locking and
object lifetime rules. Naturally, there are places where vfs rules
don't fit and nasty hacks, such as credential switching or lock
dance interleaving inode mutex and cgroup_mutex with object serial
number comparison thrown in to decide whether the operation is
actually necessary, needed to be employed.
After conversion to kernfs, internal object lifetime and locking
rules are mostly isolated from vfs interactions allowing shedding
of several nasty hacks and overall simplification. This will also
allow implmentation of operations which may affect multiple cgroups
which weren't possible before as it would have required nesting
i_mutexes.
- Various simplifications including dropping of module support,
easier cgroup name/path handling, simplified cgroup file type
handling and task_cg_lists optimization.
- Prepatory changes for the planned unified hierarchy, which is still
a patchset away from being actually operational. The dummy
hierarchy is updated to serve as the default unified hierarchy.
Controllers which aren't claimed by other hierarchies are
associated with it, which BTW was what the dummy hierarchy was for
anyway.
- Various fixes from Li and others. This pull request includes some
patches to add missing slab.h to various subsystems. This was
triggered xattr.h include removal from cgroup.h. cgroup.h
indirectly got included a lot of files which brought in xattr.h
which brought in slab.h.
There are several merge commits - one to pull in kernfs updates
necessary for converting cgroup (already in upstream through
driver-core), others for interfering changes in the fixes branch"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (74 commits)
cgroup: remove useless argument from cgroup_exit()
cgroup: fix spurious lockdep warning in cgroup_exit()
cgroup: Use RCU_INIT_POINTER(x, NULL) in cgroup.c
cgroup: break kernfs active_ref protection in cgroup directory operations
cgroup: fix cgroup_taskset walking order
cgroup: implement CFTYPE_ONLY_ON_DFL
cgroup: make cgrp_dfl_root mountable
cgroup: drop const from @buffer of cftype->write_string()
cgroup: rename cgroup_dummy_root and related names
cgroup: move ->subsys_mask from cgroupfs_root to cgroup
cgroup: treat cgroup_dummy_root as an equivalent hierarchy during rebinding
cgroup: remove NULL checks from [pr_cont_]cgroup_{name|path}()
cgroup: use cgroup_setup_root() to initialize cgroup_dummy_root
cgroup: reorganize cgroup bootstrapping
cgroup: relocate setting of CGRP_DEAD
cpuset: use rcu_read_lock() to protect task_cs()
cgroup_freezer: document freezer_fork() subtleties
cgroup: update cgroup_transfer_tasks() to either succeed or fail
cgroup: drop task_lock() protection around task->cgroups
cgroup: update how a newly forked task gets associated with css_set
Pull core locking updates from Ingo Molnar:
"The biggest change is the MCS spinlock generalization changes from Tim
Chen, Peter Zijlstra, Jason Low et al. There's also lockdep
fixes/enhancements from Oleg Nesterov, in particular a false negative
fix related to lockdep_set_novalidate_class() usage"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
locking/mutex: Fix debug checks
locking/mutexes: Add extra reschedule point
locking/mutexes: Introduce cancelable MCS lock for adaptive spinning
locking/mutexes: Unlock the mutex without the wait_lock
locking/mutexes: Modify the way optimistic spinners are queued
locking/mutexes: Return false if task need_resched() in mutex_can_spin_on_owner()
locking: Move mcs_spinlock.h into kernel/locking/
m68k: Skip futex_atomic_cmpxchg_inatomic() test
futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test
Revert "sched/wait: Suppress Sparse 'variable shadowing' warning"
lockdep: Change lockdep_set_novalidate_class() to use _and_name
lockdep: Change mark_held_locks() to check hlock->check instead of lockdep_no_validate
lockdep: Don't create the wrong dependency on hlock->check == 0
lockdep: Make held_lock->check and "int check" argument bool
locking/mcs: Allow architecture specific asm files to be used for contended case
locking/mcs: Order the header files in Kbuild of each architecture in alphabetical order
hung_task/Documentation: Fix hung_task_warnings description
locking/mcs: Allow architectures to hook in to contended paths
locking/mcs: Micro-optimize the MCS code, add extra comments
Currently AUDITSYSCALL has a long list of architecture depencency:
depends on AUDIT && (X86 || PARISC || PPC || S390 || IA64 || UML ||
SPARC64 || SUPERH || (ARM && AEABI && !OABI_COMPAT) || ALPHA)
The purpose of this patch is to replace it with HAVE_ARCH_AUDITSYSCALL
for simplicity.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com> (arm)
Acked-by: Richard Guy Briggs <rgb@redhat.com> (audit)
Acked-by: Matt Turner <mattst88@gmail.com> (alpha)
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Zhenglong.cai <zhenglong.cai@cs2c.com.cn>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Commit 73f7d1ca3263 (ACPI / init: Run acpi_early_init() before
timekeeping_init()) optimistically moved the early ACPI initialization
before timekeeping_init(), but that didn't work, because it broke fast
TSC calibration for Julian Wollrath on Thinkpad x121e (and most likely
for others too). The reason is that acpi_early_init() enables the SCI
and that interferes with the fast TSC calibration mechanism.
Thus follow the original idea to execute acpi_early_init() before
efi_enter_virtual_mode() to help the EFI people for now and we can
revisit the other problem that commit 73f7d1ca3263 attempted to
address in the future (if really necessary).
Fixes: 73f7d1ca3263 (ACPI / init: Run acpi_early_init() before timekeeping_init())
Reported-by: Julian Wollrath <jwollrath@web.de>
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
cgroup filesystem code was derived from the original sysfs
implementation which was heavily intertwined with vfs objects and
locking with the goal of re-using the existing vfs infrastructure.
That experiment turned out rather disastrous and sysfs switched, a
long time ago, to distributed filesystem model where a separate
representation is maintained which is queried by vfs. Unfortunately,
cgroup stuck with the failed experiment all these years and
accumulated even more problems over time.
Locking and object lifetime management being entangled with vfs is
probably the most egregious. vfs is never designed to be misused like
this and cgroup ends up jumping through various convoluted dancing to
make things work. Even then, operations across multiple cgroups can't
be done safely as it'll deadlock with rename locking.
Recently, kernfs is separated out from sysfs so that it can be used by
users other than sysfs. This patch converts cgroup to use kernfs,
which will bring the following benefits.
* Separation from vfs internals. Locking and object lifetime
management is contained in cgroup proper making things a lot
simpler. This removes significant amount of locking convolutions,
hairy object lifetime rules and the restriction on multi-cgroup
operations.
* Can drop a lot of code to implement filesystem interface as most are
provided by kernfs.
* Proper "severing" semantics, which allows controllers to not worry
about lingering file accesses after offline.
While the preceding patches did as much as possible to make the
transition less painful, large part of the conversion has to be one
discrete step making this patch rather large. The rest of the commit
message lists notable changes in different areas.
Overall
* vfs constructs replaced with kernfs ones. cgroup->dentry w/ ->kn,
cgroupfs_root->sb w/ ->kf_root.
* All dentry accessors are removed. Helpers to map from kernfs
constructs are added.
* All vfs plumbing around dentry, inode and bdi removed.
* cgroup_mount() now directly looks for matching root and then
proceeds to create a new one if not found.
Synchronization and object lifetime
* vfs inode locking removed. Among other things, this removes the
need for the convolution in cgroup_cfts_commit(). Future patches
will further simplify it.
* vfs refcnting replaced with cgroup internal ones. cgroup->refcnt,
cgroupfs_root->refcnt added. cgroup_put_root() now directly puts
root->refcnt and when it reaches zero proceeds to destroy it thus
merging cgroup_put_root() and the former cgroup_kill_sb().
Simliarly, cgroup_put() now directly schedules cgroup_free_rcu()
when refcnt reaches zero.
* Unlike before, kernfs objects don't hold onto cgroup objects. When
cgroup destroys a kernfs node, all existing operations are drained
and the association is broken immediately. The same for
cgroupfs_roots and mounts.
* All operations which come through kernfs guarantee that the
associated cgroup is and stays valid for the duration of operation;
however, there are two paths which need to find out the associated
cgroup from dentry without going through kernfs -
css_tryget_from_dir() and cgroupstats_build(). For these two,
kernfs_node->priv is RCU managed so that they can dereference it
under RCU read lock.
File and directory handling
* File and directory operations converted to kernfs_ops and
kernfs_syscall_ops.
* xattrs is implicitly supported by kernfs. No need to worry about it
from cgroup. This means that "xattr" mount option is no longer
necessary. A future patch will add a deprecated warning message
when sane_behavior.
* When cftype->max_write_len > PAGE_SIZE, it's necessary to make a
private copy of one of the kernfs_ops to set its atomic_write_len.
cftype->kf_ops is added and cgroup_init/exit_cftypes() are updated
to handle it.
* cftype->lockdep_key added so that kernfs lockdep annotation can be
per cftype.
* Inidividual file entries and open states are now managed by kernfs.
No need to worry about them from cgroup. cfent, cgroup_open_file
and their friends are removed.
* kernfs_nodes are created deactivated and kernfs_activate()
invocations added to places where creation of new nodes are
committed.
* cgroup_rmdir() uses kernfs_[un]break_active_protection() for
self-removal.
v2: - Li pointed out in an earlier patch that specifying "name="
during mount without subsystem specification should succeed if
there's an existing hierarchy with a matching name although it
should fail with -EINVAL if a new hierarchy should be created.
Prior to the conversion, this used by handled by deferring
failure from NULL return from cgroup_root_from_opts(), which was
necessary because root was being created before checking for
existing ones. Note that cgroup_root_from_opts() returned an
ERR_PTR() value for error conditions which require immediate
mount failure.
As we now have separate search and creation steps, deferring
failure from cgroup_root_from_opts() is no longer necessary.
cgroup_root_from_opts() is updated to always return ERR_PTR()
value on failure.
- The logic to match existing roots is updated so that a mount
attempt with a matching name but different subsys_mask are
rejected. This was handled by a separate matching loop under
the comment "Check for name clashes with existing mounts" but
got lost during conversion. Merge the check into the main
search loop.
- Add __rcu __force casting in RCU_INIT_POINTER() in
cgroup_destroy_locked() to avoid the sparse address space
warning reported by kbuild test bot. Maybe we want an explicit
interface to use kn->priv as RCU protected pointer?
v3: Make CONFIG_CGROUPS select CONFIG_KERNFS.
v4: Rebased on top of 0ab02ca8f887 ("cgroup: protect modifications to
cgroup_idr with cgroup_mutex").
Acked-by: Li Zefan <lizefan@huawei.com>
Cc: kbuild test robot fengguang.wu@intel.com>
This changes 'do_execve()' to get the executable name as a 'struct
filename', and to free it when it is done. This is what the normal
users want, and it simplifies and streamlines their error handling.
The controlled lifetime of the executable name also fixes a
use-after-free problem with the trace_sched_process_exec tracepoint: the
lifetime of the passed-in string for kernel users was not at all
obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize
the pathname allocation lifetime with the execve() having finished,
which in turn meant that the trace point that happened after
mm_release() of the old process VM ended up using already free'd memory.
To solve the kernel string lifetime issue, this simply introduces
"getname_kernel()" that works like the normal user-space getname()
function, except with the source coming from kernel memory.
As Oleg points out, this also means that we could drop the tcomm[] array
from 'struct linux_binprm', since the pathname lifetime now covers
setup_new_exec(). That would be a separate cleanup.
Reported-by: Igor Zhbanov <i.zhbanov@samsung.com>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
mca_init() no longer exists.
sbus_init() is defined in arch/sparc/kernel/sbus.c and is a subsys_initcall.
both are not needed in main.c any more.
Signed-off-by: Kang Hu <hukangustc@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespaces work from Eric Biederman:
"The work to convert the kernel to use kuid_t and kgid_t has been
finished since 3.12 so it is time to remove the scaffolding that
allowed the work to progress incrementally.
The first patch on this branch just removes the scaffolding, ensuring
we will always get compile errors if people accidentally try the
userspace and the kernel uid and gid types. The second patch an
overlooked and unused chunk of mips code that that fails to build
after the first patch.
The code hasn't been in linux-next for long (as I was out of it and
could not sheppared the cold properly) but the patch has been around
for a long time just waiting for the day when I had finished the
uid/gid conversions. Putting the code in linux-next did find the
compile failure on mips so I took the time to get that fix reviewed
and included. Beyond that I am not too worried about errors because
all these two patches do is delete a modest amount of code"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
MIPS: VPE: Remove vpe_getuid and vpe_getgid
userns: userns: Remove UIDGID_STRICT_TYPE_CHECKS
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
Use constant format string in case message changes.
Its user was removed in v2.5.2.4.
- a couple of misc things
- inotify/fsnotify work from Jan
- ocfs2 updates (partial)
- about half of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (117 commits)
mm/migrate: remove unused function, fail_migrate_page()
mm/migrate: remove putback_lru_pages, fix comment on putback_movable_pages
mm/migrate: correct failure handling if !hugepage_migration_support()
mm/migrate: add comment about permanent failure path
mm, page_alloc: warn for non-blockable __GFP_NOFAIL allocation failure
mm: compaction: reset scanner positions immediately when they meet
mm: compaction: do not mark unmovable pageblocks as skipped in async compaction
mm: compaction: detect when scanners meet in isolate_freepages
mm: compaction: reset cached scanner pfn's before reading them
mm: compaction: encapsulate defer reset logic
mm: compaction: trace compaction begin and end
memcg, oom: lock mem_cgroup_print_oom_info
sched: add tracepoints related to NUMA task migration
mm: numa: do not automatically migrate KSM pages
mm: numa: trace tasks that fail migration due to rate limiting
mm: numa: limit scope of lock for NUMA migrate rate limiting
mm: numa: make NUMA-migrate related functions static
lib/show_mem.c: show num_poisoned_pages when oom
mm/hwpoison: add '#' to hwpoison_inject
mm/memblock: use WARN_ONCE when MAX_NUMNODES passed as input parameter
"The bulk of changes are cleanups and preparations for the upcoming
kernfs conversion.
- cgroup_event mechanism which is and will be used only by memcg is
moved to memcg.
- pidlist handling is updated so that it can be served by seq_file.
Also, the list is not sorted if sane_behavior. cgroup
documentation explicitly states that the file is not sorted but it
has been for quite some time.
- All cgroup file handling now happens on top of seq_file. This is
to prepare for kernfs conversion. In addition, all operations are
restructured so that they map 1-1 to kernfs operations.
- Other cleanups and low-pri fixes"
* 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (40 commits)
cgroup: trivial style updates
cgroup: remove stray references to css_id
doc: cgroups: Fix typo in doc/cgroups
cgroup: fix fail path in cgroup_load_subsys()
cgroup: fix missing unlock on error in cgroup_load_subsys()
cgroup: remove for_each_root_subsys()
cgroup: implement for_each_css()
cgroup: factor out cgroup_subsys_state creation into create_css()
cgroup: combine css handling loops in cgroup_create()
cgroup: reorder operations in cgroup_create()
cgroup: make for_each_subsys() useable under cgroup_root_mutex
cgroup: css iterations and css_from_dir() are safe under cgroup_mutex
cgroup: unify pidlist and other file handling
cgroup: replace cftype->read_seq_string() with cftype->seq_show()
cgroup: attach cgroup_open_file to all cgroup files
cgroup: generalize cgroup_pidlist_open_file
cgroup: unify read path so that seq_file is always used
cgroup: unify cgroup_write_X64() and cgroup_write_string()
cgroup: remove cftype->read(), ->read_map() and ->write()
hugetlb_cgroup: convert away from cftype->read()
Switch to memblock interfaces for early memory allocator instead of
bootmem allocator. No functional change in beahvior than what it is in
current code from bootmem users points of view.
Archs already converted to NO_BOOTMEM now directly use memblock
interfaces instead of bootmem wrappers build on top of memblock. And
the archs which still uses bootmem, these new apis just fall back to
exiting bootmem APIs.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Tony Lindgren <tony@atomide.com>
If DEBUG_SPINLOCK and DEBUG_LOCK_ALLOC are enabled spinlock_t on x86_64
is 72 bytes. For page->ptl they will be allocated from kmalloc-96 slab,
so we loose 24 on each. An average system can easily allocate few tens
thousands of page->ptl and overhead is significant.
Let's create a separate slab for page->ptl allocation to solve this.
To make sure that it really works this time, some numbers from my test
machine (just booted, no load):
Before:
# grep '^\(kmalloc-96\|page->ptl\)' /proc/slabinfo
kmalloc-96 31987 32190 128 30 1 : tunables 120 60 8 : slabdata 1073 1073 92
After:
page->ptl 27516 28143 72 53 1 : tunables 120 60 8 : slabdata 531 531 9
kmalloc-96 3853 5280 128 30 1 : tunables 120 60 8 : slabdata 176 176 0
Note that the patch is useful not only for debug case, but also for
PREEMPT_RT, where spinlock_t is always bloated.
This is a variant patch from Rafael J. Wysocki's
ACPI / init: Run acpi_early_init() before efi_enter_virtual_mode()
According to Matt Fleming, if acpi_early_init() was executed before
efi_enter_virtual_mode(), the EFI initialization could benefit from
it, so Rafael's patch makes that happen.
And, we want accessing ACPI TAD device to set system clock, so move
acpi_early_init() before timekeeping_init(). This final position is
also before efi_enter_virtual_mode().
Tested-by: Toshi Kani <toshi.kani@hp.com>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
Pick up the latest fixes and refresh the branch.
Introduce mul_u64_u32_shr() as proposed by Andy a while back; it
allows using 64x64->128 muls on 64bit archs and recent GCC
which defines __SIZEOF_INT128__ and __int128.
(This new method will be used by the scheduler.)
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: fweisbec@gmail.com
Link: http://lkml.kernel.org/n/tip-hxjoeuzmrcaumR0uZwjpe2pv@git.kernel.org
