* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
sched: Change wait_for_completion_*_timeout() to return a signed long
sched, autogroup: Fix reference leak
sched, autogroup: Fix potential access to freed memory
sched: Remove redundant CONFIG_CGROUP_SCHED ifdef
sched: Fix interactivity bug by charging unaccounted run-time on entity re-weight
sched: Move periodic share updates to entity_tick()
printk: Use this_cpu_{read|write} api on printk_pending
sched: Make pushable_tasks CONFIG_SMP dependant
sched: Add 'autogroup' scheduling feature: automated per session task groups
sched: Fix unregister_fair_sched_group()
sched: Remove unused argument dest_cpu to migrate_task()
mutexes, sched: Introduce arch_mutex_cpu_relax()
sched: Add some clock info to sched_debug
cpu: Remove incorrect BUG_ON
cpu: Remove unused variable
sched: Fix UP build breakage
sched: Make task dump print all 15 chars of proc comm
sched: Update tg->shares after cpu.shares write
sched: Allow update_cfs_load() to update global load
sched: Implement demand based update_cfs_load()
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
Merge reason: we want to queue up dependent cleanup
A recurring complaint from CFS users is that parallel kbuild has
a negative impact on desktop interactivity. This patch
implements an idea from Linus, to automatically create task
groups. Currently, only per session autogroups are implemented,
but the patch leaves the way open for enhancement.
Implementation: each task's signal struct contains an inherited
pointer to a refcounted autogroup struct containing a task group
pointer, the default for all tasks pointing to the
init_task_group. When a task calls setsid(), a new task group
is created, the process is moved into the new task group, and a
reference to the preveious task group is dropped. Child
processes inherit this task group thereafter, and increase it's
refcount. When the last thread of a process exits, the
process's reference is dropped, such that when the last process
referencing an autogroup exits, the autogroup is destroyed.
At runqueue selection time, IFF a task has no cgroup assignment,
its current autogroup is used.
Autogroup bandwidth is controllable via setting it's nice level
through the proc filesystem:
cat /proc/<pid>/autogroup
Displays the task's group and the group's nice level.
echo <nice level> > /proc/<pid>/autogroup
Sets the task group's shares to the weight of nice <level> task.
Setting nice level is rate limited for !admin users due to the
abuse risk of task group locking.
The feature is enabled from boot by default if
CONFIG_SCHED_AUTOGROUP=y is selected, but can be disabled via
the boot option noautogroup, and can also be turned on/off on
the fly via:
echo [01] > /proc/sys/kernel/sched_autogroup_enabled
... which will automatically move tasks to/from the root task group.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Paul Turner <pjt@google.com>
[ Removed the task_group_path() debug code, and fixed !EVENTFD build failure. ]
LKML-Reference: <1290281700.28711.9.camel@maggy.simson.net>
The synchronize_srcu_expedited() function is currently quick if there
are no active readers, but will delay a full jiffy if there are any.
If these readers leave their SRCU read-side critical sections quickly,
this is way too long to wait. So this commit first waits ten microseconds,
and only then falls back to jiffy-at-a-time waiting.
Reported-by: Avi Kivity <avi@redhat.com>
Reported-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Add tracing for the tiny RCU implementations, including statistics on
boosting in the case of TINY_PREEMPT_RCU and RCU_BOOST.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Add priority boosting, but only for TINY_PREEMPT_RCU. This is enabled
by the default-off RCU_BOOST kernel parameter. The priority to which to
boost preempted RCU readers is controlled by the RCU_BOOST_PRIO kernel
parameter (defaulting to real-time priority 1) and the time to wait
before boosting the readers blocking a given grace period is controlled
by the RCU_BOOST_DELAY kernel parameter (defaulting to 500 milliseconds).
Swap accounting can be configured by CONFIG_CGROUP_MEM_RES_CTLR_SWAP
configuration option and then it is turned on by default. There is a boot
option (noswapaccount) which can disable this feature.
This makes it hard for distributors to enable the configuration option as
this feature leads to a bigger memory consumption and this is a no-go for
general purpose distribution kernel. On the other hand swap accounting
may be very usuful for some workloads.
This patch adds a new configuration option which controls the default
behavior (CGROUP_MEM_RES_CTLR_SWAP_ENABLED). If the option is selected
then the feature is turned on by default.
It also adds a new boot parameter swapaccount[=1|0] which enhances the
original noswapaccount parameter semantic by means of enable/disable logic
(defaults to 1 if no value is provided to be still consistent with
noswapaccount).
The default behavior is unchanged (if CONFIG_CGROUP_MEM_RES_CTLR_SWAP is
enabled then CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED is enabled as well)
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
We have the namespaces as a menuconfig like the cgroup. The cgroup and
the namespace are two base bricks for the containers.
It is more logical to put the namespace menu right after the cgroup menu.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Paul Menage <menage@google.com>
This subsystem is merged since a long time now, I think we can consider it
mature enough.
The different cgroup subsystems are under the cgroup submenu. The
dependency between the cgroups and the menu subsystems is pointless.
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Make the namespaces config option a submenu.
selected
As the different namespaces depend on 'CONFIG_NAMESPACES', it is logical
to enable all the namespaces when we enable NAMESPACES.
Acked-By: Matt Helsley <matthltc@us.ibm.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
The pid namespace is in the kernel since 2.6.27 and the net_ns since
2.6.29. They are enabled in the distro by default and used by userspace
component. They are mature enough to remove the 'experimental' label.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits)
driver core: Display error codes when class suspend fails
Driver core: Add section count to memory_block struct
Driver core: Add mutex for adding/removing memory blocks
Driver core: Move find_memory_block routine
hpilo: Despecificate driver from iLO generation
driver core: Convert link_mem_sections to use find_memory_block_hinted.
driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted.
kobject: Introduce kset_find_obj_hinted.
driver core: fix build for CONFIG_BLOCK not enabled
driver-core: base: change to new flag variable
sysfs: only access bin file vm_ops with the active lock
sysfs: Fail bin file mmap if vma close is implemented.
FW_LOADER: fix kconfig dependency warning on HOTPLUG
uio: Statically allocate uio_class and use class .dev_attrs.
uio: Support 2^MINOR_BITS minors
uio: Cleanup irq handling.
uio: Don't clear driver data
uio: Fix lack of locking in init_uio_class
SYSFS: Allow boot time switching between deprecated and modern sysfs layout
driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits)
cfq-iosched: Fix a gcc 4.5 warning and put some comments
block: Turn bvec_k{un,}map_irq() into static inline functions
block: fix accounting bug on cross partition merges
block: Make the integrity mapped property a bio flag
block: Fix double free in blk_integrity_unregister
block: Ensure physical block size is unsigned int
blkio-throttle: Fix possible multiplication overflow in iops calculations
blkio-throttle: limit max iops value to UINT_MAX
blkio-throttle: There is no need to convert jiffies to milli seconds
blkio-throttle: Fix link failure failure on i386
blkio: Recalculate the throttled bio dispatch time upon throttle limit change
blkio: Add root group to td->tg_list
blkio: deletion of a cgroup was causes oops
blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n
block: set the bounce_pfn to the actual DMA limit rather than to max memory
block: revert bad fix for memory hotplug causing bounces
Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK
block: Prevent hang_check firing during long I/O
cfq: improve fsync performance for small files
Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
I have some systems which need legacy sysfs due to old tools that are
making assumptions that a directory can never be a symlink to another
directory, and it's a big hazzle to compile separate kernels for them.
This patch turns CONFIG_SYSFS_DEPRECATED into a run time option
that can be switched on/off the kernel command line. This way
the same binary can be used in both cases with just a option
on the command line.
The old CONFIG_SYSFS_DEPRECATED_V2 option is still there to set
the default. I kept the weird name to not break existing
config files.
Also the compat code can be still completely disabled by undefining
CONFIG_SYSFS_DEPRECATED_SWITCH -- just the optimizer takes
care of this now instead of lots of ifdefs. This makes the code
look nicer.
v2: This is an updated version on top of Kay's patch to only
handle the block devices. I tested it on my old systems
and that seems to work.
Cc: axboe@kernel.dk
Cc: Kay Sievers <kay.sievers@vrfy.org>
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option,
but it keeps the logic around to handle block devices in the old manner
as some people like to run new kernel versions on old (pre 2007/2008)
distros.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits)
apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets
apic, x86: Check if EILVT APIC registers are available (AMD only)
x86: ioapic: Call free_irte only if interrupt remapping enabled
arm: Use ARCH_IRQ_INIT_FLAGS
genirq, ARM: Fix boot on ARM platforms
genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build
x86: Switch sparse_irq allocations to GFP_KERNEL
genirq: Switch sparse_irq allocator to GFP_KERNEL
genirq: Make sparse_lock a mutex
x86: lguest: Use new irq allocator
genirq: Remove the now unused sparse irq leftovers
genirq: Sanitize dynamic irq handling
genirq: Remove arch_init_chip_data()
x86: xen: Sanitise sparse_irq handling
x86: Use sane enumeration
x86: uv: Clean up the direct access to irq_desc
x86: Make io_apic.c local functions static
genirq: Remove irq_2_iommu
x86: Speed up the irq_remapped check in hot pathes
intr_remap: Simplify the code further
Fix up trivial conflicts in arch/x86/Kconfig
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits)
tracing: Fix compile issue for trace_sched_wakeup.c
[S390] hardirq: remove pointless header file includes
[IA64] Move local_softirq_pending() definition
perf, powerpc: Fix power_pmu_event_init to not use event->ctx
ftrace: Remove recursion between recordmcount and scripts/mod/empty
jump_label: Add COND_STMT(), reducer wrappery
perf: Optimize sw events
perf: Use jump_labels to optimize the scheduler hooks
jump_label: Add atomic_t interface
jump_label: Use more consistent naming
perf, hw_breakpoint: Fix crash in hw_breakpoint creation
perf: Find task before event alloc
perf: Fix task refcount bugs
perf: Fix group moving
irq_work: Add generic hardirq context callbacks
perf_events: Fix transaction recovery in group_sched_in()
perf_events: Fix bogus AMD64 generic TLB events
perf_events: Fix bogus context time tracking
tracing: Remove parent recording in latency tracer graph options
tracing: Use one prologue for the preempt irqs off tracer function tracers
With all the patches we have queued in the BKL removal tree, only a
few dozen modules are left that actually rely on the BKL, and even
there are lots of low-hanging fruit. We need to decide what to do
about them, this patch illustrates one of the options:
Every user of the BKL is marked as 'depends on BKL' in Kconfig,
and the CONFIG_BKL becomes a user-visible option. If it gets
disabled, no BKL using module can be built any more and the BKL
code itself is compiled out.
The one exception is file locking, which is practically always
enabled and does a 'select BKL' instead. This effectively forces
CONFIG_BKL to be enabled until we have solved the fs/lockd
mess and can apply the patch that removes the BKL from fs/locks.c.
Provide a mechanism that allows running code in IRQ context. It is
most useful for NMI code that needs to interact with the rest of the
system -- like wakeup a task to drain buffers.
Perf currently has such a mechanism, so extract that and provide it as
a generic feature, independent of perf so that others may also
benefit.
The IRQ context callback is generated through self-IPIs where
possible, or on architectures like powerpc the decrementer (the
built-in timer facility) is set to generate an interrupt immediately.
Architectures that don't have anything like this get to do with a
callback from the timer tick. These architectures can call
irq_work_run() at the tail of any IRQ handlers that might enqueue such
work (like the perf IRQ handler) to avoid undue latencies in
processing the work.
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
[ various fixes ]
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1287036094.7768.291.camel@yhuang-dev>
The generic irq Kconfig options are copied around all archs. Provide a
generic Kconfig file which can be included.
LKML-Reference: <20100927121843.217333624@linutronix.de>
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
o Actual implementation of throttling policy in block layer. Currently it
implements READ and WRITE bytes per second throttling logic. IOPS throttling
comes in later patches.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Deleted a word which apeared twice.
Signed-off-by: Stephan Sperber <sperberstephan@googlemail.com>
Implement a small-memory-footprint uniprocessor-only implementation of
preemptible RCU. This implementation uses but a single blocked-tasks
list rather than the combinatorial number used per leaf rcu_node by
TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies
processing. This version also takes advantage of uniprocessor execution
to accelerate grace periods in the case where there are no readers.
The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU.
This implementation is a step towards having RCU implementation driven
off of the SMP and PREEMPT kernel configuration variables, which can
happen once this implementation has accumulated sufficient experience.
Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as
suggested by Steve Rostedt in order to avoid the compiler-reordering
issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183).
As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte
savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time
workloads, CONFIG_TINY_RCU is even better.
text data bss dec filename
13 0 0 13 kernel/rcupdate.o
6170 825 28 7023 kernel/rcutree.o
7026 Total
2081 81 8 2170 kernel/rcutiny.o
2183 Total
CONFIG_TINY_RCU (non-preemptible)
719 25 0 744 kernel/rcutiny.o
757 Total
Requested-by: Loïc Minier <loic.minier@canonical.com>
Commit cf244dc01bf68 added a fourth level to the TREE_RCU hierarchy,
but the RCU_FANOUT help message still said "cube root". This commit
fixes this to "fourth root" and also emphasizes that production
systems are well-served by the default. (Stress-testing RCU itself
uses small RCU_FANOUT values in order to test large-system code paths
on small(er) systems.)
Located-by: John Kacur <jkacur@redhat.com>
Because both TINY_RCU and TREE_PREEMPT_RCU have been in mainline for
several releases, it is time to restrict the use of TREE_RCU to SMP
non-preemptible systems. This reduces testing/validation effort. This
commit is a first step towards driving the selection of RCU implementation
directly off of the SMP and PREEMPT configuration parameters.
It's 11 months since we changed swap_map[] to indicates SWAP_HAS_CACHE.
Since that, memcg's swap accounting has been very stable and it seems
it can be maintained.
So, I'd like to remove EXPERIMENTAL from the config.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
Audit watch should depend on CONFIG_AUDIT_SYSCALL and should select
FSNOTIFY. This splits the spagetti like mixing of audit_watch and
audit_filter code so they can be configured seperately.
Signed-off-by: Eric Paris <eparis@redhat.com>
CONFIG_AUDIT builds audit_watches which depend on fsnotify. Make
CONFIG_AUDIT select fsnotify.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Simply switch audit_trees from using inotify to using fsnotify for it's
inode pinning and disappearing act information.
slow-work doesn't have any user left. Kill it.
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits)
kbuild: Revert part of e8d400a to resolve a conflict
kbuild: Fix checking of scm-identifier variable
gconfig: add support to show hidden options that have prompts
menuconfig: add support to show hidden options which have prompts
gconfig: remove show_debug option
gconfig: remove dbg_print_ptype() and dbg_print_stype()
kconfig: fix zconfdump()
kconfig: some small fixes
add random binaries to .gitignore
kbuild: Include gen_initramfs_list.sh and the file list in the .d file
kconfig: recalc symbol value before showing search results
.gitignore: ignore *.lzo files
headerdep: perlcritic warning
scripts/Makefile.lib: Align the output of LZO
kbuild: Generate modules.builtin in make modules_install
Revert "kbuild: specify absolute paths for cscope"
kbuild: Do not unnecessarily regenerate modules.builtin
headers_install: use local file handles
headers_check: fix perl warnings
export_report: fix perl warnings
fs/ext3/fsync.c
This patch fixes few usability and configurability issues.
o All the cgroup based controller options are configurable from
"Genral Setup/Control Group Support/" menu. blkio is the only exception.
Hence make this option visible in above menu and make it configurable from
there to bring it inline with rest of the cgroup based controllers.
o Get rid of CONFIG_DEBUG_CFQ_IOSCHED.
This option currently does two things.
- Enable printing of cgroup paths in blktrace
- Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat
files in cgroup.
If we are using group scheduling, blktrace data is of not really much use
if cgroup information is not present. To get this data, currently one has to
also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of
all the additional debug stat files which is not desired.
Hence, this patch moves printing of cgroup paths under
CONFIG_CFQ_GROUP_IOSCHED.
This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all
the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which
can be enabled through config menu.
Acked-by: Divyesh Shah <dpshah@google.com>
Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"")
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com>
This patchset introduces eventfd-based API for notifications in cgroups
and implements memory notifications on top of it.
It uses statistics in memory controler to track memory usage.
Output of time(1) on building kernel on tmpfs:
Root cgroup before changes:
make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total
Non-root cgroup before changes:
make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total
Root cgroup after changes (0 thresholds):
make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total
Non-root cgroup after changes (0 thresholds):
make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total
Root cgroup after changes (1 thresholds, never crossed):
make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total
Non-root cgroup after changes (1 thresholds, never crossed):
make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total
This patch:
Introduce the write-only file "cgroup.event_control" in every cgroup.
To register new notification handler you need:
- create an eventfd;
- open a control file to be monitored. Callbacks register_event() and
unregister_event() must be defined for the control file;
- write "<event_fd> <control_fd> <args>" to cgroup.event_control.
Interpretation of args is defined by control file implementation;
eventfd will be woken up by control file implementation or when the
cgroup is removed.
To unregister notification handler just close eventfd.
If you need notification functionality for a control file you have to
implement callbacks register_event() and unregister_event() in the
struct cftype.
[kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Dan Malek <dan@embeddedalley.com>
Cc: Vladislav Buzov <vbuzov@embeddedalley.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Alexander Shishkin <virtuoso@slind.org>
Cc: Davide Libenzi <davidel@xmailserver.org>
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
sched: Fix SCHED_MC regression caused by change in sched cpu_power
sched: Don't use possibly stale sched_class
kthread, sched: Remove reference to kthread_create_on_cpu
sched: cpuacct: Use bigger percpu counter batch values for stats counters
percpu_counter: Make __percpu_counter_add an inline function on UP
sched: Remove member rt_se from struct rt_rq
sched: Change usage of rt_rq->rt_se to rt_rq->tg->rt_se[cpu]
sched: Remove unused update_shares_locked()
sched: Use for_each_bit
sched: Queue a deboosted task to the head of the RT prio queue
sched: Implement head queueing for sched_rt
sched: Extend enqueue_task to allow head queueing
sched: Fix the place where group powers are updated
sched: Assume *balance is valid
sched: Remove load_balance_newidle()
sched: Unify load_balance{,_newidle}()
sched: Add a lock break for PREEMPT=y
sched: Remove from fwd decls
sched: Remove rq_iterator from move_one_task
Fix up trivial conflicts in kernel/sched.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits)
perf_event, amd: Fix spinlock initialization
perf_event: Fix preempt warning in perf_clock()
perf tools: Flush maps on COMM events
perf_events, x86: Split PMU definitions into separate files
perf annotate: Handle samples not at objdump output addr boundaries
perf_events, x86: Remove superflous MSR writes
perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()
perf_events, x86: AMD event scheduling
perf_events: Add new start/stop PMU callbacks
perf_events: Report the MMAP pgoff value in bytes
perf annotate: Defer allocating sym_priv->hist array
perf symbols: Improve debugging information about symtab origins
perf top: Use a macro instead of a constant variable
perf symbols: Check the right return variable
perf/scripts: Tag syscall_name helper as not yet available
perf/scripts: Add perf-trace-python Documentation
perf/scripts: Remove unnecessary PyTuple resizes
perf/scripts: Add syscall tracing scripts
perf/scripts: Add Python scripting engine
perf/scripts: Remove check-perf-trace from listed scripts
Fix trivial conflict in tools/perf/util/probe-event.c
* 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
oprofile/x86: fix msr access to reserved counters
oprofile/x86: use kzalloc() instead of kmalloc()
oprofile/x86: fix perfctr nmi reservation for mulitplexing
oprofile/x86: add comment to counter-in-use warning
oprofile/x86: warn user if a counter is already active
oprofile/x86: implement randomization for IBS periodic op counter
oprofile/x86: implement lsfr pseudo-random number generator for IBS
oprofile/x86: implement IBS cpuid feature detection
oprofile/x86: remove node check in AMD IBS initialization
oprofile/x86: remove OPROFILE_IBS config option
oprofile: remove EXPERIMENTAL from the config option description
oprofile: remove tracing build dependency
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
rcu: Fix accelerated GPs for last non-dynticked CPU
rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot
rcu: Fix accelerated grace periods for last non-dynticked CPU
rcu: Export rcu_scheduler_active
rcu: Make rcu_read_lock_sched_held() take boot time into account
rcu: Make lockdep_rcu_dereference() message less alarmist
sched, cgroups: Fix module export
rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information
rcu: Fix rcutorture mod_timer argument to delay one jiffy
rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection
rcu: Convert to raw_spinlocks
rcu: Stop overflowing signed integers
rcu: Use canonical URL for Mathieu's dissertation
rcu: Accelerate grace period if last non-dynticked CPU
rcu: Fix citation of Mathieu's dissertation
rcu: Documentation update for CONFIG_PROVE_RCU
security: Apply lockdep-based checking to rcu_dereference() uses
idr: Apply lockdep-based diagnostics to rcu_dereference() uses
radix-tree: Disable RCU lockdep checking in radix tree
vfs: Abstract rcu_dereference_check for files-fdtable use
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits)
crypto: aes_generic - Fix checkpatch errors
crypto: fcrypt - Fix checkpatch errors
crypto: ecb - Fix checkpatch errors
crypto: des_generic - Fix checkpatch errors
crypto: deflate - Fix checkpatch errors
crypto: crypto_null - Fix checkpatch errors
crypto: cipher - Fix checkpatch errors
crypto: crc32 - Fix checkpatch errors
crypto: compress - Fix checkpatch errors
crypto: cast6 - Fix checkpatch errors
crypto: cast5 - Fix checkpatch errors
crypto: camellia - Fix checkpatch errors
crypto: authenc - Fix checkpatch errors
crypto: api - Fix checkpatch errors
crypto: anubis - Fix checkpatch errors
crypto: algapi - Fix checkpatch errors
crypto: blowfish - Fix checkpatch errors
crypto: aead - Fix checkpatch errors
crypto: ablkcipher - Fix checkpatch errors
crypto: pcrypt - call the complete function on error
OProfile is already used for a long time and no longer experimental.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Currently, rcu_needs_cpu() simply checks whether the current CPU
has an outstanding RCU callback, which means that the last CPU
to go into dyntick-idle mode might wait a few ticks for the
relevant grace periods to complete. However, if all the other
CPUs are in dyntick-idle mode, and if this CPU is in a quiescent
state (which it is for RCU-bh and RCU-sched any time that we are
considering going into dyntick-idle mode), then the grace period
is instantly complete.
This patch therefore repeatedly invokes the RCU grace-period
machinery in order to force any needed grace periods to complete
quickly. It does so a limited number of times in order to
prevent starvation by an RCU callback function that might pass
itself to call_rcu().
However, if any CPU other than the current one is not in
dyntick-idle mode, fall back to simply checking (with fix to bug
noted by Lai Jiangshan). Also, take advantage of last
grace-period forcing, the opportunity to do so noted by Steve
Rostedt. And apply simplified #ifdef condition suggested by
Frederic Weisbecker.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-15-git-send-email-paulmck@linux.vnet.ibm.com>
Merge reason: Merge dependent fix, update to latest -rc.
This adds CROSS_COMPILE as a kconfig string so you can store it in
.config. Then you can use plain "make" in the configured kernel build
directory to do the right cross compilation without setting the
command-line or environment variable every time.
With this, you can set up different build directories for different kernel
configurations, whether native or cross-builds, and then use the simple:
make -C /build/dir M=module-source-dir
idiom to build modules for any given target kernel, indicating which one
by nothing but the build directory chosen.
I tried a version that defaults the string with env="CROSS_COMPILE" so
that in a "make oldconfig" with CROSS_COMPILE in the environment you can
just hit return to store the way you're building it. But the kconfig
prompt for strings doesn't give you any way to say you want an empty
string instead of the default, so I punted that.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Anibal Monsalve Salazar <anibal@debian.org>
Cc: Michal Marek <mmarek@suse.cz>
