path: root/include
2008-10-20mlock: mlocked pages are unevictableNick Piggin
Make sure that mlocked pages also live on the unevictable LRU, so kswapd will not scan them over and over again. This is achieved through various strategies: 1) add yet another page flag--PG_mlocked--to indicate that the page is locked for efficient testing in vmscan and, optionally, fault path. This allows early culling of unevictable pages, preventing them from getting to page_referenced()/try_to_unmap(). Also allows separate accounting of mlock'd pages, as Nick's original patch did. Note: Nick's original mlock patch used a PG_mlocked flag. I had removed this in favor of the PG_unevictable flag + an mlock_count [new page struct member]. I restored the PG_mlocked flag to eliminate the new count field. 2) add the mlock/unevictable infrastructure to mm/mlock.c, with internal APIs in mm/internal.h. This is a rework of Nick's original patch to these files, taking into account that mlocked pages are now kept on unevictable LRU list. 3) update vmscan.c:page_evictable() to check PageMlocked() and, if vma passed in, the vm_flags. Note that the vma will only be passed in for new pages in the fault path; and then only if the "cull unevictable pages in fault path" patch is included. 4) add try_to_unlock() to rmap.c to walk a page's rmap and ClearPageMlocked() if no other vmas have it mlocked. Reuses as much of try_to_unmap() as possible. This effectively replaces the use of one of the lru list links as an mlock count. If this mechanism let's pages in mlocked vmas leak through w/o PG_mlocked set [I don't know that it does], we should catch them later in try_to_unmap(). One hopes this will be rare, as it will be relatively expensive. Original mm/internal.h, mm/rmap.c and mm/mlock.c changes: Signed-off-by: Nick Piggin <npiggin@suse.de> splitlru: introduce __get_user_pages(): New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS. because current get_user_pages() can't grab PROT_NONE pages theresore it cause PROT_NONE pages can't munlock. [akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch] [akpm@linux-foundation.org: untangle patch interdependencies] [akpm@linux-foundation.org: fix things after out-of-order merging] [hugh@veritas.com: fix page-flags mess] [lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm'] [kosaki.motohiro@jp.fujitsu.com: build fix] [kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments] [kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20SHM_LOCKED pages are unevictableLee Schermerhorn
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be kept on the normal LRU, since scanning them is a waste of time and might throw off kswapd's balancing algorithms. Place them on the unevictable LRU list instead. Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared memory regions as unevictable. Then these pages will be culled off the normal LRU lists during vmscan. Add new wrapper function to clear the mapping's unevictable state when/if shared memory segment is munlocked. Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in the shmem segment's mapping [struct address_space] for evictability now that they're no longer locked. If so, move them to the appropriate zone lru list. Changes depend on [CONFIG_]UNEVICTABLE_LRU. [kosaki.motohiro@jp.fujitsu.com: revert shm change] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Ramfs and Ram Disk pages are unevictableLee Schermerhorn
Christoph Lameter pointed out that ram disk pages also clutter the LRU lists. When vmscan finds them dirty and tries to clean them, the ram disk writeback function just redirties the page so that it goes back onto the active list. Round and round she goes... With the ram disk driver [rd.c] replaced by the newer 'brd.c', this is no longer the case, as ram disk pages are no longer maintained on the lru. [This makes them unmigratable for defrag or memory hot remove, but that can be addressed by a separate patch series.] However, the ramfs pages behave like ram disk pages used to, so: Define new address_space flag [shares address_space flags member with mapping's gfp mask] to indicate that the address space contains all unevictable pages. This will provide for efficient testing of ramfs pages in page_evictable(). Also provide wrapper functions to set/test the unevictable state to minimize #ifdefs in ramfs driver and any other users of this facility. Set the unevictable state on address_space structures for new ramfs inodes. Test the unevictable state in page_evictable() to cull unevictable pages. These changes depend on [CONFIG_]UNEVICTABLE_LRU. [riel@redhat.com: undo the brd.c part] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Debugged-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20unevictable lru: add event counting with statisticsLee Schermerhorn
Fix to unevictable-lru-page-statistics.patch Add unevictable lru infrastructure vm events to the statistics patch. Rename the "NORECL_" and "noreclaim_" symbols and text strings to "UNEVICTABLE_" and "unevictable_", respectively. Currently, both the infrastructure and the mlocked pages event are added by a single patch later in the series. This makes it difficult to add or rework the incremental patches. The events actually "belong" with the stats, so pull them up to here. Also, restore the event counting to putback_lru_page(). This was removed from previous patch in series where it was "misplaced". The actual events weren't defined that early. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20pageflag helpers for configed-out flagsLee Schermerhorn
Define proper false/noop inline functions for noreclaim page flags when !defined(CONFIG_UNEVICTABLE_LRU) Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: second chance replacement for anonymous pagesRik van Riel
We avoid evicting and scanning anonymous pages for the most part, but under some workloads we can end up with most of memory filled with anonymous pages. At that point, we suddenly need to clear the referenced bits on all of memory, which can take ages on very large memory systems. We can reduce the maximum number of pages that need to be scanned by not taking the referenced state into account when deactivating an anonymous page. After all, every anonymous page starts out referenced, so why check? If an anonymous page gets referenced again before it reaches the end of the inactive list, we move it back to the active list. To keep the maximum amount of necessary work reasonable, we scale the active to inactive ratio with the size of memory, using the formula active:inactive ratio = sqrt(memory in GB * 10). Kswapd CPU use now seems to scale by the amount of pageout bandwidth, instead of by the amount of memory present in the system. [kamezawa.hiroyu@jp.fujitsu.com: fix OOM with memcg] [kamezawa.hiroyu@jp.fujitsu.com: memcg: lru scan fix] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20define page_file_cache() functionRik van Riel
Define page_file_cache() function to answer the question: is page backed by a file? Originally part of Rik van Riel's split-lru patch. Extracted to make available for other, independent reclaim patches. Moved inline function to linux/mm_inline.h where it will be needed by subsequent "split LRU" and "noreclaim" patches. Unfortunately this needs to use a page flag, since the PG_swapbacked state needs to be preserved all the way to the point where the page is last removed from the LRU. Trying to derive the status from other info in the page resulted in wrong VM statistics in earlier split VM patchsets. The total number of page flags in use on a 32 bit machine after this patch is 19. [akpm@linux-foundation.org: fix up out-of-order merge fallout] [hugh@veritas.com: splitlru: shmem_getpage SetPageSwapBacked sooner[ Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: free swap space on swap-in/activationRik van Riel
If vm_swap_full() (swap space more than 50% full), the system will free swap space at swapin time. With this patch, the system will also free the swap space in the pageout code, when we decide that the page is not a candidate for swapout (and just wasting swap space). Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20swap: use an array for the LRU pagevecsKOSAKI Motohiro
Turn the pagevecs into an array just like the LRUs. This significantly cleans up the source code and reduces the size of the kernel by about 13kB after all the LRU lists have been created further down in the split VM patch series. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: Use an indexed array for LRU variablesChristoph Lameter
Currently we are defining explicit variables for the inactive and active list. An indexed array can be more generic and avoid repeating similar code in several places in the reclaim code. We are saving a few bytes in terms of code size: Before: text data bss dec hex filename 4097753 573120 4092484 8763357 85b7dd vmlinux After: text data bss dec hex filename 4097729 573120 4092484 8763333 85b7c5 vmlinux Having an easy way to add new lru lists may ease future work on the reclaim code. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: move isolate_lru_page() to vmscan.cNick Piggin
On large memory systems, the VM can spend way too much time scanning through pages that it cannot (or should not) evict from memory. Not only does it use up CPU time, but it also provokes lock contention and can leave large systems under memory presure in a catatonic state. This patch series improves VM scalability by: 1) putting filesystem backed, swap backed and unevictable pages onto their own LRUs, so the system only scans the pages that it can/should evict from memory 2) switching to two handed clock replacement for the anonymous LRUs, so the number of pages that need to be scanned when the system starts swapping is bound to a reasonable number 3) keeping unevictable pages off the LRU completely, so the VM does not waste CPU time scanning them. ramfs, ramdisk, SHM_LOCKED shared memory segments and mlock()ed VMA pages are keept on the unevictable list. This patch: isolate_lru_page logically belongs to be in vmscan.c than migrate.c. It is tough, because we don't need that function without memory migration so there is a valid argument to have it in migrate.c. However a subsequent patch needs to make use of it in the core mm, so we can happily move it to vmscan.c. Also, make the function a little more generic by not requiring that it adds an isolated page to a given list. Callers can do that. Note that we now have '__isolate_lru_page()', that does something quite different, visible outside of vmscan.c for use with memory controller. Methinks we need to rationalize these names/purposes. --lts [akpm@linux-foundation.org: fix mm/memory_hotplug.c build] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (94 commits) USB: remove err() macro from more usb drivers USB: remove err() macro from usb misc drivers USB: remove err() macro from usb core code USB: remove err() macro from usb class drivers USB: remove use of err() in drivers/usb/serial USB: remove info() macro from usb mtd drivers USB: remove info() macro from usb input drivers USB: remove info() macro from usb network drivers USB: remove info() macro from remaining usb drivers USB: remove info() macro from usb/misc drivers USB: remove info() macro from usb/serial drivers USB: remove warn macro from HID core USB: remove warn() macro from usb drivers USB: remove warn() macro from usb net drivers USB: remove warn() macro from usb media drivers USB: remove warn() macro from usb input drivers usb/fsl_qe_udc: clear data toggle on clear halt request usb/fsl_qe_udc: fix response to get status request fsl_usb2_udc: Fix oops on probe failure. fsl_usb2_udc: Add a wmb before priming endpoint. ...
2008-10-17Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (44 commits) drm/i915: fix ioremap of a user address for non-root (CVE-2008-3831) drm: make CONFIG_DRM depend on CONFIG_SHMEM. radeon: fix PCI bus mastering support enables. radeon: add RS400 family support. drm/radeon: add support for RS740 IGP chipsets. i915: GM45 has GM965-style MCH setup. i915: Don't run retire work handler while suspended i915: Map status page cached for chips with GTT-based HWS location. i915: Fix up ring initialization to cover G45 oddities i915: Use non-reserved status page index for breadcrumb drm: Increment dev_priv->irq_received so i915_gem_interrupts count works. drm: kill drm_device->irq drm: wbinvd is cache coherent. i915: add missing return in error path. i915: fixup permissions on gem ioctls. drm: Clean up many sparse warnings in i915. drm: Use ioremap_wc in i915_driver instead of ioremap, since we always want WC. drm: G33-class hardware has a newer 965-style MCH (no DCC register). drm: Avoid oops in GEM execbuffers with bad arguments. DRM: Return -EBADF on bad object in flink, and return curent name if it exists. ...
2008-10-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (95 commits) V4L/DVB (9296): Patch to remove warning message during cx88-dvb compilation V4L/DVB (9294): gspca: Add a stop sequence in t613. V4L/DVB (9293): gspca: Separate and fix the sensor dependant sequences in t613. V4L/DVB (9292): gspca: Call the control setting functions at init time in t613. V4L/DVB (9291): gspca: Do not set the white balance temperature by default in t613. V4L/DVB (9290): gspca: Adjust the sensor init sequences in t613. V4L/DVB (9289): gspca: Other sensor identified as om6802 in t613. V4L/DVB (9288): gspca: Write to the USB device and not USB interface in t613. V4L/DVB (9287): gspca: Change the name of the multi bytes write function in t613. V4L/DVB (9286): gspca: Compilation problem of gspca.c and the kernel version. V4L/DVB (9283): Correct typo and enable setting the gain on the mt9m111 sensor V4L/DVB (9282): Properly iterate the urbs when destroying them. V4L/DVB (9281): gspca: Add hflip and vflip to the po1030 sensor V4L/DVB (9280): gspca: Use the gspca debug macros V4L/DVB (9279): gspca: Correct some copyright headers V4L/DVB (9278): gspca: Remove the m5602_debug variable V4L/DVB (9277): gspca: propagate an error in m5602_start_transfer() V4L/DVB (9276): videobuf-dvb: two functions are now static V4L/DVB (9275): dvb: input data pointer of cx24116_writeregN() should be const V4L/DVB (9274): Remove spurious messages and turn into debug. ...
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Remove automatic enabling of the HUGE_FILE feature flag ext4: Replace hackish ext4_mb_poll_new_transaction with commit callback ext4: Update Documentation/filesystems/ext4.txt ext4: Remove unused mount options: nomballoc, mballoc, nocheck ext4: Remove compile warnings when building w/o CONFIG_PROC_FS ext4: Add missing newlines to printk messages ext4: Fix file fragmentation during large file write. vfs: Add no_nrwrite_index_update writeback control flag vfs: Remove the range_cont writeback mode. ext4: Use tag dirty lookup during mpage_da_submit_io ext4: let the block device know when unused blocks can be discarded ext4: Don't reuse released data blocks until transaction commits ext4: Use an rbtree for tracking blocks freed during transaction. ext4: Do mballoc init before doing filesystem recovery ext4: Free ext4_prealloc_space using kmem_cache_free ext4: Fix Kconfig typo for ext4dev ext4: Remove an old reference to ext4dev in Makefile comment
2008-10-17USB: anchor API changes needed for btusbOliver Neukum
This extends the anchor API as btusb needs for autosuspend. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb: vstusb.c : new driver for spectrometers used by Vernier Software & ↵Stephen Ware
Technology, Inc. This patch adds the vstusb driver to the drivers/usb/misc directory. This driver provides support for Vernier Software & Technology spectrometers, all made by Ocean Optics. The driver provides both IOCTL and read()/write() methods for sending raw data to spectrometers across the bulk channel. Each method allows for a configured timeout. From: Stephen Ware <stephen.ware@eqware.net> Signed-off-by: Dennis O'Brien <dennis.obrien@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Fix spelling in usb/serial.hGeoff Levand
Fixes a minor typo in the comments for usb_set_serial_data. Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb gadget: cdc obex glueFelipe Balbi
The following patch introduces a new f_obex.c function driver. It allows userspace obex servers to use usb as transport layer for their messages. [ dbrownell@users.sourceforge.net: various fixes and cleanups ] Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb gadget: function activation/deactivationDavid Brownell
Add a new mechanism to the composite gadget framework, letting functions deactivate (and reactivate) themselves. Think of it as a refcounted wrapper for the software pullup control. A key example of why to use this mechanism involves functions that require a userspace daemon. Those functions shuld use this new mechanism to prevent the gadget from enumerating until those daemons are activated. Without this mechanism, hosts would see devices that malfunction until the relevant daemons start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: extend poisoning to anchorsOliver Neukum
this extends the poisoning concept to anchors. This way poisoning will work with fire and forget drivers. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: kill URBs permanentlyOliver Neukum
looking at usb_kill_urb() it seems to me that it is unnecessarily lenient. In the use case of disconnect() you never want to use the URB again (for the same device) But leaving urb->reject elevated will make it easier to avoid races between read/write and disconnect. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: add USB test and measurement class driverGreg Kroah-Hartman
This driver was originaly written by Stefan Kopp, but massively reworked by Greg for submission. Thanks to Felipe Balbi <me@felipebalbi.com> for lots of work in cleaning up this driver. Thanks to Oliver Neukum <oliver@neukum.org> for reviewing previous versions and pointing out problems. Cc: Stefan Kopp <stefan_kopp@agilent.com> Cc: Marcel Janssen <korgull@home.nl> Cc: Felipe Balbi <me@felipebalbi.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-18radeon: fix PCI bus mastering support enables.Alex Deucher
Someone noticed these registers moved around for later chips, so we redo the codepaths per-chip. PCIE chips don't appear to require explicit enables. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18radeon: add RS400 family support.Alex Deucher
This adds support for the RS400 family of IGPs for Intel CPUs. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm/radeon: add support for RS740 IGP chipsets.Alex Deucher
This adds support for the HS2100 IGP chipset. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18i915: Map status page cached for chips with GTT-based HWS location.Keith Packard
This should improve performance by avoiding uncached reads by the CPU (the point of having a status page), and may improve stability. This patch only affects G33, GM45 and G45 chips as those are the only ones using GTT-based HWS mappings. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm: kill drm_device->irqJesse Barnes
Like the last patch but adds a macro to get at the irq value instead of dereferencing pdev directly. Should make things easier for the BSD guys and if we ever support non-PCI devices. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18i915 gem: install and uninstall irq handler in entervt and leavevt ioctls.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18i915: Add chip set ID param.Kristian Høgsberg
2008-10-18drm: Add GEM ("graphics execution manager") to i915 driver.Eric Anholt
GEM allows the creation of persistent buffer objects accessible by the graphics device through new ioctls for managing execution of commands on the device. The userland API is almost entirely driver-specific to ensure that any driver building on this model can easily map the interface to individual driver requirements. GEM is used by the 2d driver for managing its internal state allocations and will be used for pixmap storage to reduce memory consumption and enable zero-copy GLX_EXT_texture_from_pixmap, and in the 3d driver is used to enable GL_EXT_framebuffer_object and GL_ARB_pixel_buffer_object. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm: Rework vblank-wait handling to allow interrupt reduction.Jesse Barnes
Previously, drivers supporting vblank interrupt waits would run the interrupt all the time, or all the time that any 3d client was running, preventing the CPU from sleeping for long when the system was otherwise idle. Now, interrupts are disabled any time that no client is waiting on a vblank event. The new method uses vblank counters on the chipsets when the interrupts are turned off, rather than counting interrupts, so that we can continue to present accurate vblank numbers. Co-author: Michel Dänzer <michel@tungstengraphics.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm: remove #define's for non-linux systemsCarlos R. Mafra
There is no point in considering FreeBSD et al. in the linux kernel source code. Signed-off-by: Carlos R. Mafra <crmafra@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-17V4L/DVB (9276): videobuf-dvb: two functions are now staticMauro Carvalho Chehab
This patch marks those two functions as static: static int videobuf_dvb_register_adapter(struct videobuf_dvb_frontends *fe, static int videobuf_dvb_register_frontend(struct dvb_adapter *adapter, Since MFE patches changed their calls by videobuf_dvb_register_bus. To avoid having to declare the prototypes, the patch moves videobuf_dvb_register_bus() to be after the declaration of the above functions used there. Cc: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9271): videobuf: data storage optimisation (2)Darron Broad
To optimise data storage even further one other redundant var has been removed. This also removes a redundant assignment. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9268): tuner: add FMD1216MEX tunerDarron Broad
This tuner was already supported by proxy as an FMD1216ME, however, the MEX uses a different FM Radio IF so this addition is now required. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9265): videobuf: data storage optimisationDarron Broad
To optimise data storage redundant vars are removed. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9245): video: add header to soc_camera_platform include fileMagnus Damm
Update the soc_camera_platform header with licensing information. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9241): soc-camera: move sensor power management to ↵Guennadi Liakhovetski
soc_camera_platform.c Switching sensors on and off is now done by sensor drivers themselves, typically using platform-provided hooks. Update soc_camera_platform.c to do the same. Also remove a refundant struct soc_camera_platform_info definition from soc_camera_platform.c. Tested-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9240): saa7127: Fix two typosJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9227): MFE: Add multi-frontend mutual exclusionDarron Broad
This add frontend R/W mutual exclusion. Prior to this point in time it was possible to open both frontends simultaneously which an MFE card cannot support. In order to stop this, a delayed open is performed which has the following function: - Return EBUSY after a configurable amount of time if a frontend is unavailable due to the other being in use. - Only allow opening of a frontend if the kernel thread of the other has stopped. This solution was chosen to allow switching between frontends to work as seamlessly as possible. When both frontends are actually opened simultaneously then one will only open, but if quick switching is performed between one of many then the new open will succeed in a clean fashion rather than interrupting a kernel thread. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9225): MFE: Add configurable gate controlDarron Broad
This adds a configurable (one per card) gate control option for multi-frontend. Prior to this point gate control was assumed to be on the primary frontend, this is a fault when the gate to the analogue section is on the secondary which is the default for both the HVR-3000 and HVR-4000 in MFE. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9222): S2API: Add Multiple-frontend on a single adapter support.Steven Toth
A detailed description from the original patches 2 years ago: "The WinTV-HVR3000 has a single transport bus which is shared between a DVB-T and DVB-S modulator. These patches build on the bus acquisition cx88 work from a few weeks ago to add support for this. So to applications the HVR3000 looks like this: /dev/dvb/adapter0/fe0 (cx24123 DVB-S demod) /dev/dvb/adapter0/fe1 (cx22702 DVB-T demod) Additional boards continue as before, eg: /dev/dvb/adapter1/fe0 (lgdt3302 ATSC demod) The basic change is removing the single instance of the videobuf_dvb in cx8802_dev and saa7134_dev(?) and replacing it with a list and some supporting functions. *NOTE* This branch was taken before v4l-dvb was closed for 2.6.19 so two or three current cx88 patches appear to be reversed by this tree, this will be cleaned up in the near future. The patches missing change the mutex handing to core->lock, fix an enumeration problem." It should be recognised that a number of people have been maintaining this patchset. Significant levels of Kudos to everyone one involved, including but not limited to: Darron Broad Fabio M. Di Nitto Carlo Scarfoglio Hans Werner Without the work of these people, and countless others, my two year old patches would of died on the Mercurial linuxtv.org vine a long time ago. TODO: Revise these patches a little further so that the need for demux1 and dvr0 is optional, not mandatory on the HVR3000. HISTORY (darron): This is the last update to MFE prepared by Hans which is based upon the `scratchpad' diff created by Carlo. All MFE work prior to that point must be attributed to Fabio who ported and maintained Steve's original patch up to that time. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9209): v4l2: add comment to the v4l2-i2c-drv headers.Hans Verkuil
Looking at these headers as they appear in the kernel makes you wonder why it is done that way. Refer to the v4l-dvb repository where the full unstripped header can be found to understand the reasoning behind this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9196): Add support for DSS deliveryManu Abraham
Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9195): Frontend API Fix: 32APSK is a valid modulation for the ↵Manu Abraham
DVB-S2 delivery Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (25 commits) staging: at76_usb wireless driver Staging: workaround build system bug Staging: Lindent sxg.c Staging: SLICOSS: Call pci_release_regions at driver exit Staging: SLICOSS: Fix remaining type names Staging: SLICOSS: Fix warnings due to static usage Staging: SLICOSS: lots of checkpatch fixes Staging: go7007 v4l fixes Staging: Fix gcc warnings in sxg Staging: add echo cancelation module Staging: add wlan-ng prism2 usb driver Staging: add w35und wifi driver Staging: USB/IP: add host driver Staging: USB/IP: add client driver Staging: USB/IP: add common functions needed Staging: add the go7007 video driver Staging: add me4000 pci data collection driver Staging: add me4000 firmware files Staging: add sxg network driver Staging: add Alacritech slicoss network driver ... Fixed up conflicts due to taint flags changes and MAINTAINERS cleanup in MAINTAINERS, include/linux/kernel.h and kernel/panic.c.
2008-10-17Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: remove __generic_unplug_device() from exports block: move q->unplug_work initialization blktrace: pass zfcp driver data blktrace: add support for driver data block: fix current kernel-doc warnings block: only call ->request_fn when the queue is not stopped block: simplify string handling in elv_iosched_store() block: fix kernel-doc for blk_alloc_devt() block: fix nr_phys_segments miscalculation bug block: add partition attribute for partition number block: add BIG FAT WARNING to CONFIG_DEBUG_BLOCK_EXT_DEVT softirq: Add support for triggering softirq work on softirqs.
