path: root/include
2006-01-06[BLOCK] add FUA support to libataTejun Heo
Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] update SCSI to use new blk_ordered for barriersTejun Heo
All ordered request related stuff delegated to HLD. Midlayer now doens't deal with ordered setting or prepare_flush callback. sd.c updated to deal with blk_queue_ordered setting. Currently, ordered tag isn't used as SCSI midlayer cannot guarantee request ordering. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] reimplement handling of barrier requestTejun Heo
Reimplement handling of barrier requests. * Flexible handling to deal with various capabilities of target devices. * Retry support for falling back. * Tagged queues which don't support ordered tag can do ordered. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] add @uptodate to end_that_request_last() and @error to rq_end_io_fn()Tejun Heo
add @uptodate argument to end_that_request_last() and @error to rq_end_io_fn(). there's no generic way to pass error code to request completion function, making generic error handling of non-fs request difficult (rq->errors is driver-specific and each driver uses it differently). this patch adds @uptodate to end_that_request_last() and @error to rq_end_io_fn(). for fs requests, this doesn't really matter, so just using the same uptodate argument used in the last call to end_that_request_first() should suffice. imho, this can also help the generic command-carrying request jens is working on. Signed-off-by: tejun heo <htejun@gmail.com> Signed-Off-By: Jens Axboe <axboe@suse.de>
2006-01-05Merge http://oss.oracle.com/git/ocfs2Linus Torvalds
2006-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: remove old detach mechanismDominik Brodowski
Remove the old "detach" mechanism as it is unused now. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify detach, REMOVAL_EVENT handlers into one remove callbackDominik Brodowski
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function. Old functionality is preserved, for the moment. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: new suspend coreDominik Brodowski
Move the suspend and resume methods out of the event handler, and into special functions. Also use these functions for pre- and post-reset, as almost all drivers already do, and the remaining ones can easily be converted. Bugfix to include/pcmcia/ds.c Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: validate_mem shouldn't be voidDominik Brodowski
Add a return value to pcmcia_validate_mem. Only if we have enough memory available to map the CIS, we should proceed in trying to determine information about the device. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: remove get_socket callbackDominik Brodowski
The .get_socket callback is never used by the PCMCIA core, therefore remove it. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: remove socket register_callbackDominik Brodowski
Remove the register_callback declaration in struct pccard_operations as it is unused. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[NETFILTER]: Export ip6_masked_addrcmp, don't pass IPv6 addresses on stackPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: make ipv6_find_hdr() find transport protocol headerPatrick McHardy
The original ipv6_find_hdr() finds the specified header in IPv6 packets. This makes it possible to get transport header so that we can kill similar loop in ip6_match_packet(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Call POST_ROUTING hook before fragmentationPatrick McHardy
Call POST_ROUTING hook before fragmentation to get rid of the okfn use in ip_refrag and save the useless fragmentation/defragmentation step when NAT is used. The patch introduces one user-visible change, the POSTROUTING chain in the mangle table gets entire packets, not fragments, which should simplify use of the MARK and CLASSIFY targets for queueing as a nice side-effect. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: ctnetlink: Fix dumping of helper namePatrick McHardy
Properly dump the helper name instead of internal kernel data. Based on patch by Marcus Sundberg <marcus@ingate.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Add ctnetlink port for nf_conntrackPablo Neira Ayuso
Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-04Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
2006-01-04Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
2006-01-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
2006-01-04[PATCH] Driver Core: Add platform_device_del()Dmitry Torokhov
Driver core: add platform_device_del function Having platform_device_del90 allows more straightforward error handling code in drivers registering platform devices. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Input: fix add modalias support build errorRusty Russell
Fix build when scripts/mod/file2alias.c includes linux/input.h, which tries to include /usr/include/linux/mod_devicetable.h: In file included from scripts/mod/file2alias.c:40: include/linux/input.h:21:35: linux/mod_devicetable.h: No such file or directory make[2]: *** [scripts/mod/file2alias.o] Error 1 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Input: add modalias supportRusty Russell
Here's the patch for modalias support for input classes. It uses comma-separated numbers, and doesn't describe all the potential keys (no module currently cares, and that would make the strings huge). The changes to input.h are to move the definitions needed by file2alias outside __KERNEL__. I chose not to move those definitions to mod_devicetable.h, because there are so many that it might break compile of something else in the kernel. The rest is fairly straightforward. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] kobject_uevent CONFIG_NET=n fixakpm@osdl.org
lib/lib.a(kobject_uevent.o)(.text+0x25f): In function `kobject_uevent': : undefined reference to `__alloc_skb' lib/lib.a(kobject_uevent.o)(.text+0x2a1): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x31d): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x356): In function `kobject_uevent': : undefined reference to `netlink_broadcast' lib/lib.a(kobject_uevent.o)(.init.text+0x9): In function `kobject_uevent_init': : undefined reference to `netlink_kernel_create' make: *** [.tmp_vmlinux1] Error 1 Netlink is unconditionally enabled if CONFIG_NET, so that's OK. kobject_uevent.o is compiled even if !CONFIG_HOTPLUG, which is lazy. Let's compound the sin. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] merge kobject_uevent and kobject_hotplugKay Sievers
The distinction between hotplug and uevent does not make sense these days, netlink events are the default. udev depends entirely on netlink uevents. Only during early boot and in initramfs, /sbin/hotplug is needed. So merge the two functions and provide only one interface without all the options. The netlink layer got a nice generic interface with named slots recently, which is probably a better facility to plug events for subsystem specific events. Also the new poll() interface to /proc/mounts is a nicer way to notify about changes than sending events through the core. The uevents should only be used for driver core related requests to userspace now. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] remove mount/umount uevents from superblock handlingKay Sievers
The names of these events have been confusing from the beginning on, as they have been more like claim/release events. We needed these events for noticing HAL if storage devices have been mounted. Thanks to Al, we have the proper solution now and can poll() /proc/mounts instead to get notfied about mount tree changes. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] remove CONFIG_KOBJECT_UEVENT optionKay Sievers
It makes zero sense to have hotplug, but not the netlink events enabled today. Remove this option and merge the kobject_uevent.h header into the kobject.h header file. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB Storage: add alauda supportMatthew Dharm
This patch adds another usb-storage subdriver, which supports two fairly old dual-XD/SmartMedia reader-writers (USB1.1 devices). This driver was written by Daniel Drake <dsd@gentoo.org> -- he notes that he wrote this driver without specs, however a vendor-supplied GPL driver for the previous generation of products ("sma03") did prove to be quite useful, as did the sddr09 driver which also has to deal with low-level physical block layout on SmartMedia. The original patch has been reformed by me, as it clashed with the libusual patches. We really need to consolidate some of this common SmartMedia code, and get together with the MTD guys to share it with them as well. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Store port number in usb_deviceAlan Stern
This patch (as610) adds a field to struct usb_device to store the device's port number. This allows us to remove several loops in the hub driver (searching for a particular device among all the entries in the parent's array of children). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Consider power budget when choosing configurationAlan Stern
This patch (as609) changes the way we keep track of power budgeting for USB hubs and devices, and it updates the choose_configuration routine to take this information into account. (This is something we should have been doing all along.) A new field in struct usb_device holds the amount of bus current available from the upstream port, and the usb_hub structure keeps track of the current available for each downstream port. Two new rules for configuration selection are added: Don't select a self-powered configuration when only bus power is available. Don't select a configuration requiring more bus power than is available. However the first rule is #if-ed out, because I found that the internal hub in my HP USB keyboard claims that its only configuration is self-powered. The rule would prevent the configuration from being chosen, leaving the hub & keyboard unconfigured. Since similar descriptor errors may turn out to be fairly common, it seemed wise not to include a rule that would break automatic configuration unnecessarily for such devices. The second rule may also trigger unnecessarily, although this should be less common. More likely it will annoy people by sometimes failing to accept configurations that should never have been chosen in the first place. The patch also changes usbcore's reaction when no configuration is suitable. Instead of raising an error and rejecting the device, now the core will simply leave the device unconfigured. People can always work around such problems by installing configurations manually through sysfs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Remove USB private semaphoreAlan Stern
This patch (as605) removes the private udev->serialize semaphore, relying instead on the locking provided by the embedded struct device's semaphore. The changes are confined to the core, except that the usb_trylock_device routine now uses the return convention of down_trylock rather than down_read_trylock (they return opposite values for no good reason). A couple of other associated changes are included as well: Now that we aren't concerned about HCDs that avoid using the hcd glue layer, usb_disconnect no longer needs to acquire the usb_bus_lock -- that can be done by usb_remove_hcd where it belongs. Devices aren't locked over the same scope of code in usb_new_device and hub_port_connect_change as they used to be. This shouldn't cause any trouble. Along with the preceding driver core patch, this needs a lot of testing. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: make registering a usb driver automatically set the module ownerGreg Kroah-Hartman
This fixes the driver that forgot to set the module owner up. Now we can remove the unneeded pointer from the usb driver structure. The idea for how to do this was from Al Viro, who did this for the PCI drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: allow usb drivers to disable dynamic idsGreg Kroah-Hartman
This lets drivers, like the usb-serial ones, disable the ability to add ids from sysfs. The usb-serial drivers are "odd" in that they are really usb-serial bus drivers, not usb bus drivers, so the dynamic id logic will have to go into the usb-serial bus core for those drivers to get that ability. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: add dynamic id functionality to USB coreGreg Kroah-Hartman
Echo the usb vendor and product id to the "new_id" file in the driver's sysfs directory, and then that driver will be able to bind to a device with those ids if it is present. Example: echo 0557 2008 > /sys/bus/usb/drivers/foo_driver/new_id adds the hex values 0557 and 2008 to the device id table for the foo_driver. Note, usb-serial drivers do not currently work with this capability yet. usb-storage also might have some oddities. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: drivers/usb/storage/libusualPete Zaitcev
This patch adds a shim driver libusual, which routes devices between usb-storage and ub according to the common table, based on unusual_devs.h. The help and example syntax is in Kconfig. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: pxa27x OHCI - Separate platform code from main driverRichard Purdie
To allow multiple platforms to use the PXA27x OHCI driver, the platform code needs to be moved into the board specific files in arch/arm/mach-pxa. This patch does this for mainstone and adds preliminary hooks to allow other boards to use the driver. This has been compile tested for mainstone and successfully run on Spitz (Sharp Zaurus SL-C3000) with the addition of an appropriate board support file. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[ALSA] Revert the nested-device patchTakashi Iwai
Modules: ALSA Core Revert the nested-device patch to keep the compatibility with the current HAL configuration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-04[ALSA] version 1.0.11rc2Jaroslav Kysela
2006-01-03[TCP]: less inline'sStephen Hemminger
TCP inline usage cleanup: * get rid of inline in several places * replace __inline__ with inline where possible * move functions used in one file out of tcp.h * let compiler decide on used once cases On x86_64: text data bss dec hex filename 3594701 648348 567400 4810449 4966d1 vmlinux.orig 3593133 648580 567400 4809113 496199 vmlinux On sparc64: text data bss dec hex filename 2538278 406152 530392 3474822 350586 vmlinux.ORIG 2536382 406384 530392 3473158 34ff06 vmlinux Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Don't exclude broadcast addresses from is_multicast_ether_addr()Stephen Hemminger
The check for multicast shouldn't exclude broadcast type addresses. This reverts the incorrect change done in 2.6.13. The broadcast address is a multicast address and should be excluded from being a valid_ether_address for use in bridging or device address. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
