path: root/include
2009-10-01memcg: some modification to softlimit under hierarchical memory reclaim.KAMEZAWA Hiroyuki
This patch clean up/fixes for memcg's uncharge soft limit path. Problems: Now, res_counter_charge()/uncharge() handles softlimit information at charge/uncharge and softlimit-check is done when event counter per memcg goes over limit. Now, event counter per memcg is updated only when memory usage is over soft limit. Here, considering hierarchical memcg management, ancesotors should be taken care of. Now, ancerstors(hierarchy) are handled in charge() but not in uncharge(). This is not good. Prolems: 1. memcg's event counter incremented only when softlimit hits. That's bad. It makes event counter hard to be reused for other purpose. 2. At uncharge, only the lowest level rescounter is handled. This is bug. Because ancesotor's event counter is not incremented, children should take care of them. 3. res_counter_uncharge()'s 3rd argument is NULL in most case. ops under res_counter->lock should be small. No "if" sentense is better. Fixes: * Removed soft_limit_xx poitner and checks in charge and uncharge. Do-check-only-when-necessary scheme works enough well without them. * make event-counter of memcg incremented at every charge/uncharge. (per-cpu area will be accessed soon anyway) * All ancestors are checked at soft-limit-check. This is necessary because ancesotor's event counter may never be modified. Then, they should be checked at the same time. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01asm-generic/gpio.h: pull in linux/kernel.h for might_sleep()Mike Frysinger
The asm-generic/gpio.h header uses the might_sleep() macro but doesn't include the header for it, so any source code that might include linux/gpio.h before linux/kernel.h can easily lead to a build failure. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: ax25: Fix possible oops in ax25_make_new net: restore tx timestamping for accelerated vlans Phonet: fix mutex imbalance sit: fix off-by-one in ipip6_tunnel_get_prl net: Fix sock_wfree() race net: Make setsockopt() optlen be unsigned.
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Avoid spurious make includecheck message MIPS: VPE: Get rid of BKL. MIPS: VPE: Fix build after the credential changes a while ago. MIPS: Excite: Get rid of BKL. MIPS: Sibyte: Get rid of BKL. MIPS: BCM63xx: Add PCMCIA & Cardbus support. MIPS: MSP71xx: request_irq() failure ignored in msp_pcibios_config_access() MIPS: Decrease size of au1xxx_dbdma_pm_regs[][] MIPS: SMP: Inline arch_send_call_function_{single_ipi,ipi_mask} MIPS: SMP: Fix build. MIPS: MIPSxx SC: Avoid destructive invalidation on partial L2 cachelines. MIPS: Sibyte: Fix compilation error. MIPS: BCM1480: Re-apply patch lost due to bad resolution of merge conflict. MIPS: BCM63xx: Add serial driver for bcm63xx integrated UART. MIPS: Loongson2: Fix typo "enalbe" -> "enable" MIPS: SMTC: Remove duplicate structure field initialization MIPS: Remove duplicated #include MIPS: BCM63xx: Remove duplicated #include
2009-09-30MIPS: BCM63xx: Add serial driver for bcm63xx integrated UART.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Fix time encoding with extra epoch bits ext4: Add a stub for mpage_da_data in the trace header jbd2: Use tracepoints for history file ext4: Use tracepoints for mb_history trace file ext4, jbd2: Drop unneeded printks at mount and unmount time ext4: Handle nested ext4_journal_start/stop calls without a journal ext4: Make sure ext4_dirty_inode() updates the inode in no journal mode ext4: Avoid updating the inode table bh twice in no journal mode ext4: EXT4_IOC_MOVE_EXT: Check for different original and donor inodes first ext4: async direct IO for holes and fallocate support ext4: Use end_io callback to avoid direct I/O fallback to buffered I/O ext4: Split uninitialized extents for direct I/O ext4: release reserved quota when block reservation for delalloc retry ext4: Adjust ext4_da_writepages() to write out larger contiguous chunks ext4: Fix hueristic which avoids group preallocation for closed files ext4: Use ext4_msg() for ext4_da_writepage() errors ext4: Update documentation about quota mount options
2009-09-30Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / yenta: Fix cardbus suspend/resume regression PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) sony-laptop: re-read the rfkill state when resuming from suspend sony-laptop: check for rfkill hard block at load time wext: add back wireless/ dir in sysfs for cfg80211 interfaces wext: Add bound checks for copy_from_user mac80211: improve/fix mlme messages cfg80211: always get BSS iwlwifi: fix 3945 ucode info retrieval after failure iwlwifi: fix memory leak in command queue handling iwlwifi: fix debugfs buffer handling cfg80211: don't set privacy w/o key cfg80211: wext: don't display BSSID unless associated net: Add explicit bound checks in net/socket.c bridge: Fix double-free in br_add_if. isdn: fix netjet/isdnhdlc build errors atm: dereference of he_dev->rbps_virt in he_init_group() ax25: Add missing dev_put in ax25_setsockopt Revert "sit: stateless autoconf for isatap" net: fix double skb free in dcbnl net: fix nlmsg len size for skb when error bit is set. net: fix vlan_get_size to include vlan_flags size ...
2009-09-30Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (25 commits) drm/radeon/kms: Convert R520 to new init path and associated cleanup drm/radeon/kms: Convert RV515 to new init path and associated cleanup drm: fix radeon DRM warnings when !CONFIG_DEBUG_FS drm: fix drm_fb_helper warning when !CONFIG_MAGIC_SYSRQ drm/r600: fix memory leak introduced with 64k malloc avoidance fix. drm/kms: make fb helper work for all drivers. drm/radeon/r600: fix offset handling in CS parser drm/radeon/kms/r600: fix forcing pci mode on agp cards drm/radeon/kms: fix for the extra pages copying. drm/radeon/kms/r600: add support for vline relocs drm/radeon/kms: fix some bugs in vline reloc drm/radeon/kms/r600: clamp vram to aperture size drm/kms: protect against fb helper not being created. drm/r600: get values from the passed in IB not the copy. drm: create gitignore file for radeon drm/radeon/kms: remove unneeded master create/destroy functions. drm/kms: start adding command line interface using fb. fb: change rules for global rules match. drm/radeon/kms: don't require up to 64k allocations. (v2) drm/radeon/kms: enable dac load detection by default. ... Trivial conflicts in drivers/gpu/drm/radeon/radeon_asic.h due to adding '->vga_set_state' function pointers.
2009-09-30ext4: Add a stub for mpage_da_data in the trace headerJosh Stone
The tracepoint ext4_da_write_pages has a struct mpage_da_data* parameter, but that struct is only defined in fs/ext4/ext4.h. This patch adds a forward declaration for that struct, so this tracepoint header can still be used by tools like SystemTap. This is a continuation of the fix in commit 3661d286. http://sourceware.org/bugzilla/show_bug.cgi?id=10703 Signed-off-by: Josh Stone <jistone@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-30jbd2: Use tracepoints for history fileTheodore Ts'o
The /proc/fs/jbd2/<dev>/history was maintained manually; by using tracepoints, we can get all of the existing functionality of the /proc file plus extra capabilities thanks to the ftrace infrastructure. We save memory as a bonus. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-30ext4: Use tracepoints for mb_history trace fileTheodore Ts'o
The /proc/fs/ext4/<dev>/mb_history was maintained manually, and had a number of problems: it required a largish amount of memory to be allocated for each ext4 filesystem, and the s_mb_history_lock introduced a CPU contention problem. By ripping out the mb_history code and replacing it with ftrace tracepoints, and we get more functionality: timestamps, event filtering, the ability to correlate mballoc history with other ext4 tracepoints, etc. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-29PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()Rafael J. Wysocki
pcmcia_socket_dev_suspend() doesn't use its second argument, so it may be dropped safely. This change is necessary for the subsequent yenta suspend/resume fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2009-09-28wext: add back wireless/ dir in sysfs for cfg80211 interfacesJohannes Berg
The move away from having drivers assign wireless handlers, in favour of making cfg80211 assign them, broke the sysfs registration (the wireless/ dir went missing) because the handlers are now assigned only after registration, which is too late. Fix this by special-casing cfg80211-based devices, all of which are required to have an ieee80211_ptr, in the sysfs code, and also using get_wireless_stats() to have the same values reported as in procfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Tested-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-29ext4: Adjust ext4_da_writepages() to write out larger contiguous chunksTheodore Ts'o
Work around problems in the writeback code to force out writebacks in larger chunks than just 4mb, which is just too small. This also works around limitations in the ext4 block allocator, which can't allocate more than 2048 blocks at a time. So we need to defeat the round-robin characteristics of the writeback code and try to write out as many blocks in one inode before allowing the writeback code to move on to another inode. We add a a new per-filesystem tunable, max_writeback_mb_bump, which caps this to a default of 128mb per inode. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-28drm/kms: make fb helper work for all drivers.Dave Airlie
This initialises the fb helper with the connector helper, so that the fb cmdline code works for intel as well. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-27tty: Fix regressions caused by commit b50989dcDave Young
The following commit made console open fails while booting: commit b50989dc444599c8b21edc23536fc305f4e9b7d5 Author: Alan Cox <alan@linux.intel.com> Date: Sat Sep 19 13:13:22 2009 -0700 tty: make the kref destructor occur asynchronously Due to tty release routines run in a workqueue now, error like the following will be reported while booting: INIT open /dev/console Input/output error It also causes hibernation regression to appear as reported at http://bugzilla.kernel.org/show_bug.cgi?id=14229 The reason is that now there's latency issue with closing, but when we open a "closing not finished" tty, -EIO will be returned. Fix it as per the following Alan's suggestion: Fun but it's actually not a bug and the fix is wrong in itself as the port may be closing but not yet being destructed, in which case it seems to do the wrong thing. Opening a tty that is closing (and could be closing for long periods) is supposed to return -EIO. I suspect a better way to deal with this and keep the old console timing is to split tty->shutdown into two functions. tty->shutdown() - called synchronously just before we dump the tty onto the waitqueue for destruction tty->cleanup() - called when the destructor runs. We would then do the shutdown part which can occur in IRQ context fine, before queueing the rest of the release (from tty->magic = 0 ... the end) to occur asynchronously The USB update in -next would then need a call like if (tty->cleanup) tty->cleanup(tty); at the top of the async function and the USB shutdown to be split between shutdown and cleanup as the USB resource cleanup and final tidy cannot occur synchronously as it needs to sleep. In other words the logic becomes final kref put make object unfindable async clean it up Signed-off-by: Dave Young <hidave.darkstar@gmail.com> [ rjw: Rebased on top of 2.6.31-git, reworked the changelog. ] Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl> [ Changed serial naming to match new rules, dropped tty_shutdown as per comments from Alan Stern - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-26Revert "sit: stateless autoconf for isatap"Sascha Hlusiak
This reverts commit 645069299a1c7358cf7330afe293f07552f11a5d. While the code does not actually break anything, it does not completely follow RFC5214 yet. After talking back with Fred L. Templin, I agree that completing the ISATAP specific RS/RA code, would pollute the kernel a lot with code that is better implemented in userspace. The kernel should not send RS packages for ISATAP at all. Signed-off-by: Sascha Hlusiak <contact@saschahlusiak.de> Acked-by: Fred L. Templin <Fred.L.Templin@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: move leds-clevo-mail's probe function to .devinit.text leds: Fix indentation in LEDS_LP3944 Kconfig entry leds: Fix LED names leds: Fix leds-pca9532 whitespace issues leds: fix coding style in worker thread code for ledtrig-gpio. leds: gpio-leds: fix typographics fault leds: Add WM831x status LED driver
2009-09-26Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: backlight: new driver for ADP5520/ADP5501 MFD PMICs backlight: extend event support to also support poll() backlight/eeepc-laptop: Update the backlight state when we change brightness backlight/acpi: Update the backlight state when we change brightness backlight: Allow drivers to update the core, and generate events on changes backlight: switch to da903x driver to dev_pm_ops backlight: Add support for the Avionic Design Xanthos backlight device. backlight: spi driver for LMS283GF05 LCD backlight: move hp680-bl's probe function to .devinit.text backlight: Add support for new Apple machines. backlight: mbp_nvidia_bl: add support for MacBookAir 1,1 backlight: Add WM831x backlight driver Trivial conflicts due to '#ifdef CONFIG_PM' differences in drivers/video/backlight/da903x_bl.c
2009-09-26headers: kref.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from kref.h -- not needed, linux/types.h is enough for atomic_t * remove linux/kref.h inclusion from files which do not need it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-26Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Dont use openat() perf tools: Fix buffer allocation perf tools: .gitignore += perf*.html perf tools: Handle relative paths while loading module symbols perf tools: Fix module symbol loading bug perf_event, x86: Fix 'perf sched record' crashing the machine perf_event: Update PERF_EVENT_FORK header definition perf stat: Fix zero total printouts
2009-09-26Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: modules, tracing: Remove stale struct marker signature from module_layout() tracing/workqueue: Use %pf in workqueue trace events tracing: Fix a comment and a trivial format issue in tracepoint.h tracing: Fix failure path in ftrace_regex_open() tracing: Fix failure path in ftrace_graph_write() tracing: Check the return value of trace_get_user() tracing: Fix off-by-one in trace_get_user()
2009-09-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (32 commits) ACPI: i2c-scmi: don't use acpi_device_uid() ACPI: simplify building device HID/CID list ACPI: remove acpi_device_uid() and related stuff ACPI: remove acpi_device.flags.hardware_id ACPI: remove acpi_device.flags.compatible_ids ACPI: maintain a single list of _HID and _CID IDs ACPI: make sure every acpi_device has an ID ACPI: use acpi_device_hid() when possible ACPI: fix synthetic HID for \_SB_ ACPI: handle re-enumeration, when acpi_devices might already exist ACPI: factor out device type and status checking ACPI: add acpi_bus_get_status_handle() ACPI: use acpi_walk_namespace() to enumerate devices ACPI: identify device tree root by null parent pointer, not ACPI_BUS_TYPE ACPI: enumerate namespace before adding functional fixed hardware devices ACPI: convert acpi_bus_scan() to operate on an acpi_handle ACPI: add acpi_bus_get_parent() and remove "parent" arguments ACPI: remove unnecessary argument checking ACPI: remove redundant "type" arguments ACPI: remove acpi_device_set_context() "type" argument ...
2009-09-26writeback: pass in super_block to bdi_start_writeback()Jens Axboe
Sometimes we only want to write pages from a specific super_block, so allow that to be passed in. This fixes a problem with commit 56a131dcf7ed36c3c6e36bea448b674ea85ed5bb causing writeback on all super_blocks on a bdi, where we only really want to sync a specific sb from writeback_inodes_sb(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-25ACPI: remove acpi_device_uid() and related stuffBjorn Helgaas
Nobody uses acpi_device_uid(), so this patch removes it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: remove acpi_device.flags.hardware_idBjorn Helgaas
Every acpi_device has at least one ID (if there's no _HID or _CID, we give it a synthetic or default ID). So there's no longer a need to check whether an ID exists; we can just use it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: remove acpi_device.flags.compatible_idsBjorn Helgaas
We now keep a single list of IDs that includes both the _HID and any _CIDs. We no longer need to keep track of whether the device has a _CID. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: maintain a single list of _HID and _CID IDsBjorn Helgaas
There's no need to treat _HID and _CID differently. Keeping them in a single list makes code that uses the IDs a little simpler because it can just traverse the list rather than checking "do we have a HID?", "do we have any CIDs?" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: add acpi_bus_get_status_handle()Bjorn Helgaas
Add acpi_bus_get_status_handle() so we can get the status of a namespace object before building a struct acpi_device. This removes a use of "device->flags.dynamic_status", a cached indicator of whether _STA exists. It seems simpler and more reliable to just evaluate _STA and catch AE_NOT_FOUND errors. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: identify device tree root by null parent pointer, not ACPI_BUS_TYPEBjorn Helgaas
We can identify the root of the ACPI device tree by the fact that it has no parent. This is simpler than passing around ACPI_BUS_TYPE_SYSTEM and will help remove special treatment of the device tree root. Currently, we add the root by hand with ACPI_BUS_TYPE_SYSTEM. If we traverse the tree treating the root as just another device and use acpi_get_type(), the root shows up as ACPI_TYPE_DEVICE. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: save device_type in acpi_deviceBjorn Helgaas
Most uses of the ACPI bus device_type (ACPI_BUS_TYPE_DEVICE, ACPI_BUS_TYPE_POWER, etc) are during device initialization, but we do need it later for notify handler installation, since that is different for fixed hardware devices vs. namespace devices. This patch saves the device_type in the acpi_device structure, so we can check that rather than comparing against the _HID string. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (94 commits) genetlink: fix netns vs. netlink table locking (2) 3c59x: Get rid of "Trying to free already-free IRQ" tunnel: eliminate recursion field ems_pci: fix size of CAN controllers BAR mapping for CPC-PCI v2 net: fix htmldocs sunrpc, clnt.c Phonet: error on broadcast sending (unimplemented) Phonet: fix race for port number in concurrent bind() pktgen: better scheduler friendliness pktgen: T_TERMINATE flag is unused ipv4: check optlen for IP_MULTICAST_IF option ath9k: Initialize txgain and rxgain for newer AR9287 chipsets. iwlagn: fix panic in iwl{5000,4965}_rx_reply_tx ath9k: Fix RFKILL bugs drivers/net/wireless: Use usb_endpoint_dir_out cfg80211: don't overwrite privacy setting wl12xx: fix kconfig/link errors rt2x00: fix the definition of rt2x00crypto_rx_insert_iv iwlwifi: reduce noise when skb allocation fails iwlwifi: do not send sync command while holding spinlock mac80211: fix DTIM setting ...
2009-09-25drm/kms: start adding command line interface using fb.Dave Airlie
[note this requires an fb patch posted to linux-fbdev-devel already] This uses the normal video= command line option to control the kms output setup at boot time. It is used to override the autodetection done by kms. video= normally takes a framebuffer as the first parameter, in kms it will take a connector name, DVI-I-1, or LVDS-1 etc. If no output connector is specified the mode string will apply to all connectors. The mode specification used will match down the probed modes, and if no mode is found it will add a CVT mode that matches. video=1024x768 - all connectors match a 1024x768 mode or add a CVT on video=VGA-1:1024x768, VGA-1 connector gets mode only. The same strings as used in current fb modedb.c are used, except I've added three more letters, e, D, d, e = enable, D = enable Digital, d = disable, which allow a connector to be forced into a certain state. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-24NOMMU: Fallback for is_vmalloc_or_module_addr() should be inlineDavid Howells
The NOMMU fallback for is_vmalloc_or_module_addr() should be static inline, not just static, in linux/mm.h. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Optimize the ordering of sections in RW_DATA_SECTION.Tim Abbott
The old RW_DATA_SECTION had INIT_TASK_DATA (which was more-than-PAGE_SIZE-aligned), followed by a bunch of small alignment stuff, followed by more PAGE_SIZE-aligned stuff, so you wasted memory in the middle of .data re-aligning back up to PAGE_SIZE. This patch sorts the sections by alignment requirements, which should pack them essentially optimally. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24hugetlb_file_setup(): use C, not cppAndrew Morton
Why macros are always wrong: mm/mmap.c: In function 'do_mmap_pgoff': mm/mmap.c:953: warning: unused variable 'user' also, move a couple of struct forward-decls outside `#ifdef CONFIG_HUGETLB_PAGE' - it's pointless and frequently harmful to make these conditional (eg, this patch needed `struct user_struct'). Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24genetlink: fix netns vs. netlink table locking (2)Johannes Berg
Similar to commit d136f1bd366fdb7e747ca7e0218171e7a00a98a5, there's a bug when unregistering a generic netlink family, which is caught by the might_sleep() added in that commit: BUG: sleeping function called from invalid context at net/netlink/af_netlink.c:183 in_atomic(): 1, irqs_disabled(): 0, pid: 1510, name: rmmod 2 locks held by rmmod/1510: #0: (genl_mutex){+.+.+.}, at: [<ffffffff8138283b>] genl_unregister_family+0x2b/0x130 #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8138270c>] __genl_unregister_mc_group+0x1c/0x120 Pid: 1510, comm: rmmod Not tainted 2.6.31-wl #444 Call Trace: [<ffffffff81044ff9>] __might_sleep+0x119/0x150 [<ffffffff81380501>] netlink_table_grab+0x21/0x100 [<ffffffff813813a3>] netlink_clear_multicast_users+0x23/0x60 [<ffffffff81382761>] __genl_unregister_mc_group+0x71/0x120 [<ffffffff81382866>] genl_unregister_family+0x56/0x130 [<ffffffffa0007d85>] nl80211_exit+0x15/0x20 [cfg80211] [<ffffffffa000005a>] cfg80211_exit+0x1a/0x40 [cfg80211] Fix in the same way by grabbing the netlink table lock before doing rcu_read_lock(). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24tunnel: eliminate recursion fieldEric Dumazet
It seems recursion field from "struct ip_tunnel" is not anymore needed. recursion prevention is done at the upper level (in dev_queue_xmit()), since we use HARD_TX_LOCK protection for tunnels. This avoids a cache line ping pong on "struct ip_tunnel" : This structure should be now mostly read on xmit and receive paths. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24Phonet: error on broadcast sending (unimplemented)Rémi Denis-Courmont
If we ever implement this, then we can stop returning an error. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/cpc-usb/TODO drivers/staging/cpc-usb/cpc-usb_drv.c drivers/staging/cpc-usb/cpc.h drivers/staging/cpc-usb/cpc_int.h drivers/staging/cpc-usb/cpcusb.h
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: module: don't call percpu_modfree on NULL pointer. module: fix memory leak when load fails after srcversion/version allocated module: preferred way to use MODULE_AUTHOR param: allow whitespace as kernel parameter separator module: reduce string table for loaded modules (v2) module: reduce symbol table for loaded modules (v2)
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-25module: preferred way to use MODULE_AUTHORJohannes Berg
For the longest time now we've been using multiple MODULE_AUTHOR() statements when a module has more than one author, but the comment here disagrees. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
