path: root/include
2009-09-14Merge branch 'osync_cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'osync_cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: fsync: wait for data writeout completion before calling ->fsync vfs: Remove generic_osync_inode() and sync_page_range{_nolock}() fat: Opencode sync_page_range_nolock() pohmelfs: Use new syncing helper xfs: Convert sync_page_range() to simple filemap_write_and_wait_range() ocfs2: Update syncing after splicing to match generic version ntfs: Use new syncing helpers and update comments ext4: Remove syncing logic from ext4_file_write ext3: Remove syncing logic from ext3_file_write ext2: Update comment about generic_osync_inode vfs: Introduce new helpers for syncing after writing to O_SYNC file or IS_SYNC inode vfs: Rename generic_file_aio_write_nolock ocfs2: Use __generic_file_aio_write instead of generic_file_aio_write_nolock pohmelfs: Use __generic_file_aio_write instead of generic_file_aio_write_nolock vfs: Remove syncing from generic_file_direct_write() and generic_file_buffered_write() vfs: Export __generic_file_aio_write() and add some comments vfs: Introduce filemap_fdatawait_range
2009-09-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: GFS2: Whitespace fixes GFS2: Remove unused sysfs file GFS2: Be extra careful about deallocating inodes GFS2: Remove no_formal_ino generating code GFS2: Rename eattr.[ch] as xattr.[ch] GFS2: Clean up of extended attribute support GFS2: Add explanation of extended attr on-disk format GFS2: Add "-o errors=panic|withdraw" mount options GFS2: jumping to wrong label? GFS2: free disk inode which is deleted by remote node -V2 GFS2: Add a document explaining GFS2's uevents GFS2: Add sysfs link to device GFS2: Replace assertion with proper error handling GFS2: Improve error handling in inode allocation GFS2: Add some more info to uevents GFS2: Add online uevent to GFS2
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-14vfs: Remove generic_osync_inode() and sync_page_range{_nolock}()Jan Kara
Remove these three functions since nobody uses them anymore. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce new helpers for syncing after writing to O_SYNC file or ↵Jan Kara
IS_SYNC inode Introduce new function for generic inode syncing (vfs_fsync_range) and use it from fsync() path. Introduce also new helper for syncing after a sync write (generic_write_sync) using the generic function. Use these new helpers for syncing from generic VFS functions. This makes O_SYNC writes to block devices acquire i_mutex for syncing. If we really care about this, we can make block_fsync() drop the i_mutex and reacquire it before it returns. CC: Evgeniy Polyakov <zbr@ioremap.net> CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> CC: linux-ext4@vger.kernel.org CC: tytso@mit.edu Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Rename generic_file_aio_write_nolockChristoph Hellwig
generic_file_aio_write_nolock() is now used only by block devices and raw character device. Filesystems should use __generic_file_aio_write() in case generic_file_aio_write() doesn't suit them. So rename the function to blkdev_aio_write() and move it to fs/blockdev.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Export __generic_file_aio_write() and add some commentsJan Kara
Rename __generic_file_aio_write_nolock() to __generic_file_aio_write(), add comments to write helpers explaining how they should be used and export __generic_file_aio_write() since it will be used by some filesystems. CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce filemap_fdatawait_rangeJan Kara
This simple helper saves some filesystems conversion from byte offset to page numbers and also makes the fdata* interface more complete. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14Merge branch 'x86-percpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-percpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, percpu: Collect hot percpu variables into one cacheline x86, percpu: Fix DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() x86, percpu: Add 'percpu_read_stable()' interface for cacheable accesses
2009-09-14Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/i386: Put aligned stack-canary in percpu shared_aligned section x86/i386: Make sure stack-protector segment base is cache aligned x86: Detect stack protector for i386 builds on x86_64 x86: allow "=rm" in native_save_fl() x86: properly annotate alternatives.c x86: Introduce GDT_ENTRY_INIT(), initialize bad_bios_desc statically x86, 32-bit: Use generic sys_pipe() x86: Introduce GDT_ENTRY_INIT(), fix APM x86: Introduce GDT_ENTRY_INIT() x86: Introduce set_desc_base() and set_desc_limit() x86: Remove unused patch_espfix_desc() x86: Use get_desc_base()
2009-09-11Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (87 commits) NFSv4: Disallow 'mount -t nfs4 -overs=2' and 'mount -t nfs4 -overs=3' NFS: Allow the "nfs" file system type to support NFSv4 NFS: Move details of nfs4_get_sb() to a helper NFS: Refactor NFSv4 text-based mount option validation NFS: Mount option parser should detect missing "port=" NFS: out of date comment regarding O_EXCL above nfs3_proc_create() NFS: Handle a zero-length auth flavor list SUNRPC: Ensure that sunrpc gets initialised before nfs, lockd, etc... nfs: fix compile error in rpc_pipefs.h nfs: Remove reference to generic_osync_inode from a comment SUNRPC: cache must take a reference to the cache detail's module on open() NFS: Use the DNS resolver in the mount code. NFS: Add a dns resolver for use with NFSv4 referrals and migration SUNRPC: Fix a typo in cache_pipefs_files nfs: nfs4xdr: optimize low level decoding nfs: nfs4xdr: get rid of READ_BUF nfs: nfs4xdr: simplify decode_exchange_id by reusing decode_opaque_inline nfs: nfs4xdr: get rid of COPYMEM nfs: nfs4xdr: introduce decode_sessionid helper nfs: nfs4xdr: introduce decode_verifier helper ...
2009-09-11Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (25 commits) pata_rz1000: use printk_once ahci: kill @force_restart and refine CLO for ahci_kick_engine() pata_cs5535: add pci id for AMD based CS5535 controllers ahci: Add AMD SB900 SATA/IDE controller device IDs drivers/ata: use resource_size sata_fsl: Defer non-ncq commands when ncq commands active libata: add SATA PMP revision information for spec 1.2 libata: fix off-by-one error in ata_tf_read_block() ahci: Gigabyte GA-MA69VM-S2 can't do 64bit DMA ahci: make ahci_asus_m2a_vm_32bit_only() quirk more generic dmi: extend dmi_get_year() to dmi_get_date() dmi: fix date handling in dmi_get_year() libata: unbreak TPM filtering by reorganizing ata_scsi_pass_thru() sata_sis: convert to slave_link sata_sil24: always set protocol override for non-ATAPI data commands libata: Export AHCI capabilities libata: Delegate nonrot flag setting to SCSI [libata] Add pata_rdc driver for RDC ATA devices drivers/ata: Remove unnecessary semicolons libata: remove spindown skipping and warning ...
2009-09-11Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (105 commits) ring-buffer: only enable ring_buffer_swap_cpu when needed ring-buffer: check for swapped buffers in start of committing tracing: report error in trace if we fail to swap latency buffer tracing: add trace_array_printk for internal tracers to use tracing: pass around ring buffer instead of tracer tracing: make tracing_reset safe for external use tracing: use timestamp to determine start of latency traces tracing: Remove mentioning of legacy latency_trace file from documentation tracing/filters: Defer pred allocation, fix memory leak tracing: remove users of tracing_reset tracing: disable buffers and synchronize_sched before resetting tracing: disable update max tracer while reading trace tracing: print out start and stop in latency traces ring-buffer: disable all cpu buffers when one finds a problem ring-buffer: do not count discarded events ring-buffer: remove ring_buffer_event_discard ring-buffer: fix ring_buffer_read crossing pages ring-buffer: remove unnecessary cpu_relax ring-buffer: do not swap buffers during a commit ring-buffer: do not reset while in a commit ...
2009-09-11Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (64 commits) sched: Fix sched::sched_stat_wait tracepoint field sched: Disable NEW_FAIR_SLEEPERS for now sched: Keep kthreads at default priority sched: Re-tune the scheduler latency defaults to decrease worst-case latencies sched: Turn off child_runs_first sched: Ensure that a child can't gain time over it's parent after fork() sched: enable SD_WAKE_IDLE sched: Deal with low-load in wake_affine() sched: Remove short cut from select_task_rq_fair() sched: Turn on SD_BALANCE_NEWIDLE sched: Clean up topology.h sched: Fix dynamic power-balancing crash sched: Remove reciprocal for cpu_power sched: Try to deal with low capacity, fix update_sd_power_savings_stats() sched: Try to deal with low capacity sched: Scale down cpu_power due to RT tasks sched: Implement dynamic cpu_power sched: Add smt_gain sched: Update the cpu_power sum during load-balance sched: Add SD_PREFER_SIBLING ...
2009-09-11Merge branch 'perfcounters-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) perf tools: Avoid unnecessary work in directory lookups perf stat: Clean up statistics calculations a bit more perf stat: More advanced variance computation perf stat: Use stddev_mean in stead of stddev perf stat: Remove the limit on repeat perf stat: Change noise calculation to use stddev x86, perf_counter, bts: Do not allow kernel BTS tracing for now x86, perf_counter, bts: Correct pointer-to-u64 casts x86, perf_counter, bts: Fail if BTS is not available perf_counter: Fix output-sharing error path perf trace: Fix read_string() perf trace: Print out in nanoseconds perf tools: Seek to the end of the header area perf trace: Fix parsing of perf.data perf trace: Sample timestamps as well perf_counter: Introduce new (non-)paranoia level to allow raw tracepoint access perf trace: Sample the CPU too perf tools: Work around strict aliasing related warnings perf tools: Clean up warnings list in the Makefile perf tools: Complete support for dynamic strings ...
2009-09-11Merge branch 'oprofile-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (55 commits) arch/x86/oprofile/op_model_amd.c: fix op_amd_handle_ibs() return type Revert "x86: oprofile/op_model_amd.c set return values for op_amd_handle_ibs()" x86/oprofile: Small coding style fixes x86/oprofile: Add counter reservation check for virtual counters x86/oprofile: Implement op_x86_virt_to_phys() oprofile: Adding switch counter to oprofile statistic variables x86/oprofile: Implement mux_clone() x86/oprofile: Enable multiplexing only if the model supports it x86/oprofile: Add function has_mux() to check multiplexing support x86/oprofile: Modify initialization of num_virt_counters x86/oprofile: Remove unused num_virt_controls from struct op_x86_model_spec x86/oprofile: Remove const qualifier from struct op_x86_model_spec x86/oprofile: Moving nmi_cpu_switch() in nmi_int.c x86/oprofile: Moving nmi_cpu_save/restore_mpx_registers() in nmi_int.c x86/oprofile: Moving nmi_setup_cpu_mux() in nmi_int.c x86/oprofile: Implement multiplexing setup/shutdown functions oprofile: Grouping multiplexing code in op_model_amd.c oprofile: Introduce op_x86_phys_to_virt() oprofile: Grouping multiplexing code in oprof.c oprofile: Remove oprofile_multiplexing_init() ...
2009-09-11Merge branch 'irq-threaded-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-threaded-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Do not mask oneshot edge type interrupts genirq: Support nested threaded irq handling genirq: Add buslock support genirq: Add oneshot support
2009-09-11Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: pci/intr_remapping: Allocate irq_iommu on node irq: Add irq_node() primitive irq: Make sure irq_desc for legacy irq get correct node setting genirq: Add prototype for handle_nested_irq() irq: Remove superfluous NULL pointer check in check_irq_resend() irq: Clean up by removing irqfixup MODULE_PARM_DESC() genirq: Fix comment describing suspend_device_irqs() genirq: Remove obsolete defines and typedefs
2009-09-11Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) rcu: Move end of special early-boot RCU operation earlier rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees rcu: Remove lockdep annotations from RCU's _notrace() API members rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds rcu: Add CPU-offline processing for single-node configurations rcu: Add "notrace" to RCU function headers used by ftrace rcu: Remove CONFIG_PREEMPT_RCU rcu: Merge preemptable-RCU functionality into hierarchical RCU rcu: Simplify rcu_pending()/rcu_check_callbacks() API rcu: Use debugfs_remove_recursive() simplify code. rcu: Merge per-RCU-flavor initialization into pre-existing macro rcu: Fix online/offline indication for rcudata.csv trace file rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h rcu: Renamings to increase RCU clarity rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation. rcu: Fix typo in rcu_irq_exit() comment header rcu: Make rcupreempt_trace.c look at offline CPUs ...
2009-09-11Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (32 commits) locking, m68k/asm-offsets: Rename signal defines locking: Inline spinlock code for all locking variants on s390 locking: Simplify spinlock inlining locking: Allow arch-inlined spinlocks locking: Move spinlock function bodies to header file locking, m68k: Calculate thread_info offset with asm offset locking, m68k/asm-offsets: Rename pt_regs offset defines locking, sparc: Rename __spin_try_lock() and friends locking, powerpc: Rename __spin_try_lock() and friends lockdep: Remove recursion stattistics lockdep: Simplify lock_stat seqfile code lockdep: Simplify lockdep_chains seqfile code lockdep: Simplify lockdep seqfile code lockdep: Fix missing entries in /proc/lock_chains lockdep: Fix missing entry in /proc/lock_stat lockdep: Fix memory usage info of BFS lockdep: Reintroduce generation count to make BFS faster lockdep: Deal with many similar locks lockdep: Introduce lockdep_assert_held() lockdep: Fix style nits ...
2009-09-11Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (59 commits) x86/gart: Do not select AGP for GART_IOMMU x86/amd-iommu: Initialize passthrough mode when requested x86/amd-iommu: Don't detach device from pt domain on driver unbind x86/amd-iommu: Make sure a device is assigned in passthrough mode x86/amd-iommu: Align locking between attach_device and detach_device x86/amd-iommu: Fix device table write order x86/amd-iommu: Add passthrough mode initialization functions x86/amd-iommu: Add core functions for pd allocation/freeing x86/dma: Mark iommu_pass_through as __read_mostly x86/amd-iommu: Change iommu_map_page to support multiple page sizes x86/amd-iommu: Support higher level PTEs in iommu_page_unmap x86/amd-iommu: Remove old page table handling macros x86/amd-iommu: Use 2-level page tables for dma_ops domains x86/amd-iommu: Remove bus_addr check in iommu_map_page x86/amd-iommu: Remove last usages of IOMMU_PTE_L0_INDEX x86/amd-iommu: Change alloc_pte to support 64 bit address space x86/amd-iommu: Introduce increase_address_space function x86/amd-iommu: Flush domains if address space size was increased x86/amd-iommu: Introduce set_dte_entry function x86/amd-iommu: Add a gneric version of amd_iommu_flush_all_devices ...
2009-09-11Merge branch 'core-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debug lockups: Improve lockup detection, fix generic arch fallback debug lockups: Improve lockup detection
2009-09-11cdc-phonet: autoconfigure Phonet addressRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11Phonet: back-end for autoconfigured addressesRémi Denis-Courmont
In some cases, the network device driver knows what layer-3 address the device should have. This adds support for the Phonet stack to automatically request from the driver and add that address to the network device. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11ipv6: Add IFA_F_DADFAILED flagBrian Haley
Add IFA_F_DADFAILED flag to denote an IPv6 address that has failed Duplicate Address Detection, that way tools like /sbin/ip can be more informative. 3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000 inet6 2001:db8::1/64 scope global tentative dadfailed valid_lft forever preferred_lft forever Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11net: Add DEVTYPE support for Ethernet based devicesMarcel Holtmann
The Ethernet framing is used for a lot of devices these days. Most prominent are WiFi and WiMAX based devices. However for userspace application it is important to classify these devices correctly and not only see them as Ethernet devices. The daemons like HAL, DeviceKit or even NetworkManager with udev support tries to do the classification in userspace with a lot trickery and extra system calls. This is not good and actually reaches its limitations. Especially since the kernel does know the type of the Ethernet device it is pretty stupid. To solve this problem the underlying device type needs to be set and then the value will be exported as DEVTYPE via uevents and available within udev. # cat /sys/class/net/wlan0/uevent DEVTYPE=wlan INTERFACE=wlan0 IFINDEX=5 This is similar to subsystems like USB and SCSI that distinguish between hosts, devices, disks, partitions etc. The new SET_NETDEV_DEVTYPE() is a convenience helper to set the actual device type. All device types are free form, but for convenience the same strings as used with RFKILL are choosen. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11Merge branch 'nfs-for-2.6.32'Trond Myklebust
2009-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits) crypto: sha-s390 - Fix warnings in import function crypto: vmac - New hash algorithm for intel_txt support crypto: api - Do not displace newly registered algorithms crypto: ansi_cprng - Fix module initialization crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx crypto: fips - Depend on ansi_cprng crypto: blkcipher - Do not use eseqiv on stream ciphers crypto: ctr - Use chainiv on raw counter mode Revert crypto: fips - Select CPRNG crypto: rng - Fix typo crypto: talitos - add support for 36 bit addressing crypto: talitos - align locks on cache lines crypto: talitos - simplify hmac data size calculation crypto: mv_cesa - Add support for Orion5X crypto engine crypto: cryptd - Add support to access underlaying shash crypto: gcm - Use GHASH digest algorithm crypto: ghash - Add GHASH digest algorithm for GCM crypto: authenc - Convert to ahash crypto: api - Fix aligned ctx helper crypto: hmac - Prehash ipad/opad ...
2009-09-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (377 commits) ASoC: au1x: PSC-AC97 bugfixes ALSA: dummy - Increase MAX_PCM_SUBSTREAMS to 128 ALSA: dummy - Add debug proc file ALSA: Add const prefix to proc helper functions ALSA: Re-export snd_pcm_format_name() function ALSA: hda - Use auto model for HP laptops with ALC268 codec ALSA: cs46xx - Fix minimum period size ASoC: Fix WM835x Out4 capture enumeration ALSA: Remove unneeded ifdef from sound/core.h ALSA: Remove struct snd_monitor_file from public sound/core.h ASoC: Remove unuused hw_read_t sound: oxygen: work around MCE when changing volume ALSA: dummy - Fake buffer allocations ALSA: hda/realtek: Added support for CLEVO M540R subsystem, 6 channel + digital ASoC: fix pxa2xx-ac97.c breakage ALSA: dummy - Fix the timer calculation in systimer mode ALSA: dummy - Add more description ALSA: dummy - Better jiffies handling ALSA: dummy - Support high-res timer mode ALSA: Release v1.0.21 ...
2009-09-11Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: check for registered bdi in flusher add and inode dirty writeback: add name to backing_dev_info writeback: add some debug inode list counters to bdi stats writeback: get rid of pdflush completely writeback: switch to per-bdi threads for flushing data writeback: move dirty inodes from super_block to backing_dev_info writeback: get rid of generic_sync_sb_inodes() export
2009-09-11Merge branch 'kmemleak' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'kmemleak' of git://linux-arm.org/linux-2.6: kmemleak: Improve the "Early log buffer exceeded" error message kmemleak: fix sparse warning for static declarations kmemleak: fix sparse warning over overshadowed flags kmemleak: move common painting code together kmemleak: add clear command support kmemleak: use bool for true/false questions kmemleak: Do no create the clean-up thread during kmemleak_disable() kmemleak: Scan all thread stacks kmemleak: Don't scan uninitialized memory when kmemcheck is enabled kmemleak: Ignore the aperture memory hole on x86_64 kmemleak: Printing of the objects hex dump kmemleak: Do not report alloc_bootmem blocks as leaks kmemleak: Save the stack trace for early allocations kmemleak: Mark the early log buffer as __initdata kmemleak: Dump object information on request kmemleak: Allow rescheduling during an object scanning
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (57 commits) binfmt_elf: fix PT_INTERP bss handling TPM: Fixup boot probe timeout for tpm_tis driver sysfs: Add labeling support for sysfs LSM/SELinux: inode_{get,set,notify}secctx hooks to access LSM security context information. VFS: Factor out part of vfs_setxattr so it can be called from the SELinux hook for inode_setsecctx. KEYS: Add missing linux/tracehook.h #inclusions KEYS: Fix default security_session_to_parent() Security/SELinux: includecheck fix kernel/sysctl.c KEYS: security_cred_alloc_blank() should return int under all circumstances IMA: open new file for read KEYS: Add a keyctl to install a process's session keyring on its parent [try #6] KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6] KEYS: Do some whitespace cleanups [try #6] KEYS: Make /proc/keys use keyid not numread as file position [try #6] KEYS: Add garbage collection for dead, revoked and expired keys. [try #6] KEYS: Flag dead keys to induce EKEYREVOKED [try #6] KEYS: Allow keyctl_revoke() on keys that have SETATTR but not WRITE perm [try #6] KEYS: Deal with dead-type keys appropriately [try #6] CRED: Add some configurable debugging [try #6] selinux: Support for the new TUN LSM hooks ...
2009-09-11writeback: check for registered bdi in flusher add and inode dirtyJens Axboe
Also a debugging aid. We want to catch dirty inodes being added to backing devices that don't do writeback. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: get rid of pdflush completelyJens Axboe
It is now unused, so kill it off. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: switch to per-bdi threads for flushing dataJens Axboe
This gets rid of pdflush for bdi writeout and kupdated style cleaning. pdflush writeout suffers from lack of locality and also requires more threads to handle the same workload, since it has to work in a non-blocking fashion against each queue. This also introduces lumpy behaviour and potential request starvation, since pdflush can be starved for queue access if others are accessing it. A sample ffsb workload that does random writes to files is about 8% faster here on a simple SATA drive during the benchmark phase. File layout also seems a LOT more smooth in vmstat: r b swpd free buff cache si so bi bo in cs us sy id wa 0 1 0 608848 2652 375372 0 0 0 71024 604 24 1 10 48 42 0 1 0 549644 2712 433736 0 0 0 60692 505 27 1 8 48 44 1 0 0 476928 2784 505192 0 0 4 29540 553 24 0 9 53 37 0 1 0 457972 2808 524008 0 0 0 54876 331 16 0 4 38 58 0 1 0 366128 2928 614284 0 0 4 92168 710 58 0 13 53 34 0 1 0 295092 3000 684140 0 0 0 62924 572 23 0 9 53 37 0 1 0 236592 3064 741704 0 0 4 58256 523 17 0 8 48 44 0 1 0 165608 3132 811464 0 0 0 57460 560 21 0 8 54 38 0 1 0 102952 3200 873164 0 0 4 74748 540 29 1 10 48 41 0 1 0 48604 3252 926472 0 0 0 53248 469 29 0 7 47 45 where vanilla tends to fluctuate a lot in the creation phase: r b swpd free buff cache si so bi bo in cs us sy id wa 1 1 0 678716 5792 303380 0 0 0 74064 565 50 1 11 52 36 1 0 0 662488 5864 319396 0 0 4 352 302 329 0 2 47 51 0 1 0 599312 5924 381468 0 0 0 78164 516 55 0 9 51 40 0 1 0 519952 6008 459516 0 0 4 78156 622 56 1 11 52 37 1 1 0 436640 6092 541632 0 0 0 82244 622 54 0 11 48 41 0 1 0 436640 6092 541660 0 0 0 8 152 39 0 0 51 49 0 1 0 332224 6200 644252 0 0 4 102800 728 46 1 13 49 36 1 0 0 274492 6260 701056 0 0 4 12328 459 49 0 7 50 43 0 1 0 211220 6324 763356 0 0 0 106940 515 37 1 10 51 39 1 0 0 160412 6376 813468 0 0 0 8224 415 43 0 6 49 45 1 1 0 85980 6452 886556 0 0 4 113516 575 39 1 11 54 34 0 2 0 85968 6452 886620 0 0 0 1640 158 211 0 0 46 54 A 10 disk test with btrfs performs 26% faster with per-bdi flushing. A SSD based writeback test on XFS performs over 20% better as well, with the throughput being very stable around 1GB/sec, where pdflush only manages 750MB/sec and fluctuates wildly while doing so. Random buffered writes to many files behave a lot better as well, as does random mmap'ed writes. A separate thread is added to sync the super blocks. In the long term, adding sync_supers_bdi() functionality could get rid of this thread again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: move dirty inodes from super_block to backing_dev_infoJens Axboe
This is a first step at introducing per-bdi flusher threads. We should have no change in behaviour, although sb_has_dirty_inodes() is now ridiculously expensive, as there's no easy way to answer that question. Not a huge problem, since it'll be deleted in subsequent patches. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: get rid of generic_sync_sb_inodes() exportJens Axboe
This adds two new exported functions: - writeback_inodes_sb(), which only attempts to writeback dirty inodes on this super_block, for WB_SYNC_NONE writeout. - sync_inodes_sb(), which writes out all dirty inodes on this super_block and also waits for the IO to complete. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11pata_cs5535: add pci id for AMD based CS5535 controllersOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-11ahci: Add AMD SB900 SATA/IDE controller device IDsShane Huang
Add AMD SB900 SATA/IDE controller device IDs. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-10Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-09-11Merge branch 'next' into for-linusJames Morris
2009-09-10Merge branch 'topic/ymfpci' into for-linusTakashi Iwai
* topic/ymfpci: sound: ymfpci: increase timer resolution to 96 kHz
2009-09-10Merge branch 'topic/tlv-minmax' into for-linusTakashi Iwai
* topic/tlv-minmax: ALSA: usb-audio - Correct bogus volume dB information ALSA: usb-audio - Use the new TLV_DB_MINMAX type ALSA: Add new TLV types for dBwith min/max
2009-09-10Merge branch 'topic/soundcore-preclaim' into for-linusTakashi Iwai
* topic/soundcore-preclaim: sound: make OSS device number claiming optional and schedule its removal sound: request char-major-* module aliases for missing OSS devices chrdev: implement __[un]register_chrdev()
2009-09-10Merge branch 'topic/snd-printk' into for-linusTakashi Iwai
* topic/snd-printk: ALSA: Fixed a typo of printk() ALSA: Add debug module option ALSA: core - strip too long file names in snd_print*()
2009-09-10Merge branch 'topic/pcm-drain-nonblock' into for-linusTakashi Iwai
* topic/pcm-drain-nonblock: ALSA: pcm - Increase protocol version ALSA: pcm - Fix drain behavior in non-blocking mode
2009-09-10Merge branch 'topic/misc' into for-linusTakashi Iwai
* topic/misc: ALSA: Remove unneeded ifdef from sound/core.h ALSA: Remove struct snd_monitor_file from public sound/core.h ALSA: Release v1.0.21
2009-09-10Merge branch 'topic/dummy' into for-linusTakashi Iwai
* topic/dummy: ALSA: dummy - Increase MAX_PCM_SUBSTREAMS to 128 ALSA: dummy - Add debug proc file ALSA: Add const prefix to proc helper functions ALSA: Re-export snd_pcm_format_name() function ALSA: dummy - Fake buffer allocations ALSA: dummy - Fix the timer calculation in systimer mode ALSA: dummy - Add more description ALSA: dummy - Better jiffies handling ALSA: dummy - Support high-res timer mode
2009-09-10Merge branch 'topic/dma-sgbuf' into for-linusTakashi Iwai
* topic/dma-sgbuf: ALSA: Fix SG-buffer DMA with non-coherent architectures
