This patch changes the function reserve_bootmem_node() from void to int,
returning -ENOMEM if the allocation fails.
This fixes a build problem on x86 with CONFIG_KEXEC=y and
CONFIG_NEED_MULTIPLE_NODES=y
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Reported-by: Adrian Bunk <bunk@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
netns: Don't receive new packets in a dead network namespace.
sctp: Make sure N * sizeof(union sctp_addr) does not overflow.
pppoe: warning fix
ipv6: Drop packets for loopback address from outside of the box.
ipv6: Remove options header when setsockopt's optlen is 0
mac80211: detect driver tx bugs
Alexey Dobriyan <adobriyan@gmail.com> writes:
> Subject: ICMP sockets destruction vs ICMP packets oops
> After icmp_sk_exit() nuked ICMP sockets, we get an interrupt.
> icmp_reply() wants ICMP socket.
> Steps to reproduce:
> launch shell in new netns
> move real NIC to netns
> setup routing
> ping -i 0
> exit from shell
> BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
> IP: [<ffffffff803fce17>] icmp_sk+0x17/0x30
> PGD 17f3cd067 PUD 17f3ce067 PMD 0
> Oops: 0000 [1] PREEMPT SMP DEBUG_PAGEALLOC
> CPU 0
> Modules linked in: usblp usbcore
> Pid: 0, comm: swapper Not tainted 2.6.26-rc6-netns-ct #4
> RIP: 0010:[<ffffffff803fce17>] [<ffffffff803fce17>] icmp_sk+0x17/0x30
> RSP: 0018:ffffffff8057fc30 EFLAGS: 00010286
> RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff81017c7db900
> RDX: 0000000000000034 RSI: ffff81017c7db900 RDI: ffff81017dc41800
> RBP: ffffffff8057fc40 R08: 0000000000000001 R09: 000000000000a815
> R10: 0000000000000000 R11: 0000000000000001 R12: ffffffff8057fd28
> R13: ffffffff8057fd00 R14: ffff81017c7db938 R15: ffff81017dc41800
> FS: 0000000000000000(0000) GS:ffffffff80525000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
> CR2: 0000000000000000 CR3: 000000017fcda000 CR4: 00000000000006e0
> DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> Process swapper (pid: 0, threadinfo ffffffff8053a000, task ffffffff804fa4a0)
> Stack: 0000000000000000 ffff81017c7db900 ffffffff8057fcf0 ffffffff803fcfe4
> ffffffff804faa38 0000000000000246 0000000000005a40 0000000000000246
> 000000000001ffff ffff81017dd68dc0 0000000000005a40 0000000055342436
> Call Trace:
> <IRQ> [<ffffffff803fcfe4>] icmp_reply+0x44/0x1e0
> [<ffffffff803d3a0a>] ? ip_route_input+0x23a/0x1360
> [<ffffffff803fd645>] icmp_echo+0x65/0x70
> [<ffffffff803fd300>] icmp_rcv+0x180/0x1b0
> [<ffffffff803d6d84>] ip_local_deliver+0xf4/0x1f0
> [<ffffffff803d71bb>] ip_rcv+0x33b/0x650
> [<ffffffff803bb16a>] netif_receive_skb+0x27a/0x340
> [<ffffffff803be57d>] process_backlog+0x9d/0x100
> [<ffffffff803bdd4d>] net_rx_action+0x18d/0x250
> [<ffffffff80237be5>] __do_softirq+0x75/0x100
> [<ffffffff8020c97c>] call_softirq+0x1c/0x30
> [<ffffffff8020f085>] do_softirq+0x65/0xa0
> [<ffffffff80237af7>] irq_exit+0x97/0xa0
> [<ffffffff8020f198>] do_IRQ+0xa8/0x130
> [<ffffffff80212ee0>] ? mwait_idle+0x0/0x60
> [<ffffffff8020bc46>] ret_from_intr+0x0/0xf
> <EOI> [<ffffffff80212f2c>] ? mwait_idle+0x4c/0x60
> [<ffffffff80212f23>] ? mwait_idle+0x43/0x60
> [<ffffffff8020a217>] ? cpu_idle+0x57/0xa0
> [<ffffffff8040f380>] ? rest_init+0x70/0x80
> Code: 10 5b 41 5c 41 5d 41 5e c9 c3 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 53
> 48 83 ec 08 48 8b 9f 78 01 00 00 e8 2b c7 f1 ff 89 c0 <48> 8b 04 c3 48 83 c4 08
> 5b c9 c3 66 66 66 66 66 2e 0f 1f 84 00
> RIP [<ffffffff803fce17>] icmp_sk+0x17/0x30
> RSP <ffffffff8057fc30>
> ---[ end trace ea161157b76b33e8 ]---
> Kernel panic - not syncing: Aiee, killing interrupt handler!
Receiving packets while we are cleaning up a network namespace is a
racy proposition. It is possible when the packet arrives that we have
removed some but not all of the state we need to fully process it. We
have the choice of either playing wack-a-mole with the cleanup routines
or simply dropping packets when we don't have a network namespace to
handle them.
Since the check looks inexpensive in netif_receive_skb let's just
drop the incoming packets.
Vast majority of these build failures are gcc-4.3 warnings
about static functions and objects being referenced from
non-static (read: "extern inline") functions, in conjunction
with our -Werror.
We cannot just convert "extern inline" to "static inline",
as people keep suggesting all the time, because "extern inline"
logic is crucial for generic kernel build.
So
- just make sure that all callees of critical "extern inline"
functions are also "extern inline";
- use "static inline", wherever it's possible.
traps.c: work around gcc-4.3 being too smart about array
bounds-checking.
TODO: add "gnu_inline" attribute to all our "extern inline"
functions to ensure desired behaviour with future compilers.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To calculate addresses of locally defined variables, GCC uses 32-bit
displacement from the GP. Which doesn't work for per cpu variables in
modules, as an offset to the kernel per cpu area is way above 4G.
The workaround is to force allocation of a GOT entry for per cpu variable
using ldq instruction with a 'literal' relocation.
I had to use custom asm/percpu.h, as a required argument magic doesn't
work with asm-generic/percpu.h macros.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, geode: add a VSA2 ID for General Software
x86: use BOOTMEM_EXCLUSIVE on 32-bit
x86, 32-bit: fix boot failure on TSC-less processors
x86: fix NULL pointer deref in __switch_to
x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.
[ Based upon original report and patch by Karsten Keil. Karsten
has verified that this fixes the TAHI test case "ICMPv6 test
v6LC.5.1.2 Part F". -DaveM ]
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
General Software writes their own VSA2 module for their version
of the Geode BIOS, which returns a different ID then the standard
VSA2. This was causing the framebuffer driver to break for most
GSW boards.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Cc: tglx@linutronix.de
Cc: linux-geode@lists.infradead.org
This allows other threads to run when the serial driver polls the CTS
PIN in a loop.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
When a 64-bit x86 processor runs in 32-bit PAE mode, a pte can
potentially have the same number of physical address bits as the
64-bit host ("Enhanced Legacy PAE Paging"). This means, in theory,
we could have up to 52 bits of physical address in a pte.
The 32-bit kernel uses a 32-bit unsigned long to represent a pfn.
This means that it can only represent physical addresses up to 32+12=44
bits wide. Rather than widening pfns everywhere, just set 2^44 as the
Linux x86_32-PAE architectural limit for physical address size.
This is a bugfix for two cases:
1. running a 32-bit PAE kernel on a machine with
more than 64GB RAM.
2. running a 32-bit PAE Xen guest on a host machine with
more than 64GB RAM
In both cases, a pte could need to have more than 36 bits of physical,
and masking it to 36-bits will cause fairly severe havoc.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp/intel: cleanup some serious whitespace badness
[AGP] intel_agp: Add support for Intel 4 series chipsets
[AGP] intel_agp: extra stolen mem size available for IGD_GM chipset
agp: more boolean conversions.
drivers/char/agp - use bool
agp: two-stage page destruction issue
agp/via: fixup pci ids
Use boolean in AGP instead of having own TRUE/FALSE
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits)
netlink: genl: fix circular locking
Revert "mac80211: Use skb_header_cloned() on TX path."
af_unix: fix 'poll for write'/ connected DGRAM sockets
tun: Proper handling of IPv6 header in tun driver when TUN_NO_PI is set
atl1: relax eeprom mac address error check
net/enc28j60: low power mode
net/enc28j60: section fix
sky2: 88E8040T pci device id
netxen: download firmware in pci probe
netxen: cleanup debug messages
netxen: remove global physical_port array
netxen: fix portnum for hp mezz cards
ibm_newemac: select CRC32 in Kconfig
xfrm: fix fragmentation for ipv4 xfrm tunnel
netfilter: nf_conntrack_h323: fix module unload crash
netfilter: nf_conntrack_h323: fix memory leak in module initialization error path
netfilter: nf_nat: fix RCU races
atm: [he] send idle cells instead of unassigned when in SDH mode
atm: [he] limit queries to the device's register space
atm: [br2864] fix routed vcmux support
Fix three ct_extend/NAT extension related races:
- When cleaning up the extension area and removing it from the bysource hash,
the nat->ct pointer must not be set to NULL since it may still be used in
a RCU read side
- When replacing a NAT extension area in the bysource hash, the nat->ct
pointer must be assigned before performing the replacement
- When reallocating extension storage in ct_extend, the old memory must
not be freed immediately since it may still be used by a RCU read side
Possibly fixes https://bugzilla.redhat.com/show_bug.cgi?id=449315
and/or http://bugzilla.kernel.org/show_bug.cgi?id=10875
We've introduced extra need of compat layer for ip_tunnel_prl{}
for PRL (Potential Router List) management. Though compat_ioctl
is still missing in ipv4/ipv6, let's make the interface more
straight-forward and eliminate extra need for nasty compat layer
anyway since the interface is new for 2.6.26.
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix CONFIG_IA64_SGI_UV build error
[IA64] Update check_sal_cache_flush to use platform_send_ipi()
[IA64] perfmon: fix async exit bug
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (21 commits)
[POWERPC] Turn on ATA_SFF so we get SATA_SVW back in defconfigs
[POWERPC] Remove ppc32's export of console_drivers
[POWERPC] Fix -Os kernel builds with newer gcc versions
[POWERPC] Fix bootwrapper builds with newer gcc versions
[POWERPC] Build fix for drivers/macintosh/mediabay.c
[POWERPC] Fix warning in pseries/eeh_driver.c
[POWERPC] Add missing of_node_put in drivers/macintosh/therm_adt746x.c
[POWERPC] Add missing of_node_put in drivers/macintosh/smu.c
[POWERPC] Add missing of_node_put in pseries/nvram.c
[POWERPC] Fix return value check logic in debugfs virq_mapping setup
[POWERPC] Fix rmb to order cacheable vs. noncacheable
powerpc/spufs: fix missed stop-and-signal event
powerpc/spufs: synchronize interaction between spu exception handling and time slicing
powerpc/spufs: remove class_0_dsisr from spu exception handling
powerpc/spufs: wait for stable spu status in spu_stopped()
[POWERPC] bootwrapper: add simpleImage* to list of boot targets
[POWERPC] 83xx: MPC837xRDB's VSC7385 ethernet switch isn't on the MDIO bus
[POWERPC] Updated Freescale PPC defconfigs
[POWERPC] 8610: Update defconfig for MPC8610 HPCD
[POWERPC] 85xx: MPC8548CDS - Fix size of PCIe IO space
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Au1200: MMC resource size off by one
[MIPS] TANBAC: Update defconfig
[MIPS] Vr41xx: Initialize PCI io_map_base
[MIPS] Malta: Always compile MTD platform device registration code.
[MIPS] Malta: Fix build errors for 64-bit kernels
[MIPS] Lasat: sysctl fixup
[MIPS] Fix buggy use of kmap_coherent.
[MIPS] Lasat: bring back from the dead
[MIPS] vpe_id is required for VSMP and SMTC builds
[MIPS] Export smp_call_function and smp_call_function_single.
[MIPS] Bring the SWARM defconfig up to date
[MIPS] Sibyte: Build RTC support as an object
[MIPS] Fix the fix for divide by zero error in build_{clear,copy}_page
[MIPS] Fix build for PNX platforms.
[MIPS] Add RM200 with R5000 CPU to known ARC machines
[MIPS] Better load address for big endian SNI RM
[MIPS] SB1250: Initialize io_map_base
[MIPS] Alchemy: Add au1500 reserved interrupt
[MIPS] Export empty_zero_page for sake of the ext4 module.
This seems to have been removed accidentally in commit
ed7b1889da256977574663689b598d88950bbd23 ("Unexport asm/page.h"), but
wasn't supposed to have been -- the original patch at
http://lkml.org/lkml/2007/10/30/144 just moved it from $(header-y) to
$(unifdef-y)
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
This file is only included where it makes sense now, so there's no need
for the CONFIG_ARCH_SUPPORTS_AOUT conditional -- and that conditional is
bad, because we want to export <linux/a.out.h> to userspace.
Fix build error in CONFIG_IA64_SGI_UV config. (GENERIC builds
are ok).
Signed-off-by: Jack Steiner <steiner@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Fix 64-bit Malta by using CKSEG0ADDR and correct casts.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
After the common MIPS CPU interrupt controller (for irq0-7) was introduced
the Lasat boards didn't get their interrupts right, so nothing worked. The
old routines need to be offset by the new 8 hardware interrupts common to
all MIPS CPU's.
Signed-off-by: Thomas Horsten <thomas@horsten.com>
Signed-off-by: Chris Dearman <chris@mips.com>
Build error was caused by commit 351336929ccf222ae38ff0cb7a8dd5fd5c6236a0.
In the conversion done in the commits
95c4eb3ef4484ca85da5c98780d358cffd546b90
9d360ab4a7568a8d177280f651a8a772ae52b9b9
[MIPS] Alchemy: Renumber interrupts so irq_cpu can work.
one reserved interrupt on au1500 was missed. this broke the au1000 ethernet
driver.
Signed-off-by: Bruno Randolf <br1@einfach.org>
This fixes the following build error with CONFIG_BLK_DEV_IDE_PMAC=n:
<-- snip -->
CC drivers/macintosh/mediabay.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c: In function 'check_media_bay':
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c:428: error: 'struct media_bay_info' has no member named 'cd_index'
make[3]: *** [drivers/macintosh/mediabay.o] Error 1
<-- snip -->
Signed-off-by: Adrian Bunk <bunk@kernel.org>
lwsync is explicitly defined not to have any effect on the ordering of
accesses to device memory, so it cannot be used for rmb(). sync appears
to be the only barrier which fits the bill.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jk/spufs into merge
According to the CBEA, the SPU dsisr is not updated for class 0
exceptions.
spu_stopped() is testing the dsisr that was passed to it from the class
0 exception handler, so we return a false positive here.
This patch cleans up the interrupt handler and erroneous tests in
spu_stopped. It also removes the fields from the csa since it is not
needed to process class 0 events.
Signed-off-by: Luke Browning <lukebrowning@us.ibm.com>
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fixup write combine comment in pci_mmap_resource
x86: PAT export resource_wc in pci sysfs
x86, pci-dma.c: don't always add __GFP_NORETRY to gfp
suspend-vs-iommu: prevent suspend if we could not resume
x86: pci-dma.c: use __GFP_NO_OOM instead of __GFP_NORETRY
pci, x86: add workaround for bug in ASUS A7V600 BIOS (rev 1005)
PCI: use dev_to_node in pci_call_probe
PCI: Correct last two HP entries in the bfsort whitelist
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: update my email address
parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3
parisc: fix off by one in setup_sigcontext32
parisc: export empty_zero_page
parisc: export copy_user_page_asm
parisc: move head.S to head.text section
Revert "parisc: fix trivial section name warnings"
ip_fast_csum needs an asm "memory" clobber, otherwise the aggressive
optimizations in gcc-4.3 cause it to be miscompiled.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
tcp: Revert 'process defer accept as established' changes.
ipv6: Fix duplicate initialization of rawv6_prot.destroy
bnx2x: Updating the Maintainer
net: Eliminate flush_scheduled_work() calls while RTNL is held.
drivers/net/r6040.c: correct bad use of round_jiffies()
fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUP
ipg: fix receivemode IPG_RM_RECEIVEMULTICAST{,HASH} in ipg_nic_set_multicast_list()
netfilter: nf_conntrack: fix ctnetlink related crash in nf_nat_setup_info()
netfilter: Make nflog quiet when no one listen in userspace.
ipv6: Fail with appropriate error code when setting not-applicable sockopt.
ipv6: Check IPV6_MULTICAST_LOOP option value.
ipv6: Check the hop limit setting in ancillary data.
ipv6 route: Fix route lifetime in netlink message.
ipv6 mcast: Check address family of gf_group in getsockopt(MS_FILTER).
dccp: Bug in initial acknowledgment number assignment
dccp ccid-3: X truncated due to type conversion
dccp ccid-3: TFRC reverse-lookup Bug-Fix
dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request sockets
dccp: Fix sparse warnings
dccp ccid-3: Bug-Fix - Zero RTT is possible
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5091/1: Add missing bitfield include to regs-lcd.h
[ARM] 5090/1: Correct pxafb palette typo error
[ARM] 5077/1: spi: fix list scan success verification in PXA ssp driver
We need this at least for huge page detection for now, because powerpc
needs the vm_area_struct to be able to determine whether a virtual address
is referring to a huge page (its pmd_huge() doesn't work).
It might also come in handy for some of the other users.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Add support for the next generation of HP Smart Array SAS/SATA
controllers. Shipping date is late Fall 2008.
Bump the driver version to 3.6.20 to reflect the new hardware support from
patch 1 of this set.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Move the forward-declaration of struct mm_struct a little way up
proc_fs.h. This fixes a bunch of "'struct mm_struct' declared inside
parameter list" warnings with CONFIG_PROC_FS=n
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Add ext2_find_{first,next}_bit(), which are needed for ext4. They're
derived out of the ext2_find_next_zero_bit found in the same file.
Compile tested with crosstools
[Reworked to preserve all symmetry with ext2_find_{first,next}_zero_bit()]
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10393
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87
("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and
the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38
("tcp: Fix slab corruption with ipv6 and tcp6fuzz").
This change causes several problems, first reported by Ingo Molnar
as a distcc-over-loopback regression where connections were getting
stuck.
Ilpo Järvinen first spotted the locking problems. The new function
added by this code, tcp_defer_accept_check(), only has the
child socket locked, yet it is modifying state of the parent
listening socket.
Fixing that is non-trivial at best, because we can't simply just grab
the parent listening socket lock at this point, because it would
create an ABBA deadlock. The normal ordering is parent listening
socket --> child socket, but this code path would require the
reverse lock ordering.
Next is a problem noticed by Vitaliy Gusev, he noted:
>--- a/net/ipv4/tcp_timer.c
>+++ b/net/ipv4/tcp_timer.c
>@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data)
> goto death;
>+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) {
>+ tcp_send_active_reset(sk, GFP_ATOMIC);
>+ goto death;
Here socket sk is not attached to listening socket's request queue. tcp_done()
will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should
release this sk) as socket is not DEAD. Therefore socket sk will be lost for
freeing.
Finally, Alexey Kuznetsov argues that there might not even be any
real value or advantage to these new semantics even if we fix all
of the bugs:
Hiding from accept() sockets with only out-of-order data only
is the only thing which is impossible with old approach. Is this really
so valuable? My opinion: no, this is nothing but a new loophole
to consume memory without control.
So revert this thing for now.
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip into for-linus
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: 64-bit: fix arithmetics overflow
sched: fair group: fix overflow(was: fix divide by zero)
sched: fix TASK_WAKEKILL vs SIGKILL race
Macros like Fld() or FShft used in regs-lcd.h are defined in bitfield.h, but
the latter is not included.
Also fix one whitespace issue while being there.
Signed-off-by: Antonio Ospite <ao2@openezx.org>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Eric Miao <eric.miao@marvell.com>
* 'core/iter-div' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
always_inline timespec_add_ns
add an inlined version of iter_div_u64_rem
common implementation of iterative div/mod
timespec_add_ns is used from the x86-64 vdso, which cannot call out to
other kernel code. Make sure that timespec_add_ns is always inlined
(and only uses always_inlined functions) to make sure there are no
unexpected calls.
