path: root/include
2010-07-28fanotify: use both marks when possibleEric Paris
fanotify currently, when given a vfsmount_mark will look up (if it exists) the corresponding inode mark. This patch drops that lookup and uses the mark provided. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: pass both the vfsmount mark and inode markEric Paris
should_send_event() and handle_event() will both need to look up the inode event if they get a vfsmount event. Lets just pass both at the same time since we have them both after walking the lists in lockstep. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: remove global fsnotify groups listsEric Paris
The global fsnotify groups lists were invented as a way to increase the performance of fsnotify by shortcutting events which were not interesting. With the changes to walk the object lists rather than global groups lists these shortcuts are not useful. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: remove group->maskEric Paris
group->mask is now useless. It was originally a shortcut for fsnotify to save on performance. These checks are now redundant, so we remove them. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: remove the global masksEric Paris
Because we walk the object->fsnotify_marks list instead of the global fsnotify groups list we don't need the fsnotify_inode_mask and fsnotify_vfsmount_mask as these were simply shortcuts in fsnotify() for performance. They are now extra checks, rip them out. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: send fsnotify_mark to groups in event handling functionsEric Paris
With the change of fsnotify to use srcu walking the marks list instead of walking the global groups list we now know the mark in question. The code can send the mark to the group's handling functions and the groups won't have to find those marks themselves. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: srcu to protect read side of inode and vfsmount locksEric Paris
Currently reading the inode->i_fsnotify_marks or vfsmount->mnt_fsnotify_marks lists are protected by a spinlock on both the read and the write side. This patch protects the read side of those lists with a new single srcu. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been calledEric Paris
Currently fsnotify check is mark->group is NULL to decide if fsnotify_destroy_mark() has already been called or not. With the upcoming rcu work it is a heck of a lot easier to use an explicit flag than worry about group being set to NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: store struct file not struct pathEric Paris
Al explains that calling dentry_open() with a mnt/dentry pair is only garunteed to be safe if they are already used in an open struct file. To make sure this is the case don't store and use a struct path in fsnotify, always use a struct file. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: fsnotify_add_notify_event should return an eventEric Paris
Rather than the horrific void ** argument and such just to pass the fanotify_merge event back to the caller of fsnotify_add_notify_event() have those things return an event if it was different than the event suggusted to be added. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: groups can specify their f_flags for new fdEric Paris
Currently fanotify fds opened for thier listeners are done with f_flags equal to O_RDONLY | O_LARGEFILE. This patch instead takes f_flags from the fanotify_init syscall and uses those when opening files in the context of the listener. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: check to make sure all fsnotify bits are uniqueEric Paris
This patch adds a check to make sure that all fsnotify bits are unique and we cannot accidentally use the same bit for 2 different fsnotify event types. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28inotify: force inotify and fsnotify use same bitsEric Paris
inotify uses bits called IN_* and fsnotify uses bits called FS_*. These need to line up. This patch adds build time checks to make sure noone can change these bits so they are not the same. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28inotify: allow users to request not to recieve events on unlinked childrenEric Paris
An inotify watch on a directory will send events for children even if those children have been unlinked. This patch add a new inotify flag IN_EXCL_UNLINK which allows a watch to specificy they don't care about unlinked children. This should fix performance problems seen by tasks which add a watch to /tmp and then are overrun with events when other processes are reading and writing to unlinked files they created in /tmp. https://bugzilla.kernel.org/show_bug.cgi?id=16296 Requested-by: Matthias Clasen <mclasen@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: drop the useless priority argumentEric Paris
The priority argument in fanotify is useless. Kill it. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: initialize mask in fsnotify_permEric Paris
akpm got a warning the fsnotify_mask could be used uninitialized in fsnotify_perm(). It's not actually possible but his compiler complained about it. This patch just initializes it to 0 to shut up the compiler. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: userspace interface for permission responsesEric Paris
fanotify groups need to respond to events which include permissions types. To do so groups will send a response using write() on the fanotify_fd they have open. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: permissions and blockingEric Paris
This is the backend work needed for fanotify to support the new FS_OPEN_PERM and FS_ACCESS_PERM fsnotify events. This is done using the new fsnotify secondary queue. No userspace interface is provided actually respond to or request these events. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: new fsnotify hooks and events types for access decisionsEric Paris
introduce a new fsnotify hook, fsnotify_perm(), which is called from the security code. This hook is used to allow fsnotify groups to make access control decisions about events on the system. We also must change the generic fsnotify function to return an error code if we intend these hooks to be in any way useful. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28sysctl extern cleanup: inotifyDave Young
Extern declarations in sysctl.c should be move to their own head file, and then include them in relavant .c files. Move inotify_table extern declaration to linux/inotify.h Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28dnotify: move dir_notify_enable declarationAlexey Dobriyan
Move dir_notify_enable declaration to where it belongs -- dnotify.h . Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: use unsigned char * for dentry->d_name.nameEric Paris
fsnotify was using char * when it passed around the d_name.name string internally but it is actually an unsigned char *. This patch switches fsnotify to use unsigned and should silence some pointer signess warnings which have popped out of xfs. I do not add -Wpointer-sign to the fsnotify code as there are still issues with kstrdup and strlen which would pop out needless warnings. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: intoduce a notification merge argumentEric Paris
Each group can define their own notification (and secondary_q) merge function. Inotify does tail drop, fanotify does matching and drop which can actually allocate a completely new event. But for fanotify to properly deal with permissions events it needs to know the new event which was ultimately added to the notification queue. This patch just implements a void ** argument which is passed to the merge function. fanotify can use this field to pass the new event back to higher layers. Signed-off-by: Eric Paris <eparis@redhat.com> for fanotify to properly deal with permissions events
2010-07-28fsnotify: add group prioritiesEric Paris
This introduces an ordering to fsnotify groups. With purely asynchronous notification based "things" implementing fsnotify (inotify, dnotify) ordering isn't particularly important. But if people want to use fsnotify for the basis of sycronous notification or blocking notification ordering becomes important. eg. A Hierarchical Storage Management listener would need to get its event before an AV scanner could get its event (since the HSM would need to bring the data in for the AV scanner to scan.) Typically asynchronous notification would want to run after the AV scanner made any relevant access decisions so as to not send notification about an event that was denied. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: clear all fanotify marksEric Paris
fanotify listeners may want to clear all marks. They may want to do this to destroy all of their inode marks which have nothing but ignores. Realistically this is useful for av vendors who update policy and want to clear all of their cached allows. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: allow ignored_masks to survive modifyEric Paris
Some users may want to truely ignore an inode even if it has been modified. Say you are wanting a mount which contains a log file and you really don't want any notification about that file. This patch allows the listener to do that. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: allow ignored_mask to survive modificationEric Paris
Some inodes a group may want to never hear about a set of events even if the inode is modified. We add a new mark flag which indicates that these marks should not have their ignored_mask cleared on modification. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: allow users to set an ignored_maskEric Paris
Change the sys_fanotify_mark() system call so users can set ignored_masks on inodes. Remember, if a user new sets a real mask, and only sets ignored masks, the ignore will never be pinned in memory. Thus ignored_masks can be lost under memory pressure and the user may again get events they previously thought were ignored. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: ignored_mask - excluding notificationEric Paris
The ignored_mask is a new mask which is part of fsnotify marks. A group's should_send_event() function can use the ignored mask to determine that certain events are not of interest. In particular if a group registers a mask including FS_OPEN on a vfsmount they could add FS_OPEN to the ignored_mask for individual inodes and not send open events for those inodes. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: allow marks to not pin inodes in coreEric Paris
inotify marks must pin inodes in core. dnotify doesn't technically need to since they are closed when the directory is closed. fanotify also need to pin inodes in core as it works today. But the next step is to introduce the concept of 'ignored masks' which is actually a mask of events for an inode of no interest. I claim that these should be liberally sent to the kernel and should not pin the inode in core. If the inode is brought back in the listener will get an event it may have thought excluded, but this is not a serious situation and one any listener should deal with. This patch lays the ground work for non-pinning inode marks by using lazy inode pinning. We do not pin a mark until it has a non-zero mask entry. If a listener new sets a mask we never pin the inode. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: remove fanotify.h declarationsAndreas Gruenbacher
fanotify_mark_validate functions are all needlessly declared in headers as static inlines. Instead just do the checks where they are needed for code readability. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: rename FAN_MARK_ON_VFSMOUNT to FAN_MARK_MOUNTAndreas Gruenbacher
the term 'vfsmount' isn't sensicle to userspace. instead call is 'mount. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: hooks the fanotify_mark syscall to the vfsmount codeEric Paris
Create a new fanotify_mark flag which indicates we should attach the mark to the vfsmount holding the object referenced by dfd and pathname rather than the inode itself. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: should_send_event needs to handle vfsmountsEric Paris
currently should_send_event in fanotify only cares about marks on inodes. This patch extends that interface to indicate that it cares about events that happened on vfsmounts. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: Infrastructure for per-mount watchesAndreas Gruenbacher
Per-mount watches allow groups to listen to fsnotify events on an entire mount. This patch simply adds and initializes the fields needed in the vfsmount struct to make this happen. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: vfsmount marks generic functionsEric Paris
Much like inode-mark.c has all of the code dealing with marks on inodes this patch adds a vfsmount-mark.c which has similar code but is intended for marks on vfsmounts. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify/vfsmount: add fsnotify fields to struct vfsmountAndreas Gruenbacher
This patch adds the list and mask fields needed to support vfsmount marks. These are the same fields fsnotify needs on an inode. They are not used, just declared and we note where the cleanup hook should be (the function is not yet defined) Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: split generic and inode specific mark codeEric Paris
currently all marking is done by functions in inode-mark.c. Some of this is pretty generic and should be instead done in a generic function and we should only put the inode specific code in inode-mark.c Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: Add pids to eventsAndreas Gruenbacher
Pass the process identifiers of the triggering processes to fanotify listeners: this information is useful for event filtering and logging. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: send events using readEric Paris
Send events to userspace by reading the file descriptor from fanotify_init(). One will get blocks of data which look like: struct fanotify_event_metadata { __u32 event_len; __u32 vers; __s32 fd; __u64 mask; __s64 pid; __u64 cookie; } __attribute__ ((packed)); Simple code to retrieve and deal with events is below while ((len = read(fan_fd, buf, sizeof(buf))) > 0) { struct fanotify_event_metadata *metadata; metadata = (void *)buf; while(FAN_EVENT_OK(metadata, len)) { [PROCESS HERE!!] if (metadata->fd >= 0 && close(metadata->fd) != 0) goto fail; metadata = FAN_EVENT_NEXT(metadata, len); } } Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: fanotify_mark syscall implementationEric Paris
NAME fanotify_mark - add, remove, or modify an fanotify mark on a filesystem object SYNOPSIS int fanotify_mark(int fanotify_fd, unsigned int flags, u64 mask, int dfd, const char *pathname) DESCRIPTION fanotify_mark() is used to add remove or modify a mark on a filesystem object. Marks are used to indicate that the fanotify group is interested in events which occur on that object. At this point in time marks may only be added to files and directories. fanotify_fd must be a file descriptor returned by fanotify_init() The flags field must contain exactly one of the following: FAN_MARK_ADD - or the bits in mask and ignored mask into the mark FAN_MARK_REMOVE - bitwise remove the bits in mask and ignored mark from the mark The following values can be OR'd into the flags field: FAN_MARK_DONT_FOLLOW - same meaning as O_NOFOLLOW as described in open(2) FAN_MARK_ONLYDIR - same meaning as O_DIRECTORY as described in open(2) dfd may be any of the following: AT_FDCWD: the object will be lookup up based on pathname similar to open(2) file descriptor of a directory: if pathname is not NULL the object to modify will be lookup up similar to openat(2) file descriptor of the final object: if pathname is NULL the object to modify will be the object referenced by dfd The mask is the bitwise OR of the set of events of interest such as: FAN_ACCESS - object was accessed (read) FAN_MODIFY - object was modified (write) FAN_CLOSE_WRITE - object was writable and was closed FAN_CLOSE_NOWRITE - object was read only and was closed FAN_OPEN - object was opened FAN_EVENT_ON_CHILD - interested in objected that happen to children. Only relavent when the object is a directory FAN_Q_OVERFLOW - event queue overflowed (not implemented) RETURN VALUE On success, this system call returns 0. On error, -1 is returned, and errno is set to indicate the error. ERRORS EINVAL An invalid value was specified in flags. EINVAL An invalid value was specified in mask. EINVAL An invalid value was specified in ignored_mask. EINVAL fanotify_fd is not a file descriptor as returned by fanotify_init() EBADF fanotify_fd is not a valid file descriptor EBADF dfd is not a valid file descriptor and path is NULL. ENOTDIR dfd is not a directory and path is not NULL EACCESS no search permissions on some part of the path ENENT file not found ENOMEM Insufficient kernel memory is available. CONFORMING TO These system calls are Linux-specific. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: sys_fanotify_mark declartionEric Paris
This patch simply declares the new sys_fanotify_mark syscall int fanotify_mark(int fanotify_fd, unsigned int flags, u64_mask, int dfd const char *pathname) Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: fanotify_init syscall implementationEric Paris
NAME fanotify_init - initialize an fanotify group SYNOPSIS int fanotify_init(unsigned int flags, unsigned int event_f_flags, int priority); DESCRIPTION fanotify_init() initializes a new fanotify instance and returns a file descriptor associated with the new fanotify event queue. The following values can be OR'd into the flags field: FAN_NONBLOCK Set the O_NONBLOCK file status flag on the new open file description. Using this flag saves extra calls to fcntl(2) to achieve the same result. FAN_CLOEXEC Set the close-on-exec (FD_CLOEXEC) flag on the new file descriptor. See the description of the O_CLOEXEC flag in open(2) for reasons why this may be useful. The event_f_flags argument is unused and must be set to 0 The priority argument is unused and must be set to 0 RETURN VALUE On success, this system call return a new file descriptor. On error, -1 is returned, and errno is set to indicate the error. ERRORS EINVAL An invalid value was specified in flags. EINVAL A non-zero valid was passed in event_f_flags or in priority ENFILE The system limit on the total number of file descriptors has been reached. ENOMEM Insufficient kernel memory is available. CONFORMING TO These system calls are Linux-specific. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: fanotify_init syscall declarationEric Paris
This patch defines a new syscall fanotify_init() of the form: int sys_fanotify_init(unsigned int flags, unsigned int event_f_flags, unsigned int priority) This syscall is used to create and fanotify group. This is very similar to the inotify_init() syscall. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: fscking all notification systemEric Paris
fanotify is a novel file notification system which bases notification on giving userspace both an event type (open, close, read, write) and an open file descriptor to the object in question. This should address a number of races and problems with other notification systems like inotify and dnotify and should allow the future implementation of blocking or access controlled notification. These are useful for on access scanners or hierachical storage management schemes. This patch just implements the basics of the fsnotify functions. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fanotify: FMODE_NONOTIFY and __O_SYNC in sparc conflictSigned-off-by: Wu Fengguang
sparc used the same value as FMODE_NONOTIFY so change FMODE_NONOTIFY to be something unique. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28vfs: introduce FMODE_NONOTIFYEric Paris
This is a new f_mode which can only be set by the kernel. It indicates that the fd was opened by fanotify and should not cause future fanotify events. This is needed to prevent fanotify livelock. An example of obvious livelock is from fanotify close events. Process A closes file1 This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. This creates a close event for file1. fanotify opens file1 for Listener X Listener X deals with the event and closes its fd for file1. notice a pattern? The fix is to add the FMODE_NONOTIFY bit to the open filp done by the kernel for fanotify. Thus when that file is used it will not generate future events. This patch simply defines the bit. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: rename mark_entry to just markEric Paris
previously I used mark_entry when talking about marks on inodes. The _entry is pretty useless. Just use "mark" instead. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: rename fsnotify_find_mark_entry to fsnotify_find_markEric Paris
the _entry portion of fsnotify functions is useless. Drop it. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28fsnotify: rename fsnotify_mark_entry to just fsnotify_markEric Paris
The name is long and it serves no real purpose. So rename fsnotify_mark_entry to just fsnotify_mark. Signed-off-by: Eric Paris <eparis@redhat.com>
