* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits)
perf tools: Add mode to build without newt support
perf symbols: symbol inconsistency message should be done only at verbose=1
perf tui: Add explicit -lslang option
perf options: Type check all the remaining OPT_ variants
perf options: Type check OPT_BOOLEAN and fix the offenders
perf options: Check v type in OPT_U?INTEGER
perf options: Introduce OPT_UINTEGER
perf tui: Add workaround for slang < 2.1.4
perf record: Fix bug mismatch with -c option definition
perf options: Introduce OPT_U64
perf tui: Add help window to show key associations
perf tui: Make <- exit menus too
perf newt: Add single key shortcuts for zoom into DSO and threads
perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed
perf newt: Fix the 'A'/'a' shortcut for annotate
perf newt: Make <- exit the ui_browser
x86, perf: P4 PMU - fix counters management logic
perf newt: Make <- zoom out filters
perf report: Report number of events, not samples
perf hist: Clarify events_stats fields usage
Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
* 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits)
oprofile/x86: make AMD IBS hotplug capable
oprofile/x86: notify cpus only when daemon is running
oprofile/x86: reordering some functions
oprofile/x86: stop disabled counters in nmi handler
oprofile/x86: protect cpu hotplug sections
oprofile/x86: remove CONFIG_SMP macros
oprofile/x86: fix uninitialized counter usage during cpu hotplug
oprofile/x86: remove duplicate IBS capability check
oprofile/x86: move IBS code
oprofile/x86: return -EBUSY if counters are already reserved
oprofile/x86: moving shutdown functions
oprofile/x86: reserve counter msrs pairwise
oprofile/x86: rework error handler in nmi_setup()
oprofile: update file list in MAINTAINERS file
oprofile: protect from not being in an IRQ context
oprofile: remove double ring buffering
ring-buffer: Add lost event count to end of sub buffer
tracing: Show the lost events in the trace_pipe output
ring-buffer: Add place holder recording of dropped events
tracing: Fix compile error in module tracepoints when MODULE_UNLOAD not set
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits)
rcu: remove all rcu head initializations, except on_stack initializations
rcu head introduce rcu head init on stack
Debugobjects transition check
rcu: fix build bug in RCU_FAST_NO_HZ builds
rcu: RCU_FAST_NO_HZ must check RCU dyntick state
rcu: make SRCU usable in modules
rcu: improve the RCU CPU-stall warning documentation
rcu: reduce the number of spurious RCU_SOFTIRQ invocations
rcu: permit discontiguous cpu_possible_mask CPU numbering
rcu: improve RCU CPU stall-warning messages
rcu: print boot-time console messages if RCU configs out of ordinary
rcu: disable CPU stall warnings upon panic
rcu: enable CPU_STALL_VERBOSE by default
rcu: slim down rcutiny by removing rcu_scheduler_active and friends
rcu: refactor RCU's context-switch handling
rcu: rename rcutiny rcu_ctrlblk to rcu_sched_ctrlblk
rcu: shrink rcutiny by making synchronize_rcu_bh() be inline
rcu: fix now-bogus rcu_scheduler_active comments.
rcu: Fix bogus CONFIG_PROVE_LOCKING in comments to reflect reality.
rcu: ignore offline CPUs in last non-dyntick-idle CPU check
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86/amd-iommu: Add amd_iommu=off command line option
iommu-api: Remove iommu_{un}map_range functions
x86/amd-iommu: Implement ->{un}map callbacks for iommu-api
x86/amd-iommu: Make amd_iommu_iova_to_phys aware of multiple page sizes
x86/amd-iommu: Make iommu_unmap_page and fetch_pte aware of page sizes
x86/amd-iommu: Make iommu_map_page and alloc_pte aware of page sizes
kvm: Change kvm_iommu_map_pages to map large pages
VT-d: Change {un}map_range functions to implement {un}map interface
iommu-api: Add ->{un}map callbacks to iommu_ops
iommu-api: Add iommu_map and iommu_unmap functions
iommu-api: Rename ->{un}map function pointers to ->{un}map_range
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: amiga - Floppy platform device conversion
m68k: amiga - Sound platform device conversion
m68k: amiga - Frame buffer platform device conversion
m68k: amiga - Zorro host bridge platform device conversion
m68k: amiga - Zorro bus modalias support
platform: Make platform resource input parameters const
m68k: invoke oom-killer from page fault
serial167: Kill unused variables
m68k: Implement generic_find_next_{zero_,}le_bit()
m68k: hp300 - Checkpatch cleanup
m68k: Remove trailing spaces in messages
m68k: Simplify param.h by using <asm-generic/param.h>
m68k: Remove BKL from rtc implementations
Add Amiga Zorro bus modalias and uevent support
Make the platform resource input parameters of platform_device_add_resources()
and platform_device_register_simple() const, as the resources are copied and
never modified.
When looking at a performance problem on PowerPC, I noticed some awful code
generation:
c00000000051fc98: 3b 60 00 01 li r27,1
c00000000051fca0: 3b 80 00 00 li r28,0
c00000000051fcdc: 93 61 00 70 stw r27,112(r1)
c00000000051fce0: 93 81 00 74 stw r28,116(r1)
c00000000051fce4: 81 21 00 70 lwz r9,112(r1)
c00000000051fce8: 80 01 00 74 lwz r0,116(r1)
c00000000051fcec: 7d 29 07 b4 extsw r9,r9
c00000000051fcf0: 7c 00 07 b4 extsw r0,r0
c00000000051fcf4: 7c 20 04 ac lwsync
c00000000051fcf8: 7d 60 f8 28 lwarx r11,0,r31
c00000000051fcfc: 7c 0b 48 00 cmpw r11,r9
c00000000051fd00: 40 c2 00 10 bne- c00000000051fd10
c00000000051fd04: 7c 00 f9 2d stwcx. r0,0,r31
c00000000051fd08: 40 c2 ff f0 bne+ c00000000051fcf8
c00000000051fd0c: 4c 00 01 2c isync
We create two constants, write them out to the stack, read them straight back
in and sign extend them. What a mess.
It turns out this bad code is a result of us defining atomic_t as a
volatile int.
We removed the volatile attribute from the powerpc atomic_t definition years
ago, but commit ea435467500612636f8f4fb639ff6e76b2496e4b (atomic_t: unify all
arch definitions) added it back in.
To dig up an old quote from Linus:
> The fact is, volatile on data structures is a bug. It's a wart in the C
> language. It shouldn't be used.
> Volatile accesses in *code* can be ok, and if we have "atomic_read()"
> expand to a "*(volatile int *)&(x)->value", then I'd be ok with that.
> But marking data structures volatile just makes the compiler screw up
> totally, and makes code for initialization sequences etc much worse.
And screw up it does :)
With the volatile removed, we see much more reasonable code generation:
c00000000051f5b8: 3b 60 00 01 li r27,1
c00000000051f5c0: 3b 80 00 00 li r28,0
c00000000051fc7c: 7c 20 04 ac lwsync
c00000000051fc80: 7c 00 f8 28 lwarx r0,0,r31
c00000000051fc84: 7c 00 d8 00 cmpw r0,r27
c00000000051fc88: 40 c2 00 10 bne- c00000000051fc98
c00000000051fc8c: 7f 80 f9 2d stwcx. r28,0,r31
c00000000051fc90: 40 c2 ff f0 bne+ c00000000051fc80
c00000000051fc94: 4c 00 01 2c isync
Six instructions less.
In preparation for removing volatile from the atomic_t definition, this
patch adds a volatile cast to all the atomic read functions.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
rtnetlink: make SR-IOV VF interface symmetric
sctp: delete active ICMP proto unreachable timer when free transport
tcp: fix MD5 (RFC2385) support
Now we have a set of nested attributes:
IFLA_VFINFO_LIST (NESTED)
IFLA_VF_INFO (NESTED)
IFLA_VF_MAC
IFLA_VF_VLAN
IFLA_VF_TX_RATE
This allows a single set to operate on multiple attributes if desired.
Among other things, it means a dump can be replayed to set state.
The current interface has yet to be released, so this seems like
something to consider for 2.6.34.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
TCP MD5 support uses percpu data for temporary storage. It currently
disables preemption so that same storage cannot be reclaimed by another
thread on same cpu.
We also have to make sure a softirq handler wont try to use also same
context. Various bug reports demonstrated corruptions.
Fix is to disable preemption and BH.
Reported-by: Bhaskar Dutta <bhaskie@gmail.com>
1) i_flags simply doesn't work for mount/unlink race prevention;
we may have many links to file and rm on one of those obviously
shouldn't prevent bind on top of another later on. To fix it
right way we need to mark _dentry_ as unsuitable for mounting
upon; new flag (DCACHE_CANT_MOUNT) is protected by d_flags and
i_mutex on the inode in question. Set it (with dont_mount(dentry))
in unlink/rmdir/etc., check (with cant_mount(dentry)) in places
in namespace.c that used to check for S_DEAD. Setting S_DEAD
is still needed in places where we used to set it (for directories
getting killed), since we rely on it for readdir/rmdir race
prevention.
2) rename()/mount() protection has another bogosity - we unhash
the target before we'd checked that it's not a mountpoint. Fixed.
3) ancient bogosity in pivot_root() - we locked i_mutex on the
right directory, but checked S_DEAD on the different (and wrong)
one. Noticed and fixed.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: <stable@kernel.org>
dma_sync_single_range_for_cpu() and dma_sync_single_range_for_device() use
a wrong address with a partial synchronization.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Remove all rcu head inits. We don't care about the RCU head state before passing
it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can
keep track of objects on stack.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
net: Fix FDDI and TR config checks in ipv4 arp and LLC.
IPv4: unresolved multicast route cleanup
mac80211: remove association work when processing deauth request
ar9170: wait for asynchronous firmware loading
ipv4: udp: fix short packet and bad checksum logging
phy: Fix initialization in micrel driver.
sctp: Fix a race between ICMP protocol unreachable and connect()
veth: Dont kfree_skb() after dev_forward_skb()
IPv6: fix IPV6_RECVERR handling of locally-generated errors
net/gianfar: drop recycled skbs on MTU change
iwlwifi: work around passive scan issue
arch/x86/kernel/amd_iommu.c
This reverts commit 4fd38e4595e2f6c9d27732c042a0e16b2753049c.
It causes various crashes and hangs when events are activated.
The cause is not fully understood yet but we need to revert it
because the effects are severe.
Reported-by: Stephane Eranian <eranian@google.com>
Reported-by: Lin Ming <ming.m.lin@intel.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <new-submission>
PEM:
o Would it be possible to make this bisectable as follows?
a. Insert a new patch after current patch 4/6 that
defines destroy_rcu_head_on_stack(),
init_rcu_head_on_stack(), and init_rcu_head() with
their !CONFIG_DEBUG_OBJECTS_RCU_HEAD definitions.
This patch performs this transition.
CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
CC: David S. Miller <davem@davemloft.net>
CC: akpm@linux-foundation.org
CC: mingo@elte.hu
CC: laijs@cn.fujitsu.com
CC: dipankar@in.ibm.com
CC: josh@joshtriplett.org
CC: dvhltc@us.ibm.com
CC: niv@us.ibm.com
CC: tglx@linutronix.de
CC: peterz@infradead.org
CC: rostedt@goodmis.org
CC: Valdis.Kletnieks@vt.edu
CC: dhowells@redhat.com
CC: eric.dumazet@gmail.com
CC: Alexey Dobriyan <adobriyan@gmail.com>
Implement a basic state machine checker in the debugobjects.
This state machine checker detects races and inconsistencies within the "active"
life of a debugobject. The checker only keeps track of the current state; all
the state machine logic is kept at the object instance level.
The checker works by adding a supplementary "unsigned int astate" field to the
debug_obj structure. It keeps track of the current "active state" of the object.
The only constraints that are imposed on the states by the debugobjects system
is that:
- activation of an object sets the current active state to 0,
- deactivation of an object expects the current active state to be 0.
For the rest of the states, the state mapping is determined by the specific
object instance. Therefore, the logic keeping track of the state machine is
within the specialized instance, without any need to know about it at the
debugobject level.
The current object active state is changed by calling:
debug_object_active_state(addr, descr, expect, next)
where "expect" is the expected state and "next" is the next state to move to if
the expected state is found. A warning is generated if the expected is not
found.
CC: mingo@elte.hu
CC: niv@us.ibm.com
Add a #include for mutex.h to allow SRCU to be more easily used in
kernel modules.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC.
So conditionally compile rcu_scheduler_active in order to slim down
rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is
responsible for most of the slimming.
The addition of preemptible RCU to treercu resulted in a bit of
confusion and inefficiency surrounding the handling of context switches
for RCU-sched and for RCU-preempt. For RCU-sched, a context switch
is a quiescent state, pure and simple, just like it always has been.
For RCU-preempt, a context switch is in no way a quiescent state, but
special handling is required when a task blocks in an RCU read-side
critical section.
However, the callout from the scheduler and the outer loop in ksoftirqd
still calls something named rcu_sched_qs(), whose name is no longer
accurate. Furthermore, when rcu_check_callbacks() notes an RCU-sched
quiescent state, it ends up unnecessarily (though harmlessly, aside
from the performance hit) enqueuing the current task if it happens to
be running in an RCU-preempt read-side critical section. This not only
increases the maximum latency of scheduler_tick(), it also needlessly
increases the overhead of the next outermost rcu_read_unlock() invocation.
This patch addresses this situation by separating the notion of RCU's
context-switch handling from that of RCU-sched's quiescent states.
The context-switch handling is covered by rcu_note_context_switch() in
general and by rcu_preempt_note_context_switch() for preemptible RCU.
This permits rcu_sched_qs() to handle quiescent states and only quiescent
states. It also reduces the maximum latency of scheduler_tick(), though
probably by much less than a microsecond. Finally, it means that tasks
within preemptible-RCU read-side critical sections avoid incurring the
overhead of queuing unless there really is a context switch.
Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Because synchronize_rcu_bh() is identical to synchronize_sched(),
make the former a static inline invoking the latter, saving the
overhead of an EXPORT_SYMBOL_GPL() and the duplicate code.
The rcu_scheduler_active check has been wrapped into the new
debug_lockdep_rcu_enabled() function, so update the comments to
reflect this new reality.
It is CONFIG_DEBUG_LOCK_ALLOC rather than CONFIG_PROVE_LOCKING, so fix it.
There is no need to disable lockdep after an RCU lockdep splat,
so remove the debug_lockdeps_off() from lockdep_rcu_dereference().
To avoid repeated lockdep splats, use a static variable in the inlined
rcu_dereference_check() and rcu_dereference_protected() macros so that
a given instance splats only once, but so that multiple instances can
be detected per boot.
This is controlled by a new config variable CONFIG_PROVE_RCU_REPEATEDLY,
which is disabled by default. This provides the normal lockdep behavior
by default, but permits people who want to find multiple RCU-lockdep
splats per boot to easily do so.
Requested-by: Eric Paris <eparis@redhat.com>
Tested-by: Eric Paris <eparis@redhat.com>
Merge reason: Update to Linus's latest -rc.
lock_acquired, lock_contended and lock_release now share the
same prototype and format. Let's factorize them into a lock
event class.
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Drop the nested field as we don't use it. Every nested state can
be computed from a state machine on post processing already.
Drop the waittime field from the lock_acquired event, we can
calculate it by substracting the lock_acquired event timestamp
with the matching lock_acquire one.
It is not needed and takes useless space in the traces.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/ttm: Remove the ttm_bo_block_reservation() function.
drm/ttm: Remove some leftover debug messages.
drm/radeon: async event synchronization for drmWaitVblank
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.34' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB: pxa_camera: move fifo reset direct before dma start
V4L/DVB: video: testing unsigned for less than 0
V4L/DVB: mx1-camera: compile fix
V4L/DVB: budget: Oops: "BUG: unable to handle kernel NULL pointer dereference"
V4L/DVB: ngene: Workaround for stuck DiSEqC pin
V4L/DVB: saa7146: fix regression of the av7110/budget-av driver
V4L/DVB: v4l: fix config dependencies: mxb and saa7191 are V4L2 drivers, not V4L1
V4L/DVB: feature-removal: announce videotext.h removal
V4L/DVB: V4L - vpfe capture - fix for kernel crash
V4L/DVB: gspca: make usb id 0461:0815 get handled by the right driver
V4L/DVB: gspca - stv06xx: Remove the 046d:08da from the stv06xx driver
V4L/DVB: gspca - sn9c20x: Correct onstack wait_queue_head declaration
V4L/DVB: saa7146: fix up bytesperline if it is an impossible value
V4L/DVB: V4L: vpfe_capture - free ccdc_lock when memory allocation fails
V4L/DVB: V4L - Makfile:Removed duplicate entry of davinci
V4L/DVB: omap24xxcam: potential buffer overflow
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: create rcu_my_thread_group_empty() wrapper
memcg: css_id() must be called under rcu_read_lock()
cgroup: Check task_lock in task_subsys_state()
sched: Fix an RCU warning in print_task()
cgroup: Fix an RCU warning in alloc_css_id()
cgroup: Fix an RCU warning in cgroup_path()
KEYS: Fix an RCU warning in the reading of user keys
Add group scheduling transactional APIs to struct pmu.
These APIs will be implemented in arch code, based on Peter's idea as
below.
> the idea behind hw_perf_group_sched_in() is to not perform
> schedulability tests on each event in the group, but to add the group
> as a whole and then perform one test.
> Of course, when that test fails, you'll have to roll-back the whole
> group again.
> So start_txn (or a better name) would simply toggle a flag in the pmu
> implementation that will make pmu::enable() not perform the
> schedulablilty test.
> Then commit_txn() will perform the schedulability test (so note the
> method has to have a !void return value.
> This will allow us to use the regular
> kernel/perf_event.c::group_sched_in() and all the rollback code.
> Currently each hw_perf_group_sched_in() implementation duplicates all
> the rolllback code (with various bugs).
->start_txn:
Start group events scheduling transaction, set a flag to make
pmu::enable() not perform the schedulability test, it will be performed
at commit time.
->commit_txn:
Commit group events scheduling transaction, perform the group
schedulability as a whole
->cancel_txn:
Stop group events scheduling transaction, clear the flag so
pmu::enable() will perform the schedulability test.
Reviewed-by: Stephane Eranian <eranian@google.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <1272002160.5707.60.camel@minggr.sh.intel.com>
Rename perf_event_attr::precise to perf_event_attr::precise_ip and
widen it to 2 bits. This new field describes the required precision of
the PERF_SAMPLE_IP field:
0 - SAMPLE_IP can have arbitrary skid
1 - SAMPLE_IP must have constant skid
2 - SAMPLE_IP requested to have 0 skid
3 - SAMPLE_IP must have 0 skid
And modify the Intel PEBS code accordingly. The PEBS implementation
now supports up to precise_ip == 2, where we perform the IP fixup.
Also s/PERF_RECORD_MISC_EXACT/&_IP/ to clarify its meaning, this bit
should be set for each PERF_SAMPLE_IP field known to match the actual
instruction triggering the event.
This new scheme allows for a PEBS mode that uses the buffer for more
than a single event.
Cc: Stephane Eranian <eranian@google.com>
Merge reason: Resolve patch dependency
Both Stephane and Corey reported that PERF_FORMAT_GROUP didn't work
as expected if the task the counters were attached to quit before
the read() call.
The cause is that we unconditionally destroy the grouping when we
remove counters from their context. Fix this by only doing this when
we free the counter itself.
Reported-by: Corey Ashford <cjashfor@linux.vnet.ibm.com>
LKML-Reference: <1273160566.5605.404.camel@twins>
It's unused and buggy in its current form, since it can place a bo
in the reserved state without removing it from lru lists.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
An earlier regression fix for the mxb driver (V4L/DVB: saa7146_vv: fix
regression where v4l2_device was registered too late) caused a new
regression in the av7110 driver.
Reverted the old fix and fixed the problem in the mxb driver instead.
Tested on mxb and budget-av cards.
The real problem is that the saa7146 framework has separate probe()
and attach() driver callbacks which should be rolled into one. This
is now done for the mxb driver, but others should do the same. Lack
of hardware makes this hard to do, though. I hope to get hold of some
hexium cards and then I can try to improve the framework to prevent
this from happening again.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Some RCU-lockdep splat repairs need to know whether they are running
in a single-threaded process. Unfortunately, the thread_group_empty()
primitive is defined in sched.h, and can induce #include hell. This
commit therefore introduces a rcu_my_thread_group_empty() wrapper that
is defined in rcupdate.c, thus avoiding the need to include sched.h
everywhere.
Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
ICMP protocol unreachable handling completely disregarded
the fact that the user may have locked the socket. It proceeded
to destroy the association, even though the user may have
held the lock and had a ref on the association. This resulted
in the following:
Attempt to release alive inet socket f6afcc00
[ BUG: held lock freed! ]
somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held
there!
(sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
1 lock held by somenu/2672:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
stack backtrace:
Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55
Call Trace:
[<c1232266>] ? printk+0xf/0x11
[<c1038553>] debug_check_no_locks_freed+0xce/0xff
[<c10620b4>] kmem_cache_free+0x21/0x66
[<c1185f25>] __sk_free+0x9d/0xab
[<c1185f9c>] sk_free+0x1c/0x1e
[<c1216e38>] sctp_association_put+0x32/0x89
[<c1220865>] __sctp_connect+0x36d/0x3f4
[<c122098a>] ? sctp_connect+0x13/0x4c
[<c102d073>] ? autoremove_wake_function+0x0/0x33
[<c12209a8>] sctp_connect+0x31/0x4c
[<c11d1e80>] inet_dgram_connect+0x4b/0x55
[<c11834fa>] sys_connect+0x54/0x71
[<c103a3a2>] ? lock_release_non_nested+0x88/0x239
[<c1054026>] ? might_fault+0x42/0x7c
[<c11847ab>] sys_socketcall+0x6d/0x178
[<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c1002959>] syscall_call+0x7/0xb
This was because the sctp_wait_for_connect() would aqcure the socket
lock and then proceed to release the last reference count on the
association, thus cause the fully destruction path to finish freeing
the socket.
The simplest solution is to start a very short timer in case the socket
is owned by user. When the timer expires, we can do some verification
and be able to do the release properly.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
FEC: Fix kernel panic in fec_set_mac_address.
ipv6: Fix default multicast hops setting.
net: ep93xx_eth stops receiving packets
drivers/net/phy: micrel phy driver
dm9601: fix phy/eeprom write routine
ppp_generic: handle non-linear skbs when passing them to pppd
ppp_generic: pull 2 bytes so that PPP_PROTO(skb) is valid
net: fix compile error due to double return type in SOCK_DEBUG
net/usb: initiate sync sequence in sierra_net.c driver
net/usb: remove default in Kconfig for sierra_net driver
r8169: Fix rtl8169_rx_interrupt()
e1000e: Fix oops caused by ASPM patch.
net/sb1250: register mdio bus in probe
sctp: Fix skb_over_panic resulting from multiple invalid parameter errors (CVE-2010-1173) (v4)
p54pci: fix bugs in p54p_check_tx_ring
Expand task_subsys_state()'s rcu_dereference_check() to include the full
locking rule as documented in Documentation/cgroups/cgroups.txt by adding
a check for task->alloc_lock being held.
This fixes an RCU false positive when resuming from suspend. The warning
comes from freezer cgroup in cgroup_freezing_or_frozen().
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
Using a single list for all userspace devices leads to a dead lock
on multiplexed buses in some circumstances (mux chip instantiated
from userspace). This is solved by using a separate list for each
bus segment.
Acked-by: Michael Lawnick <ml.lawnick@gmx.de>
Fix this one:
include/net/sock.h: error: two or more data types in declaration specifiers
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
The breakpoint generic layer assumes that archs always know in advance
the static number of address registers available to host breakpoints
through the HBP_NUM macro.
However this is not true for every archs. For example Arm needs to get
this information dynamically to handle the compatiblity between
different versions.
To solve this, this patch proposes to drop the static HBP_NUM macro
and let the arch provide the number of available slots through a
new hw_breakpoint_slots() function. For archs that have
CONFIG_HAVE_MIXED_BREAKPOINTS_REGS selected, it will be called once
as the number of registers fits for instruction and data breakpoints
together.
For the others it will be called first to get the number of
instruction breakpoint registers and another time to get the
data breakpoint registers, the targeted type is given as a
parameter of hw_breakpoint_slots().
Reported-by: Will Deacon <will.deacon@arm.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Cc: K. Prasad <prasad@linux.vnet.ibm.com>
Cc: Jason Wessel <jason.wessel@windriver.com>
There are two outstanding fashions for archs to implement hardware
breakpoints.
The first is to separate breakpoint address pattern definition
space between data and instruction breakpoints. We then have
typically distinct instruction address breakpoint registers
and data address breakpoint registers, delivered with
separate control registers for data and instruction breakpoints
as well. This is the case of PowerPc and ARM for example.
The second consists in having merged breakpoint address space
definition between data and instruction breakpoint. Address
registers can host either instruction or data address and
the access mode for the breakpoint is defined in a control
register. This is the case of x86 and Super H.
This patch adds a new CONFIG_HAVE_MIXED_BREAKPOINTS_REGS config
that archs can select if they belong to the second case. Those
will have their slot allocation merged for instructions and
data breakpoints.
The others will have a separate slot tracking between data and
