path: root/include
2012-07-20ENGR00210075-3 - SPDC: Add Sipix driverFugang Duan
Add Sipix driver for electronic paper dispaly - Support RGB565 & Y4 formats with 800x600 resolution - Support synchronization update by waiting the last request update completed. - Support automated update using Linux deferred io mechanism - Support for panning(y-direction) - Support rotation with 90,180,and 270 degree. - Initial integration with ePXP, output Y4 format - Support specific waveform modes update. - Support Snapshot, Queue and Queue Merge update sheeme. - Support full and partial EPD screen updates. mode_1 & mode_2: partial update mode_0 & mode_3: full update - Align waveform mode with EPDC as below: mode_init = mode_0; mode_gc4 = mode_2; mode_A2 = mode_4, mode_du =mode_4; mode_gc8 = mode_1, mode_gc16 = mode_1, mode_gc32 = mode_1; Signed-off-by: Fugang Duan <B38611@freescale.com>
2012-07-20ENGR00209062-2: mx6dq and mx6dl dual camera supportWu Guoxing
dual camera support for mx6q and mx6dl: 1. let mipi and parallel camera working on different csi 2. the two camera can work independently and synchronously 3. the two camera will be registered and different video device(/dev/video0, /dev/video1) 4. when both camera are working, the can not use the same ipu channel, that is, when camera one using PRP_ENC_MEM or PRP_VF_MEM channel, the other one can only use CSI_MEM this is the driver part. Signed-off-by: Wu Guoxing <b39297@freescale.com>
2012-07-20ENGR00209978-2: imx6sl: lcdif: update driver partRobby Cai
- use new console lock/unlock Board Rework Needed: - remove R572, R569, R611 to eliminate conflict with FEC modules. Signed-off-by: Robby Cai <R63905@freescale.com>
2012-07-20ENGR00182769 HDMI: No sound when playing audio in 480p modeSandor Yu
It is cause by HDMI audio driver can't get right pixel clock from IPU driver if pixel clock source from HSP clock not from DI clock. HDMI driver get pixel clock by call clk_get_rate() function, but the function return actually clock, in some videomode the actually pixel clock is not right equal the pixel clock in CEA spec. Get pixel clock from video mode struct instead of CCM register. 480P HDMI audio can work. Signed-off-by: Sandor Yu <R01008@freescale.com>
2012-07-20ENGR00209570 - PxP : Add Y4 output format.Fugang Duan
- Add Y4 output format for SPDC. Signed-off-by: Fugang Duan <B38611@freescale.com>
2012-07-20ENGR00181094-4: MAX8903: improve battery charger driverRong Dian
1.change the battery driver's name to sabresd_battery.c ,it means this driver is only special for sabersd boards. 2.fix battery charger function bugs and improve driver code. Signed-off-by: Rong Dian <b38775@freescale.com>
2012-07-20ENGR00181094-2: MAX8903: Add battery charger driverRong Dian
Add battery charger driver on SABRESD_rev.B board. Signed-off-by: Rong Dian <b38775@freescale.com>
2012-07-20ENGR00179601 Synopsys approved hdmi fifo workaround - rev 3Alan Tull
This patch includes some of the clk enable/disable changes from rev2 Check the version of the HDMI IP to determine whether the fifo threshold needs to be high. The i.Mx6dl version of the HDMI doesn't need the workaround. All other parts of the workaround are used for both parts for code simplicity. ---------------------------------------------------------- For i.Mxq, set the Threshold of audio fifo as: FIFO depth - 2 (fixed and independent of the number of channels actually used). Use unspecified length ahb bursts (using fixed INCRx will make the audio dma fail). Additionally and in order to get it working on all conditions it will be necessary to run the following sw steps at startup of video and audio (or when video changes or audio changes): 1-Configure AUD_N1 and AUD_CTS1 registers with final value and let the AUD_N2, AUD_N3, AUD_CTS2 and AUD_CTS3 to 0s. 2-Configure start and end addresses of audio DMA registers. 3-Start DMA operation 4-Configure the AUD_CTS2 and AUD_CTS3 with the final value. 5-Configure the AUD_N2 and AUD_N3 with final value. Signed-off-by: Alan Tull <r80115@freescale.com>
2012-07-20ENGR00179513-2 IPU: Add TILED_NV12_FRAME_SIZE macro for consistencyWayne Zou
VPU needs 4K align buffer address for tiled format data output. Use this macro for IPU/V4L2/Apps to calculate the frame/field size. Signed-off-by: Wayne Zou <b36644@freescale.com>
2012-07-20ENGR00179284-1 support ONFI NAND device on mx6q_arm2_pop boardAllen Xu
Add a platform data to indicate whether the board support ONFI nand Signed-off-by: Allen Xu <allen.xu@freescale.com>
2012-07-20ENGR00179123 AMFM I2C module to ARD platform for IMX6Q and IMX6DLAlejandro Sierra
Basic I2C module integration of AMFM module to ARD platform IMX6Q and IMX6DL rev A and rev B boards. Supported for kernel 3.0.15. Signed-off-by: Alejandro Sierra <b18039@freescale.com>
2012-07-20ENGR00178875-2 VDOA: Add vdoa support on i.MX6 SOC platformWayne Zou
Add tiled format macros: IPU_PIX_FMT_TILED_NV12 and IPU_PIX_FMT_TILED_NV12F Signed-off-by: Wayne Zou <b36644@freescale.com>
2012-07-20ENGR00179077 ASRC:delete unused variableChen Liangjun
Delete unused variable busy_lock in mxc_asrc.h. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00177281-5 WM8962: add record featureGary Zhang
1. add amic and dmic support. 2. update wm8962 codec driver Signed-off-by: Gary Zhang <b13634@freescale.com>
2012-07-20ENGR00178290-2 mmc: sdhci: introduce QUIRK_BROKEN_AUTO_CMD23 for mx6Dong Aisheng
We observed a few commands timeout when using auto cmd23. The root cause is still unkonwn. This patch is a workaround to not use auto cmd23 temporarily. Signed-off-by: Dong Aisheng <b29396@freescale.com>
2012-07-20ENGR00177302 ASRC: change clock managementChen Liangjun
1 close clock when asrc is not working. 2 enable the asrc core clock when user sucessfully request an ASRC pair and disable it when the pair is release.So the call from ESAI using the p2p DMA mode can be support. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00176177-2 Add irq count mechanism to interactive governorAnson Huang
Add irq count to CPUFreq as a freq change condition. Because some devices' working mode is unable to issue CPUFreq change because of low CPU loading, but the cpu freq will impact these devices' performace significantly. Interactive govervor will sample the cpu loading as well as the irq count which is registered. If the loading or the irq count exceed the threshold we set, governor will issue an CPUFreq change request. These devices' irq threshold and enable/disable can be modified via /sys/devices/system/cpu/cpufreq/interactive/irq_scaling echo 0xAABBBC to change the default setting as below AA : irq number BBB: threshold C :enable or disable Currently only enable USDHC3, USDHC4, GPU, SATA and USB by default, we can add device to the init struct which is located in arch/arm/mach-mx6/irq.c. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-07-20ENGR00177745-1 Add interactive cpufreq governorAnson Huang
cpufreq: interactive: New 'interactive' governor This governor is designed for latency-sensitive workloads, such as interactive user interfaces. The interactive governor aims to be significantly more responsive to ramp CPU quickly up when CPU-intensive activity begins. Existing governors sample CPU load at a particular rate, typically every X ms. This can lead to under-powering UI threads for the period of time during which the user begins interacting with a previously-idle system until the next sample period happens. The 'interactive' governor uses a different approach. Instead of sampling the CPU at a specified rate, the governor will check whether to scale the CPU frequency up soon after coming out of idle. When the CPU comes out of idle, a timer is configured to fire within 1-2 ticks. If the CPU is very busy from exiting idle to when the timer fires then we assume the CPU is underpowered and ramp to MAX speed. If the CPU was not sufficiently busy to immediately ramp to MAX speed, then the governor evaluates the CPU load since the last speed adjustment, choosing the highest value between that longer-term load or the short-term load since idle exit to determine the CPU speed to ramp to. A realtime thread is used for scaling up, giving the remaining tasks the CPU performance benefit, unlike existing governors which are more likely to schedule rampup work to occur after your performance starved tasks have completed. The tuneables for this governor are: /sys/devices/system/cpu/cpufreq/interactive/min_sample_time: The minimum amount of time to spend at the current frequency before ramping down. This is to ensure that the governor has seen enough historic CPU load data to determine the appropriate workload. /sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load The CPU load at which to ramp to max speed. Signed-off-by: Anson Huang <b20788@freescale.com>
2012-07-20ENGR00171874 fix ASRC noise bug for i.MX6Chen Liangjun
Solve the ASRC noise: 1 change the DMA mode from normal mode to loop mode. 2 use dma_alloc_coherent alloc dma buffer instead of kzalloc. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00176299-3 usb host suspend/resume can't work randomlyTony LIU
head file part Signed-off-by: Tony LIU <junjie.liu@freescale.com>
2012-07-20ENGR00176649-1 sabrelite_SD ARD pfuze: update pfuze driver for pfuze100 1.0Robin Gong
Since some power rail is differnet between pfuze100 0.1 and pfuze100 1.0, remove PFUZE100_FIRST_VERSION and change PFUZE100_SW4_VOL6 define. Signed-off-by: Robin Gong <b38343@freescale.com>
2012-07-20ENGR00176147-3: usb: change data types for wakeup_eventPeter Chen
In order to know which wakeup event occurs for usb wakeup Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-07-20ENGR00176061-2 usb: otg: add discharge vbus flagPeter Chen
Add discharge vbus flag Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-07-20ENGR00175864 [MMC]pipeline mmc requestsTony Lin
the patch is based on a series of patches by Per Forlin the patch is sdhci host side implementation. using a toshiba SDHC3.0 card, the performance increases from 48.5MB/s to 52.4MB/s. cmd: dd if=/dev/mmcblk0 of=/dev/null bs=1M count=500 the performance results running@1GHz, 200MHz CPU freq are: 52.4MB/s -> 20.7MB/s Signed-off-by: Tony Lin <tony.lin@freescale.com>
2012-07-20ENGR00170526-2 AUDIO: Remove struct field rst_gpio to audio platform dataLionel Xu
Remove rst_gpio field to mxc_audio_platform_data. Signed-off-by: Lionel Xu <Lionel.Xu@freescale.com>
2012-07-20mmc: queue: let host controllers specify maximum discard timeoutAdrian Hunter
Some host controllers will not operate without a hardware timeout that is limited in value. However large discards require large timeouts, so there needs to be a way to specify the maximum discard size. A host controller driver may now specify the maximum discard timeout possible so that max_discard_sectors can be calculated. However, for eMMC when the High Capacity Erase Group Size is not in use, the timeout calculation depends on clock rate which may change. For that case Preferred Erase Size is used instead. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-20mmc: block: allow get_card_status() to return error statusRussell King - ARM Linux
If the MMC_SEND_STATUS command is not successful, we should not return a zero status word, but instead allow the caller to know positively that an error occurred. Convert the open-coded get_card_status() to use the helper function, and provide definitions for the card state field. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-20mmc: core: add non-blocking mmc request functionPer Forlin
Previously there has only been one function mmc_wait_for_req() to start and wait for a request. This patch adds: * mmc_start_req() - starts a request wihtout waiting If there is on ongoing request wait for completion of that request and start the new one and return. Does not wait for the new command to complete. This patch also adds new function members in struct mmc_host_ops only called from core.c: * pre_req - asks the host driver to prepare for the next job * post_req - asks the host driver to clean up after a completed job The intention is to use pre_req() and post_req() to do cache maintenance while a request is active. pre_req() can be called while a request is active to minimize latency to start next job. post_req() can be used after the next job is started to clean up the request. This will minimize the host driver request end latency. post_req() is typically used before ending the block request and handing over the buffer to the block layer. Add a host-private member in mmc_data to be used by pre_req to mark the data. The host driver will then check this mark to see if the data is prepared or not. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Venkatraman S <svenkatr@ti.com> Tested-by: Sourav Poddar <sourav.poddar@ti.com> Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-20plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-07-20ENGR00175221-02 [MX6] MMCSD: clear EXE_TUNE bit after tuning finishes.Ryan QIAN
- add hook for post tuning in common code - add hook for post tuning for platform code to deal with clean up stuff on finishing tuning. Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-07-20ENGR00174734-3 usb: change function name for discharge data linePeter Chen
In order to reflect the function well, it needs to discharge both dp and dm, so change the function name. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-07-20ENGR00171079-3 fsl_devices add generic audio codec platform dataAdrian Alonso
* Add generic audio codec platform_data to be able to pass specific settings to audio codecs found in Freescale target boards. * cs42888 get this platform data to override specific settings Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2012-07-20ENGR00173964 make hdmi audio init dependent on hdmi video initAlan Tull
Don't show hdmi as an audio playback device if hdmi isn't configured on the command line. Signed-off-by: Alan Tull <r80115@freescale.com>
2012-07-20ENGR00174747 ASRC:fix spinlock bugChen Liangjun
When use clk_enable and clk_disable function, system may enter sleep. so these 2 funciton can not used surrounding with spin lock/unlock. And the clk_enable/disable function already keep the counter of open and close and it is no need to keep the counter in driver. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00174732 ASRC:close core clock if ASRC idleChen Liangjun
Close ASRC core clock when ASRC device is not used. Open ASRC core clock when an ASRC device is open. Close ASRC core clock when an ASRC device is close. Signed-off-by: Chen Liangjun <b36089@freescale.com>
2012-07-20ENGR00174106-3 - EPDC fb: Support EPDC v2.0Danny Nold
- Added new register definitions for EPDCv2.0 - Added support for 64 LUTs - Conditionalized code for EPDC versions 1.0, 2.0, and 2.1 - Support for EPDC auto-waveform selection - Support for collision test mode - Support for PxP bypassing - Support for LUT cancellation - Support for new PxP limitations - Support for collision minimization EPDC feature - Added workaround for collision status bug (can't clear IRQ before reading collision status for LUTs 16-63) Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-07-20ENGR00174299-1: driver part: Add ePxP v2 DMAENGINE driverRobby Cai
add ePxP v2 DMAENGINE driver Signed-off-by: Robby Cai <R63905@freescale.com>
2012-07-20ENGR00174121-1 power: max8903 add support for dcm always high.Zhang Jiejing
add this to support MX6Q_SABRESD board hardware design. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-07-20ENGR00174128-3 Revert "Remove the discharge for VBUS and DP -3"Peter Chen
This reverts commit cc9616316bf044382ec422da5a6d4ed007235a3d. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2012-07-20ENGR00174037-3 Add HSIC suspend/resume featureTony LIU
head file Signed-off-by: Tony LIU <junjie.liu@freescale.com>
2012-07-20ENGR00172342-2 EDID parse audio data blocksAlan Tull
Add functionality to parse Audio Data Blocks from EDID data to find out what modes of LPCM are suppored by the HDMI sink device. The parsed settings are saved in the hdmi mfd. The HDMI audio driver will check the settings when the audio stream is opened and will then apply appropriate constraints. If we are unable to read from the EDID, then we default to supporting Basic Audio as defined by the HDMI specification (stereo, 16 bit, 32KHz, 44.1KHz, 48KHz PCM). Signed-off-by: Alan Tull <r80115@freescale.com>
2012-07-20ENGR00173864 MX6Q ipu capture: add multi camera switchYuxi Sun
Add IOCTRL command V4L2_CID_MXC_SWITCH_CAM for multi camera switch Signed-off-by: Yuxi Sun <b36102@freescale.com>
2012-07-20ENGR00174038 [mx6 mmc]fix build errTony Lin
fix build error: incompatible pointer type Signed-off-by: Tony Lin <tony.lin@freescale.com>
2012-07-20ENGR00174031 [MX6Q] Support AR6003 SDIO wifi on kernel v3.0Ryan QIAN
- add macros and struct used in new ath6kl. Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-07-20ENGR00173947-1 mtd/gpmi : add BBT support to gpmi nand driverHuang Shijie
Add a new field to gpmi_nand_platform_data{}. Make the BBT support to board specific. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20ENGR00173731-1 mxs-dma : rename the dma.h for mxs-dmaHuang Shijie
Move the header to a more common place. The mxs dma engine is not only used in mx23/mx28, but also used in mx50/mx6q. It will also be used in the future chips. rename it to mxs-dma.h Acked-by: Lily Zhang <r58066@freescale.com> Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20ENGR00173288-02 merge "[MX6Q]add SDHC3.0 support on uSDHC controller"Ryan QIAN
ENGR152547-03 [MX6Q]add SDHC3.0 support on uSDHC controller add voltage switch function due to SDHC3.0 spec requirement add tuning function due to SDHC3.0 spec requirement extend some functions to support SDR50 & SDR104 speed mode - adjust the sequence of current_limit and bus_speed_mode - add FSL specific tuning procedure Signed-off-by: Ryan QIAN <b32804@freescale.com>
2012-07-20ENGR00173397 MTD: add NAND_BBT_USE_FLASH macroHuang Shijie
add the new macro to fix a compiling error. Signed-off-by: Huang Shijie <b32955@freescale.com>
2012-07-20mtd: abstract last MTD partition parser argumentDmitry Eremin-Solenikov
Encapsulate last MTD partition parser argument into a separate structure. Currently it holds only 'origin' field for RedBoot parser, but will be extended in future to contain at least device_node for OF devices. Amended commentary to make kerneldoc happy Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2012-07-20mtd: add new API for handling MTD registrationDmitry Eremin-Solenikov
Lots (nearly all) mtd drivers contain nearly the similar code that calls parse_mtd_partitions, provides some platform-default values, if parsing fails, and registers mtd device. This is an aim to provide single implementation of this scenario: mtd_device_parse_register() which will handle all this parsing and defaults. Artem: amended comments Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
