It's for migrating to generic clk framework API.
The helper functions help cases clk_enable/clk_disable is used
in non-atomic context.
For example, Call clk_enable in probe and clk_disable in remove.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
As discussed previously, there's the need on some platforms to run some
parts of clk_enable() in contexts which can schedule. The solution
which was agreed upon was to provide clk_prepare() and clk_unprepare()
to contain this parts, while clk_enable() and clk_disable() perform
the atomic part.
This patch provides a common definition for clk_prepare() and
clk_unprepare() in linux/clk.h, and provides an upgrade path for
existing implementation and drivers: drivers can start using
clk_prepare() and clk_unprepare() once this patch is merged without
having to wait for platform support. Platforms can then start to
provide these additional functions.
Eventually, HAVE_CLK_PREPARE will be removed from the kernel, and
everyone will have to provide these new APIs.
Acked-by: Saravana Kannan <skannan@codeaurora.org>
fixup usage of dma direction by introducing dma_transfer_direction,
this patch moves dma/drivers/* to use new enum
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Mika Westerberg <mika.westerberg@iki.fi>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Zhang Wei <zw@zh-kernel.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Shawn Guo <shawn.guo@freescale.com>
Cc: Yong Wang <yong.y.wang@intel.com>
Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com>
Cc: Boojin Kim <boojin.kim@samsung.com>
Cc: Barry Song <Baohua.Song@csr.com>
Acked-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
Before dma_transfer_direction was introduced to replace
dma_data_direction, some dmaengine device uses DMA_NONE of
dma_data_direction for some talk with its client drivers.
The mxs-dma and its clients mxs-mmc and gpmi-nand are such case.
This patch adds DMA_TRANS_NONE to dma_transfer_direction and
migrate the DMA_NONE use in mxs-dma to it.
It also fixes the compile warning below.
CC drivers/dma/mxs-dma.o
drivers/dma/mxs-dma.c: In function ‘mxs_dma_prep_slave_sg’:
drivers/dma/mxs-dma.c:420:16: warning: comparison between ‘enum dma_transfer_direction’ and ‘enum dma_data_direction’
The implicit presence of module.h and all its sub-includes was
masking these implicit header usages:
include/linux/dmaengine.h:684: warning: 'struct page' declared inside parameter list
include/linux/dmaengine.h:684: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/dmaengine.h:687: warning: 'struct page' declared inside parameter list
include/linux/dmaengine.h:736:2: error: implicit declaration of function 'bitmap_zero'
With input from Stephen Rothwell <sfr@canb.auug.org.au>
This new enum removes usage of dma_data_direction for dma direction. The new
enum cleans tells the DMA direction and mode
This further paves way for merging the dmaengine _prep operations and also for
interleaved dma
Suggested-by: Jassi Brar <jaswinder.singh@linaro.org>
Reviewed-by: Barry Song <Baohua.Song@csr.com>
Commit 90b44f8 introduces dmaengine_prep_slave_single API which adds
scatterlist.h in dmaengine.h, so defining struct scatterlist is not required
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
For clients which require a single slave transfer and dont want to be bothered
about the scatterlist api, this helper gives simple API for this transfer and
creates single scatterlist for DMA API
Idea from Russell King
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
ENGR126228 eMMC: Configure boot_partition_enable
Enable the configurations of the boot enable on the eMMC cards.
Add the interface that used to configure the boot_bus_width
In order to make sure that the re-read the ext-csd of card
can be completed successfully, add the method to wait for
the finish of the busy state.
NOTE:
The following are the valid inputs when configure the boot
bus width of the eMMC cards.
| Bit7 Bit6 Bit5 | Bit4 Bit3 | Bit2 | Bit1 Bit0 |
| X | BOOT_MODE | RESET_BOOT_BUS_WIDTH | BOOT_BUS_WIDTH |
Bit [4:3] : BOOT_MODE (non-volatile)
0x0 : Use single data rate + backward compatible timings in boot
operation (default)
0x1 : Use single data rate + high speed timings in boot operation mode
0x2 : Use dual data rate in boot operation
0x3 : Reserved
Bit [2]: RESET_BOOT_BUS_WIDTH (non-volatile)
0x0 : Reset bus width to x1, single data rate and backward compatible
timings after boot operation (default)
0x1 : Retain boot bus width and boot mode after boot operation
Bit[1:0] : BOOT_BUS_WIDTH (non-volatile)
0x0 : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
0x1 : x4 (sdr/ddr) bus width in boot operation mode
0x2 : x8 (sdr/ddr) bus width in boot operation mode
0x3 : Reserved
partitions of the eMMC cards.
| Bit7 | Bit6 | Bit5 Bit4 Bit3 | Bit2 Bit1 Bit0 |
| X | BOOT_ACK | BOOT_PARTITION_ENABLE | PARTITION_ACCESS |
Bit7: Reserved
Bit6: always set to vaule '1' when boot_part is enabled
Bit[5:3]:
0x0 : Device not boot enabled (default)
0x1 : Boot partition 1 enabled for boot
0x2 : Boot partition 2 enabled for boot
0x7 : User area enabled for boot
Bit[2:0]:
0x0 : No access to boot partition (default)
0x1 : R/W boot partition 1
0x2 : R/W boot partition 2
So only the '0, 1, 2; 8, 9, 10; 16, 17, 18; 56, 57, 58' are
valid parameters when configure the boot_partiton.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Signed-off-by: Ryan QIAN <b32804@freescale.com>
ENGR125411 eMMC: Boot Partition switch func used in MFG tool
User can get eMMC partitions info from user space layer in
linux OS enviroment.
User can do switch operations between the eMMC boot partitions
and the user partition.
User can access the eMMC boot partitions from user space layer
in linux OS enviroment.
NOTE:This func had been verified on TOSHIBA eMMC44 card only.
Signed-off-by: Rob Herring <r.herring@freescale.com>
The driver gpmi-nand should compile at least. This patch adds the
missing gpmi-nand.h to fix the compile error below.
CC drivers/mtd/nand/gpmi-nand/gpmi-nand.o
CC drivers/mtd/nand/gpmi-nand/gpmi-lib.o
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:25:33: fatal error: linux/mtd/gpmi-nand.h: No such file or directory
drivers/mtd/nand/gpmi-nand/gpmi-lib.c:21:33: fatal error: linux/mtd/gpmi-nand.h: No such file or directory
This header is grabbed from patch below, which has not been postponed
for merging.
[PATCH v8 1/4] ARM: mxs: add GPMI-NAND support for imx23/imx28
http://permalink.gmane.org/gmane.linux.drivers.mtd/37338
Signed-off-by: Huang Shijie <b32955@freescale.com>
Remove usless code in pfuze100 regulator driver
Signed-off-by: Robin Gong <b38343@freescale.com>
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
Add TVin struct to Head file.
Signed-off-by: Even Xu <b21019@freescale.com>
Kconfig and Makefile was modified in order to
enable adv7180 driver for mx6q architecture.
adv7180.c mutex was changed to semaphore as is described in
"https://lwn.net/Articles/304725/ ".
sensor data structure is added in fsl_devices.h.
mxc_v4l2_capture.c condition in mxc_v4l2_sparam
was removed because is going to be always true
capture mode only have 1 possible value as is described in
"https://lwn.net/Articles/235023/".
ipu_capture.c clock divisor setup was added at init the csi.
Signed-off-by: B37753 <B37753@freescale.com>
fix build warnings on pfuze driver:
arch/arm/mach-mx6/mx6q_sabreauto_pmic_pfuze100.c:388:
warning: initialization from incompatible pointer type
drivers/mfd/pfuze-core.c:523:
drivers/mfd/pfuze-core.c:412:
warning: 'pfuze_add_subdevice' defined but not used
Signed-off-by: Robin Gong <B38343@freescale.com>
Add MLB main driver for mx6q.
Signed-off-by: Terry Lv <r65388@freescale.com>
Add MLB driver platform data structure.
add pfuze core driver for mx6
* Overwrite codec_name if passed as platform data
* Add codec_name in mxc_audio_platform_data
* Codec name follows the naming convention
<codec>.<i2c-channel>-<codec i2c address> i.e. cs42888.0-0048
* For IMX6Q-ARD this name convention doesn't follow previous settings for
imx6q platforms codec is on different i2c channel and can't be resolved
by CONFIG macros on imx_3stack_dai data structure; So we overwrite in
probe function by getting the correct value from plat_data->codec_name.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
* Remove hard codded gpio reset definition
* Add in mxc_audio_platform_data reset gpio reference to be able
to pass gpio reset assignment in board definition file instead
of a macro for each different board.
* Add plat_data null check, return EINV if no set.
This commit intends to implement the flowchart and details
documented in the HDMI Transmitter Controller User Guide
section entitled "Programming Model".
Some input is also from the Synopsys API code.
The HDMI specification requires HDMI to set itself to VGA DVI mode
before reading the EDID.
So follow this sequence when HDMI is hotplugged:
1. Hdmi connector is plugged in, HDMI video gets an interrupt.
2. Clear out video mode list. Add only VGA DVI mode to list.
3. Request VGA DVI mode (call fb_set_var())
4. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
call mxc_hdmi_setup() to set up HDMI.
5. Read the edid and add video modes from edid. Select the video
mode that is similar to the command line default.
6. Request VGA DVI mode (call fb_set_var())
7. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
do mxc_hdmi_setup().
Also included is a workaround for an overflow condition in the HDMI.
The frame composer has an arithmetic unit that gets updated every time
we write to one of the FC registers. But sometimes, depending on the
relation between the tmds and sfr clocks, it may happen that this unit
doesn't get updated, even though the registers are holding correct
values. The workaround for this is, after completing the controller
configuration, to rewrite one of the FC registers (i.e. FC_INVIDCONF)
three or four times with the same value, and then follow it up by a SW
reset to the TMDS clock domain (MC_SWRSTZ).
We clear the overflow condition as described above every time we
change video mode. Also an overflow interupt handler will clear the
overflow condition if it happens again. This overflow condition is
expected (and not a problem) when we are in DVI (non-HDMI) mode, so
we do not worry about it in that case.
Signed-off-by: Alan Tull <alan.tull@freescale.com>
This reverts commit 9f26eaa231cf2a19064c5589a3515bdd60af596a.
This reverts commit b35268ca923a8785ab311170b0a84210b3c7863e.
Signed-off-by: Jason Liu <jason.hui@linaro.org>
header file
- remove the definition of discharge dp
Signed-off-by: Tony LIU <junjie.liu@freescale.com>
remove FB_EVENT_PREMODE_CHANGE for mxc ldb/tve drivers
add dispdrv setup interface for ldb/tve drivers
re-structure the dispdrv framework for display devices
Signed-off-by: Wayne Zou <b36644@freescale.com>
Add a new member named "io_init" to fsl camera platform data, this
Function can initialize IO of camera sensor before it works.
add plt_init & plt_exit functions to structure, so that
the driver would have chance to do platform specific init and exit
Signed-off-by: Tony Lin <tony.lin@freescale.com>
- An well-behavior class driver should disable their endpoints
after being notified disconnect with host, we use all endpoints
are stopped (ep->stopped) to indicates the class
driver will not visit device driver any more.
the ep-stopped will be initialized as 1 for non-control endpoint
it will be 0 after fsl_ep_enable, and be 1 after fsl_ep_disable.
Where is a non-sleep wait routine at disconnect event for waiting all
endpoints are stopped
- Some controller's (like i.mx6q) DP will change from J
to SE0 slowly after the cable disconnects with host, in that case there
will be a wakeup interrupt after driver enables the wakeup interrupt.
For i.mx6q, there is a discharge routine for DP after the disconnection.
- Should not wait vbus to low during first otg switch, as the wait will
be timeout when the usb cable is connecting to host.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
1. Read calibration from fuse to adjust formula
for thermal driver;
2. For the parts that didn't contain valid
calibration data, cooling device will be disabled;
Signed-off-by: Anson Huang <b20788@freescale.com>
- Added V3P3 regulator to max17135
- Added calls to enable/disable V3P3 regulator from EPDC driver
- Improved Kconfig detail for max17135 MFD and HWMON entries
Signed-off-by: Danny Nold <dannynold@freescale.com>
Fix v4l2 build error.
revert mxc_v4l2.h to 01c98ebc63d
Signed-off-by: Frank Li <Frank.Li@freescale.com>
- Set phy AR8031 to save power mode when no cable connect.
- Close enet clock gate when FEC is no use.
Signed-off-by: Fugang Duan <B38611@freescale.com>
This new v4l2 output driver is based on videobuf, using dma contig alloc method.
It creates video dev node for each display framebuffer begin from /dev/video16
by default.
If need post-processing, this driver will do it by ipu pp driver which support:
- resizing
- CSC
- rotate
- deinterlacing
If no need post-processing, the IPU IC will be bypassed as old driver, the
buf will be set to fb buffer directly by crack fb smem_start.
The user should do setting before streamon like below:
1. set output crop
2. set ctrl like rotate/vflip/hflip/deinterlacing motion
3. set fmt
4. reqbuf
The new features compare to old driver:
- support multi-instance
- support user point buffer
- runtime suspend/resume
For suspend/resume, still has chance to meet issue on mx6q, will fix later.
This patch for head file.
Signed-off-by: Jason Chen <b02280@freescale.com>
1. no dma alloc for rot buf every time which will cost time.
2. fix split mode condition.
3. export some functions.
This patch for common head file.
Header file
Previously, only one static struct for ops existed for all
platform DMA drivers to share. Half of the ops are shared
functions which don't have stubs in the ALSA core. The
other half are initialized to point directly to ops in the
platform driver. This creates problems where each time
soc_new_pcm is called, the new platform driver's ops would
overwrite a subset of the ops.
Add Anatop regulator driver.
Audio driver for i.Mx built-in HDMI Transmitter.
* Uses HDMI Transmitter's built-in DMA.
* Adds IEC958-style digital audio header info to the raw audio.
* Gets pixel clock from the IPU driver and calculates clock
regenerator values (cts and N).
* Move ipu_id, and disp_id from the HDMI's platform data to the
HDMI mfd's platform data. Saves them in the hdmi mfd.
* Add mfd functionality to update the clock regenerator values
when the hdmi changes the pixel clock rate or when requested
from the audio driver with a new audio sample rate.
add new mc34708's core driver based on MFD
Move the board specific code out of the FEC driver to the platform
layer
Signed-off-by: Mahesh Mahadevan <r9aadq@freescale.com>
* Add spdif block clock divider settings and spdif_clk_set_rate
function to mxc_spdif_platform_data.
- Ensure HDMI clocks are disabled when leaving HDMI core probe function.
- Create HDMI core api to allow HDMI sub-drivers to init, enable, and
disable the HDMI IRQ. Required to optimally manage HDMI clocks,
allow IAHB to be disabled, and still have video and audio sub-drivers
able to receive interrupts.
- Update code to adjust for decoupled ISFR and IAHB clocks.
- Disable IAHB clocks whenever HDMI not plugged in.
Currently we do not support split mode with rotation.
Change from u8 declaration in pxp_dma.h to __u8
- Add support for 8-bit grayscale colormaps to be used
during EPDC update processing
- Add support in PxP for programming of colormaps
for include/linux/ipu.h.
IPU's IC/IRT/VDI modules provide resizing/CSC/combination/de-interlacing
support, this patch make all these features into one processing driver.
A struct ipu_task is the interface between user and this driver, user
just need fill his task struct and queue it through ioctl, then wait
ipu hardware finish its job (now only support BLOCKING operation, not
support NO_BLOCK operation).
Pls refer to inlcude/linux/ipu.h for structure information and unit test
for usage.
This patch is for header file change.
- Cleaned up video mode configuration in HDMI driver
- Add support for configurable ipu-to-hdmi mappings
- Add hotplug support.
- Adapt interrupt handling to account for sharing interrupt with HDMI audio
- Remove audio configuration
- Change code to only use CEA HDMI modes
- Add support for AVI InfoFrame
- Add aspect ratio to EDID mode data
- Add rounding support to IPU pix clk setup
- Add powerdown/powerup flow
- Support FB notifications
- Remove build warnings
