path: root/include
2008-10-23proc: move rest of /proc/partitions code to block/genhd.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move rest of /proc/locks to fs/locks.cAlexey Dobriyan
2008-10-23proc: move /proc/hardware to m68k-specific codeAlexey Dobriyan
2008-10-23proc: switch /proc/meminfo to seq_fileAlexey Dobriyan
and move it to fs/proc/meminfo.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-20fix WARN() for PPCArjan van de Ven
powerpc doesn't use the generic WARN_ON infrastructure. The newly introduced WARN() as a result didn't print the message, this patch adds the printk for this specific case. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: convert to generic compat_sys_ptrace parisc: add rtc platform driver parisc: initialize unwinder much earlier parisc: add new syscalls parisc: hijack jump to start_kernel parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlocked parisc: move include/asm-parisc to arch/parisc/include/asm parisc: move pdc_result to real2.S parisc: unify CCIO_COLLECT_STATS implementation parisc: add arch/parisc/kernel/.gitignore parisc: ropes.h - fix <asm-parisc/*> -> <asm/*> parisc: parisc-agp - fix <asm-parisc/*> -> <asm/*> Resolve remove/rename conflict: include/asm-parisc/a.out.h is no longer relevant.
2008-10-20Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (41 commits) PCI: fix pci_ioremap_bar() on s390 PCI: fix AER capability check PCI: use pci_find_ext_capability everywhere PCI: remove #ifdef DEBUG around dev_dbg call PCI hotplug: fix get_##name return value problem PCI: document the pcie_aspm kernel parameter PCI: introduce an pci_ioremap(pdev, barnr) function powerpc/PCI: Add legacy PCI access via sysfs PCI: Add ability to mmap legacy_io on some platforms PCI: probing debug message uniformization PCI: support PCIe ARI capability PCI: centralize the capabilities code in probe.c PCI: centralize the capabilities code in pci-sysfs.c PCI: fix 64-vbit prefetchable memory resource BARs PCI: replace cfg space size (256/4096) by macros. PCI: use resource_size() everywhere. PCI: use same arg names in PCI_VDEVICE comment PCI hotplug: rpaphp: make debug var unique PCI: use %pF instead of print_fn_descriptor_symbol() in quirks.c PCI: fix hotplug get_##name return value problem ...
2008-10-20Merge branch 'tracing-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (131 commits) tracing/fastboot: improve help text tracing/stacktrace: improve help text tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix bootgraph.pl initcall name regexp tracing/fastboot: fix issues and improve output of bootgraph.pl tracepoints: synchronize unregister static inline tracepoints: tracepoint_synchronize_unregister() ftrace: make ftrace_test_p6nop disassembler-friendly markers: fix synchronize marker unregister static inline tracing/fastboot: add better resolution to initcall debug/tracing trace: add build-time check to avoid overrunning hex buffer ftrace: fix hex output mode of ftrace tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix printk format typo in boot tracer ftrace: return an error when setting a nonexistent tracer ftrace: make some tracers reentrant ring-buffer: make reentrant ring-buffer: move page indexes into page headers tracing/fastboot: only trace non-module initcalls ftrace: move pc counter in irqtrace ... Manually fix conflicts: - init/main.c: initcall tracing - kernel/module.c: verbose level vs tracepoints - scripts/bootgraph.pl: fallout from cherry-picking commits.
2008-10-20Merge branch 'genirq-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip This merges branches irq/genirq, irq/sparseirq-v4, timers/hpet-percpu and x86/uv. The sparseirq branch is just preliminary groundwork: no sparse IRQs are actually implemented by this tree anymore - just the new APIs are added while keeping the old way intact as well (the new APIs map 1:1 to irq_desc[]). The 'real' sparse IRQ support will then be a relatively small patch ontop of this - with a v2.6.29 merge target. * 'genirq-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (178 commits) genirq: improve include files intr_remapping: fix typo io_apic: make irq_mis_count available on 64-bit too genirq: fix name space collisions of nr_irqs in arch/* genirq: fix name space collision of nr_irqs in autoprobe.c genirq: use iterators for irq_desc loops proc: fixup irq iterator genirq: add reverse iterator for irq_desc x86: move ack_bad_irq() to irq.c x86: unify show_interrupts() and proc helpers x86: cleanup show_interrupts genirq: cleanup the sparseirq modifications genirq: remove artifacts from sparseirq removal genirq: revert dynarray genirq: remove irq_to_desc_alloc genirq: remove sparse irq code genirq: use inline function for irq_to_desc genirq: consolidate nr_irqs and for_each_irq_desc() x86: remove sparse irq from Kconfig genirq: define nr_irqs for architectures with GENERIC_HARDIRQS=n ...
2008-10-20Merge branch 'v28-timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) fix documentation of sysrq-q really Fix documentation of sysrq-q timer_list: add base address to clock base timer_list: print cpu number of clockevents device timer_list: print real timer address NOHZ: restart tick device from irq_enter() NOHZ: split tick_nohz_restart_sched_tick() NOHZ: unify the nohz function calls in irq_enter() timers: fix itimer/many thread hang, fix timers: fix itimer/many thread hang, v3 ntp: improve adjtimex frequency rounding timekeeping: fix rounding problem during clock update ntp: let update_persistent_clock() sleep hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds posix-timers: lock_timer: make it readable posix-timers: lock_timer: kill the bogus ->it_id check posix-timers: kill ->it_sigev_signo and ->it_sigev_value posix-timers: sys_timer_create: cleanup the error handling posix-timers: move the initialization of timer->sigq from send to create path posix-timers: sys_timer_create: simplify and s/tasklist/rcu/ ... Fix trivial conflicts due to sysrq-q description clahes in Documentation/sysrq.txt and drivers/char/sysrq.c
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (36 commits) ide: re-add TRM290 fix lost during ide_build_dmatable() cleanup scc_pata: kill unused variables sgiioc4: kill duplicate ioremap() sgiioc4: kill useless address checks delkin_cb: add PM support ide: remove broken hpt34x driver ide-floppy: remove idefloppy_floppy_t typedef sgiioc4: remove maskproc() method hpt366: cleanup maskproc() method ide: mask interrupt in ide_config_drive_speed() hpt366: fix compile warning ide: remove unused macros from <asm-parisc/ide.h> ide: remove M68K_IDE_SWAPW define from <asm-m68k/ide.h> ide: remove dead <asm-arm/arch-sa1100/ide.h> ide: fix support for IDE PCI controllers using MMIO on frv ide-cd: remove stale comment ide-cd: small drive type print fix ide-cd: debug log enhancements ide: add generic ATA/ATAPI disk driver ide: allow device drivers to specify per-device type /proc settings ...
2008-10-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: implement nonseekable open fuse: add include protectors fuse: config description improvement fuse: add missing fuse_request_free fuse: fix SEEK_END incorrectness
2008-10-20PCI: fix pci_ioremap_bar() on s390Heiko Carstens
s390 doesn't have ioremap_*, so protect the definition of the new pci_ioremap_bar function with CONFIG_HAS_IOMEM to avoid build breakage. Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: fix AER capability checkYu Zhao
The 'use pci_find_ext_capability everywhere' cleanup brought a new bug, which makes the AER stop working. Fix it by actually using find_ext_cap instead of just find_cap. Drop the unused config space size define while we're at it. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: use pci_find_ext_capability everywhereJesse Barnes
Remove some open coded (and buggy) versions of pci_find_ext_capability in favor of the real routine in the PCI core. Tested-by: Tomasz Czernecki <czernecki@gmail.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: introduce an pci_ioremap(pdev, barnr) functionArjan van de Ven
A common thing in many PCI drivers is to ioremap() an entire bar. This is a slightly fragile thing right now, needing both an address and a size, and many driver writers do.. various things there. This patch introduces an pci_ioremap() function taking just a PCI device struct and the bar number as arguments, and figures this all out itself, in one place. In addition, we can add various sanity checks to this function (the patch already checks to make sure that the bar in question really is a MEM bar; few to no drivers do that sort of thing). Hopefully with this type of API we get less chance of mistakes in drivers with ioremap() operations. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: support PCIe ARI capabilityYu Zhao
This patch adds support for PCI Express Alternative Routing-ID Interpretation (ARI) capability. The ARI capability extends the Function Number field of the PCI Express Endpoint by reusing the Device Number which is otherwise hardwired to 0. With ARI, an Endpoint can have up to 256 functions. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: use same arg names in PCI_VDEVICE commentZhao, Yu
This cleanup makes the argument names in PCI_VDEVICE comment consistent with those used in its definition. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20x86/PCI: irq and pci_ids patch for Intel Ibex Peak DeviceIDsSeth Heasley
This patch updates the Intel Ibex Peak (PCH) LPC and SMBus Controller DeviceIDs. The LPC Controller ID is set by Firmware within the range of 0x3b00-3b1f. This range is included in pci_ids.h using min and max values, and irq.c now has code to handle the range (in lieu of 32 additions to a SWITCH statement). The SMBus Controller ID is a fixed-value and will not change. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: change MSI-x vector to 32bitYinghai Lu
We are using 28bit pci (bus/dev/fn + 12 bits) as irq number, so the cache for irq number should be 32 bit too. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI PM: Introduce function pci_wake_from_d3Rafael J. Wysocki
Many device drivers use the following sequence of statements to enable the device to wake up the system while being in the D3_hot or D3_cold low power state: pci_enable_wake(pdev, PCI_D3hot, 1); pci_enable_wake(pdev, PCI_D3cold, 1); However, the second call is not necessary if the first one succeeds (the ordering of the statements above doesn't matter here) and it may even be harmful, because we are not supposed to enable PME# after the wake-up power has been enabled for the device. To allow drivers to overcome this problem, introduce function pci_wake_from_d3() that will enable the device to wake up the system from any of D3_hot and D3_cold as long as the wake-up from at least one of them is supported. Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: remove dynids.use_driver_dataMilton Miller
The driver flag dynids.use_driver_data is almost consistently not set, and causes more problems than it solves. It was initially intended as a flag to indicate whether a driver's usage of driver_data had been carefully inspected and was ready for values from userspace. That audit was never done, so most drivers just get a 0 for driver_data when new IDs are added from userspace via sysfs. So remove the flag, allowing drivers to see the data directly (a followon patch validates the passed driver_data value against what the drivers expect). Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: bq27x00_battery: use unaligned access helper power_supply: fix dependency of tosa_battery power_supply: Support for Texas Instruments BQ27200 battery managers power_supply: Add function to return system-wide power state pda_power: Check and handle return value of set_irq_wake
2008-10-20Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: (26 commits) 9p: add more conservative locking 9p: fix oops in protocol stat parsing error path. 9p: fix device file handling 9p: Improve debug support 9p: eliminate depricated conv functions 9p: rework client code to use new protocol support functions 9p: remove unnecessary tag field from p9_req_t structure 9p: remove 9p fcall debug prints 9p: add new protocol support code 9p: encapsulate version function 9p: move dirread to fs layer 9p: adjust 9p vfs write operation 9p: move readn meta-function from client to fs layer 9p: consolidate read/write functions 9p: drop broken unused error path from p9_conn_create() 9p: make rpc code common and rework flush code 9p: use the rcall structure passed in the request in trans_fd read_work 9p: apply common request code to trans_fd 9p: apply common tagpool handling to trans_fd 9p: move request management to client code ...
2008-10-20Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: use correct fs type for v4 submounts and referrals Make nfs_file_cred more robust. NFS: Enable NFSv4 callback server to listen on AF_INET6 sockets
2008-10-20Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: mfd: further unbork the ucb1400 ac97_bus dependencies mfd: ucb1400 needs GPIO mfd: ucb1400 sound driver uses/depends on AC97_BUS: mfd: Don't use NO_IRQ in WM8350 mfd: update TMIO drivers to use the clock API mfd: twl4030-core irq simplification mfd: add base support for Dialog DA9030/DA9034 PMICs mfd: TWL4030 core driver mfd: support tmiofb cell on tc6393xb mfd: add OHCI cell to tc6393xb mfd: Fix htc-egpio compile warning mfd: do tcb6393xb state restore on resume only if requested mfd: provide and use setup hook for tc6393xb mfd: update sm501 debugging/low information messages mfd: reduce stack usage in mfd-core.c
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (112 commits) sh: Move SH-4 CPU headers down one more level. sh: Only build in gpio.o when CONFIG_GENERIC_GPIO is selected. sh: Migrate common board headers to mach-common/. sh: Move the CPU definition headers from asm/ to cpu/. serial: sh-sci: Add support SCIF of SH7723 video: add sh_mobile_lcdc platform flags video: remove unused sh_mobile_lcdc platform data sh: remove consistent alloc cruft sh: add dynamic crash base address support sh: reduce Migo-R smc91x overruns sh: Fix up some merge damage. Fix debugfs_create_file's error checking method for arch/sh/mm/ Fix debugfs_create_dir's error checking method for arch/sh/kernel/ sh: ap325rxa: Add support RTC RX-8564LC in AP325RXA board sh: Use sh7720 GPIO on magicpanelr2 board sh: Add sh7720 pinmux code sh: Use sh7203 GPIO on rsk7203 board sh: Add sh7203 pinmux code sh: Use sh7723 GPIO on AP325RXA board sh: Add sh7723 pinmux code ...
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netfilter: replace old NF_ARP calls with NFPROTO_ARP netfilter: fix compilation error with NAT=n netfilter: xt_recent: use proc_create_data() netfilter: snmp nat leaks memory in case of failure netfilter: xt_iprange: fix range inversion match netfilter: netns: use NFPROTO_NUMPROTO instead of NUMPROTO for tables array netfilter: ctnetlink: remove obsolete NAT dependency from Kconfig pkt_sched: sch_generic: Fix oops in sch_teql dccp: Port redirection support for DCCP tcp: Fix IPv6 fallout from 'Port redirection support for TCP' netdev: change name dropping error codes ipvs: Update CONFIG_IP_VS_IPV6 description and help text
2008-10-20Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (69 commits) Revert "[MTD] m25p80.c code cleanup" [MTD] [NAND] GPIO driver depends on ARM... for now. [MTD] [NAND] sh_flctl: fix compile error [MTD] [NOR] AT49BV6416 has swapped erase regions [MTD] [NAND] GPIO NAND flash driver [MTD] cmdlineparts documentation change - explain where mtd-id comes from [MTD] cfi_cmdset_0002.c: Add Macronix CFI V1.0 TopBottom detection [MTD] [NAND] Fix compilation warnings in drivers/mtd/nand/cs553x_nand.c [JFFS2] Write buffer offset adjustment for NOR-ECC (Sibley) flash [MTD] mtdoops: Fix a bug where block may not be erased [MTD] mtdoops: Add a magic number to logged kernel oops [MTD] mtdoops: Fix an off by one error [JFFS2] Correct parameter names of jffs2_compress() in comments [MTD] [NAND] sh_flctl: add support for Renesas SuperH FLCTL [MTD] [NAND] Bug on atmel_nand HW ECC : OOB info not correctly written [MTD] [MAPS] Remove unused variable after ROM API cleanup. [MTD] m25p80.c extended jedec support (v2) [MTD] remove unused mtd parameter in of_mtd_parse_partitions() [MTD] [NAND] remove dead Kconfig associated with !CONFIG_PPC_MERGE [MTD] [NAND] driver extension to support NAND on TQM85xx modules ...
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20include/linux/bcd.h: remove commentsAdrian Bunk
- the macros are gone - there's no more code in this file, LGPL + GPL = GPL, and the code that was moved to lib/bcd.c is anyway trivial Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20remove the obsolete BCD*BIN/BIN*BCD macrosAdrian Bunk
Remove the following obsolete macros: - BCD2BIN - BIN2BCD - BCD_TO_BIN - BIN_TO_BCD Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20rtc: use bcd2bin/bin2bcdAdrian Bunk
Change various rtc related code to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20make mm/rmap.c:anon_vma_cachep staticAdrian Bunk
This patch makes the needlessly global anon_vma_cachep static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20byteorder: provide swabb.h generically in asm/byteorder.hHarvey Harrison
This is needed during the transition to the new byteorder headers as the swabb.h functionality will be provided from asm/byteorder.h in the new version. To avoid breakage on arches still using the old implementation, provide swabb.h from asm/byteorder.h as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20byteorder: use generic C version for value byteswappingHarvey Harrison
This makes the new implementation of the byteorder helpers match the old in how it degraded when an arch-defined version was not available: 1) swab() - look for arch defined - if not, use generic c version 2) swabp() - look for arch-defined - if not, deref pointer and use swab() 3) swabs() - look for arch defined - if not, use swabp Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20byteorder: add new headers for make headers-installHarvey Harrison
2008-10-20kdump: add is_vmcore_usable() and vmcore_unusable()Simon Horman
The usage of elfcorehdr_addr has changed recently such that being set to ELFCORE_ADDR_MAX is used by is_kdump_kernel() to indicate if the code is executing in a kernel executed as a crash kernel. However, arch/ia64/kernel/setup.c:reserve_elfcorehdr will rest elfcorehdr_addr to ELFCORE_ADDR_MAX on error, which means any subsequent calls to is_kdump_kernel() will return 0, even though they should return 1. Ok, at this point in time there are no subsequent calls, but I think its fair to say that there is ample scope for error or at the very least confusion. This patch add an extra state, ELFCORE_ADDR_ERR, which indicates that elfcorehdr_addr was passed on the command line, and thus execution is taking place in a crashdump kernel, but vmcore can't be used for some reason. This is tested for using is_vmcore_usable() and set using vmcore_unusable(). A subsequent patch makes use of this new code. To summarise, the states that elfcorehdr_addr can now be in are as follows: ELFCORE_ADDR_MAX: not a crashdump kernel ELFCORE_ADDR_ERR: crashdump kernel but vmcore is unusable any other value: crash dump kernel and vmcore is usable Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20kdump: make elfcorehdr_addr independent of CONFIG_PROC_VMCOREVivek Goyal
o elfcorehdr_addr is used by not only the code under CONFIG_PROC_VMCORE but also by the code which is not inside CONFIG_PROC_VMCORE. For example, is_kdump_kernel() is used by powerpc code to determine if kernel is booting after a panic then use previous kernel's TCE table. So even if CONFIG_PROC_VMCORE is not set in second kernel, one should be able to correctly determine that we are booting after a panic and setup calgary iommu accordingly. o So remove the assumption that elfcorehdr_addr is under CONFIG_PROC_VMCORE. o Move definition of elfcorehdr_addr to arch dependent crash files. (Unfortunately crash dump does not have an arch independent file otherwise that would have been the best place). o kexec.c is not the right place as one can Have CRASH_DUMP enabled in second kernel without KEXEC being enabled. o I don't see sh setup code parsing the command line for elfcorehdr_addr. I am wondering how does vmcore interface work on sh. Anyway, I am atleast defining elfcoredhr_addr so that compilation is not broken on sh. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20add CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERSRoland McGrath
This adds a kconfig option to change the /proc/PID/coredump_filter default. Fedora has been carrying a trivial patch to change the hard-wired value for this default, since Fedora 8. The default default can't change safely because there are old GDB versions out there (all before 6.7) that are confused by the core dump files created by the MMF_DUMP_ELF_HEADERS setting. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Kawai Hidehiro <hidehiro.kawai.ez@hitachi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20make ptrace_untrace() staticAdrian Bunk
ptrace_untrace() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20bitmask: remove bitmap_scnprintf_len()Lai Jiangshan
bitmap_scnprintf_len() is not used now, so we remove it. Otherwise we have to maintain it and make its return value always equal to bitmap_scnprintf()'s return value. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20seq_file: add seq_cpumask_list(), seq_nodemask_list()Lai Jiangshan
seq_cpumask_list(), seq_nodemask_list() are very like seq_cpumask(), seq_nodemask(), but they print human readable string. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20cgroups: fix declaration of cgroup_mm_owner_callbacksPaul Menage
The choice of real/dummy declaration for cgroup_mm_owner_callbacks() shouldn't be based on CONFIG_MM_OWNER, but on CONFIG_CGROUPS. Otherwise kernel/exit.c fails to compile when something other than a cgroups controller selects CONFIG_MM_OWNER Signed-off-by: Paul Menage <menage@google.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20cgroups: convert tasks file to use a seq_file with shared pid arrayPaul Menage
Rather than pre-generating the entire text for the "tasks" file each time the file is opened, we instead just generate/update the array of process ids and use a seq_file to report these to userspace. All open file handles on the same "tasks" file can share a pid array, which may be updated any time that no thread is actively reading the array. By sharing the array, the potential for userspace to DoS the system by opening many handles on the same "tasks" file is removed. [Based on a patch by Lai Jiangshan, extended to use seq_file] Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20cgroups: fix probable race with put_css_set[_taskexit] and find_css_setLai Jiangshan
put_css_set_taskexit may be called when find_css_set is called on other cpu. And the race will occur: put_css_set_taskexit side find_css_set side | atomic_dec_and_test(&kref->refcount) | /* kref->refcount = 0 */ | .................................................................... | read_lock(&css_set_lock) | find_existing_css_set | get_css_set | read_unlock(&css_set_lock); .................................................................... __release_css_set | .................................................................... | /* use a released css_set */ | [put_css_set is the same. But in the current code, all put_css_set are put into cgroup mutex critical region as the same as find_css_set.] [akpm@linux-foundation.org: repair comments] [menage@google.com: eliminate race in css_set refcounting] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20ext3: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount a ext3 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20fb: convert lock/unlock_kernel() into local fb mutexKrzysztof Helt
Change lock_kernel()/unlock_kernel() to local fb mutex. Each frame buffer instance has its own mutex. The one line try_to_load() function is unrolled to request_module() in two places for readability. [righi.andrea@gmail.com: fb: fix NULL pointer BUG dereference in fb_open()] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: implement freezer cgroup subsystemMatt Helsley
This patch implements a new freezer subsystem in the control groups framework. It provides a way to stop and resume execution of all tasks in a cgroup by writing in the cgroup filesystem. The freezer subsystem in the container filesystem defines a file named freezer.state. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. Reading will return the current state. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This is the basic mechanism which should do the right thing for user space task in a simple scenario. It's important to note that freezing can be incomplete. In that case we return EBUSY. This means that some tasks in the cgroup are busy doing something that prevents us from completely freezing the cgroup at this time. After EBUSY, the cgroup will remain partially frozen -- reflected by freezer.state reporting "FREEZING" when read. The state will remain "FREEZING" until one of these things happens: 1) Userspace cancels the freezing operation by writing "RUNNING" to the freezer.state file 2) Userspace retries the freezing operation by writing "FROZEN" to the freezer.state file (writing "FREEZING" is not legal and returns EIO) 3) The tasks that blocked the cgroup from entering the "FROZEN" state disappear from the cgroup's set of tasks. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: export thaw_process] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
