path: root/include
2006-08-07Merge branch 'master' into upstreamJeff Garzik
2006-08-06Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (24 commits) Input: ati_remote - use msec instead of jiffies Input: ati_remote - add missing input_sync() Input: ati_remote - relax permissions sysfs module parameters Input: ati_remote - make filter time a module parameter Input: atkbd - restore repeat rate when resuming Input: trackpoint - activate protocol when resuming Input: logips2pp - fix button mapping for MX300 Input: keyboard - change to use kzalloc Input: serio/gameport - check whether driver core calls succeeded Input: spaceball - make 4000FLX Lefty work Input: keyboard - simplify emulate_raw() implementation Input: keyboard - remove static variable and clean up initialization Input: hiddev - use standard list implementation Input: add missing handler->start() call Input: HID - fix potential out-of-bound array access Input: fix list iteration in input_release_device() Input: iforce - add Trust Force Feedback Race Master support Input: iforce - check array bounds before accessing elements Input: libps2 - warn instead of oopsing when passed bad arguments Input: fm801-gp - fix use after free ...
2006-08-06Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [LAPB]: Fix windowsize check [TCP]: Fixes IW > 2 cases when TCP is application limited [PKT_SCHED] RED: Fix overflow in calculation of queue average [LLX]: SOCK_DGRAM interface fixes [PKT_SCHED]: Return ENOENT if qdisc module is unavailable [BRIDGE]: netlink status fix
2006-08-06[PATCH] debug_locks.h: add "struct task_struct;"Alexey Dobriyan
Removes many, many "declared inside parameter list" warnings on parisc. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] fix vmstat per cpu usageJan Blunck
The per cpu variables are used incorrectly in vmstat.h. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Lameter <clameter@engr.sgi.com> Acked-by: Steve Fox <drfickle@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] Make suspend possible with a traced process at a breakpointRafael J. Wysocki
It should be possible to suspend, either to RAM or to disk, if there's a traced process that has just reached a breakpoint. However, this is a special case, because its parent process might have been frozen already and then we are unable to deliver the "freeze" signal to the traced process. If this happens, it's better to cancel the freezing of the traced process. Ref. http://bugzilla.kernel.org/show_bug.cgi?id=6787 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-04[PKT_SCHED] RED: Fix overflow in calculation of queue averageIlpo Järvinen
Overflow can occur very easily with 32 bits, e.g., with 1 second us_idle is approx. 2^20, which leaves only 11-Wlog bits for queue length. Since the EWMA exponent is typically around 9, queue lengths larger than 2^2 cause overflow. Whether the affected branch is taken when us_idle is as high as 1 second, depends on Scell_log, but with rather reasonable configuration Scell_log is large enough to cause p->Stab to have zero index, which always results zero shift (typically also few other small indices result in zero shift). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-04Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 ↵Dmitry Torokhov
into for-linus
2006-08-04Merge branch 'fixes' of git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* 'fixes' of git://git.linux-nfs.org/pub/linux/nfs-2.6: SUNRPC: Fix obvious refcounting bugs in rpc_pipefs. RPC: Ensure that we disconnect TCP socket when client requests error out NLM/lockd: remove b_done NFS: make 2 functions static NFS: Release dcache_lock in an error path of nfs_path
2006-08-04Merge branch 'master' into upstreamJeff Garzik
2006-08-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: PNP: Add missing casts in printk() arguments PCI: docking station: remove dock uevents PCI: Unhide the SMBus on Asus PU-DLS PCI Hotplug: add acpiphp to MAINTAINERS PCI: pci/search: EXPORTs cannot be __devinit PCIE: cleanup on probe error pcie: fix warnings when CONFIG_PM=n
2006-08-03Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-03RPC: Ensure that we disconnect TCP socket when client requests error outTrond Myklebust
If we're part way through transmitting a TCP request, and the client errors, then we need to disconnect and reconnect the TCP socket in order to avoid confusing the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from 031a50c8b9ea82616abd4a4e18021a25848941ce commit)
2006-08-03NLM/lockd: remove b_doneJ. Bruce Fields
We never actually set the b_done field any more; it's always zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from af8412d4283ef91356e65e0ed9b025b376aebded commit)
2006-08-03NFS: make 2 functions staticAdrian Bunk
nfs_writedata_free() and nfs_readdata_free() can now become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from 5e1ce40f0c3c8f67591aff17756930d7a18ceb1a commit)
2006-08-03PCI: docking station: remove dock ueventsKristen Carlson Accardi
Remove uevent dock notifications. There are no consumers of these events at present, and uevents are likely not the correct way to send this type of event anyway. Until I get some kind of idea if anyone in userspace cares about dock events, I will just not send any. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-03PCI: Unhide the SMBus on Asus PU-DLSJean Delvare
Unhide the SMBus controller on the Asus PU-DLS board. This fixes bug #6763. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-03Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix show_mem for VIRTUAL_MEM_MAP+FLATMEM [IA64] align high endpoint of VIRTUAL_MEM_MAP [PATCH] Fix RAID5 + IA64 compile [IA64] Don't alloc empty frame in ia64_switch_mode_phys [IA64] Do not assume output registers be reservered. [IA64] add platform check to snsc driver init [IA64] sparse cleanups [IA64] Fix breakage in simscsi.c [IA64] Format /proc/pal/*/version_info correctly
2006-08-03[IA64] fix show_mem for VIRTUAL_MEM_MAP+FLATMEMBob Picco
contig.c (FLATMEM) requires the same optimization as in discontig.c for show_mem when VIRTUAL_MEM_MAP is in use. Otherwise FLATMEM has softlockup timeouts. This was boot tested for memory configuration: SPARSEMEM, DISCONTIG+VIRTUAL_MEM_MAP, FLATMEM, FLATMEM+VIRTUAL_MEM_MAP and FLATMEM+VIRTUAL_MEM_MAP with largest memory gap less than LARGE_GAP by using boot parameter "mem=". This was boot tested and "echo m >/proc/sysrq-trigger" output evaluated for : FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and SPARSEMEM. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-08-03[PATCH] don't bother with aux entires for dummy contextAl Viro
2006-08-03[PATCH] mark context of syscall entered with no rules as dummyAl Viro
2006-08-03[PATCH] introduce audit rules counterAl Viro
2006-08-03[PATCH] fix missed create event for directory auditAmy Griffis
When an object is created via a symlink into an audited directory, audit misses the event due to not having collected the inode data for the directory. Modify __audit_inode_child() to copy the parent inode data if a parent wasn't found in audit_names[]. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-03[PATCH] fix faulty inode data collection for open() with O_CREATAmy Griffis
When the specified path is an existing file or when it is a symlink, audit collects the wrong inode number, which causes it to miss the open() event. Adding a second hook to the open() path fixes this. Also add audit_copy_inode() to consolidate some code. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-02Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) [NET]: Fix more per-cpu typos [SECURITY]: Fix build with CONFIG_SECURITY disabled. [I/OAT]: Remove CPU hotplug lock from net_dma_rebalance [DECNET]: Fix for routing bug [AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patch [NET]: skb_queue_lock_key() is no longer used. [NET]: Remove lockdep_set_class() call from skb_queue_head_init(). [IPV6]: SNMPv2 "ipv6IfStatsOutFragCreates" counter error [IPV6]: SNMPv2 "ipv6IfStatsInHdrErrors" counter error [NET]: Kill the WARN_ON() calls for checksum fixups. [NETFILTER]: xt_hashlimit/xt_string: missing string validation [NETFILTER]: SIP helper: expect RTP streams in both directions [E1000]: Convert to netdev_alloc_skb [TG3]: Convert to netdev_alloc_skb [NET]: Add netdev_alloc_skb(). [TCP]: Process linger2 timeout consistently. [SECURITY] secmark: nul-terminate secdata [NET] infiniband: Cleanup ib_addr module to use the netevents [NET]: Core net changes to generate netevents [NET]: Network Event Notifier Mechanism. ...
2006-08-02Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (24 commits) Revert "[PATCH] USB: move usb_device_class class devices to be real devices" Revert "[PATCH] USB: convert usb class devices to real devices" USB: UHCI: Don't test the Short Packet Detect bit USB: unusual_devs entry for Nokia 3250 USB: dummy-hcd: disable interrupts during req->complete USB: fix the USB_GADGET_DUMMY_HCD dependencies USB: ati_remote.c: autorepeat fix USB: doc: fixes devio.c location in proc_usb_info.txt. USB: doc: usb-help.txt update. USB: Patch for rtl8150 to fix unplug problems USB: cypress driver comment updates USB: unusual_devs device removal usb-storage: Add US_FL_IGNORE_DEVICE flag; ignore ZyXEL G220F USB: New USB ID for Belkin Serial Adapter USB: Additional PID for the ftdi_sio driver USB: adding support for SHARP WS003SH to ipaq.c USB: Fix Freescale high-speed USB host dependency USB: Removed 3-port device handler from Option driver USB: Drop Sierra Wireless MC8755 from the Option driver USB: Let option driver handle Anydata CDMA modems. Remove anydata driver. ...
2006-08-02Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3743/1: ARM: OMAP: Fix compile for OMAP [ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.name
2006-08-02Revert "[PATCH] USB: move usb_device_class class devices to be real devices"Greg Kroah-Hartman
This reverts c182274ffe1277f4e7c564719a696a37cacf74ea commit because it required a newer version of udev to work properly than what is currently documented in Documentation/Changes. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02Revert "[PATCH] USB: convert usb class devices to real devices"Greg Kroah-Hartman
This reverts bd00949647ddcea47ce4ea8bb2cfcfc98ebf9f2a commit because it required a newer version of udev to work properly than what is currently documented in Documentation/Changes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02usb-storage: Add US_FL_IGNORE_DEVICE flag; ignore ZyXEL G220FDaniel Drake
This patch adds a new unusual_devs flag for when usb-storage needs to ignore a device that it would otherwise claim. We need to ignore the ZyXEL G220F as it is a virtual CDROM drive which includes the windows driver for this USB-WLAN adapter. After the windows driver is installed on a windows system, it converts it into a WLAN adapter (by ejecting the virtual disc). The virtual CDROM is of no interest to Linux users. The zd1211rw driver will automatically perform the eject operation, we just need to ensure that usb-storage does not claim the device. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02[IA64] sparse cleanupsKeith Owens
Fix some sparse warnings on ia64. Large constants that should be long instead of int. Use NULL instead of 0. Add some missing __iomem casts. Replace a non-C99 structure assignment. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-08-02[NET]: Fix more per-cpu typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[SECURITY]: Fix build with CONFIG_SECURITY disabled.David S. Miller
include/linux/security.h: In function ‘security_release_secctx’: include/linux/security.h:2757: warning: ‘return’ with a value, in function returning void Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patchCatherine Zhang
From: Catherine Zhang <cxzhang@watson.ibm.com> This patch implements a cleaner fix for the memory leak problem of the original unix datagram getpeersec patch. Instead of creating a security context each time a unix datagram is sent, we only create the security context when the receiver requests it. This new design requires modification of the current unix_getsecpeer_dgram LSM hook and addition of two new hooks, namely, secid_to_secctx and release_secctx. The former retrieves the security context and the latter releases it. A hook is required for releasing the security context because it is up to the security module to decide how that's done. In the case of Selinux, it's a simple kfree operation. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: skb_queue_lock_key() is no longer used.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Remove lockdep_set_class() call from skb_queue_head_init().Arjan van de Ven
The skb_queue_head_init() function is used both in drivers for private use and in the core networking code. The usage models are vastly set of functions that is only softirq safe; while the driver usage tends to be more limited to a few hardirq safe accessor functions. Rather than annotating all 133+ driver usages, for now just split this lock into a per queue class. This change is obviously safe and probably should make 2.6.18. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Add netdev_alloc_skb().Christoph Hellwig
Add a dev_alloc_skb variant that takes a struct net_device * paramater. For now that paramater is unused, but I'll use it to allocate the skb from node-local memory in a follow-up patch. Also there have been some other plans mentioned on the list that can use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Network Event Notifier Mechanism.Tom Tucker
This patch uses notifier blocks to implement a network event notifier mechanism. Clients register their callback function by calling register_netevent_notifier() like this: static struct notifier_block nb = { .notifier_call = my_callback_func }; ... register_netevent_notifier(&nb); Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[TCP]: SNMPv2 tcpAttemptFails counter errorWei Yongjun
Refer to RFC2012, tcpAttemptFails is defined as following: tcpAttemptFails OBJECT-TYPE SYNTAX Counter32 MAX-ACCESS read-only STATUS current DESCRIPTION "The number of times TCP connections have made a direct transition to the CLOSED state from either the SYN-SENT state or the SYN-RCVD state, plus the number of times TCP connections have made a direct transition to the LISTEN state from the SYN-RCVD state." ::= { tcp 7 } When I lookup into RFC793, I found that the state change should occured under following condition: 1. SYN-SENT -> CLOSED a) Received ACK,RST segment when SYN-SENT state. 2. SYN-RCVD -> CLOSED b) Received SYN segment when SYN-RCVD state(came from LISTEN). c) Received RST segment when SYN-RCVD state(came from SYN-SENT). d) Received SYN segment when SYN-RCVD state(came from SYN-SENT). 3. SYN-RCVD -> LISTEN e) Received RST segment when SYN-RCVD state(came from LISTEN). In my test, those direct state transition can not be counted to tcpAttemptFails. Signed-off-by: Wei Yongjun <yjwei@nanjing-fnst.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NETFILTER]: include/linux/netfilter_bridge.h: header cleanupAlexey Dobriyan
Header doesn't use anything from atomic.h. It fixes headers_check warning: include/linux/netfilter_bridge.h requires asm/atomic.h, which does not exist Compile tested on alpha arm i386-up sparc sparc64-up x86_64 alpha-up i386 sparc64 sparc-up x86_64-up Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[IPV6]: Audit all ip6_dst_lookup/ip6_dst_store callsHerbert Xu
The current users of ip6_dst_lookup can be divided into two classes: 1) The caller holds no locks and is in user-context (UDP). 2) The caller does not want to lookup the dst cache at all. The second class covers everyone except UDP because most people do the cache lookup directly before calling ip6_dst_lookup. This patch adds ip6_sk_dst_lookup for the first class. Similarly ip6_dst_store users can be divded into those that need to take the socket dst lock and those that don't. This patch adds __ip6_dst_store for those (everyone except UDP/datagram) that don't need an extra lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (26 commits) V4L/DVB (4380): Bttv: Revert VBI_OFFSET to previous value, it works better V4L/DVB (4379): Videodev: Check return value of class_device_register() correctly V4L/DVB (4373): Correctly handle sysfs error leg file removal in pvrusb2 V4L/DVB (4368): Bttv: use class_device_create_file and handle errors V4L/DVB (4367): Videodev: Handle class_device related errors V4L/DVB (4365): OVERLAY flag were enabled by mistake V4L/DVB (4344): Fix broken dependencies on media Kconfig V4L/DVB (4343): Fix for compilation without V4L1 or V4L1_COMPAT V4L/DVB (4342): Fix ext_controls align on 64 bit architectures V4L/DVB (4341): VIDIOCSMICROCODE were missing on compat_ioctl32 V4L/DVB (4322): Fix dvb-pll autoprobing V4L/DVB (4311): Fix possible dvb-pll oops V4L/DVB (4337): Refine dead code elimination in pvrusb2 V4L/DVB (4323): [budget/budget-av/budget-ci/budget-patch drivers] fixed DMA start/stop code V4L/DVB (4316): Check __must_check warnings V4L/DVB (4314): Set the Auxiliary Byte when tuning LG H06xF in analog mode V4L/DVB (4313): Bugfix for keycode calculation on NPG remotes V4L/DVB (4310): Saa7134: rename dmasound_{init, exit} V4L/DVB (4306): Support non interlaced capture by default for saa713x V4L/DVB (4298): Check all __must_check warnings in bttv. ...
2006-08-02[ARM] 3743/1: ARM: OMAP: Fix compile for OMAPTony Lindgren
Patch from Tony Lindgren "clocks" is only needed only for CONFIG_OMAP_RESET_CLOCKS, which turns of all unused clocks in with late_initcall. This is to kill clocks that may have been left on by the bootloader. Having static and non-static declaration of clocks makes omap_h2_1610_defconfig build fail. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-31[PATCH] powermac: More powermac backlight fixesMichael Hanselmann
This patch fixes several problems: - The legacy backlight value might be set at interrupt time. Introduced a worker to prevent it from directly calling the backlight code. - via-pmu allows the backlight to be grabbed, in which case we need to prevent other kernel code from changing the brightness. - Don't send PMU requests in via-pmu-backlight when the machine is about to sleep or waking up. - More Kconfig fixes. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] fbdev: statically link the framebuffer notification functionsAntonino A. Daplas
The backlight and lcd subsystems can be notified by the framebuffer layer of blanking events. However, these subsystems, as a whole, can function independently from the framebuffer layer. But in order to enable to the lcd and backlight subsystems, the framebuffer has to be compiled also, effectively sucking in a huge amount of unneeded code. To prevent dependency problems, separate out the framebuffer notification mechanism from the framebuffer layer and permanently link it to the kernel. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] Add parentheses around arguments in the SH_DIV macro.Uwe Zeisberger
There is currently no affected user in the tree, but usage is less surprising that way. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] always define IRQ_PER_CPUYoichi Yuasa
Reduce the likelihood of someone accidentally introducing namespace collisions. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] IA64: kprobe invalidate icache of jump bufferbibo, mao
Kprobe inserts breakpoint instruction in probepoint and then jumps to instruction slot when breakpoint is hit, the instruction slot icache must be consistent with dcache. Here is the patch which invalidates instruction slot icache area. Without this patch, in some machines there will be fault when executing instruction slot where icache content is inconsistent with dcache. Signed-off-by: bibo,mao <bibo.mao@intel.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Acked-by: Keshavamurthy Anil S <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] delay accounting: temporarily enable by defaultShailabh Nagar
Enable delay accounting by default so that feature gets coverage testing without requiring special measures. Earlier, it was off by default and had to be enabled via a boot time param. This patch reverses the default behaviour to improve coverage testing. It can be removed late in the kernel development cycle if its believed users shouldn't have to incur any cost if they don't want delay accounting. Or it can be retained forever if the utility of the stats is deemed common enough to warrant keeping the feature on. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] make taskstats sending completely independent of delay accounting ↵Shailabh Nagar
on/off status Complete the separation of delay accounting and taskstats by ignoring the return value of delay accounting functions that fill in parts of taskstats before it is sent out (either in response to a command or as part of a task exit). Also make delayacct_add_tsk return silently when delay accounting is turned off rather than treat it as an error. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
