path: root/include
2006-12-02[NET] rules: Share common attribute validation policyThomas Graf
Move the attribute policy for the non-specific attributes into net/fib_rules.h and include it in the respective protocols. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] rules: Protocol independant mark selectorThomas Graf
Move mark selector currently implemented per protocol into the protocol independant part. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV4] nl_fib_lookup: Rename fl_fwmark to fl_markThomas Graf
For the sake of consistency. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Turn nfmark into generic markThomas Graf
nfmark is being used in various subsystems and has become the defacto mark field for all kinds of packets. Therefore it makes sense to rename it to `mark' and remove the dependency on CONFIG_NETFILTER. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[XFRM]: uninline xfrm_selector_match()Andrew Morton
Six callsites, huge. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[BLUETOOTH] lockdep: annotate sk_lock nesting in AF_BLUETOOTHPeter Zijlstra
============================================= [ INFO: possible recursive locking detected ] 2.6.18-1.2726.fc6 #1
2006-12-02SELinux: Fix SA selection semanticsVenkat Yekkirala
Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. This eliminates the SELinux policy's ability to use/sendto SAs with contexts other than the socket's. With this patch applied, the SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Various xfrm labeling fixesVenkat Yekkirala
Since the upstreaming of the mlsxfrm modification a few months back, testing has resulted in the identification of the following issues/bugs that are resolved in this patch set. 1. Fix the security context used in the IKE negotiation to be the context of the socket as opposed to the context of the SPD rule. 2. Fix SO_PEERSEC for tcp sockets to return the security context of the peer as opposed to the source. 3. Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. The following would be the result of applying this patchset: - SO_PEERSEC will now correctly return the peer's context. - IKE deamons will receive the context of the source socket/flow as opposed to the SPD rule's context so that the negotiated SA will be at the same context as the source socket/flow. - The SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; This Patch: Pass correct security context to IKE for use in negotiation Fix the security context passed to IKE for use in negotiation to be the context of the socket as opposed to the context of the SPD rule so that the SA carries the label of the originating socket/flow. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[BLUETOOTH]: rfcomm endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: ip6_output annotationsAl Viro
2006-12-02[NETFILTER]: trivial annotationsAl Viro
2006-12-02[AF_PACKET]: annotateAl Viro
Weirdness: the third argument of socket() is net-endian here. Oh, well - it's documented in packet(7). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[LLC]: anotationsAl Viro
2006-12-02[IPV6]: annotate inet6_csk_search_req()Al Viro
2006-12-02[IPV6]: flowlabels are net-endianAl Viro
2006-12-02[INET]: annotate inet_ecn.hAl Viro
2006-12-02[NET]: annotate dsfield.hAl Viro
2006-12-02[XFRM]: annotate ->new_mapping()Al Viro
2006-12-02[AF_KEY]: annotateAl Viro
2006-12-02[IPV4]: encapsulation annotationsAl Viro
2006-12-02[IPV6]: annotate struct frag_hdrAl Viro
2006-12-02[IPV6]: annotate icmpv6 headersAl Viro
2006-12-02[IPV6]: 'info' argument of ipv6 ->err_handler() is net-endianAl Viro
2006-12-02[XFRM]: misc annotationsAl Viro
2006-12-02[IPV6]: annotate inet6_hashtablesAl Viro
2006-12-02[NET]: ipconfig and nfsroot annotationsAl Viro
2006-12-02[TIPC]: endianness annotationsAl Viro
2006-12-02Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (118 commits) [netdrvr] skge: build fix [PATCH] NetXen: driver cleanup, removed unnecessary __iomem type casts [PATCH] PHY: Add support for configuring the PHY connection interface [PATCH] chelesio: transmit locking (plus bug fix). [PATCH] chelsio: statistics improvement [PATCH] chelsio: add MSI support [PATCH] chelsio: use standard CRC routines [PATCH] chelsio: cleanup pm3393 code [PATCH] chelsio: add 1G swcixw aupport [PATCH] chelsio: add support for other 10G boards [PATCH] chelsio: remove unused mutex [PATCH] chelsio: use kzalloc [PATCH] chelsio: whitespace fixes [PATCH] amd8111e use standard CRC lib [PATCH] sky2: msi enhancements. [PATCH] sky2: kfree_skb_any needed [PATCH] sky2: fixes for Yukon EC_U chip revisions [PATCH] sky2: add Dlink 560SX id [PATCH] sky2: receive error handling fix [PATCH] skge: don't clear MC state on link down ...
2006-12-02Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/drzeus/mmc: mmc: correct request error handling mmc: Flush block queue when removing card mmc: sdhci high speed support mmc: Support for high speed SD cards mmc: Fix mmc_delay() function mmc: Add support for mmc v4 wide-bus modes [PATCH] mmc: Add support for mmc v4 high speed mode trivial change for mmc/Kconfig: MMC_PXA does not mean only PXA255 Make general code cleanups Add MMC_CAP_{MULTIWRITE,BYTEBLOCK} flags Platform device error handling cleanup Move register definitions away from the header file Change OMAP_MMC_{READ,WRITE} macros to use the host pointer Replace base with virt_base and phys_base mmc: constify mmc_host_ops vectors mmc: remove kernel_thread()
2006-12-02[PATCH] PHY: Add support for configuring the PHY connection interfaceAndy Fleming
Most PHYs connect to an ethernet controller over a GMII or MII interface. However, a growing number are connected over different interfaces, such as RGMII or SGMII. The ethernet driver will tell the PHY what type of connection it is by setting it manually, or passing it in through phy_connect (or phy_attach). Changes include: * Updates to documentation * Updates to PHY Lib consumers * Changes to PHY Lib to add interface support * Some minor changes to whitespace in phy.h * gianfar driver now detects interface and passes appropriate value to PHY Lib Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] mv643xx_eth: fix unbalanced parentheses in macrosMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] forcedeth: add new NVIDIA pci idsAyaz Abdulla
Add pci device ids for the NVIDIA MCP67 chip. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] wext: extend MLME supportChristian Lamparter
This patch adds two new defines for the SIOCSIWMLME to cover all kinds MLMEs (well, except REASSOC) through a ioctl. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] ieee80211: Drop and count duplicate data frames to remove 'replay ↵Larry Finger
detected' log messages In the SoftMAC version of the IEEE 802.11 stack, not all duplicate messages are detected. For the most part, there is no difficulty; however for TKIP and CCMP encryption, the duplicates result in a "replay detected" log message where the received and previous values of the TSC are identical. This change adds a new variable to the ieee80211_device structure that holds the 'seq_ctl' value for the previous frame. When a new frame repeats the value, the frame is dropped and the appropriate counter is incremented. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] ieee80211: Move IV/ICV stripping into ieee80211_rxDaniel Drake
This patch adds a host_strip_iv_icv flag to ieee80211 which indicates that ieee80211_rx should strip the IV/ICV/other security features from the payload. This saves on some memmove() calls in the driver and seems like something that belongs in the stack as it can be used by bcm43xx, ipw2200, and zd1211rw I will submit the ipw2200 patch separately as it needs testing. This patch also adds some sensible variable reuse (idx vs keyidx) in ieee80211_rx Signed-off-by: Daniel Drake <dsd@gentoo.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] 2.6.18: sb1250-mac: Missing inclusions from <linux/phy.h>Maciej W. Rozycki
The <linux/phy.h> uses some types and macros defined in <linux/ethtool.h>, <linux/mii.h>, <linux/timer.h> and <linux/workqueue.h>, but fails to include these headers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> patch-mips-2.6.18-20060920-include-phy-16 Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-01Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (31 commits) [MIPS] Remove duplicate ISA DMA code for 0 DMA channel case. [MIPS] Remove unused definition of cpu_to_lelongp() [MIPS] Remove userspace proofing from <asm/bitops.h>. [MIPS] Remove old junk left from old atomic_lock. [MIPS] Use conditional traps for BUG_ON on MIPS II and better. [MIPS] mips HPT cleanup: make clocksource_mips public [MIPS] do_IRQ cleanup [MIPS] Avoid dupliate D-cache flush on R400C / R4400 SC and MC variants. [MIPS] Remove redundant r4k_blast_icache() calls [MIPS] Work around bogus gcc warnings. [MIPS] Fix double inclusions [MIPS] use generic_handle_irq, handle_level_irq, handle_percpu_irq [MIPS] IRQ cleanups [MIPS] mips hpt cleanup: get rid of mips_hpt_init [MIPS] PB1200: Remove duplicate definitions [MIPS] Fix alignment hole in struct cache_desc; shrink struct. [MIPS] Oprofile: kernel support for the R10000. [MIPS] Remove unused R10000 performance counter definitions. [MIPS] Add support for kexec [MIPS] Don't print presence of WAIT instruction on bootup. ...
2006-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (25 commits) IB/ucm: Fix deadlock in cleanup IB/cm: Fix automatic path migration support IPoIB: Fix skb leak when freeing neighbour IB/srp: Fix memory leak on reconnect RDMA/addr: list_move() cleanups RDMA/addr: Fix some cancellation problems in process_req() RDMA/amso1100: Prevent deadlock in destroy QP IB/mthca: Fix initial SRQ logsize for mem-free HCAs IB/ehca: Use WQE offset instead of WQE addr for pending work reqs RDMA/iwcm: Fix comment for iwcm_deref_id() to match code RDMA/iwcm: Remove unnecessary function argument RDMA/iwcm: Remove unnecessary initializations RDMA/iwcm: Fix memory leak RDMA/iwcm: Fix memory corruption bug in cm_work_handler() IB: Convert kmem_cache_t -> struct kmem_cache IB/ipath: Fix typo in pma_counter_select subscript RDMA/amso1100: Fix section mismatches IB/mthca: Fix section mismatches IB/srp: Increase supported CDB size RDMA/cm: Remove setting local write as part of QP access flags ...
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (103 commits) usbcore: remove unused argument in autosuspend USB: keep count of unsuspended children USB hub: simplify remote-wakeup handling USB: struct usb_device: change flag to bitflag OHCI: make autostop conditional on CONFIG_PM USB: Add autosuspend support to the hub driver EHCI: Fix root-hub and port suspend/resume problems USB: create a new thread for every USB device found during the probe sequence USB: add driver for the USB debug devices USB: added dynamic major number for USB endpoints USB: pegasus error path not resetting task's state USB: endianness fix for asix.c USB: build the appledisplay driver USB serial: replace kmalloc+memset with kzalloc USB: hid-core: canonical defines for Apple USB device IDs USB: idmouse cleanup USB: make drivers/usb/core/driver.c:usb_device_match() static USB: lh7a40x_udc remove double declaration USB: pxa2xx_udc recognizes ixp425 rev b0 chip usbtouchscreen: add support for DMC TSC-10/25 devices ...
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (28 commits) PCI: make arch/i386/pci/common.c:pci_bf_sort static PCI: ibmphp_pci.c: fix NULL dereference pciehp: remove unnecessary pci_disable_msi pciehp: remove unnecessary free_irq PCI: rpaphp: change device tree examination PCI: Change memory allocation for acpiphp slots i2c-i801: SMBus patch for Intel ICH9 PCI: irq: irq and pci_ids patch for Intel ICH9 PCI: pci_{enable,disable}_device() nestable ports PCI: switch pci_{enable,disable}_device() to be nestable PCI: arch/i386/kernel/pci-dma.c: ioremap balanced with iounmap pci/i386: style cleanups PCI: Block on access to temporarily unavailable pci device pci: fix __pci_register_driver error handling pci: clear osc support flags if no _OSC method acpiphp: fix missing acpiphp_glue_exit() acpiphp: fix use of list_for_each macro Altix: Initial ACPI support - ROM shadowing. Altix: SN ACPI hotplug support. Altix: Add initial ACPI IO support ...
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) Driver core: show drivers in /sys/module/ Documentation/driver-model/platform.txt update/rewrite Driver core: platform_driver_probe(), can save codespace driver core: Use klist_remove() in device_move() driver core: Introduce device_move(): move a device to a new parent. Driver core: make drivers/base/core.c:setup_parent() static driver core: Introduce device_find_child(). sysfs: sysfs_write_file() writes zero terminated data cpu topology: consider sysfs_create_group return value Driver core: Call platform_notify_remove later ACPI: Change ACPI to use dev_archdata instead of firmware_data Driver core: add dev_archdata to struct device Driver core: convert sound core to use struct device Driver core: change mem class_devices to be real devices Driver core: convert fb code to use struct device Driver core: convert firmware code to use struct device Driver core: convert mmc code to use struct device Driver core: convert ppdev code to use struct device Driver core: convert PPP code to use struct device Driver core: convert cpuid code to use struct device ...
2006-12-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix typos in drivers/isdn/hisax/isdnl2.c Fix typos in doc and comments BUG_ON conversion for fs/aio.c BUG_ON conversion for drivers/mmc/omap.c BUG_ON conversion for drivers/media/video/pwc/pwc-if.c Fix misc .c/.h comment typos Fix misc Kconfig typos Fix typos in /Documentation : Misc Fix typos in /Documentation : 'U-Z' Fix typos in /Documentation : 'T'' Fix jiffies.h comment tabify MAINTAINERS fix spelling error in include/linux/kernel.h mqueue.h: don't include linux/types.h
2006-12-01Driver core: show drivers in /sys/module/Kay Sievers
Show the drivers, which belong to the module: $ ls -l /sys/module/usbcore/drivers/ hub -> ../../../bus/usb/drivers/hub usb -> ../../../bus/usb/drivers/usb usbfs -> ../../../bus/usb/drivers/usbfs Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01Driver core: platform_driver_probe(), can save codespaceDavid Brownell
This defines a new platform_driver_probe() method allowing the driver's probe() method, and its support code+data, to safely live in __init sections for typical system configurations. Many system-on-chip processors could benefit from this API, to the tune of recovering hundreds to thousands of bytes per driver. That's memory which is currently wasted holding code which can never be called after system startup, yet can not be removed. It can't be removed because of the linkage requirement that pointers to init section code (like, ideally, probe support) must not live in other sections (like driver method tables) after those pointers would be invalid. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01driver core: Introduce device_move(): move a device to a new parent.Cornelia Huck
Provide a function device_move() to move a device to a new parent device. Add auxilliary functions kobject_move() and sysfs_move_dir(). kobject_move() generates a new uevent of type KOBJ_MOVE, containing the previous path (DEVPATH_OLD) in addition to the usual values. For this, a new interface kobject_uevent_env() is created that allows to add further environmental data to the uevent at the kobject layer. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01driver core: Introduce device_find_child().Cornelia Huck
Introduce device_find_child() to match device_for_each_child(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01ACPI: Change ACPI to use dev_archdata instead of firmware_dataBenjamin Herrenschmidt
Change ACPI to use dev_archdata instead of firmware_data This patch changes ACPI to use the new dev_archdata on i386, x86_64 and ia64 (is there any other arch using ACPI ?) to store it's acpi_handle. It also removes the firmware_data field from struct device as this was the only user. Only build-tested on x86 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01Driver core: add dev_archdata to struct deviceBenjamin Herrenschmidt
Add arch specific dev_archdata to struct device Adds an arch specific struct dev_arch to struct device. This enables architecture to add specific fields to every device in the system, like DMA operation pointers, NUMA node ID, firmware specific data, etc... Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Andi Kleen <ak@suse.de> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
