path: root/include
2008-10-05xfrm: MIGRATE enhancements (draft-ebalard-mext-pfkey-enhanced-migrate)Arnaud Ebalard
Provides implementation of the enhancements of XFRM/PF_KEY MIGRATE mechanism specified in draft-ebalard-mext-pfkey-enhanced-migrate-00. Defines associated PF_KEY SADB_X_EXT_KMADDRESS extension and XFRM/netlink XFRMA_KMADDRESS attribute. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: implement GPRS virtual interface over PEP socketRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: receive pipe control requests as out-of-band dataRémi Denis-Courmont
2008-10-05Phonet: Pipe End Point for Phonet Pipes protocolRémi Denis-Courmont
This protocol provides some connection handling and negotiated congestion control. Nokia cellular modems use it for bulk transfers. It provides packet boundaries (hence SOCK_SEQPACKET). Congestion control is per packet rather per byte, so we do not re-use the generic socket memory accounting. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: connected sockets glueRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01sctp: try harder to figure out address family when checking wildcardsVlad Yasevich
sctp_is_any() function that is used to check for wildcard addresses only looks at the address itself to determine the address family. This function is used in the API to check the address passed in from the user. If the user simply zerroes out the sockaddr_storage and pass that in, we'll end up failing. So, let's try harder to determine the address family by also checking the socket if it's possible. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-10-01sctp: reduce memory footprint of sctp_chunk structureNeil Horman
sctp_chunks should be put on a diet. This is some of the low hanging fruit that we can strip out. Changes all the __s8/__u8 flags to bitfields. Saves 12 bytes per chunk. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-10-01udp: Export UDP socket lookup functionKOVACS Krisztian
The iptables tproxy code has to be able to do UDP socket hash lookups, so we have to provide an exported lookup function for this purpose. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01tcp: Port redirection support for TCPKOVACS Krisztian
Current TCP code relies on the local port of the listening socket being the same as the destination address of the incoming connection. Port redirection used by many transparent proxying techniques obviously breaks this, so we have to store the original destination port address. This patch extends struct inet_request_sock and stores the incoming destination port value there. It also modifies the handshake code to use that value as the source port when sending reply packets. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make Netfilter's ip_route_me_harder() non-local address compatibleKOVACS Krisztian
Netfilter's ip_route_me_harder() tries to re-route packets either generated or re-routed by Netfilter. This patch changes ip_route_me_harder() to handle packets from non-locally-bound sockets with IP_TRANSPARENT set as local and to set the appropriate flowi flags when re-doing the routing lookup. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01tcp: Handle TCP SYN+ACK/ACK/RST transparencyKOVACS Krisztian
The TCP stack sends out SYN+ACK/ACK/RST reply packets in response to incoming packets. The non-local source address check on output bites us again, as replies for transparently redirected traffic won't have a chance to leave the node. This patch selectively sets the FLOWI_FLAG_ANYSRC flag when doing the route lookup for those replies. Transparent replies are enabled if the listening socket has the transparent socket flag set. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Conditionally enable transparent flow flag when connectingKOVACS Krisztian
Set FLOWI_FLAG_ANYSRC in flowi->flags if the socket has the transparent socket option set. This way we selectively enable certain connections with non-local source addresses to be routed. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make inet_sock.h independent of route.hKOVACS Krisztian
inet_iif() in inet_sock.h requires route.h. Since users of inet_iif() usually require other route.h functionality anyway this patch moves inet_iif() to route.h. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Implement IP_TRANSPARENT socket optionKOVACS Krisztian
This patch introduces the IP_TRANSPARENT socket option: enabling that will make the IPv4 routing omit the non-local source address check on output. Setting IP_TRANSPARENT requires NET_ADMIN capability. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Loosen source address check on IPv4 outputJulian Anastasov
ip_route_output() contains a check to make sure that no flows with non-local source IP addresses are routed. This obviously makes using such addresses impossible. This patch introduces a flowi flag which makes omitting this check possible. The new flag provides a way of handling transparent and non-transparent connections differently. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipsec: Put dumpers on the dump listHerbert Xu
Herbert Xu came up with the idea and the original patch to make xfrm_state dump list contain also dumpers: As it is we go to extraordinary lengths to ensure that states don't go away while dumpers go to sleep. It's much easier if we just put the dumpers themselves on the list since they can't go away while they're going. I've also changed the order of addition on new states to prevent a never-ending dump. Timo Teräs improved the patch to apply cleanly to latest tree, modified iteration code to be more readable by using a common struct for entries in the list, implemented the same idea for xfrm_policy dumping and moved the af_key specific "last" entry caching to af_key. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath9k/core.c drivers/net/wireless/ath9k/main.c net/core/dev.c
2008-10-01ipv6: almost identical frag hashing funcs combinedIlpo Järvinen
$ diff-funcs ip6qhashfn reassembly.c netfilter/nf_conntrack_reasm.c --- reassembly.c:ip6qhashfn() +++ netfilter/nf_conntrack_reasm.c:ip6qhashfn() @@ -1,5 +1,5 @@ -static unsigned int ip6qhashfn(__be32 id, struct in6_addr *saddr, - struct in6_addr *daddr) +static unsigned int ip6qhashfn(__be32 id, const struct in6_addr *saddr, + const struct in6_addr *daddr) { u32 a, b, c; @@ -9,7 +9,7 @@ a += JHASH_GOLDEN_RATIO; b += JHASH_GOLDEN_RATIO; - c += ip6_frags.rnd; + c += nf_frags.rnd; __jhash_mix(a, b, c); a += (__force u32)saddr->s6_addr32[3]; And codiff xx.o.old xx.o.new: net/ipv6/netfilter/nf_conntrack_reasm.c: ip6qhashfn | -512 nf_hashfn | +6 nf_ct_frag6_gather | +36 3 functions changed, 42 bytes added, 512 bytes removed, diff: -470 net/ipv6/reassembly.c: ip6qhashfn | -512 ip6_hashfn | +7 ipv6_frag_rcv | +89 3 functions changed, 96 bytes added, 512 bytes removed, diff: -416 net/ipv6/reassembly.c: inet6_hash_frag | +510 1 function changed, 510 bytes added, diff: +510 Total: -376 Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01net: add skb_recycle_check() to enable netdriver skb recyclingLennert Buytenhek
This patch adds skb_recycle_check(), which can be used by a network driver after transmitting an skb to check whether this skb can be recycled as a receive buffer. skb_recycle_check() checks that the skb is not shared or cloned, and that it is linear and its head portion large enough (as determined by the driver) to be recycled as a receive buffer. If these conditions are met, it does any necessary reference count dropping and cleans up the skbuff as if it just came from __alloc_skb(). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2008-10-01phonet: Protect if_phonet.h against multiple inclusions.Remi Denis-Courmont
From: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30ieee80211.h: remove superfluous ETH_P_PAE definitionJohn W. Linville
2008-09-30sctp: Fix kernel panic while process protocol violation parameterWei Yongjun
Since call to function sctp_sf_abort_violation() need paramter 'arg' with 'struct sctp_chunk' type, it will read the chunk type and chunk length from the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen() always with 'struct sctp_paramhdr' type's parameter, it will be passed to sctp_sf_abort_violation(). This may cause kernel panic. sctp_sf_violation_paramlen() |-- sctp_sf_abort_violation() |-- sctp_make_abort_violation() This patch fixed this problem. This patch also fix two place which called sctp_sf_violation_paramlen() with wrong paramter type. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30Phonet: declare headersRémi Denis-Courmont
2008-09-30netdev: use const for some name functionsStephen Hemminger
dev_change_name and netdev_drivername should use const char on parameters that are read-only input values. The strcpy to newname is not needed since newname is not used later in function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-26kgdb, x86_64: fix PS CS SS registers in gdb serialJason Wessel
On x86_64 the gdb serial register structure defines the PS (also known as eflags), CS and SS registers as 4 bytes entities. This patch splits the x86_64 regnames enum into a 32 and 64 version to account for the 32 bit entities in the gdb serial packets. Also the program counter is properly filled in for the sleeping threads. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-26kgdb, x86_64: gdb serial has BX and DX reversedJason Wessel
The BX and DX registers in the gdb serial register packet need to be flipped for gdb to receive the correct data. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-25Merge branch 'master' of ↵David S. Miller
2008-09-24Merge branch 'for-2.6.28' of git://git.marvell.com/mv643xx_eth into ↵Jeff Garzik
upstream-next
2008-09-24Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fixe the definition of PTRS_PER_PGD [MIPS] au1000: Fix gpio direction
2008-09-24MN10300: Move asm-arm/cnt32_to_63.h to include/linux/David Howells
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make use of it too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24netxen: add pci idsDhananjay Phadke
Define old and new pci vendor and device ids. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix put_data error handling 9p: use an IS_ERR test rather than a NULL test 9p: introduce missing kfree 9p-trans_fd: fix and clean up module init/exit paths 9p-trans_fd: don't do fs segment mangling in p9_fd_poll() 9p-trans_fd: clean up p9_conn_create() 9p-trans_fd: fix trans_fd::p9_conn_destroy() 9p: implement proper trans module refcounting and unregistration
2008-09-249p: implement proper trans module refcounting and unregistrationTejun Heo
9p trans modules aren't refcounted nor were they unregistered properly. Fix it. * Add 9p_trans_module->owner and reference the module on each trans instance creation and put it on destruction. * Protect v9fs_trans_list with a spinlock. This isn't strictly necessary as the list is manipulated only during module loading / unloading but it's a good idea to make the API safe. * Unregister trans modules when the corresponding module is being unloaded. * While at it, kill unnecessary EXPORT_SYMBOL on p9_trans_fd_init(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-09-24mac80211: clean up rate control APIJohannes Berg
Long awaited, hard work. This patch totally cleans up the rate control API to remove the requirement to include internal headers outside of net/mac80211/. There's one internal use in the PID algorithm left for mesh networking, we'll have to figure out a way to clean that one up and decide how to do the peer link evaluation, possibly independent of the rate control algorithm or via new API. Additionally, ath9k is left using the cross-inclusion hack for now, we will add new API where necessary to make this work properly, but right now I'm not expert enough to do it. It's still off better than before. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24mac80211: mesh portal functionality supportYanBo
Currently the mesh code doesn't support bridging mesh point interfaces with wired ethernet or AP to construct an MPP or MAP. This patch adds code to support the "6 address frame format packet" functionality to mesh point interfaces. Now the mesh network can be used as backhaul for end to end communication. Signed-off-by: Li YanBo <dreamfly281@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24cfg80211: show interface typeJohannes Berg
This patch makes cfg80211 show the interface in the nl80211 information about a specific interface. API users are required to keep the type updated (everything else is fairly complicated) but you will get a warning if you fail to keep it updated. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24cfg80211: fix code ordering in header fileJohannes Berg
Luis added the regulatory hint stuff to this file without observing that __ieee80211_get_channel and ieee80211_get_channel really belong together. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24[MIPS] Fixe the definition of PTRS_PER_PGDJack Tan
When we use > 4KB's page size the original definition is not consistent with PGDIR_SIZE. For exeample, if we use 16KB page size the PGDIR_SHIFT is (14-2) + 14 = 26, PGDIR_SIZE is 2^26,so the PTRS_PER_PGD should be: 2^32/2^26 = 2^6 but the original definition of PTRS_PER_PGD is 4096 (PGDIR_ORDER = 0). So, this definition needs to be consistent with the PGDIR_SIZE. And the new definition is consistent with the PGD init in pagetable_init(). Signed-off-by: Dajie Tan <jiankemeng@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-23Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers: fix build error in !oneshot case x86: c1e_idle: don't mark TSC unstable if CPU has invariant TSC x86: prevent C-states hang on AMD C1E enabled machines clockevents: prevent mode mismatch on cpu online clockevents: check broadcast device not tick device clockevents: prevent stale tick_next_period for onlining CPUs x86: prevent stale state of c1e_mask across CPU offline/online clockevents: prevent cpu online to interfere with nohz
2008-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: fix compiler warnings in pci_get_subsys() PCI: Fix pcie_aspm=force
2008-09-23smb.h: do not include linux/time.h in userspaceKirill A. Shutemov
linux/time.h conflicts with time.h from glibc It breaks building smbmount from samba. It's regression introduced by commit 76308da (" smb.h: uses struct timespec but didn't include linux/time.h"). Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: <stable@kernel.org> [2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23x86: prevent C-states hang on AMD C1E enabled machinesThomas Gleixner
Impact: System hang when AMD C1E machines switch into C2/C3 AMD C1E enabled systems do not work with normal ACPI C-states even if the BIOS is advertising them. Limit the C-states to C1 for the ACPI processor idle code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-23x86: prevent stale state of c1e_mask across CPU offline/onlineThomas Gleixner
Impact: hang which happens across CPU offline/online on AMD C1E systems. When a CPU goes offline then the corresponding bit in the broadcast mask is cleared. For AMD C1E enabled CPUs we do not reenable the broadcast when the CPU comes online again as we do not clear the corresponding bit in the c1e_mask, which keeps track which CPUs have been switched to broadcast already. So on those !$@#& machines we never switch back to broadcasting after a CPU offline/online cycle. Clear the bit when the CPU plays dead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-23pkt_sched: Remove the tx queue state check in qdisc_run()Jarek Poplawski
The current check wrongly uses the state of one (currently the first) tx queue for all tx queues in case of non-default qdiscs. This check mainly prevented requeuing loop with __netif_schedule(), but now it's controlled inside __qdisc_run(), while dequeuing. The wrongness of this check was first noticed by Herbert Xu. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-23tcp: Use SKB queue handling interfaces instead of by-hand versions.David S. Miller
2008-09-23net: Add skb_queue_walk_from() and skb_queue_walk_from_safe().David S. Miller
These will be used by TCP write queue handling and elsewhere. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-23net: Add skb_queue_next().David S. Miller
A lot of code wants to iterate over an SKB queue at the top level using it's own control structure and iterator scheme. Provide skb_queue_next(), which is only valid to invoke if skb_queue_is_last() returns false. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-23tcp: Use skb_queue_is_last() instead of by-hand version.David S. Miller
2008-09-23net: Add skb_queue_is_last().David S. Miller
Several bits of code want to know "is this the last SKB in a queue", and all of them implement this by hand. Provide an common interface to make this check. Signed-off-by: David S. Miller <davem@davemloft.net>
