This commit moves from the old ACCESS_ONCE() API to the new READ_ONCE()
and WRITE_ONCE() APIs.
[ paulmck: Updated to include kernel/torture.c as suggested by Jason Low. ]
Pull irq updates from Thomas Gleixner:
"Two patches from the irq departement:
- a simple fix to make dummy_irq_chip usable for wakeup scenarios
- removal of the gic arch_extn hackery. Now that all users are
converted we really want to get rid of the interface so people wont
come up with new use cases"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: gic: Drop support for gic_arch_extn
genirq: Set IRQCHIP_SKIP_SET_WAKE flag for dummy_irq_chip
Pull block fixes from Jens Axboe:
"A collection of fixes since the merge window;
- fix for a double elevator module release, from Chao Yu. Ancient bug.
- the splice() MORE flag fix from Christophe Leroy.
- a fix for NVMe, fixing a patch that went in in the merge window.
From Keith.
- two fixes for blk-mq CPU hotplug handling, from Ming Lei.
- bdi vs blockdev lifetime fix from Neil Brown, fixing and oops in md.
- two blk-mq fixes from Shaohua, fixing a race on queue stop and a
bad merge issue with FUA writes.
- division-by-zero fix for writeback from Tejun.
- a block bounce page accounting fix, making sure we inc/dec after
bouncing so that pre/post IO pages match up. From Wang YanQing"
* 'for-linus' of git://git.kernel.dk/linux-block:
splice: sendfile() at once fails for big files
blk-mq: don't lose requests if a stopped queue restarts
blk-mq: fix FUA request hang
block: destroy bdi before blockdev is unregistered.
block:bounce: fix call inc_|dec_zone_page_state on different pages confuse value of NR_BOUNCE
elevator: fix double release of elevator module
writeback: use |1 instead of +1 to protect against div by zero
blk-mq: fix CPU hotplug handling
blk-mq: fix race between timeout and CPU hotplug
NVMe: Fix VPD B0 max sectors translation
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fix from Steven Rostedt:
"The newly added ftrace_print_array_seq() function had a bug in it.
Luckily, the only user of it didn't make the 4.1 merge window.
But the helper function should be fixed before 4.2 when the users
start coming in"
* tag 'trace-fixes-v4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Make ftrace_print_array_seq compute buf_len
Pull infiniband updates from Doug Ledford:
"Minor updates for 4.1-rc
Most of the changes are fairly small and well confined. The iWARP
address reporting changes are the only ones that are a medium size. I
had these queued up prior to rc1, but due to the shuffle in
maintainers, they did not get submitted when I expected. My apologies
for that. I feel comfortable with them however due to the testing
they've received, so I left them in this submission"
* tag 'for-linus' of git://github.com/dledford/linux:
MAINTAINERS: Update InfiniBand subsystem maintainer
MAINTAINERS: add include/rdma/ to InfiniBand subsystem
IPoIB/CM: Fix indentation level
iw_cxgb4: Remove negative advice dmesg warnings
IB/core: Fix unaligned accesses
IB/core: change rdma_gid2ip into void function as it always return zero
IB/qib: use arch_phys_wc_add()
IB/qib: add acounting for MTRR
IB/core: dma unmap optimizations
IB/core: dma map/unmap locking optimizations
RDMA/cxgb4: Report the actual address of the remote connecting peer
RDMA/nes: Report the actual address of the remote connecting peer
RDMA/core: Enable the iWarp Port Mapper to provide the actual address of the connecting peer to its clients
iw_cxgb4: enforce qp/cq id requirements
iw_cxgb4: use BAR2 GTS register for T5 kernel mode CQs
iw_cxgb4: 32b platform fixes
iw_cxgb4: Cleanup register defines/MACROS
RDMA/CMA: Canonize IPv4 on IPV6 sockets properly
The only caller to this function (__print_array) was getting it wrong by
passing the array length instead of buffer length. As the element size
was already being passed for other reasons it seems reasonable to push
the calculation of buffer length into the function.
Link: http://lkml.kernel.org/r/1430320727-14582-1-git-send-email-alex.bennee@linaro.org
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen bug fixes from David Vrabel:
- fix blkback regression if using persistent grants
- fix various event channel related suspend/resume bugs
- fix AMD x86 regression with X86_BUG_SYSRET_SS_ATTRS
- SWIOTLB on ARM now uses frames <4 GiB (if available) so device only
capable of 32-bit DMA work.
* tag 'for-linus-4.1b-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: Add __GFP_DMA flag when xen_swiotlb_init gets free pages on ARM
hypervisor/x86/xen: Unset X86_BUG_SYSRET_SS_ATTRS on Xen PV guests
xen/events: Set irq_info->evtchn before binding the channel to CPU in __startup_pirq()
xen/console: Update console event channel on resume
xen/xenbus: Update xenbus event channel on resume
xen/events: Clear cpu_evtchn_mask before resuming
xen-pciback: Add name prefix to global 'permissive' variable
xen: Suspend ticks on all CPUs during suspend
xen/grant: introduce func gnttab_unmap_refs_sync()
xen/blkback: safely unmap purge persistent grants
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, but also an uncore PMU driver fix and an uncore
PMU driver hardware-enablement addition"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf probe: Fix segfault if passed with ''.
perf report: Fix -T/--threads option to work again
perf bench numa: Fix immediate meeting of convergence condition
perf bench numa: Fixes of --quiet argument
perf bench futex: Fix hung wakeup tasks after requeueing
perf probe: Fix bug with global variables handling
perf top: Fix a segfault when kernel map is restricted.
tools lib traceevent: Fix build failure on 32-bit arch
perf kmem: Fix compiles on RHEL6/OL6
tools lib api: Undefine _FORTIFY_SOURCE before setting it
perf kmem: Consistently use PRIu64 for printing u64 values
perf trace: Disable events and drain events when forked workload ends
perf trace: Enable events when doing system wide tracing and starting a workload
perf/x86/intel/uncore: Move PCI IDs for IMC to uncore driver
perf/x86/intel/uncore: Add support for Intel Haswell ULT (lower power Mobile Processor) IMC uncore PMUs
perf/x86/intel: Add cpu_(prepare|starting|dying) for core_pmu
The range check for b-tree level parameter in nilfs_btree_root_broken()
is wrong; it accepts the case of "level == NILFS_BTREE_LEVEL_MAX" even
though the level is limited to values in the range of 0 to
(NILFS_BTREE_LEVEL_MAX - 1).
Since the level parameter is read from storage device and used to index
nilfs_btree_path array whose element count is NILFS_BTREE_LEVEL_MAX, it
can cause memory overrun during btree operations if the boundary value
is set to the level parameter on device.
This fixes the broken sanity check and adds a comment to clarify that
the upper bound NILFS_BTREE_LEVEL_MAX is exclusive.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Cc: <stable@vger.kernel.org>
Using the new find_closest() macro can result in the following sparse
warnings.
drivers/hwmon/lm85.c:194:16: warning:
incorrect type in initializer (different modifiers)
drivers/hwmon/lm85.c:194:16: expected int *__fc_a
drivers/hwmon/lm85.c:194:16: got int static const [toplevel] *<noident>
drivers/hwmon/lm85.c:210:16: warning:
drivers/hwmon/lm85.c:210:16: expected int *__fc_a
drivers/hwmon/lm85.c:210:16: got int const *map
This is because the array passed to find_closest() will typically be
declared as array of constants, but the macro declares a non-constant
pointer to it.
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Addresses the following kernel logs seen during boot of sparc systems:
Kernel unaligned access at TPC[103bce50] cm_find_listen+0x34/0xf8 [ib_cm]
Signed-off-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Signed-off-by: Honggang Li <honli@redhat.com>
Acked-by: Sean Hefty <sean.hefty@intel.com>
Pull crypto fixes from Herbert Xu:
"This fixes a build problem with bcm63xx and yet another fix to the
memzero_explicit function to ensure that the memset is not elided"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
hwrng: bcm63xx - Fix driver compilation
lib: make memzero_explicit more robust against dead store elimination
Add functionality to enable the port mapper on the passive side to provide to its
clients the actual (non-mapped) ip/tcp address information of the connecting peer
1) Adding remote_info_cb() to process the address info of the connecting peer
The address info is provided by the user space port mapper service when
the connection is initiated by the peer
2) Adding a hash list to store the remote address info
3) Adding functionality to add/remove the remote address info
After the info has been provided to the port mapper client,
it is removed from the hash list
Signed-off-by: Tatyana Nikolova <tatyana.e.nikolova@intel.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
When a FUA request enters its DATA stage of flush pipeline, the
request is added to mq requeue list, the request will then be added to
ctx->rq_list. blk_mq_attempt_merge() might merge the request with a bio.
Later when the request is finished the flush pipeline, the
request->__data_len is 0. Then I only saw the bio gets endio called, the
original request never finish.
Adding REQ_FLUSH_SEQ into REQ_NOMERGE_FLAGS looks an easy fix.
stable: 3.15+
Signed-off-by: Shaohua Li <shli@fb.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
In commit 0b053c951829 ("lib: memzero_explicit: use barrier instead
of OPTIMIZER_HIDE_VAR"), we made memzero_explicit() more robust in
case LTO would decide to inline memzero_explicit() and eventually
find out it could be elimiated as dead store.
While using barrier() works well for the case of gcc, recent efforts
from LLVMLinux people suggest to use llvm as an alternative to gcc,
and there, Stephan found in a simple stand-alone user space example
that llvm could nevertheless optimize and thus elimitate the memset().
A similar issue has been observed in the referenced llvm bug report,
which is regarded as not-a-bug.
Based on some experiments, icc is a bit special on its own, while it
doesn't seem to eliminate the memset(), it could do so with an own
implementation, and then result in similar findings as with llvm.
The fix in this patch now works for all three compilers (also tested
with more aggressive optimization levels). Arguably, in the current
kernel tree it's more of a theoretical issue, but imho, it's better
to be pedantic about it.
It's clearly visible with gcc/llvm though, with the below code: if we
would have used barrier() only here, llvm would have omitted clearing,
not so with barrier_data() variant:
static inline void memzero_explicit(void *s, size_t count)
memset(s, 0, count);
barrier_data(s);
int main(void)
char buff[20];
memzero_explicit(buff, sizeof(buff));
return 0;
$ gcc -O2 test.c
$ gdb a.out
(gdb) disassemble main
Dump of assembler code for function main:
0x0000000000400400 <+0>: lea -0x28(%rsp),%rax
0x0000000000400405 <+5>: movq $0x0,-0x28(%rsp)
0x000000000040040e <+14>: movq $0x0,-0x20(%rsp)
0x0000000000400417 <+23>: movl $0x0,-0x18(%rsp)
0x000000000040041f <+31>: xor %eax,%eax
0x0000000000400421 <+33>: retq
End of assembler dump.
$ clang -O2 test.c
$ gdb a.out
0x00000000004004f0 <+0>: xorps %xmm0,%xmm0
0x00000000004004f3 <+3>: movaps %xmm0,-0x18(%rsp)
0x00000000004004f8 <+8>: movl $0x0,-0x8(%rsp)
0x0000000000400500 <+16>: lea -0x18(%rsp),%rax
0x0000000000400505 <+21>: xor %eax,%eax
0x0000000000400507 <+23>: retq
As gcc, clang, but also icc defines __GNUC__, it's sufficient to define
this in compiler-gcc.h only to be picked up. For a fallback or otherwise
unsupported compiler, we define it as a barrier. Similarly, for ecc which
does not support gcc inline asm.
Reference: https://llvm.org/bugs/show_bug.cgi?id=15495
Reported-by: Stephan Mueller <smueller@chronox.de>
Tested-by: Stephan Mueller <smueller@chronox.de>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Stephan Mueller <smueller@chronox.de>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: mancha security <mancha1@zoho.com>
Cc: Mark Charlebois <charlebm@gmail.com>
Cc: Behan Webster <behanw@converseincode.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is three logical fixes (as 5 patches).
The 3ware class of drivers were causing an oops with multiqueue by
tearing down the command mappings after completing the command (where
the variables in the command used to tear down the mapping were
no-longer valid). There's also a fix for the qnap iscsi target which
was choking on us sending it commands that were too long and a fix for
the reworked aha1542 allocating GFP_KERNEL under a lock"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
3w-9xxx: fix command completion race
3w-xxxx: fix command completion race
3w-sas: fix command completion race
aha1542: Allocate memory before taking a lock
SCSI: add 1024 max sectors black list flag
Pull networking fixes from David Miller:
1) Receive packet length needs to be adjust by 2 on RX to accomodate
the two padding bytes in altera_tse driver. From Vlastimil Setka.
2) If rx frame is dropped due to out of memory in macb driver, we leave
the receive ring descriptors in an undefined state. From Punnaiah
Choudary Kalluri
3) Some netlink subsystems erroneously signal NLM_F_MULTI. That is
only for dumps. Fix from Nicolas Dichtel.
4) Fix mis-use of raw rt->rt_pmtu value in ipv4, one must always go via
the ipv4_mtu() helper. From Herbert Xu.
5) Fix null deref in bridge netfilter, and miscalculated lengths in
jump/goto nf_tables verdicts. From Florian Westphal.
6) Unhash ping sockets properly.
7) Software implementation of BPF divide did 64/32 rather than 64/64
bit divide. The JITs got it right. Fix from Alexei Starovoitov.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (30 commits)
ipv4: Missing sk_nulls_node_init() in ping_unhash().
net: fec: Fix RGMII-ID mode
net/mlx4_en: Schedule napi when RX buffers allocation fails
netxen_nic: use spin_[un]lock_bh around tx_clean_lock
net/mlx4_core: Fix unaligned accesses
mlx4_en: Use correct loop cursor in error path.
cxgb4: Fix MC1 memory offset calculation
bnx2x: Delay during kdump load
net: Fix Kernel Panic in bonding driver debugfs file: rlb_hash_table
net: dsa: Fix scope of eeprom-length property
net: macb: Fix race condition in driver when Rx frame is dropped
hv_netvsc: Fix a bug in netvsc_start_xmit()
altera_tse: Correct rx packet length
mlx4: Fix tx ring affinity_mask creation
tipc: fix problem with parallel link synchronization mechanism
tipc: remove wrong use of NLM_F_MULTI
bridge/nl: remove wrong use of NLM_F_MULTI
bridge/mdb: remove wrong use of NLM_F_MULTI
net: sched: act_connmark: don't zap skb->nfct
trivial: net: systemport: bcmsysport.h: fix 0x0x prefix
Here the "other side" refers to the guest or host.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Pull power management and ACPI fixes from Rafael Wysocki:
"Three regression fixes this time, one for a recent regression in the
cpuidle core affecting multiple systems, one for an inadvertently
added duplicate typedef in ACPICA that breaks compilation with GCC 4.5
and one for an ACPI Smart Battery Subsystem driver regression
introduced during the 3.18 cycle (stable-candidate).
Specifics:
- Fix for a regression in the cpuidle core introduced by one of the
recent commits in the clockevents_notify() removal series that put
a call to a function which had to be executed with disabled
interrupts into a code path running with enabled interrupts (Rafael
J Wysocki)
- Fix for a build problem in ACPICA (with GCC 4.5) introduced by one
of the recent ACPICA tools commits that added a duplicate typedef
to one of the ACPICA's header files by mistake (Olaf Hering)
- Fix for a regression in the ACPI SBS (Smart Battery Subsystem)
driver introduced during the 3.18 development cycle causing the
smart battery manager to be marked as not present when it should be
marked as present (Chris Bainbridge)"
* tag 'pm+acpi-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: Run tick_broadcast_exit() with disabled interrupts
ACPI / SBS: Enable battery manager when present
ACPICA: remove duplicate u8 typedef
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"One nice fix is Peter's patch to make the old good SB Audigy PCI to
work with 32bit DMA instead of 31bit. This allows the MIDI synth
running on modern machines again. Along with it, a few fixes for
emu10k1 have merged.
In ASoC side, there is one fix in the common code, but it's just
trivial additions of static inline functions for CONFIG_PM=n. The
rest are various device-specific small fixes.
Last but not least, a few HD-audio fixes are included, as usual, too"
* tag 'sound-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (23 commits)
ASoC: rt5677: fixed wrong DMIC ref clock
ALSA: emu10k1: Emu10k2 32 bit DMA mode
ALSA: emux: Fix mutex deadlock in OSS emulation
ASoC: Update email-id of Rajeev Kumar
ASoC: rt5645: Fix mask for setting RT5645_DMIC_2_DP_GPIO12 bit
ALSA: hda - Fix missing va_end() call in snd_hda_codec_pcm_new()
ALSA: emux: Fix mutex deadlock at unloading
ALSA: emu10k1: Fix card shortname string buffer overflow
ALSA: hda - Add mute-LED mode control to Thinkpad
ALSA: hda - Fix mute-LED fixed mode
ALSA: hda - Fix click noise at start on Dell XPS13
ASoC: rt5645: Add ACPI match ID
ASoC: rt5677: add register patch for PLL
ASoC: Intel: fix the makefile for atom code
ASoC: dapm: Enable autodisable on SOC_DAPM_SINGLE_TLV_AUTODISABLE
ASoC: add static inline funcs to fix a compiling issue
ASoC: Intel: sst_byt: remove kfree for memory allocated with devm_kzalloc
ASoC: samsung: s3c24xx-i2s: Fix return value check in s3c24xx_iis_dev_probe()
ASoC: tfa9879: Fix return value check in tfa9879_i2c_probe()
ASoC: fsl_ssi: Fix platform_get_irq() error handling
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v4.1
A few fixes for v4.1, none earth shattering and mostly driver related
except for one change to fix !PM builds for Intel platforms which is
done by adding stubs in the core so other platforms don't run into the
same issue.
Pull kvm changes from Paolo Bonzini:
"Remove from guest code the handling of task migration during a pvclock
read; instead use the correct protocol in KVM.
This removes the need for task migration notifiers in core scheduler
code"
[ The scheduler people really hated the migration notifiers, so this was
kind of required - Linus ]
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
x86: pvclock: Really remove the sched notifier for cross-cpu migrations
kvm: x86: fix kvmclock update protocol
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some small tty/serial driver fixes for 4.1-rc2.
They include some minor fixes that resolve reported issues, and a new
device quirk.
All have been in linux-next succesfully"
* tag 'tty-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
serial: 8250_pci: Add support for 16 port Exar boards
serial: samsung: fix serial console break
tty/serial: at91: maxburst was missing for dma transfers
serial: of-serial: Remove device_type = "serial" registration
serial: xilinx: Use platform_get_irq to get irq description structure
serial: core: Fix kernel-doc build warnings
tty: Re-add external interface for tty_set_termios()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of small USB fixes for 4.2-rc2. They revert one
problem patch, fix some minor things, and add some new quirks for
"broken" devices.
All have been in linux-next successfully"
* tag 'usb-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
cdc-acm: prevent infinite loop when parsing CDC headers.
Revert "usb: host: ehci-msm: Use devm_ioremap_resource instead of devm_ioremap"
usb: chipidea: otg: remove mutex unlock and lock while stop and start role
uas: Set max_sectors_240 quirk for ASM1053 devices
uas: Add US_FL_MAX_SECTORS_240 flag
uas: Allow uas_use_uas_driver to return usb-storage flags
NLM_F_MULTI must be used only when a NLMSG_DONE message is sent. In fact,
it is sent only at the end of a dump.
Libraries like libnl will wait forever for NLMSG_DONE.
Fixes: e5a55a898720 ("net: create generic bridge ops")
Fixes: 815cccbf10b2 ("ixgbe: add setlink, getlink support to ixgbe and ixgbevf")
CC: John Fastabend <john.r.fastabend@intel.com>
CC: Sathya Perla <sathya.perla@emulex.com>
CC: Subbu Seetharaman <subbu.seetharaman@emulex.com>
CC: Ajit Khaparde <ajit.khaparde@emulex.com>
CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
CC: intel-wired-lan@lists.osuosl.org
CC: Jiri Pirko <jiri@resnulli.us>
CC: Scott Feldman <sfeldma@gmail.com>
CC: Stephen Hemminger <stephen@networkplumber.org>
CC: bridge@lists.linux-foundation.org
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Commit 77e32c89a711 ("clockevents: Manage device's state separately for
the core") decouples clockevent device's modes from states. With this
change when a Xen guest tries to resume, it won't be calling its
set_mode op which needs to be done on each VCPU in order to make the
hypervisor aware that we are in oneshot mode.
This happens because clockevents_tick_resume() (which is an intermediate
step of resuming ticks on a processor) doesn't call clockevents_set_state()
anymore and because during suspend clockevent devices on all VCPUs (except
for the one doing the suspend) are left in ONESHOT state. As result, during
resume the clockevents state machine will assume that device is already
where it should be and doesn't need to be updated.
To avoid this problem we should suspend ticks on all VCPUs during
suspend.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
'asoc/fix/pm', 'asoc/fix/qcom' and 'asoc/fix/rcar' into asoc-linus
Looks like audigy emu10k2 (probably emu10k1 - sb live too) support two
modes for DMA. Second mode is useful for 64 bit os with more then 2 GB
of ram (fixes problems with big soundfont loading)
1) 32MB from 2 GB address space using 8192 pages (used now as default)
2) 16MB from 4 GB address space using 4096 pages
Mode is set using HCFG_EXPANDED_MEM flag in HCFG register.
Also format of emu10k2 page table is then different.
Signed-off-by: Peter Zubaj <pzubaj@marticonet.sk>
Tested-by: Takashi Iwai <tiwai@suse.de>
During commit e252652fb266 ("ACPICA: acpidump: Remove integer types
translation protection.") two 'unsigned char' types got converted to 'u8'.
The result does not compile with gcc-4.5, it can not cope with duplicate
typedefs.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"One additional new feature for 4.1, a new PRNG based on SHA-512 for
the zcrypt driver.
Two memory management related changes, the page table reallocation for
KVM is removed, and with file ptes gone the encoding of page table
entries is improved.
And three bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/zcrypt: Introduce new SHA-512 based Pseudo Random Generator.
s390/mm: change swap pte encoding and pgtable cleanup
s390/mm: correct transfer of dirty & young bits in __pmd_to_pte
s390/bpf: add dependency to z196 features
s390/3215: free memory in error path
s390/kvm: remove delayed reallocation of page tables for KVM
kexec: allocate the kexec control page with KEXEC_CONTROL_MEMORY_GFP
rajeev-dlh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with Rajeev Kumar <rajeevkumar.linux@gmail.com>
Signed-off-by: Rajeev Kumar <rajeevkumar.linux@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
This is needed by Bluetooth hci_uart module to be able to change speed
of Bluetooth controller and local UART.
Signed-off-by: Frederic Danis <frederic.danis@linux.intel.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
The usb-storage driver sets max_sectors = 240 in its scsi-host template,
for uas we do not want to do that for all devices, but testing has shown
that some devices need it.
This commit adds a US_FL_MAX_SECTORS_240 flag for such devices, and
implements support for it in uas.c, while at it it also adds support
for US_FL_MAX_SECTORS_64 to uas.c.
Cc: stable@vger.kernel.org # 3.16
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix a crash in nf_tables when dictionaries are used from the ruleset,
due to memory corruption, from Florian Westphal.
2) Fix another crash in nf_queue when used with br_netfilter. Also from
Florian.
Both fixes are related to new stuff that got in 4.0-rc.
1) mlx4 doesn't check fully for supported valid RSS hash function, fix
from Amir Vadai
2) Off by one in ibmveth_change_mtu(), from David Gibson
3) Prevent altera chip from reporting false error interrupts in some
circumstances, from Chee Nouk Phoon
4) Get rid of that stupid endless loop trying to allocate a FIN packet
in TCP, and in the process kill deadlocks. From Eric Dumazet
5) Fix get_rps_cpus() crash due to wrong invalid-cpu value, also from
Eric Dumazet
6) Fix two bugs in async rhashtable resizing, from Thomas Graf
7) Fix topology server listener socket namespace bug in TIPC, from Ying
Xue
8) Add some missing HAS_DMA kconfig dependencies, from Geert
Uytterhoeven
9) bgmac driver intends to force re-polling but does so by returning
the wrong value from it's ->poll() handler. Fix from Rafał Miłecki
10) When the creater of an rhashtable configures a max size for it,
don't bark in the logs and drop insertions when that is exceeded.
Fix from Johannes Berg
11) Recover from out of order packets in ppp mppe properly, from Sylvain
Rochet
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits)
bnx2x: really disable TPA if 'disable_tpa' option is set
net:treewide: Fix typo in drivers/net
net/mlx4_en: Prevent setting invalid RSS hash function
mdio-mux-gpio: use new gpiod_get_array and gpiod_put_array functions
netfilter; Add some missing default cases to switch statements in nft_reject.
ppp: mppe: discard late packet in stateless mode
ppp: mppe: sanity error path rework
net/bonding: Make DRV macros private
net: rfs: fix crash in get_rps_cpus()
altera tse: add support for fixed-links.
pxa168: fix double deallocation of managed resources
net: fix crash in build_skb()
net: eth: altera: Resolve false errors from MSGDMA to TSE
ehea: Fix memory hook reference counting crashes
net/tg3: Release IRQs on permanent error
net: mdio-gpio: support access that may sleep
inet: fix possible panic in reqsk_queue_unlink()
rhashtable: don't attempt to grow when at max_size
bgmac: fix requests for extra polling calls from NAPI
tcp: avoid looping in tcp_send_fin()
This works around a issue with qnap iscsi targets not handling large IOs
very well.
The target returns:
VPD INQUIRY: Block limits page (SBC)
Maximum compare and write length: 1 blocks
Optimal transfer length granularity: 1 blocks
Maximum transfer length: 4294967295 blocks
Optimal transfer length: 4294967295 blocks
Maximum prefetch, xdread, xdwrite transfer length: 0 blocks
Maximum unmap LBA count: 8388607
Maximum unmap block descriptor count: 1
Optimal unmap granularity: 16383
Unmap granularity alignment valid: 0
Unmap granularity alignment: 0
Maximum write same length: 0xffffffff blocks
Maximum atomic transfer length: 0
Atomic alignment: 0
Atomic transfer length granularity: 0
and it is *sometimes* able to handle at least one IO of size up to 8 MB. We
have seen in traces where it will sometimes work, but other times it
looks like it fails and it looks like it returns failures if we send
multiple large IOs sometimes. Also it looks like it can return 2 different
errors. It will sometimes send iscsi reject errors indicating out of
resources or it will send invalid cdb illegal requests check conditions.
And then when it sends iscsi rejects it does not seem to handle retries
when there are command sequence holes, so I could not just add code to
try and gracefully handle that error code.
The problem is that we do not have a good contact for the company,
so we are not able to determine under what conditions it returns
which error and why it sometimes works.
So, this patch just adds a new black list flag to set targets like this to
the old max safe sectors of 1024. The max_hw_sectors changes added in 3.19
caused this regression, so I also ccing stable.
Reported-by: Christian Hesse <list@eworm.de>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
This reverts commits 0a4e6be9ca17c54817cf814b4b5aa60478c6df27
and 80f7fdb1c7f0f9266421f823964fd1962681f6ce.
The task migration notifier was originally introduced in order to support
the pvclock vsyscall with non-synchronized TSC, but KVM only supports it
with synchronized TSC. Hence, on KVM the race condition is only needed
due to a bad implementation on the host side, and even then it's so rare
that it's mostly theoretical.
As far as KVM is concerned it's possible to fix the host, avoiding the
additional complexity in the vDSO and the (re)introduction of the task
migration notifier.
Xen, on the other hand, hasn't yet implemented vsyscall support at
all, so we do not care about its plans for non-synchronized TSC.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Marcelo Tosatti <mtosatti@redhat.com>
There are several place using gnttab async unmap and wait for
completion, so move the common code to a function
gnttab_unmap_refs_sync().
Signed-off-by: Bob Liu <bob.liu@oracle.com>
Acked-by: Roger Pau Monné <roger.pau@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
The bonding modules currently defines four macros with
general names that pollute the global namespace:
DRV_VERSION
DRV_RELDATE
DRV_NAME
DRV_DESCRIPTION
Fixing that by defining a private bonding_priv.h
header files which includes those defines.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Pull intel iommu updates from David Woodhouse:
"This lays a little of the groundwork for upcoming Shared Virtual
Memory support — fixing some bogus #defines for capability bits and
adding the new ones, and starting to use the new wider page tables
where we can, in anticipation of actually filling in the new fields
therein.
It also allows graphics devices to be assigned to VM guests again.
This got broken in 3.17 by disallowing assignment of RMRR-afflicted
devices. Like USB, we do understand why there's an RMRR for graphics
devices — and unlike USB, it's actually sane. So we can make an
exception for graphics devices, just as we do USB controllers.
Finally, tone down the warning about the X2APIC_OPT_OUT bit, due to
persistent requests. X2APIC_OPT_OUT was added to the spec as a nasty
hack to allow broken BIOSes to forbid us from using X2APIC when they
do stupid and invasive things and would break if we did.
Someone noticed that since Windows doesn't have full IOMMU support for
DMA protection, setting the X2APIC_OPT_OUT bit made Windows avoid
initialising the IOMMU on the graphics unit altogether.
This means that it would be available for use in "driver mode", where
the IOMMU registers are made available through a BAR of the graphics
device and the graphics driver can do SVM all for itself.
So they started setting the X2APIC_OPT_OUT bit on *all* platforms with
SVM capabilities. And even the platforms which *might*, if the
planets had been aligned correctly, possibly have had SVM capability
but which in practice actually don't"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: support extended root and context entries
iommu/vt-d: Add new extended capabilities from v2.3 VT-d specification
iommu/vt-d: Allow RMRR on graphics devices too
iommu/vt-d: Print x2apic opt out info instead of printing a warning
iommu/vt-d: kill bogus ecap_niotlb_iunits()
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform
Pull chrome platform updates from Olof Johansson:
"Here's a set of updates to the Chrome OS platform drivers for this
merge window.
Main new things this cycle is:
- Driver changes to expose the lightbar to users. With this, you can
make your own blinkenlights on Chromebook Pixels.
- Changes in the way that the atmel_mxt trackpads are probed. The
laptop driver is trying to be smart and not instantiate the devices
that don't answer to probe. For the trackpad that can come up in
two modes (bootloader or regular), this gets complicated since the
driver already knows how to handle the two modes including the
actual addresses used. So now the laptop driver needs to know more
too, instantiating the regular address even if the bootloader one
is the probe that passed.
- mfd driver improvements by Javier Martines Canillas, and a few
bugfixes from him, kbuild and myself"
* tag 'chrome-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform:
platform/chrome: chromeos_laptop - instantiate Atmel at primary address
platform/chrome: cros_ec_lpc - Depend on X86 || COMPILE_TEST
platform/chrome: cros_ec_lpc - Include linux/io.h header file
platform/chrome: fix platform_no_drv_owner.cocci warnings
platform/chrome: cros_ec_lightbar - fix duplicate const warning
platform/chrome: cros_ec_dev - fix Unknown escape '%' warning
platform/chrome: Expose Chrome OS Lightbar to users
platform/chrome: Create sysfs attributes for the ChromeOS EC
mfd: cros_ec: Instantiate ChromeOS EC character device
platform/chrome: Add Chrome OS EC userspace device interface
platform/chrome: Add cros_ec_lpc driver for x86 devices
mfd: cros_ec: Add char dev and virtual dev pointers
mfd: cros_ec: Use fixed size arrays to transfer data with the EC
Pull second batch of KVM changes from Paolo Bonzini:
"This mostly includes the PPC changes for 4.1, which this time cover
Book3S HV only (debugging aids, minor performance improvements and
some cleanups). But there are also bug fixes and small cleanups for
ARM, x86 and s390.
The task_migration_notifier revert and real fix is still pending
review, but I'll send it as soon as possible after -rc1"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (29 commits)
KVM: arm/arm64: check IRQ number on userland injection
KVM: arm: irqfd: fix value returned by kvm_irq_map_gsi
KVM: VMX: Preserve host CR4.MCE value while in guest mode.
KVM: PPC: Book3S HV: Use msgsnd for signalling threads on POWER8
KVM: PPC: Book3S HV: Translate kvmhv_commence_exit to C
KVM: PPC: Book3S HV: Streamline guest entry and exit
KVM: PPC: Book3S HV: Use bitmap of active threads rather than count
KVM: PPC: Book3S HV: Use decrementer to wake napping threads
KVM: PPC: Book3S HV: Don't wake thread with no vcpu on guest IPI
KVM: PPC: Book3S HV: Get rid of vcore nap_count and n_woken
KVM: PPC: Book3S HV: Move vcore preemption point up into kvmppc_run_vcpu
KVM: PPC: Book3S HV: Minor cleanups
KVM: PPC: Book3S HV: Simplify handling of VCPUs that need a VPA update
KVM: PPC: Book3S HV: Accumulate timing information for real-mode code
KVM: PPC: Book3S HV: Create debugfs file for each guest's HPT
KVM: PPC: Book3S HV: Add ICP real mode counters
KVM: PPC: Book3S HV: Move virtual mode ICP functions to real-mode
KVM: PPC: Book3S HV: Convert ICS mutex lock to spin lock
KVM: PPC: Book3S HV: Add guest->host real mode completion counters
KVM: PPC: Book3S HV: Add helpers for lock/unlock hpte
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
I_DIO_WAKEUP is never directly used, but fix it up anyway.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
do_blockdev_direct_IO() increments and decrements the inode
->i_dio_count for each IO operation. It does this to protect against
truncate of a file. Block devices don't need this sort of protection.
For a capable multiqueue setup, this atomic int is the only shared
state between applications accessing the device for O_DIRECT, and it
presents a scaling wall for that. In my testing, as much as 30% of
system time is spent incrementing and decrementing this value. A mixed
read/write workload improved from ~2.5M IOPS to ~9.6M IOPS, with
better latencies too. Before:
clat percentiles (usec):
| 1.00th=[ 33], 5.00th=[ 34], 10.00th=[ 34], 20.00th=[ 34],
| 30.00th=[ 34], 40.00th=[ 34], 50.00th=[ 35], 60.00th=[ 35],
| 70.00th=[ 35], 80.00th=[ 35], 90.00th=[ 37], 95.00th=[ 80],
| 99.00th=[ 98], 99.50th=[ 151], 99.90th=[ 155], 99.95th=[ 155],
| 99.99th=[ 165]
After:
| 1.00th=[ 95], 5.00th=[ 108], 10.00th=[ 129], 20.00th=[ 149],
| 30.00th=[ 155], 40.00th=[ 161], 50.00th=[ 167], 60.00th=[ 171],
| 70.00th=[ 177], 80.00th=[ 185], 90.00th=[ 201], 95.00th=[ 270],
| 99.00th=[ 390], 99.50th=[ 398], 99.90th=[ 418], 99.95th=[ 422],
| 99.99th=[ 438]
In other setups, Robert Elliott reported seeing good performance
improvements:
https://lkml.org/lkml/2015/4/3/557
The more applications accessing the device, the worse it gets.
Add a new direct-io flags, DIO_SKIP_DIO_COUNT, which tells
do_blockdev_direct_IO() that it need not worry about incrementing
or decrementing the inode i_dio_count for this caller.
Cc: Elliott, Robert (Server Storage) <elliott@hp.com>
Now that the users of gic_arch_extn have been fixed, drop the
"feature" for good. This leads to the removal of some now useless
locking.
Cc: Jason Cooper <jason@lakedaemon.net>
