path: root/include
2011-07-20->permission() sanitizing: don't pass flags to ->inode_permission()Al Viro
pass that via mask instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: MAY_NOT_BLOCKAl Viro
Duplicate the flags argument into mask bitmap. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20lockless get_write_access/deny_write_accessAl Viro
new helpers: atomic_inc_unless_negative()/atomic_dec_unless_positive() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill file_permission() completelyAl Viro
convert the last remaining caller to inode_permission() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20consolidate BINPRM_FLAGS_ENFORCE_NONDUMP handlingAl Viro
new helper: would_dump(bprm, file). Checks if we are allowed to read the file and if we are not - sets ENFORCE_NODUMP. Exported, used in places that previously open-coded the same logics. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20new helper: iterate_supers_type()Al Viro
Call the given function for all superblocks of given type. Function gets a superblock (with s_umount locked shared) and (void *) argument supplied by caller of iterator. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: add a DCACHE_NEED_LOOKUP flag for d_flagsJosef Bacik
Btrfs (and I'd venture most other fs's) stores its indexes in nice disk order for readdir, but unfortunately in the case of anything that stats the files in order that readdir spits back (like oh say ls) that means we still have to do the normal lookup of the file, which means looking up our other index and then looking up the inode. What I want is a way to create dummy dentries when we find them in readdir so that when ls or anything else subsequently does a stat(), we already have the location information in the dentry and can go straight to the inode itself. The lookup stuff just assumes that if it finds a dentry it is done, it doesn't perform a lookup. So add a DCACHE_NEED_LOOKUP flag so that the lookup code knows it still needs to run i_op->lookup() on the parent to get the inode for the dentry. I have tested this with btrfs and I went from something that looks like this http://people.redhat.com/jwhiter/ls-noreada.png To this http://people.redhat.com/jwhiter/ls-good.png Thats a savings of 1300 seconds, or 22 minutes. That is a significant savings. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-18include/linux/sdla.h: remove the prototype of sdla()WANG Cong
`make headers_check` complains that linux-2.6/usr/include/linux/sdla.h:116: userspace cannot reference function or variable defined in the kernel this is due to that there is no such a kernel function, void sdla(void *cfg_info, char *dev, struct frad_conf *conf, int quiet); I don't know why we have it in a kernel header, so remove it. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: Bluetooth: Fix crash with incoming L2CAP connections Bluetooth: Fix regression in L2CAP connection procedure gianfar: rx parser r6040: only disable RX interrupt if napi_schedule_prep is successful net: remove NETIF_F_ALL_TX_OFFLOADS net: sctp: fix checksum marking for outgoing packets
2011-07-17Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: Fixes device power states array overflow ACPI, APEI, HEST, Detect duplicated hardware error source ID ACPI: Fix lockdep false positives in acpi_power_off()
2011-07-15drm/radeon/kms: add new NI pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-14net: remove NETIF_F_ALL_TX_OFFLOADSMichał Mirosław
There is no software fallback implemented for SCTP or FCoE checksumming, and so it should not be passed on by software devices like bridge or bonding. For VLAN devices, this is different. First, the driver for underlying device should be prepared to get offloaded packets even when the feature is disabled (especially if it advertises it in vlan_features). Second, devices under VLANs do not get replaced without tearing down the VLAN first. This fixes a mess I accidentally introduced while converting bonding to ndo_fix_features. NETIF_F_SOFT_FEATURES are removed from BOND_VLAN_FEATURES because they are unused as of commit 712ae51afd. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-14Merge branches 'd3cold', 'bugzilla-37412' and 'bugzilla-38152' into releaseLen Brown
2011-07-13ACPI: Fixes device power states array overflowLin Ming
Commit 28c2103 added new state ACPI_STATE_D3_COLD, so the device power states array must be expanded by one also. v2: Use ACPI_D_STATE_COUNT instead of number 5 for the array size. Reported-by: Dan Carpenter <error27@gmail.com> Suggested-by: Oldřich Jedlička <oldium.pro@seznam.cz> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: core: Bus width testing needs to handle suspend/resume
2011-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) slip: fix wrong SLIP6 ifdef-endif placing natsemi: fix another dma-debug report sctp: ABORT if receive, reassmbly, or reodering queue is not empty while closing socket net: Fix default in docs for tcp_orphan_retries. hso: fix a use after free condition net/natsemi: Fix module parameter permissions XFRM: Fix memory leak in xfrm_state_update sctp: Enforce retransmission limit during shutdown mac80211: fix TKIP replay vulnerability mac80211: fix ie memory allocation for scheduled scans ssb: fix init regression of hostmode PCI core rtlwifi: rtl8192cu: Add new USB ID for Netgear WNA1000M ath9k: Fix tx throughput drops for AR9003 chips with AES encryption carl9170: add NEC WL300NU-AG usbid cfg80211: fix deadlock with rfkill/sched_scan by adding new mutex ath5k: fix incorrect use of drvdata in PCI suspend/resume code ath5k: fix incorrect use of drvdata in sysfs code Bluetooth: Fix memory leak under page timeouts Bluetooth: Fix regression with incoming L2CAP connections Bluetooth: Fix hidp disconnect deadlocks and lost wakeup ...
2011-07-13mmc: core: Bus width testing needs to handle suspend/resumePhilip Rakity
On reading the ext_csd for the first time (in 1 bit mode), save the ext_csd information needed for bus width compare. On every pass we make re-reading the ext_csd, compare the data against the saved ext_csd data. This fixes a regression introduced in 3.0-rc1 by 08ee80cc397ac1a3 ("mmc: core: eMMC bus width may not work on all platforms"), which incorrectly assumed we would be re-reading the ext_csd at resume- time. Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-13ACPI: Fix lockdep false positives in acpi_power_off()Rafael J. Wysocki
All ACPICA locks are allocated by the same function, acpi_os_create_lock(), with the help of a local variable called "lock". Thus, when lockdep is enabled, it uses "lock" as the name of all those locks and regards them as instances of the same lock, which causes it to report possible locking problems with them when there aren't any. To work around this problem, define acpi_os_create_lock() as a macro and make it pass its argument to spin_lock_init(), so that lockdep uses it as the name of the new lock. Define this macron in a Linux-specific file, to minimize the resulting modifications of the OS-independent ACPICA parts. This change is based on an earlier patch from Andrea Righi and it addresses a regression from 2.6.39 tracked as https://bugzilla.kernel.org/show_bug.cgi?id=38152 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Tested-by: Andrea Righi <andrea@betterlinux.com> Reviewed-by: Florian Mickler <florian@mickler.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-12Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/mm: Fix memory_block_size_bytes() for non-pseries mm: Move definition of MIN_MEMORY_BLOCK_SIZE to a header
2011-07-12Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: pcmcia: pxa2xx/vpac270: free gpios on exist rather than requesting ARM: pxa/raumfeld: fix device name for codec ak4104 ARM: pxa/raumfeld: display initialisation fixes ARM: pxa/raumfeld: adapt to upcoming hardware change ARM: pxa: fix gpio_to_chip() clash with gpiolib namespace genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd) arm: mach-vt8500: add forgotten irq_data conversion ARM: pxa168: correct nand pmu setting ARM: pxa910: correct nand pmu setting ARM: pxa: fix PGSR register address calculation
2011-07-12mm: Move definition of MIN_MEMORY_BLOCK_SIZE to a headerBenjamin Herrenschmidt
The macro MIN_MEMORY_BLOCK_SIZE is currently defined twice in two .c files, and I need it in a third one to fix a powerpc bug, so let's first move it into a header Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2011-07-11Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] msp3400: fill in v4l2_tuner based on vt->type field [media] tuner-core.c: don't change type field in g_tuner or g_frequency [media] cx18/ivtv: fix g_tuner support [media] tuner-core: power up tuner when called with s_power(1) [media] v4l2-ioctl.c: check for valid tuner type in S_HW_FREQ_SEEK [media] tuner-core: simplify the standard fixup [media] tuner-core/v4l2-subdev: document that the type field has to be filled in [media] v4l2-subdev.h: remove unused s_mode tuner op [media] feature-removal-schedule: change in how radio device nodes are handled [media] bttv: fix s_tuner for radio [media] pvrusb2: fix g/s_tuner support [media] v4l2-ioctl.c: prefill tuner type for g_frequency and g/s_tuner [media] tuner-core: fix tuner_resume: use t->mode instead of t->type [media] tuner-core: fix s_std and s_tuner
2011-07-08w1: ds1wm: add a reset recovery parameterJean-François Dagenais
This fixes a regression in 3.0 reported by Paul Parsons regarding the removal of the msleep(1) in the ds1wm_reset() function: : The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying" : error messages on an HP iPAQ hx4700 PDA (XScale-PXA270): : : <snip> : Driver for 1-wire Dallas network protocol. : DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko : 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko : ds1wm ds1wm: pass: 1 bus error, retrying : ds1wm ds1wm: pass: 2 bus error, retrying : ds1wm ds1wm: pass: 3 bus error, retrying : ds1wm ds1wm: pass: 4 bus error, retrying : ds1wm ds1wm: pass: 5 bus error, retrying : ... : : The visible result is that the battery charging LED is erratic; sometimes : it works, mostly it doesn't. : : The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1, : 3.0-rc2, or 3.0-rc3. This sleep should not be required on normal circuitry provided the pull-ups on the bus are correctly adapted to the slaves. Unfortunately, this is not always the case. The sleep is restored but as a parameter to the probe function in the pdata. [akpm@linux-foundation.org: coding-style fixes] Reported-by: Paul Parsons <lost.distance@yahoo.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08sctp: ABORT if receive, reassmbly, or reodering queue is not empty while ↵Thomas Graf
closing socket Trigger user ABORT if application closes a socket which has data queued on the socket receive queue or chunks waiting on the reassembly or ordering queue as this would imply data being lost which defeats the point of a graceful shutdown. This behavior is already practiced in TCP. We do not check the input queue because that would mean to parse all chunks on it to look for unacknowledged data which seems too much of an effort. Control chunks or duplicated chunks may also be in the input queue and should not be stopping a graceful shutdown. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07sctp: Enforce retransmission limit during shutdownThomas Graf
When initiating a graceful shutdown while having data chunks on the retransmission queue with a peer which is in zero window mode the shutdown is never completed because the retransmission error count is reset periodically by the following two rules: - Do not timeout association while doing zero window probe. - Reset overall error count when a heartbeat request has been acknowledged. The graceful shutdown will wait for all outstanding TSN to be acknowledged before sending the SHUTDOWN request. This never happens due to the peer's zero window not acknowledging the continuously retransmitted data chunks. Although the error counter is incremented for each failed retransmission, the receiving of the SACK announcing the zero window clears the error count again immediately. Also heartbeat requests continue to be sent periodically. The peer acknowledges these requests causing the error counter to be reset as well. This patch changes behaviour to only reset the overall error counter for the above rules while not in shutdown. After reaching the maximum number of retransmission attempts, the T5 shutdown guard timer is scheduled to give the receiver some additional time to recover. The timer is stopped as soon as the receiver acknowledges any data. The issue can be easily reproduced by establishing a sctp association over the loopback device, constantly queueing data at the sender while not reading any at the receiver. Wait for the window to reach zero, then initiate a shutdown by killing both processes simultaneously. The association will never be freed and the chunks on the retransmission queue will be retransmitted indefinitely. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: drbd: we should write meta data updates with FLUSH FUA drbd: fix limit define, we support 1 PiByte now drbd: when receive times out on meta socket, also check last receive time on data socket drbd: account bitmap IO during resync as resync-(related-)-io drbd: don't cond_resched_lock with IRQs disabled drbd: add missing spinlock to bitmap receive drbd: Use the correct max_bio_size when creating resync requests cfq-iosched: make code consistent cfq-iosched: fix a rcu warning
2011-07-07FS-Cache: Add a helper to bulk uncache pages on an inodeDavid Howells
Add an FS-Cache helper to bulk uncache pages on an inode. This will only work for the circumstance where the pages in the cache correspond 1:1 with the pages attached to an inode's page cache. This is required for CIFS and NFS: When disabling inode cookie, we were returning the cookie and setting cifsi->fscache to NULL but failed to invalidate any previously mapped pages. This resulted in "Bad page state" errors and manifested in other kind of errors when running fsstress. Fix it by uncaching mapped pages when we disable the inode cookie. This patch should fix the following oops and "Bad page state" errors seen during fsstress testing. ------------[ cut here ]------------ kernel BUG at fs/cachefiles/namei.c:201! invalid opcode: 0000 [#1] SMP Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles] RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282 RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282 RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300 R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840 R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0 FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0) Stack: 0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00 ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380 ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56 Call Trace: cachefiles_lookup_object+0x78/0xd4 [cachefiles] fscache_lookup_object+0x131/0x16d [fscache] fscache_object_work_func+0x1bc/0x669 [fscache] process_one_work+0x186/0x298 worker_thread+0xda/0x15d kthread+0x84/0x8c kernel_thread_helper+0x4/0x10 RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles] ---[ end trace 1d481c9af1804caa ]--- I tested the uncaching by the following means: (1) Create a big file on my NFS server (104857600 bytes). (2) Read the file into the cache with md5sum on the NFS client. Look in /proc/fs/fscache/stats: Pages : mrk=25601 unc=0 (3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc again: Pages : mrk=25601 unc=25601 Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de> cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-07Merge branches 'core-urgent-for-linus', 'perf-urgent-for-linus' and ↵Linus Torvalds
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: Fix boot crash when kmemleak and debugobjects enabled * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: jump_label: Fix jump_label update for modules oprofile, x86: Fix race in nmi handler while starting counters * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Disable (revert) SCHED_LOAD_SCALE increase sched, cgroups: Fix MIN_SHARES on 64-bit boxen
2011-07-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) sctp: fix missing send up SCTP_SENDER_DRY_EVENT when subscribe it net: refine {udp|tcp|sctp}_mem limits vmxnet3: round down # of queues to power of two net: sh_eth: fix the parameter for the ETHER of SH7757 net: sh_eth: fix cannot work half-duplex mode net: vlan: enable soft features regardless of underlying device vmxnet3: fix starving rx ring whenoc_skb kb fails bridge: Always flood broadcast packets greth: greth_set_mac_add would corrupt the MAC address. net: bind() fix error return on wrong address family natsemi: silence dma-debug warnings net: 8139too: Initial necessary vlan_features to support vlan Fix call trace when interrupts are disabled while sleeping function kzalloc is called qlge:Version change to v1.00.00.29 qlge: Fix printk priority so chip fatal errors are always reported. qlge:Fix crash caused by mailbox execution on wedged chip. xfrm4: Don't call icmp_send on local error ipv4: Don't use ufo handling on later transformed packets xfrm: Remove family arg from xfrm_bundle_ok ipv6: Don't put artificial limit on routing table size. ...
2011-07-07[media] tuner-core/v4l2-subdev: document that the type field has to be filled inHans Verkuil
The tuner ops g_frequency, g_tuner and s_tuner require that the tuner type field is filled in. Document this. The tuner-core doc is based on a patch from Mauro Carvalho Chehab <mchehab@redhat.com>. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-07[media] v4l2-subdev.h: remove unused s_mode tuner opHans Verkuil
s_mode is no longer used, so remove it. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-07genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd)Simon Guinot
This fixes a regression introduced by e59347a "arm: orion: Use generic irq chip". Depending on the device, interrupts acknowledgement is done by setting or by clearing a dedicated register. Replace irq_gc_ack() with some {set,clr}_bit variants allows to handle both cases. Note that this patch affects the following SoCs: Davinci, Samsung and Orion. Except for this last, the change is minor: irq_gc_ack() is just renamed into irq_gc_ack_set_bit(). For the Orion SoCs, the edge GPIO interrupts support is currently broken. irq_gc_ack() try to acknowledge a such interrupt by setting the corresponding cause register bit. The Orion GPIO device expect the opposite. To fix this issue, the irq_gc_ack_clr_bit() variant is used. Tested on Network Space v2. Reported-by: Joey Oravec <joravec@drewtech.com> Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-07-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits) [media] rc: call input_sync after scancode reports [media] imon: allow either proto on unknown 0xffdc [media] imon: auto-config ffdc 7e device [media] saa7134: fix raw IR timeout value [media] rc: fix ghost keypresses with certain hw [media] [staging] lirc_serial: allocate irq at init time [media] lirc_zilog: fix spinning rx thread [media] keymaps: fix table for pinnacle pctv hd devices [media] ite-cir: 8709 needs to use pnp resource 2 [media] V4L: mx1-camera: fix uninitialized variable [media] omap_vout: Added check in reqbuf & mmap for buf_size allocation [media] OMAP_VOUT: Change hardcoded device node number to -1 [media] OMAP_VOUTLIB: Fix wrong resizer calculation [media] uvcvideo: Disable the queue when failing to start [media] uvcvideo: Remove buffers from the queues when freeing [media] uvcvideo: Ignore entities for terminals with no supported format [media] v4l: Don't access media entity after is has been destroyed [media] media: omap3isp: fix a potential NULL deref [media] media: vb2: fix allocation failure check [media] media: vb2: reset queued_count value during queue reinitialization ... Fix up trivial conflict in MAINTAINERS as per Mauro
2011-07-05sched: Disable (revert) SCHED_LOAD_SCALE increasePeter Zijlstra
Alex reported that commit c8b281161df ("sched: Increase SCHED_LOAD_SCALE resolution") caused a power usage regression under light load as it increases the number of load-balance operations and keeps idle cpus from staying idle. Time has run out to find the root cause for this release so disable the feature for v3.0 until we can figure out what causes the problem. Reported-by: "Alex, Shi" <alex.shi@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nikhil Rao <ncrao@google.com> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-m4onxn0sxnyn5iz9o88eskc3@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-04Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x: vesafb: fix memory leak fbdev: amba: Link fb device to its parent fsl-diu-fb: remove check for pixel clock ranges udlfb: Correct sub-optimal resolution selection. hecubafb: add module_put on error path in hecubafb_probe() sm501fb: fix section mismatch warning gx1fb: Fix section mismatch warnings fbdev: sh_mobile_meram: Correct pointer check for YCbCr chroma plane
2011-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sb16 - Fix build errors on MIPS and others with 13bit ioctl size ALSA: hdspm - Fix compile warnings with PPC ALSA: cs5535 - Fix invalid big-endian conversions ALSA: HDMI - fix ELD monitor name length ALSA: atmel - update author email for ABDAC, AC97C and AT73C213 ALSA: HDA: Add model=auto quirk for Acer Aspire 3830TG ALSA: HDA: Add a new Conexant codec ID (506c)
2011-07-01ipv6: Don't put artificial limit on routing table size.David S. Miller
IPV6, unlike IPV4, doesn't have a routing cache. Routing table entries, as well as clones made in response to route lookup requests, all live in the same table. And all of these things are together collected in the destination cache table for ipv6. This means that routing table entries count against the garbage collection limits, even though such entries cannot ever be reclaimed and are added explicitly by the administrator (rather than being created in response to lookups). Therefore it makes no sense to count ipv6 routing table entries against the GC limits. Add a DST_NOCOUNT destination cache entry flag, and skip the counting if it is set. Use this flag bit in ipv6 when adding routing table entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01Merge branch 'for-davem' of ↵David S. Miller
2011-06-30Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-30ALSA: sb16 - Fix build errors on MIPS and others with 13bit ioctl sizeTakashi Iwai
One of ioctl definition in sound/sb16_csp.h contains the data size over 8kB, and this causes build errors on architectures like MIPS, which define _IOC_SIZEBITS=13. For avoiding this build errors but keeping the compatibility, manually expand with _IOC() instead of using _IOW() for the problematic ioctl. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-30Merge branch 'for-3.0-important' of git://git.drbd.org/linux-2.6-drbd into ↵Jens Axboe
for-linus
2011-06-30drbd: fix limit define, we support 1 PiByte nowLars Ellenberg
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-28Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Connector: Correctly set the error code in case of success when dispatching receive callbacks Connector: Set the CN_NETLINK_USERS correctly pti: PTI semantics fix in pti_tty_cleanup. pti: ENXIO error case memory leak PTI fix. pti: double-free security PTI fix drivers:misc: ti-st: fix skipping of change remote baud drivers/base/platform.c: don't mark platform_device_register_resndata() as __init_or_module st_kim: Handle case of no device found for ID 0 firmware: fix GOOGLE_SMI kconfig dependency warning
2011-06-28Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: serial: bcm63xx_uart: fix irq storm after rx fifo overrun. amba pl011: platform data for reg lockup and glitch v2 amba pl011: workaround for uart registers lockup tty: n_gsm: improper skb_pull() use was leaking framed data tty: n_gsm: Fixed logic to decode break signal from modem status TTY: ntty, add one more sanity check TTY: ldisc, do not close until there are readers 8250: Fix capabilities when changing the port type 8250_pci: Fix missing const from merges ARM: SAMSUNG: serial: Fix on handling of one clock source for UART serial: ioremap warning fix for jsm driver. 8250_pci: add -ENODEV code for Intel EG20T PCH
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27include/linux/compat.h: declare compat_sys_sendmmsg()Chris Metcalf
This is required for tilegx to be able to use the compat unistd.h header where compat_sys_sendmmsg() is now mentioned. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
