path: root/include
2008-10-17Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: remove __generic_unplug_device() from exports block: move q->unplug_work initialization blktrace: pass zfcp driver data blktrace: add support for driver data block: fix current kernel-doc warnings block: only call ->request_fn when the queue is not stopped block: simplify string handling in elv_iosched_store() block: fix kernel-doc for blk_alloc_devt() block: fix nr_phys_segments miscalculation bug block: add partition attribute for partition number block: add BIG FAT WARNING to CONFIG_DEBUG_BLOCK_EXT_DEVT softirq: Add support for triggering softirq work on softirqs.
2008-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (39 commits) [SCSI] sd: fix compile failure with CONFIG_BLK_DEV_INTEGRITY=n libiscsi: fix locking in iscsi_eh_device_reset libiscsi: check reason why we are stopping iscsi session to determine error value [SCSI] iscsi_tcp: return a descriptive error value during connection errors [SCSI] libiscsi: rename host reset to target reset [SCSI] iscsi class: fix endpoint id handling [SCSI] libiscsi: Support drivers initiating session removal [SCSI] libiscsi: fix data corruption when target has to resend data-in packets [SCSI] sd: Switch kernel printing level for DIF messages [SCSI] sd: Correctly handle all combinations of DIF and DIX [SCSI] sd: Always print actual protection_type [SCSI] sd: Issue correct protection operation [SCSI] scsi_error: fix target reset handling [SCSI] lpfc 8.2.8 v2 : Add statistical reporting control and additional fc vendor events [SCSI] lpfc 8.2.8 v2 : Add sysfs control of target queue depth handling [SCSI] lpfc 8.2.8 v2 : Revert target busy in favor of transport disrupted [SCSI] scsi_dh_alua: remove REQ_NOMERGE [SCSI] lpfc 8.2.8 : update driver version to 8.2.8 [SCSI] lpfc 8.2.8 : Add MSI-X support [SCSI] lpfc 8.2.8 : Update driver to use new Host byte error code DID_TRANSPORT_DISRUPTED ...
2008-10-17block: remove __generic_unplug_device() from exportsJens Axboe
The only out-of-core user is IDE, and that should be using blk_start_queueing() instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17blktrace: add support for driver dataStefan Raspl
This patch adds the new api call blk_add_driver_data() to blktrace. It allows to trace device driver-specific binary data. Signed-off-by: Stefan Raspl <raspl@linux.vnet.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: fix nr_phys_segments miscalculation bugFUJITA Tomonori
This fixes the bug reported by Nikanth Karthikesan <knikanth@suse.de>: http://lkml.org/lkml/2008/10/2/203 The root cause of the bug is that blk_phys_contig_segment miscalculates q->max_segment_size. blk_phys_contig_segment checks: req->biotail->bi_size + next_req->bio->bi_size > q->max_segment_size But blk_recalc_rq_segments might expect that req->biotail and the previous bio in the req are supposed be merged into one segment. blk_recalc_rq_segments might also expect that next_req->bio and the next bio in the next_req are supposed be merged into one segment. In such case, we merge two requests that can't be merged here. Later, blk_rq_map_sg gives more segments than it should. We need to keep track of segment size in blk_recalc_rq_segments and use it to see if two requests can be merged. This patch implements it in the similar way that we used to do for hw merging (virtual merging). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17softirq: Add support for triggering softirq work on softirqs.David S. Miller
This is basically a genericization of Jens Axboe's block layer remote softirq changes. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-16Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (53 commits) NFS: Fix a resolution problem with nfs_inode->cache_change_attribute NFS: Fix the resolution problem with nfs_inode_attrs_need_update() NFS: Changes to inode->i_nlinks must set the NFS_INO_INVALID_ATTR flag RPC/RDMA: ensure connection attempt is complete before signalling. RPC/RDMA: correct the reconnect timer backoff RPC/RDMA: optionally emit useful transport info upon connect/disconnect. RPC/RDMA: reformat a debug printk to keep lines together. RPC/RDMA: harden connection logic against missing/late rdma_cm upcalls. RPC/RDMA: fix connect/reconnect resource leak. RPC/RDMA: return a consistent error, when connect fails. RPC/RDMA: adhere to protocol for unpadded client trailing write chunks. RPC/RDMA: avoid an oops due to disconnect racing with async upcalls. RPC/RDMA: maintain the RPC task bytes-sent statistic. RPC/RDMA: suppress retransmit on RPC/RDMA clients. RPC/RDMA: fix connection IRD/ORD setting RPC/RDMA: support FRMR client memory registration. RPC/RDMA: check selected memory registration mode at runtime. RPC/RDMA: add data types and new FRMR memory registration enum. RPC/RDMA: refactor the inline memory registration code. NFS: fix nfs_parse_ip_address() corner case ...
2008-10-16Merge branch 'kvm-updates/2.6.28' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (134 commits) KVM: ia64: Add intel iommu support for guests. KVM: ia64: add directed mmio range support for kvm guests KVM: ia64: Make pmt table be able to hold physical mmio entries. KVM: Move irqchip_in_kernel() from ioapic.h to irq.h KVM: Separate irq ack notification out of arch/x86/kvm/irq.c KVM: Change is_mmio_pfn to kvm_is_mmio_pfn, and make it common for all archs KVM: Move device assignment logic to common code KVM: Device Assignment: Move vtd.c from arch/x86/kvm/ to virt/kvm/ KVM: VMX: enable invlpg exiting if EPT is disabled KVM: x86: Silence various LAPIC-related host kernel messages KVM: Device Assignment: Map mmio pages into VT-d page table KVM: PIC: enhance IPI avoidance KVM: MMU: add "oos_shadow" parameter to disable oos KVM: MMU: speed up mmu_unsync_walk KVM: MMU: out of sync shadow core KVM: MMU: mmu_convert_notrap helper KVM: MMU: awareness of new kvm_mmu_zap_page behaviour KVM: MMU: mmu_parent_walk KVM: x86: trap invlpg KVM: MMU: sync roots on mmu reload ...
2008-10-16Merge branch 'core-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: do_generic_file_read: s/EINTR/EIO/ if lock_page_killable() fails softirq, warning fix: correct a format to avoid a warning softirqs, debug: preemption check x86, pci-hotplug, calgary / rio: fix EBDA ioremap() IO resources, x86: ioremap sanity check to catch mapping requests exceeding, fix IO resources, x86: ioremap sanity check to catch mapping requests exceeding the BAR sizes softlockup: Documentation/sysctl/kernel.txt: fix softlockup_thresh description dmi scan: warn about too early calls to dmi_check_system() generic: redefine resource_size_t as phys_addr_t generic: make PFN_PHYS explicitly return phys_addr_t generic: add phys_addr_t for holding physical addresses softirq: allocate less vectors IO resources: fix/remove printk printk: robustify printk, update comment printk: robustify printk, fix #2 printk: robustify printk, fix printk: robustify printk Fixed up conflicts in: arch/powerpc/include/asm/types.h arch/powerpc/platforms/Kconfig.cputype manually.
2008-10-16Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix compat-vdso x86/mm: unify init task OOM handling x86/mm: do not trigger a kernel warning if user-space disables interrupts and generates a page fault
2008-10-16FRV: Switch unaligned access to the packed-struct implementationHarvey Harrison
Switch unaligned access to the packed-struct implementation for BE accesses as this reduces the size of the kernel a little. LE still uses the byte shift. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: Add more documentation to firewire-cdev.h firewire: fix ioctl() return code firewire: fix setting tag and sy in iso transmission firewire: fw-sbp2: fix another small generation access bug firewire: fw-sbp2: enforce s/g segment size limit firewire: fw_send_request_sync() ieee1394: survive a few seconds connection loss ieee1394: nodemgr clean up class iterators ieee1394: dv1394, video1394: remove unnecessary expressions ieee1394: raw1394: make write() thread-safe ieee1394: raw1394: narrow down the state_mutex protected region ieee1394: raw1394: replace BKL by local mutex, make ioctl() and mmap() thread-safe ieee1394: sbp2: enforce s/g segment size limit ieee1394: sbp2: check for DMA mapping failures ieee1394: sbp2: stricter dma_sync ieee1394: Use DIV_ROUND_UP
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits) UIO: Fix mapping of logical and virtual memory UIO: add automata sercos3 pci card support UIO: Change driver name of uio_pdrv UIO: Add alignment warnings for uio-mem Driver core: add bus_sort_breadthfirst() function NET: convert the phy_device file to use bus_find_device_by_name kobject: Cleanup kobject_rename and !CONFIG_SYSFS kobject: Fix kobject_rename and !CONFIG_SYSFS sysfs: Make dir and name args to sysfs_notify() const platform: add new device registration helper sysfs: use ilookup5() instead of ilookup5_nowait() PNP: create device attributes via default device attributes Driver core: make bus_find_device_by_name() more robust usb: turn dev_warn+WARN_ON combos into dev_WARN debug: use dev_WARN() rather than WARN_ON() in device_pm_add() debug: Introduce a dev_WARN() function sysfs: fix deadlock device model: Do a quickcheck for driver binding before doing an expensive check Driver core: Fix cleanup in device_create_vargs(). Driver core: Clarify device cleanup. ...
2008-10-16Merge branch 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITY
2008-10-16Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: fix input truncation in safe_delay_store() md: check for memory allocation failure in faulty personality md: build failure due to missing delay.h md: Relax minimum size restrictions on chunk_size. md: remove space after function name in declaration and call. md: Remove unnecessary #includes, #defines, and function declarations. md: Convert remaining 1k representations in linear.c to sectors. md: linear.c: Make two local variables sector-based. md: linear: Represent dev_info->size and dev_info->offset in sectors. md: linear.c: Remove broken debug code. md: linear.c: Remove pointless initialization of curr_offset. md: linear.c: Fix typo in comment. md: Don't try to set an array to 'read-auto' if it is already in that state. md: Allow metadata_version to be updated for externally managed metadata. md: Fix rdev_size_store with size == 0
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: wm97xx - update email address for Liam Girdwood Input: i8042 - add Thinkpad R31 to nomux list Input: move map_to_7segment.h to include/linux Input: ads7846 - fix cache line sharing issue Input: cm109 - add missing newlines to messages Input: document i8042.debug in kernel-parameters.txt Input: keyboard - fix potential out of bound access to key_map Input: psmouse - add OLPC touchpad driver Input: psmouse - tweak PSMOUSE_DEFINE_ATTR to support raw set callbacks Input: psmouse - add psmouse_queue_work() for ps/2 extension to make use of Input: psmouse - export psmouse_set_state for ps/2 extensions to use Input: ads7846 - introduce .gpio_pendown to get pendown state Input: ALPS - add signature for DualPoint found in Dell Latitude E6500 Input: serio_raw - allow attaching to translated (SERIO_I8042XL) ports Input: cm109 - don't use obsolete logging macros Input: atkbd - expand Latitude's force release quirk to other Dells Input: bf54x-keys - add power management support Input: atmel_tsadcc - improve accuracy Input: convert drivers to use strict_strtoul() Input: appletouch - handle geyser 3/4 status bits ...
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) decnet: Fix compiler warning in dn_dev.c IPV6: Fix default gateway criteria wrt. HIGH/LOW preference radv option net/802/fc.c: Fix compilation warnings netns: correct mib stats in ip6_route_me_harder() netns: fix net_generic array leak rt2x00: fix regression introduced by "mac80211: free up 2 bytes in skb->cb" rtl8187: Add USB ID for Belkin F5D7050 with RTL8187B chip p54usb: Device ID updates mac80211: fixme for kernel-doc ath9k/mac80211: disallow fragmentation in ath9k, report to userspace libertas : Remove unused variable warning for "old_channel" from cmd.c mac80211: Fix scan RX processing oops orinoco: fix unsafe locking in spectrum_cs_suspend orinoco: fix unsafe locking in orinoco_cs_resume cfg80211: fix debugfs error handling mac80211: fix debugfs netdev rename iwlwifi: fix ct kill configuration for 5350 mac80211: fix HT information element parsing p54: Fix compilation problem on PPC mac80211: fix debugfs lockup ...
2008-10-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (51 commits) [ARM] 5308/1: Fix Viper ISA IRQ handling [ARM] 5307/1: pxa: fix CM-X2XX PCMCIA build error [ARM] 5306/1: pxa: fix build error on CM-X270 [ARM] 5302/1: ARM: OMAP: Revert omap3 WDT changes to avoid merge conflict [ARM] 5305/1: ARM: OMAP: Fix compile of McBSP by removing unnecessary check [ARM] 5301/1: ARM: OMAP: Add missing irq defines ARM: OMAP3: Add default kernel config for OMAP LDP ARM: OMAP3: Add basic board support for OMAP LDP ARM: OMAP3: Defconfig for the Gumstix Overo board (rev 3) ARM: OMAP3: Add support for the Gumstix Overo board (rev 3) ARM: OMAP3: Add Beagle defconfig ARM: OMAP3: Add minimal Beagle board support ARM: OMAP3: Add minimal omap3430 support ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ code ARM: OMAP: Fixes to omap_mcbsp_request function ARM: OMAP: Add support for OMAP2430 in McBSP ARM: OMAP: Add support for McBSP devices 3 - 5 on 34xx ARM: OMAP: Allocate McBSP devices dynamically Fix sections for omap-mcbsp platform driver [ARM] S3C24XX: Additional include moves ...
2008-10-16resource: add resource_type() and IORESOURCE_TYPE_BITSMagnus Damm
Add resource_type() and IORESOURCE_TYPE_BITS. They make it easier to add more resource types without having to rewrite tons of code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Configure out AIO supportThomas Petazzoni
This patchs adds the CONFIG_AIO option which allows to remove support for asynchronous I/O operations, that are not necessarly used by applications, particularly on embedded devices. As this is a size-reduction option, it depends on CONFIG_EMBEDDED. It allows to save ~7 kilobytes of kernel code/data: text data bss dec hex filename 1115067 119180 217088 1451335 162547 vmlinux 1108025 119048 217088 1444161 160941 vmlinux.new -7042 -132 0 -7174 -1C06 +/- This patch has been originally written by Matt Mackall <mpm@selenic.com>, and is part of the Linux Tiny project. [randy.dunlap@oracle.com: build fix] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16parport: remove CVS keywordsAdrian Bunk
Remove CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pid_ns: kill the now unused task_child_reaper()Oleg Nesterov
task_child_reaper() has no callers anymore, kill it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16quota: remove CVS keywordsAdrian Bunk
Remove CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16telephony: remove CVS keywordsAdrian Bunk
2008-10-16pnp: make the resource type an unsigned longRene Herman
PnP encodes the resource type directly as its struct resource->flags value which is an unsigned long. Make it so... Signed-off-by: Rene Herman <rene.herman@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16fbdev: add new TMIO framebuffer driverDmitry Baryshkov
Add driver for TMIO framebuffer cells as found e.g. in Toshiba TC6393XB chips. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Ian Molton <spyro@f2s.com> Acked-by: Samuel Ortiz <sameo@openedhand.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16matroxfb: support G200eV chipDarrick J. Wong
Support the Matrox G200eV chip, based on timings that I found in the X.org matrox driver. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16fbdev: allow more chip revisions in Epson s1d13... video driverKristoffer Ericson
The Epson s1d13xxx hardware is common in many handhelds, but our driver is currently locked to a single chip revision. This patch adds an array of known to work revisions (which can be extended). [akpm@linux-foundation.org: cleanups] Signed-off-by: Kristoffer Ericson <Kristoffer.Ericson@gmail.com> Acked-by: Thibaut Varène <varenet@parisc-linux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16radeonfb: accelerate imageblit and other improvementsBenjamin Herrenschmidt
Implement support for HW color expansion of 1bpp images, along with some improvements to the FIFO handling and other accel operations. The offset fixup code is now unnecessary as the fbcon core will call our set_par upon switch back from KD_GRAPHICS before anything else happens. I removed it as it would slow down accel operations. The fifo wait has been improved to avoid hitting the HW register as often, and the various accel ops are now performing better caching of register values. Overall, this improve accel performances. The imageblit acceleration does result in a small overall regression in performances on some machines (on the order of 5% on some x86), probably becaus the SW path provides a better bus utilisation, but I decided to ingnore that as the performances is still very good, and on the other hand, some machines such as some sparc64 get a 3 fold performance improvement. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16radeonfb: misc cleanup of engine and dst cache handlingBenjamin Herrenschmidt
Fix a couple of incomplete tests of the chip families in the engine init/reset code and proper initialization of the destination cache mode. The result should better match what the latest X radeon driver does. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16neofb: remove open_lock mutexKrzysztof Helt
Remove mutex from the fb_open/fb_release functions as these operations are mutexed at fb layer. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: request/free hooksDavid Brownell
Add a new internal mechanism to gpiolib to support low power operations by letting gpio_chip instances see when their GPIOs are in use. When no GPIOs are active, chips may be able to enter lower powered runtime states by disabling clocks and/or power domains. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Magnus Damm" <magnus.damm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: gpio_to_irq() hooksDavid Brownell
Add a new gpiolib mechanism: gpio_chip instances can provide mappings between their (input) GPIOs and any associated IRQs. This makes it easier for platforms to support IRQs that are provided by board-specific external chips instead of as part of their core (such as SOC-integrated GPIOs). Also update the irq_to_gpio() description, saying to avoid it because it's not always supported. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio_free might sleep, generic partUwe Kleine-König
According to the documentation gpio_free should only be called from task context only. To make this more explicit add a might sleep to all implementations. This is the generic part which changes gpiolib and the fallback implementation only. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: make gpiochip label constDmitry Baryshkov
Mark gpiochip label as a const char pointer. Fixes things like arch/arm/common/scoop.c: In function `scoop_probe': arch/arm/common/scoop.c:250: warning: assignment discards qualifiers from pointer target type Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: add miscellaneous device for ioctlsIan Kent
Add a miscellaneous device to the autofs4 module for routing ioctls. This provides the ability to obtain an ioctl file handle for an autofs mount point that is possibly covered by another mount. The actual problem with autofs is that it can't reconnect to existing mounts. Immediately one things of just adding the ability to remount autofs file systems would solve it, but alas, that can't work. This is because autofs direct mounts and the implementation of "on demand mount and expire" of nested mount trees have the file system mounted on top of the mount trigger dentry. To resolve this a miscellaneous device node for routing ioctl commands to these mount points has been implemented in the autofs4 kernel module and a library added to autofs. This provides the ability to open a file descriptor for these over mounted autofs mount points. Please refer to Documentation/filesystems/autofs4-mount-control.txt for a discussion of the problem, implementation alternatives considered and a description of the interface. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: cleanup autofs mount type usageIan Kent
Usage of the AUTOFS_TYPE_* defines is a little confusing and appears inconsistent. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16i2o: Fix 32/64bit DMA lockingAlan Cox
The I2O ioctls assume 32bits. In itself that is fine as they are old cards and nobody uses 64bit. However on LKML it was noted this assumption is also made for allocated memory and is unsafe on 64bit systems. Fixing this is a mess. It turns out there is tons of crap buried in a header file that does racy 32/64bit filtering on the masks. So we: - Verify all callers of the racy code can sleep (i2o_dma_[re]alloc) - Move the code into a new i2o/memory.c file - Remove the gfp_mask argument so nobody can try and misuse the function - Wrap a mutex around the problem area (a single mutex is easy to do and none of this is performance relevant) - Switch the remaining problem kmalloc holdout to use i2o_dma_alloc Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16orion_spi: handle 88F6183 erratumLennert Buytenhek
Add support to orion_spi for the 88F6183 ARM SoC by adding code to work around a 6183-specific erratum. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Allow recursion in binfmt_script and binfmt_miscKirill A. Shutemov
binfmt_script and binfmt_misc disallow recursion to avoid stack overflow using sh_bang and misc_bang. It causes problem in some cases: $ echo '#!/bin/ls' > /tmp/t0 $ echo '#!/tmp/t0' > /tmp/t1 $ echo '#!/tmp/t1' > /tmp/t2 $ chmod +x /tmp/t* $ /tmp/t2 zsh: exec format error: /tmp/t2 Similar problem with binfmt_misc. This patch introduces field 'recursion_depth' into struct linux_binprm to track recursion level in binfmt_misc and binfmt_script. If recursion level more then BINPRM_MAX_RECURSION it generates -ENOEXEC. [akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16alpha: introduce field 'taso' into struct linux_binprmKirill A. Shutemov
This change is Alpha-specific. It adds field 'taso' into struct linux_binprm to remember if the application is TASO. Previously, field sh_bang was used for this purpose. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16introduce generic iommu_num_pages functionJoerg Roedel
This patch introduces the generic iommu_num_pages function. It can be used by a given memory area. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This series of patches re-introduces the iommu_num_pages function so that it can be used by each architecture specific IOMMU implementations. The series also changes IOMMU implementations for X86, Alpha, PowerPC and UltraSparc. The other implementations are not yet changed because the modifications required are not obvious and I can't test them on real hardware. This patch: This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16compat: generic compat get/settimeofdayChristoph Hellwig
Nothing arch specific in get/settimeofday. The details of the timeval conversion varied a little from arch to arch, but all with the same results. Also add an extern declaration for sys_tz to linux/time.h because externs in .c files are fowned upon. I'll kill the externs in various other files in a sparate patch. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> [ sparc bits ] Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16compat: move cp_compat_stat to common codeChristoph Hellwig
struct stat / compat_stat is the same on all architectures, so cp_compat_stat should be, too. Turns out it is, except that various architectures have slightly and some high2lowuid/high2lowgid or the direct assignment instead of the SET_UID/SET_GID that expands to the correct one anyway. This patch replaces the arch-specific cp_compat_stat implementations with a common one based on the x86-64 one. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> [ sparc bits ] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [ parisc bits ] Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16include/linux/clk.h: fix commentAlex Raimondi
clk_get and clk_put may not be used from within interrupt context. Change comment to this function. Signed-off-by: Alex Raimondi <raimondi@miromico.ch> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16profiling: dynamically enable readprofile at runtimeDave Hansen
Way too often, I have a machine that exhibits some kind of crappy behavior. The CPU looks wedged in the kernel or it is spending way too much system time and I wonder what is responsible. I try to run readprofile. But, of course, Ubuntu doesn't enable it by default. Dang! The reason we boot-time enable it is that it takes a big bufffer that we generally can only bootmem alloc. But, does it hurt to at least try and runtime-alloc it? To use: echo 2 > /sys/kernel/profile Then run readprofile like normal. This should fix the compile issue with allmodconfig. I've compile-tested on a bunch more configs now including a few more architectures. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Make the taint flags reliableAndi Kleen
It's somewhat unlikely that it happens, but right now a race window between interrupts or machine checks or oopses could corrupt the tainted bitmap because it is modified in a non atomic fashion. Convert the taint variable to an unsigned long and use only atomic bit operations on it. Unfortunately this means the intvec sysctl functions cannot be used on it anymore. It turned out the taint sysctl handler could actually be simplified a bit (since it only increases capabilities) so this patch actually removes code. [akpm@linux-foundation.org: remove unneeded include] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
