[ Upstream commit 4c3024debf62de4c6ac6d3cb4c0063be21d4f652 ]
BPF can adjust gso only for tcp bytestreams. Fail on other gso types.
But only on gso packets. It does not touch this field if !gso_size.
Fixes: b90efd225874 ("bpf: only adjust gso_size on bytestream protocols")
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit 2b6e492467c78183bb629bb0a100ea3509b615a5 upstream.
With string type property entries we need to use
sizeof(const char *) instead of the number of characters as
the length of the entry.
If the string was shorter then sizeof(const char *),
attempts to read it would have failed with -EOVERFLOW. The
problem has been hidden because all build-in string
properties have had a string longer then 8 characters until
now.
Fixes: a85f42047533 ("device property: helper macros for property entry creation")
Cc: 4.5+ <stable@vger.kernel.org> # 4.5+
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
commit a0ce2f0aa6ad97c3d4927bf2ca54bcebdf062d55 upstream.
Before this patch, it was possible for two pipes to affect each other after
data had been transferred between them with tee():
$ cat tee_test.c
int main(void) {
int pipe_a[2];
if (pipe(pipe_a)) err(1, "pipe");
int pipe_b[2];
if (pipe(pipe_b)) err(1, "pipe");
if (write(pipe_a[1], "abcd", 4) != 4) err(1, "write");
if (tee(pipe_a[0], pipe_b[1], 2, 0) != 2) err(1, "tee");
if (write(pipe_b[1], "xx", 2) != 2) err(1, "write");
char buf[5];
if (read(pipe_a[0], buf, 4) != 4) err(1, "read");
buf[4] = 0;
printf("got back: '%s'\n", buf);
$ gcc -o tee_test tee_test.c
$ ./tee_test
got back: 'abxx'
As suggested by Al Viro, fix it by creating a separate type for
non-mergeable pipe buffers, then changing the types of buffers in
splice_pipe_to_pipe() and link_pipe().
Cc: <stable@vger.kernel.org>
Fixes: 7c77f0b3f920 ("splice: implement pipe to pipe splicing")
Fixes: 70524490ee2e ("[PATCH] splice: add support for sys_tee()")
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 6321aa197547da397753757bd84c6ce64b3e3d89 ]
clang warns about overflowing the data[] member in the struct pnpipehdr:
net/phonet/pep.c:295:8: warning: array index 4 is past the end of the array (which contains 1 element) [-Warray-bounds]
if (hdr->data[4] == PEP_IND_READY)
include/net/phonet/pep.h:66:3: note: array 'data' declared here
u8 data[1];
Using a flexible array member at the end of the struct avoids the
warning, but since we cannot have a flexible array member inside
of the union, each index now has to be moved back by one, which
makes it a little uglier.
Acked-by: Rémi Denis-Courmont <remi@remlab.net>
[ Upstream commit 822ad64d7e46a8e2c8b8a796738d7b657cbb146d ]
In the request_key() upcall mechanism there's a dependency loop by which if
a key type driver overrides the ->request_key hook and the userspace side
manages to lose the authorisation key, the auth key and the internal
construction record (struct key_construction) can keep each other pinned.
Fix this by the following changes:
(1) Killing off the construction record and using the auth key instead.
(2) Including the operation name in the auth key payload and making the
payload available outside of security/keys/.
(3) The ->request_key hook is given the authkey instead of the cons
record and operation name.
Changes (2) and (3) allow the auth key to naturally be cleaned up if the
keyring it is in is destroyed or cleared or the auth key is unlinked.
Fixes: 7ee02a316600 ("keys: Fix dependency loop between construction record and auth key")
Signed-off-by: James Morris <james.morris@microsoft.com>
[ Upstream commit b90efd2258749e04e1b3f71ef0d716f2ac2337e0 ]
bpf_skb_change_proto and bpf_skb_adjust_room change skb header length.
For GSO packets they adjust gso_size to maintain the same MTU.
The gso size can only be safely adjusted on bytestream protocols.
Commit d02f51cbcf12 ("bpf: fix bpf_skb_adjust_net/bpf_skb_proto_xlat
to deal with gso sctp skbs") excluded SKB_GSO_SCTP.
Since then type SKB_GSO_UDP_L4 has been added, whose contents are one
gso_size unit per datagram. Also exclude these.
Move from a blacklist to a whitelist check to future proof against
additional such new GSO types, e.g., for fraglist based GRO.
Fixes: bec1f6f69736 ("udp: generate gso with UDP_SEGMENT")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit fc3bc475231e12e9c0142f60100cf84d077c79e1 ]
vgic_dist->lpi_list_lock must always be taken with interrupts disabled as
it is used in interrupt context.
For configurations such as PREEMPT_RT_FULL, this means that it should
be a raw_spinlock since RT spinlocks are interruptible.
Signed-off-by: Julien Thierry <julien.thierry@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@arm.com>
[ Upstream commit e02f5c1bb2283cfcee68f2f0feddcc06150f13aa ]
The DRM driver stack is designed to work with cache coherent devices
only, but permits an optimization to be enabled in some cases, where
for some buffers, both the CPU and the GPU use uncached mappings,
removing the need for DMA snooping and allocation in the CPU caches.
The use of uncached GPU mappings relies on the correct implementation
of the PCIe NoSnoop TLP attribute by the platform, otherwise the GPU
will use cached mappings nonetheless. On x86 platforms, this does not
seem to matter, as uncached CPU mappings will snoop the caches in any
case. However, on ARM and arm64, enabling this optimization on a
platform where NoSnoop is ignored results in loss of coherency, which
breaks correct operation of the device. Since we have no way of
detecting whether NoSnoop works or not, just disable this
optimization entirely for ARM and arm64.
Cc: Christian Koenig <christian.koenig@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: David Zhou <David1.Zhou@amd.com>
Cc: Huang Rui <ray.huang@amd.com>
Cc: Junwei Zhang <Jerry.Zhang@amd.com>
Cc: Michel Daenzer <michel.daenzer@amd.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Sean Paul <sean@poorly.run>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: amd-gfx list <amd-gfx@lists.freedesktop.org>
Cc: dri-devel <dri-devel@lists.freedesktop.org>
Reported-by: Carsten Haitzler <Carsten.Haitzler@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Link: https://patchwork.kernel.org/patch/10778815/
Signed-off-by: Christian König <christian.koenig@amd.com>
[ Upstream commit 56841070ccc87b463ac037d2d1f2beb8e5e35f0c ]
According to ARM IHI 0069C (ID070116), we should use GITS_TYPER's
bits [7:4] as ITT_entry_size instead of [8:4]. Although this is
pretty annoying, it only results in a potential over-allocation
of memory, and nothing bad happens.
Fixes: 3dfa576bfb45 ("irqchip/gic-v3-its: Add probing for VLPI properties")
Signed-off-by: Zenghui Yu <yuzenghui@huawei.com>
[maz: massaged subject and commit message]
[ Upstream commit 4ec5302fa906ec9d86597b236f62315bacdb9622 ]
If we don't have DT then stmmac_clk will not be available. Let's add a
new Platform Data field so that we can specify the refclk by this mean.
This way we can still use the coalesce command in PCI based setups.
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
Cc: Joao Pinto <jpinto@synopsys.com>
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
commit c4f5627f7eeecde1bb6b646d8c0907b96dc2b2a6 upstream.
With commit e16337622016 ("Bluetooth: Handle bt_accept_enqueue() socket
atomically") lock_sock[_nested]() is used to acquire the socket lock
before manipulating the socket. lock_sock[_nested]() may block, which
is problematic since bt_accept_enqueue() can be called in bottom half
context (e.g. from rfcomm_connect_ind()):
[<ffffff80080d81ec>] __might_sleep+0x4c/0x80
[<ffffff800876c7b0>] lock_sock_nested+0x24/0x58
[<ffffff8000d7c27c>] bt_accept_enqueue+0x48/0xd4 [bluetooth]
[<ffffff8000e67d8c>] rfcomm_connect_ind+0x190/0x218 [rfcomm]
Add a parameter to bt_accept_enqueue() to indicate whether the
function is called from BH context, and acquire the socket lock
with bh_lock_sock_nested() if that's the case.
Also adapt all callers of bt_accept_enqueue() to pass the new
parameter:
- l2cap_sock_new_connection_cb()
- uses lock_sock() to lock the parent socket => process context
- rfcomm_connect_ind()
- acquires the parent socket lock with bh_lock_sock() => BH
context
- __sco_chan_add()
- called from sco_chan_add(), which is called from sco_connect().
parent is NULL, hence bt_accept_enqueue() isn't called in this
code path and we can ignore it
- also called from sco_conn_ready(). uses bh_lock_sock() to acquire
the parent lock => BH context
Fixes: e16337622016 ("Bluetooth: Handle bt_accept_enqueue() socket atomically")
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: stable@vger.kernel.org
[ Upstream commit 3da1ed7ac398f34fff1694017a07054d69c5f5c5 ]
Extract IP options in cipso_v4_error and use __icmp_send.
Signed-off-by: Sergey Nazarov <s-nazarov@yandex.ru>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 9ef6b42ad6fd7929dd1b6092cb02014e382c6a91 ]
Add __icmp_send function having ip_options struct parameter
Reviewed-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 5e1a99eae84999a2536f50a0beaf5d5262337f40 ]
For ip rules, we need to use 'ipproto ipv6-icmp' to match ICMPv6 headers.
But for ip -6 route, currently we only support tcp, udp and icmp.
Add ICMPv6 support so we can match ipv6-icmp rules for route lookup.
v2: As David Ahern and Sabrina Dubroca suggested, Add an argument to
rtm_getroute_parse_ip_proto() to handle ICMP/ICMPv6 with different family.
Reported-by: Jianlin Shi <jishi@redhat.com>
Fixes: eacb9384a3fe ("ipv6: support sport, dport and ip_proto in RTM_GETROUTE")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 46b1c18f9deb326a7e18348e668e4c7ab7c7458b ]
In the series fc8b81a5981f ("Merge branch 'lockless-qdisc-series'")
John made the assumption that the data path had no need to read
the qdisc qlen (number of packets in the qdisc).
It is true when pfifo_fast is used as the root qdisc, or as direct MQ/MQPRIO
children.
But pfifo_fast can be used as leaf in class full qdiscs, and existing
logic needs to access the child qlen in an efficient way.
HTB breaks badly, since it uses cl->leaf.q->q.qlen in :
htb_activate() -> WARN_ON()
htb_dequeue_tree() to decide if a class can be htb_deactivated
when it has no more packets.
HFSC, DRR, CBQ, QFQ have similar issues, and some calls to
qdisc_tree_reduce_backlog() also read q.qlen directly.
Using qdisc_qlen_sum() (which iterates over all possible cpus)
in the data path is a non starter.
It seems we have to put back qlen in a central location,
at least for stable kernels.
For all qdisc but pfifo_fast, qlen is guarded by the qdisc lock,
so the existing q.qlen{++|--} are correct.
For 'lockless' qdisc (pfifo_fast so far), we need to use atomic_{inc|dec}()
because the spinlock might be not held (for example from
pfifo_fast_enqueue() and pfifo_fast_dequeue())
This patch adds atomic_qlen (in the same location than qlen)
and renames the following helpers, since we want to express
they can be used without qdisc lock, and that qlen is no longer percpu.
- qdisc_qstats_cpu_qlen_dec -> qdisc_qstats_atomic_qlen_dec()
- qdisc_qstats_cpu_qlen_inc -> qdisc_qstats_atomic_qlen_inc()
Later (net-next) we might revert this patch by tracking all these
qlen uses and replace them by a more efficient method (not having
to access a precise qlen, but an empty/non_empty status that might
be less expensive to maintain/track).
Another possibility is to have a legacy pfifo_fast version that would
be used when used a a child qdisc, since the parent qdisc needs
a spinlock anyway. But then, future lockless qdiscs would also
have the same problem.
Fixes: 7e66016f2c65 ("net: sched: helpers to sum qlen and qlen for per cpu logic")
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Jiri Pirko <jiri@resnulli.us>
commit 625c85a62cb7d3c79f6e16de3cfa972033658250 upstream.
The cpufreq_global_kobject is created using kobject_create_and_add()
helper, which assigns the kobj_type as dynamic_kobj_ktype and show/store
routines are set to kobj_attr_show() and kobj_attr_store().
These routines pass struct kobj_attribute as an argument to the
show/store callbacks. But all the cpufreq files created using the
cpufreq_global_kobject expect the argument to be of type struct
attribute. Things work fine currently as no one accesses the "attr"
argument. We may not see issues even if the argument is used, as struct
kobj_attribute has struct attribute as its first element and so they
will both get same address.
But this is logically incorrect and we should rather use struct
kobj_attribute instead of struct global_attr in the cpufreq core and
drivers and the show/store callbacks should take struct kobj_attribute
as argument instead.
This bug is caught using CFI CLANG builds in android kernel which
catches mismatch in function prototypes for such callbacks.
Reported-by: Donghee Han <dh.han@samsung.com>
Reported-by: Sangkyu Kim <skwith.kim@samsung.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
[ Upstream commit 3b707c3008cad04604c1f50e39f456621821c414 ]
__bpf_redirect() and act_mirred checks this boolean
to determine whether to prefix an ethernet header.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 7fc5854f8c6efae9e7624970ab49a1eac2faefb1 ]
sync_inodes_sb() can race against cgwb (cgroup writeback) membership
switches and fail to writeback some inodes. For example, if an inode
switches to another wb while sync_inodes_sb() is in progress, the new
wb might not be visible to bdi_split_work_to_wbs() at all or the inode
might jump from a wb which hasn't issued writebacks yet to one which
already has.
This patch adds backing_dev_info->wb_switch_rwsem to synchronize cgwb
switch path against sync_inodes_sb() so that sync_inodes_sb() is
guaranteed to see all the target wbs and inodes can't jump wbs to
escape syncing.
v2: Fixed misplaced rwsem init. Spotted by Jiufei.
Reported-by: Jiufei Xue <xuejiufei@gmail.com>
Link: http://lkml.kernel.org/r/dc694ae2-f07f-61e1-7097-7c8411cee12d@gmail.com
Acked-by: Jan Kara <jack@suse.cz>
[ Upstream commit 76f99ae5b54d48430d1f0c5512a84da0ff9761e0 ]
Linux spreads out the non managed interrupt across the possible target CPUs
to avoid vector space exhaustion.
Managed interrupts are treated differently, as for them the vectors are
reserved (with guarantee) when the interrupt descriptors are initialized.
When the interrupt is requested a real vector is assigned. The assignment
logic uses the first CPU in the affinity mask for assignment. If the
interrupt has more than one CPU in the affinity mask, which happens when a
multi queue device has less queues than CPUs, then doing the same search as
for non managed interrupts makes sense as it puts the interrupt on the
least interrupt plagued CPU. For single CPU affine vectors that's obviously
a NOOP.
Restructre the matrix allocation code so it does the 'best CPU' search, add
the sanity check for an empty affinity mask and adapt the call site in the
x86 vector management code.
[ tglx: Added the empty mask check to the core and improved change log ]
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180908175838.14450-2-dou_liyang@163.com
commit 68a958a915ca912b8ce71b9eea7445996f6e681e upstream.
The udlfb driver maintained an open count and cleaned up itself when the
count reached zero. But the console is also counted in the reference count
- so, if the user unplugged the device, the open count would not drop to
zero and the driver stayed loaded with console attached. If the user
re-plugged the adapter, it would create a device /dev/fb1, show green
screen and the access to the console would be lost.
The framebuffer subsystem has reference counting on its own - in order to
fix the unplug bug, we rely the framebuffer reference counting. When the
user unplugs the adapter, we call unregister_framebuffer unconditionally.
unregister_framebuffer will unbind the console, wait until all users stop
using the framebuffer and then call the fb_destroy method. The fb_destroy
cleans up the USB driver.
This patch makes the following changes:
* Drop dlfb->kref and rely on implicit framebuffer reference counting
instead.
* dlfb_usb_disconnect calls unregister_framebuffer, the rest of driver
cleanup is done in the function dlfb_ops_destroy. dlfb_ops_destroy will
be called by the framebuffer subsystem when no processes have the
framebuffer open or mapped.
* We don't use workqueue during initialization, but initialize directly
from dlfb_usb_probe. The workqueue could race with dlfb_usb_disconnect
and this racing would produce various kinds of memory corruption.
* We use usb_get_dev and usb_put_dev to make sure that the USB subsystem
doesn't free the device under us.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
cc: Dave Airlie <airlied@redhat.com>
Cc: Bernie Thompson <bernie@plugable.com>,
Cc: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 9e8db5913264d3967b93c765a6a9e464d9c473db upstream.
GSO packets with vnet_hdr must conform to a small set of gso_types.
The below commit uses flow dissection to drop packets that do not.
But it has false positives when the skb is not fully initialized.
Dissection needs skb->protocol and skb->network_header.
Infer skb->protocol from gso_type as the two must agree.
SKB_GSO_UDP can use both ipv4 and ipv6, so try both.
Exclude callers for which network header offset is not known.
Fixes: d5be7f632bad ("net: validate untrusted gso packets without csum offload")
commit d5be7f632bad0f489879eed0ff4b99bd7fe0b74c upstream.
Syzkaller again found a path to a kernel crash through bad gso input.
By building an excessively large packet to cause an skb field to wrap.
If VIRTIO_NET_HDR_F_NEEDS_CSUM was set this would have been dropped in
skb_partial_csum_set.
GSO packets that do not set checksum offload are suspicious and rare.
Most callers of virtio_net_hdr_to_skb already pass them to
skb_probe_transport_header.
Move that test forward, change it to detect parse failure and drop
packets on failure as those cleary are not one of the legitimate
VIRTIO_NET_HDR_GSO types.
Fixes: bfd5f4a3d605 ("packet: Add GSO/csum offload support.")
Fixes: f43798c27684 ("tun: Allow GSO using virtio_net_hdr")
Reported-by: syzbot <syzkaller@googlegroups.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit cc1780fc42c76c705dd07ea123f1143dc5057630 upstream.
Align the payload of "user" and "logon" keys so that users of the
keyrings service can access it as a struct that requires more than
2-byte alignment. fscrypt currently does this which results in the read
of fscrypt_key::size being misaligned as it needs 4-byte alignment.
Align to __alignof__(u64) rather than __alignof__(long) since in the
future it's conceivable that people would use structs beginning with
u64, which on some platforms would require more than 'long' alignment.
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Fixes: 2aa349f6e37c ("[PATCH] Keys: Export user-defined keyring operations")
Fixes: 88bd6ccdcdd6 ("ext4 crypto: add encryption key management facilities")
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit 1ec17dbd90f8b638f41ee650558609c1af63dfa0 ]
Field idiag_ext in struct inet_diag_req_v2 used as bitmap of requested
extensions has only 8 bits. Thus extensions starting from DCTCPINFO
cannot be requested directly. Some of them included into response
unconditionally or hook into some of lower 8 bits.
Extension INET_DIAG_CLASS_ID has not way to request from the beginning.
This patch bundle it with INET_DIAG_TCLASS (ipv6 tos), fixes space
reservation, and documents behavior for other extensions.
Also this patch adds fallback to reporting socket priority. This filed
is more widely used for traffic classification because ipv4 sockets
automatically maps TOS to priority and default qdisc pfifo_fast knows
about that. But priority could be changed via setsockopt SO_PRIORITY so
INET_DIAG_TOS isn't enough for predicting class.
Also cgroup2 obsoletes net_cls classid (it always zero), but we cannot
reuse this field for reporting cgroup2 id because it is 64-bit (ino+gen).
So, after this patch INET_DIAG_CLASS_ID will report socket priority
for most common setup when net_cls isn't set and/or cgroup2 in use.
Fixes: 0888e372c37f ("net: inet: diag: expose sockets cgroup classid")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[ Upstream commit 10f4e765879e514e1ce7f52ed26603047af196e2 ]
In the forward chain, the iif is changed from slave device to master vrf
device. Thus, flow offload does not find a match on the lower slave
device.
This patch uses the cached route, ie. dst->dev, to update the iif and
oif fields in the flow entry.
After this patch, the following example works fine:
# ip addr add dev eth0 1.1.1.1/24
# ip addr add dev eth1 10.0.0.1/24
# ip link add user1 type vrf table 1
# ip l set user1 up
# ip l set dev eth0 master user1
# ip l set dev eth1 master user1
# nft add table firewall
# nft add flowtable f fb1 { hook ingress priority 0 \; devices = { eth0, eth1 } \; }
# nft add chain f ftb-all {type filter hook forward priority 0 \; policy accept \; }
# nft add rule f ftb-all ct zone 1 ip protocol tcp flow offload @fb1
# nft add rule f ftb-all ct zone 1 ip protocol udp flow offload @fb1
Signed-off-by: wenxu <wenxu@ucloud.cn>
[ Upstream commit 3e2ffd655cc6a694608d997738989ff5572a8266 ]
Since commit 815f0ddb346c ("include/linux/compiler*.h: make compiler-*.h
mutually exclusive") clang no longer reuses the OPTIMIZER_HIDE_VAR macro
from compiler-gcc - instead it gets the version in
include/linux/compiler.h. Unfortunately that version doesn't actually
prevent compiler from optimizing out the variable.
Fix up by moving the macro out from compiler-gcc.h to compiler.h.
Compilers without incline asm support will keep working
since it's protected by an ifdef.
Also fix up comments to match reality since we are no longer overriding
any macros.
Build-tested with gcc and clang.
Fixes: 815f0ddb346c ("include/linux/compiler*.h: make compiler-*.h mutually exclusive")
Cc: Eli Friedman <efriedma@codeaurora.org>
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
[ Upstream commit 2d533a9287f2011632977e87ce2783f4c689c984 ]
In PBL chains with non power of 2 page count, the producer is not at the
beginning of the chain when index is 0 after a wrap. Therefore, after the
producer index wrap around, page index should be calculated more carefully.
Signed-off-by: Denis Bolotin <dbolotin@marvell.com>
Signed-off-by: Ariel Elior <aelior@marvell.com>
commit 63530aba7826a0f8e129874df9c4d264f9db3f9e upstream.
syzbot found that ax25 routes where not properly protected
against concurrent use [1].
In this particular report the bug happened while
copying ax25->digipeat.
Fix this problem by making sure we call ax25_get_route()
while ax25_route_lock is held, so that no modification
could happen while using the route.
The current two ax25_get_route() callers do not sleep,
so this change should be fine.
Once we do that, ax25_get_route() no longer needs to
grab a reference on the found route.
[1]
ax25_connect(): syz-executor0 uses autobind, please contact jreuter@yaina.de
BUG: KASAN: use-after-free in memcpy include/linux/string.h:352 [inline]
BUG: KASAN: use-after-free in kmemdup+0x42/0x60 mm/util.c:113
Read of size 66 at addr ffff888066641a80 by task syz-executor2/531
CPU: 1 PID: 531 Comm: syz-executor2 Not tainted 5.0.0-rc2+ #10
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1db/0x2d0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
check_memory_region_inline mm/kasan/generic.c:185 [inline]
check_memory_region+0x123/0x190 mm/kasan/generic.c:191
memcpy+0x24/0x50 mm/kasan/common.c:130
kmemdup include/linux/string.h:425 [inline]
ax25_rt_autobind+0x25d/0x750 net/ax25/ax25_route.c:424
ax25_connect.cold+0x30/0xa4 net/ax25/af_ax25.c:1224
__sys_connect+0x357/0x490 net/socket.c:1664
__do_sys_connect net/socket.c:1675 [inline]
__se_sys_connect net/socket.c:1672 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1672
do_syscall_64+0x1a3/0x800 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x458099
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f870ee22c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000458099
RDX: 0000000000000048 RSI: 0000000020000080 RDI: 0000000000000005
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
ax25_connect(): syz-executor4 uses autobind, please contact jreuter@yaina.de
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f870ee236d4
R13: 00000000004be48e R14: 00000000004ce9a8 R15: 00000000ffffffff
Allocated by task 526:
save_stack+0x45/0xd0 mm/kasan/common.c:73
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc mm/kasan/common.c:496 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:469
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:504
ax25_connect(): syz-executor5 uses autobind, please contact jreuter@yaina.de
kmem_cache_alloc_trace+0x151/0x760 mm/slab.c:3609
kmalloc include/linux/slab.h:545 [inline]
ax25_rt_add net/ax25/ax25_route.c:95 [inline]
ax25_rt_ioctl+0x3b9/0x1270 net/ax25/ax25_route.c:233
ax25_ioctl+0x322/0x10b0 net/ax25/af_ax25.c:1763
sock_do_ioctl+0xe2/0x400 net/socket.c:950
sock_ioctl+0x32f/0x6c0 net/socket.c:1074
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:509 [inline]
do_vfs_ioctl+0x107b/0x17d0 fs/ioctl.c:696
ksys_ioctl+0xab/0xd0 fs/ioctl.c:713
__do_sys_ioctl fs/ioctl.c:720 [inline]
__se_sys_ioctl fs/ioctl.c:718 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:718
Freed by task 550:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:458
kasan_slab_free+0xe/0x10 mm/kasan/common.c:466
__cache_free mm/slab.c:3487 [inline]
kfree+0xcf/0x230 mm/slab.c:3806
ax25_rt_add net/ax25/ax25_route.c:92 [inline]
ax25_rt_ioctl+0x304/0x1270 net/ax25/ax25_route.c:233
The buggy address belongs to the object at ffff888066641a80
which belongs to the cache kmalloc-96 of size 96
The buggy address is located 0 bytes inside of
96-byte region [ffff888066641a80, ffff888066641ae0)
The buggy address belongs to the page:
page:ffffea0001999040 count:1 mapcount:0 mapping:ffff88812c3f04c0 index:0x0
flags: 0x1fffc0000000200(slab)
raw: 01fffc0000000200 ffffea0001817948 ffffea0002341dc8 ffff88812c3f04c0
raw: 0000000000000000 ffff888066641000 0000000100000020 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff888066641980: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641a00: 00 00 00 00 00 00 00 00 02 fc fc fc fc fc fc fc
>ffff888066641a80: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641b00: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641b80: 00 00 00 00 00 00 00 00 00 00 00 00 fc fc fc fc
[ Upstream commit 8681ef1f3d295bd3600315325f3b3396d76d02f6 ]
Fixes: 3b89ea9c5902 ("net: Fix for_each_netdev_feature on Big endian")
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit c09551c6ff7fe16a79a42133bcecba5fc2fc3291 ]
According to the algorithm described in the comment block at the
beginning of ip_rt_send_redirect, the host should try to send
'ip_rt_redirect_number' ICMP redirect packets with an exponential
backoff and then stop sending them at all assuming that the destination
ignores redirects.
If the device has previously sent some ICMP error packets that are
rate-limited (e.g TTL expired) and continues to receive traffic,
the redirect packets will never be transmitted. This happens since
peer->rate_tokens will be typically greater than 'ip_rt_redirect_number'
and so it will never be reset even if the redirect silence timeout
(ip_rt_redirect_silence) has elapsed without receiving any packet
requiring redirects.
Fix it by using a dedicated counter for the number of ICMP redirect
packets that has been sent by the host
I have not been able to identify a given commit that introduced the
issue since ip_rt_send_redirect implements the same rate-limiting
algorithm from commit 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 3b89ea9c5902acccdbbdec307c85edd1bf52515e ]
The features attribute is of type u64 and stored in the native endianes on
the system. The for_each_set_bit() macro takes a pointer to a 32 bit array
and goes over the bits in this area. On little Endian systems this also
works with an u64 as the most significant bit is on the highest address,
but on big endian the words are swapped. When we expect bit 15 here we get
bit 47 (15 + 32).
This patch converts it more or less to its own for_each_set_bit()
implementation which works on 64 bit integers directly. This is then
completely in host endianness and should work like expected.
Fixes: fd867d51f ("net/core: generic support for disabling netdev features down stack")
Signed-off-by: Hauke Mehrtens <hauke.mehrtens@intel.com>
commit dcf6e2e38a1c7ccbc535de5e1d9b14998847499d upstream.
The kblockd workqueue is created with the WQ_MEM_RECLAIM flag set.
This generates a rescuer thread for that queue that will trigger when
the CPU is under heavy load and collect the uncompleted work.
In the case of mmc, this creates the possibility of a deadlock when
there are multiple partitions on the device as other blk-mq work is
also run on the same queue. For example:
- worker 0 claims the mmc host to work on partition 1
- worker 1 attempts to claim the host for partition 2 but has to wait
for worker 0 to finish
- worker 0 schedules complete_work to release the host
- rescuer thread is triggered after time-out and collects the dangling
work
- rescuer thread attempts to complete the work in order starting with
claim host
- the task to release host is now blocked by a task to claim it and
will never be called
The above results in multiple hung tasks that lead to failures to
mount partitions.
Handling complete_work on a separate workqueue avoids this by keeping
the work completion tasks separate from the other blk-mq work. This
allows the host to be released without getting blocked by other tasks
attempting to claim the host.
Signed-off-by: Zachary Hays <zhays@lexmark.com>
Fixes: 81196976ed94 ("mmc: block: Add blk-mq support")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 81ec3f3c4c4d78f2d3b6689c9816bfbdf7417dbb upstream.
Vince (and later on Ravi) reported crashes in the BTS code during
fuzzing with the following backtrace:
general protection fault: 0000 [#1] SMP PTI
RIP: 0010:perf_prepare_sample+0x8f/0x510
Call Trace:
<IRQ>
? intel_pmu_drain_bts_buffer+0x194/0x230
intel_pmu_drain_bts_buffer+0x160/0x230
? tick_nohz_irq_exit+0x31/0x40
? smp_call_function_single_interrupt+0x48/0xe0
? call_function_single_interrupt+0xf/0x20
? call_function_single_interrupt+0xa/0x20
? x86_schedule_events+0x1a0/0x2f0
? x86_pmu_commit_txn+0xb4/0x100
? find_busiest_group+0x47/0x5d0
? perf_event_set_state.part.42+0x12/0x50
? perf_mux_hrtimer_restart+0x40/0xb0
intel_pmu_disable_event+0xae/0x100
? intel_pmu_disable_event+0xae/0x100
x86_pmu_stop+0x7a/0xb0
x86_pmu_del+0x57/0x120
event_sched_out.isra.101+0x83/0x180
group_sched_out.part.103+0x57/0xe0
ctx_sched_out+0x188/0x240
ctx_resched+0xa8/0xd0
__perf_event_enable+0x193/0x1e0
event_function+0x8e/0xc0
remote_function+0x41/0x50
flush_smp_call_function_queue+0x68/0x100
generic_smp_call_function_single_interrupt+0x13/0x30
smp_call_function_single_interrupt+0x3e/0xe0
</IRQ>
The reason is that while event init code does several checks
for BTS events and prevents several unwanted config bits for
BTS event (like precise_ip), the PERF_EVENT_IOC_PERIOD allows
to create BTS event without those checks being done.
Following sequence will cause the crash:
If we create an 'almost' BTS event with precise_ip and callchains,
and it into a BTS event it will crash the perf_prepare_sample()
function because precise_ip events are expected to come
in with callchain data initialized, but that's not the
case for intel_pmu_drain_bts_buffer() caller.
Adding a check_period callback to be called before the period
is changed via PERF_EVENT_IOC_PERIOD. It will deny the change
if the event would become BTS. Plus adding also the limit_period
check as well.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20190204123532.GA4794@krava
This patch is only appropriate for stable kernels v4.16 - v4.19
Since commit 9b30889c548a ("SUNRPC: Ensure we always close the socket after
a connection shuts down"), and until commit c544577daddb ("SUNRPC: Clean up
transport write space handling"), it is possible for the NFS client to spin
in the following tight loop:
269.964083: rpc_task_run_action: task:43@0 flags=5a81 state=0005 status=0 action=call_bind [sunrpc]
269.964083: rpc_task_run_action: task:43@0 flags=5a81 state=0005 status=0 action=call_connect [sunrpc]
269.964083: rpc_task_run_action: task:43@0 flags=5a81 state=0005 status=0 action=call_transmit [sunrpc]
269.964085: xprt_transmit: peer=[10.0.1.82]:2049 xid=0x761d3f77 status=-32
269.964085: rpc_task_run_action: task:43@0 flags=5a81 state=0005 status=-32 action=call_transmit_status [sunrpc]
269.964085: rpc_task_run_action: task:43@0 flags=5a81 state=0005 status=-32 action=call_status [sunrpc]
269.964085: rpc_call_status: task:43@0 status=-32
The issue is that the path through call_transmit_status does not release
the XPRT_LOCK when the transmit result is -EPIPE, so the socket cannot be
properly shut down.
The below commit fixed things up in mainline by unconditionally calling
xprt_end_transmit() and releasing the XPRT_LOCK after every pass through
call_transmit. However, the entirety of this commit is not appropriate for
stable kernels because its original inclusion was part of a series that
modifies the sunrpc code to use a different queueing model. As a result,
there are machinations within this patch that are not needed for a stable
fix and will not make sense without a larger backport of the mainline
series.
In this patch, we take the slightly modified bit of the mainline patch
below, which is to release the XPRT_LOCK on transmission error should we
detect that the transport is waiting to close.
commit c544577daddb618c7dd5fa7fb98d6a41782f020e upstream
Author: Trond Myklebust <trond.myklebust@hammerspace.com>
Date: Mon Sep 3 23:39:27 2018 -0400
SUNRPC: Clean up transport write space handling
Treat socket write space handling in the same way we now treat transport
congestion: by denying the XPRT_LOCK until the transport signals that it
has free buffer space.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
The original discussion of the problem is here:
https://lore.kernel.org/linux-nfs/20181212135157.4489-1-dwysocha@redhat.com/T/#t
This passes my usual cthon and xfstests on NFS as applied on v4.19 mainline.
Reported-by: Dave Wysochanski <dwysocha@redhat.com>
Suggested-by: Trond Myklebust <trondmy@hammerspace.com>
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
commit b284909abad48b07d3071a9fc9b5692b3e64914b upstream.
With the following commit:
73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS")
... the hotplug code attempted to detect when SMT was disabled by BIOS,
in which case it reported SMT as permanently disabled. However, that
code broke a virt hotplug scenario, where the guest is booted with only
primary CPU threads, and a sibling is brought online later.
The problem is that there doesn't seem to be a way to reliably
distinguish between the HW "SMT disabled by BIOS" case and the virt
"sibling not yet brought online" case. So the above-mentioned commit
was a bit misguided, as it permanently disabled SMT for both cases,
preventing future virt sibling hotplugs.
Going back and reviewing the original problems which were attempted to
be solved by that commit, when SMT was disabled in BIOS:
1) /sys/devices/system/cpu/smt/control showed "on" instead of
"notsupported"; and
2) vmx_vm_init() was incorrectly showing the L1TF_MSG_SMT warning.
I'd propose that we instead consider #1 above to not actually be a
problem. Because, at least in the virt case, it's possible that SMT
wasn't disabled by BIOS and a sibling thread could be brought online
later. So it makes sense to just always default the smt control to "on"
to allow for that possibility (assuming cpuid indicates that the CPU
supports SMT).
The real problem is #2, which has a simple fix: change vmx_vm_init() to
query the actual current SMT state -- i.e., whether any siblings are
currently online -- instead of looking at the SMT "control" sysfs value.
So fix it by:
a) reverting the original "fix" and its followup fix:
bc2d8d262cba ("cpu/hotplug: Fix SMT supported evaluation")
and
b) changing vmx_vm_init() to query the actual current SMT state --
instead of the sysfs control value -- to determine whether the L1TF
warning is needed. This also requires the 'sched_smt_present'
variable to exported, instead of 'cpu_smt_control'.
Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS")
Reported-by: Igor Mammedov <imammedo@redhat.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Joe Mario <jmario@redhat.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: kvm@vger.kernel.org
Link: https://lkml.kernel.org/r/e3a85d585da28cc333ecbc1e78ee9216e6da9396.1548794349.git.jpoimboe@redhat.com
commit 13054abbaa4f1fd4e6f3b4b63439ec033b4c8035 upstream.
Ring buffer implementation in hid_debug_event() and hid_debug_events_read()
is strange allowing lost or corrupted data. After commit 717adfdaf147
("HID: debug: check length before copy_to_user()") it is possible to enter
an infinite loop in hid_debug_events_read() by providing 0 as count, this
locks up a system. Fix this by rewriting the ring buffer implementation
with kfifo and simplify the code.
This fixes CVE-2019-3819.
v2: fix an execution logic and add a comment
v3: use __set_current_state() instead of set_current_state()
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1669187
Cc: stable@vger.kernel.org # v4.18+
Fixes: cd667ce24796 ("HID: use debugfs for events/reports dumping")
Fixes: 717adfdaf147 ("HID: debug: check length before copy_to_user()")
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 4f2ab5e1d13d6aa77c55f4914659784efd776eb4 upstream.
It is normal user behaviour to start, stop, then start a stream
again without closing it. Currently this works for compressed
playback streams but not capture ones.
The states on a compressed capture stream go directly from OPEN to
PREPARED, unlike a playback stream which moves to SETUP and waits
for a write of data before moving to PREPARED. Currently however,
when a stop is sent the state is set to SETUP for both types of
streams. This leaves a capture stream in the situation where a new
start can't be sent as that requires the state to be PREPARED and
a new set_params can't be sent as that requires the state to be
OPEN. The only option being to close the stream, and then reopen.
Correct this issues by allowing snd_compr_drain_notify to set the
state depending on the stream direction, as we already do in
set_params.
Fixes: 49bb6402f1aa ("ALSA: compress_core: Add support for capture streams")
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
[ Upstream commit 7a86dab8cf2f0fdf508f3555dddfc236623bff60 ]
Since the offset is added directly to the hva from the
gfn_to_hva_cache, a negative offset could result in an out of bounds
write. The existing BUG_ON only checks for addresses beyond the end of
the gfn_to_hva_cache, not for addresses before the start of the
gfn_to_hva_cache.
Note that all current call sites have non-negative offsets.
Fixes: 4ec6e8636256 ("kvm: Introduce kvm_write_guest_offset_cached()")
Reported-by: Cfir Cohen <cfir@google.com>
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Cfir Cohen <cfir@google.com>
Reviewed-by: Peter Shier <pshier@google.com>
Reviewed-by: Krish Sadhukhan <krish.sadhukhan@oracle.com>
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit a52c5a16cf19d8a85831bb1b915a221dd4ffae3c ]
There are several warnings from Clang about no case statement matching
the constant 0:
In file included from drivers/block/drbd/drbd_receiver.c:48:
In file included from drivers/block/drbd/drbd_int.h:48:
In file included from ./include/linux/drbd_genl_api.h:54:
In file included from ./include/linux/genl_magic_struct.h:236:
./include/linux/drbd_genl.h:321:1: warning: no case matching constant
switch condition '0'
GENL_struct(DRBD_NLA_HELPER, 24, drbd_helper_info,
./include/linux/genl_magic_struct.h:220:10: note: expanded from macro
'GENL_struct'
switch (0) {
Silence this warning by adding a 'case 0:' statement. Additionally,
adjust the alignment of the statements in the ct_assert_unique macro to
avoid a checkpatch warning.
This solution was originally sent by Arnd Bergmann with a default case
statement: https://lore.kernel.org/patchwork/patch/756723/
Link: https://github.com/ClangBuiltLinux/linux/issues/43
Suggested-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit 1e86ace4c140fd5a693e266c9b23409358f25381 ]
Currently the cpu affinity hint mask for completion EQs is stored and
read from the wrong place, since reading and storing is done from the
same index, there is no actual issue with that, but internal irq_info
for completion EQs stars at MLX5_EQ_VEC_COMP_BASE offset in irq_info
array, this patch changes the code to use the correct offset to store
and read the IRQ affinity hint.
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Tariq Toukan <tariqt@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit 18534df419041e6c1f4b41af56ee7d41f757815c ]
gpiod_request_commit() copies the pointer to the label passed as
an argument only to be used later. But there's a chance the caller
could immediately free the passed string(e.g., local variable).
This could trigger a use after free when we use gpio label(e.g.,
gpiochip_unlock_as_irq(), gpiochip_is_requested()).
To be on the safe side: duplicate the string with kstrdup_const()
so that if an unaware user passes an address to a stack-allocated
buffer, we won't get the arbitrary label.
Also fix gpiod_set_consumer_name().
Signed-off-by: Muchun Song <smuchun@gmail.com>
commit 144552c786925314c1e7cb8f91a71dae1aca8798 upstream.
Add checks:
- attempted kfree due to refcount reaching zero before overlay
is removed
- properties linked to an overlay node when the node is removed
- node refcount > one during node removal in a changeset destroy,
if the node was created by the changeset
After applying this patch, several validation warnings will be
reported from the devicetree unittest during boot due to
pre-existing devicetree bugs. The warnings will be similar to:
OF: ERROR: of_node_release(), unexpected properties in /testcase-data/overlay-node/test-bus/test-unittest11
OF: ERROR: memory leak, expected refcount 1 instead of 2, of_node_get()/of_node_put() unbalanced - destroy cset entry: attach overlay node /testcase-data-2/substation@100/
hvac-medium-2
Tested-by: Alan Tull <atull@kernel.org>
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
commit 9bcdeb51bd7d2ae9fe65ea4d60643d2aeef5bfe3 upstream.
Arkadiusz reported that enabling memcg's group oom killing causes
strange memcg statistics where there is no task in a memcg despite the
number of tasks in that memcg is not 0. It turned out that there is a
bug in wake_oom_reaper() which allows enqueuing same task twice which
makes impossible to decrease the number of tasks in that memcg due to a
refcount leak.
This bug existed since the OOM reaper became invokable from
task_will_free_mem(current) path in out_of_memory() in Linux 4.7,
T1@P1 |T2@P1 |T3@P1 |OOM reaper
# Processing an OOM victim in a different memcg domain.
try_charge()
mem_cgroup_out_of_memory()
mutex_lock(&oom_lock)
try_charge()
try_charge()
out_of_memory()
oom_kill_process(P1)
do_send_sig_info(SIGKILL, @P1)
mark_oom_victim(T1@P1)
wake_oom_reaper(T1@P1) # T1@P1 is enqueued.
mutex_unlock(&oom_lock)
out_of_memory()
mark_oom_victim(T2@P1)
wake_oom_reaper(T2@P1) # T2@P1 is enqueued.
out_of_memory()
wake_oom_reaper(T1@P1) # T1@P1 is enqueued again due to oom_reaper_list == T2@P1 && T1@P1->oom_reaper_list == NULL.
# Completed processing an OOM victim in a different memcg domain.
spin_lock(&oom_reaper_lock)
# T1P1 is dequeued.
spin_unlock(&oom_reaper_lock)
but memcg's group oom killing made it easier to trigger this bug by
calling wake_oom_reaper() on the same task from one out_of_memory()
request.
Fix this bug using an approach used by commit 855b018325737f76 ("oom,
oom_reaper: disable oom_reaper for oom_kill_allocating_task"). As a
side effect of this patch, this patch also avoids enqueuing multiple
threads sharing memory via task_will_free_mem(current) path.
Link: http://lkml.kernel.org/r/e865a044-2c10-9858-f4ef-254bc71d6cc2@i-love.sakura.ne.jp
Link: http://lkml.kernel.org/r/5ee34fc6-1485-34f8-8790-903ddabaa809@i-love.sakura.ne.jp
Fixes: af8e15cc85a25315 ("oom, oom_reaper: do not enqueue task if it is on the oom_reaper_list head")
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Acked-by: Roman Gushchin <guro@fb.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Aleksa Sarai <asarai@suse.de>
Cc: Jay Kamat <jgkamat@fb.com>
[ Upstream commit d5256083f62e2720f75bb3c5a928a0afe47d6bc3 ]
While implementing ipvlan l3 and l3s mode for kubernetes CNI plugin,
I ran into the issue that while l3 mode is working fine, l3s mode
does not have any connectivity to kube-apiserver and hence all pods
end up in Error state as well. The ipvlan master device sits on
top of a bond device and hostns traffic to kube-apiserver (also running
in hostns) is DNATed from 10.152.183.1:443 to 139.178.29.207:37573
where the latter is the address of the bond0. While in l3 mode, a
curl to https://10.152.183.1:443 or to https://139.178.29.207:37573
works fine from hostns, neither of them do in case of l3s. In the
latter only a curl to https://127.0.0.1:37573 appeared to work where
for local addresses of bond0 I saw kernel suddenly starting to emit
ARP requests to query HW address of bond0 which remained unanswered
and neighbor entries in INCOMPLETE state. These ARP requests only
happen while in l3s.
Debugging this further, I found the issue is that l3s mode is piggy-
backing on l3 master device, and in this case local routes are using
l3mdev_master_dev_rcu(dev) instead of net->loopback_dev as per commit
f5a0aab84b74 ("net: ipv4: dst for local input routes should use l3mdev
if relevant") and 5f02ce24c269 ("net: l3mdev: Allow the l3mdev to be
a loopback"). I found that reverting them back into using the
net->loopback_dev fixed ipvlan l3s connectivity and got everything
working for the CNI.
Now judging from 4fbae7d83c98 ("ipvlan: Introduce l3s mode") and the
l3mdev paper in [0] the only sole reason why ipvlan l3s is relying
on l3 master device is to get the l3mdev_ip_rcv() receive hook for
setting the dst entry of the input route without adding its own
ipvlan specific hacks into the receive path, however, any l3 domain
semantics beyond just that are breaking l3s operation. Note that
ipvlan also has the ability to dynamically switch its internal
operation from l3 to l3s for all ports via ipvlan_set_port_mode()
at runtime. In any case, l3 vs l3s soley distinguishes itself by
'de-confusing' netfilter through switching skb->dev to ipvlan slave
device late in NF_INET_LOCAL_IN before handing the skb to L4.
Minimal fix taken here is to add a IFF_L3MDEV_RX_HANDLER flag which,
if set from ipvlan setup, gets us only the wanted l3mdev_l3_rcv() hook
without any additional l3mdev semantics on top. This should also have
minimal impact since dev->priv_flags is already hot in cache. With
this set, l3s mode is working fine and I also get things like
masquerading pod traffic on the ipvlan master properly working.
[0] https://netdevconf.org/1.2/papers/ahern-what-is-l3mdev-paper.pdf
Fixes: f5a0aab84b74 ("net: ipv4: dst for local input routes should use l3mdev if relevant")
Fixes: 5f02ce24c269 ("net: l3mdev: Allow the l3mdev to be a loopback")
Fixes: 4fbae7d83c98 ("ipvlan: Introduce l3s mode")
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: David Ahern <dsa@cumulusnetworks.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Martynas Pumputis <m@lambda.lt>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
commit 141e5dcaa7356077028b4cd48ec351a38c70e5e5 upstream.
Arnd Bergmann pointed out that CONFIG_* cannot be used in a uapi header.
Override with an equivalent conditional.
Fixes: 2e746942ebac ("Input: input_event - provide override for sparc64")
Fixes: 152194fe9c3f ("Input: extend usable life of event timestamps to 2106 on 32 bit systems")
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
[ commit d3bd7413e0ca40b60cf60d4003246d067cafdeda upstream ]
While 979d63d50c0c ("bpf: prevent out of bounds speculation on pointer
arithmetic") took care of rejecting alu op on pointer when e.g. pointer
came from two different map values with different map properties such as
value size, Jann reported that a case was not covered yet when a given
alu op is used in both "ptr_reg += reg" and "numeric_reg += reg" from
different branches where we would incorrectly try to sanitize based
on the pointer's limit. Catch this corner case and reject the program
instead.
Fixes: 979d63d50c0c ("bpf: prevent out of bounds speculation on pointer arithmetic")
Reported-by: Jann Horn <jannh@google.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ commit 979d63d50c0c0f7bc537bf821e056cc9fe5abd38 upstream ]
Jann reported that the original commit back in b2157399cc98
("bpf: prevent out-of-bounds speculation") was not sufficient
to stop CPU from speculating out of bounds memory access:
While b2157399cc98 only focussed on masking array map access
for unprivileged users for tail calls and data access such
that the user provided index gets sanitized from BPF program
and syscall side, there is still a more generic form affected
from BPF programs that applies to most maps that hold user
data in relation to dynamic map access when dealing with
unknown scalars or "slow" known scalars as access offset, for
example:
- Load a map value pointer into R6
- Load an index into R7
- Do a slow computation (e.g. with a memory dependency) that
loads a limit into R8 (e.g. load the limit from a map for
high latency, then mask it to make the verifier happy)
- Exit if R7 >= R8 (mispredicted branch)
- Load R0 = R6[R7]
- Load R0 = R6[R0]
For unknown scalars there are two options in the BPF verifier
where we could derive knowledge from in order to guarantee
safe access to the memory: i) While </>/<=/>= variants won't
allow to derive any lower or upper bounds from the unknown
scalar where it would be safe to add it to the map value
pointer, it is possible through ==/!= test however. ii) another
option is to transform the unknown scalar into a known scalar,
for example, through ALU ops combination such as R &= <imm>
followed by R |= <imm> or any similar combination where the
original information from the unknown scalar would be destroyed
entirely leaving R with a constant. The initial slow load still
precedes the latter ALU ops on that register, so the CPU
executes speculatively from that point. Once we have the known
scalar, any compare operation would work then. A third option
only involving registers with known scalars could be crafted
as described in [0] where a CPU port (e.g. Slow Int unit)
would be filled with many dependent computations such that
the subsequent condition depending on its outcome has to wait
for evaluation on its execution port and thereby executing
speculatively if the speculated code can be scheduled on a
different execution port, or any other form of mistraining
as described in [1], for example. Given this is not limited
to only unknown scalars, not only map but also stack access
is affected since both is accessible for unprivileged users
and could potentially be used for out of bounds access under
speculation.
In order to prevent any of these cases, the verifier is now
sanitizing pointer arithmetic on the offset such that any
out of bounds speculation would be masked in a way where the
pointer arithmetic result in the destination register will
stay unchanged, meaning offset masked into zero similar as
in array_index_nospec() case. With regards to implementation,
there are three options that were considered: i) new insn
for sanitation, ii) push/pop insn and sanitation as inlined
BPF, iii) reuse of ax register and sanitation as inlined BPF.
Option i) has the downside that we end up using from reserved
bits in the opcode space, but also that we would require
each JIT to emit masking as native arch opcodes meaning
mitigation would have slow adoption till everyone implements
it eventually which is counter-productive. Option ii) and iii)
have both in common that a temporary register is needed in
order to implement the sanitation as inlined BPF since we
are not allowed to modify the source register. While a push /
pop insn in ii) would be useful to have in any case, it
requires once again that every JIT needs to implement it
first. While possible, amount of changes needed would also
be unsuitable for a -stable patch. Therefore, the path which
has fewer changes, less BPF instructions for the mitigation
and does not require anything to be changed in the JITs is
option iii) which this work is pursuing. The ax register is
already mapped to a register in all JITs (modulo arm32 where
it's mapped to stack as various other BPF registers there)
and used in constant blinding for JITs-only so far. It can
be reused for verifier rewrites under certain constraints.
The interpreter's tmp "register" has therefore been remapped
into extending the register set with hidden ax register and
reusing that for a number of instructions that needed the
prior temporary variable internally (e.g. div, mod). This
allows for zero increase in stack space usage in the interpreter,
and enables (restricted) generic use in rewrites otherwise as
long as such a patchlet does not make use of these instructions.
The sanitation mask is dynamic and relative to the offset the
map value or stack pointer currently holds.
There are various cases that need to be taken under consideration
for the masking, e.g. such operation could look as follows:
ptr += val or val += ptr or ptr -= val. Thus, the value to be
sanitized could reside either in source or in destination
register, and the limit is different depending on whether
the ALU op is addition or subtraction and depending on the
current known and bounded offset. The limit is derived as
follows: limit := max_value_size - (smin_value + off). For
subtraction: limit := umax_value + off. This holds because
we do not allow any pointer arithmetic that would
temporarily go out of bounds or would have an unknown
value with mixed signed bounds where it is unclear at
verification time whether the actual runtime value would
be either negative or positive. For example, we have a
derived map pointer value with constant offset and bounded
one, so limit based on smin_value works because the verifier
requires that statically analyzed arithmetic on the pointer
must be in bounds, and thus it checks if resulting
smin_value + off and umax_value + off is still within map
value bounds at time of arithmetic in addition to time of
access. Similarly, for the case of stack access we derive
the limit as follows: MAX_BPF_STACK + off for subtraction
and -off for the case of addition where off := ptr_reg->off +
ptr_reg->var_off.value. Subtraction is a special case for
the masking which can be in form of ptr += -val, ptr -= -val,
or ptr -= val. In the first two cases where we know that
the value is negative, we need to temporarily negate the
value in order to do the sanitation on a positive value
where we later swap the ALU op, and restore original source
register if the value was in source.
The sanitation of pointer arithmetic alone is still not fully
sufficient as is, since a scenario like the following could
happen ...
PTR += 0x1000 (e.g. K-based imm)
PTR -= BIG_NUMBER_WITH_SLOW_COMPARISON
PTR += 0x1000
... which under speculation could end up as ...
PTR += 0x1000
PTR -= 0 [ truncated by mitigation ]
PTR += 0x1000
... and therefore still access out of bounds. To prevent such
case, the verifier is also analyzing safety for potential out
of bounds access under speculative execution. Meaning, it is
also simulating pointer access under truncation. We therefore
"branch off" and push the current verification state after the
ALU operation with known 0 to the verification stack for later
analysis. Given the current path analysis succeeded it is
likely that the one under speculation can be pruned. In any
case, it is also subject to existing complexity limits and
therefore anything beyond this point will be rejected. In
terms of pruning, it needs to be ensured that the verification
state from speculative execution simulation must never prune
a non-speculative execution path, therefore, we mark verifier
state accordingly at the time of push_stack(). If verifier
detects out of bounds access under speculative execution from
one of the possible paths that includes a truncation, it will
reject such program.
Given we mask every reg-based pointer arithmetic for
unprivileged programs, we've been looking into how it could
affect real-world programs in terms of size increase. As the
majority of programs are targeted for privileged-only use
case, we've unconditionally enabled masking (with its alu
restrictions on top of it) for privileged programs for the
sake of testing in order to check i) whether they get rejected
in its current form, and ii) by how much the number of
instructions and size will increase. We've tested this by
using Katran, Cilium and test_l4lb from the kernel selftests.
For Katran we've evaluated balancer_kern.o, Cilium bpf_lxc.o
and an older test object bpf_lxc_opt_-DUNKNOWN.o and l4lb
we've used test_l4lb.o as well as test_l4lb_noinline.o. We
found that none of the programs got rejected by the verifier
with this change, and that impact is rather minimal to none.
balancer_kern.o had 13,904 bytes (1,738 insns) xlated and
7,797 bytes JITed before and after the change. Most complex
program in bpf_lxc.o had 30,544 bytes (3,817 insns) xlated
and 18,538 bytes JITed before and after and none of the other
tail call programs in bpf_lxc.o had any changes either. For
the older bpf_lxc_opt_-DUNKNOWN.o object we found a small
increase from 20,616 bytes (2,576 insns) and 12,536 bytes JITed
before to 20,664 bytes (2,582 insns) and 12,558 bytes JITed
after the change. Other programs from that object file had
similar small increase. Both test_l4lb.o had no change and
remained at 6,544 bytes (817 insns) xlated and 3,401 bytes
JITed and for test_l4lb_noinline.o constant at 5,080 bytes
(634 insns) xlated and 3,313 bytes JITed. This can be explained
in that LLVM typically optimizes stack based pointer arithmetic
by using K-based operations and that use of dynamic map access
is not overly frequent. However, in future we may decide to
optimize the algorithm further under known guarantees from
branch and value speculation. Latter seems also unclear in
terms of prediction heuristics that today's CPUs apply as well
as whether there could be collisions in e.g. the predictor's
Value History/Pattern Table for triggering out of bounds access,
thus masking is performed unconditionally at this point but could
be subject to relaxation later on. We were generally also
brainstorming various other approaches for mitigation, but the
blocker was always lack of available registers at runtime and/or
overhead for runtime tracking of limits belonging to a specific
pointer. Thus, we found this to be minimally intrusive under
given constraints.
With that in place, a simple example with sanitized access on
unprivileged load at post-verification time looks as follows:
# bpftool prog dump xlated id 282
28: (79) r1 = *(u64 *)(r7 +0)
29: (79) r2 = *(u64 *)(r7 +8)
30: (57) r1 &= 15
31: (79) r3 = *(u64 *)(r0 +4608)
32: (57) r3 &= 1
33: (47) r3 |= 1
34: (2d) if r2 > r3 goto pc+19
35: (b4) (u32) r11 = (u32) 20479 |
36: (1f) r11 -= r2 | Dynamic sanitation for pointer
37: (4f) r11 |= r2 | arithmetic with registers
38: (87) r11 = -r11 | containing bounded or known
39: (c7) r11 s>>= 63 | scalars in order to prevent
40: (5f) r11 &= r2 | out of bounds speculation.
41: (0f) r4 += r11 |
42: (71) r4 = *(u8 *)(r4 +0)
43: (6f) r4 <<= r1
For the case where the scalar sits in the destination register
as opposed to the source register, the following code is emitted
for the above example:
16: (b4) (u32) r11 = (u32) 20479
17: (1f) r11 -= r2
18: (4f) r11 |= r2
19: (87) r11 = -r11
20: (c7) r11 s>>= 63
21: (5f) r2 &= r11
22: (0f) r2 += r0
23: (61) r0 = *(u32 *)(r2 +0)
JIT blinding example with non-conflicting use of r10:
d5: je 0x0000000000000106 _
d7: mov 0x0(%rax),%edi |
da: mov $0xf153246,%r10d | Index load from map value and
e0: xor $0xf153259,%r10 | (const blinded) mask with 0x1f.
e7: and %r10,%rdi |_
ea: mov $0x2f,%r10d |
f0: sub %rdi,%r10 | Sanitized addition. Both use r10
f3: or %rdi,%r10 | but do not interfere with each
f6: neg %r10 | other. (Neither do these instructions
f9: sar $0x3f,%r10 | interfere with the use of ax as temp
fd: and %r10,%rdi | in interpreter.)
100: add %rax,%rdi |_
103: mov 0x0(%rdi),%eax
Tested that it fixes Jann's reproducer, and also checked that test_verifier
and test_progs suite with interpreter, JIT and JIT with hardening enabled
on x86-64 and arm64 runs successfully.
[0] Speculose: Analyzing the Security Implications of Speculative
Execution in CPUs, Giorgi Maisuradze and Christian Rossow,
https://arxiv.org/pdf/1801.04084.pdf
[1] A Systematic Evaluation of Transient Execution Attacks and
Defenses, Claudio Canella, Jo Van Bulck, Michael Schwarz,
Moritz Lipp, Benjamin von Berg, Philipp Ortner, Frank Piessens,
Dmitry Evtyushkin, Daniel Gruss,
https://arxiv.org/pdf/1811.05441.pdf
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ commit 9b73bfdd08e73231d6a90ae6db4b46b3fbf56c30 upstream ]
Right now we are using BPF ax register in JIT for constant blinding as
well as in interpreter as temporary variable. Verifier will not be able
to use it simply because its use will get overridden from the former in
bpf_jit_blind_insn(). However, it can be made to work in that blinding
will be skipped if there is prior use in either source or destination
register on the instruction. Taking constraints of ax into account, the
verifier is then open to use it in rewrites under some constraints. Note,
ax register already has mappings in every eBPF JIT.
[ commit 144cd91c4c2bced6eb8a7e25e590f6618a11e854 upstream ]
This change moves the on-stack 64 bit tmp variable in ___bpf_prog_run()
into the hidden ax register. The latter is currently only used in JITs
for constant blinding as a temporary scratch register, meaning the BPF
interpreter will never see the use of ax. Therefore it is safe to use
it for the cases where tmp has been used earlier. This is needed to later
on allow restricted hidden use of ax in both interpreter and JITs.
[ commit c08435ec7f2bc8f4109401f696fd55159b4b40cb upstream ]
Move prev_insn_idx and insn_idx from the do_check() function into
the verifier environment, so they can be read inside the various
helper functions for handling the instructions. It's easier to put
this into the environment rather than changing all call-sites only
to pass it along. insn_idx is useful in particular since this later
on allows to hold state in env->insn_aux_data[env->insn_idx].
