Add variants of drm_format_plane_{width,height}() that take an entire fb
object instead of just the format. These should be more efficent as they
can just look up the format info from the fb->format pointer rather than
having to look it up (using a linear search based on the format).
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1479498793-31021-30-git-send-email-ville.syrjala@linux.intel.com
To avoid having to look up the format information struct every time,
let's just store a pointer to it under drm_framebuffer.
v2: Don't populate the fb->format pointer in drm_framebuffer_init().
instead we'll treat a NULL format as an error later
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com> (v1)
Link: http://patchwork.freedesktop.org/patch/msgid/1479498793-31021-20-git-send-email-ville.syrjala@linux.intel.com
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Pass the drm_device to drm_helper_mode_fill_fb_struct() so that we can
populate fb->dev early. Will make it easier to use the fb before we
register it.
identifier fb, mode_cmd;
void drm_helper_mode_fill_fb_struct(
+ struct drm_device *dev,
struct drm_framebuffer *fb,
const struct drm_mode_fb_cmd2 *mode_cmd
function func;
identifier dev;
expression E1, E2;
func(struct drm_device *dev, ...)
+ dev,
E1, E2);
expression E1, E2;
+ dev,
E1, E2);
v2: Rerun spatch due to code changes
Link: http://patchwork.freedesktop.org/patch/msgid/1481748539-18283-1-git-send-email-ville.syrjala@linux.intel.com
into drm-misc-next
Main pull request for drm for 4.10 kernel - resync drm-misc with full
4.10 state (2 new drivers) so that we can start pulling in all the
refactorings for 4.11!
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
We need to define DRM_FORMAT_MOD_VENDOR_NONE for the fourcc_mod_code()
macro to work correctly.
Signed-off-by: Kristian H. Kristensen <hoegsberg@google.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1481657272-25975-1-git-send-email-hoegsberg@google.com
- Again move the information relevant for driver writers next to the
callbacks.
- Put the overview and userspace interface documentation into a DOC:
section within the code.
- Remove the text that mmap needs to be coherent - since the
DMA_BUF_IOCTL_SYNC landed that's no longer the case. But keep the text
that for pte zapping exporters need to adjust the address space.
- Add a FIXME that kmap and the new begin/end stuff used by the SYNC
ioctl don't really mix correctly. That's something I just realized
while doing this doc rework.
- Augment function and structure docs like usual.
Cc: linux-doc@vger.kernel.org
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[sumits: fix cosmetic issues]
Link: http://patchwork.freedesktop.org/patch/msgid/20161209185309.1682-5-daniel.vetter@ffwll.ch
- Put the initial overview for dma-buf into dma-buf.rst.
- Put all the comments about detailed semantics into the right
kernel-doc comment for functions or ops structure member.
- To allow that detail, switch the reworked kerneldoc to inline style
for dma_buf_ops.
- Tie everything together into a much more streamlined overview
comment, relying on the hyperlinks for all the details.
- Also sprinkle some links into the kerneldoc for dma_buf and
dma_buf_attachment to tie it all together.
Link: http://patchwork.freedesktop.org/patch/msgid/20161209185309.1682-4-daniel.vetter@ffwll.ch
Backmerge the docs-next branch from Jon into drm-misc so that we can
apply the dma-buf documentation cleanup patches. Git found a conflict
where there was none because both drm-misc and docs had identical
patches to clean up file rename issues in the rst include directives.
No one looks at the major/minor versions except the unique/busid
stuff. If we protect that with the master_mutex (since it also affects
the unique of each master, oh well) we can mark these two IOCTL with
DRM_UNLOCKED.
While doing this I realized that the comment for the magic_map is
outdated, I've forgotten to update it in:
commit d2b34ee62b409a03c6fe43c07b779983be51d017
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Fri Jun 17 09:33:21 2016 +0200
drm: Protect authmagic with master_mutex
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Emil Velikov <emil.l.velikov@gmail.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161210215255.7765-1-daniel.vetter@ffwll.ch
Not setting the fb modifiers flag is something different from setting
the fb modifiers to 0 (which means explicitly linear). We kinda failed
to document that properly. Spotted by Kristian.
Cc: hoegsberg@google.com
Reviewed-by: Kristian H. Kristensen <hoegsberg@google.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1478694996-4200-1-git-send-email-daniel.vetter@ffwll.ch
drm-next
This pull request brings in VEC (TV-out) support for vc4, along with a
pageflipping race fix.
* tag 'drm-vc4-next-2016-12-09' of https://github.com/anholt/linux:
drm/vc4: Don't use drm_put_dev
drm/vc4: Document VEC DT binding
drm/vc4: Add support for the VEC (Video Encoder) IP
drm: Add TV connector states to drm_connector_state
drm: Turn DRM_MODE_SUBCONNECTOR_xx definitions into an enum
drm/vc4: Fix ->clock_select setting for the VEC encoder
drm/vc4: Fix race between page flip completion event and clean-up
Joonas complained that writing ww_mutex_lock(&resv->lock, ctx) was too
intrusive compared to reservation_object_lock(resv, ctx);
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161115154642.31850-1-chris@chris-wilson.co.uk
Some generic TV connector properties are exposed in drm_mode_config, but
they are currently handled independently in each DRM encoder driver.
Extend the drm_connector_state to store TV related states, and modify the
drm_atomic_connector_{set,get}_property() helpers to fill the connector
state accordingly.
Each driver is then responsible for checking and applying the new config
in its ->atomic_mode_{check,set}() operations.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Eric Anholt <eric@anholt.net>
List of values like the DRM_MODE_SUBCONNECTOR_xx ones are better
represented with enums.
Turn the DRM_MODE_SUBCONNECTOR_xx macros into an enum.
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
git://anongit.freedesktop.org/git/drm-misc into drm-next
Another pile of misc stuff, final one for 4.10. If there's some serious
bugfix still I'll send you a pull for drm-misc-next-fixes (like we do with
intel), otherwise this is it and next pull next year for 4.11.
Most interesting bits are probably Chris' fb helper fixes against mst
hotplug oopses.
* tag 'drm-misc-next-2016-12-08' of git://anongit.freedesktop.org/git/drm-misc: (22 commits)
drm: Take ownership of the dmabuf->obj when exporting
drm: Allow CAP_PRIME on !MODESET
drm/fence: add drm_crtc_create_fence()
drm/bridge: analogix: Don't return -EINVAL when panel doesn't support PSR
drm/atomic: doc: remove old comment about nonblocking commits
drm: Don't block the kworker waiting for mode_config.mutex in output_poll()
drm: Return -ENOTSUPP when called for KMS cap with a non-KMS driver
drm/amdgpu: don't add files at control minor debugfs directory
drm: allow changing DPMS mode
drm/qxl: fix use of uninitialized variable
drm/qxl: Don't register debugfs for control minors
drm/radeon: don't add files at control minor debugfs directory
drm/vmwgfx: Switch to mode_cmd2
drm/vgem: Use ww_mutex_(un)lock even with a NULL context
drm: Make the connector .detect() callback optional
drm/bridge: tc358767: don't warn if display side ASSR enable fails
drm: Initialise drm_mm.head_node.allocated
drm: Fix locking cargo-cult in encoder/plane init/cleanup
drm/doc: Fix indenting in drm_modeset_lock.c comment
drm: Protect fb_helper list manipulation with a mutex
into drm-next
Misc fixes and cleanups for 4.10. Highlights:
- Cursor fixes for radeon and amdgpu
- DPM fixes for some new SI variants
- Powerplay fixes
- Clock and powergating fixes
* 'drm-next-4.10' of git://people.freedesktop.org/~agd5f/linux: (39 commits)
drm/amdgpu/dce6: Set MASTER_UPDATE_MODE to 0 in resume_mc_access as well
drm/amdgpu: use pin rather than pin_restricted in a few cases
drm/amd/powerplay: use pr_debug to print function not implemented message
drm/amd/amdgpu: Add gpr reading for GFX v7
drm/amd/amdgpu: Add gpr reading for GFX v6
drm/amd/amdgpu: Add debugfs support for reading GPRs (v2)
drm/amd/amdgpu: export vbios information (v2)
drm/amd/amdgpu: stored bios_size
drm/amdgpu: update golden setting of tonga
drm/amdgpu/si: load the proper firmware on 0x87 oland boards
drm/amdgpu: add additional pci revision to dpm workaround
drm/radeon/si: load the proper firmware on 0x87 oland boards
drm/radeon: add additional pci revision to dpm workaround
drm/amd/powerplay: Fix potential NULL pointer issue
drm/amdgpu: Don't touch GFX hw during HW fini
drm/amd/powerplay: Adjust the position of data size initial
drm/amd/powerplay: Ignore smu buffer usage
drm/amd/powerplay: cut digest part
drm/amdgpu: drop redundant vi_mqd define
drm/amdgpu: fix gtt available page num accounting
Allows userspace components to fetch information
from the vbios image.
v2: agd: fix warning
Reviewed-by: Edward O'Callaghan <funfunctor@folklore1984.net>
Signed-off-by: Evan Quan <evan.quan@amd.com>
Reviewed-by: Christian Koenig <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
drm_universal_plane_init() and drm_plane_init() take "unsigned long
possible_crtcs" parameter, but then stuff it into uint32_t. Change the
parameter to uint32_t.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Backmerge v4.9-rc8 to get at
commit e94bd1736f1f60e916a85a80c0b0ebeaae36cce5
Author: Michel Dänzer <michel.daenzer@amd.com>
Date: Wed Nov 30 17:30:01 2016 +0900
drm: Don't call drm_for_each_crtc with a non-KMS driver
so I can apply Michel's follow-up patch.
Linux 4.9-rc8
Daniel requested this so we could apply some follow on fixes cleanly to -next.
Pull networking fixes from David Miller:
1) Lots more phydev and probe error path leaks in various drivers by
Johan Hovold.
2) Fix race in packet_set_ring(), from Philip Pettersson.
3) Use after free in dccp_invalid_packet(), from Eric Dumazet.
4) Signnedness overflow in SO_{SND,RCV}BUFFORCE, also from Eric
Dumazet.
5) When tunneling between ipv4 and ipv6 we can be left with the wrong
skb->protocol value as we enter the IPSEC engine and this causes all
kinds of problems. Set it before the output path does any
dst_output() calls, from Eli Cooper.
6) bcmgenet uses wrong device struct pointer in DMA API calls, fix from
Florian Fainelli.
7) Various netfilter nat bug fixes from FLorian Westphal.
8) Fix memory leak in ipvlan_link_new(), from Gao Feng.
9) Locking fixes, particularly wrt. socket lookups, in l2tp from
Guillaume Nault.
10) Avoid invoking rhash teardowns in atomic context by moving netlink
cb->done() dump completion from a worker thread. Fix from Herbert
Xu.
11) Buffer refcount problems in tun and macvtap on errors, from Jason
Wang.
12) We don't set Kconfig symbol DEFAULT_TCP_CONG properly when the user
selects BBR. Fix from Julian Wollrath.
13) Fix deadlock in transmit path on altera TSE driver, from Lino
Sanfilippo.
14) Fix unbalanced reference counting in dsa_switch_tree, from Nikita
Yushchenko.
15) tc_tunnel_key needs to be properly exported to userspace via uapi,
fix from Roi Dayan.
16) rds_tcp_init_net() doesn't unregister notifier in error path, fix
from Sowmini Varadhan.
17) Stale packet header pointer access after pskb_expand_head() in
genenve driver, fix from Sabrina Dubroca.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits)
net: avoid signed overflows for SO_{SND|RCV}BUFFORCE
geneve: avoid use-after-free of skb->data
tipc: check minimum bearer MTU
net: renesas: ravb: unintialized return value
sh_eth: remove unchecked interrupts for RZ/A1
net: bcmgenet: Utilize correct struct device for all DMA operations
NET: usb: qmi_wwan: add support for Telit LE922A PID 0x1040
cdc_ether: Fix handling connection notification
ip6_offload: check segs for NULL in ipv6_gso_segment.
RDS: TCP: unregister_netdevice_notifier() in error path of rds_tcp_init_net
Revert: "ip6_tunnel: Update skb->protocol to ETH_P_IPV6 in ip6_tnl_xmit()"
ipv6: Set skb->protocol properly for local output
ipv4: Set skb->protocol properly for local output
packet: fix race condition in packet_set_ring
net: ethernet: altera: TSE: do not use tx queue lock in tx completion handler
net: ethernet: altera: TSE: Remove unneeded dma sync for tx buffers
net: ethernet: stmmac: fix of-node and fixed-link-phydev leaks
net: ethernet: stmmac: platform: fix outdated function header
net: ethernet: stmmac: dwmac-meson8b: fix probe error path
net: ethernet: stmmac: dwmac-generic: fix probe error path
With binutils-2.26 and before, a weak missing symbol was kept during the
final link, and a missing CRC for an export would lead to that CRC being
treated as zero implicitly. With binutils-2.27, the crc symbol gets
dropped, and any module trying to use it will fail to load.
This sets the weak CRC symbol to zero explicitly, making it defined in
vmlinux, which in turn lets us load the modules referring to that CRC.
The comment above the __CRC_SYMBOL macro suggests that this was always
the intention, although it also seems that all symbols defined in C have
a correct CRC these days, and only the exports that are now done in
assembly need this.
Tested-by: Adam Borowski <kilobyte@angband.pl>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"PCI fixes:
- Fix Read Completion Boundary setting, which fixes a boot failure on
IBM x3850 with Mellanox MT27500 ConnectX-3
- Update some MAINTAINERS entries and email addresses"
* tag 'pci-v4.9-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Set Read Completion Boundary to 128 iff Root Port supports it (_HPX)
PCI: Export pcie_find_root_port
PCI: designware-plat: Update author email
PCI: designware: Change maintainer to Joao Pinto
MAINTAINERS: Add devicetree binding to PCI i.MX6 entry
MAINTAINERS: Update Richard Zhu's email address
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov: "We are disabling automatic
probing of BYD touchpads as it results in too many false positives,
and the hardware is not terribly popular and having the protocol
support does not result in significantly improved user experience.
We also change keycode for KEY_DATA to avoid clashing with
KEY_FASTREVERSE. Luckily this newish code is used by CEC framework
that is still in staging, so it is extremely unlikely that someone has
already started using this keycode"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: change KEY_DATA from 0x275 to 0x277
Input: psmouse - disable automatic probing of BYD touchpads
Pablo Neira Ayuso says:
Netfilter fixes for net
This is a large batch of Netfilter fixes for net, they are:
1) Three patches to fix NAT conversion to rhashtable: Switch to rhlist
structure that allows to have several objects with the same key.
Moreover, fix wrong comparison logic in nf_nat_bysource_cmp() as this is
expecting a return value similar to memcmp(). Change location of
the nat_bysource field in the nf_conn structure to avoid zeroing
this as it breaks interaction with SLAB_DESTROY_BY_RCU and lead us
to crashes. From Florian Westphal.
2) Don't allow malformed fragments go through in IPv6, drop them,
otherwise we hit GPF, patch from Florian Westphal.
3) Fix crash if attributes are missing in nft_range, from Liping Zhang.
4) Fix arptables 32-bits userspace 64-bits kernel compat, from Hongxu Jia.
5) Two patches from David Ahern to fix netfilter interaction with vrf.
From David Ahern.
6) Fix element timeout calculation in nf_tables, we take milliseconds
from userspace, but we use jiffies from kernelspace. Patch from
Anders K. Pedersen.
7) Missing validation length netlink attribute for nft_hash, from
Laura Garcia.
8) Fix nf_conntrack_helper documentation, we don't default to off
anymore for a bit of time so let's get this in sync with the code.
I know is late but I think these are important, specifically the NAT
bits, as they are mostly addressing fallout from recent changes. I also
read there are chances to have -rc8, if that is the case, that would
also give us a bit more time to test this.
Many drivers (21 to be exact) create connectors that are always
connected (for instance to an LVDS or DSI panel). Instead of forcing
them to implement a dummy .detect() handler, make the callback optional
and consider the connector as always connected in that case.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Jyri Sarha <jsarha@ti.com>
Acked-by: Jani Nikula <jani.nikula@intel.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Vincent Abriou <vincent.abriou@st.com>
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
[seanpaul fixed small conflict in rcar-du/rcar_du_lvdscon.c]
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Hugetlb pages have ->index in size of the huge pages (PMD_SIZE or
PUD_SIZE), not in PAGE_SIZE as other types of pages. This means we
cannot user page_to_pgoff() to check whether we've got the right page
for the radix-tree index.
Let's introduce page_to_index() which would return radix-tree index for
given page.
We will be able to get rid of this once hugetlb will be switched to
multi-order entries.
Fixes: fc127da085c2 ("truncate: handle file thp")
Link: http://lkml.kernel.org/r/20161123093053.mjbnvn5zwxw5e6lk@black.fi.intel.com
Reported-by: Doug Nelson <doug.nelson@intel.com>
Tested-by: Doug Nelson <doug.nelson@intel.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [4.8+]
kasan_global struct is part of compiler/runtime ABI. gcc revision
241983 has added a new field to kasan_global struct. Update kernel
definition of kasan_global struct to include the new field.
Without this patch KASAN is broken with gcc 7.
Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: <stable@vger.kernel.org> [4.0+]
drm-next
On the userspace side, all the basics are working, and most of glmark2
is working. I've been working through deqp, and I've got a couple more
things to fix (but we've gone from 70% to 80+% pass in last day, and
current deqp run that is going should pick up another 5-10%). I expect
to push the mesa patches today or tomorrow.
There are a couple more a5xx related patches to take the gpu out of
secure mode (for the devices that come up in secure mode, like the hw
I have), but those depend on an scm patch that would come in through
another tree. If that can land in the next day or two, there might
be a second late pull request for drm/msm.
In addition to the new-shiny, there have also been a lot of overlay/
plane related fixes for issues found using drm-hwc2 (in the process of
testing/debugging the atomic/kms fence patches), resulting in rework
to assign hwpipes to kms planes dynamically (as part of global atomic
state) and also handling SMP (fifo) block allocation atomically as
part of the ->atomic_check() step. All those patches should also help
out atomic weston (when those patches eventually land).
* 'msm-next' of git://people.freedesktop.org/~robclark/linux: (36 commits)
drm/msm: gpu: Add support for the GPMU
drm/msm: gpu: Add A5XX target support
drm/msm: Disable interrupts during init
drm/msm: Remove 'src_clk' from adreno configuration
drm/msm: gpu: Add OUT_TYPE4 and OUT_TYPE7
drm/msm: Add adreno_gpu_write64()
drm/msm: gpu Add new gpu register read/write functions
drm/msm: gpu: Return error on hw_init failure
drm/msm: gpu: Cut down the list of "generic" registers to the ones we use
drm/msm: update generated headers
drm/msm/adreno: move scratch register dumping to per-gen code
drm/msm/rd: support for 64b iova
drm/msm: convert iova to 64b
drm/msm: set dma_mask properly
drm/msm: Remove bad calls to of_node_put()
drm/msm/mdp5: move LM bounds check into plane->atomic_check()
drm/msm/mdp5: dump smp state on errors too
drm/msm/mdp5: add debugfs to show smp block status
drm/msm/mdp5: handle SMP block allocations "atomically"
drm/msm/mdp5: dynamically assign hw pipes to planes
Socket flags aren't updated atomically, so the socket must be locked
while reading the SOCK_ZAPPED flag.
This issue exists for both l2tp_ip and l2tp_ip6. For IPv6, this patch
also brings error handling for __ip6_datagram_connect() failures.
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
0x275 is used by KEY_FASTREVERSE.
Fixes: 488326947cd1 ("Input: add HDMI CEC specific keycodes")
Signed-off-by: Ping Cheng <ping.cheng@wacom.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Cc: stable@vger.kernel.org
Big thing is that drm-misc is now officially a group maintainer/committer
model thing, with MAINTAINERS suitably updated. Otherwise just the usual
pile of misc things all over, nothing that stands out this time around.
* tag 'drm-misc-next-2016-11-29' of git://anongit.freedesktop.org/git/drm-misc: (33 commits)
drm: Introduce drm_framebuffer_assign()
drm/bridge: adv7511: Enable the audio data and clock pads on adv7533
drm/bridge: adv7511: Add Audio support
drm/edid: Consider alternate cea timings to be the same VIC
drm/atomic: Constify drm_atomic_crtc_needs_modeset()
drm: bridge: dw-hdmi: add ASoC dependency
drm: Fix shift operations for drm_fb_helper::drm_target_preferred()
drm: Avoid NULL dereference for DRM_LEGACY debug message
drm: Use u64_to_user_ptr() helper for blob ioctls
drm: Fix conflicting macro parameter in drm_mm_for_each_node_in_range()
drm: Fixup kernel doc for driver->gem_create_object
drm/hisilicon/hibmc: mark PM functions __maybe_unused
drm/hisilicon/hibmc: Checking for NULL instead of IS_ERR()
drm: bridge: add DesignWare HDMI I2S audio support
drm: Check against color expansion in drm_mm_reserve_node()
drm: Define drm_mm_for_each_node_in_range()
drm/doc: Fix links in drm_property.c
MAINTAINERS: Add link to drm-misc documentation
vgaarb: use valid dev pointer in vgaarb_info()
drm/atomic: Unconfuse the old_state mess in commmit_tail
git://anongit.freedesktop.org/git/drm-intel into drm-next
Final 4.10 updates:
- fine-tune fb flushing and tracking (Chris Wilson)
- refactor state check dumper code for more conciseness (Tvrtko)
- roll out dev_priv all over the place (Tvrkto)
- finally remove __i915__ magic macro (Tvrtko)
- more gvt bugfixes (Zhenyu&team)
- better opregion CADL handling (Jani)
- refactor/clean up wm programming (Maarten)
- gpu scheduler + priority boosting for flips as first user (Chris
Wilson)
- make fbc use more atomic (Paulo)
- initial kvm-gvt framework, but not yet complete (Zhenyu&team)
* tag 'drm-intel-next-2016-11-21' of git://anongit.freedesktop.org/git/drm-intel: (127 commits)
drm/i915: Update DRIVER_DATE to 20161121
drm/i915: Skip final clflush if LLC is coherent
drm/i915: Always flush the dirty CPU cache when pinning the scanout
drm/i915: Don't touch NULL sg on i915_gem_object_get_pages_gtt() error
drm/i915: Check that each request phase is completed before retiring
drm/i915: i915_pages_create_for_stolen should return err ptr
drm/i915: Enable support for nonblocking modeset
drm/i915: Be more careful to drop the GT wakeref
drm/i915: Move frontbuffer CS write tracking from ggtt vma to object
drm/i915: Only dump dp_m2_n2 configuration when drrs is used
drm/i915: don't leak global_timeline
drm/i915: add i915_address_space_fini
drm/i915: Add a few more sanity checks for stolen handling
drm/i915: Waterproof verification of gen9 forcewake table ranges
drm/i915: Introduce enableddisabled helper
drm/i915: Only dump possible panel fitter config for the platform
drm/i915: Only dump scaler config where supported
drm/i915: Compact a few pipe config debug lines
drm/i915: Don't log pipe config kernel pointer and duplicated pipe name
drm/i915: Dump FDI config only where applicable
drm/virtio: fix busid in a different way, allocate more vbufs.
drm/qxl: various bugfixes and cleanups,
* tag 'drm-qemu-20161121' of git://git.kraxel.org/linux: (224 commits)
drm/virtio: allocate some extra bufs
qxl: Allow resolution which are not multiple of 8
qxl: Don't notify userspace when monitors config is unchanged
qxl: Remove qxl_bo_init() return value
qxl: Call qxl_gem_{init, fini}
qxl: Add missing '\n' to qxl_io_log() call
qxl: Remove unused prototype
qxl: Mark some internal functions as static
Revert "drm: virtio: reinstate drm_virtio_set_busid()"
drm/virtio: fix busid regression
drm: re-export drm_dev_set_unique
Linux 4.9-rc5
gp8psk: Fix DVB frontend attach
gp8psk: fix gp8psk_usb_in_op() logic
dvb-usb: move data_mutex to struct dvb_usb_device
iio: maxim_thermocouple: detect invalid storage size in read()
aoe: fix crash in page count manipulation
lightnvm: invalid offset calculation for lba_shift
Kbuild: enable -Wmaybe-uninitialized warnings by default
pcmcia: fix return value of soc_pcmcia_regulator_set
Add helper to deregister fixed-link PHYs registered using
of_phy_register_fixed_link().
Convert the two drivers that care to deregister their fixed-link PHYs to
use the new helper, but note that most drivers currently fail to do so.
Signed-off-by: Johan Hovold <johan@kernel.org>
In a couple of places currently, and with the intent to add more, we
update a pointer to a framebuffer to hold a new fb reference (evicting
the old).
Link: http://patchwork.freedesktop.org/patch/msgid/20161125153231.13255-2-chris@chris-wilson.co.uk
This reverts commit 9d76931180557270796f9631e2c79b9c7bb3c9fb.
Using unregister_netdev at shutdown flow prevents calling
the netdev's ndos or trying to access its freed resources.
This fixes crashes like the following:
Call Trace:
[<ffffffff81587a6e>] dev_get_phys_port_id+0x1e/0x30
[<ffffffff815a36ce>] rtnl_fill_ifinfo+0x4be/0xff0
[<ffffffff815a53f3>] rtmsg_ifinfo_build_skb+0x73/0xe0
[<ffffffff815a5476>] rtmsg_ifinfo.part.27+0x16/0x50
[<ffffffff815a54c8>] rtmsg_ifinfo+0x18/0x20
[<ffffffff8158a6c6>] netdev_state_change+0x46/0x50
[<ffffffff815a5e78>] linkwatch_do_dev+0x38/0x50
[<ffffffff815a6165>] __linkwatch_run_queue+0xf5/0x170
[<ffffffff815a6205>] linkwatch_event+0x25/0x30
[<ffffffff81099a82>] process_one_work+0x152/0x400
[<ffffffff8109a325>] worker_thread+0x125/0x4b0
[<ffffffff8109a200>] ? rescuer_thread+0x350/0x350
[<ffffffff8109fc6a>] kthread+0xca/0xe0
[<ffffffff8109fba0>] ? kthread_park+0x60/0x60
[<ffffffff816a1285>] ret_from_fork+0x25/0x30
Fixes: 9d7693118055 ("net/mlx4_en: Avoid unregister_netdev at shutdown flow")
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reported-by: Steve Wise <swise@opengridcomputing.com>
Cc: Jiri Pirko <jiri@mellanox.com>
Export tc_tunnel_key so it can be used from user space.
Signed-off-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Amir Vadai <amir@vadai.me>
drm_atomic_crtc_needs_modeset() doesn't change the passed in
crtc state, so pass it as const.
Link: http://patchwork.freedesktop.org/patch/msgid/1480009622-28127-1-git-send-email-ville.syrjala@linux.intel.com
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
start is being used as both a macro parameter and as a member of struct
drm_mm_node (node->start). This causes a conflict as cpp then tries to
replace node->start with the passed in string for "start". Work just
fine so long as you also happened to using local variables called start!
Fixes: 522e85dd8677 ("drm: Define drm_mm_for_each_node_in_range()")
Reviewed-by: Christian König <christian.koenig@amd.com>.
[danvet: Fixup kerneldoc.]
Link: http://patchwork.freedesktop.org/patch/msgid/20161127111623.11124-1-chris@chris-wilson.co.uk
Pull IOMMU fixes from David Woodhouse:
"Two minor fixes.
The first fixes the assignment of SR-IOV virtual functions to the
correct IOMMU unit, and the second fixes the excessively large (and
physically contiguous) PASID tables used with SVM"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: Fix PASID table allocation
iommu/vt-d: Fix IOMMU lookup for SR-IOV Virtual Functions
1) Fix leak in fsl/fman driver, from Dan Carpenter.
2) Call flow dissector initcall earlier than any networking driver can
register and start to use it, from Eric Dumazet.
3) Some dup header fixes from Geliang Tang.
4) TIPC link monitoring compat fix from Jon Paul Maloy.
5) Link changes require EEE re-negotiation in bcm_sf2 driver, from
Florian Fainelli.
6) Fix bogus handle ID passed into tfilter_notify_chain(), from Roman
Mashak.
7) Fix dump size calculation in rtnl_calcit(), from Zhang Shengju.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits)
tipc: resolve connection flow control compatibility problem
mvpp2: use correct size for memset
net/mlx5: drop duplicate header delay.h
net: ieee802154: drop duplicate header delay.h
ibmvnic: drop duplicate header seq_file.h
fsl/fman: fix a leak in tgec_free()
net: ethtool: don't require CAP_NET_ADMIN for ETHTOOL_GLINKSETTINGS
tipc: improve sanity check for received domain records
tipc: fix compatibility bug in link monitoring
net: ethernet: mvneta: Remove IFF_UNICAST_FLT which is not implemented
dwc_eth_qos: drop duplicate headers
net sched filters: fix filter handle ID in tfilter_notify_chain()
net: dsa: bcm_sf2: Ensure we re-negotiate EEE during after link change
bnxt: do not busy-poll when link is down
udplite: call proper backlog handlers
ipv6: bump genid when the IFA_F_TENTATIVE flag is clear
net/mlx4_en: Free netdev resources under state lock
net: revert "net: l2tp: Treat NET_XMIT_CN as success in l2tp_eth_dev_xmit"
rtnetlink: fix the wrong minimal dump size getting from rtnl_calcit()
bnxt_en: Fix a VXLAN vs GENEVE issue
The same file in libdrm is, as is the tradition with the rest of libdrm,
etc, using an MIT license. To avoid complications in the future with
sync'ing the uapi header to libdrm, lets fix the license mismatch now
before there are any non-trivial commits from someone other than myself.
Cc: Gabriel Laskar <gabriel@lse.epita.fr>
Cc: Mikko Rapeli <mikko.rapeli@iki.fi>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Acked-by: Emil Velikov <emil.l.velikov@gmail.com>
Silences
./include/drm/drm_drv.h:295: warning: Incorrect use of kernel-doc format
Link: http://patchwork.freedesktop.org/patch/msgid/20161125123427.15188-1-chris@chris-wilson.co.uk
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Johan Hedberg says:
pull request: bluetooth 2016-11-23
Sorry about the late pull request for 4.9, but we have one more
important Bluetooth patch that should make it to the release. It fixes
connection creation for Bluetooth LE controllers that do not have a
public address (only a random one).
Please let me know if there are any issues pulling. Thanks.
Stas Nichiporovich reports oops in nf_nat_bysource_cmp(), trying to
access nf_conn struct at address 0xffffffffffffff50.
This is the result of fetching a null rhash list (struct embedded at
offset 176; 0 - 176 gets us ...fff50).
The problem is that conntrack entries are allocated from a
SLAB_DESTROY_BY_RCU cache, i.e. entries can be free'd and reused
on another cpu while nf nat bysource hash access the same conntrack entry.
Freeing is fine (we hold rcu read lock); zeroing rhlist_head isn't.
-> Move the rhlist struct outside of the memset()-inited area.
Fixes: 7c9664351980aaa6a ("netfilter: move nat hlist_head to nf_conn")
Reported-by: Stas Nichiporovich <stasn77@gmail.com>
As Liping Zhang reports, after commit a8b1e36d0d1d ("netfilter: nft_dynset:
fix element timeout for HZ != 1000"), priv->timeout was stored in jiffies,
while set->timeout was stored in milliseconds. This is inconsistent and
incorrect.
Firstly, we already call msecs_to_jiffies in nft_set_elem_init, so
priv->timeout will be converted to jiffies twice.
Secondly, if the user did not specify the NFTA_DYNSET_TIMEOUT attr,
set->timeout will be used, but we forget to call msecs_to_jiffies
when do update elements.
Fix this by using jiffies internally for traditional sets and doing the
conversions to/from msec when interacting with userspace - as dynset
already does.
This is preferable to doing the conversions, when elements are inserted or
updated, because this can happen very frequently on busy dynsets.
Fixes: a8b1e36d0d1d ("netfilter: nft_dynset: fix element timeout for HZ != 1000")
Reported-by: Liping Zhang <zlpnobody@gmail.com>
Signed-off-by: Anders K. Pedersen <akp@cohaesio.com>
Acked-by: Liping Zhang <zlpnobody@gmail.com>
I got offlist bug report about failing connections and high cpu usage.
This happens because we hit 'elasticity' checks in rhashtable that
refuses bucket list exceeding 16 entries.
The nat bysrc hash unfortunately needs to insert distinct objects that
share same key and are identical (have same source tuple), this cannot
be avoided.
Switch to the rhlist interface which is designed for this.
The nulls_base is removed here, I don't think its needed:
A (unlikely) false positive results in unneeded port clash resolution,
a false negative results in packet drop during conntrack confirmation,
when we try to insert the duplicate into main conntrack hash table.
Tested by adding multiple ip addresses to host, then adding
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
... and then creating multiple connections, from same source port but
different addresses:
for i in $(seq 2000 2032);do nc -p 1234 192.168.7.1 $i > /dev/null & done
(all of these then get hashed to same bysource slot)
Then, to test that nat conflict resultion is working:
nc -s 10.0.0.1 -p 1234 192.168.7.1 2000
nc -s 10.0.0.2 -p 1234 192.168.7.1 2000
tcp .. src=10.0.0.1 dst=192.168.7.1 sport=1234 dport=2000 src=192.168.7.1 dst=192.168.7.10 sport=2000 dport=1024 [ASSURED]
tcp .. src=10.0.0.2 dst=192.168.7.1 sport=1234 dport=2000 src=192.168.7.1 dst=192.168.7.10 sport=2000 dport=1025 [ASSURED]
tcp .. src=192.168.7.10 dst=192.168.7.1 sport=1234 dport=2000 src=192.168.7.1 dst=192.168.7.10 sport=2000 dport=1234 [ASSURED]
tcp .. src=192.168.7.10 dst=192.168.7.1 sport=1234 dport=2001 src=192.168.7.1 dst=192.168.7.10 sport=2001 dport=1234 [ASSURED]
-> nat altered source ports to 1024 and 1025, respectively.
This can also be confirmed on destination host which shows
ESTAB 0 0 192.168.7.1:2000 192.168.7.10:1024
ESTAB 0 0 192.168.7.1:2000 192.168.7.10:1025
ESTAB 0 0 192.168.7.1:2000 192.168.7.10:1234
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Fixes: 870190a9ec907 ("netfilter: nat: convert nat bysrc hash to rhashtable")
Some clients would like to iterate over every node within a certain
range. Make a nice little macro for them to hide the mixing of the
rbtree search and linear walk.
v2: Blurb
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161123141118.23876-1-chris@chris-wilson.co.uk
Fix kernel-doc warning in <linux/netdevice.h> (missing ':'):
..//include/linux/netdevice.h:1904: warning: No description found for parameter 'prio_tc_map[TC_BITMASK + 1]'
