This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot time as
possible, hoping to capitalize on any possible variation in CPU operation
(due to runtime data differences, hardware differences, SMP ordering,
thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example for
how to manipulate kernel code using the gcc plugin internals.
The need for very-early boot entropy tends to be very architecture or
system design specific, so this plugin is more suited for those sorts
of special cases. The existing kernel RNG already attempts to extract
entropy from reliable runtime variation, but this plugin takes the idea to
a logical extreme by permuting a global variable based on any variation
in code execution (e.g. a different value (and permutation function)
is used to permute the global based on loop count, case statement,
if/then/else branching, etc).
To do this, the plugin starts by inserting a local variable in every
marked function. The plugin then adds logic so that the value of this
variable is modified by randomly chosen operations (add, xor and rol) and
random values (gcc generates separate static values for each location at
compile time and also injects the stack pointer at runtime). The resulting
value depends on the control flow path (e.g., loops and branches taken).
Before the function returns, the plugin mixes this local variable into
the latent_entropy global variable. The value of this global variable
is added to the kernel entropy pool in do_one_initcall() and _do_fork(),
though it does not credit any bytes of entropy to the pool; the contents
of the global are just used to mix the pool.
Additionally, the plugin can pre-initialize arrays with build-time
random contents, so that two different kernel builds running on identical
hardware will not have the same starting values.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message and code comments]
Pull networking fixes from David Miller:
1) Fix wrong TCP checksums on MTU probing when checksum offloading is
disabled, from Douglas Caetano dos Santos.
2) Fix qdisc backlog updates in qfq and sfb schedulers, from Cong Wang.
3) Route lookup flow key protocol value is wrong in ip6gre_xmit_other(),
fix from Lance Richardson.
4) Scheduling while atomic in multicast routing code of ipv4 and ipv6,
fix from Nikolay Aleksandrov.
5) Fix packet alignment in fec driver, from Eric Nelson.
6) Fix perf regression in sctp due to struct layout and cache misses,
from Xin Long.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
sctp: fix the issue sctp_diag uses lock_sock in rcu_read_lock
sctp: change to check peer prsctp_capable when using prsctp polices
sctp: remove prsctp_param from sctp_chunk
sctp: move sent_count to the memory hole in sctp_chunk
tg3: Avoid NULL pointer dereference in tg3_io_error_detected()
act_ife: Fix false encoding
act_ife: Fix external mac header on encode
VSOCK: Don't dec ack backlog twice for rejected connections
Revert "net: ethernet: bcmgenet: use phydev from struct net_device"
net: fec: align IP header in hardware
net: fec: remove QUIRK_HAS_RACC from i.mx27
net: fec: remove QUIRK_HAS_RACC from i.mx25
ipmr, ip6mr: fix scheduling while atomic and a deadlock with ipmr_get_route
ip6_gre: fix flowi6_proto value in ip6gre_xmit_other()
tcp: fix a compile error in DBGUNDO()
tcp: fix wrong checksum calculation on MTU probing
sch_sfb: keep backlog updated with qlen
sch_qfq: keep backlog updated with qlen
can: dev: fix deadlock reported after bus-off
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fix from James Bottomley:
"One final fix before 4.8.
There was a memory leak triggered by turning scsi mq off due to the
fact that we assume on host release that the already running hosts
weren't mq based because that's the state of the global flag (even
though they were).
Fix it by tracking this on a per host host basis"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: Avoid that toggling use_blk_mq triggers a memory leak
This fixes commit d76eebfa175e ("include/linux/property.h: fix build
issues with gcc-4.4.4").
With that commit we get the following compile error when using the
PROPERTY_ENTRY_INTEGER_ARRAY macro.
include/linux/property.h:201:39: error: `u32_data' undeclared (first
use in this function)
PROPERTY_ENTRY_INTEGER_ARRAY(_name_, u32, _val_)
include/linux/property.h:193:17: note: in definition of macro
`PROPERTY_ENTRY_INTEGER_ARRAY'
{ .pointer = { _type_##_data = _val_ } }, \
This needs a '.' to reference the union member. It seems this was just
overlooked here since it is done correctly in similar constructs in
other parts of the original commit.
This fix is in preparation of upcoming commits that will use this macro.
Fixes: commit d76eebfa175e ("include/linux/property.h: fix build issues with gcc-4.4.4")
Link: http://lkml.kernel.org/r/2de3b929290d88a723ed829a3e3cbd02044714df.1475114627.git.johnyoun@synopsys.com
Signed-off-by: John Youn <johnyoun@synopsys.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
replace_page_cache_page()
Antonio reports the following crash when using fuse under memory pressure:
kernel BUG at /build/linux-a2WvEb/linux-4.4.0/mm/workingset.c:346!
invalid opcode: 0000 [#1] SMP
Modules linked in: all of them
CPU: 2 PID: 63 Comm: kswapd0 Not tainted 4.4.0-36-generic #55-Ubuntu
Hardware name: System manufacturer System Product Name/P8H67-M PRO, BIOS 3904 04/27/2013
task: ffff88040cae6040 ti: ffff880407488000 task.ti: ffff880407488000
RIP: shadow_lru_isolate+0x181/0x190
Call Trace:
__list_lru_walk_one.isra.3+0x8f/0x130
list_lru_walk_one+0x23/0x30
scan_shadow_nodes+0x34/0x50
shrink_slab.part.40+0x1ed/0x3d0
shrink_zone+0x2ca/0x2e0
kswapd+0x51e/0x990
kthread+0xd8/0xf0
ret_from_fork+0x3f/0x70
which corresponds to the following sanity check in the shadow node
tracking:
BUG_ON(node->count & RADIX_TREE_COUNT_MASK);
The workingset code tracks radix tree nodes that exclusively contain
shadow entries of evicted pages in them, and this (somewhat obscure)
line checks whether there are real pages left that would interfere with
reclaim of the radix tree node under memory pressure.
While discussing ways how fuse might sneak pages into the radix tree
past the workingset code, Miklos pointed to replace_page_cache_page(),
and indeed there is a problem there: it properly accounts for the old
page being removed - __delete_from_page_cache() does that - but then
does a raw raw radix_tree_insert(), not accounting for the replacement
page. Eventually the page count bits in node->count underflow while
leaving the node incorrectly linked to the shadow node LRU.
To address this, make sure replace_page_cache_page() uses the tracked
page insertion code, page_cache_tree_insert(). This fixes the page
accounting and makes sure page-containing nodes are properly unlinked
from the shadow node LRU again.
Also, make the sanity checks a bit less obscure by using the helpers for
checking the number of pages and shadows in a radix tree node.
Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check")
Link: http://lkml.kernel.org/r/20160919155822.29498-1-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Antonio SJ Musumeci <trapexit@spawn.link>
Debugged-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: <stable@vger.kernel.org> [3.15+]
Now sctp uses chunk->prsctp_param to save the prsctp param for all the
prsctp polices, we didn't need to introduce prsctp_param to sctp_chunk.
We can just use chunk->sinfo.sinfo_timetolive for RTX and BUF polices,
and reuse msg->expires_at for TTL policy, as the prsctp polices and old
expires policy are mutual exclusive.
This patch is to remove prsctp_param from sctp_chunk, and reuse msg's
expires_at for TTL and chunk's sinfo.sinfo_timetolive for RTX and BUF
polices.
Note that sctp can't use chunk's sinfo.sinfo_timetolive for TTL policy,
as it needs a u64 variables to save the expires_at time.
This one also fixes the "netperf-Throughput_Mbps -37.2% regression"
issue.
Fixes: a6c2f792873a ("sctp: implement prsctp TTL policy")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Now pahole sctp_chunk, it has 2 memory holes:
struct sctp_chunk {
struct list_head list;
atomic_t refcnt;
/* XXX 4 bytes hole, try to pack */
long unsigned int prsctp_param;
int sent_count;
This patch is to move up sent_count to fill the 1st one and eliminate
the 2nd one.
It's not just another struct compaction, it also fixes the "netperf-
Throughput_Mbps -37.2% regression" issue when overloading the CPU.
When CONFIG_DMA_API_DEBUG is enabled we need to preserve unmapping address
even if "unmap" is a no-op for our architecutre because we need
debug_dma_unmap_page() to correctly cleanup all of the debug bookkeeping.
Failing to do so results in a false positive warnings about previously
mapped areas never being unmapped.
Link: http://lkml.kernel.org/r/1474387125-3713-1-git-send-email-andrew.smirnov@gmail.com
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Zhen Lei <thunder.leizhen@huawei.com>
Cc: "Luis R. Rodriguez" <mcgrof@suse.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Geliang Tang <geliangtang@163.com>
This patch avoids that the following memory leak is triggered if
use_blk_mq is disabled after a SCSI host has been allocated by the
ib_srp driver and before the same SCSI host is freed:
unreferenced object 0xffff8803a168c568 (size 256):
backtrace:
[<ffffffff81620c95>] kmemleak_alloc+0x45/0xa0
[<ffffffff811bb104>] __kmalloc_node+0x1e4/0x400
[<ffffffff81309fe4>] blk_mq_alloc_tag_set+0xb4/0x230
[<ffffffff814731b7>] scsi_mq_setup_tags+0xc7/0xd0
[<ffffffff81469c26>] scsi_add_host_with_dma+0x216/0x2d0
[<ffffffffa064bef5>] srp_create_target+0xe55/0x13d0 [ib_srp]
[<ffffffff8143ce23>] dev_attr_store+0x13/0x20
[<ffffffff8125f030>] sysfs_kf_write+0x40/0x50
[<ffffffff8125e397>] kernfs_fop_write+0x137/0x1c0
[<ffffffff811d8c13>] __vfs_write+0x23/0x140
[<ffffffff811d92e0>] vfs_write+0xb0/0x190
[<ffffffff811da5b4>] SyS_write+0x44/0xa0
[<ffffffff8162c8a5>] entry_SYSCALL_64_fastpath+0x18/0xa8
Fixes: 9aa9cc4221f5 ("scsi: remove the disable_blk_mq host flag")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Since the commit below the ipmr/ip6mr rtnl_unicast() code uses the portid
instead of the previous dst_pid which was copied from in_skb's portid.
Since the skb is new the portid is 0 at that point so the packets are sent
to the kernel and we get scheduling while atomic or a deadlock (depending
on where it happens) by trying to acquire rtnl two times.
Also since this is RTM_GETROUTE, it can be triggered by a normal user.
Here's the sleeping while atomic trace:
[ 7858.212557] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620
[ 7858.212748] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper/0
[ 7858.212881] 2 locks held by swapper/0/0:
[ 7858.213013] #0: (((&mrt->ipmr_expire_timer))){+.-...}, at: [<ffffffff810fbbf5>] call_timer_fn+0x5/0x350
[ 7858.213422] #1: (mfc_unres_lock){+.....}, at: [<ffffffff8161e005>] ipmr_expire_process+0x25/0x130
[ 7858.213807] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.8.0-rc7+ #179
[ 7858.213934] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 7858.214108] 0000000000000000 ffff88005b403c50 ffffffff813a7804 0000000000000000
[ 7858.214412] ffffffff81a1338e ffff88005b403c78 ffffffff810a4a72 ffffffff81a1338e
[ 7858.214716] 000000000000026c 0000000000000000 ffff88005b403ca8 ffffffff810a4b9f
[ 7858.215251] Call Trace:
[ 7858.215412] <IRQ> [<ffffffff813a7804>] dump_stack+0x85/0xc1
[ 7858.215662] [<ffffffff810a4a72>] ___might_sleep+0x192/0x250
[ 7858.215868] [<ffffffff810a4b9f>] __might_sleep+0x6f/0x100
[ 7858.216072] [<ffffffff8165bea3>] mutex_lock_nested+0x33/0x4d0
[ 7858.216279] [<ffffffff815a7a5f>] ? netlink_lookup+0x25f/0x460
[ 7858.216487] [<ffffffff8157474b>] rtnetlink_rcv+0x1b/0x40
[ 7858.216687] [<ffffffff815a9a0c>] netlink_unicast+0x19c/0x260
[ 7858.216900] [<ffffffff81573c70>] rtnl_unicast+0x20/0x30
[ 7858.217128] [<ffffffff8161cd39>] ipmr_destroy_unres+0xa9/0xf0
[ 7858.217351] [<ffffffff8161e06f>] ipmr_expire_process+0x8f/0x130
[ 7858.217581] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217785] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217990] [<ffffffff810fbc95>] call_timer_fn+0xa5/0x350
[ 7858.218192] [<ffffffff810fbbf5>] ? call_timer_fn+0x5/0x350
[ 7858.218415] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.218656] [<ffffffff810fde10>] run_timer_softirq+0x260/0x640
[ 7858.218865] [<ffffffff8166379b>] ? __do_softirq+0xbb/0x54f
[ 7858.219068] [<ffffffff816637c8>] __do_softirq+0xe8/0x54f
[ 7858.219269] [<ffffffff8107a948>] irq_exit+0xb8/0xc0
[ 7858.219463] [<ffffffff81663452>] smp_apic_timer_interrupt+0x42/0x50
[ 7858.219678] [<ffffffff816625bc>] apic_timer_interrupt+0x8c/0xa0
[ 7858.219897] <EOI> [<ffffffff81055f16>] ? native_safe_halt+0x6/0x10
[ 7858.220165] [<ffffffff810d64dd>] ? trace_hardirqs_on+0xd/0x10
[ 7858.220373] [<ffffffff810298e3>] default_idle+0x23/0x190
[ 7858.220574] [<ffffffff8102a20f>] arch_cpu_idle+0xf/0x20
[ 7858.220790] [<ffffffff810c9f8c>] default_idle_call+0x4c/0x60
[ 7858.221016] [<ffffffff810ca33b>] cpu_startup_entry+0x39b/0x4d0
[ 7858.221257] [<ffffffff8164f995>] rest_init+0x135/0x140
[ 7858.221469] [<ffffffff81f83014>] start_kernel+0x50e/0x51b
[ 7858.221670] [<ffffffff81f82120>] ? early_idt_handler_array+0x120/0x120
[ 7858.221894] [<ffffffff81f8243f>] x86_64_start_reservations+0x2a/0x2c
[ 7858.222113] [<ffffffff81f8257c>] x86_64_start_kernel+0x13b/0x14a
Fixes: 2942e9005056 ("[RTNETLINK]: Use rtnl_unicast() for rtnetlink unicasts")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
When building XFS with -Werror, it now fails with:
include/linux/pagemap.h: In function 'fault_in_multipages_readable':
include/linux/pagemap.h:602:16: error: variable 'c' set but not used [-Werror=unused-but-set-variable]
volatile char c;
This is a regression caused by commit e23d4159b109 ("fix
fault_in_multipages_...() on architectures with no-op access_ok()").
Fix it by re-adding the "(void)c" trick taht was previously used to make
the compiler think the variable is used.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mkl/linux-can
Marc Kleine-Budde says:
pull-request: can 2016-09-22
this is a pull request of one patch for the upcoming linux-4.8 release.
The patch by Sergei Miroshnichenko fixes a potential deadlock in the generic
CAN device code that cann occour after a bus-off.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- several fixes for new drivers added for Kernel 4.8 addition (cec
core, pulse8 cec driver and Mediatek vcodec)
- a regression fix for cx23885 and saa7134 drivers
- an important fix for rcar-fcp, making rcar_fcp_enable() return 0 on
success
* tag 'media/v4.8-7' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (25 commits)
[media] cx23885/saa7134: assign q->dev to the PCI device
[media] rcar-fcp: Make sure rcar_fcp_enable() returns 0 on success
[media] cec: fix ioctl return code when not registered
[media] cec: don't Feature Abort broadcast msgs when unregistered
[media] vcodec:mediatek: Refine VP8 encoder driver
[media] vcodec:mediatek: Refine H264 encoder driver
[media] vcodec:mediatek: change H264 profile default to profile high
[media] vcodec:mediatek: Add timestamp and timecode copy for V4L2 Encoder
[media] vcodec:mediatek: Fix visible_height larger than coded_height issue in s_fmt_out
[media] vcodec:mediatek: Fix fops_vcodec_release flow for V4L2 Encoder
[media] vcodec:mediatek:code refine for v4l2 Encoder driver
[media] cec-funcs.h: add missing vendor-specific messages
[media] cec-edid: check for IEEE identifier
[media] pulse8-cec: fix error handling
[media] pulse8-cec: set correct Signal Free Time
[media] mtk-vcodec: add HAS_DMA dependency
[media] cec: ignore messages when log_addr_mask == 0
[media] cec: add item to TODO
[media] cec: set unclaimed addresses to CEC_LOG_ADDR_INVALID
[media] cec: add CEC_LOG_ADDRS_FL_ALLOW_UNREG_FALLBACK flag
"Mostly small bits scattered all over the place, which is usually how
things go this late in the -rc series.
1) Proper driver init device resets in bnx2, from Baoquan He.
2) Fix accounting overflow in __tcp_retransmit_skb(),
sk_forward_alloc, and ip_idents_reserve, from Eric Dumazet.
3) Fix crash in bna driver ethtool stats handling, from Ivan Vecera.
4) Missing check of skb_linearize() return value in mac80211, from
Johannes Berg.
5) Endianness fix in nf_table_trace dumps, from Liping Zhang.
6) SSN comparison fix in SCTP, from Marcelo Ricardo Leitner.
7) Update DSA and b44 MAINTAINERS entries.
8) Make input path of vti6 driver work again, from Nicolas Dichtel.
9) Off-by-one in mlx4, from Sebastian Ott.
10) Fix fallback route lookup handling in ipv6, from Vincent Bernat.
11) Fix stack corruption on probe in qed driver, from Yuval Mintz.
12) PHY init fixes in r8152 from Hayes Wang.
13) Missing SKB free in irda_accept error path, from Phil Turnbull"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
tcp: properly account Fast Open SYN-ACK retrans
tcp: fix under-accounting retransmit SNMP counters
MAINTAINERS: Update b44 maintainer.
net: get rid of an signed integer overflow in ip_idents_reserve()
net/mlx4_core: Fix to clean devlink resources
net: can: ifi: Configure transmitter delay
vti6: fix input path
ipmr, ip6mr: return lastuse relative to now
r8152: disable ALDPS and EEE before setting PHY
r8152: remove r8153_enable_eee
r8152: move PHY settings to hw_phy_cfg
r8152: move enabling PHY
r8152: move some functions
cxgb4/cxgb4vf: Allocate more queues for 25G and 100G adapter
qed: Fix stack corruption on probe
MAINTAINERS: Add an entry for the core network DSA code
net: ipv6: fallback to full lookup if table lookup is unsuitable
net/mlx5: E-Switch, Handle mode change failures
net/mlx5: E-Switch, Fix error flow in the SRIOV e-switch init code
net/mlx5: Fix flow counter bulk command out mailbox allocation
A timer was used to restart after the bus-off state, leading to a
relatively large can_restart() executed in an interrupt context,
which in turn sets up pinctrl. When this happens during system boot,
there is a high probability of grabbing the pinctrl_list_mutex,
which is locked already by the probe() of other device, making the
kernel suspect a deadlock condition [1].
To resolve this issue, the restart_timer is replaced by a delayed
work.
[1] https://github.com/victronenergy/venus/issues/24
Signed-off-by: Sergei Miroshnichenko <sergeimir@emcraft.com>
Cc: linux-stable <stable@vger.kernel.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
pull request (net): ipsec 2016-09-21
1) Propagate errors on security context allocation.
From Mathias Krause.
2) Fix inbound policy checks for inter address family tunnels.
From Thomas Zeitlhofer.
3) Fix an old memory leak on aead algorithm usage.
From Ilan Tayari.
4) A recent patch fixed a possible NULL pointer dereference
but broke the vti6 input path.
Fix from Nicolas Dichtel.
Since commit 1625f4529957, vti6 is broken, all input packets are dropped
(LINUX_MIB_XFRMINNOSTATES is incremented).
XFRM_TUNNEL_SKB_CB(skb)->tunnel.ip6 is set by vti6_rcv() before calling
xfrm6_rcv()/xfrm6_rcv_spi(), thus we cannot set to NULL that value in
xfrm6_rcv_spi().
A new function xfrm6_rcv_tnl() that enables to pass a value to
xfrm6_rcv_spi() is added, so that xfrm6_rcv() is not touched (this function
is used in several handlers).
CC: Alexey Kodanev <alexey.kodanev@oracle.com>
Fixes: 1625f4529957 ("net/xfrm_input: fix possible NULL deref of tunnel.ip6->parms.i_key")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Switching iov_iter fault-in to multipages variants has exposed an old
bug in underlying fault_in_multipages_...(); they break if the range
passed to them wraps around. Normally access_ok() done by callers will
prevent such (and it's a guaranteed EFAULT - ERR_PTR() values fall into
such a range and they should not point to any valid objects).
However, on architectures where userland and kernel live in different
MMU contexts (e.g. s390) access_ok() is a no-op and on those a range
with a wraparound can reach fault_in_multipages_...().
Since any wraparound means EFAULT there, the fix is trivial - turn
those
while (uaddr <= end)
into
if (unlikely(uaddr > end))
return -EFAULT;
do
while (uaddr <= end);
Reported-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Cc: stable@vger.kernel.org # v3.5+
fanotify_get_response() calls fsnotify_remove_event() when it finds that
group is being released from fanotify_release() (bypass_perm is set).
However the event it removes need not be only in the group's notification
queue but it can have already moved to access_list (userspace read the
event before closing the fanotify instance fd) which is protected by a
different lock. Thus when fsnotify_remove_event() races with
fanotify_release() operating on access_list, the list can get corrupted.
Fix the problem by moving all the logic removing permission events from
the lists to one place - fanotify_release().
Fixes: 5838d4442bd5 ("fanotify: fix double free of pending permission events")
Link: http://lkml.kernel.org/r/1473797711-14111-3-git-send-email-jack@suse.cz
Reported-by: Miklos Szeredi <mszeredi@redhat.com>
Tested-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Miklos Szeredi <mszeredi@redhat.com>
Implement a function that can be called when a group is being shutdown
to stop queueing new events to the group. Fanotify will use this.
Link: http://lkml.kernel.org/r/1473797711-14111-2-git-send-email-jack@suse.cz
Pull SMP build fixlet from Thomas Gleixner:
"Add a missing include in cpuhotplug.h"
* 'smp-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
cpu/hotplug: Include linux/types.h in linux/cpuhotplug.h
Pull irq fixes from Thomas Gleixner:
"Two patches from Boris which address a potential deadlock in the atmel
irq chip driver"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/atmel-aic: Fix potential deadlock in ->xlate()
genirq: Provide irq_gc_{lock_irqsave,unlock_irqrestore}() helpers
... by turning it into what used to be multipages counterpart
This function actually operates on u32 yet its paramteres were declared
as u16, causing integer truncation upon calling.
Note in patch context that ADDIP_SERIAL_SIGN_BIT is already 32 bits.
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
A malicious TCP receiver, sending SACK, can force the sender to split
skbs in write queue and increase its memory usage.
Then, when socket is closed and its write queue purged, we might
overflow sk_forward_alloc (It becomes negative)
sk_mem_reclaim() does nothing in this case, and more than 2GB
are leaked from TCP perspective (tcp_memory_allocated is not changed)
Then warnings trigger from inet_sock_destruct() and
sk_stream_kill_queues() seeing a not zero sk_forward_alloc
All TCP stack can be stuck because TCP is under memory pressure.
A simple fix is to preemptively reclaim from sk_mem_uncharge().
This makes sure a socket wont have more than 2 MB forward allocated,
after burst and idle period.
Pull uaccess fixes from Al Viro:
"Fixes for broken uaccess primitives - mostly lack of proper zeroing
in copy_from_user()/get_user()/__get_user(), but for several
architectures there's more (broken clear_user() on frv and
strncpy_from_user() on hexagon)"
* 'uaccess-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (28 commits)
avr32: fix copy_from_user()
microblaze: fix __get_user()
microblaze: fix copy_from_user()
m32r: fix __get_user()
blackfin: fix copy_from_user()
sparc32: fix copy_from_user()
sh: fix copy_from_user()
sh64: failing __get_user() should zero
score: fix copy_from_user() and friends
score: fix __get_user/get_user
s390: get_user() should zero on failure
ppc32: fix copy_from_user()
parisc: fix copy_from_user()
openrisc: fix copy_from_user()
nios2: fix __get_user()
nios2: copy_from_user() should zero the tail of destination
mn10300: copy_from_user() should zero on access_ok() failure...
mn10300: failing __get_user() and get_user() should zero
mips: copy_from_user() must zero the destination on access_ok() failure
ARC: uaccess: get_user to zero out dest in cause of fault
The linux/cpuhotplug.h header makes use of the bool type, but wasn't
including linux/types.h to ensure that type has been defined. Fix this
by including linux/types.h in preparation for including
linux/cpuhotplug.h in a file that doesn't do so already.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: Richard Cochran <rcochran@linutronix.de>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Link: http://lkml.kernel.org/r/20160914100027.20945-1-paul.burton@imgtec.com
both for access_ok() failures and for faults halfway through
Pull locking fix from Ingo Molnar:
"Another lockless_dereference() Sparse fix"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/barriers: Don't use sizeof(void) in lockless_dereference()
Pull EFI fixes from Ingo Molnar:
"This contains a Xen fix, an arm64 fix and a race condition /
robustization set of fixes related to ExitBootServices() usage and
boundary conditions"
* 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/efi: Use efi_exit_boot_services()
efi/libstub: Use efi_exit_boot_services() in FDT
efi/libstub: Introduce ExitBootServices helper
efi/libstub: Allocate headspace in efi_get_memory_map()
efi: Fix handling error value in fdt_find_uefi_params
efi: Make for_each_efi_memory_desc_in_map() cope with running on Xen
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Endianess fix for the new nf_tables netlink trace infrastructure,
NFTA_TRACE_POLICY endianess was not correct, patch from Liping Zhang.
2) Fix broken re-route after userspace queueing in nf_tables route
chain. This patch is large but it is simple since it is just getting
this code in sync with iptable_mangle. Also from Liping.
3) NAT mangling via ctnetlink lies to userspace when nf_nat_setup_info()
fails to setup the NAT conntrack extension. This problem has been
there since the beginning, but it can now show up after rhashtable
conversion.
4) Fix possible NULL pointer dereference due to failures in allocating
the synproxy and seqadj conntrack extensions, from Gao feng.
Some irqchip drivers need to take the generic chip lock outside of the
irq context.
Provide the irq_gc_{lock_irqsave,unlock_irqrestore}() helpers to allow
one to disable irqs while entering a critical section protected by
gc->lock.
Note that we do not provide optimized version of these helpers for !SMP,
because they are not called from the hot-path.
[ tglx: Added a comment when these helpers should be [not] used ]
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Link: http://lkml.kernel.org/r/1473775109-4192-1-git-send-email-boris.brezillon@free-electrons.com
When memory is exhausted, nfct_seqadj_ext_add may fail to add the
synproxy and seqadj extensions. The function nf_ct_seqadj_init doesn't
check if get valid seqadj pointer by the nfct_seqadj.
Now drop the packet directly when fail to add seqadj extension to
avoid dereference NULL pointer in nf_ct_seqadj_init from
init_conntrack().
Signed-off-by: Gao Feng <fgao@ikuai8.com>
"Mostly small sets of driver fixes scattered all over the place.
1) Mediatek driver fixes from Sean Wang. Forward port not written
correctly during TX map, missed handling of EPROBE_DEFER, and
mistaken use of put_page() instead of skb_free_frag().
2) Fix socket double-free in KCM code, from WANG Cong.
3) QED driver fixes from Sudarsana Reddy Kalluru, including a fix for
using the dcbx buffers before initializing them.
4) Mellanox Switch driver fixes from Jiri Pirko, including a fix for
double fib removals and an error handling fix in
mlxsw_sp_module_init().
5) Fix kernel panic when enabling LLDP in i40e driver, from Dave
Ertman.
6) Fix padding of TSO packets in thunderx driver, from Sunil Goutham.
7) TCP's rcv_wup not initialized properly when using fastopen, from
Neal Cardwell.
8) Don't use uninitialized flow keys in flow dissector, from Gao
Feng.
9) Use after free in l2tp module unload, from Sabrina Dubroca.
10) Fix interrupt registry ordering issues in smsc911x driver, from
Jeremy Linton.
11) Fix crashes in bonding having to do with enslaving and rx_handler,
from Mahesh Bandewar.
12) AF_UNIX deadlock fixes from Linus.
13) In mlx5 driver, don't read skb->xmit_mode after it might have been
freed from the TX reclaim path. From Tariq Toukan.
14) Fix a bug from 2015 in TCP Yeah where the congestion window does
not increase, from Artem Germanov.
15) Don't pad frames on receive in NFP driver, from Jakub Kicinski.
16) Fix chunk fragmenting in SCTP wrt. GSO, from Marcelo Ricardo
Leitner.
17) Fix deletion of VRF routes, from Mark Tomlinson.
18) Fix device refcount leak when DAD fails in ipv6, from Wei Yongjun"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits)
net/mlx4_en: Fix panic on xmit while port is down
net/mlx4_en: Fixes for DCBX
net/mlx4_en: Fix the return value of mlx4_en_dcbnl_set_state()
net/mlx4_en: Fix the return value of mlx4_en_dcbnl_set_all()
net: ethernet: renesas: sh_eth: add POST registers for rz
drivers: net: phy: mdio-xgene: Add hardware dependency
dwc_eth_qos: do not register semi-initialized device
sctp: identify chunks that need to be fragmented at IP level
mlxsw: spectrum: Set port type before setting its address
mlxsw: spectrum_router: Fix error path in mlxsw_sp_router_init
nfp: don't pad frames on receive
nfp: drop support for old firmware ABIs
nfp: remove linux/version.h includes
tcp: cwnd does not increase in TCP YeAH
net/mlx5e: Fix parsing of vlan packets when updating lro header
net/mlx5e: Fix global PFC counters replication
net/mlx5e: Prevent casting overflow
net/mlx5e: Move an_disable_cap bit to a new position
net/mlx5e: Fix xmit_more counter race issue
tcp: fastopen: avoid negative sk_forward_alloc
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull fscrypto fixes fromTed Ts'o:
"Fix some brown-paper-bag bugs for fscrypto, including one one which
allows a malicious user to set an encryption policy on an empty
directory which they do not own"
* tag 'for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
fscrypto: require write access to mount to set encryption policy
fscrypto: only allow setting encryption policy on directories
fscrypto: add authorization check for setting encryption policy
Since setting an encryption policy requires writing metadata to the
filesystem, it should be guarded by mnt_want_write/mnt_drop_write.
Otherwise, a user could cause a write to a frozen or readonly
filesystem. This was handled correctly by f2fs but not by ext4. Make
fscrypt_process_policy() handle it rather than relying on the filesystem
to get it right.
Cc: stable@vger.kernel.org # 4.1+; check fs/{ext4,f2fs}
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Acked-by: Jaegeuk Kim <jaegeuk@kernel.org>
... in all cases, including the failing access_ok()
Note that some architectures using asm-generic/uaccess.h have
__copy_from_user() not zeroing the tail on failure halfway
through. This variant works either way.
Previous an_disable_cap position bit31 is deprecated to be use in driver
with newer firmware. New firmware will advertise the same capability
in bit29.
Old capability didn't allow setting more than one protocol for a
specific speed when autoneg is off, while newer firmware will allow
this and it is indicated in the new capability location.
Signed-off-by: Bodong Wang <bodong@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Just for good measure, make sure that check_object_size() is always
inlined too, as already done for copy_*_user() and __copy_*_user().
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
When deleting an IP address from an interface, there is a clean-up of
routes which refer to this local address. However, there was no check to
see that the VRF matched. This meant that deletion wasn't confined to
the VRF it should have been.
To solve this, a new field has been added to fib_info to hold a table
id. When removing fib entries corresponding to a local ip address, this
table id is also used in the comparison.
The table id is populated when the fib_info is created. This was already
done in some places, but not in ip_rt_ioctl(). This has now been fixed.
Fixes: 021dd3b8a142 ("net: Add routes to the table associated with the device")
Acked-by: David Ahern <dsa@cumulusnetworks.com>
Tested-by: David Ahern <dsa@cumulusnetworks.com>
Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
Instead of having each caller of check_object_size() need to remember to
check for a const size parameter, move the check into check_object_size()
itself. This actually matches the original implementation in PaX, though
this commit cleans up the now-redundant builtin_const() calls in the
various architectures.
Pull SCSI fixes from James Bottomley:
"This is really three fixes, but the SES one comes in a bundle of three
(making the replacement API available properly, using it and removing
the non-working one). The SES problem causes an oops on hpsa devices
because they attach virtual disks to the host which aren't SAS
attached (the replacement API ignores them).
The other two fixes are fairly minor: the sense key one means we
actually resolve a newly added sense key and the RDAC device
blacklisting is needed to prevent us annoying the universal XPORT lun
of various RDAC arrays"
scsi: sas: remove is_sas_attached()
scsi: ses: use scsi_is_sas_rphy instead of is_sas_attached
scsi: sas: provide stub implementation for scsi_is_sas_rphy
scsi: blacklist all RDAC devices for BLIST_NO_ULD_ATTACH
scsi: fix upper bounds check of sense key in scsi_sense_key_string()
The spec allows ExitBootServices to fail with EFI_INVALID_PARAMETER if a
race condition has occurred where the EFI has updated the memory map after
the stub grabbed a reference to the map. The spec defines a retry
proceedure with specific requirements to handle this scenario.
This scenario was previously observed on x86 - commit d3768d885c6c ("x86,
efi: retry ExitBootServices() on failure") but the current fix is not spec
compliant and the scenario is now observed on the Qualcomm Technologies
QDF2432 via the FDT stub which does not handle the error and thus causes
boot failures. The user will notice the boot failure as the kernel is not
executed and the system may drop back to a UEFI shell, but will be
unresponsive to input and the system will require a power cycle to recover.
Add a helper to the stub library that correctly adheres to the spec in the
case of EFI_INVALID_PARAMETER from ExitBootServices and can be universally
used across all stub implementations.
Signed-off-by: Jeffrey Hugo <jhugo@codeaurora.org>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
efi_get_memory_map() allocates a buffer to store the memory map that it
retrieves. This buffer may need to be reused by the client after
ExitBootServices() is called, at which point allocations are not longer
permitted. To support this usecase, provide the allocated buffer size back
to the client, and allocate some additional headroom to account for any
reasonable growth in the map that is likely to happen between the call to
efi_get_memory_map() and the client reusing the buffer.
While commit 55f1ea15216 ("efi: Fix for_each_efi_memory_desc_in_map()
for empty memmaps") made an attempt to deal with empty memory maps, it
didn't address the case where the map field never gets set, as is
apparently the case when running under Xen.
Reported-by: <lists@ssl-mail.com>
Tested-by: <lists@ssl-mail.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: <stable@vger.kernel.org> # v4.7+
Signed-off-by: Jan Beulich <jbeulich@suse.com>
[ Guard the loop with a NULL check instead of pointer underflow ]
My previous commit:
112dc0c8069e ("locking/barriers: Suppress sparse warnings in lockless_dereference()")
caused sparse to complain that (in radix-tree.h) we use sizeof(void)
since that rcu_dereference()s a void *.
Really, all we need is to have the expression *p in here somewhere
to make sure p is a pointer type, and sizeof(*p) was the thing that
came to my mind first to make sure that's done without really doing
anything at runtime.
Another thing I had considered was using typeof(*p), but obviously
we can't just declare a typeof(*p) variable either, since that may
end up being void. Declaring a variable as typeof(*p)* gets around
that, and still checks that typeof(*p) is valid, so do that. This
type construction can't be done for _________p1 because that will
actually be used and causes sparse address space warnings, so keep
a separate unused variable for it.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Paul E . McKenney <paulmck@linux.vnet.ibm.com>
Cc: kbuild-all@01.org
Fixes: 112dc0c8069e ("locking/barriers: Suppress sparse warnings in lockless_dereference()")
Link: http://lkml.kernel.org/r/1472192160-4049-1-git-send-email-johannes@sipsolutions.net
Right now we use the 'readlock' both for protecting some of the af_unix
IO path and for making the bind be single-threaded.
The two are independent, but using the same lock makes for a nasty
deadlock due to ordering with regards to filesystem locking. The bind
locking would want to nest outside the VSF pathname locking, but the IO
locking wants to nest inside some of those same locks.
We tried to fix this earlier with commit c845acb324aa ("af_unix: Fix
splice-bind deadlock") which moved the readlock inside the vfs locks,
but that caused problems with overlayfs that will then call back into
filesystem routines that take the lock in the wrong order anyway.
Splitting the locks means that we can go back to having the bind lock be
the outermost lock, and we don't have any deadlocks with lock ordering.
Acked-by: Rainer Weikusat <rweikusat@cyberadapt.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Following few steps will crash kernel -
(a) Create bonding master
> modprobe bonding miimon=50
(b) Create macvlan bridge on eth2
> ip link add link eth2 dev mvl0 address aa:0:0:0:0:01 \
type macvlan
(c) Now try adding eth2 into the bond
> echo +eth2 > /sys/class/net/bond0/bonding/slaves
<crash>
Bonding does lots of things before checking if the device enslaved is
busy or not.
In this case when the notifier call-chain sends notifications, the
bond_netdev_event() assumes that the rx_handler /rx_handler_data is
registered while the bond_enslave() hasn't progressed far enough to
register rx_handler for the new slave.
This patch adds a rx_handler check that can be performed right at the
beginning of the enslave code to avoid getting into this situation.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO driver fixes from Greg KH:
"Here are a number of small fixes for staging and IIO drivers that
resolve reported problems.
Full details are in the shortlog. All of these have been in
linux-next with no reported issues"
* tag 'staging-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (35 commits)
arm: dts: rockchip: add reset node for the exist saradc SoCs
arm64: dts: rockchip: add reset saradc node for rk3368 SoCs
iio: adc: rockchip_saradc: reset saradc controller before programming it
iio: accel: kxsd9: Fix raw read return
iio: adc: ti_am335x_adc: Increase timeout value waiting for ADC sample
iio: adc: ti_am335x_adc: Protect FIFO1 from concurrent access
include/linux: fix excess fence.h kernel-doc notation
staging: wilc1000: correctly check if associatedsta has not been found
staging: wilc1000: NULL dereference on error
staging: wilc1000: txq_event: Fix coding error
MAINTAINERS: Add file patterns for ion device tree bindings
MAINTAINERS: Update maintainer entry for wilc1000
iio: chemical: atlas-ph-sensor: fix typo in val assignment
iio: fix sched WARNING "do not call blocking ops when !TASK_RUNNING"
staging: comedi: ni_mio_common: fix AO inttrig backwards compatibility
staging: comedi: dt2811: fix a precedence bug
staging: comedi: adv_pci1760: Do not return EINVAL for CMDF_ROUND_DOWN.
staging: comedi: ni_mio_common: fix wrong insn_write handler
staging: comedi: comedi_test: fix timer race conditions
staging: comedi: daqboard2000: bug fix board type matching code
