Introduce proper declarations for i8253_lock and i8259A_lock.
Commit 4866cde064afbb6c2a488c265e696879de616daa requires finish_arch_switch
to have only one parameter instead of two.
Also fix another compile error (double declaration of account_system_vtime)
if CONFIG_VIRT_CPU_ACCOUNTING is not defined.
Remove legacy ISA serial ports for Accent, Boca, Fourport, Hub6 and MCA
from the architecture specific serial.h include.
The only ports which remain in asm-*/serial.h are the platform specific
entries. These should really be converted by platform maintainers to
use a platform device, such as can be found in
arch/arm/mach-footbridge/isa.c
Patch from Richard Purdie
With DEBUG enabled, head.S includes arch/debug-macro.S. On the PXA, this
contains references to the macro io_p2v() so hardware.h needs to be
included.
Signed-off-by: Richard Purdie <rpurdie@openedhand.com>
Convert ARMs timer implementations to use readl/writel instead of accessing
the registers via a struct.
People have recently asked if accessing timers via a structure is the
"right way" and its not the Linux way. So fix this code to conform to
"The Linux Way"(tm).
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This crept in with the resync-to-mainline. Nothing uses 802.11-crypt in
mainline, so we can safely comment it out for now.
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Add Philips Webcam format.
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Signed-off-by: Luc Saillard <luc@saillard.org>.
Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru>
*tuner-core.c:
- some tuner_info msgs will be generated only if insmod opt
tuner_debug enabled.
- Implemented tuner-core support for VIDIO_S_TUNER to allow
changing mono/stereo mode
- Remove unneeded config options.
- I2C_CLIENT_MULTI option removed.
- support for Philips FMD12ME hybrid tuner
- allow to initialize with another tuner
- Move PHILIPS_FMD initialization code to set_type function,
* tda8290:
- Fix dumb error in tda8290 tunning.
- Radio tuner uses high-precision step instead of 62.5 KHz.
*tea5767.c:
- tuner_info msgs will be generated only if insmod tuner option
- some cleanups for better reading.
- Changing radio mode stereo/mono for tea5767 working.
*tuner-simple.c:
- TNF9533-D/IF UHF fixup.
- Radio tuners now uses high-precision step instead of 62.5 KHz.
*mt20xx.c:
*tda9887.c:
- tab and blank spaces corrections.
Signed-off-by: Gerd Knorr <kraxel@bytesex.org>
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Anyone reporting a stuck IRQ should try these options. Its effectiveness
varies we've found in the Fedora case. Quite a few systems with misdescribed
IRQ routing just work when you use irqpoll. It also fixes up the VIA systems
although thats now fixed with the VIA quirk (which we could just make default
as its what Redmond OS does but Linus didn't like it historically).
A small number of systems have jammed IRQ sources or misdescribes that cause
an IRQ that we have no handler registered anywhere for. In those cases it
doesn't help.
Signed-off-by: Alan Cox <number6@the-village.bc.nu>
get_io_context needlessly turned off interrupts and checked for racing io
context creations. Both of which aren't needed, because the io context can
only be created while in process context of the current process.
Also, split the function in 2. A light version, current_io_context does not
elevate the reference count specifically, but can be used when in process
context, because the process holds a reference itself.
Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Jens Axboe <axboe@suse.de>
This patch for usb_ch9.h includes linux/types.h instead of asm/types.h so that
__le16 and so on is explicitly defined. It also cleans up non standard //
comment.
Signed-off-by: GOTO Masanori <gotom@debian.or.jp>
Cc: Greg KH <greg@kroah.com>
This patch lets i2c-dev.h include linux/compiler.h so that __user is defined.
This patch cleans up asm-ppc64/byteorder.h to enable ___arch__swab16 and
___arch__swab32 which are marked TODO currently. It removes ___arch__swab64
because ppc64 does not have short instruction combinations for swab64, the
recent gcc generates enough smart code that is equivalent to hand assembled
code under my tests.
Looks like it sneaked back with the NFS ACL merge..
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
In file included from drivers/media/dvb/ttpci/av7110_hw.c:38:
include/linux/byteorder/swabb.h:96: warning: type qualifiers ignored on function return type
include/linux/byteorder/swabb.h:110: warning: type qualifiers ignored on function return type
In file included from drivers/media/dvb/ttpci/av7110_v4l.c:36:
In file included from drivers/media/dvb/ttpci/av7110_av.c:37:
drivers/isdn/icn/icn.c:719:4: warning: #warning TODO test headroom or use skb->nb to flag ACK
In file included from drivers/media/dvb/ttpci/av7110_ca.c:39:
In file included from drivers/media/dvb/ttpci/av7110.c:41:
Does declaring a function to return a const value actually mean something to
gcc?
Dunno. Kill it and replace sone `__inline__'s with `inline' too.
linux/etherdevice.h can't be included standalone at the moment, which
is required in order to sort the header files in the recommended
alphabetic order. This patch fixes that and is needed to build spider_net.
Signed-off-by: Arnd Bergmann <arndb@de.ibm.com>
Remove two more unused IPV6_AUTHHDR option things,
which I failed to remove them last time,
plus, mark IPV6_AUTHHDR obsolete.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Patch from Ben Dooks
This provides the s3c24xx audio platform data which can be
supplied from any of the board specific drivers.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Plug holes with padding fields and initialized them to zero.
This enables the existing __xchg implementation to be used on SMP.
There's another problem shown up by Ingo's recent patch to make
smp_processor_id() complain if it's called with preemption enabled.
local_finish_flush_tlb_mm() calls activate_context() in a situation
where it could be rescheduled to another processor. This patch
disables preemption around the call.
Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This patch fixes an ordering issue between the init code for the
tiocx bus driver and tiocx-related device drivers. Also adds
a new brick to the list of known FPGA bricks.
Signed-off-by: Bruce Losure <blosure@sgi.com>
This patch is a sparse compile cleanup of tioca_provider.c, sn_hwperf.h, and
tioca_provider.h. Each of these files had sparse warnings when
compiled.
Signed-off-by: Prarit Bhargava <prarit@sgi.com>
This patches provides support on Shub2 for the separate TIO IOSPACE MMR. This
patch is SN specific.
Signed-off-by: Colin Ngam <cngam@sgi.com>
This patch changes some macros that are used when running kernel on the
SGI simulator.
Signed-off-by: Jack Steiner <steiner@sgi.com>
This patch is a sparse compile cleanup of shub_mmr.h using both the defconfig
and the sn2_defconfig config files.
The issue with this file was the missing usage of __IA64_UL_CONST wrapper.
This wrapper is defined in include/asm-ia64/types.h and wraps a long
constant definition with UL or with nothing depending on its usage in the
kernel. The missing wrapper caused many sparse compile errors like
warning: constant 0x0x0000000010000380 so big it is long
Resend 2 with changes per Bjorn Helgaas comments. Changes from original:
+ Change globals to vga_console_iobase/vga_console_membase and make them
unconditional.
+ Address style-related comments.
Patch to extend the PCDP vga setup code to support PCI io/mem translations
for the legacy vga ioport and ram spaces on architectures (e.g. altix) which
need them.
Summary of the changes:
drivers/firmware/pcdp.c
drivers/firmware/pcdp.h
+ add declaration for the spec-defined PCI interface struct (pcdp_if_pci)
as well as support macros.
+ extend setup_vga_console() to know about pcdp_if_pci and add a couple of
globals to hold the io and mem translation offsets if present.
arch/ia64/kernel/setup.c
+ tweek early_console_setup() to allow multiple early console setup routines
to be called.
include/asm-ia64/vga.h
+ make VGA_MAP_MEM vga_console_membase aware
Signed-off-by: Mark Maule <maule@sgi.com>
The existing TLB flush implementations only have an effect on
the local CPU. Prefix them with local_.
This patch is the first step in properly handling the MCFG PCI table.
It defines the structures properly, and saves off the table so that the
pci mmconfig code can access it. It moves the parsing of the table a
little later in the boot process, but still before the information is
needed.
With CONFIG_PCI=n:
In file included from include/linux/pci.h:917,
from lib/iomap.c:6:
include/asm/pci.h:104: warning: `enum pci_dma_burst_strategy' declared inside parameter list
include/asm/pci.h:104: warning: its scope is only this definition or declaration, which is probably not what you want.
include/asm/pci.h: In function `pci_dma_burst_advice':
include/asm/pci.h:106: dereferencing pointer to incomplete type
include/asm/pci.h:106: `PCI_DMA_BURST_INFINITY' undeclared (first use in this function)
include/asm/pci.h:106: (Each undeclared identifier is reported only once
include/asm/pci.h:106: for each function it appears in.)
make[1]: *** [lib/iomap.o] Error 1
After seeing, at best, "guesses" as to the following kind
of information in several drivers, I decided that we really
need a way for platforms to specifically give advice in this
area for what works best with their PCI controller implementation.
Basically, this new interface gives DMA bursting advice on
PCI. There are three forms of the advice:
1) Burst as much as possible, it is not necessary to end bursts
on some particular boundary for best performance.
2) Burst on some byte count multiple. A DMA burst to some multiple of
number of bytes may be done, but it is important to end the burst
on an exact multiple for best performance.
The best example of this I am aware of are the PPC64 PCI
controllers, where if you end a burst mid-cacheline then
chip has to refetch the data and the IOMMU translations
which hurts performance a lot.
3) Burst on a single byte count multiple. Bursts shall end
exactly on the next multiple boundary for best performance.
Sparc64 and Alpha's PCI controllers operate this way. They
disconnect any device which tries to burst across a cacheline
boundary.
Actually, newer sparc64 PCI controllers do not have this behavior.
That is why the "pdev" is passed into the interface, so I can
add code later to check which PCI controller the system is using
and give advice accordingly.
This is an updated version of Ben's fix-pci-mmap-on-ppc-and-ppc64.patch
which is in 2.6.12-rc4-mm1.
It fixes the patch to work on PPC iSeries, removes some debug printks
at Ben's request, and incorporates your
fix-pci-mmap-on-ppc-and-ppc64-fix.patch also.
Originally from Benjamin Herrenschmidt <benh@kernel.crashing.org>
This patch was discussed at length on linux-pci and so far, the last
iteration of it didn't raise any comment. It's effect is a nop on
architecture that don't define the new pci_resource_to_user() callback
anyway. It allows architecture like ppc who put weird things inside of
PCI resource structures to convert to some different value for user
visible ones. It also fixes mmap'ing of IO space on those archs.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
This patch adds PCI based I/O xAPIC hot-add support to ACPIPHP
driver. When PCI root bridge is hot-added, all PCI based I/O xAPICs
under the root bridge are hot-added by this patch. Hot-remove support
is TBD.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
This is an ia64 implementation of acpi_register_ioapic() and
acpi_unregister_ioapic() interfaces.
This patch adds the following new interfaces for I/O xAPIC
hotplug. The implementation of these interfaces depends on each
architecture.
o int acpi_register_ioapic(acpi_handle handle, u64 phys_addr,
u32 gsi_base);
This new interface is to add a new I/O xAPIC specified by
phys_addr and gsi_base pair. phys_addr is the physical address
to which the I/O xAPIC is mapped and gsi_base is global system
interrupt base of the I/O xAPIC. acpi_register_ioapic returns
0 on success, or negative value on error.
o int acpi_unregister_ioapic(acpi_handle handle, u32 gsi_base);
This new interface is to remove a I/O xAPIC specified by
gsi_base. acpi_unregister_ioapic returns 0 on success, or
handle
Export an acpi interface to get PCI domain/bus/devfn information from the
corresponding namespace handle. Used by acpiphp code to transpate the device
handle of the hot-plugged root bridge to the corresponding pci location
information.
Signed-off-by: Rajesh Shah <rajesh.shah@intel.com>
independently
Create new interfaces to recursively add an acpi namespace object to the acpi
device list, and recursively start the namespace object. This is needed for
ACPI based hotplug of a root bridge hierarchy where the add operation must be
performed first and the start operation must be performed separately after the
hot-plugged devices have been properly configured.
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and
devices attached to it that have not been configured by firmware. In this
case, we need to configure the devices before starting them. This patch
separates device start from device scan so that we can introduce the
configuration step in the middle.
I kept the existing semantics for pci_scan_bus() since there are a huge number
of callers to that function.
Also, I have no way of testing the changes I made to the parisc files, so this
needs review by those folks. Sorry for the massive cross-post, this touches
files in many different places.
