The statistics are:
- VRAM usage in bytes
- GTT usage in bytes
- number of bytes moved by TTM
The last one is actually a counter, so you need to sample it before and after
command submission and take the difference.
This is useful for finding performance bottlenecks. Userspace queries are
also added.
v2: use atomic64_t
Signed-off-by: Marek Olšák <marek.olsak@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
When passing buffers between processes, the receiving process needs to know
the original buffer domain, so that it doesn't accidentally move the buffer.
v2: reserve the buffer
git://people.freedesktop.org/~deathsimple/linux into drm-next
So this is the initial pull request for radeon drm-next 3.15. Highlights:
- VCE bringup including DPM support
- Few cleanups for the ring handling code
* 'drm-next-3.15' of git://people.freedesktop.org/~deathsimple/linux:
drm/radeon: cleanup false positive lockup handling
drm/radeon: drop radeon_ring_force_activity
drm/radeon: drop drivers copy of the rptr
drm/radeon/cik: enable/disable vce cg when encoding v2
drm/radeon: add support for vce 2.0 clock gating
drm/radeon/dpm: properly enable/disable vce when vce pg is enabled
drm/radeon/dpm: enable dynamic vce state switching v2
drm/radeon: add vce dpm support for KV/KB
drm/radeon: enable vce dpm on CI
drm/radeon: add vce dpm support for CI
drm/radeon: fill in set_vce_clocks for CIK asics
drm/radeon/dpm: fetch vce states from the vbios
drm/radeon/dpm: fill in some initial vce infrastructure
drm/radeon/dpm: move platform caps fetching to a separate function
drm/radeon: add callback for setting vce clocks
drm/radeon: add VCE version parsing and checking
drm/radeon: add VCE ring query
drm/radeon: initial VCE support v4
drm/radeon: fix CP semaphores on CIK
ssh://git.freedesktop.org/git/drm-intel into drm-next
- Yet more steps towards atomic modeset from Ville.
- DP panel power sequencing improvements from Paulo.
- irq code cleanups from Ville.
- 5.4 GHz dp lane clock support for bdw/hsw from Todd.
- Clock readout support for hsw/bdw (aka fastboot) from Jesse.
- Make pipe underruns report at ERROR level (Ville). This is to check our
improved watermarks code.
- Full ppgtt support from Ben for gen7.
- More fbc fixes and improvements from Ville all over the place, unfortunately
not yet enabled by default on more platforms.
- w/a cleanups from Ville.
- HiZ stall optimization settings (Chia-I Wu).
- Display register mmio offset refactor patch from Antti.
- RPS improvements for corner-cases from Jeff McGee.
* tag 'drm-intel-next-2014-02-07' of ssh://git.freedesktop.org/git/drm-intel: (166 commits)
drm/i915: Update rps interrupt limits
drm/i915: Restore rps/rc6 on reset
drm/i915: Prevent recursion by retiring requests when the ring is full
drm/i915: Generate a hang error code
drm/i915: unify FLIP_DONE macro names
drm/i915: vlv: s/spin_lock_irqsave/spin_lock/ in irq handler
drm/i915: factor out valleyview_pipestat_irq_handler
drm/i915: vlv: don't unmask IIR[DISPLAY_PIPE_A/B_VBLANK] interrupt
drm/i915: Reorganize display pipe register accesses
drm/i915: Treat using a purged buffer as a source of EFAULT
drm/i915: Convert EFAULT into a silent SIGBUS
drm/i915: release mutex in i915_gem_init()'s error path
drm/i915: check for oom when allocating private_default_ctx
drm/i915/vlv: WA to fix Voltage not getting dropped to Vmin when Gfx is power gated.
drm/i915: Get rid of acthd based guilty batch search
drm/i915: Use hangcheck score to find guilty context
drm/i915: Drop WaDisablePSDDualDispatchEnable:ivb for IVB GT2
drm/i915: Fix IVB GT2 WaDisableDopClockGating and WaDisablePSDDualDispatchEnable
drm/i915: Don't access snooped pages through the GTT (even for error capture)
drm/i915: Only print information for filing bug reports once
drivers/gpu/drm/i915/intel_dp.c
git://anongit.freedesktop.org/tegra/linux into drm-next
drm: DisplayPort AUX framework for v3.15-rc1
This series of patches implements a small framework that abstracts away
some of the functionality that the DisplayPort AUX channel provides. It
comes with a set of generic helpers that use the driver implementations
to reduce code duplication.
* tag 'drm/dp-aux-for-3.15-rc1' of git://anongit.freedesktop.org/tegra/linux:
drm/dp: Allow registering AUX channels as I2C busses
drm/dp: Add DisplayPort link helpers
drm/dp: Add drm_dp_dpcd_read_link_status()
drm/dp: Add AUX channel infrastructure
Implements an I2C-over-AUX I2C adapter on top of the generic drm_dp_aux
infrastructure. It extracts the retry logic from existing drivers, which
should help in porting those drivers to this new helper.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Changes in v5:
- move comments partially to to header file
- keep MOT set between I2C messages
- return -EPROTO on short reads
Changes in v4:
- fix typo "bitrate" -> "bit rate"
Changes in v3:
- add back DRM_DEBUG_KMS and DRM_ERROR messages
- embed i2c_adapter within struct drm_dp_aux
- fix typo in comment
Add a helper to probe a DP link (read out the supported DPCD revision,
maximum rate, link count and capabilities) as well as power up the DP
link and configure it accordingly.
Changes in v5:
- export helpers
Changes in v4:
- fix a couple of typos in comments as pointed out by Alex Deucher
Changes in v3:
- split into drm_dp_link_power_up() and drm_dp_link_configure()
- do not change sink state for DPCD versions earlier than 1.1
- sleep for 1-2 ms after setting local sink to D0 state
- read and write consecutive registers where possible
- read DPCD revision when link is probed
- remove duplicate kerneldoc
The function reads the link status (6 bytes starting at offset 0x202)
from the DPCD so that it can be conveniently passed to other DPCD
helpers.
This is a superset of the current i2c_dp_aux bus functionality and can
be used to transfer native AUX in addition to I2C-over-AUX messages.
Helpers are provided to read and write the DPCD, either blockwise or
byte-wise. Many of the existing helpers for DisplayPort take a copy of a
portion of the DPCD and operate on that, without a way to write data
back to the DPCD (e.g. for configuration of the link).
Subsequent patches will build upon this infrastructure to provide common
functionality in a generic way.
Changes in v5:
- move comments partially to struct drm_dp_aux_msg in header file
- return -EPROTO on short reads in DPCD helpers
Changes in v4:
- fix a typo in a comment
Changes in v3:
- reorder drm_dp_dpcd_writeb() arguments to be more intuitive
- return number of bytes transferred in drm_dp_dpcd_write()
- factor out drm_dp_dpcd_access()
- describe error codes
Because of a recent syscall design debate; its deemed appropriate for
each syscall to have a flags argument for future extension; without
immediately requiring new syscalls.
Cc: juri.lelli@gmail.com
Suggested-by: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20140214161929.GL27965@twins.programming.kicks-ass.net
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"The most interesting thing here is the change to enable INTx (by
clearing PCI_COMMAND_INTX_DISABLE) if the BIOS left INTx disabled.
Apparently the Baytrail BIOS does this, which means EHCI doesn't work.
Also, fix an AHCI MSI regression and other issues with the recent MSI
changes. This also adds pci_enable_msi_exact() and
pci_enable_msix_exact(), which aren't regression fixes, but will keep
us from touching drivers twice (once to stop using the deprecated
pci_enable_msi(), etc., and again to use the *_exact() variants).
There's also a minor MVEBU fix.
Summary:
MSI:
- Fix AHCI single-MSI fallback (Alexander Gordeev)
- Fix populate_msi_sysfs() error paths (Greg Kroah-Hartman)
- Fix htmldocs problem (Masanari Iida)
- Add pci_enable_msi_exact() and pci_enable_msix_exact() (Alexander Gordeev)
- Update documentation (Alexander Gordeev)
Miscellaneous:
- mvebu: expose device ID & revision via lspci (Andrew Lunn)
- Enable INTx if the BIOS left them disabled (Bjorn Helgaas)"
* tag 'pci-v3.14-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
ahci: Fix broken fallback to single MSI mode
PCI: Enable INTx if BIOS left them disabled
PCI/MSI: Add pci_enable_msi_exact() and pci_enable_msix_exact()
PCI/MSI: Fix cut-and-paste errors in documentation
PCI/MSI: Add pci_enable_msi() documentation back
PCI/MSI: Fix pci_msix_vec_count() htmldocs failure
PCI/MSI: Fix leak of msi_attrs
PCI/MSI: Check kmalloc() return value, fix leak of name
PCI: mvebu: Use Device ID and revision from underlying endpoint
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"Quite a few fixes this time.
Three locking fixes, all marked for -stable. A couple error path
fixes and some misc fixes. Hugh found a bug in memcg offlining
sequence and we thought we could fix that from cgroup core side but
that turned out to be insufficient and got reverted. A different fix
has been applied to -mm"
* 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: update cgroup_enable_task_cg_lists() to grab siglock
Revert "cgroup: use an ordered workqueue for cgroup destruction"
cgroup: protect modifications to cgroup_idr with cgroup_mutex
cgroup: fix locking in cgroup_cfts_commit()
cgroup: fix error return from cgroup_create()
cgroup: fix error return value in cgroup_mount()
nfs: include xattr.h from fs/nfs/nfs3proc.c
cpuset: update MAINTAINERS entry
arm, pm, vmpressure: add missing slab.h includes
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq
Pull workqueue fixes from Tejun Heo:
"Two workqueue fixes. One for an unlikely but possible critical bug
during kworker shutdown and the other to make lockdep names a bit more
descriptive"
* 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: ensure @task is valid across kthread_stop()
workqueue: add args to workqueue lockdep name
Pull MFD fixes from Lee Jones:
"Couple of small issues solved:
- Suspend/Resume call-backs require CONFIG_PM_SLEEP
- Some drivers written for 32bit architectures fail when compiled
with a 64bit compiler. The fixes will future proof the drivers"
* tag 'mfd-fixes-3.14-1' of git://git.linaro.org/people/lee.jones/mfd:
mfd: sec-core: sec_pmic_{suspend,resume}() should depend on CONFIG_PM_SLEEP
mfd: max14577: max14577_{suspend,resume}() should depend on CONFIG_PM_SLEEP
mfd: tps65217: Naturalise cross-architecture discrepancies
mfd: wm8994-core: Naturalise cross-architecture discrepancies
mfd: max8998: Naturalise cross-architecture discrepancies
mfd: max8997: Naturalise cross-architecture discrepancies
If we compile the TPS65217 for a 64bit architecture we receive the following
warnings:
drivers/mfd/tps65217.c: In function ‘tps65217_probe’:
drivers/mfd/tps65217.c:173:13:
warning: cast from pointer to integer of different size
chip_id = (unsigned int)match->data;
Signed-off-by: Lee Jones <lee.jones@linaro.org>
If we compile the MAX8998 for a 64bit architecture we receive the following
warnings:
drivers/mfd/max8998.c: In function ‘max8998_i2c_get_driver_data’:
drivers/mfd/max8998.c:178:10:
return (int)match->data;
If we compile the MAX8997 for a 64bit architecture we receive the following
warnings:
drivers/mfd/max8997.c: In function ‘max8997_i2c_get_driver_data’:
drivers/mfd/max8997.c:173:10:
Pull drm fixes from Dave Airlie:
"Lots of little small things, nothing too major: nouveau regression
fixes, vmware fixes for the new hw support, memory leaks in error path
fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (31 commits)
drm/radeon/ni: fix typo in dpm sq ramping setup
drm/radeon/si: fix typo in dpm sq ramping setup
drm/radeon: delete a stray tab
drm/radeon: fix display tiling setup on SI
drm/radeon/dpm: reduce r7xx vblank mclk threshold to 200
drm/radeon: fill in DRM_CAPs for cursor size
drm: add DRM_CAPs for cursor size
drm/radeon: unify bpc handling
drm/ttm: Fix memory leak in ttm_agp_backend.c
drm/ttm: declare 'struct device' in ttm_page_alloc.h
drm/nouveau: fix TTM_PL_TT memtype on pre-nv50
drm/nv50/disp: use correct register to determine DP display bpp
drm/nouveau/fb: use correct ram oclass for nv1a hardware
drm/nv50/gr: add missing nv_error parameter priv
drm/nouveau: fix ENG_RUNLIST register address
drm/nv4c/bios: disallow retrieving from prom on nv4x igp's
drm/nv4c/vga: decode register is in a different place on nv4x igp's
drm/nv4c/mc: nv4x igp's have a different msi rearm register
drm/nouveau: set irq_enabled manually
Pull networking fixes from David Miller:
1) kvaser CAN driver has fixed limits of some of it's table, validate
that we won't exceed those limits at probe time. Fix from Olivier
Sobrie.
2) Fix rtl8192ce disabling interrupts for too long, from Olivier
Langlois.
3) Fix botched shift in ath5k driver, from Dan Carpenter.
4) Fix corruption of deferred packets in TIPC, from Erik Hugne.
5) Fix newlink error path in macvlan driver, from Cong Wang.
6) Fix netpoll deadlock in bonding, from Ding Tianhong.
7) Handle GSO packets properly in forwarding path when fragmentation is
necessary on egress, from Florian Westphal.
8) Fix axienet build errors, from Michal Simek.
9) Fix refcounting of ubufs on tx in vhost net driver, from Michael S
Tsirkin.
10) Carrier status isn't set properly in hyperv driver, from Haiyang
Zhang.
11) Missing pci_disable_device() in tulip_remove_one), from Ingo Molnar.
12) AF_PACKET qdisc bypass mode doesn't adhere to driver provided TX
queue selection method. Add a fallback method mechanism to fix this
bug, from Daniel Borkmann.
13) Fix regression in link local route handling on GRE tunnels, from
Nicolas Dichtel.
14) Bonding can assign dup aggregator IDs in some sequences of
configuration, fix by making the allocation counter per-bond instead
of global. From Jiri Bohac.
15) sctp_connectx() needs compat translations, from Daniel Borkmann.
16) Fix of_mdio PHY interrupt parsing, from Ben Dooks
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits)
MAINTAINERS: add entry for the PHY library
of_mdio: fix phy interrupt passing
net: ethernet: update dependency and help text of mvneta
NET: fec: only enable napi if we are successful
af_packet: remove a stray tab in packet_set_ring()
net: sctp: fix sctp_connectx abi for ia32 emulation/compat mode
ipv4: fix counter in_slow_tot
irtty-sir.c: Do not set_termios() on irtty_close()
bonding: 802.3ad: make aggregator_identifier bond-private
usbnet: remove generic hard_header_len check
gre: add link local route when local addr is any
batman-adv: fix potential kernel paging error for unicast transmissions
batman-adv: avoid double free when orig_node initialization fails
batman-adv: free skb on TVLV parsing success
batman-adv: fix TT CRC computation by ensuring byte order
batman-adv: fix potential orig_node reference leak
batman-adv: avoid potential race condition when adding a new neighbour
batman-adv: properly check pskb_may_pull return value
batman-adv: release vlan object after checking the CRC
batman-adv: fix TT-TVLV parsing on OGM reception
git://people.freedesktop.org/~thomash/linux into drm-fixes
Pull request of 2014-02-18
One compile fix and one memory leak.
* tag 'ttm-fixes-3.14-2014-02-18' of git://people.freedesktop.org/~thomash/linux:
Pull request of 2014-02-18.
Nothing special. The biggest change is adding a couple of command defines and
packing the command data correctly.
* tag 'vmwgfx-fixes-3.14-2014-02-18' of git://people.freedesktop.org/~thomash/linux:
drm/vmwgfx: Fix command defines and checks
drm/vmwgfx: Fix possible integer overflow
drm/vmwgfx: Remove stray const
drm/vmwgfx: unlock on error path in vmw_execbuf_process()
drm/vmwgfx: Get maximum mob size from register SVGA_REG_MOB_MAX_SIZE
drm/vmwgfx: Fix a couple of sparse warnings and errors
Some hardware may not support standard 64x64 cursors. Add
a drm cap to query the cursor size from the kernel. Some examples
include radeon CIK parts (128x128 cursors) and armada (32x64 or 64x32).
This allows things like device specific ddxes to remove asics specific
logic and also allows xf86-video-modesetting to work properly with hw
cursors on this hardware. Default to 64 if the driver doesn't specify
a size.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Rob Clark <robdclark@gmail.com>
Also make the result available to userspace.
Signed-off-by: Christian König <christian.koenig@amd.com>
Only VCE 2.0 support so far.
v2: squashing multiple patches into this one
v3: add IRQ support for CIK, major cleanups,
basic code documentation
v4: remove HAINAN from chipset list
Declare 'struct device' explicitly in ttm_page_alloc.h as this file
does not include any file declaring it. This removes the following
warning:
warning: 'struct device' declared inside parameter list
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph fixes from Sage Weil:
"We have some patches fixing up ACL support issues from Zheng and
Guangliang and a mount option to enable/disable this support. (These
fixes were somewhat delayed by the Chinese holiday.)
There is also a small fix for cached readdir handling when directories
are fragmented"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: fix __dcache_readdir()
ceph: add acl, noacl options for cephfs mount
ceph: make ceph_forget_all_cached_acls() static inline
ceph: add missing init_acl() for mkdir() and atomic_open()
ceph: fix ceph_set_acl()
ceph: fix ceph_removexattr()
ceph: remove xattr when null value is given to setxattr()
ceph: properly handle XATTR_CREATE and XATTR_REPLACE
git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf
Pull dma-buf fix from Sumit Semwal:
"Just some debugfs output updates.
There's another patch related to dma-buf, but it'll get upstreamed via
Greg KH's pull request"
* tag 'dma-buf-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf:
dma-buf: update debugfs output
For the setxattr request, introduce a new flag CEPH_XATTR_REMOVE
to distinguish null value case from the zero-length value case.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Ben Herrenschmidt:
"Here are some more powerpc fixes for 3.14
The main one is a nasty issue with the NUMA balancing support which
requires a small generic change and the addition of a new accessor to
set _PAGE_NUMA. Both have been reviewed and acked by Mel and Rik.
The changelog should have plenty of details but basically, without
this fix, we get random user segfaults and/or corruptions due to
missing TLB/hash flushes. Aneesh series of 3 patches fixes it.
We have some vDSO vs. perf fixes from Anton, some small EEH fixes
from Gavin, a ppc32 regression vs the stack overflow detector, and a
fix for the way we handle PCIe host bridge speed settings on pseries
(which is needed for proper operations of AMD graphics cards on
Power8)"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/eeh: Disable EEH on reboot
powerpc/eeh: Cleanup on eeh_subsystem_enabled
powerpc/powernv: Rework EEH reset
powerpc: Use unstripped VDSO image for more accurate profiling data
powerpc: Link VDSOs at 0x0
mm: Use ptep/pmdp_set_numa() for updating _PAGE_NUMA bit
mm: Dirty accountable change only apply to non prot numa case
powerpc/mm: Add new "set" flag argument to pte/pmd update function
powerpc/pseries: Add Gen3 definitions for PCIE link speed
powerpc/pseries: Fix regression on PCI link speed
powerpc: Set the correct ksp_limit on ppc32 when switching to irq stack
In order to allow users to invoke netdev_cap_txqueue, it needs to
be moved into netdevice.h header file. While at it, also add kernel
doc header to document the API.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Add a new argument for ndo_select_queue() callback that passes a
fallback handler. This gets invoked through netdev_pick_tx();
fallback handler is currently __netdev_pick_tx() as most drivers
invoke this function within their customized implementation in
case for skbs that don't need any special handling. This fallback
handler can then be replaced on other call-sites with different
queue selection methods (e.g. in packet sockets, pktgen etc).
This also has the nice side-effect that __netdev_pick_tx() is
then only invoked from netdev_pick_tx() and export of that
function to modules can be undone.
Suggested-by: David S. Miller <davem@davemloft.net>
receiver's buffer
Implementation of (a)rwnd calculation might lead to severe performance issues
and associations completely stalling. These problems are described and solution
is proposed which improves lksctp's robustness in congestion state.
1) Sudden drop of a_rwnd and incomplete window recovery afterwards
Data accounted in sctp_assoc_rwnd_decrease takes only payload size (sctp data),
but size of sk_buff, which is blamed against receiver buffer, is not accounted
in rwnd. Theoretically, this should not be the problem as actual size of buffer
is double the amount requested on the socket (SO_RECVBUF). Problem here is
that this will have bad scaling for data which is less then sizeof sk_buff.
E.g. in 4G (LTE) networks, link interfacing radio side will have a large portion
of traffic of this size (less then 100B).
An example of sudden drop and incomplete window recovery is given below. Node B
exhibits problematic behavior. Node A initiates association and B is configured
to advertise rwnd of 10000. A sends messages of size 43B (size of typical sctp
message in 4G (LTE) network). On B data is left in buffer by not reading socket
in userspace.
Lets examine when we will hit pressure state and declare rwnd to be 0 for
scenario with above stated parameters (rwnd == 10000, chunk size == 43, each
chunk is sent in separate sctp packet)
Logic is implemented in sctp_assoc_rwnd_decrease:
socket_buffer (see below) is maximum size which can be held in socket buffer
(sk_rcvbuf). current_alloced is amount of data currently allocated (rx_count)
A simple expression is given for which it will be examined after how many
packets for above stated parameters we enter pressure state:
We start by condition which has to be met in order to enter pressure state:
socket_buffer < currently_alloced;
currently_alloced is represented as size of sctp packets received so far and not
yet delivered to userspace. x is the number of chunks/packets (since there is no
bundling, and each chunk is delivered in separate packet, we can observe each
chunk also as sctp packet, and what is important here, having its own sk_buff):
socket_buffer < x*each_sctp_packet;
each_sctp_packet is sctp chunk size + sizeof(struct sk_buff). socket_buffer is
twice the amount of initially requested size of socket buffer, which is in case
of sctp, twice the a_rwnd requested:
2*rwnd < x*(payload+sizeof(struc sk_buff));
sizeof(struct sk_buff) is 190 (3.13.0-rc4+). Above is stated that rwnd is 10000
and each payload size is 43
20000 < x(43+190);
x > 20000/233;
x ~> 84;
After ~84 messages, pressure state is entered and 0 rwnd is advertised while
received 84*43B ~= 3612B sctp data. This is why external observer notices sudden
drop from 6474 to 0, as it will be now shown in example:
IP A.34340 > B.12345: sctp (1) [INIT] [init tag: 1875509148] [rwnd: 81920] [OS: 10] [MIS: 65535] [init TSN: 1096057017]
IP B.12345 > A.34340: sctp (1) [INIT ACK] [init tag: 3198966556] [rwnd: 10000] [OS: 10] [MIS: 10] [init TSN: 902132839]
IP A.34340 > B.12345: sctp (1) [COOKIE ECHO]
IP B.12345 > A.34340: sctp (1) [COOKIE ACK]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057017] [SID: 0] [SSEQ 0] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057017] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057018] [SID: 0] [SSEQ 1] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057018] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057019] [SID: 0] [SSEQ 2] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057019] [a_rwnd 9914] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057098] [SID: 0] [SSEQ 81] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057098] [a_rwnd 6517] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057099] [SID: 0] [SSEQ 82] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057099] [a_rwnd 6474] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057100] [SID: 0] [SSEQ 83] [PPID 0x18]
--> Sudden drop
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
At this point, rwnd_press stores current rwnd value so it can be later restored
in sctp_assoc_rwnd_increase. This however doesn't happen as condition to start
slowly increasing rwnd until rwnd_press is returned to rwnd is never met. This
condition is not met since rwnd, after it hit 0, must first reach rwnd_press by
adding amount which is read from userspace. Let us observe values in above
example. Initial a_rwnd is 10000, pressure was hit when rwnd was ~6500 and the
amount of actual sctp data currently waiting to be delivered to userspace
is ~3500. When userspace starts to read, sctp_assoc_rwnd_increase will be blamed
only for sctp data, which is ~3500. Condition is never met, and when userspace
reads all data, rwnd stays on 3569.
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 1505] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057100] [a_rwnd 3010] [#gap acks 0] [#dup tsns 0]
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057101] [SID: 0] [SSEQ 84] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057101] [a_rwnd 3569] [#gap acks 0] [#dup tsns 0]
--> At this point userspace read everything, rwnd recovered only to 3569
IP A.34340 > B.12345: sctp (1) [DATA] (B)(E) [TSN: 1096057102] [SID: 0] [SSEQ 85] [PPID 0x18]
IP B.12345 > A.34340: sctp (1) [SACK] [cum ack 1096057102] [a_rwnd 3569] [#gap acks 0] [#dup tsns 0]
Reproduction is straight forward, it is enough for sender to send packets of
size less then sizeof(struct sk_buff) and receiver keeping them in its buffers.
2) Minute size window for associations sharing the same socket buffer
In case multiple associations share the same socket, and same socket buffer
(sctp.rcvbuf_policy == 0), different scenarios exist in which congestion on one
of the associations can permanently drop rwnd of other association(s).
Situation will be typically observed as one association suddenly having rwnd
dropped to size of last packet received and never recovering beyond that point.
Different scenarios will lead to it, but all have in common that one of the
associations (let it be association from 1)) nearly depleted socket buffer, and
the other association blames socket buffer just for the amount enough to start
the pressure. This association will enter pressure state, set rwnd_press and
announce 0 rwnd.
When data is read by userspace, similar situation as in 1) will occur, rwnd will
increase just for the size read by userspace but rwnd_press will be high enough
so that association doesn't have enough credit to reach rwnd_press and restore
to previous state. This case is special case of 1), being worse as there is, in
the worst case, only one packet in buffer for which size rwnd will be increased.
Consequence is association which has very low maximum rwnd ('minute size', in
our case down to 43B - size of packet which caused pressure) and as such
unusable.
Scenario happened in the field and labs frequently after congestion state (link
breaks, different probabilities of packet drop, packet reordering) and with
scenario 1) preceding. Here is given a deterministic scenario for reproduction:
>From node A establish two associations on the same socket, with rcvbuf_policy
being set to share one common buffer (sctp.rcvbuf_policy == 0). On association 1
repeat scenario from 1), that is, bring it down to 0 and restore up. Observe
scenario 1). Use small payload size (here we use 43). Once rwnd is 'recovered',
bring it down close to 0, as in just one more packet would close it. This has as
a consequence that association number 2 is able to receive (at least) one more
packet which will bring it in pressure state. E.g. if association 2 had rwnd of
10000, packet received was 43, and we enter at this point into pressure,
rwnd_press will have 9957. Once payload is delivered to userspace, rwnd will
increase for 43, but conditions to restore rwnd to original state, just as in
1), will never be satisfied.
--> Association 1, between A.y and B.12345
IP A.55915 > B.12345: sctp (1) [INIT] [init tag: 836880897] [rwnd: 10000] [OS: 10] [MIS: 65535] [init TSN: 4032536569]
IP B.12345 > A.55915: sctp (1) [INIT ACK] [init tag: 2873310749] [rwnd: 81920] [OS: 10] [MIS: 10] [init TSN: 3799315613]
IP A.55915 > B.12345: sctp (1) [COOKIE ECHO]
IP B.12345 > A.55915: sctp (1) [COOKIE ACK]
--> Association 2, between A.z and B.12346
IP A.55915 > B.12346: sctp (1) [INIT] [init tag: 534798321] [rwnd: 10000] [OS: 10] [MIS: 65535] [init TSN: 2099285173]
IP B.12346 > A.55915: sctp (1) [INIT ACK] [init tag: 516668823] [rwnd: 81920] [OS: 10] [MIS: 10] [init TSN: 3676403240]
IP A.55915 > B.12346: sctp (1) [COOKIE ECHO]
IP B.12346 > A.55915: sctp (1) [COOKIE ACK]
--> Deplete socket buffer by sending messages of size 43B over association 1
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315613] [SID: 0] [SSEQ 0] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315613] [a_rwnd 9957] [#gap acks 0] [#dup tsns 0]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315696] [a_rwnd 6388] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315697] [SID: 0] [SSEQ 84] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315697] [a_rwnd 6345] [#gap acks 0] [#dup tsns 0]
--> Sudden drop on 1
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315698] [SID: 0] [SSEQ 85] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315698] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Here userspace read, rwnd 'recovered' to 3698, now deplete again using
association 1 so there is place in buffer for only one more packet
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315799] [SID: 0] [SSEQ 186] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315799] [a_rwnd 86] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315800] [SID: 0] [SSEQ 187] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 43] [#gap acks 0] [#dup tsns 0]
--> Socket buffer is almost depleted, but there is space for one more packet,
send them over association 2, size 43B
IP B.12346 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3676403240] [SID: 0] [SSEQ 0] [PPID 0x18]
IP A.55915 > B.12346: sctp (1) [SACK] [cum ack 3676403240] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Immediate drop
IP A.60995 > B.12346: sctp (1) [SACK] [cum ack 387491510] [a_rwnd 0] [#gap acks 0] [#dup tsns 0]
--> Read everything from the socket, both association recover up to maximum rwnd
they are capable of reaching, note that association 1 recovered up to 3698,
and association 2 recovered only to 43
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 1548] [#gap acks 0] [#dup tsns 0]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315800] [a_rwnd 3053] [#gap acks 0] [#dup tsns 0]
IP B.12345 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3799315801] [SID: 0] [SSEQ 188] [PPID 0x18]
IP A.55915 > B.12345: sctp (1) [SACK] [cum ack 3799315801] [a_rwnd 3698] [#gap acks 0] [#dup tsns 0]
IP B.12346 > A.55915: sctp (1) [DATA] (B)(E) [TSN: 3676403241] [SID: 0] [SSEQ 1] [PPID 0x18]
IP A.55915 > B.12346: sctp (1) [SACK] [cum ack 3676403241] [a_rwnd 43] [#gap acks 0] [#dup tsns 0]
A careful reader might wonder why it is necessary to reproduce 1) prior
reproduction of 2). It is simply easier to observe when to send packet over
association 2 which will push association into the pressure state.
Proposed solution:
Both problems share the same root cause, and that is improper scaling of socket
buffer with rwnd. Solution in which sizeof(sk_buff) is taken into concern while
calculating rwnd is not possible due to fact that there is no linear
relationship between amount of data blamed in increase/decrease with IP packet
in which payload arrived. Even in case such solution would be followed,
complexity of the code would increase. Due to nature of current rwnd handling,
slow increase (in sctp_assoc_rwnd_increase) of rwnd after pressure state is
entered is rationale, but it gives false representation to the sender of current
buffer space. Furthermore, it implements additional congestion control mechanism
which is defined on implementation, and not on standard basis.
Proposed solution simplifies whole algorithm having on mind definition from rfc:
o Receiver Window (rwnd): This gives the sender an indication of the space
available in the receiver's inbound buffer.
Core of the proposed solution is given with these lines:
sctp_assoc_rwnd_update:
if ((asoc->base.sk->sk_rcvbuf - rx_count) > 0)
asoc->rwnd = (asoc->base.sk->sk_rcvbuf - rx_count) >> 1;
else
asoc->rwnd = 0;
We advertise to sender (half of) actual space we have. Half is in the braces
depending whether you would like to observe size of socket buffer as SO_RECVBUF
or twice the amount, i.e. size is the one visible from userspace, that is,
from kernelspace.
In this way sender is given with good approximation of our buffer space,
regardless of the buffer policy - we always advertise what we have. Proposed
solution fixes described problems and removes necessity for rwnd restoration
algorithm. Finally, as proposed solution is simplification, some lines of code,
along with some bytes in struct sctp_association are saved.
Version 2 of the patch addressed comments from Vlad. Name of the function is set
to be more descriptive, and two parts of code are changed, in one removing the
superfluous call to sctp_assoc_rwnd_update since call would not result in update
of rwnd, and the other being reordering of the code in a way that call to
sctp_assoc_rwnd_update updates rwnd. Version 3 corrected change introduced in v2
in a way that existing function is not reordered/copied in line, but it is
correctly called. Thanks Vlad for suggesting.
Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com>
Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Archs like ppc64 doesn't do tlb flush in set_pte/pmd functions when using
a hash table MMU for various reasons (the flush is handled as part of
the PTE modification when necessary).
ppc64 thus doesn't implement flush_tlb_range for hash based MMUs.
Additionally ppc64 require the tlb flushing to be batched within ptl locks.
The reason to do that is to ensure that the hash page table is in sync with
linux page table.
We track the hpte index in linux pte and if we clear them without flushing
hash and drop the ptl lock, we can have another cpu update the pte and can
end up with duplicate entry in the hash table, which is fatal.
We also want to keep set_pte_at simpler by not requiring them to do hash
flush for performance reason. We do that by assuming that set_pte_at() is
never *ever* called on a PTE that is already valid.
This was the case until the NUMA code went in which broke that assumption.
Fix that by introducing a new pair of helpers to set _PAGE_NUMA in a
way similar to ptep/pmdp_set_wrprotect(), with a generic implementation
using set_pte_at() and a powerpc specific one using the appropriate
mechanism needed to keep the hash table in sync.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"We have a small collection of fixes in my for-linus branch.
The big thing that stands out is a revert of a new ioctl. Users
haven't shipped yet in btrfs-progs, and Dave Sterba found a better way
to export the information"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: use right clone root offset for compressed extents
btrfs: fix null pointer deference at btrfs_sysfs_add_one+0x105
Btrfs: unset DCACHE_DISCONNECTED when mounting default subvol
Btrfs: fix max_inline mount option
Btrfs: fix a lockdep warning when cleaning up aborted transaction
Revert "btrfs: add ioctl to export size of global metadata reservation"
Pull SCSI target fixes from Nicholas Bellinger:
"Mostly minor fixes this time to v3.14-rc1 related changes. Also
included is one fix for a free after use regression in persistent
reservations UNREGISTER logic that is CC'ed to >= v3.11.y stable"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
Target/sbc: Fix protection copy routine
IB/srpt: replace strict_strtoul() with kstrtoul()
target: Simplify command completion by removing CMD_T_FAILED flag
iser-target: Fix leak on failure in isert_conn_create_fastreg_pool
iscsi-target: Fix SNACK Type 1 + BegRun=0 handling
target: Fix missing length check in spc_emulate_evpd_83()
qla2xxx: Remove last vestiges of qla_tgt_cmd.cmd_list
target: Fix 32-bit + CONFIG_LBDAF=n link error w/ sector_div
target: Fix free-after-use regression in PR unregister
Pull irq update from Thomas Gleixner:
"Fix from the urgent branch: a trivial oneliner adding the missing
Kconfig dependency curing build failures which have been discovered by
several build robots.
The update in the irq-core branch provides a new function in the
irq/devres code, which is a prerequisite for driver developers to get
rid of boilerplate code all over the place.
Not a bugfix, but it has zero impact on the current kernel due to the
lack of users. It's simpler to provide the infrastructure to
interested parties via your tree than fulfilling the wishlist of
driver maintainers on which particular commit or tag this should be
based on"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Add devm_request_any_context_irq()
Pull ARM SoC fixes from Kevin Hilman:
"A collection of ARM SoC fixes for v3.14-rc1.
Mostly a collection of Kconfig, device tree data and compilation fixes
along with fix to drivers/phy that fixes a boot regression on some
Marvell mvebu platforms"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
dma: mv_xor: Silence a bunch of LPAE-related warnings
ARM: ux500: disable msp2 device tree node
ARM: zynq: Reserve not DMAable space in front of the kernel
ARM: multi_v7_defconfig: Select CONFIG_SOC_DRA7XX
ARM: imx6: Initialize low-power mode early again
ARM: pxa: fix various compilation problems
ARM: pxa: fix compilation problem on AM300EPD board
ARM: at91: add Atmel's SAMA5D3 Xplained board
spi/atmel: document clock properties
mmc: atmel-mci: document clock properties
ARM: at91: enable USB host on at91sam9n12ek board
ARM: at91/dt: fix sama5d3 ohci hclk clock reference
ARM: at91/dt: sam9263: fix compatibility string for the I2C
ata: sata_mv: Fix probe failures with optional phys
drivers: phy: Add support for optional phys
drivers: phy: Make NULL a valid phy reference
ARM: fix HAVE_ARM_TWD selection for OMAP and shmobile
ARM: moxart: move DMA_OF selection to driver
ARM: hisi: fix kconfig warning on HAVE_ARM_TWD
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here is a bunch of USB fixes for 3.14-rc3. Most of these are xhci
reverts, fixing a bunch of reported issues with USB 3 host controller
issues that loads of people have been hitting (with the exception of
kernel developers, all of our machines seem to be working fine, which
is why these took so long to get resolved...)
There are some other minor fixes and new device ids, as ususal. All
have been in linux-next successfully"
* tag 'usb-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (22 commits)
usb: option: blacklist ZTE MF667 net interface
Revert "usb: xhci: Link TRB must not occur within a USB payload burst"
Revert "xhci: Avoid infinite loop when sg urb requires too many trbs"
Revert "xhci: Set scatter-gather limit to avoid failed block writes."
xhci 1.0: Limit arbitrarily-aligned scatter gather.
Modpost: fixed USB alias generation for ranges including 0x9 and 0xA
usb: core: Fix potential memory leak adding dyn USBdevice IDs
USB: ftdi_sio: add Tagsys RFID Reader IDs
usb: qcserial: add Netgear Aircard 340U
usb-storage: enable multi-LUN scanning when needed
USB: simple: add Dynastream ANT USB-m Stick device support
usb-storage: add unusual-devs entry for BlackBerry 9000
usb-storage: restrict bcdDevice range for Super Top in Cypress ATACB
usb: phy: move some error messages to debug
usb: ftdi_sio: add Mindstorms EV3 console adapter
usb: dwc2: fix memory corruption in dwc2 driver
usb: dwc2: fix role switch breakage
usb: dwc2: bail out early when booting with "nousb"
Revert "xhci: replace xhci_read_64() with readq()"
Revert "xhci: replace xhci_write_64() with writeq()"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc fixes from Greg KH:
"Here are some small char/misc driver fixes, along with some
documentation updates, for 3.14-rc3. Nothing major, just a number of
fixes for reported issues"
* tag 'char-misc-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Revert "misc: eeprom: sunxi: Add new compatibles"
Revert "ARM: sunxi: dt: Convert to the new SID compatibles"
misc: mic: fix possible signed underflow (undefined behavior) in userspace API
misc: genwqe: Fix potential memory leak when pinning memory
Documentation:Update Documentation/zh_CN/arm64/memory.txt
Documentation:Update Documentation/zh_CN/arm64/booting.txt
Documentation:Chinese translation of Documentation/arm64/tagged-pointers.txt
raw: set range for MAX_RAW_DEVS
raw: test against runtime value of max_raw_minors
Drivers: hv: vmbus: Don't timeout during the initial connection with host
Drivers: hv: vmbus: Specify the target CPU that should receive notification
VME: Correct read/write alignment algorithm
mei: don't unset read cb ptr on reset
mei: clear write cb from waiting list on reset
This reverts commit 01e219e8069516cdb98594d417b8bb8d906ed30d.
David Sterba found a different way to provide these features without adding a new
ioctl. We haven't released any progs with this ioctl yet, so I'm taking this out
for now until we finalize things.
Signed-off-by: Chris Mason <clm@fb.com>
Signed-off-by: David Sterba <dsterba@suse.cz>
CC: Jeff Mahoney <jeffm@suse.com>
Pull x86 fixes from Peter Anvin:
"A collection of small fixes:
- There still seem to be problems with asm goto which requires the
empty asm hack.
- If SMAP is disabled at compile time, don't enable it nor try to
interpret a page fault as an SMAP violation.
- Fix a case of unbounded recursion while tracing"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, smap: smap_violation() is bogus if CONFIG_X86_SMAP is off
x86, smap: Don't enable SMAP if CONFIG_X86_SMAP is disabled
compiler/gcc4: Make quirk for asm_volatile_goto() unconditional
x86: Use preempt_disable_notrace() in cycles_2_ns()
Pull ACPI and power management fixes from Rafael Wysocki:
"These include a fix for a recent intel_pstate regression, a fix for a
regression in the ACPI-based PCI hotplug (ACPIPHP) code introduced
during the 3.12 cycle, fixes for two bugs in the ACPI core introduced
recently and a MAINTAINERS update related to cpufreq.
Specifics:
- Fix for a recent regression in the intel_pstate driver that
introduced a race condition causing systems to crash during
initialization in some situations. This removes the affected code
altogether. From Dirk Brandewie.
- ACPIPHP fix for a regression introduced during the 3.12 cycle
causing devices to be dropped as a result of bus check
notifications after system resume on some systems due to the way
ACPIPHP interprets _STA return values (arguably incorrectly). From
Mika Westerberg.
- ACPI dock driver fix for a problem causing docking to fail due to a
check that always fails after recent ACPI core changes (found by
code inspection).
- ACPI container driver fix to prevent memory from being leaked in an
error code path after device_register() failures.
- Update of the arm_big_little cpufreq driver maintainer's e-mail
address"
* tag 'pm+acpi-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
MAINTAINERS / cpufreq: update Sudeep's email address
intel_pstate: Remove energy reporting from pstate_sample tracepoint
ACPI / container: Fix error code path in container_device_attach()
ACPI / hotplug / PCI: Relax the checking of _STA return values
ACPI / dock: Use acpi_device_enumerated() to check if dock is present
Pull block IO fixes from Jens Axboe:
"Second round of updates and fixes for 3.14-rc2. Most of this stuff
has been queued up for a while. The notable exception is the blk-mq
changes, which are naturally a bit more in flux still.
The pull request contains:
- Two bug fixes for the new immutable vecs, causing crashes with raid
or swap. From Kent.
- Various blk-mq tweaks and fixes from Christoph. A fix for
integrity bio's from Nic.
- A few bcache fixes from Kent and Darrick Wong.
- xen-blk{front,back} fixes from David Vrabel, Matt Rushton, Nicolas
Swenson, and Roger Pau Monne.
- Fix for a vec miscount with integrity vectors from Martin.
- Minor annotations or fixes from Masanari Iida and Rashika Kheria.
- Tweak to null_blk to do more normal FIFO processing of requests
from Shlomo Pongratz.
- Elevator switching bypass fix from Tejun.
- Softlockup in blkdev_issue_discard() fix when !CONFIG_PREEMPT from
me"
* 'for-linus' of git://git.kernel.dk/linux-block: (31 commits)
block: add cond_resched() to potentially long running ioctl discard loop
xen-blkback: init persistent_purge_work work_struct
blk-mq: pair blk_mq_start_request / blk_mq_requeue_request
blk-mq: dont assume rq->errors is set when returning an error from ->queue_rq
block: Fix cloning of discard/write same bios
block: Fix type mismatch in ssize_t_blk_mq_tag_sysfs_show
blk-mq: rework flush sequencing logic
null_blk: use blk_complete_request and blk_mq_complete_request
virtio_blk: use blk_mq_complete_request
blk-mq: rework I/O completions
fs: Add prototype declaration to appropriate header file include/linux/bio.h
fs: Mark function as static in fs/bio-integrity.c
block/null_blk: Fix completion processing from LIFO to FIFO
block: Explicitly handle discard/write same segments
block: Fix nr_vecs for inline integrity vectors
blk-mq: Add bio_integrity setup to blk_mq_make_request
blk-mq: initialize sg_reserved_size
blk-mq: handle dma_drain_size
blk-mq: divert __blk_put_request for MQ ops
blk-mq: support at_head inserations for blk_execute_rq
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull RDMA/InfiniBand fixes from Roland Dreier:
- Fix some rough edges from the "IP addressing for IBoE" merge
- Other misc fixes, mostly to hardware drivers
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (21 commits)
RDMA/ocrdma: Fix load time panic during GID table init
RDMA/ocrdma: Fix traffic class shift
IB/iser: Fix use after free in iser_snd_completion()
IB/iser: Avoid dereferencing iscsi_iser conn object when not bound to iser connection
IB/usnic: Fix smatch endianness error
IB/mlx5: Remove dependency on X86
mlx5: Add include of <linux/slab.h> because of kzalloc()/kfree() use
IB/qib: Add missing serdes init sequence
RDMA/cxgb4: Add missing neigh_release in LE-Workaround path
IB: Report using RoCE IP based gids in port caps
IB/mlx4: Build the port IBoE GID table properly under bonding
IB/mlx4: Do IBoE GID table resets per-port
IB/mlx4: Do IBoE locking earlier when initializing the GID table
IB/mlx4: Move rtnl locking to the right place
IB/mlx4: Make sure GID index 0 is always occupied
IB/mlx4: Don't allocate range of steerable UD QPs for Ethernet-only device
RDMA/amso1100: Fix error return code
RDMA/nes: Fix error return code
IB/mlx5: Don't set "block multicast loopback" capability
IB/mlx5: Fix binary compatibility with libmlx5
'ocrdma', 'qib' and 'usnic' into for-next
Tommi noticed a 'funny' lock class name: "%s#5" from a lock acquired in
process_one_work().
Maybe #fmt plus #args could be used as the lock_name to give some more
information for some fmt string like the above.
__builtin_constant_p() check is removed (as there seems no good way to
check all the variables in args list). However, by removing the check,
it only adds two additional "s for those constants.
Some lockdep name examples printed out after the change:
lockdep name wq->name
"events_long" events_long
"%s"("khelper") khelper
"xfs-data/%s"mp->m_fsname xfs-data/dm-3
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
On some architectures (for example, arm), we don't end up indirectly
pulling in the declaration of kzalloc() and kfree(), and so building
anything that includes <linux/mlx5/driver.h> breaks. Fix this by adding
an explicit include to get the declaration.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
For userspace RoCE UD QPs we need to know the GID format that the
kernel uses, e.g when working over older kernels. For that end, add a
new port capability IB_PORT_IP_BASED_GIDS and report it when query
port is issued.
Signed-off-by: Moni Shoua <monis@mellanox.co.il>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
Will be used by upcoming ipv4 forward path change that needs to
determine feature mask using skb->dst->dev instead of skb->dev.
