Signed-off-by: Thomas Graf <tgraf@suug.ch>
Adds rtnl_notify() to send rtnetlink notification messages and
rtnl_set_sk_err() to report notification errors as socket
errors in order to indicate the need of a resync due to loss
of events.
nlmsg_report() is added to properly document the meaning of
NLM_F_ECHO.
Adds nlmsg_notify() implementing proper notification logic. The
message is multicasted to all listeners in the group. The
applications the requests orignates from can request a unicast
back report in which case said socket will be excluded from the
multicast to avoid duplicated notifications.
nlmsg_multicast() is extended to take allocation flags to
allow notification in atomic contexts.
Signed-off-by: Martin Bligh <mbligh@google.com>
- make the following needlessly global functions static:
- dn_fib.c: dn_fib_sync_down()
- dn_fib.c: dn_fib_sync_up()
- dn_rules.c: dn_fib_rule_action()
- remove the following unneeded prototype:
- dn_fib.c: dn_cache_dump()
Make the following needlessly global code static:
- fib6_walker_lock
- struct fib6_walker_list
- fib6_walk_continue()
- fib6_walk()
Increase the number of possible routing tables to 2^32 by replacing the
fixed sized array of pointers by a hash table and replacing iterations
over all possible table IDs by hash table walking.
Increase number of possible routing tables to 2^32 by replacing iterations
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute
to hold 32 bit routing table IDs. Usespace compatibility is provided by
continuing to accept and send the rtm_table field, but because of its
limited size it can only carry the low 8 bits of the table ID. This
implies that if larger IDs are used, _all_ userspace programs using them
need to use RTA_TABLE.
Use u32 for routing table IDs in net/ipv4 and net/decnet in preparation of
support for a larger number of routing tables. net/ipv6 already uses u32
everywhere and needs no further changes. No functional changes are made by
this patch.
Rather than opencoding the mask, it looks better to use ALIGN()
macro from kernel.h.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
The sock_register() doesn't change the family, so the protocols can
define it read-only. No caller ever checks return value from
sock_unregister()
Three values in net_proto_family are defined but never used.
This patch converts the DECnet rules code to use the generic
rules system created by Thomas Graf <tgraf@suug.ch>.
Signed-off-by: Steven Whitehouse <steve@chygwyn.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
Right now most inet_lookup_* functions take a host-order hnum instead
of a network-order dport because that's how it is represented
internally.
This means that users of these functions have to be careful about
using the right byte-order. To add more confusion, inet_lookup takes
a network-order dport unlike all other functions.
So this patch changes all visible inet_lookup functions to take a
dport and move all dport->hnum conversion inside them.
By modern standards this function is way too big to be inlined. It's
even bigger than __inet_lookup_listener :)
The value is_setbyuser from struct ip_options is never used and set
only one time (http://linux-net.osdl.org/index.php/TODO#IPV4).
This little patch removes it from the kernel source.
Signed-off-by: Louis Nyffenegger <louis.nyffenegger@gmail.com>
As noted by Adrian Bunk this function is totally unused.
This patch makes needlessly global code static.
This patch implements wrapper functions that provide a convenient way
to access the sockets API for in-kernel users like sunrpc, cifs &
ocfs2 etc and any future users.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: James Morris <jmorris@namei.org>
rtnetlink_rcv_msg() is not longer required to parse attributes
for the neighbour tables layer, remove dependency on obsolete and
buggy rta_buf.
Moves netlink neighbour bits to linux/neighbour.h. Also
moves bits to be exported to userspace from net/neighbour.h
to linux/neighbour.h and removes __KERNEL__ guards, userspace
is not supposed to be using it.
for the neighbour layer, remove dependency on obsolete and
buggy rta_buf.
Update hardware checksums incrementally to avoid breaking GSO.
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose
checksum still needs to be completed) and CHECKSUM_COMPLETE (for
incoming packets, device supplied full checksum).
Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3.
Adds:
nlmsg_get_pos() return current position in message
nlmsg_trim() trim part of message
nla_reserve_nohdr(skb, len) reserve room for an attribute w/o hdr
nla_put_nohdr(skb, len, data) add attribute w/o hdr
nla_find_nested() find attribute in nested attributes
Fixes nlmsg_new() to take allocation flags and consider size.
Adds support for policy routing rules including a new
local table for routes with a local destination.
Derived from net/ipv/fib_rules.c
Adds the framework to support multiple IPv6 routing tables.
Currently all automatically generated routes are put into the
same table. This could be changed at a later point after
considering the produced locking overhead.
Add NetLabel support to the SELinux LSM and modify the
socket_post_create() LSM hook to return an error code. The most
significant part of this patch is the addition of NetLabel hooks into
the following SELinux LSM hooks:
* selinux_file_permission()
* selinux_socket_sendmsg()
* selinux_socket_post_create()
* selinux_socket_sock_rcv_skb()
* selinux_socket_getpeersec_stream()
* selinux_socket_getpeersec_dgram()
* selinux_sock_graft()
* selinux_inet_conn_request()
The basic reasoning behind this patch is that outgoing packets are
"NetLabel'd" by labeling their socket and the NetLabel security
attributes are checked via the additional hook in
selinux_socket_sock_rcv_skb(). NetLabel itself is only a labeling
mechanism, similar to filesystem extended attributes, it is up to the
SELinux enforcement mechanism to perform the actual access checks.
In addition to the changes outlined above this patch also includes
some changes to the extended bitmap (ebitmap) and multi-level security
(mls) code to import and export SELinux TE/MLS attributes into and out
of NetLabel.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Add support for the Commercial IP Security Option (CIPSO) to the IPv4
network stack. CIPSO has become a de-facto standard for
trusted/labeled networking amongst existing Trusted Operating Systems
such as Trusted Solaris, HP-UX CMW, etc. This implementation is
designed to be used with the NetLabel subsystem to provide explicit
packet labeling to LSM developers.
The CIPSO/IPv4 packet labeling works by the LSM calling a NetLabel API
function which attaches a CIPSO label (IPv4 option) to a given socket;
this in turn attaches the CIPSO label to every packet leaving the
socket without any extra processing on the outbound side. On the
inbound side the individual packet's sk_buff is examined through a
call to a NetLabel API function to determine if a CIPSO/IPv4 label is
present and if so the security attributes of the CIPSO label are
returned to the caller of the NetLabel API function.
Changes to the core network stack to support the NetLabel subsystem. This
includes changes to the IPv4 option handling to support CIPSO labels.
This automatically labels the TCP, Unix stream, and dccp child sockets
as well as openreqs to be at the same MLS level as the peer. This will
result in the selection of appropriately labeled IPSec Security
Associations.
This also uses the sock's sid (as opposed to the isec sid) in SELinux
enforcement of secmark in rcv_skb and postroute_last hooks.
Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com>
This defaults the label of socket-specific IPSec policies to be the
same as the socket they are set on.
This labels the flows that could utilize IPSec xfrms at the points the
flows are defined so that IPSec policy and SAs at the right label can
be used.
The following protos are currently not handled, but they should
continue to be able to use single-labeled IPSec like they currently
do.
ipmr
ip_gre
ipip
igmp
sit
sctp
ip6_tunnel (IPv6 over IPv6 tunnel device)
decnet
This implements a seemless mechanism for xfrm policy selection and
state matching based on the flow sid. This also includes the necessary
SELinux enforcement pieces.
This adds security to flow key for labeling of flows as also to allow
for making flow cache lookups based on the security label seemless.
This adds security for IP sockets at the sock level. Security at the
sock level is needed to enforce the SELinux security policy for
security associations even when a sock is orphaned (such as in the TCP
LAST_ACK state).
This will also be used to enforce SELinux controls over data arriving
at or leaving a child socket while it's still waiting to be accepted.
* git://git.infradead.org/~dwmw2/hdroneline:
[HEADERS] One line per header in Kbuild files to reduce conflicts
Manual (trivial) conflict resolution in include/asm-s390/Kbuild
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (64 commits)
[BLOCK] dm-crypt: trivial comment improvements
[CRYPTO] api: Deprecate crypto_digest_* and crypto_alg_available
[CRYPTO] padlock: Convert padlock-sha to use crypto_hash
[CRYPTO] users: Use crypto_comp and crypto_has_*
[CRYPTO] api: Add crypto_comp and crypto_has_*
[CRYPTO] users: Use crypto_hash interface instead of crypto_digest
[SCSI] iscsi: Use crypto_hash interface instead of crypto_digest
[CRYPTO] digest: Remove old HMAC implementation
[CRYPTO] doc: Update documentation for hash and me
[SCTP]: Use HMAC template and hash interface
[IPSEC]: Use HMAC template and hash interface
[CRYPTO] tcrypt: Use HMAC template and hash interface
[CRYPTO] hmac: Add crypto template implementation
[CRYPTO] digest: Added user API for new hash type
[CRYPTO] api: Mark parts of cipher interface as deprecated
[PATCH] scatterlist: Add const to sg_set_buf/sg_init_one pointer argument
[CRYPTO] drivers: Remove obsolete block cipher operations
[CRYPTO] users: Use block ciphers where applicable
[SUNRPC] GSS: Use block ciphers where applicable
[IPSEC] ESP: Use block ciphers where applicable
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (44 commits)
[S390] hypfs crashes with invalid mount option.
[S390] cio: subchannel evaluation function operates without lock
[S390] cio: always query all paths on path verification.
[S390] cio: update path groups on logical CHPID changes.
[S390] cio: subchannels in no-path state.
[S390] Replace nopav-message on VM.
[S390] set modalias for ccw bus uevents.
[S390] Get rid of DBG macro.
[S390] Use alternative user-copy operations for new hardware.
[S390] Make user-copy operations run-time configurable.
[S390] Cleanup in signal handling code.
[S390] Cleanup in page table related code.
[S390] Linux API for writing z/VM APPLDATA Monitor records.
[S390] xpram off by one error.
[S390] Remove kexec experimental flag.
[S390] cleanup appldata.
[S390] fix typo in vmcp.
[S390] Kernel stack overflow handling.
[S390] qdio slsb processing state.
[S390] Missing initialization in common i/o layer.
* git://git.infradead.org/mtd-2.6:
Remove accidentally-added include/linux/utsrelease.h
Revert "[MTD] blkdev helper code: fix printk format warning"
[MTD] Add SSFDC (SmartMedia) read-only translation layer
[MTD] pmc551 pci cleanup
[MTD] pmc551 use kzalloc
[MTD] pmc551 whitespace cleanup
[MTD] Remove iq80310 map driver
[MTD NAND] Fix in typo ndfc.c causing wrong ECC layout
[MTD] physmap: add power management support
ioremap balanced with iounmap for drivers/mtd subsystem
[MTD] Switch to pci_get_device and do ref counting
[MTD] Fix ixp4xx partition parsing.
[JFFS2] Remove unneeded ifdefs from jffs2_fs_i.h
[MTD NAND] Remove old code in au1550nd.c
[MTD] Unlock NOR flash automatically where necessary
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (114 commits)
[POWERPC] Fix ohare IDE irq workaround on old powermacs
[POWERPC] EEH: Power4 systems sometimes need multiple resets.
[POWERPC] Include <asm/mmu.h> in arch/powerpc/sysdev/fsl_soc.h for phys_addr_t.
[POWERPC] Demacrofy arch/powerpc/platforms/maple/pci.c
[POWERPC] Maple U3 HT - reject inappropriate config space access
[POWERPC] Fix IPIC pending register assignments
[POWERPC] powerpc: fix building gdb against asm/ptrace.h
[POWERPC] Remove DISCONTIGMEM cruft from page.h
[POWERPC] Merge iSeries i/o operations with the rest
[POWERPC] 40x: Fix debug status register defines
[POWERPC] Fix compile error in sbc8560
[POWERPC] EEH: support MMIO enable recovery step
[POWERPC] EEH: enable MMIO/DMA on frozen slot
[POWERPC] EEH: code comment cleanup
[POWERPC] EEH: balance pcidev_get/put calls
[POWERPC] PPC: Fix xmon stack frame address in backtrace
[POWERPC] Add AT_PLATFORM value for Xilinx Virtex-4 FX
[POWERPC] Start arch/powerpc/boot code reorganization
[POWERPC] Define of_read_ulong helper
[POWERPC] iseries: eliminate a couple of warnings
ioremap must be balanced by an iounmap and failing to do so can result
in a memory leak.
Tested (compilation only) with:
- allmodconfig
- Modifying drivers/mtd/maps/Kconfig and drivers/mtd/nand/Kconfig to
make sure that the changed file is compiling without warning
Signed-off-by: Amol Lad <amol@verismonetworks.com>
