Move disk->holder_dir to part0->holder_dir. Kill now mostly
superflous bdev_get_holder().
While at it, kill superflous kobject_get/put() around holder_dir,
slave_dir and cmd_filter creation and collapse
disk_sysfs_add_subdirs() into register_disk(). These serve no purpose
but obfuscating the code.
Move disk->policy to part0->policy. Implement and use get_disk_ro().
Now that capacity and __dev are moved to part0, part0 and others can
share the same method.
Move disk->__dev to part0->__dev. This simplifies bdget_disk() and
lookup_devt() and allows common sysfs attributes to be unified.
part_to_disk() is updated to handle part0 -> disk.
Updated to include a fix from Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>,
he writes:
"part0 is a "special" partition and doesn't need to have capacity set - this
fixes regression caused by "block: move __dev from disk to part0" commit."
Move disk->capacity to part0->nr_sects and convert all users who
directly accessed the field to use {get|set}_capacity(). This is done
early to allow the __dev field to be moved.
genhd and partition code handled disk and partitions separately. All
information about the whole disk was in struct genhd and partitions in
struct hd_struct. However, the whole disk (part0) and other
partitions have a lot in common and the data structures end up having
good number of common fields and thus separate code paths doing the
same thing. Also, the partition array was indexed by partno - 1 which
gets pretty confusing at times.
This patch introduces partition 0 and makes the partition array
indexed by partno. Following patches will unify the handling of disk
and parts piece-by-piece.
This patch also implements disk_partitionable() which tests whether a
disk is partitionable. With coming dynamic partition array change,
the most common usage of disk_max_parts() will be testing whether a
disk is partitionable and the number of max partitions will become
much less important.
Implement {disk|part}_to_dev() and use them to access generic device
instead of directly dereferencing {disk|part}->dev. To make sure no
user is left behind, rename generic devices fields to __dev.
This is in preparation of unifying partition 0 handling with other
partitions.
With extended minors and the soon-to-follow debug feature, large minor
numbers for block devices will be common. This patch does the
followings to make printouts pretty.
* Adapt print formats such that large minors don't break the
formatting.
* For extended MAJ:MIN, %02x%02x for MAJ:MIN used in
printk_all_partitions() doesn't cut it anymore. Update it such that
%03x:%05x is used if either MAJ or MIN doesn't fit in %02x.
* Implement ext_range sysfs attribute which shows total minors the
device can use including both conventional minor space and the
extended one.
Implement extended device numbers. A block driver can tell block
layer that it wants to use extended device numbers. After the usual
minor space is used up, block layer automatically allocates devt's
from EXT_BLOCK_MAJOR.
Currently only one major number is allocated for this but as the
allocation is strictly on-demand, ~1mil minor space under it should
suffice unless the system actually has more than ~1mil partitions and
if that ever happens adding more majors to the extended devt area is
easy.
Due to internal implementation issues, the first partition can't be
allocated on the extended area. In other words, genhd->minors should
at least be 1. This limitation will be lifted by later changes.
There are two variants of stat functions - ones prefixed with double
underbars which don't care about preemption and ones without which
disable preemption before manipulating per-cpu counters. It's unclear
whether the underbarred ones assume that preemtion is disabled on
entry as some callers don't do that.
This patch unifies diskstats access by implementing disk_stat_lock()
and disk_stat_unlock() which take care of both RCU (for partition
access) and preemption (for per-cpu counter access). diskstats access
should always be enclosed between the two functions. As such, there's
no need for the versions which disables preemption. They're removed
and double underbars ones are renamed to drop the underbars. As an
extra argument is added, there's no danger of using the old version
unconverted.
disk_stat_lock() uses get_cpu() and returns the cpu index and all
diskstat functions which access per-cpu counters now has @cpu
argument to help RT.
This change adds RCU or preemption operations at some places but also
collapses several preemption ops into one at others. Overall, the
performance difference should be negligible as all involved ops are
very lightweight per-cpu ones.
disk->part[] is protected by its matching bdev's lock. However,
non-critical accesses like collecting stats and printing out sysfs and
proc information used to be performed without any locking. As
partitions can come and go dynamically, partitions can go away
underneath those non-critical accesses. As some of those accesses are
writes, this theoretically can lead to silent corruption.
This patch fixes the race by using RCU for the partition array and dev
reference counter to hold partitions.
* Rename disk->part[] to disk->__part[] to make sure no one outside
genhd layer proper accesses it directly.
* Use RCU for disk->__part[] dereferencing.
* Implement disk_{get|put}_part() which can be used to get and put
partitions from gendisk respectively.
* Iterators are implemented to help iterate through all partitions
safely.
* Functions which require RCU readlock are marked with _rcu suffix.
* Use disk_put_part() in __blkdev_put() instead of directly putting
the contained kobject.
* Implement disk_devt() and part_devt() and use them to directly
access devt instead of computing it from ->major and ->first_minor.
Note that all references to ->major and ->first_minor outside of
block layer is used to determine devt of the disk (the part0) and as
->major and ->first_minor will continue to represent devt for the
disk, converting these users aren't strictly necessary. However,
convert them for consistency.
* Implement disk_max_parts() to avoid directly deferencing
genhd->minors.
* Update bdget_disk() such that it doesn't assume consecutive minor
space.
* Move devt computation from register_disk() to add_disk() and make it
the only one (all other usages use the initially determined value).
These changes clean up the code and will help disk->part dereference
fix and extended block device numbers.
In hd_struct, @partno is used to denote partition number and a number
of other places use @part to denote hd_struct. Functions use @part
and @index instead. This causes confusion and makes it difficult to
use consistent variable names for hd_struct. Always use @partno if a
variable represents partition number.
Also, print out functions use @f or @part for seq_file argument. Use
@seqf uniformly instead.
This patch makes the following misc updates in preparation for
disk->part dereference fix and extended block devt support.
* implment part_to_disk()
* fix comment about gendisk->part indexing
* rename get_part() to disk_map_sector()
* don't use n which is always zero while printing disk information in
diskstats_show()
Iterating over entries using callback usually isn't too fun especially
when the entry being iterated over can't be manipulated freely. This
patch converts class->p->class_devices to klist and implements class
device iterator so that the users can freely build their own control
structure. The users are also free to call back into class code
without worrying about locking.
class_for_each_device() and class_find_device() are converted to use
the new iterators, so their users don't have to worry about locking
anymore either.
Note: This depends on klist-dont-iterate-over-deleted-entries patch
because class_intf->add/remove_dev() depends on proper synchronization
with device removal.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
A klist entry is kept on the list till all its current iterations are
finished; however, a new iteration after deletion also iterates over
deleted entries as long as their reference count stays above zero.
This causes problems for cases where there are users which iterate
over the list while synchronized against list manipulations and
natuarally expect already deleted entries to not show up during
iteration.
This patch implements dead flag which gets set on deletion so that
iteration can skip already deleted entries. The dead flag piggy backs
on the lowest bit of knode->n_klist and only visible to klist
implementation proper.
While at it, drop klist_iter->i_head as it's redundant and doesn't
offer anything in semantics or performance wise as klist_iter->i_klist
is dereferenced on every iteration anyway.
Cc: Alan Stern <stern@rowland.harvard.edu>
raid5 can overflow with more than 255 stripes, and we can increase it
to an int for free on both 32 and 64-bit archs due to the padding.
Remove hw_segments field from struct bio and struct request. Without virtual
merge accounting they have no purpose.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Remove virtual merge accounting.
requests
struct request has an ioprio member but it is never updated because
currently bios do not hold io context information. The implication of
this is that virtio_blk ends up passing useless information to the
backend driver.
That said, some IO schedulers such as CFQ do store io context
information in struct request, but use private members for that, which
means that that information cannot be directly accessed in a IO
scheduler-independent way.
This patch adds a function to obtain the ioprio of a request. We should
avoid accessing ioprio directly and use this function instead, so that
its users do not have to care about future changes in block layer
structures or what the currently active IO controller is.
This patch does not introduce any functional changes but paves the way
for future clean-ups and enhancements.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
It was only used by ps3disk, and it should probably have been
REQ_TYPE_LINUX_BLOCK + REQ_LB_OP_FLUSH.
But blkdev_issue_discard() still emits requests which are interpreted as
soft barriers, because naïve callers might otherwise issue subsequent
writes to those same sectors, which might cross on the queue (if they're
reallocated quickly enough).
Callers still _can_ issue non-barrier discard requests, but they have to
take care of queue ordering for themselves.
We may well want mkfs tools to use this to mark the whole device as
unwanted before they format it, for example.
The ioctl takes a pair of uint64_ts, which are start offset and length
in _bytes_. Although at the moment it might make sense for them both to
be in 512-byte sectors, I don't want to limit the ABI to that.
Some block devices benefit from a hint that they can forget the contents
of certain sectors. Add basic support for this to the block core, along
with a 'blkdev_issue_discard()' helper function which issues such
requests.
The caller doesn't get to provide an end_io functio, since
blkdev_issue_discard() will automatically split the request up into
multiple bios if appropriate. Neither does the function wait for
completion -- it's expected that callers won't care about when, or even
_if_, the request completes. It's only a hint to the device anyway. By
definition, the file system doesn't _care_ about these sectors any more.
[With feedback from OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> and
Jens Axboe <jens.axboe@oracle.com]
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: workaround for bogus gcc warning in ide_sysfs_register_port()
ide-cd: Optiarc DVD RW AD-7200A does play audio
IDE: Fix platform device registration in Swarm IDE driver (v2)
ide-dma: fix ide_build_dmatable() for TRM290
ide-cd: temporary tray close fix
This one fixes http://bugzilla.kernel.org/show_bug.cgi?id=11602.
A more generic fix for drives which cannot autoclose tray will follow.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
[bart: add an extra parentheses for consistency with the rest of kernel code]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
include/linux/stacktrace.h:13: warning:
'struct task_struct' declared inside parameter list
(This might be a hard error on sparc64, which uses this header and has
-Werror)
Reported-by: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Arjan van de Ven <arjan@infradead.org>
Rework of SMTC support to make it work with the new clock event system,
allowing "tickless" operation, and to make it compatible with the use of
the "wait_irqoff" idle loop. The new clocking scheme means that the
previously optional IPI instant replay mechanism is now required, and has
been made more robust.
Signed-off-by: Kevin D. Kissell <kevink@paralogos.com>
Though from a hardware perspective it would be sensible to use only a
32-bit unsigned int type Linux defines interrupt flags to be stored in
an unsigned long and nothing else.
The previous patch db203d53d474aa068984e409d807628f5841da1b ("mm:
tiny-shmem fix lock ordering: mmap_sem vs i_mutex") to fix the lock
ordering in tiny-shmem breaks shared anonymous and IPC memory on NOMMU
architectures because it was using the expanding truncate to signal ramfs
to allocate a physically contiguous RAM backing the inode (otherwise it is
unusable for "memory mapping" it to userspace).
However do_truncate is what caused the lock ordering error, due to it
taking i_mutex. In this case, we can actually just call ramfs directly to
allocate memory for the mapping, rather than go via truncate.
Acked-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Matt Mackall <mpm@selenic.com>
Fix inotify lock order reversal with mmap_sem due to holding locks over
copy_to_user.
Reported-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
Tested-by: "Daniel J Blueman" <daniel.blueman@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
af_key: Free dumping state on socket close
XFRM,IPv6: initialize ip6_dst_blackhole_ops.kmem_cachep
ipv6: NULL pointer dereferrence in tcp_v6_send_ack
tcp: Fix NULL dereference in tcp_4_send_ack()
sctp: Fix kernel panic while process protocol violation parameter
iucv: Fix mismerge again.
ipsec: Fix pskb_expand_head corruption in xfrm_state_check_space
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
hrtimer: prevent migration of per CPU hrtimers
hrtimer: mark migration state
hrtimer: fix migration of CB_IRQSAFE_NO_SOFTIRQ hrtimers
hrtimer: migrate pending list on cpu offline
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Since call to function sctp_sf_abort_violation() need paramter 'arg' with
'struct sctp_chunk' type, it will read the chunk type and chunk length from
the chunk_hdr member of chunk. But call to sctp_sf_violation_paramlen()
always with 'struct sctp_paramhdr' type's parameter, it will be passed to
sctp_sf_abort_violation(). This may cause kernel panic.
|-- sctp_sf_abort_violation()
|-- sctp_make_abort_violation()
This patch fixed this problem. This patch also fix two place which called
sctp_sf_violation_paramlen() with wrong paramter type.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Impact: per CPU hrtimers can be migrated from a dead CPU
The hrtimer code has no knowledge about per CPU timers, but we need to
prevent the migration of such timers and warn when such a timer is
active at migration time.
Explicitely mark the timers as per CPU and use a more understandable
mode descriptor for the interrupts safe unlocked callback mode, which
is used by hrtimer_sleeper and the scheduler code.
Impact: during migration active hrtimers can be seen as inactive
The migration code removes the hrtimers from the queues of the dead
CPU and sets the state temporary to INACTIVE. The enqueue code sets it
to ACTIVE/PENDING again.
Prevent that the wrong state can be seen by using a separate migration
state bit.
On x86_64 the gdb serial register structure defines the PS (also known
as eflags), CS and SS registers as 4 bytes entities.
This patch splits the x86_64 regnames enum into a 32 and 64 version to
account for the 32 bit entities in the gdb serial packets.
Also the program counter is properly filled in for the sleeping
threads.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The BX and DX registers in the gdb serial register packet need to be
flipped for gdb to receive the correct data.
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fixe the definition of PTRS_PER_PGD
[MIPS] au1000: Fix gpio direction
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make
use of it too.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: fix put_data error handling
9p: use an IS_ERR test rather than a NULL test
9p: introduce missing kfree
9p-trans_fd: fix and clean up module init/exit paths
9p-trans_fd: don't do fs segment mangling in p9_fd_poll()
9p-trans_fd: clean up p9_conn_create()
9p-trans_fd: fix trans_fd::p9_conn_destroy()
9p: implement proper trans module refcounting and unregistration
9p trans modules aren't refcounted nor were they unregistered
properly. Fix it.
* Add 9p_trans_module->owner and reference the module on each trans
instance creation and put it on destruction.
* Protect v9fs_trans_list with a spinlock. This isn't strictly
necessary as the list is manipulated only during module loading /
unloading but it's a good idea to make the API safe.
* Unregister trans modules when the corresponding module is being
unloaded.
* While at it, kill unnecessary EXPORT_SYMBOL on p9_trans_fd_init().
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
When we use > 4KB's page size the original definition is not consistent
with PGDIR_SIZE. For exeample, if we use 16KB page size the PGDIR_SHIFT is
(14-2) + 14 = 26, PGDIR_SIZE is 2^26,so the PTRS_PER_PGD should be:
2^32/2^26 = 2^6
but the original definition of PTRS_PER_PGD is 4096 (PGDIR_ORDER = 0).
So, this definition needs to be consistent with the PGDIR_SIZE.
And the new definition is consistent with the PGD init in pagetable_init().
Signed-off-by: Dajie Tan <jiankemeng@gmail.com>
