path: root/include
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add driver for Atmel AT42QT2160 Sensor Chip Input: max7359 - use threaded IRQs Input: add driver for Maxim MAX7359 key switch controller Input: add driver for ADP5588 QWERTY I2C Keypad Input: add touchscreen driver for MELFAS MCS-5000 controller Input: add driver for OpenCores Keyboard Controller Input: dm355evm_keys - remove dm355evm_keys_hardirq Input: synaptics_i2c - switch to using __cancel_delayed_work() Input: ad7879 - add support for AD7889 Input: atkbd - rely on input core to restore state on resume Input: add generic suspend and resume for input devices Input: libps2 - additional locking for i8042 ports
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Propagate 'fsc' mount option through automounts sunrpc/rpc_pipe: fix kernel-doc notation sunrpc: xdr_xcode_hyper helpers cannot presume 64-bit alignment NFS: Add nfs_alloc_parsed_mount_data NFS/RPC: fix problems with reestablish_timeout and related code. NFS: Get rid of the NFS_MOUNT_VER3 and NFS_MOUNT_TCP flags
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: Update documentation to add fscache related bits 9p: Add fscache support to 9p 9p: Fix the incorrect update of inode size in v9fs_file_write() 9p: Use the i_size_[read, write]() macros instead of using inode->i_size directly.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: do not destroy the avc_cache_nodep KEYS: Have the garbage collector set its timer for live expired keys tpm-fixup-pcrs-sysfs-file-update creds_are_invalid() needs to be exported for use by modules: include/linux/cred.h: fix build Fix trivial BUILD_BUG_ON-induced conflicts in drivers/char/tpm/tpm.c
2009-09-23sunrpc: xdr_xcode_hyper helpers cannot presume 64-bit alignmentBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23serial core: fix new kernel-doc warningsRandy Dunlap
Fix new kernel-doc warnings in serial_core.[hc] files. Warning(include/linux/serial_core.h:485): No description found for parameter 'uport' Warning(include/linux/serial_core.h:485): Excess function parameter 'port' description in 'uart_handle_dcd_change' Warning(include/linux/serial_core.h:511): No description found for parameter 'uport' Warning(include/linux/serial_core.h:511): Excess function parameter 'port' description in 'uart_handle_cts_change' Warning(drivers/serial/serial_core.c:2437): No description found for parameter 'uport' Warning(drivers/serial/serial_core.c:2437): Excess function parameter 'port' description in 'uart_add_one_port' Warning(drivers/serial/serial_core.c:2509): No description found for parameter 'uport' Warning(drivers/serial/serial_core.c:2509): Excess function parameter 'port' description in 'uart_remove_one_port' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-239p: Add fscache support to 9pAbhishek Kulkarni
This patch adds a persistent, read-only caching facility for 9p clients using the FS-Cache caching backend. When the fscache facility is enabled, each inode is associated with a corresponding vcookie which is an index into the FS-Cache indexing tree. The FS-Cache indexing tree is indexed at 3 levels: - session object associated with each mount. - inode/vcookie - actual data (pages) A cache tag is chosen randomly for each session. These tags can be read off /sys/fs/9p/caches and can be passed as a mount-time parameter to re-attach to the specified caching session. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-09-23include/linux/cred.h: fix buildAndrew Morton
mips allmodconfig: include/linux/cred.h: In function `creds_are_invalid': include/linux/cred.h:187: error: `PAGE_SIZE' undeclared (first use in this function) include/linux/cred.h:187: error: (Each undeclared identifier is reported only once include/linux/cred.h:187: error: for each function it appears in.) Fixes commit b6dff3ec5e116e3af6f537d4caedcad6b9e5082a Author: David Howells <dhowells@redhat.com> AuthorDate: Fri Nov 14 10:39:16 2008 +1100 Commit: James Morris <jmorris@namei.org> CommitDate: Fri Nov 14 10:39:16 2008 +1100 CRED: Separate task security context from task_struct I think. It's way too large to be inlined anyway. Dunno if this needs an EXPORT_SYMBOL() yet. Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply: Add driver for the PMU on WM831x PMICs ds2760_battery: Fix integer overflow for time_to_empty_now wm97xx_battery: Convert to dev_pm_ops wm97xx_battery: Use irq to detect charger state wm97xx_battery: Use platform_data wm97xx-core: Pass platform_data to battery ds2760_battery: implement set_charged() feature power_supply: get_by_name and set_charged functionality power_supply: EXPORT_SYMBOL cleanups ds2760_battery: add current_accum module parameter ds2760_battery: handle full_active_uAh == 0 case correctly ds2760_battery: add rated_capacity module parameter ds2760_battery: export more features ds2760_battery: delay power supply registration wm8350_power: Implement charge type property power_supply: Add a charge_type property, and use it for olpc driver olpc_battery: Add an 'error' sysfs device that displays raw errors Revert "power: remove POWER_SUPPLY_PROP_CAPACITY_LEVEL"
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-23Merge branch 'vgaarb-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'vgaarb-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: vgaarb: make client interface config invariant.
2009-09-23Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: (23 commits) intel-iommu: Disable PMRs after we enable translation, not before intel-iommu: Kill DMAR_BROKEN_GFX_WA option. intel-iommu: Fix integer wrap on 32 bit kernels intel-iommu: Fix integer overflow in dma_pte_{clear_range,free_pagetable}() intel-iommu: Limit DOMAIN_MAX_PFN to fit in an 'unsigned long' intel-iommu: Fix kernel hang if interrupt remapping disabled in BIOS intel-iommu: Disallow interrupt remapping if not all ioapics covered intel-iommu: include linux/dmi.h to use dmi_ routines pci/dmar: correct off-by-one error in dmar_fault() intel-iommu: Cope with yet another BIOS screwup causing crashes intel-iommu: iommu init error path bug fixes intel-iommu: Mark functions with __init USB: Work around BIOS bugs by quiescing USB controllers earlier ia64: IOMMU passthrough mode shouldn't trigger swiotlb init intel-iommu: make domain_add_dev_info() call domain_context_mapping() intel-iommu: Unify hardware and software passthrough support intel-iommu: Cope with broken HP DC7900 BIOS iommu=pt is a valid early param intel-iommu: double kfree() intel-iommu: Kill pointless intel_unmap_single() function ... Fixed up trivial include lines conflict in drivers/pci/intel-iommu.c
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (41 commits) regulator: Add some brief design documentation regulator: fix voltage range in da9034 ldo12 regulator/driver: be more specific in nanodoc for is_enabled regulator/lp3971: drop unnecessary initialization regulator: drop 'default n' regulator: fix typos regulator: fix calculation of voltage range in da9034_set_ldo12_voltage() regulator: update a filename in documentation drivers/regulator/Kconfig: fix typo (s/Usersapce/Userspace/) in REGULATOR_USERSPACE_CONSUMER description REGULATOR Handle positive returncode from enable regulator: tps650xx - build fixes for x86_64 Fix some regulator documentation Regulator: Adding TPS65023 and TPS6507x in Kconfig and Makefile Regulator: Add TPS6507x regulator driver Regulator: Add TPS65023 regulator driver regulator: userspace: use sysfs_create_group regulator: Add GPIO enable control to fixed voltage regulator driver Regulator: Implement list_voltage for pcf50633 regulator driver. regulator: regulator_enable() permission checking regulator: Push locking for regulator_is_enabled() out ...
2009-09-23Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: itimers: Add tracepoints for itimer hrtimer: Add tracepoint for hrtimers timers: Add tracepoints for timer_list timers cputime: Optimize jiffies_to_cputime(1) itimers: Simplify arm_timer() code a bit itimers: Fix periodic tics precision itimers: Merge ITIMER_VIRT and ITIMER_PROF Trivial header file include conflicts in kernel/fork.c
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: sbp2: remove a workaround for Momobay FX-3A firewire: sbp2: remove a workaround for Momobay FX-3A firewire: sbp2: fix status reception firewire: core: fix topology map response handler firewire: core: fix race with parallel PCI device probe firewire: core: header file cleanup firewire: ohci: fix Self ID Count register mask (safeguard against buffer overflow) ieee1394: raw1394: Do not leak memory on failed trylock.
2009-09-23Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: remove unneeded includes sfi: Remove unused code SFI: Hook PCI MMCONFIG x86: add arch-specific SFI support SFI: add capability to parse ACPI tables SFI: add platform-independent core support SFI: create linux/sfi.h SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-23Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Clearly mark ACPI drivers as such i2c: Add driver for SMBus Control Method Interface i2c-pnx: Correct use of request_region/request_mem_region MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665 i2c-piix4: Add AMD SB900 SMBus device ID i2c/chips: Remove deprecated pcf8574 driver i2c/chips: Remove deprecated pca9539 driver i2c/chips: Remove deprecated pcf8575 driver gpio/pcf857x: Copy i2c_device_id from old pcf8574 driver i2c/scx200_acb: Provide more information on bus errors i2c: Provide compatibility links for i2c adapters i2c: Convert i2c adapters to bus devices i2c: Convert i2c clients to a device type i2c/tsl2550: Use combined SMBus transactions i2c-taos-evm: Switch echo off to improve performance i2c: Drop unused i2c_driver.id field
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits) USB: Fix sysfs paths in documentation USB: skeleton: fix coding style issues. USB: O_NONBLOCK in read path of skeleton USB: make usb-skeleton honor O_NONBLOCK in write path USB: skel_read really sucks royally USB: Add hub descriptor update hook for xHCI USB: xhci: Support USB hubs. USB: xhci: Set multi-TT field for LS/FS devices under hubs. USB: xhci: Set route string for all devices. USB: xhci: Fix command wait list handling. USB: xhci: Change how xHCI commands are handled. USB: xhci: Refactor input device context setup. USB: xhci: Endpoint representation refactoring. USB: gadget: ether needs to select CRC32 USB: fix USBTMC get_capabilities success handling USB: fix missing error check in probing USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag USB: support for autosuspend in sierra while online USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp ...
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: don't force VIRTIO_F_NOTIFY_ON_EMPTY lguest: cleanup for map_switcher() lguest: use PGDIR_SHIFT for PAE code to allow different PAGE_OFFSET lguest: use set_pte/set_pmd uniformly for real page table entries lguest: move panic notifier registration to its expected place. virtio_blk: add support for cache flush virtio: add virtio IDs file virtio: get rid of redundant VIRTIO_ID_9P definition virtio: make add_buf return capacity remaining virtio_pci: minor MSI-X cleanups
2009-09-23fs: change sys_truncate length parameter typeHeiko Carstens
For this system call user space passes a signed long length parameter, while the kernel side takes an unsigned long parameter and converts it later to signed long again. This has led to bugs in compat wrappers see e.g. dd90bbd5 "powerpc: Add compat_sys_truncate". The s390 compat wrapper for this functions is broken as well since it also performs zero extension instead of sign extension for the length parameter. In addition if hpa comes up with an automated way of generating compat wrappers it would generate a wrong one here. So change the length parameter from unsigned long to long. Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'x86/orig_ax' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland * 'x86/orig_ax' of git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland: x86: ptrace: set TS_COMPAT when 32-bit ptrace sets orig_eax>=0 x86: ptrace: do not sign-extend orig_ax on write x86: syscall_get_nr returns int asm-generic: syscall_get_nr returns int
2009-09-23jbd.h: bitfields should be unsignedH Hartley Sweeten
bitfields should be unsigned. This fixes sparse noise: error: dubious one-bit signed bitfield Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Jan Kara <jack@ucw.cz> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23davinci-fb-frame-buffer-driver-for-ti-da8xx-omap-l1xx-v4Sudhakar Rajashekhara
Since the previous version, return values in ioctl() function have been modified. [akpm@linux-foundation.org: simplify lcd_disable_raster()] Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Signed-off-by: Steve Chen <schen@mvista.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23davinci: fb: Frame Buffer driver for TI DA8xx/OMAP-L1xxSudhakar Rajashekhara
Add LCD controller (LCDC) driver for TI's DA8xx/OMAP-L1xx architecture. LCDC specifications can be found at http://www.ti.com/litv/pdf/sprufm0a. LCDC on DA8xx consists of two independent controllers, the Raster Controller and the LCD Interface Display Driver (LIDD) controller. LIDD further supports character and graphic displays. This patch adds support for the graphic display (Sharp LQ035Q3DG01) found on the DA830 based EVM. The EVM details can be found at: http://support.spectrumdigital.com/boards/dskda830/revc/. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Signed-off-by: Steve Chen <schen@mvista.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> DESC davinci-fb-frame-buffer-driver-for-ti-da8xx-omap-l1xx-fix EDESC From: Andrew Morton <akpm@linux-foundation.org> fix kconfig indenting Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Cc: Steve Chen <schen@mvista.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mfd/gpio: add a GPIO interface to the UCB1400 MFD chip driver via gpiolibMarek Vasut
Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Cc: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23gpio: add MC33880 driverRichard Röjfors
A GPIO driver for the Freescale MC33880 High/Low side switch Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23gpiolib: allow exported GPIO nodes to be named using sysfs linksJani Nikula
Commit 926b663ce8215ba448960e1ff6e58b67a2c3b99b (gpiolib: allow GPIOs to be named) already provides naming on the chip level. This patch provides more flexibility by allowing multiple names where ever in sysfs on a per GPIO basis. Adapted from David Brownell's comments on a similar concept: http://lkml.org/lkml/2009/4/20/203. [randy.dunlap@oracle.com: fix build for CONFIG_GENERIC_GPIO=n] Signed-off-by: Jani Nikula <ext-jani.1.nikula@nokia.com> Acked-by: David Brownell <david-b@pacbell.net> Cc: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: handle TX-only/RX-onlyDavid Brownell
Support two new half-duplex SPI implementation restrictions, for links that talk to TX-only or RX-only devices. (Existing half-duplex flavors support both transfer directions, just not at the same time.) Move spi_async() into the spi.c core, and stop inlining it. Then make that function perform error checks and reject messages that demand more than the underlying controller can support. Based on a patch from Marek Szyprowski which did this only for the bitbanged GPIO driver. Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: add support for device table matchingAnton Vorontsov
With this patch spi drivers can use standard spi_driver.id_table and MODULE_DEVICE_TABLE() mechanisms to bind against the devices. Just like we do with I2C drivers. This is useful when a single driver supports several variants of devices but it is not possible to detect them in run-time (like non-JEDEC chips probing in drivers/mtd/devices/m25p80.c), and when platform_data usage is overkill. This patch also makes life a lot easier on OpenFirmware platforms, since with OF we extensively use proper device IDs in modaliases. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi.h: add missing kernel-doc for struct spi_masterRandy Dunlap
Add missing kernel-doc notation in spi.h for struct spi_master: Warning(include/linux/spi/spi.h:289): No description found for parameter 'mode_bits' Warning(include/linux/spi/spi.h:289): No description found for parameter 'flags' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23ramfs: move RAMFS_MAGIC to include/linux/magic.hmaximilian attems
initramfs userspace likes to use this magic number. Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register module area in generic wayKAMEZAWA Hiroyuki
Some archs define MODULED_VADDR/MODULES_END which is not in VMALLOC area. This is handled only in x86-64. This patch make it more generic. And we can use vread/vwrite to access the area. Fix it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmemmap rangeKAMEZAWA Hiroyuki
Benjamin Herrenschmidt <benh@kernel.crashing.org> pointed out that vmemmap range is not included in KCORE_RAM, KCORE_VMALLOC .... This adds KCORE_VMEMMAP if SPARSEMEM_VMEMMAP is used. By this, vmemmap can be readable via /proc/kcore Because it's not vmalloc area, vread/vwrite cannot be used. But the range is static against the memory layout, this patch handles vmemmap area by the same scheme with physical memory. This patch assumes SPARSEMEM_VMEMMAP range is not in VMALLOC range. It's correct now. [akpm@linux-foundation.org: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23walk system ram rangeKAMEZAWA Hiroyuki
Originally, walk_memory_resource() was introduced to traverse all memory of "System RAM" for detecting memory hotplug/unplug range. For doing so, flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for memory hotplug. But for using other purpose, /proc/kcore, this may includes some firmware area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the check strict to find out busy "System RAM". Note: PPC64 keeps their own walk_memory_resouce(), which walk through ppc64's lmb informaton. Because old kclist_add() is called per lmb, this patch makes no difference in behavior, finally. And this patch removes CONFIG_MEMORY_HOTPLUG check from this function. Because pfn_valid() just show "there is memmap or not* and cannot be used for "there is physical memory or not", this function is useful in generic to scan physical memory range. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: use usual list for kclistKAMEZAWA Hiroyuki
This patchset is for /proc/kcore. With this, - many per-arch hooks are removed. - /proc/kcore will know really valid physical memory area. - /proc/kcore will be aware of memory hotplug. - /proc/kcore will be architecture independent i.e. if an arch supports CONFIG_MMU, it can use /proc/kcore. (if the arch uses usual memory layout.) This patch: /proc/kcore uses its own list handling codes. It's better to use generic list codes. No changes in logic. just clean up. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23procfs: provide stack information for threadsStefani Seibold
A patch to give a better overview of the userland application stack usage, especially for embedded linux. Currently you are only able to dump the main process/thread stack usage which is showed in /proc/pid/status by the "VmStk" Value. But you get no information about the consumed stack memory of the the threads. There is an enhancement in the /proc/<pid>/{task/*,}/*maps and which marks the vm mapping where the thread stack pointer reside with "[thread stack xxxxxxxx]". xxxxxxxx is the maximum size of stack. This is a value information, because libpthread doesn't set the start of the stack to the top of the mapped area, depending of the pthread usage. A sample output of /proc/<pid>/task/<tid>/maps looks like: 08048000-08049000 r-xp 00000000 03:00 8312 /opt/z 08049000-0804a000 rw-p 00001000 03:00 8312 /opt/z 0804a000-0806b000 rw-p 00000000 00:00 0 [heap] a7d12000-a7d13000 ---p 00000000 00:00 0 a7d13000-a7f13000 rw-p 00000000 00:00 0 [thread stack: 001ff4b4] a7f13000-a7f14000 ---p 00000000 00:00 0 a7f14000-a7f36000 rw-p 00000000 00:00 0 a7f36000-a8069000 r-xp 00000000 03:00 4222 /lib/libc.so.6 a8069000-a806b000 r--p 00133000 03:00 4222 /lib/libc.so.6 a806b000-a806c000 rw-p 00135000 03:00 4222 /lib/libc.so.6 a806c000-a806f000 rw-p 00000000 00:00 0 a806f000-a8083000 r-xp 00000000 03:00 14462 /lib/libpthread.so.0 a8083000-a8084000 r--p 00013000 03:00 14462 /lib/libpthread.so.0 a8084000-a8085000 rw-p 00014000 03:00 14462 /lib/libpthread.so.0 a8085000-a8088000 rw-p 00000000 00:00 0 a8088000-a80a4000 r-xp 00000000 03:00 8317 /lib/ld-linux.so.2 a80a4000-a80a5000 r--p 0001b000 03:00 8317 /lib/ld-linux.so.2 a80a5000-a80a6000 rw-p 0001c000 03:00 8317 /lib/ld-linux.so.2 afaf5000-afb0a000 rw-p 00000000 00:00 0 [stack] ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso] Also there is a new entry "stack usage" in /proc/<pid>/{task/*,}/status which will you give the current stack usage in kb. A sample output of /proc/self/status looks like: Name: cat State: R (running) Tgid: 507 Pid: 507 . . . CapBnd: fffffffffffffeff voluntary_ctxt_switches: 0 nonvoluntary_ctxt_switches: 0 Stack usage: 12 kB I also fixed stack base address in /proc/<pid>/{task/*,}/stat to the base address of the associated thread stack and not the one of the main process. This makes more sense. [akpm@linux-foundation.org: fs/proc/array.c now needs walk_page_range()] Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: make SDIO device/driver struct accessors publicNicolas Pitre
Especially with the PM framework, those are quite handy to have in driver code too. Signed-off-by: Nicolas Pitre <nico@marvell.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23sdio: add MMC_QUIRK_LENIENT_FN0Ohad Ben-Cohen
Normally writes to SDIO function 0 outside the vendor specific CCCR registers are prohibited. To support embedded devices that require writes to SDIO function 0 outside this range (e.g. TI WL127x embedded sdio wifi device), MMC_QUIRK_LENIENT_FN0 is introduced. A card quirks field is added to `struct mmc_card' to support non-standard devices (e.g. embedded sdio devices). [akpm@linux-foundation.org: code in C, not cpp!] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23sdio: add CD disable supportOhad Ben-Cohen
Add support to disconnect the pull-up resistor on CD/DAT[3] (pin 1) of the card. This may be desired on certain setups of boards, controllers and embedded sdio devices which do not need the card's pull-up. As a result, card detection is disabled and power is saved. [akpm@linux-foundation.org: simplify sdio_disable_cd() a bit] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Philip Langdale <philipl@overt.org> Cc: Pierre Ossman <pierre@ossman.eu> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: check status after MMC SWITCH commandAdrian Hunter
According to the standard, the SWITCH command should be followed by a SEND_STATUS command to check for errors. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: add mmc card sleep and awake supportJarkko Lavinen
Add support for the new MMC command SLEEP_AWAKE. Signed-off-by: Jarkko Lavinen <jarkko.lavinen@nokia.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: add ability to save power by powering off cardsAdrian Hunter
Power can be saved by powering off cards that are not in use. This is similar to suspend / resume except it is under the control of the driver, and does not require any power management support. It can only be used when the driver can monitor whether the card is removed, otherwise it is unsafe. This is possible because, unlike suspend, the driver still receives card detect and / or cover switch interrupts. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: add MMC_CAP_NONREMOVABLE host capabilityAdrian Hunter
eMMC's are not removable, so unsafe resume is OK always. To permit this a new host capability MMC_CAP_NONREMOVABLE has been added and suspend / resume updated accordingly. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: allow host claim / release nestingAdrian Hunter
This change allows the MMC host to be claimed in situations where the host may or may not have already been claimed. Also 'mmc_try_claim_host()' is now exported. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23mmc: add 'enable' and 'disable' methods to mmc hostAdrian Hunter
MMC hosts that support power saving can use the 'enable' and 'disable' methods to exit and enter power saving states. An explanation of their use is provided in the comments added to include/linux/mmc/host.h. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
