We can reduce pressure on dst entry refcount that slowdown UDP transmit
path on SMP machines. This pressure is visible on RTP servers when
delivering content to mediagateways, especially big ones, handling
thousand of streams. Several cpus send UDP frames to the same
destination, hence use the same dst entry.
This patch makes ip_append_data() eventually steal the refcount its
callers had to take on the dst entry.
This doesnt avoid all refcounting, but still gives speedups on SMP,
on UDP/RAW transmit path
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Linus mentioned we could try to perform long word operations, even
on potentially unaligned addresses, on x86 at least. David mentioned
the HAVE_EFFICIENT_UNALIGNED_ACCESS test to handle this on all
arches that have efficient unailgned accesses.
I tried this idea and got nice assembly on 32 bits:
158: 33 82 38 01 00 00 xor 0x138(%edx),%eax
15e: 33 8a 34 01 00 00 xor 0x134(%edx),%ecx
164: c1 e0 10 shl $0x10,%eax
167: 09 c1 or %eax,%ecx
169: 74 0b je 176 <eth_type_trans+0x87>
And very nice assembly on 64 bits of course (one xor, one shl)
Nice oprofile improvement in eth_type_trans(), 0.17 % instead of 0.41 %,
expected since we remove 8 instructions on a fast path.
This patch implements a compare_ether_addr_64bits() function, that
uses the CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS ifdef to efficiently
perform the 6 bytes comparison on all capable arches.
This is the last step to be able to perform full RCU lookups
in __inet_lookup() : After established/timewait tables, we
add RCU lookups to listening hash table.
The only trick here is that a socket of a given type (TCP ipv4,
TCP ipv6, ...) can now flight between two different tables
(established and listening) during a RCU grace period, so we
must use different 'nulls' end-of-chain values for two tables.
We define a large value :
#define LISTENING_NULLS_BASE (1U << 29)
So that slots in listening table are guaranteed to have different
end-of-chain values than slots in established table. A reader can
still detect it finished its lookup in the right chain.
With this patch, TX/RX CCIDs can now be changed on a per-connection
basis, which overrides the defaults set by the global sysctl variables
for TX/RX CCIDs.
To make full use of this facility, the remaining patches of this patch
set are needed, which track dependencies and activate negotiated
feature values.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
For killing directly reference of netdev->priv, use netdev->ml_priv to replace it.
Because the private pvc data comes from add_pvc() and can't be allocated in
alloc_netdev().
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Acked-by: Krzysztof Halasa <khc@pm.waw.pl>
We can avoid some useless instructions if !CONFIG_NET_NS
Because of RCU, we use INET_MATCH or INET_TW_MATCH twice for the found
socket, so thats six instructions less per incoming TCP packet.
Yet another tbench speedup :)
This patch adds #include <linux/timer.h> in lib80211.h to avoid
these compilation erros.
> In file included from /work/src/wireless-testing/net/wireless/lib80211.c:24:
> /work/src/wireless-testing/include/net/lib80211.h:113: error: field
> 'crypt_deinit_timer' has incomplete type
> /work/src/wireless-testing/net/wireless/lib80211.c: In function
> 'lib80211_crypt_info_init':
> /work/src/wireless-testing/net/wireless/lib80211.c:83: error: implicit
> declaration of function 'setup_timer'
> 'lib80211_crypt_info_free':
> /work/src/wireless-testing/net/wireless/lib80211.c:95: error: implicit
> declaration of function 'del_timer_sync'
> 'lib80211_crypt_deinit_handler':
> /work/src/wireless-testing/net/wireless/lib80211.c:157: error:
> implicit declaration of function 'add_timer'
> 'lib80211_crypt_delayed_deinit':
> /work/src/wireless-testing/net/wireless/lib80211.c:182: error:
> implicit declaration of function 'timer_pending'
> make[3]: *** [net/wireless/lib80211.o] Error 1
> make[2]: *** [net/wireless] Error 2
> make[1]: *** [net] Error 2
> make: *** [sub-make] Error 2
Signed-off-by: Rami Rosen <ramirose@gmail.com>
Otherwise, the BUILD_BUG_ON calls in ieee80211_tx_info_clear_status can
fail on some architectures.
These bits are shared already between ipw2x00 and hostap, and could
probably be shared both more cleanly and with other drivers. This
commit simply relocates the code to lib80211 and adjusts the drivers
appropriately.
Delete kernel-doc struct descriptions for fields that don't exist:
Warning(include/net/mac80211.h:1263): Excess struct/union/enum/typedef member 'conf_ht' description in 'ieee80211_ops'
Warning(net/mac80211/sta_info.h:309): Excess struct/union/enum/typedef member 'addr' description in 'sta_info'
Warning(net/mac80211/sta_info.h:309): Excess struct/union/enum/typedef member 'aid' description in 'sta_info'
cc: Johannes Berg <johannes@sipsolutions.net>
cc: John W. Linville <linville@tuxdriver.com>
On ARM alignment is done slightly different from other architectures.
struct ieee80211_tx_rate is aligned to word size, even though it only has 3
single-byte members, which triggers the BUILD_BUG_ON in
This patch marks the struct ieee80211_tx_rate as packed, so that ARM
behaves like the other architectures.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Adds an interface to configure the Backward Congestion Notification
(BCN) feature. In a BCN capabale network, congestion notifications
from congested points out in the network can cause the end station
limit the rate of a given traffic flow.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
Adds a netlink interface for Data Center Bridging (DCB) to get and set
the enable state of the Priority Flow Control (PFC) feature.
Primarily, this is a way to turn off PFC in the driver while DCB
remains enabled.
Adds interface for Data Center Bridging (DCB) to query (and set if
supported) the number of traffic classes currently supported by the
device for the two (DCB) features: priority groups (PG) and priority
flow control (PFC).
Adds to the netlink interface for Data Center Bridging (DCB), allowing
the DCB capabilities supported by a device to be queried.
This adds support for Data Center Bridging (DCB) features in the ixgbe
driver and adds an rtnetlink interface for configuring DCB to the
kernel. The DCB feature support included are Priority Grouping (PG) -
which allows bandwidth guarantees to be allocated to groups to traffic
based on the 802.1q priority, and Priority Based Flow Control (PFC) -
which introduces a new MAC control PAUSE frame which works at
granularity of the 802.1p priority instead of the link (IEEE 802.3x).
Now TCP & DCCP use RCU lookups, we can convert ehash rwlocks to spinlocks.
/proc/net/tcp and other seq_file 'readers' can safely be converted to 'writers'.
This should speedup writers, since spin_lock()/spin_unlock()
only use one atomic operation instead of two for write_lock()/write_unlock()
Convert the HIPPI infrastructure for use with net_device_ops.
Similar to ethernet. Convert infrastructure and the one lone FDDI
driver (for the one lone user of that hardware??). Compile tested only.
This patch moves neigh_setup and hard_start_xmit into the network device ops
structure. For bisection, fix all the previously converted drivers as well.
Bonding driver took the biggest hit on this.
Added a prefetch of the hard_start_xmit in the fast path to try and reduce
any impact this would have.
drivers/net/ixgbe/ixgbe_main.c
net/phonet/af_phonet.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits)
net: fix tiny output corruption of /proc/net/snmp6
atl2: don't request irq on resume if netif running
ipv6: use seq_release_private for ip6mr.c /proc entries
pkt_sched: fix missing check for packet overrun in qdisc_dump_stab()
smc911x: Fix printf format typo in smc911x driver.
asix: Fix asix-based cards connecting to 10/100Mbs LAN.
mv643xx_eth: fix recycle check bound
mv643xx_eth: fix the order of mdiobus_{unregister, free}() calls
sh: sh_eth: Update to change of mii_bus
TPROXY: supply a struct flowi->flags argument in inet_sk_rebuild_header()
TPROXY: fill struct flowi->flags in udp_sendmsg()
net: ipg.c fix bracing on endian swapping
phylib: Fix auto-negotiation restart avoidance
net: jme.c rxdesc.flags is __le16, other missing endian swaps
phylib: fix phy name example in documentation
net: Do not fire linkwatch events until the device is registered.
phonet: fix compilation with gcc-3.4
ixgbe: fix compilation with gcc-3.4
pktgen: fix multiple queue warning
net: fix ip_mr_init() error path
Add classful DRR scheduler as a more flexible replacement for SFQ.
The main difference to the algorithm described in "Efficient Fair Queueing
using Deficit Round Robin" is that this implementation doesn't drop packets
from the longest queue on overrun because its classful and limits are
handled by each individual child qdisc.
A netlink attribute padding of zero triggers this sparse warning:
include/linux/netlink.h:245:8: warning: memset with byte count of 0
Avoid the memset when the size parameter is constant and requires no padding.
SKF_AD_NLATTR allows us to find the first matching attribute in a
stream of netlink attributes from one offset to the end of the
netlink message. This is not suitable to look for a specific
matching inside a set of nested attributes.
For example, in ctnetlink messages, if we look for the CTA_V6_SRC
attribute in a message that talks about an IPv4 connection,
SKF_AD_NLATTR returns the offset of CTA_STATUS which has the same
value of CTA_V6_SRC but outside the nest. To differenciate
CTA_STATUS and CTA_V6_SRC, we would have to make assumptions on the
size of the attribute and the usual offset, resulting in horrible
BSF code.
This patch adds SKF_AD_NLATTR_NEST, which is a variant of
SKF_AD_NLATTR, that looks for an attribute inside the limits of
a nested attributes, but not further.
This patch validates that we have enough room to look for the
nested attributes - based on a suggestion from Patrick McHardy.
Acked-by: Patrick McHardy <kaber@trash.net>
This patch prepares RCU migration of listening_hash table for
TCP/DCCP protocols.
listening_hash table being small (32 slots per protocol), we add
a spinlock for each slot, instead of a single rwlock for whole table.
This should reduce hold time of readers, and writers concurrency.
When ethernet devices are converted, the function pointer setup
by eth_setup() need to be done during intialization.
In order for the network device ops get_stats call to be immutable, the handling
of the default internal network device stats block has to be changed. Add a new
helper function which replaces the old use of internal_get_stats.
Note: change return code to make it clear that the caller should not
go changing the returned statistics.
This patch changes the network device internal API to move adminstrative
operations out of the network device structure and into a separate structure.
This patch involves some hackery to maintain compatablity between the
new and old model, so all 300+ drivers don't have to be changed at once.
For drivers that aren't converted yet, the netdevice_ops virt function list
still resides in the net_device structure. For old protocols, the new
net_device_ops are copied out to the old net_device pointers.
After the transistion is completed the nag message can be changed to
an WARN_ON, and the compatiablity code can be made configurable.
Some function pointers aren't moved:
* destructor can't be in net_device_ops because
it may need to be referenced after the module is unloaded.
* neighbor setup is manipulated in a couple of places that need special
consideration
* hard_start_xmit is in the fast path for transmit.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: more general identifier for Phoenix BIOS
AMD IOMMU: check for next_bit also in unmapped area
AMD IOMMU: fix fullflush comparison length
AMD IOMMU: enable device isolation per default
AMD IOMMU: add parameter to disable device isolation
x86, PEBS/DS: fix code flow in ds_request()
x86: add rdtsc barrier to TSC sync check
xen: fix scrub_page()
x86: fix es7000 compiling
x86, bts: fix unlock problem in ds.c
x86, voyager: fix smp generic helper voyager breakage
x86: move iomap.h to the new include location
After adding a node into the machine, top cpuset's mems isn't updated.
By reviewing the code, we found that the update function
cpuset_track_online_nodes()
was invoked after node_states[N_ONLINE] changes. It is wrong because
N_ONLINE just means node has pgdat, and if node has/added memory, we use
N_HIGH_MEMORY. So, We should invoke the update function after
node_states[N_HIGH_MEMORY] changes, just like its commit says.
This patch fixes it. And we use notifier of memory hotplug instead of
direct calling of cpuset_track_online_nodes().
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Paul Menage <menage@google.com
Introduce a new accept4() system call. The addition of this system call
matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(),
inotify_init1(), epoll_create1(), pipe2()) which added new system calls
that differed from analogous traditional system calls in adding a flags
argument that can be used to access additional functionality.
The accept4() system call is exactly the same as accept(), except that
it adds a flags bit-mask argument. Two flags are initially implemented.
(Most of the new system calls in 2.6.27 also had both of these flags.)
SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled
for the new file descriptor returned by accept4(). This is a useful
security feature to avoid leaking information in a multithreaded
program where one thread is doing an accept() at the same time as
another thread is doing a fork() plus exec(). More details here:
http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling",
Ulrich Drepper).
The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag
to be enabled on the new open file description created by accept4().
(This flag is merely a convenience, saving the use of additional calls
fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result.
Here's a test program. Works on x86-32. Should work on x86-64, but
I (mtk) don't have a system to hand to test with.
It tests accept4() with each of the four possible combinations of
SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies
that the appropriate flags are set on the file descriptor/open file
description returned by accept4().
I tested Ulrich's patch in this thread by applying against 2.6.28-rc2,
and it passes according to my test program.
/* test_accept4.c
Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk
<mtk.manpages@gmail.com>
Licensed under the GNU GPLv2 or later.
#define _GNU_SOURCE
#include <unistd.h>
#include <sys/syscall.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <stdlib.h>
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
#define PORT_NUM 33333
#define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0)
/* The following is what we need until glibc gets a wrapper for
accept4() */
/* Flags for socket(), socketpair(), accept4() */
#ifndef SOCK_CLOEXEC
#define SOCK_CLOEXEC O_CLOEXEC
#endif
#ifndef SOCK_NONBLOCK
#define SOCK_NONBLOCK O_NONBLOCK
#endif
#ifdef __x86_64__
#define SYS_accept4 288
#elif __i386__
#define USE_SOCKETCALL 1
#define SYS_ACCEPT4 18
#else
#error "Sorry -- don't know the syscall # on this architecture"
#endif
static int
accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags)
printf("Calling accept4(): flags = %x", flags);
if (flags != 0) {
printf(" (");
if (flags & SOCK_CLOEXEC)
printf("SOCK_CLOEXEC");
if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK))
printf(" ");
if (flags & SOCK_NONBLOCK)
printf("SOCK_NONBLOCK");
printf(")");
printf("\n");
#if USE_SOCKETCALL
long args[6];
args[0] = fd;
args[1] = (long) sockaddr;
args[2] = (long) addrlen;
args[3] = flags;
return syscall(SYS_socketcall, SYS_ACCEPT4, args);
#else
return syscall(SYS_accept4, fd, sockaddr, addrlen, flags);
#endif
static int
do_test(int lfd, struct sockaddr_in *conn_addr,
int closeonexec_flag, int nonblock_flag)
int connfd, acceptfd;
int fdf, flf, fdf_pass, flf_pass;
struct sockaddr_in claddr;
socklen_t addrlen;
printf("=======================================\n");
connfd = socket(AF_INET, SOCK_STREAM, 0);
if (connfd == -1)
die("socket");
if (connect(connfd, (struct sockaddr *) conn_addr,
sizeof(struct sockaddr_in)) == -1)
die("connect");
addrlen = sizeof(struct sockaddr_in);
acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen,
closeonexec_flag | nonblock_flag);
if (acceptfd == -1) {
perror("accept4()");
close(connfd);
return 0;
fdf = fcntl(acceptfd, F_GETFD);
if (fdf == -1)
die("fcntl:F_GETFD");
fdf_pass = ((fdf & FD_CLOEXEC) != 0) ==
((closeonexec_flag & SOCK_CLOEXEC) != 0);
printf("Close-on-exec flag is %sset (%s); ",
(fdf & FD_CLOEXEC) ? "" : "not ",
fdf_pass ? "OK" : "failed");
flf = fcntl(acceptfd, F_GETFL);
if (flf == -1)
flf_pass = ((flf & O_NONBLOCK) != 0) ==
((nonblock_flag & SOCK_NONBLOCK) !=0);
printf("nonblock flag is %sset (%s)\n",
(flf & O_NONBLOCK) ? "" : "not ",
flf_pass ? "OK" : "failed");
close(acceptfd);
close(connfd);
printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL");
return fdf_pass && flf_pass;
static int
create_listening_socket(int port_num)
struct sockaddr_in svaddr;
int lfd;
int optval;
memset(&svaddr, 0, sizeof(struct sockaddr_in));
svaddr.sin_family = AF_INET;
svaddr.sin_addr.s_addr = htonl(INADDR_ANY);
svaddr.sin_port = htons(port_num);
lfd = socket(AF_INET, SOCK_STREAM, 0);
if (lfd == -1)
die("socket");
optval = 1;
if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval,
sizeof(optval)) == -1)
die("setsockopt");
if (bind(lfd, (struct sockaddr *) &svaddr,
die("bind");
if (listen(lfd, 5) == -1)
die("listen");
return lfd;
int
main(int argc, char *argv[])
struct sockaddr_in conn_addr;
int lfd;
int port_num;
int passed;
passed = 1;
port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM;
memset(&conn_addr, 0, sizeof(struct sockaddr_in));
conn_addr.sin_family = AF_INET;
conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
conn_addr.sin_port = htons(port_num);
lfd = create_listening_socket(port_num);
if (!do_test(lfd, &conn_addr, 0, 0))
passed = 0;
if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0))
passed = 0;
if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK))
passed = 0;
if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK))
passed = 0;
close(lfd);
exit(passed ? EXIT_SUCCESS : EXIT_FAILURE);
[mtk.manpages@gmail.com: rewrote changelog, updated test program]
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Tested-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: <linux-api@vger.kernel.org>
Cc: <linux-arch@vger.kernel.org>
The first argument to csum_partial is const void *
casts to char/u8 * are not necessary
drivers/isdn/i4l/isdn_net.c
fs/cifs/connect.c
Before ieee80211_notify_mac() was added, it was presented with the
use case of using it to tell mac80211 that the association may
have been lost because the firmware crashed/reset.
Since then, it has also been used by iwlwifi to (slightly) speed
up re-association after resume, a workaround around the fact that
mac80211 has no suspend/resume handling yet. It is also not used
by any other drivers, so clearly it cannot be necessary for "good
enough" suspend/resume.
Unfortunately, the callback suffers from a severe problem: It only
works for station mode. If suspend/resume happens while in IBSS or
any other mode (but station), then the callback is pointless.
Recently, it has created a number of locking issues, first because
it required rtnl locking rather than RCU due to calling sleeping
functions within the critical section, and now because it's called
by iwlwifi from the mac80211 workqueue that may not use the rtnl
because it is flushed under rtnl.
(cf. http://bugzilla.kernel.org/show_bug.cgi?id=12046)
I think, therefore, that we should take a step back, remove it
entirely for now and add the small feature it provided properly.
For suspend and resume we will need to introduce new hooks, and for
the case where the firmware was reset the driver will probably
simply just pretend it has done a suspend/resume cycle to get
mac80211 to reprogram the hardware completely, not just try to
connect to the current AP again in station mode. When doing so, we
will need to take into account locking issues and possibly defer
to schedule_work from within mac80211 for the resume operation,
while the suspend operation must be done directly.
Proper suspend/resume should also not necessarily try to reconnect
to the current AP, the time spent in suspend may have been short
enough to not be disconnected from the AP, mac80211 will detect
that the AP went out of range quickly if it did, and if the
association is lost then the AP will disassoc as soon as a data
frame is sent. We might also take into account WWOL then, and
have mac80211 program the hardware into such a mode where it is
available and requested.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: hold extra reference to bio in blk_rq_map_user_iov()
relay: fix cpu offline problem
Release old elevator on change elevator
block: fix boot failure with CONFIG_DEBUG_BLOCK_EXT_DEVT=y and nash
block/md: fix md autodetection
block: make add_partition() return pointer to hd_struct
block: fix add_partition() error path
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kernel/profile.c: fix section mismatch warning
function tracing: fix wrong pos computing when read buffer has been fulfilled
tracing: fix mmiotrace resizing crash
ring-buffer: no preempt for sched_clock()
ring-buffer: buffer record on/off switch
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into x86/urgent
Make add_partition() return pointer to the new hd_struct on success
and ERR_PTR() value on failure. This change will be used to fix md
autodetection bug.
Cc: Neil Brown <neilb@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
rtnetlink: propagate error from dev_change_flags in do_setlink()
isdn: remove extra byteswap in isdn_net_ciscohdlck_slarp_send_reply
Phonet: refuse to send bigger than MTU packets
e1000e: fix IPMI traffic
e1000e: fix warn_on reload after phy_id error
phy: fix phy address bug
e100: fix dma error in direction for mapping
igb: use dev_printk instead of printk
qla3xxx: Cleanup: Fix link print statements.
igb: Use device_set_wakeup_enable
e1000: Use device_set_wakeup_enable
e1000e: Use device_set_wakeup_enable
via-velocity: enable perfect filtering for multicast packets
phy: Add support for Marvell 88E1118 PHY
mlx4_en: Pause parameters per port
phylib: fix premature freeing of struct mii_bus
atl1: Do not enumerate options unsupported by chip
atl1e: fix broken multicast by removing unnecessary crc inversion
gianfar: Fix DMA unmap invocations
net/ucc_geth: Fix oops in uec_get_ethtool_stats()
Simply delete ops from list and let list debugging do the job.
This patch deprecates the Ack Ratio sysctl, since
* Ack Ratio is entirely ignored by CCID-3 and CCID-4,
* Ack Ratio currently doesn't work in CCID-2 (i.e. is always set to 1);
* even if it would work in CCID-2, there is no point for a user to change it:
- Ack Ratio is constrained by cwnd (RFC 4341, 6.1.2),
- if Ack Ratio > cwnd, the system resorts to spurious RTO timeouts
(since waiting for Acks which will never arrive in this window),
- cwnd is not a user-configurable value.
The only reasonable place for Ack Ratio is to print it for debugging. It is
planned to do this later on, as part of e.g. dccp_probe.
With this patch Ack Ratio is now under full control of feature negotiation:
* Ack Ratio is resolved as a dependency of the selected CCID;
* if the chosen CCID supports it (i.e. CCID == CCID-2), Ack Ratio is set to
the default of 2, following RFC 4340, 11.3 - "New connections start with Ack
Ratio 2 for both endpoints";
* what happens then is part of another patch set, since it concerns the
dynamic update of Ack Ratio while the connection is in full flight.
Thanks to Tomasz Grobelny for discussion leading up to this patch.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This provides feature negotiation for server minimum checksum coverage
which so far has been missing.
Since sender/receiver coverage values range only from 0...15, their
type has also been reduced in size from u16 to u4.
Feature-negotiation options are now generated for both sender and receiver
coverage, i.e. when the peer has `forgotten' to enable partial coverage
then feature negotiation will automatically enable (negotiate) the partial
coverage value for this connection.
Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
The previous setsockopt interface, which passed socket options via struct
dccp_so_feat, is complicated/difficult to use. Continuing to support it leads to
ugly code since the old approach did not distinguish between NN and SP values.
This patch removes the old setsockopt interface and replaces it with two new
functions to register NN/SP values for feature negotiation.
These are essentially wrappers around the internal __feat_register functions,
with checking added to avoid
* wrong usage (type);
* changing values while the connection is in progress.
If segmentation offload is enabled by the host, we currently allocate
maximum sized packet buffers and pass them to the host. This uses up
20 ring entries, allowing us to supply only 20 packet buffers to the
host with a 256 entry ring. This is a huge overhead when receiving
small packets, and is most keenly felt when receiving MTU sized
packets from off-host.
The VIRTIO_NET_F_MRG_RXBUF feature flag is set by hosts which support
using receive buffers which are smaller than the maximum packet size.
In order to transfer large packets to the guest, the host merges
together multiple receive buffers to form a larger logical buffer.
The number of merged buffers is returned to the guest via a field in
the virtio_net_hdr.
Make use of this support by supplying single page receive buffers to
the host. On receive, we extract the virtio_net_hdr, copy 128 bytes of
the payload to the skb's linear data buffer and adjust the fragment
offset to point to the remaining data. This ensures proper alignment
and allows us to not use any paged data for small packets. If the
payload occupies multiple pages, we simply append those pages as
fragments and free the associated skbs.
This scheme allows us to be efficient in our use of ring entries
while still supporting large packets. Benchmarking using netperf from
an external machine to a guest over a 10Gb/s network shows a 100%
improvement from ~1Gb/s to ~2Gb/s. With a local host->guest benchmark
with GSO disabled on the host side, throughput was seen to increase
from 700Mb/s to 1.7Gb/s.
Based on a patch from Herbert Xu.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use netdev_priv)
As found in the past (commit f1dd9c379cac7d5a76259e7dffcd5f8edc697d17
[NET]: Fix tbench regression in 2.6.25-rc1), it is really
important that struct dst_entry refcount is aligned on a cache line.
We cannot use __atribute((aligned)), so manually pad the structure
for 32 and 64 bit arches.
for 32bit : offsetof(truct dst_entry, __refcnt) is 0x80
for 64bit : offsetof(truct dst_entry, __refcnt) is 0xc0
As it is not possible to guess at compile time cache line size,
we use a generic value of 64 bytes, that satisfies many current arches.
(Using 128 bytes alignment on 64bit arches would waste 64 bytes)
Add a BUILD_BUG_ON to catch future updates to "struct dst_entry" dont
break this alignment.
"tbench 8" is 4.4 % faster on a dual quad core (HP BL460c G1), Intel E5450 @3.00GHz
(2350 MB/s instead of 2250 MB/s)
