a6c140969b46 ("Delete pcibios_select_root") removed pcibios_select_root().
But a7db50405216 ("PCI: remove pcibios_scan_all_fns()") added a few copies
back, probably with some incorrect merge conflict resolutions.
Remove the still-unused pcibios_select_root() definitions.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is three logical fixes (as 5 patches).
The 3ware class of drivers were causing an oops with multiqueue by
tearing down the command mappings after completing the command (where
the variables in the command used to tear down the mapping were
no-longer valid). There's also a fix for the qnap iscsi target which
was choking on us sending it commands that were too long and a fix for
the reworked aha1542 allocating GFP_KERNEL under a lock"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
3w-9xxx: fix command completion race
3w-xxxx: fix command completion race
3w-sas: fix command completion race
aha1542: Allocate memory before taking a lock
SCSI: add 1024 max sectors black list flag
Pull networking fixes from David Miller:
1) Receive packet length needs to be adjust by 2 on RX to accomodate
the two padding bytes in altera_tse driver. From Vlastimil Setka.
2) If rx frame is dropped due to out of memory in macb driver, we leave
the receive ring descriptors in an undefined state. From Punnaiah
Choudary Kalluri
3) Some netlink subsystems erroneously signal NLM_F_MULTI. That is
only for dumps. Fix from Nicolas Dichtel.
4) Fix mis-use of raw rt->rt_pmtu value in ipv4, one must always go via
the ipv4_mtu() helper. From Herbert Xu.
5) Fix null deref in bridge netfilter, and miscalculated lengths in
jump/goto nf_tables verdicts. From Florian Westphal.
6) Unhash ping sockets properly.
7) Software implementation of BPF divide did 64/32 rather than 64/64
bit divide. The JITs got it right. Fix from Alexei Starovoitov.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (30 commits)
ipv4: Missing sk_nulls_node_init() in ping_unhash().
net: fec: Fix RGMII-ID mode
net/mlx4_en: Schedule napi when RX buffers allocation fails
netxen_nic: use spin_[un]lock_bh around tx_clean_lock
net/mlx4_core: Fix unaligned accesses
mlx4_en: Use correct loop cursor in error path.
cxgb4: Fix MC1 memory offset calculation
bnx2x: Delay during kdump load
net: Fix Kernel Panic in bonding driver debugfs file: rlb_hash_table
net: dsa: Fix scope of eeprom-length property
net: macb: Fix race condition in driver when Rx frame is dropped
hv_netvsc: Fix a bug in netvsc_start_xmit()
altera_tse: Correct rx packet length
mlx4: Fix tx ring affinity_mask creation
tipc: fix problem with parallel link synchronization mechanism
tipc: remove wrong use of NLM_F_MULTI
bridge/nl: remove wrong use of NLM_F_MULTI
bridge/mdb: remove wrong use of NLM_F_MULTI
net: sched: act_connmark: don't zap skb->nfct
trivial: net: systemport: bcmsysport.h: fix 0x0x prefix
Here the "other side" refers to the guest or host.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Pull power management and ACPI fixes from Rafael Wysocki:
"Three regression fixes this time, one for a recent regression in the
cpuidle core affecting multiple systems, one for an inadvertently
added duplicate typedef in ACPICA that breaks compilation with GCC 4.5
and one for an ACPI Smart Battery Subsystem driver regression
introduced during the 3.18 cycle (stable-candidate).
Specifics:
- Fix for a regression in the cpuidle core introduced by one of the
recent commits in the clockevents_notify() removal series that put
a call to a function which had to be executed with disabled
interrupts into a code path running with enabled interrupts (Rafael
J Wysocki)
- Fix for a build problem in ACPICA (with GCC 4.5) introduced by one
of the recent ACPICA tools commits that added a duplicate typedef
to one of the ACPICA's header files by mistake (Olaf Hering)
- Fix for a regression in the ACPI SBS (Smart Battery Subsystem)
driver introduced during the 3.18 development cycle causing the
smart battery manager to be marked as not present when it should be
marked as present (Chris Bainbridge)"
* tag 'pm+acpi-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: Run tick_broadcast_exit() with disabled interrupts
ACPI / SBS: Enable battery manager when present
ACPICA: remove duplicate u8 typedef
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"One nice fix is Peter's patch to make the old good SB Audigy PCI to
work with 32bit DMA instead of 31bit. This allows the MIDI synth
running on modern machines again. Along with it, a few fixes for
emu10k1 have merged.
In ASoC side, there is one fix in the common code, but it's just
trivial additions of static inline functions for CONFIG_PM=n. The
rest are various device-specific small fixes.
Last but not least, a few HD-audio fixes are included, as usual, too"
* tag 'sound-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (23 commits)
ASoC: rt5677: fixed wrong DMIC ref clock
ALSA: emu10k1: Emu10k2 32 bit DMA mode
ALSA: emux: Fix mutex deadlock in OSS emulation
ASoC: Update email-id of Rajeev Kumar
ASoC: rt5645: Fix mask for setting RT5645_DMIC_2_DP_GPIO12 bit
ALSA: hda - Fix missing va_end() call in snd_hda_codec_pcm_new()
ALSA: emux: Fix mutex deadlock at unloading
ALSA: emu10k1: Fix card shortname string buffer overflow
ALSA: hda - Add mute-LED mode control to Thinkpad
ALSA: hda - Fix mute-LED fixed mode
ALSA: hda - Fix click noise at start on Dell XPS13
ASoC: rt5645: Add ACPI match ID
ASoC: rt5677: add register patch for PLL
ASoC: Intel: fix the makefile for atom code
ASoC: dapm: Enable autodisable on SOC_DAPM_SINGLE_TLV_AUTODISABLE
ASoC: add static inline funcs to fix a compiling issue
ASoC: Intel: sst_byt: remove kfree for memory allocated with devm_kzalloc
ASoC: samsung: s3c24xx-i2s: Fix return value check in s3c24xx_iis_dev_probe()
ASoC: tfa9879: Fix return value check in tfa9879_i2c_probe()
ASoC: fsl_ssi: Fix platform_get_irq() error handling
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v4.1
A few fixes for v4.1, none earth shattering and mostly driver related
except for one change to fix !PM builds for Intel platforms which is
done by adding stubs in the core so other platforms don't run into the
same issue.
Pull kvm changes from Paolo Bonzini:
"Remove from guest code the handling of task migration during a pvclock
read; instead use the correct protocol in KVM.
This removes the need for task migration notifiers in core scheduler
code"
[ The scheduler people really hated the migration notifiers, so this was
kind of required - Linus ]
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
x86: pvclock: Really remove the sched notifier for cross-cpu migrations
kvm: x86: fix kvmclock update protocol
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some small tty/serial driver fixes for 4.1-rc2.
They include some minor fixes that resolve reported issues, and a new
device quirk.
All have been in linux-next succesfully"
* tag 'tty-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
serial: 8250_pci: Add support for 16 port Exar boards
serial: samsung: fix serial console break
tty/serial: at91: maxburst was missing for dma transfers
serial: of-serial: Remove device_type = "serial" registration
serial: xilinx: Use platform_get_irq to get irq description structure
serial: core: Fix kernel-doc build warnings
tty: Re-add external interface for tty_set_termios()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of small USB fixes for 4.2-rc2. They revert one
problem patch, fix some minor things, and add some new quirks for
"broken" devices.
All have been in linux-next successfully"
* tag 'usb-4.1-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
cdc-acm: prevent infinite loop when parsing CDC headers.
Revert "usb: host: ehci-msm: Use devm_ioremap_resource instead of devm_ioremap"
usb: chipidea: otg: remove mutex unlock and lock while stop and start role
uas: Set max_sectors_240 quirk for ASM1053 devices
uas: Add US_FL_MAX_SECTORS_240 flag
uas: Allow uas_use_uas_driver to return usb-storage flags
NLM_F_MULTI must be used only when a NLMSG_DONE message is sent. In fact,
it is sent only at the end of a dump.
Libraries like libnl will wait forever for NLMSG_DONE.
Fixes: e5a55a898720 ("net: create generic bridge ops")
Fixes: 815cccbf10b2 ("ixgbe: add setlink, getlink support to ixgbe and ixgbevf")
CC: John Fastabend <john.r.fastabend@intel.com>
CC: Sathya Perla <sathya.perla@emulex.com>
CC: Subbu Seetharaman <subbu.seetharaman@emulex.com>
CC: Ajit Khaparde <ajit.khaparde@emulex.com>
CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
CC: intel-wired-lan@lists.osuosl.org
CC: Jiri Pirko <jiri@resnulli.us>
CC: Scott Feldman <sfeldma@gmail.com>
CC: Stephen Hemminger <stephen@networkplumber.org>
CC: bridge@lists.linux-foundation.org
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
'asoc/fix/pm', 'asoc/fix/qcom' and 'asoc/fix/rcar' into asoc-linus
Looks like audigy emu10k2 (probably emu10k1 - sb live too) support two
modes for DMA. Second mode is useful for 64 bit os with more then 2 GB
of ram (fixes problems with big soundfont loading)
1) 32MB from 2 GB address space using 8192 pages (used now as default)
2) 16MB from 4 GB address space using 4096 pages
Mode is set using HCFG_EXPANDED_MEM flag in HCFG register.
Also format of emu10k2 page table is then different.
Signed-off-by: Peter Zubaj <pzubaj@marticonet.sk>
Tested-by: Takashi Iwai <tiwai@suse.de>
Cc: <stable@vger.kernel.org>
During commit e252652fb266 ("ACPICA: acpidump: Remove integer types
translation protection.") two 'unsigned char' types got converted to 'u8'.
The result does not compile with gcc-4.5, it can not cope with duplicate
typedefs.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"One additional new feature for 4.1, a new PRNG based on SHA-512 for
the zcrypt driver.
Two memory management related changes, the page table reallocation for
KVM is removed, and with file ptes gone the encoding of page table
entries is improved.
And three bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/zcrypt: Introduce new SHA-512 based Pseudo Random Generator.
s390/mm: change swap pte encoding and pgtable cleanup
s390/mm: correct transfer of dirty & young bits in __pmd_to_pte
s390/bpf: add dependency to z196 features
s390/3215: free memory in error path
s390/kvm: remove delayed reallocation of page tables for KVM
kexec: allocate the kexec control page with KEXEC_CONTROL_MEMORY_GFP
rajeev-dlh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with Rajeev Kumar <rajeevkumar.linux@gmail.com>
Signed-off-by: Rajeev Kumar <rajeevkumar.linux@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
This is needed by Bluetooth hci_uart module to be able to change speed
of Bluetooth controller and local UART.
Signed-off-by: Frederic Danis <frederic.danis@linux.intel.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
The usb-storage driver sets max_sectors = 240 in its scsi-host template,
for uas we do not want to do that for all devices, but testing has shown
that some devices need it.
This commit adds a US_FL_MAX_SECTORS_240 flag for such devices, and
implements support for it in uas.c, while at it it also adds support
for US_FL_MAX_SECTORS_64 to uas.c.
Cc: stable@vger.kernel.org # 3.16
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix a crash in nf_tables when dictionaries are used from the ruleset,
due to memory corruption, from Florian Westphal.
2) Fix another crash in nf_queue when used with br_netfilter. Also from
Florian.
Both fixes are related to new stuff that got in 4.0-rc.
1) mlx4 doesn't check fully for supported valid RSS hash function, fix
from Amir Vadai
2) Off by one in ibmveth_change_mtu(), from David Gibson
3) Prevent altera chip from reporting false error interrupts in some
circumstances, from Chee Nouk Phoon
4) Get rid of that stupid endless loop trying to allocate a FIN packet
in TCP, and in the process kill deadlocks. From Eric Dumazet
5) Fix get_rps_cpus() crash due to wrong invalid-cpu value, also from
Eric Dumazet
6) Fix two bugs in async rhashtable resizing, from Thomas Graf
7) Fix topology server listener socket namespace bug in TIPC, from Ying
Xue
8) Add some missing HAS_DMA kconfig dependencies, from Geert
Uytterhoeven
9) bgmac driver intends to force re-polling but does so by returning
the wrong value from it's ->poll() handler. Fix from Rafał Miłecki
10) When the creater of an rhashtable configures a max size for it,
don't bark in the logs and drop insertions when that is exceeded.
Fix from Johannes Berg
11) Recover from out of order packets in ppp mppe properly, from Sylvain
Rochet
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (41 commits)
bnx2x: really disable TPA if 'disable_tpa' option is set
net:treewide: Fix typo in drivers/net
net/mlx4_en: Prevent setting invalid RSS hash function
mdio-mux-gpio: use new gpiod_get_array and gpiod_put_array functions
netfilter; Add some missing default cases to switch statements in nft_reject.
ppp: mppe: discard late packet in stateless mode
ppp: mppe: sanity error path rework
net/bonding: Make DRV macros private
net: rfs: fix crash in get_rps_cpus()
altera tse: add support for fixed-links.
pxa168: fix double deallocation of managed resources
net: fix crash in build_skb()
net: eth: altera: Resolve false errors from MSGDMA to TSE
ehea: Fix memory hook reference counting crashes
net/tg3: Release IRQs on permanent error
net: mdio-gpio: support access that may sleep
inet: fix possible panic in reqsk_queue_unlink()
rhashtable: don't attempt to grow when at max_size
bgmac: fix requests for extra polling calls from NAPI
tcp: avoid looping in tcp_send_fin()
This works around a issue with qnap iscsi targets not handling large IOs
very well.
The target returns:
VPD INQUIRY: Block limits page (SBC)
Maximum compare and write length: 1 blocks
Optimal transfer length granularity: 1 blocks
Maximum transfer length: 4294967295 blocks
Optimal transfer length: 4294967295 blocks
Maximum prefetch, xdread, xdwrite transfer length: 0 blocks
Maximum unmap LBA count: 8388607
Maximum unmap block descriptor count: 1
Optimal unmap granularity: 16383
Unmap granularity alignment valid: 0
Unmap granularity alignment: 0
Maximum write same length: 0xffffffff blocks
Maximum atomic transfer length: 0
Atomic alignment: 0
Atomic transfer length granularity: 0
and it is *sometimes* able to handle at least one IO of size up to 8 MB. We
have seen in traces where it will sometimes work, but other times it
looks like it fails and it looks like it returns failures if we send
multiple large IOs sometimes. Also it looks like it can return 2 different
errors. It will sometimes send iscsi reject errors indicating out of
resources or it will send invalid cdb illegal requests check conditions.
And then when it sends iscsi rejects it does not seem to handle retries
when there are command sequence holes, so I could not just add code to
try and gracefully handle that error code.
The problem is that we do not have a good contact for the company,
so we are not able to determine under what conditions it returns
which error and why it sometimes works.
So, this patch just adds a new black list flag to set targets like this to
the old max safe sectors of 1024. The max_hw_sectors changes added in 3.19
caused this regression, so I also ccing stable.
Reported-by: Christian Hesse <list@eworm.de>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
This reverts commits 0a4e6be9ca17c54817cf814b4b5aa60478c6df27
and 80f7fdb1c7f0f9266421f823964fd1962681f6ce.
The task migration notifier was originally introduced in order to support
the pvclock vsyscall with non-synchronized TSC, but KVM only supports it
with synchronized TSC. Hence, on KVM the race condition is only needed
due to a bad implementation on the host side, and even then it's so rare
that it's mostly theoretical.
As far as KVM is concerned it's possible to fix the host, avoiding the
additional complexity in the vDSO and the (re)introduction of the task
migration notifier.
Xen, on the other hand, hasn't yet implemented vsyscall support at
all, so we do not care about its plans for non-synchronized TSC.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Marcelo Tosatti <mtosatti@redhat.com>
The bonding modules currently defines four macros with
general names that pollute the global namespace:
DRV_VERSION
DRV_RELDATE
DRV_NAME
DRV_DESCRIPTION
Fixing that by defining a private bonding_priv.h
header files which includes those defines.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Pull intel iommu updates from David Woodhouse:
"This lays a little of the groundwork for upcoming Shared Virtual
Memory support — fixing some bogus #defines for capability bits and
adding the new ones, and starting to use the new wider page tables
where we can, in anticipation of actually filling in the new fields
therein.
It also allows graphics devices to be assigned to VM guests again.
This got broken in 3.17 by disallowing assignment of RMRR-afflicted
devices. Like USB, we do understand why there's an RMRR for graphics
devices — and unlike USB, it's actually sane. So we can make an
exception for graphics devices, just as we do USB controllers.
Finally, tone down the warning about the X2APIC_OPT_OUT bit, due to
persistent requests. X2APIC_OPT_OUT was added to the spec as a nasty
hack to allow broken BIOSes to forbid us from using X2APIC when they
do stupid and invasive things and would break if we did.
Someone noticed that since Windows doesn't have full IOMMU support for
DMA protection, setting the X2APIC_OPT_OUT bit made Windows avoid
initialising the IOMMU on the graphics unit altogether.
This means that it would be available for use in "driver mode", where
the IOMMU registers are made available through a BAR of the graphics
device and the graphics driver can do SVM all for itself.
So they started setting the X2APIC_OPT_OUT bit on *all* platforms with
SVM capabilities. And even the platforms which *might*, if the
planets had been aligned correctly, possibly have had SVM capability
but which in practice actually don't"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: support extended root and context entries
iommu/vt-d: Add new extended capabilities from v2.3 VT-d specification
iommu/vt-d: Allow RMRR on graphics devices too
iommu/vt-d: Print x2apic opt out info instead of printing a warning
iommu/vt-d: kill bogus ecap_niotlb_iunits()
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform
Pull chrome platform updates from Olof Johansson:
"Here's a set of updates to the Chrome OS platform drivers for this
merge window.
Main new things this cycle is:
- Driver changes to expose the lightbar to users. With this, you can
make your own blinkenlights on Chromebook Pixels.
- Changes in the way that the atmel_mxt trackpads are probed. The
laptop driver is trying to be smart and not instantiate the devices
that don't answer to probe. For the trackpad that can come up in
two modes (bootloader or regular), this gets complicated since the
driver already knows how to handle the two modes including the
actual addresses used. So now the laptop driver needs to know more
too, instantiating the regular address even if the bootloader one
is the probe that passed.
- mfd driver improvements by Javier Martines Canillas, and a few
bugfixes from him, kbuild and myself"
* tag 'chrome-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform:
platform/chrome: chromeos_laptop - instantiate Atmel at primary address
platform/chrome: cros_ec_lpc - Depend on X86 || COMPILE_TEST
platform/chrome: cros_ec_lpc - Include linux/io.h header file
platform/chrome: fix platform_no_drv_owner.cocci warnings
platform/chrome: cros_ec_lightbar - fix duplicate const warning
platform/chrome: cros_ec_dev - fix Unknown escape '%' warning
platform/chrome: Expose Chrome OS Lightbar to users
platform/chrome: Create sysfs attributes for the ChromeOS EC
mfd: cros_ec: Instantiate ChromeOS EC character device
platform/chrome: Add Chrome OS EC userspace device interface
platform/chrome: Add cros_ec_lpc driver for x86 devices
mfd: cros_ec: Add char dev and virtual dev pointers
mfd: cros_ec: Use fixed size arrays to transfer data with the EC
Pull second batch of KVM changes from Paolo Bonzini:
"This mostly includes the PPC changes for 4.1, which this time cover
Book3S HV only (debugging aids, minor performance improvements and
some cleanups). But there are also bug fixes and small cleanups for
ARM, x86 and s390.
The task_migration_notifier revert and real fix is still pending
review, but I'll send it as soon as possible after -rc1"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (29 commits)
KVM: arm/arm64: check IRQ number on userland injection
KVM: arm: irqfd: fix value returned by kvm_irq_map_gsi
KVM: VMX: Preserve host CR4.MCE value while in guest mode.
KVM: PPC: Book3S HV: Use msgsnd for signalling threads on POWER8
KVM: PPC: Book3S HV: Translate kvmhv_commence_exit to C
KVM: PPC: Book3S HV: Streamline guest entry and exit
KVM: PPC: Book3S HV: Use bitmap of active threads rather than count
KVM: PPC: Book3S HV: Use decrementer to wake napping threads
KVM: PPC: Book3S HV: Don't wake thread with no vcpu on guest IPI
KVM: PPC: Book3S HV: Get rid of vcore nap_count and n_woken
KVM: PPC: Book3S HV: Move vcore preemption point up into kvmppc_run_vcpu
KVM: PPC: Book3S HV: Minor cleanups
KVM: PPC: Book3S HV: Simplify handling of VCPUs that need a VPA update
KVM: PPC: Book3S HV: Accumulate timing information for real-mode code
KVM: PPC: Book3S HV: Create debugfs file for each guest's HPT
KVM: PPC: Book3S HV: Add ICP real mode counters
KVM: PPC: Book3S HV: Move virtual mode ICP functions to real-mode
KVM: PPC: Book3S HV: Convert ICS mutex lock to spin lock
KVM: PPC: Book3S HV: Add guest->host real mode completion counters
KVM: PPC: Book3S HV: Add helpers for lock/unlock hpte
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
I_DIO_WAKEUP is never directly used, but fix it up anyway.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
do_blockdev_direct_IO() increments and decrements the inode
->i_dio_count for each IO operation. It does this to protect against
truncate of a file. Block devices don't need this sort of protection.
For a capable multiqueue setup, this atomic int is the only shared
state between applications accessing the device for O_DIRECT, and it
presents a scaling wall for that. In my testing, as much as 30% of
system time is spent incrementing and decrementing this value. A mixed
read/write workload improved from ~2.5M IOPS to ~9.6M IOPS, with
better latencies too. Before:
clat percentiles (usec):
| 1.00th=[ 33], 5.00th=[ 34], 10.00th=[ 34], 20.00th=[ 34],
| 30.00th=[ 34], 40.00th=[ 34], 50.00th=[ 35], 60.00th=[ 35],
| 70.00th=[ 35], 80.00th=[ 35], 90.00th=[ 37], 95.00th=[ 80],
| 99.00th=[ 98], 99.50th=[ 151], 99.90th=[ 155], 99.95th=[ 155],
| 99.99th=[ 165]
After:
| 1.00th=[ 95], 5.00th=[ 108], 10.00th=[ 129], 20.00th=[ 149],
| 30.00th=[ 155], 40.00th=[ 161], 50.00th=[ 167], 60.00th=[ 171],
| 70.00th=[ 177], 80.00th=[ 185], 90.00th=[ 201], 95.00th=[ 270],
| 99.00th=[ 390], 99.50th=[ 398], 99.90th=[ 418], 99.95th=[ 422],
| 99.99th=[ 438]
In other setups, Robert Elliott reported seeing good performance
improvements:
https://lkml.org/lkml/2015/4/3/557
The more applications accessing the device, the worse it gets.
Add a new direct-io flags, DIO_SKIP_DIO_COUNT, which tells
do_blockdev_direct_IO() that it need not worry about incrementing
or decrementing the inode i_dio_count for this caller.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Elliott, Robert (Server Storage) <elliott@hp.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Might not have an outdev yet. We'll oops when iface goes down while skbs
are still nfqueue'd:
RIP: 0010:[<ffffffff81422a2f>] [<ffffffff81422a2f>] dev_cmp+0x4f/0x80
nfqnl_rcv_dev_event+0xe2/0x150
notifier_call_chain+0x53/0xa0
Fixes: c737b7c4510026 ("netfilter: bridge: add helpers for fetching physin/outdev")
"Here are a few fixes that have been pending since the previous pull
request: a regression fix for HD-audio multiple SPDIF / HDMI devices,
several ALC256 codec fixes, a couple of i915 HDMI audio fixes, and
various small fixes.
Nothing exciting, just boring, but things good to have"
* tag 'sound-fix-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - fix headset mic detection problem for one more machine
ALSA: hda/realtek - Fix Headphone Mic doesn't recording for ALC256
ALSA: hda - fix "num_steps = 0" error on ALC256
ALSA: usb-audio: Fix audio output on Roland SC-D70 sound module
ALSA: hda - add AZX_DCAPS_I915_POWERWELL to Baytrail
ALSA: hda - only sync BCLK to the display clock for Haswell & Broadwell
ALSA: hda - Mute headphone pin on suspend on XPS13 9333
sound/oss: fix deadlock in sequencer_ioctl(SNDCTL_SEQ_OUTOFBAND)
ALSA: asound.h - use SNDRV_CTL_ELEM_ID_NAME_MAXLEN
ALSA: hda - potential (but unlikely) uninitialized variable
ALSA: hda - Fix regression for slave SPDIF setups
ALSA: intel8x0: Check pci_iomap() success for DEVICE_ALI
ALSA: hda - simplify azx_has_pm_runtime
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Lots of activity in target land the last months.
The highlights include:
- Convert fabric drivers tree-wide to target_register_template() (hch
+ bart)
- iser-target hardening fixes + v1.0 improvements (sagi)
- Convert iscsi_thread_set usage to kthread.h + kill
iscsi_target_tq.c (sagi + nab)
- Add support for T10-PI WRITE_STRIP + READ_INSERT operation (mkp +
sagi + nab)
- DIF fixes for CONFIG_DEBUG_SG=y + UNMAP file emulation (akinobu +
sagi + mkp)
- Extended TCMU ABI v2 for future BIDI + DIF support (andy + ilias)
- Fix COMPARE_AND_WRITE handling for NO_ALLLOC drivers (hch + nab)
Thanks to everyone who contributed this round with new features,
bug-reports, fixes, cleanups and improvements.
Looking forward, it's currently shaping up to be a busy v4.2 as well"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (69 commits)
target: Put TCMU under a new config option
target: Version 2 of TCMU ABI
target: fix tcm_mod_builder.py
target/file: Fix UNMAP with DIF protection support
target/file: Fix SG table for prot_buf initialization
target/file: Fix BUG() when CONFIG_DEBUG_SG=y and DIF protection enabled
target: Make core_tmr_abort_task() skip TMFs
target/sbc: Update sbc_dif_generate pr_debug output
target/sbc: Make internal DIF emulation honor ->prot_checks
target/sbc: Return INVALID_CDB_FIELD if DIF + sess_prot_type disabled
target: Ensure sess_prot_type is saved across session restart
target/rd: Don't pass incomplete scatterlist entries to sbc_dif_verify_*
target: Remove the unused flag SCF_ACK_KREF
target: Fix two sparse warnings
target: Fix COMPARE_AND_WRITE with SG_TO_MEM_NOALLOC handling
target: simplify the target template registration API
target: simplify target_xcopy_init_pt_lun
target: remove the unused SCF_CMD_XCOPY_PASSTHROUGH flag
target/rd: reduce code duplication in rd_execute_rw()
tcm_loop: fixup tpgt string to integer conversion
git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf
Pull dma-buf updates from Sumit Semwal:
"Minor cleanup only; this could've gone in for the 4.0 merge window,
but for a copy-paste stupidity from me.
It has been in the for-next since then, and no issues reported.
- cleanup of dma_buf_export()
- correction of copy-paste stupidity while doing the cleanup"
* tag 'dma-buf-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf:
staging: android: ion: fix wrong init of dma_buf_export_info
dma-buf: cleanup dma_buf_export() to make it easily extensible
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
Pull md updates from Neil Brown:
"More updates that usual this time. A few have performance impacts
which hould mostly be positive, but RAID5 (in particular) can be very
work-load ensitive... We'll have to wait and see.
Highlights:
- "experimental" code for managing md/raid1 across a cluster using
DLM. Code is not ready for general use and triggers a WARNING if
used. However it is looking good and mostly done and having in
mainline will help co-ordinate development.
- RAID5/6 can now batch multiple (4K wide) stripe_heads so as to
handle a full (chunk wide) stripe as a single unit.
- RAID6 can now perform read-modify-write cycles which should help
performance on larger arrays: 6 or more devices.
- RAID5/6 stripe cache now grows and shrinks dynamically. The value
set is used as a minimum.
- Resync is now allowed to go a little faster than the 'mininum' when
there is competing IO. How much faster depends on the speed of the
devices, so the effective minimum should scale with device speed to
some extent"
* tag 'md/4.1' of git://neil.brown.name/md: (58 commits)
md/raid5: don't do chunk aligned read on degraded array.
md/raid5: allow the stripe_cache to grow and shrink.
md/raid5: change ->inactive_blocked to a bit-flag.
md/raid5: move max_nr_stripes management into grow_one_stripe and drop_one_stripe
md/raid5: pass gfp_t arg to grow_one_stripe()
md/raid5: introduce configuration option rmw_level
md/raid5: activate raid6 rmw feature
md/raid6 algorithms: xor_syndrome() for SSE2
md/raid6 algorithms: xor_syndrome() for generic int
md/raid6 algorithms: improve test program
md/raid6 algorithms: delta syndrome functions
raid5: handle expansion/resync case with stripe batching
raid5: handle io error of batch list
RAID5: batch adjacent full stripe write
raid5: track overwrite disk count
raid5: add a new flag to track if a stripe can be batched
raid5: use flex_array for scribble data
md raid0: access mddev->queue (request queue member) conditionally because it is not set when accessed from dm-raid
md: allow resync to go faster when there is competing IO.
md: remove 'go_faster' option from ->sync_request()
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull second batch of devicetree updates from Rob Herring:
"As Grant mentioned in the first devicetree pull request, here is the
2nd batch of DT changes for 4.1. The main remaining item here is the
endianness bindings and related 8250 driver support.
- DT endianness specification bindings
- big-endian 8250 serial support
- DT overlay unittest updates
- various DT doc updates
- compile fixes for OF_IRQ=n"
* tag 'devicetree-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
frv: add io{read,write}{16,32}be functions
mn10300: add io{read,write}{16,32}be functions
Documentation: DT bindings: add doc for Altera's SoCFPGA platform
of: base: improve of_get_next_child() kernel-doc
Doc: dt: arch_timer: discourage clock-frequency use
of: unittest: overlay: Keep track of created overlays
of/fdt: fix allocation size for device node path
serial: of_serial: Support big-endian register accesses
serial: 8250: Add support for big-endian MMIO accesses
of: Document {little,big,native}-endian bindings
of/fdt: Add endianness helper function for early init code
of: Add helper function to check MMIO register endianness
of/fdt: Remove "reg" data prints from early_init_dt_scan_memory
of: add vendor prefix for Artesyn
of: Add dummy of_irq_to_resource_table() for IRQ_OF=n
of: OF_IRQ should depend on IRQ_DOMAIN
[ 3897.923145] BUG: unable to handle kernel NULL pointer dereference at
0000000000000080
[ 3897.931025] IP: [<ffffffffa9f27686>] reqsk_timer_handler+0x1a6/0x243
There is a race when reqsk_timer_handler() and tcp_check_req() call
inet_csk_reqsk_queue_unlink() on the same req at the same time.
Before commit fa76ce7328b2 ("inet: get rid of central tcp/dccp listener
timer"), listener spinlock was held and race could not happen.
To solve this bug, we change reqsk_queue_unlink() to not assume req
must be found, and we return a status, to conditionally release a
refcount on the request sock.
This also means tcp_check_req() in non fastopen case might or not
consume req refcount, so tcp_v6_hnd_req() & tcp_v4_hnd_req() have
to properly handle this.
(Same remark for dccp_check_req() and its callers)
inet_csk_reqsk_queue_drop() is now too big to be inlined, as it is
called 4 times in tcp and 3 times in dccp.
Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer")
Reported-by: Yuchung Cheng <ycheng@google.com>
The conversion of mac80211's station table to rhashtable had a bug
that I found by accident in code review, that hadn't been found as
rhashtable apparently managed to have a maximum hash chain length
of one (!) in all our testing.
In order to test the bug and verify the fix I set my rhashtable's
max_size very low (4) in order to force getting hash collisions.
At that point, rhashtable WARNed in rhashtable_insert_rehash() but
didn't actually reject the hash table insertion. This caused it to
lose insertions - my master list of stations would have 9 entries,
but the rhashtable only had 5. This may warrant a deeper look, but
that WARN_ON() just shouldn't happen.
Fix this by not returning true from rht_grow_above_100() when the
rhashtable's max_size has been reached - in this case the user is
explicitly configuring it to be at most that big, so even if it's
now above 100% it shouldn't attempt to resize.
This fixes the "lost insertion" issue and consequently allows my
code to display its error (and verify my fix for it.)
Acked-by: Thomas Graf <tgraf@suug.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull initial ACPI support for arm64 from Will Deacon:
"This series introduces preliminary ACPI 5.1 support to the arm64
kernel using the "hardware reduced" profile. We don't support any
peripherals yet, so it's fairly limited in scope:
- MEMORY init (UEFI)
- ACPI discovery (RSDP via UEFI)
- CPU init (FADT)
- GIC init (MADT)
- SMP boot (MADT + PSCI)
- ACPI Kconfig options (dependent on EXPERT)
ACPI for arm64 has been in development for a while now and hardware
has been available that can boot with either FDT or ACPI tables. This
has been made possible by both changes to the ACPI spec to cater for
ARM-based machines (known as "hardware-reduced" in ACPI parlance) but
also a Linaro-driven effort to get this supported on top of the Linux
kernel. This pull request is the result of that work.
These changes allow us to initialise the CPUs, interrupt controller,
and timers via ACPI tables, with memory information and cmdline coming
from EFI. We don't support a hybrid ACPI/FDT scheme. Of course,
there is still plenty of work to do (a serial console would be nice!)
but I expect that to happen on a per-driver basis after this core
series has been merged.
Anyway, the diff stat here is fairly horrible, but splitting this up
and merging it via all the different subsystems would have been
extremely painful. Instead, we've got all the relevant Acks in place
and I've not seen anything other than trivial (Kconfig) conflicts in
-next (for completeness, I've included my resolution below). Nearly
half of the insertions fall under Documentation/.
So, we'll see how this goes. Right now, it all depends on EXPERT and
I fully expect people to use FDT by default for the immediate future"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (31 commits)
ARM64 / ACPI: make acpi_map_gic_cpu_interface() as void function
ARM64 / ACPI: Ignore the return error value of acpi_map_gic_cpu_interface()
ARM64 / ACPI: fix usage of acpi_map_gic_cpu_interface
ARM64: kernel: acpi: honour acpi=force command line parameter
ARM64: kernel: acpi: refactor ACPI tables init and checks
ARM64: kernel: psci: let ACPI probe PSCI version
ARM64: kernel: psci: factor out probe function
ACPI: move arm64 GSI IRQ model to generic GSI IRQ layer
ARM64 / ACPI: Don't unflatten device tree if acpi=force is passed
ARM64 / ACPI: additions of ACPI documentation for arm64
Documentation: ACPI for ARM64
ARM64 / ACPI: Enable ARM64 in Kconfig
XEN / ACPI: Make XEN ACPI depend on X86
ARM64 / ACPI: Select ACPI_REDUCED_HARDWARE_ONLY if ACPI is enabled on ARM64
clocksource / arch_timer: Parse GTDT to initialize arch timer
irqchip: Add GICv2 specific ACPI boot support
ARM64 / ACPI: Introduce ACPI_IRQ_MODEL_GIC and register device's gsi
ACPI / processor: Make it possible to get CPU hardware ID via GICC
ACPI / processor: Introduce phys_cpuid_t for CPU hardware ID
ARM64 / ACPI: Parse MADT for SMP initialization
Pull nfsd updates from Bruce Fields:
"A quiet cycle this time; this is basically entirely bugfixes.
The few that aren't cc'd to stable are cleanup or seemed unlikely to
affect anyone much"
* 'for-4.1' of git://linux-nfs.org/~bfields/linux:
uapi: Remove kernel internal declaration
nfsd: fix nsfd startup race triggering BUG_ON
nfsd: eliminate NFSD_DEBUG
nfsd4: fix READ permission checking
nfsd4: disallow SEEK with special stateids
nfsd4: disallow ALLOCATE with special stateids
nfsd: add NFSEXP_PNFS to the exflags array
nfsd: Remove duplicate macro define for max sec label length
nfsd: allow setting acls with unenforceable DENYs
nfsd: NFSD_FAULT_INJECTION depends on DEBUG_FS
nfsd: remove unused status arg to nfsd4_cleanup_open_state
nfsd: remove bogus setting of status in nfsd4_process_open2
NFSD: Use correct reply size calculating function
NFSD: Using path_equal() for checking two paths
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs update from Dave Chinner:
"This update contains:
- RENAME_WHITEOUT support
- conversion of per-cpu superblock accounting to use generic counters
- new inode mmap lock so that we can lock page faults out of
truncate, hole punch and other direct extent manipulation functions
to avoid racing mmap writes from causing data corruption
- rework of direct IO submission and completion to solve data
corruption issue when running concurrent extending DIO writes.
Also solves problem of running IO completion transactions in
interrupt context during size extending AIO writes.
- FALLOC_FL_INSERT_RANGE support for inserting holes into a file via
direct extent manipulation to avoid needing to copy data within the
file
- attribute block header field overflow fix for 64k block size
filesystems
- Lots of changes to log messaging to be more informative and concise
when errors occur. Also prevent a lot of unnecessary log spamming
due to cascading failures in error conditions.
- lots of cleanups and bug fixes
One thing of note is the direct IO fixes that we merged last week
after the window opened. Even though a little late, they fix a user
reported data corruption and have been pretty well tested. I figured
there was not much point waiting another 2 weeks for -rc1 to be
released just so I could send them to you..."
* tag 'xfs-for-linus-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (49 commits)
xfs: using generic_file_direct_write() is unnecessary
xfs: direct IO EOF zeroing needs to drain AIO
xfs: DIO write completion size updates race
xfs: DIO writes within EOF don't need an ioend
xfs: handle DIO overwrite EOF update completion correctly
xfs: DIO needs an ioend for writes
xfs: move DIO mapping size calculation
xfs: factor DIO write mapping from get_blocks
xfs: unlock i_mutex in xfs_break_layouts
xfs: kill unnecessary firstused overflow check on attr3 leaf removal
xfs: use larger in-core attr firstused field and detect overflow
xfs: pass attr geometry to attr leaf header conversion functions
xfs: disallow ro->rw remount on norecovery mount
xfs: xfs_shift_file_space can be static
xfs: Add support FALLOC_FL_INSERT_RANGE for fallocate
xfs: Fix incorrect positive ENOMEM return
xfs: xfs_mru_cache_insert() should use GFP_NOFS
xfs: %pF is only for function pointers
xfs: fix shadow warning in xfs_da3_root_split()
NFS: NFSoRDMA Client Changes
This patch series creates an operation vector for each of the different
memory registration modes. This should make it easier to one day increase
credit limit, rsize, and wsize.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
This file is only used internally to the NFS v4 module, so it doesn't
need to be in the global include path. I also renamed it from
nfs_idmap.h to nfs4idmap.h to emphasize that it's an NFSv4-only include
file.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
The idmapper is completely internal to the NFS v4 module, so this macro
will always evaluate to true. This patch also removes unnecessary
includes of this file from the generic NFS client.
v2: gracefully handle the case where some dentry pointers end up NULL
and be more dilligent about zeroing out dentry pointers
We currently have a problem that SELinux policy is being enforced when
creating debugfs files. If a debugfs file is created as a side effect of
doing some syscall, then that creation can fail if the SELinux policy
for that process prevents it.
This seems wrong. We don't do that for files under /proc, for instance,
so Bruce has proposed a patch to fix that.
While discussing that patch however, Greg K.H. stated:
"No kernel code should care / fail if a debugfs function fails, so
please fix up the sunrpc code first."
This patch converts all of the sunrpc debugfs setup code to be void
return functins, and the callers to not look for errors from those
functions.
This should allow rpc_clnt and rpc_xprt creation to work, even if the
kernel fails to create debugfs files for some reason.
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
This patch adds a GETATTR to the end of ALLOCATE and DEALLOCATE
operations so we can set the updated inode size and change attribute
directly. DEALLOCATE will still need to release pagecache pages, so
nfs42_proc_deallocate() now calls truncate_pagecache_range() before
contacting the server.
With the CPU iteration variable called 'i', it's relatively easy
to have variable shadowing which sparse will warn about. Avoid
that by renaming the variable to __cpu which is less likely to
be used in the surrounding context.
