* pnfs_generic:
NFSv4.1/pNFS: Cleanup constify struct pnfs_layout_range arguments
NFSv4.1/pnfs: Cleanup copying of pnfs_layout_range structures
NFSv4.1/pNFS: Cleanup pnfs_mark_matching_lsegs_invalid()
NFSv4.1/pNFS: Fix a race in initiate_file_draining()
NFSv4.1/pNFS: pnfs_error_mark_layout_for_return() must always return layout
NFSv4.1/pNFS: pnfs_mark_matching_lsegs_return() should set the iomode
NFSv4.1/pNFS: Use nfs4_stateid_copy for copying stateids
NFSv4.1/pNFS: Don't pass stateids by value to pnfs_send_layoutreturn()
NFS: Relax requirements in nfs_flush_incompatible
NFSv4.1/pNFS: Don't queue up a new commit if the layout segment is invalid
NFS: Allow multiple commit requests in flight per file
NFS/pNFS: Fix up pNFS write reschedule layering violations and bugs
NFSv4: List stateid information in the callback tracepoints
NFSv4.1/pNFS: Don't return NFS4ERR_DELAY unnecessarily in CB_LAYOUTRECALL
NFSv4.1/pNFS: Ensure we enforce RFC5661 Section 12.5.5.2.1
pNFS: If we have to delay the layout callback, mark the layout for return
NFSv4.1/pNFS: Add a helper to mark the layout as returned
pNFS: Ensure nfs4_layoutget_prepare returns the correct error
If the layout segment is invalid, then we should not be adding more
write requests to the commit list. Instead, those writes should be
replayed after requesting a new layout.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Allow synchronous RPC calls to wait for pending RPC calls to finish,
but also allow asynchronous ones to just fire off another commit.
With this patch, the xfstests generic/074 test completes in 226s
instead of 242s
The flexfiles layout in particular, seems to want to poke around in the
O_DIRECT flags when retransmitting.
This patch sets up an interface to allow it to call back into O_DIRECT
to handle retransmission correctly. It also fixes a potential bug whereby
we could change the behaviour of O_DIRECT if an error is already pending.
* flexfiles:
pNFS/flexfiles: Ensure we record layoutstats even if RPC is terminated early
pNFS: Add flag to track if we've called nfs4_ff_layout_stat_io_start_read/write
pNFS/flexfiles: Fix a statistics gathering imbalance
pNFS/flexfiles: Don't mark the entire layout as failed, when returning it
pNFS/flexfiles: Don't prevent flexfiles client from retrying LAYOUTGET
pnfs/flexfiles: count io stat in rpc_count_stats callback
pnfs/flexfiles: do not mark delay-like status as DS failure
NFS41: map NFS4ERR_LAYOUTUNAVAILABLE to ENODATA
nfs: only remove page from mapping if launder_page fails
nfs: handle request add failure properly
nfs: centralize pgio error cleanup
nfs: clean up rest of reqs when failing to add one
NFS41: pop some layoutget errors to application
pNFS/flexfiles: Support server-supplied layoutstats sampling period
Instead of dropping pages when write fails, only do it when
we get fatal failure in launder_page write back.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
Allow LAYOUTRETURN and DELEGRETURN to use machine credentials if the
server supports it. Add request for OPEN_DOWNGRADE as the close path
also uses that.
Signed-off-by: Andrew Elble <aweits@rit.edu>
pnfs_update_layout is really the "nexus" of layout handling. If it
returns NULL then we end up going through the MDS. This patch adds
some tracepoints to that function that allow us to determine the
cause when we end up going through the MDS unexpectedly.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"Three fixes this time, two in SES picked up by KASAN for various types
of buffer overrun. The first is a USB array which returns page 8
whatever is asked for and causes us to overrun with incorrect data
format assumptions and the second is an invalid iteration of page 10
(the additional information page).
The final fix is a reversion of a NULL deref fix which caused
suspend/resume not to be called in pairs leading to incorrect device
operation (Jens has queued a more proper fix for the problem in
block)"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
ses: fix additional element traversal bug
Revert "SCSI: Fix NULL pointer dereference in runtime PM"
ses: Fix problems with simple enclosures
Merge misc fixes from Andrew Morton:
"Three patches"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
include/linux/mmdebug.h: should include linux/bug.h
mm/zswap: change incorrect strncmp use to strcmp
proc: fix -ESRCH error when writing to /proc/$pid/coredump_filter
mmdebug.h uses BUILD_BUG_ON_INVALID(), assuming someone else included
linux/bug.h. Include it ourselves.
This saves build-failures such as:
arch/arm64/include/asm/pgtable.h: In function 'set_pte_at':
arch/arm64/include/asm/pgtable.h:281:3: error: implicit declaration of function 'BUILD_BUG_ON_INVALID' [-Werror=implicit-function-declaration]
VM_WARN_ONCE(!pte_young(pte),
Fixes: 02602a18c32d7 ("bug: completely remove code generated by disabled VM_BUG_ON()")
Signed-off-by: James Morse <james.morse@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen bug fixes from David Vrabel:
- XSA-155 security fixes to backend drivers.
- XSA-157 security fixes to pciback.
* tag 'for-linus-4.4-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen-pciback: fix up cleanup path when alloc fails
xen/pciback: Don't allow MSI-X ops if PCI_COMMAND_MEMORY is not set.
xen/pciback: For XEN_PCI_OP_disable_msi[|x] only disable if device has MSI(X) enabled.
xen/pciback: Do not install an IRQ handler for MSI interrupts.
xen/pciback: Return error on XEN_PCI_OP_enable_msix when device has MSI or MSI-X enabled
xen/pciback: Return error on XEN_PCI_OP_enable_msi when device has MSI or MSI-X enabled
xen/pciback: Save xen_pci_op commands before processing it
xen-scsiback: safely copy requests
xen-blkback: read from indirect descriptors only once
xen-blkback: only read request operation from shared ring once
xen-netback: use RING_COPY_REQUEST() throughout
xen-netback: don't use last request to determine minimum Tx credit
xen: Add RING_COPY_REQUEST()
xen/x86/pvh: Use HVM's flush_tlb_others op
xen: Resume PMU from non-atomic context
xen/events/fifo: Consume unprocessed events when a CPU dies
Using RING_GET_REQUEST() on a shared ring is easy to use incorrectly
(i.e., by not considering that the other end may alter the data in the
shared ring while it is being inspected). Safe usage of a request
generally requires taking a local copy.
Provide a RING_COPY_REQUEST() macro to use instead of
RING_GET_REQUEST() and an open-coded memcpy(). This takes care of
ensuring that the copy is done correctly regardless of any possible
compiler optimizations.
Use a volatile source to prevent the compiler from reordering or
omitting the copy.
This is part of XSA155.
CC: stable@vger.kernel.org
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Pull networking fixes from David Miller:
1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of
people reported this... From Arnd Bergmann.
2) Don't init mutex twice in i40e driver, from Jesse Brandeburg.
3) Fix spurious EBUSY in rhashtable, from Herbert Xu.
4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas.
5) Fix race with work structure access in pppoe driver causing
corruptions, from Guillaume Nault.
6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb()
actually succeeded or not, from Sergei Shtylyov.
7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from
Bjørn Mork.
8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc.
9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo
Leitner.
10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven.
11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling
properly as well, from Jiri Benc.
12) Handle request sockets properly in xfrm layer, from Eric Dumazet.
13) Double stats update in ipv6 geneve transmit path, fix from Pravin B
Shelar.
14) sk->sk_policy[] needs RCU protection, and as a result
xfrm_policy_destroy() needs to free policies using an RCU grace
period, from Eric Dumazet.
15) SCTP needs to clone ipv6 tx options in order to avoid use after
free, from Eric Dumazet.
16) Missing kbuild export if ila.h, from Stephen Hemminger.
17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from
Tobias Klauser.
18) Validate protocol value range in ->create() methods, from Hannes
Frederic Sowa.
19) Fix early socket demux races that result in illegal dst reuse, from
Eric Dumazet.
20) Validate socket address length in pptp code, from WANG Cong.
21) skb_reorder_vlan_header() uses incorrect offset and can corrupt
packets, from Vlad Yasevich.
22) Fix memory leaks in nl80211 registry code, from Ola Olsson.
23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and
qlcnic. From Dan Carpenter.
24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for
example, AF_ALG will interpret it as an async call. From Tadeusz
Struk.
25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from
Eric Dumazet.
26) rhashtable enforces the minimum table size not early enough,
breaking how we calculate the per-cpu lock allocations. From
Herbert Xu.
27) Fix FCC port lockup in 82xx driver, from Martin Roth.
28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa.
29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and
sock_setsockopt() wrt. timestamp handling. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits)
net: check both type and procotol for tcp sockets
drivers: net: xgene: fix Tx flow control
tcp: restore fastopen with no data in SYN packet
af_unix: Revert 'lock_interruptible' in stream receive code
fou: clean up socket with kfree_rcu
82xx: FCC: Fixing a bug causing to FCC port lock-up
gianfar: Don't enable RX Filer if not supported
net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration
rhashtable: Fix walker list corruption
rhashtable: Enforce minimum size on initial hash table
inet: tcp: fix inetpeer_set_addr_v4()
ipv6: automatically enable stable privacy mode if stable_secret set
net: fix uninitialized variable issue
bluetooth: Validate socket address length in sco_sock_bind().
net_sched: make qdisc_tree_decrease_qlen() work for non mq
ser_gigaset: remove unnecessary kfree() calls from release method
ser_gigaset: fix deallocation of platform device structure
ser_gigaset: turn nonsense checks into WARN_ON
ser_gigaset: fix up NULL checks
qlcnic: fix a timeout loop
declaration
Docbook does not like the definition of macros inside a field declaration
and adds a warning. Move the definition out.
Fixes: 79462ad02e86180 ("net: add validation for the socket syscall protocol argument")
Reported-by: kbuild test robot <lkp@intel.com>
David Ahern added a vif field in the a4 part of inetpeer_addr struct.
This broke IPv4 TCP fast open client side and more generally tcp metrics
cache, because inetpeer_addr_cmp() is now comparing two u32 instead of
one.
inetpeer_set_addr_v4() needs to properly init vif field, otherwise
the comparison result depends on uninitialized data.
Fixes: 192132b9a034 ("net: Add support for VRFs to inetpeer cache")
Reported-by: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"This has fixes spread thru driver, notably among them:
- edma fixes for recent edma DT changes which went into 4.4
- odd fixes for at_hdmac
- minor fixes on bc dma and mic dma"
* tag 'dmaengine-fix-4.4-rc6' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: at_xdmac: fix at_xdmac_prep_dma_memcpy()
dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type
dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type
dmaengine: mic_x100: add missing spin_unlock
dmaengine: bcm2835-dma: Convert to use DMA pool
dmaengine: at_xdmac: fix bad behavior in interleaved mode
dmaengine: at_xdmac: fix false condition for memset_sg transfers
dmaengine: at_xdmac: fix macro typo
David Wilder reported crashes caused by dst reuse.
<quote David>
I am seeing a crash on a distro V4.2.3 kernel caused by a double
release of a dst_entry. In ipv4_dst_destroy() the call to
list_empty() finds a poisoned next pointer, indicating the dst_entry
has already been removed from the list and freed. The crash occurs
18 to 24 hours into a run of a network stress exerciser.
</quote>
Thanks to his detailed report and analysis, we were able to understand
the core issue.
IP early demux can associate a dst to skb, after a lookup in TCP/UDP
sockets.
When socket cache is not properly set, we want to store into
sk->sk_dst_cache the dst for future IP early demux lookups,
by acquiring a stable refcount on the dst.
Problem is this acquisition is simply using an atomic_inc(),
which works well, unless the dst was queued for destruction from
dst_release() noticing dst refcount went to zero, if DST_NOCACHE
was set on dst.
We need to make sure current refcount is not zero before incrementing
it, or risk double free as David reported.
This patch, being a stable candidate, adds two new helpers, and use
them only from IP early demux problematic paths.
It might be possible to merge in net-next skb_dst_force() and
skb_dst_force_safe(), but I prefer having the smallest patch for stable
kernels : Maybe some skb_dst_force() callers do not expect skb->dst
can suddenly be cleared.
Can probably be backported back to linux-3.6 kernels
Reported-by: David J. Wilder <dwilder@us.ibm.com>
Tested-by: David J. Wilder <dwilder@us.ibm.com>
郭永刚 reported that one could simply crash the kernel as root by
using a simple program:
int socket_fd;
struct sockaddr_in addr;
addr.sin_port = 0;
addr.sin_addr.s_addr = INADDR_ANY;
addr.sin_family = 10;
socket_fd = socket(10,3,0x40000000);
connect(socket_fd , &addr,16);
AF_INET, AF_INET6 sockets actually only support 8-bit protocol
identifiers. inet_sock's skc_protocol field thus is sized accordingly,
thus larger protocol identifiers simply cut off the higher bits and
store a zero in the protocol fields.
This could lead to e.g. NULL function pointer because as a result of
the cut off inet_num is zero and we call down to inet_autobind, which
is NULL for raw sockets.
kernel: Call Trace:
kernel: [<ffffffff816db90e>] ? inet_autobind+0x2e/0x70
kernel: [<ffffffff816db9a4>] inet_dgram_connect+0x54/0x80
kernel: [<ffffffff81645069>] SYSC_connect+0xd9/0x110
kernel: [<ffffffff810ac51b>] ? ptrace_notify+0x5b/0x80
kernel: [<ffffffff810236d8>] ? syscall_trace_enter_phase2+0x108/0x200
kernel: [<ffffffff81645e0e>] SyS_connect+0xe/0x10
kernel: [<ffffffff81779515>] tracesys_phase2+0x84/0x89
I found no particular commit which introduced this problem.
CVE: CVE-2015-8543
Cc: Cong Wang <cwang@twopensource.com>
Reported-by: 郭永刚 <guoyonggang@360.cn>
The commit 33db4125ec74 ("openvswitch: Rename LABEL->LABELS") left
over an old OVS_CT_ATTR_LABEL instance, fix it.
Fixes: 33db4125ec74 ("openvswitch: Rename LABEL->LABELS")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Joe Stringer <joe@ovn.org>
Pablo Neira Ayuso says:
netfilter fixes for net
The following patchset contains Netfilter fixes for you net tree,
specifically for nf_tables and nfnetlink_queue, they are:
1) Avoid a compilation warning in nfnetlink_queue that was introduced
in the previous merge window with the simplification of the conntrack
integration, from Arnd Bergmann.
2) nfnetlink_queue is leaking the pernet subsystem registration from
a failure path, patch from Nikolay Borisov.
3) Pass down netns pointer to batch callback in nfnetlink, this is the
largest patch and it is not a bugfix but it is a dependency to
resolve a splat in the correct way.
4) Fix a splat due to incorrect socket memory accounting with nfnetlink
skbuff clones.
5) Add missing conntrack dependencies to NFT_DUP_IPV4 and NFT_DUP_IPV6.
6) Traverse the nftables commit list in reverse order from the commit
path, otherwise we crash when the user applies an incremental update
via 'nft -f' that deletes an object that was just introduced in this
batch, from Xin Long.
Regarding the compilation warning fix, many people have sent us (and
keep sending us) patches to address this, that's why I'm including this
batch even if this is not critical.
Jan Stancek reported that I wrecked things for him by fixing things for
Vladimir :/
His report was due to an UNINTERRUPTIBLE wait getting -EINTR, which
should not be possible, however my previous patch made this possible by
unconditionally checking signal_pending().
We cannot use current->state as was done previously, because the
instruction after the store to that variable it can be changed. We must
instead pass the initial state along and use that.
Fixes: 68985633bccb ("sched/wait: Fix signal handling in bit wait helpers")
Reported-by: Jan Stancek <jstancek@redhat.com>
Reported-by: Chris Mason <clm@fb.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Vladimir Murzin <vladimir.murzin@arm.com>
Tested-by: Chris Mason <clm@fb.com>
Reviewed-by: Paul Turner <pjt@google.com>
Cc: tglx@linutronix.de
Cc: hpa@zytor.com
Pull timer fixlets from Thomas Gleixner:
"Two trivial fixes which add missing header fileas and forward
declarations so the code will compile even when the magic include
chains are different"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/gic-v3: Add missing include for barrier.h
irqchip/gic-v3: Add missing struct device_node declaration
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB driver fixes from Greg KH:
"Here are a number of small USB fixes for 4.4-rc5. All of them have
been in linux-next. The majority are gadget and phy issues, with a
few new quirks and device ids added as well"
* tag 'usb-4.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (32 commits)
USB: add quirk for devices with broken LPM
xhci: fix usb2 resume timing and races.
usb: musb: fail with error when no DMA controller set
usb: gadget: uvc: fix permissions of configfs attributes
usb: musb: core: Fix pm runtime for deferred probe
usb: phy: msm: fix a possible NULL dereference
USB: host: ohci-at91: fix a crash in ohci_hcd_at91_overcurrent_irq
usb: Quiet down false peer failure messages
usb: xhci: fix config fail of FS hub behind a HS hub with MTT
xhci: Fix memory leak in xhci_pme_acpi_rtd3_enable()
usb: Use the USB_SS_MULT() macro to decode burst multiplier for log message
USB: whci-hcd: add check for dma mapping error
usb: core : hub: Fix BOS 'NULL pointer' kernel panic
USB: quirks: Apply ALWAYS_POLL to all ELAN devices
usb-storage: Fix scsi-sd failure "Invalid field in cdb" for USB adapter JMicron
USB: quirks: Fix another ELAN touchscreen
usb: dwc3: gadget: don't prestart interrupt endpoints
USB: serial: Another Infineon flash loader USB ID
USB: cdc_acm: Ignore Infineon Flash Loader utility
USB: cp210x: Remove CP2110 ID from compatibility list
"17 fixes"
MIPS: fix DMA contiguous allocation
sh64: fix __NR_fgetxattr
ocfs2: fix SGID not inherited issue
mm/oom_kill.c: avoid attempting to kill init sharing same memory
drivers/base/memory.c: prohibit offlining of memory blocks with missing sections
tmpfs: fix shmem_evict_inode() warnings on i_blocks
mm/hugetlb.c: fix resv map memory leak for placeholder entries
mm: hugetlb: call huge_pte_alloc() only if ptep is null
kernel: remove stop_machine() Kconfig dependency
mm: kmemleak: mark kmemleak_init prototype as __init
mm: fix kerneldoc on mem_cgroup_replace_page
osd fs: __r4w_get_page rely on PageUptodate for uptodate
MAINTAINERS: make Vladimir co-maintainer of the memory controller
mm, vmstat: allow WQ concurrency to discover memory reclaim doesn't make any progress
mm: fix swapped Movable and Reclaimable in /proc/pagetypeinfo
memcg: fix memory.high target
mm: hugetlb: fix hugepage memory leak caused by wrong reserve count
Pull block layer fixes from Jens Axboe:
"A set of fixes for the current series. This contains:
- A bunch of fixes for lightnvm, should be the last round for this
series. From Matias and Wenwei.
- A writeback detach inode fix from Ilya, also marked for stable.
- A block (though it says SCSI) fix for an OOPS in SCSI runtime power
management.
- Module init error path fixes for null_blk from Minfei"
* 'for-linus' of git://git.kernel.dk/linux-block:
null_blk: Fix error path in module initialization
lightnvm: do not compile in debugging by default
lightnvm: prevent gennvm module unload on use
lightnvm: fix media mgr registration
lightnvm: replace req queue with nvmdev for lld
lightnvm: comments on constants
lightnvm: check mm before use
lightnvm: refactor spin_unlock in gennvm_get_blk
lightnvm: put blks when luns configure failed
lightnvm: use flags in rrpc_get_blk
block: detach bdev inode from its wb in __blkdev_put()
Currently the full stop_machine() routine is only enabled on SMP if
module unloading is enabled, or if the CPUs are hotpluggable. This
leads to configurations where stop_machine() is broken as it will then
only run the callback on the local CPU with irqs disabled, and not stop
the other CPUs or run the callback on them.
For example, this breaks MTRR setup on x86 in certain configs since
ea8596bb2d8d379 ("kprobes/x86: Remove unused text_poke_smp() and
text_poke_smp_batch() functions") as the MTRR is only established on the
boot CPU.
This patch removes the Kconfig option for STOP_MACHINE and uses the SMP
and HOTPLUG_CPU config options to compile the correct stop_machine() for
the architecture, removing the false dependency on MODULE_UNLOAD in the
process.
Link: https://lkml.org/lkml/2014/10/8/124
References: https://bugs.freedesktop.org/show_bug.cgi?id=84794
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Iulia Manda <iulia.manda21@gmail.com>
Cc: Chuck Ebbert <cebbert.lkml@gmail.com>
The kmemleak_init() definition in mm/kmemleak.c is marked __init but its
prototype in include/linux/kmemleak.h is marked __ref since commit
a6186d89c913 ("kmemleak: Mark the early log buffer as __initdata").
This causes a section mismatch which is reported as a warning when
building with clang -Wsection, because kmemleak_init() is declared in
section .ref.text but defined in .init.text.
Fix this by marking kmemleak_init() prototype __init.
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
The file ila.h used for lightweight tunnels is being used by iproute2
but is not exported yet.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
XFRM can deal with SYNACK messages, sent while listener socket
is not locked. We add proper rcu protection to __xfrm_sk_clone_policy()
and xfrm_sk_policy_lookup()
This might serve as the first step to remove xfrm.xfrm_policy_lock
use in fast path.
Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer")
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
We will soon switch sk->sk_policy[] to RCU protection,
as SYNACK packets are sent while listener socket is not locked.
This patch simply adds RCU grace period before struct xfrm_policy
freeing, and the corresponding rcu_head in struct xfrm_policy.
Some USB device / host controller combinations seem to have problems
with Link Power Management. For example, Steinar found that his xHCI
controller wouldn't handle bandwidth calculations correctly for two
video cards simultaneously when LPM was enabled, even though the bus
had plenty of bandwidth available.
This patch introduces a new quirk flag for devices that should remain
disabled for LPM, and creates quirk entries for Steinar's devices.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
Cc: stable <stable@vger.kernel.org>
KASAN found that our additional element processing scripts drop off
the end of the VPD page into unallocated space. The reason is that
not every element has additional information but our traversal
routines think they do, leading to them expecting far more additional
information than is present. Fix this by adding a gate to the
traversal routine so that it only processes elements that are expected
to have additional information (list is in SES-2 section 6.1.13.1:
Additional Element Status diagnostic page overview)
Reported-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Tested-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Cc: stable@vger.kernel.org
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma fixes from Doug Ledford:
"Most are minor to important fixes.
There is one performance enhancement that I took on the grounds that
failing to check if other processes can run before running what's
intended to be a background, idle-time task is a bug, even though the
primary effect of the fix is to improve performance (and it was a very
simple patch)"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma:
IB/mlx5: Postpone remove_keys under knowledge of coming preemption
IB/mlx4: Use vmalloc for WR buffers when needed
IB/mlx4: Use correct order of variables in log message
iser-target: Remove explicit mlx4 work-around
mlx4: Expose correct max_sge_rd limit
IB/mad: Require CM send method for everything except ClassPortInfo
IB/cma: Add a missing rcu_read_unlock()
IB core: Fix ib_sg_to_pages()
IB/srp: Fix srp_map_sg_fr()
IB/srp: Fix indirect data buffer rkey endianness
IB/srp: Initialize dma_length in srp_map_idb
IB/srp: Fix possible send queue overflow
IB/srp: Fix a memory leak
IB/sa: Put netlink request into the request list before sending
IB/iser: use sector_div instead of do_div
IB/core: use RCU for uverbs id lookup
IB/qib: Minor fixes to qib per SFF 8636
IB/core: Fix user mode post wr corruption
IB/qib: Fix qib_mr structure
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Again less intensive changes in this rc: you can find only a few
HD-audio fixes (noise fixes for Intel Broxton chip and a few Thinkpad
models, quirks for Alienware 17 and Packard Bell DOTS) in addition to
a long-standing rme96 bug fix"
* tag 'sound-4.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/ca0132 - quirk for Alienware 17 2015
ALSA: hda - Fix noise problems on Thinkpad T440s
ALSA: hda - Fixing speaker noise on the two latest thinkpad models
ALSA: hda - Add inverted dmic for Packard Bell DOTS
ALSA: hda - Fix playback noise with 24/32 bit sample size on BXT
ALSA: rme96: Fix unexpected volume reset after rate changes
When the GICv3 header file is used in a C file that doesn't include
any of the OF stuff, we end up with a bunch of ugly warnings.
Let's keep GCC quiet by adding a forward declaration.
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1449483072-17694-2-git-send-email-marc.zyngier@arm.com
Pass the net pointer to the call_batch callback functions so we can skip
recurrent lookups.
Tested-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com>
This change makes the DT file to be easier to read since the memcpy
channels array does not need the '/bits/ 16' to be specified, which might
confuse some people.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pull VFIO fixes from Alex Williamson:
- Various fixes for removing redundancy, const'ifying structs, avoiding
stack usage, fixing WARN usage (Krzysztof Kozlowski, Julia Lawall,
Kees Cook, Dan Carpenter)
- Revert No-IOMMU mode as the intended user has not emerged (Alex
Williamson)
* tag 'vfio-v4.4-rc5' of git://github.com/awilliam/linux-vfio:
Revert: "vfio: Include No-IOMMU mode"
vfio: fix a warning message
vfio: platform: remove needless stack usage
vfio-pci: constify pci_error_handlers structures
vfio: Drop owner assignment from platform_driver
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DT fixes from Rob Herring:
"I think this should be all for 4.4:
- Fix incorrect warning about overlapping memory regions
- Export of_irq_find_parent again which was made static in 4.4, but
has users pending for 4.5.
- Fix of_msi_map_rid declaration location
- Fix re-entrancy for of_fdt_unflatten_tree
- Clean-up of phys_addr_t printks"
* tag 'devicetree-fixes-for-4.4-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of/irq: move of_msi_map_rid declaration to the correct ifdef section
of/irq: Export of_irq_find_parent again
of/fdt: Add mutex protection for calls to __unflatten_device_tree()
of/address: fix typo in comment block of of_translate_one()
of: do not use 0x in front of %pa
of: Fix comparison of reserved memory regions
ROL on a 32 bit integer with a shift of 32 or more is undefined and the
result is arch-dependent. Avoid this by handling the trivial case of
roling by 0 correctly.
The trivial solution of checking if shift is 0 breaks gcc's detection
of this code as a ROL instruction, which is unacceptable.
This bug was reported and fixed in GCC
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=57157):
The standard rotate idiom,
(x << n) | (x >> (32 - n))
is recognized by gcc (for concreteness, I discuss only the case that x
is an uint32_t here).
However, this is portable C only for n in the range 0 < n < 32. For n
== 0, we get x >> 32 which gives undefined behaviour according to the
C standard (6.5.7, Bitwise shift operators). To portably support n ==
0, one has to write the rotate as something like
(x << n) | (x >> ((-n) & 31))
And this is apparently not recognized by gcc.
Note that this is broken on older GCCs and will result in slower ROL.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
In checking fixes for of_irq_find_parent declaration location, I found
that of_msi_map_rid is also wrong. of_msi_map_rid is not implemented for
Sparc, so it should not be in the Sparc specific section of the header.
Move it to just depend on OF_IRQ.
Cc: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
of_irq_find_parent was made static since it had no users outside of
of_irq.c. Export it again since we are going to use it again.
Signed-off-by: Carlo Caione <carlo@endlessm.com>
[robh: move of_irq_find_parent to correct ifdef section]
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"More change than I'd have liked at this stage. The pids controller
and the changes made to cgroup core to support it introduced and
revealed several important issues.
- Assigning membership to a newly created task and migrating it can
race leading to incorrect accounting. Oleg fixed it by widening
threadgroup synchronization. It looks like we'll be able to merge
it with a different percpu rwsem which is used in fork path making
things simpler and cheaper.
- The recent change to extend cgroup membership to zombies (so that
pid accounting can extend till the pid is actually released) missed
pinning the underlying data structures leading to use-after-free.
Fixed.
- v2 hierarchy was calling subsystem callbacks with the wrong target
cgroup_subsys_state based on the incorrect assumption that they
share the same target. pids is the first controller affected by
this. Subsys callbacks updated so that they can deal with
multi-target migrations"
* 'for-4.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup_pids: don't account for the root cgroup
cgroup: fix handling of multi-destination migration from subtree_control enabling
cgroup_freezer: simplify propagation of CGROUP_FROZEN clearing in freezer_attach()
cgroup: pids: kill pids_fork(), simplify pids_can_fork() and pids_cancel_fork()
cgroup: pids: fix race between cgroup_post_fork() and cgroup_migrate()
cgroup: make css_set pin its css's to avoid use-afer-free
cgroup: fix cftype->file_offset handling
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Nothing too interesting. All are device specific additions and
workarounds"
* 'for-4.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ata/sata_fsl.c: add ATA_FLAG_NO_LOG_PAGE to blacklist the controller for log page reads
libata-eh.c: Introduce new ata port flag for controller which lockup on read log page
sata_sil: disable trim
AHCI: Fix softreset failed issue of Port Multiplier
sata/mvebu: use #ifdef around suspend/resume code
ahci: Order SATA device IDs for codename Lewisburg
ahci: Add Device ID for Intel Sunrise Point PCH
Pull perf fixes from Ingo Molnar:
"This tree includes four core perf fixes for misc bugs, three fixes to
x86 PMU drivers, and two updates to old email addresses"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Do not send exit event twice
perf/x86/intel: Fix INTEL_FLAGS_UEVENT_CONSTRAINT_DATALA_NA macro
perf/x86/intel: Make L1D_PEND_MISS.FB_FULL not constrained on Haswell
perf: Fix PERF_EVENT_IOC_PERIOD deadlock
treewide: Remove old email address
perf/x86: Fix LBR call stack save/restore
perf: Update email address in MAINTAINERS
perf/core: Robustify the perf_cgroup_from_task() RCU checks
perf/core: Fix RCU problem with cgroup context switching code
mlx4 devices (ConnectX-2, ConnectX-3) has a limitation
where rdma read work queue entries cannot exceed 512 bytes.
A rdma_read wqe needs to fit in 512 bytes:
- wqe control segment (16 bytes)
- rdma segment (16 bytes)
- scatter elements (16 bytes each)
So max_sge_rd should be: (512 - 16 - 16) / 16 = 30.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Receipt of CM MAD with other than the Send method for an attribute
other than the ClassPortInfo attribute is invalid.
CM attributes other than ClassPortInfo only use the send method.
The SRP initiator does not maintain a timeout policy for CM connect
requests relies on the CM layer to do that. The result was that
the SRP initiator hung as the connect request never completed.
A new SRP target has been observed to respond to Send CM REQ
with GetResp of CM REQ with bad status. This is non conformant
with IBA spec but exposes a vulnerability in the current MAD/CM
code which will respond to the incoming GetResp of CM REQ as if
it was a valid incoming Send of CM REQ rather than tossing
this on the floor. It also causes the MAD layer not to
retransmit the original REQ even though it has not received a REP.
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Hal Rosenstock <hal@mellanox.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
