1. The tracee can go from ptrace_stop() to do_signal_stop()
after __ptrace_unlink(p).
2. It is unsafe to __ptrace_unlink(p) while p->parent may wait
for tasklist_lock in ptrace_detach().
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
To find out if a packet needs to be handled by IPsec after SNAT, packets
are currently rerouted in POST_ROUTING and a new xfrm lookup is done. This
breaks SNAT of non-unicast packets to non-local addresses because the
packet is routed as incoming packet and no neighbour entry is bound to the
dst_entry. In general, it seems to be a bad idea to replace the dst_entry
after the packet was already sent to the output routine because its state
might not match what's expected.
This patch changes the xfrm lookup in POST_ROUTING to re-use the original
dst_entry without routing the packet again. This means no policy routing
can be used for transport mode transforms (which keep the original route)
when packets are SNATed to match the policy, but it looks like the best
we can do for now.
Make the FRV arch use virtual interrupt disablement because accesses to the
processor status register (PSR) are relatively slow and because we will
soon have the need to deal with multiple interrupt controls at the same
time (separate h/w and inter-core interrupts).
The way this is done is to dedicate one of the four integer condition code
registers (ICC2) to maintaining a virtual interrupt disablement state
whilst inside the kernel. This uses the ICC2.Z flag (Zero) to indicate
whether the interrupts are virtually disabled and the ICC2.C flag (Carry)
to indicate whether the interrupts are physically disabled.
ICC2.Z is set to indicate interrupts are virtually disabled. ICC2.C is set
to indicate interrupts are physically enabled. Under normal running
conditions Z==0 and C==1.
Disabling interrupts with local_irq_disable() doesn't then actually
physically disable interrupts - it merely sets ICC2.Z to 1. Should an
interrupt then happen, the exception prologue will note ICC2.Z is set and
branch out of line using one instruction (an unlikely BEQ). Here it will
physically disable interrupts and clear ICC2.C.
When it comes time to enable interrupts (local_irq_enable()), this simply
clears the ICC2.Z flag and invokes a trap #2 if both Z and C flags are
clear (the HI integer condition). This can be done with the TIHI
conditional trap instruction.
The trap then physically reenables interrupts and sets ICC2.C again. Upon
returning the interrupt will be taken as interrupts will then be enabled.
Note that whilst processing the trap, the whole exceptions system is
disabled, and so an interrupt can't happen till it returns.
If no pending interrupt had happened, ICC2.C would still be set, the HI
condition would not be fulfilled, and no trap will happen.
Saving interrupts (local_irq_save) is simply a matter of pulling the ICC2.Z
flag out of the CCR register, shifting it down and masking it off. This
gives a result of 0 if interrupts were enabled and 1 if they weren't.
Restoring interrupts (local_irq_restore) is then a matter of taking the
saved value mentioned previously and XOR'ing it against 1. If it was one,
the result will be zero, and if it was zero the result will be non-zero.
This result is then used to affect the ICC2.Z flag directly (it is a
condition code flag after all). An XOR instruction does not affect the
Carry flag, and so that bit of state is unchanged. The two flags can then
be sampled to see if they're both zero using the trap (TIHI) as for the
unconditional reenablement (local_irq_enable).
This patch also:
(1) Modifies the debugging stub (break.S) to handle single-stepping crossing
into the trap #2 handler and into virtually disabled interrupts.
(2) Removes superseded fixup pointers from the second instructions in the trap
tables (there's no a separate fixup table for this).
(3) Declares the trap #3 vector for use in .org directives in the trap table.
(4) Moves irq_enter() and irq_exit() in do_IRQ() to avoid problems with
virtual interrupt handling, and removes the duplicate code that has now
been folded into irq_exit() (softirq and preemption handling).
(5) Tells the compiler in the arch Makefile that ICC2 is now reserved.
(6) Documents the in-kernel ABI, including the virtual interrupts.
(7) Renames the old irq management functions to different names.
Make various alterations and fixes to the FRV arch:
(1) Resyncs the FRV system call collection with the i386 arch.
(2) Discards __iounmap() as it's not used.
(3) Fixes the use of the SWAP/SWAPI instruction to get the arguments the right
way around in atomic.h, and also to get the asm constraints correct.
(4) Moves copy_to/from_user_page() to asm/cacheflush.h to be consistent with
other archs.
Revert commit d7102e95b7b9c00277562c29aad421d2d521c5f6:
[PATCH] sched: filter affine wakeups
Apparently caused more than 10% performance regression for aim7 benchmark.
The setup in use is 16-cpu HP rx8620, 64Gb of memory and 12 MSA1000s with 144
disks. Each disk is 72Gb with a single ext3 filesystem (courtesy of HP, who
supplied benchmark results).
The problem is, for aim7, the wake-up pattern is random, but it still needs
load balancing action in the wake-up path to achieve best performance. With
the above commit, lack of load balancing hurts that workload.
However, for workloads like database transaction processing, the requirement
is exactly opposite. In the wake up path, best performance is achieved with
absolutely zero load balancing. We simply wake up the process on the CPU that
it was previously run. Worst performance is obtained when we do load
balancing at wake up.
There isn't an easy way to auto detect the workload characteristics. Ingo's
earlier patch that detects idle CPU and decide whether to load balance or not
doesn't perform with aim7 either since all CPUs are busy (it causes even
bigger perf. regression).
Revert commit d7102e95b7b9c00277562c29aad421d2d521c5f6, which causes more
than 10% performance regression with aim7.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Currently, copy-on-write may change the physical address of a page even if the
user requested that the page is pinned in memory (either by mlock or by
get_user_pages). This happens if the process forks meanwhile, and the parent
writes to that page. As a result, the page is orphaned: in case of
get_user_pages, the application will never see any data hardware DMA's into
this page after the COW. In case of mlock'd memory, the parent is not getting
the realtime/security benefits of mlock.
In particular, this affects the Infiniband modules which do DMA from and into
user pages all the time.
This patch adds madvise options to control whether memory range is inherited
across fork. Useful e.g. for when hardware is doing DMA from/into these
pages. Could also be useful to an application wanting to speed up its forks
by cutting large areas out of consideration.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
Acked-by: Hugh Dickins <hugh@veritas.com>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
The correct way to export hyperthreading based functions is to predicate
them on CONFIG_X86_HT. Without this, the topology exporting patch breaks
the build on all non-PC x86 subarchitectures.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
If 2 threads attached to the same process are blocking on different locks on
different files (maybe even on different servers) but have the same lock
arguments (i.e. same offset+length - actually quite common, since most
processes try to lock the entire file) then the first GRANTED call that wakes
one up will also wake the other.
Currently when the NLM_GRANTED callback comes in, lockd walks the list of
blocked locks in search of a match to the lock that the NLM server has
granted. Although it checks the lock pid, start and end, it fails to check
the filehandle and the server address.
By checking the filehandle and server IP address, we ensure that this only
happens if the locks truly are referencing the same file.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
This patch reverts commit f93ea411b73594f7d144855fd34278bcf34a9afc:
[PATCH] jbd: split checkpoint lists
This broke journal_flush() for OCFS2, which is its method of being sure
that metadata is sent to disk for another node.
And two related commits 8d3c7fce2d20ecc3264c8d8c91ae3beacdeaed1b and
43c3e6f5abdf6acac9b90c86bf03f995bf7d3d92 with the subjects:
[PATCH] jbd: log_do_checkpoint fix
[PATCH] jbd: remove_transaction fix
These seem to be incremental bugfixes on the original patch and as such are
no longer needed.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
From Richard Sandiford <richard@codesourcery.com>:
This patch caused a miscompilation of the restore_gp_regs() block
in restore_sigcontext(). This was in a 32-bit kernel compiled with
GCC CVS head.
restore_gp_regs() copies 64-bit user fields into 32-bit variables,
and in this combination, the new __get_user_asm_ll32() clobbers too
many registers. It says:
* Get a long long 64 using 32 bit registers.
__asm__ __volatile__( \
"1: lw %1, (%3) \n" \
"2: lw %D1, 4(%3) \n" \
" move %0, $0 \n" \
"3: .section .fixup,\"ax\" \n" \
"4: li %0, %4 \n" \
" move %1, $0 \n" \
" move %D1, $0 \n" \
" j 3b \n" \
" .previous \n" \
" .section __ex_table,\"a\" \n" \
" " __UA_ADDR " 1b, 4b \n" \
" " __UA_ADDR " 2b, 4b \n" \
" .previous \n" \
: "=r" (__gu_err), "=&r" (val) \
: "0" (0), "r" (addr), "i" (-EFAULT)); \
and this requires val (%1) to be a 64-bit value. In the case I saw,
gcc was using $3 for the 32-bit val, and wasn't expecting $4 to be
clobbered.
Add blast_xxx_range(), protected_blast_xxx_range() etc. for common
use. They are built by __BUILD_BLAST_CACHE_RANGE().
Use protected_cache_op() macro for various protected_ routines.
Output code should be logically same.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
So we can get rid of config.h and the #ifdef crapola in the generic
timex.h.
Based upon a patch by Dave Jones.
Signed-off-by: Dave Jones <davej@redhat.com>
This patch reduces the default L2CAP MTU for all RFCOMM connections
from 1024 to 1013 to improve the interoperability with some broken
RFCOMM implementations. To make this more flexible the L2CAP MTU
becomes also a module parameter and so it can changed at runtime.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Add fstatat64 support to s390 in order to follow changes with
commit cff2b760096d1e6feaa31948e7af4abbefe47822 .
Also fixes compilation for 31 bit.
Add support for Geforce4 MX 4000 (0x185)
Signed-off-by: Antonino Daplas <adaplas@pol.net>
Right now in __constant_test_bit for the s390 there is an extra set of ()
surrounding the calculation. This patch simply removes one set of () that is
surrounding the whole clause.
Signed-off-by: Eric Paris <eparis@redhat.com>
Based on a patch from Maximilian Attems <maks@sternwelten.at> . Nothing in
asm-s390/setup.h is of interest for user space.
Add support for unshare system call.
Add missing smp_cpu_not_running define to avoid build warnings in the non smp
case.
With David Woodhouse <dwmw2@infradead.org>
select() presently has a habit of increasing the value of the user's
`timeout' argument on return.
We were writing back a timeout larger than the original. We _deliberately_
round up, since we know we must wait at _least_ as long as the caller asks
us to.
The patch adds a couple of helper functions for magnitude comparison of
timespecs and of timevals, and uses them to prevent the various poll and
select functions from returning a timeout which is larger than the one which
was passed in.
The patch also fixes a bug in compat_sys_pselect7(): it was adding the new
timeout value to the old one and was returning that. It should just return
the new timeout value.
(We have various handy timespec/timeval-to-from-nsec conversion functions in
time.h. But this code open-codes it all).
Cc: Andi Kleen <ak@muc.de>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: george anzinger <george@mvista.com>
[description from AK]
The IBM Summit 3 chipset doesn't implement the HPET timer replacement
option. Since the current Linux code relies on it use a mixed mode with
both PIT for the interrupt and HPET counters for the time keeping. That
was already implemented, but didn't work properly because it was still
using the last interrupt offset in HPET. This resulted in x460 not
booting. Fix this up by using the free running HPET counter.
Shouldn't affect any other machine because they either use full HPET mode
or no HPET at all.
TBD needs a similar 32bit fix.
Signed-off-by: Andi Kleen <ak@suse.de>
Cc: Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com>
Cc: Bob Picco <bob.picco@hp.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: john stultz <johnstul@us.ibm.com>
The *at patches introduced fstatat and, due to inusfficient research, I
used the newfstat functions generally as the guideline. The result is that
on 32-bit platforms we don't have all the information needed to implement
fstatat64.
This patch modifies the code to pass up 64-bit information if
__ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make
this clear. Other archs will continue to use the existing code. On x86-64
the compat code is implemented using a new sys32_ function. this is what
is done for the other stat syscalls as well.
This patch might break some other archs (those which define
__ARCH_WANT_STAT64 and which already wired up the syscall). Yet others
might need changes to accomodate the compatibility mode. I really don't
want to do that work because all this stat handling is a mess (more so in
glibc, but the kernel is also affected). It should be done by the arch
maintainers. I'll provide some stand-alone test shortly. Those who are
eager could compile glibc and run 'make check' (no installation needed).
The patch below has been tested on x86 and x86-64.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Patch from Ben Dooks
Define the bits for the two board control latches
that control various items on the H1940 iPAQ.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Prevent stalled processing of received data when a driver allocates tty
buffer space but does not immediately follow the allocation with more data
and a call to schedule receive tty processing. (example: hvc_console) This
bug was introduced by the first locking patch for the new tty buffering.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Initialising cpu_possible_map to all-ones with CONFIG_HOTPLUG_CPU means that
a) All for_each_cpu() loops will iterate across all NR_CPUS CPUs, rather
than over possible ones. That can be quite expensive.
b) Soon we'll be allocating per-cpu areas only for possible CPUs. So with
CPU_MASK_ALL, we'll be wasting memory.
I also switched voyager over to not use CPU_MASK_ALL in the non-CPU-hotplug
case. Should be OK..
I note that parisc is also using CPU_MASK_ALL. Suggest that it stop doing
that.
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Paul Jackson <pj@sgi.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Zwane Mwaikambo <zwane@linuxpower.ca>
It is possible that the reserved crashkernel region can be overlapped with
initrd since the bootloader sets the initrd location. When the initrd
region is freed, the second kernel memory will not be contiguous. The
Kexec_load can cause an oops since there is no contiguous memory to write
the second kernel or this memory could be used in the first kernel itself
and may not be part of the dump. For example, on powerpc, the initrd is
located at 36MB and the crashkernel starts at 32MB. The kexec_load caused
panic since writing into non-allocated memory (after 36MB). We could see
the similar issue even on other archs.
One possibility is to move the initrd outside of crashkernel region. But,
the initrd region will be freed anyway before the system is up. This patch
fixes this issue and frees only regions that are not part of crashkernel
memory in case overlaps.
Signed-off-by: Haren Myneni <haren@us.ibm.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Registers system call for the powerpc architecture.
Signed-off-by: Janak Desai <janak@us.ibm.com>
Cc: Al Viro <viro@ftp.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
This patch set IrDA's addr_len properly, i.e to 4 bytes, the size of the
IrLAP device address.
Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com>
netlink overrun was broken while improvement of netlink.
Destination socket is used in the place where it was meant to be source socket,
so that now overrun is never sent to user netlink sockets, when it should be,
and it even can be set on kernel socket, which results in complete deadlock
of rtnetlink.
Suggested fix is to restore status quo passing source socket as additional
argument to netlink_attachskb().
A little explanation: overrun is set on a socket, when it failed
to receive some message and sender of this messages does not or even
have no way to handle this error. This happens in two cases:
1. when kernel sends something. Kernel never retransmits and cannot
wait for buffer space.
2. when user sends a broadcast and the message was not delivered
to some recipients.
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Clear unblockable signals beforehand.
Add unshare syscall for x86-64
ppoll/pselect are not ready yet, but add reservations.
Registers system call for the ia64 architecture.
Reserves space for ppoll and pselect, and adds unshare at system
call number 1296.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Manual conflict merge of arch/arm/Kconfig
Patch from Tony Lindgren
This patch adds the missing cache flushes to common low-level
init that are needed to access the IO region. These flushes
are normally done at the end of devicemaps_init(), but we
need to detect the OMAP core type early.
This patch adds new PCI serial card support.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Patch from Nicolas Pitre
Since:
if (unlikely(__res || __ex_flag))
produces worse code on ARM than:
if (unlikely(__res | __ex_flag))
I therefore made it more explicit:
__res |= __ex_flag;
if (unlikely(__res != 0))
so it is not seen as a typo again.
Also made everything static inline rather than macros for better readability
(both produce the same code after all).
And finally added missing \t from multi-line assembly code.
Signed-off-by: Nicolas Pitre <nico@cam.org>
