path: root/include
2011-07-28md: load/store badblock list from v1.x metadataNeilBrown
Space must have been allocated when array was created. A feature flag is set when the badblock list is non-empty, to ensure old kernels don't load and trust the whole device. We only update the on-disk badblocklist when it has changed. If the badblocklist (or other metadata) is stored on a bad block, we don't cope very well. If metadata has no room for bad block, flag bad-blocks as disabled, and do the same for 0.90 metadata. Signed-off-by: NeilBrown <neilb@suse.de>
2011-07-15drm/radeon/kms: add new NI pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: core: Bus width testing needs to handle suspend/resume
2011-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) slip: fix wrong SLIP6 ifdef-endif placing natsemi: fix another dma-debug report sctp: ABORT if receive, reassmbly, or reodering queue is not empty while closing socket net: Fix default in docs for tcp_orphan_retries. hso: fix a use after free condition net/natsemi: Fix module parameter permissions XFRM: Fix memory leak in xfrm_state_update sctp: Enforce retransmission limit during shutdown mac80211: fix TKIP replay vulnerability mac80211: fix ie memory allocation for scheduled scans ssb: fix init regression of hostmode PCI core rtlwifi: rtl8192cu: Add new USB ID for Netgear WNA1000M ath9k: Fix tx throughput drops for AR9003 chips with AES encryption carl9170: add NEC WL300NU-AG usbid cfg80211: fix deadlock with rfkill/sched_scan by adding new mutex ath5k: fix incorrect use of drvdata in PCI suspend/resume code ath5k: fix incorrect use of drvdata in sysfs code Bluetooth: Fix memory leak under page timeouts Bluetooth: Fix regression with incoming L2CAP connections Bluetooth: Fix hidp disconnect deadlocks and lost wakeup ...
2011-07-13mmc: core: Bus width testing needs to handle suspend/resumePhilip Rakity
On reading the ext_csd for the first time (in 1 bit mode), save the ext_csd information needed for bus width compare. On every pass we make re-reading the ext_csd, compare the data against the saved ext_csd data. This fixes a regression introduced in 3.0-rc1 by 08ee80cc397ac1a3 ("mmc: core: eMMC bus width may not work on all platforms"), which incorrectly assumed we would be re-reading the ext_csd at resume- time. Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-12Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/mm: Fix memory_block_size_bytes() for non-pseries mm: Move definition of MIN_MEMORY_BLOCK_SIZE to a header
2011-07-12Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: pcmcia: pxa2xx/vpac270: free gpios on exist rather than requesting ARM: pxa/raumfeld: fix device name for codec ak4104 ARM: pxa/raumfeld: display initialisation fixes ARM: pxa/raumfeld: adapt to upcoming hardware change ARM: pxa: fix gpio_to_chip() clash with gpiolib namespace genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd) arm: mach-vt8500: add forgotten irq_data conversion ARM: pxa168: correct nand pmu setting ARM: pxa910: correct nand pmu setting ARM: pxa: fix PGSR register address calculation
2011-07-12mm: Move definition of MIN_MEMORY_BLOCK_SIZE to a headerBenjamin Herrenschmidt
The macro MIN_MEMORY_BLOCK_SIZE is currently defined twice in two .c files, and I need it in a third one to fix a powerpc bug, so let's first move it into a header Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2011-07-11Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] msp3400: fill in v4l2_tuner based on vt->type field [media] tuner-core.c: don't change type field in g_tuner or g_frequency [media] cx18/ivtv: fix g_tuner support [media] tuner-core: power up tuner when called with s_power(1) [media] v4l2-ioctl.c: check for valid tuner type in S_HW_FREQ_SEEK [media] tuner-core: simplify the standard fixup [media] tuner-core/v4l2-subdev: document that the type field has to be filled in [media] v4l2-subdev.h: remove unused s_mode tuner op [media] feature-removal-schedule: change in how radio device nodes are handled [media] bttv: fix s_tuner for radio [media] pvrusb2: fix g/s_tuner support [media] v4l2-ioctl.c: prefill tuner type for g_frequency and g/s_tuner [media] tuner-core: fix tuner_resume: use t->mode instead of t->type [media] tuner-core: fix s_std and s_tuner
2011-07-08w1: ds1wm: add a reset recovery parameterJean-François Dagenais
This fixes a regression in 3.0 reported by Paul Parsons regarding the removal of the msleep(1) in the ds1wm_reset() function: : The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying" : error messages on an HP iPAQ hx4700 PDA (XScale-PXA270): : : <snip> : Driver for 1-wire Dallas network protocol. : DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko : 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko : ds1wm ds1wm: pass: 1 bus error, retrying : ds1wm ds1wm: pass: 2 bus error, retrying : ds1wm ds1wm: pass: 3 bus error, retrying : ds1wm ds1wm: pass: 4 bus error, retrying : ds1wm ds1wm: pass: 5 bus error, retrying : ... : : The visible result is that the battery charging LED is erratic; sometimes : it works, mostly it doesn't. : : The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1, : 3.0-rc2, or 3.0-rc3. This sleep should not be required on normal circuitry provided the pull-ups on the bus are correctly adapted to the slaves. Unfortunately, this is not always the case. The sleep is restored but as a parameter to the probe function in the pdata. [akpm@linux-foundation.org: coding-style fixes] Reported-by: Paul Parsons <lost.distance@yahoo.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08sctp: ABORT if receive, reassmbly, or reodering queue is not empty while ↵Thomas Graf
closing socket Trigger user ABORT if application closes a socket which has data queued on the socket receive queue or chunks waiting on the reassembly or ordering queue as this would imply data being lost which defeats the point of a graceful shutdown. This behavior is already practiced in TCP. We do not check the input queue because that would mean to parse all chunks on it to look for unacknowledged data which seems too much of an effort. Control chunks or duplicated chunks may also be in the input queue and should not be stopping a graceful shutdown. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07sctp: Enforce retransmission limit during shutdownThomas Graf
When initiating a graceful shutdown while having data chunks on the retransmission queue with a peer which is in zero window mode the shutdown is never completed because the retransmission error count is reset periodically by the following two rules: - Do not timeout association while doing zero window probe. - Reset overall error count when a heartbeat request has been acknowledged. The graceful shutdown will wait for all outstanding TSN to be acknowledged before sending the SHUTDOWN request. This never happens due to the peer's zero window not acknowledging the continuously retransmitted data chunks. Although the error counter is incremented for each failed retransmission, the receiving of the SACK announcing the zero window clears the error count again immediately. Also heartbeat requests continue to be sent periodically. The peer acknowledges these requests causing the error counter to be reset as well. This patch changes behaviour to only reset the overall error counter for the above rules while not in shutdown. After reaching the maximum number of retransmission attempts, the T5 shutdown guard timer is scheduled to give the receiver some additional time to recover. The timer is stopped as soon as the receiver acknowledges any data. The issue can be easily reproduced by establishing a sctp association over the loopback device, constantly queueing data at the sender while not reading any at the receiver. Wait for the window to reach zero, then initiate a shutdown by killing both processes simultaneously. The association will never be freed and the chunks on the retransmission queue will be retransmitted indefinitely. Signed-off-by: Thomas Graf <tgraf@infradead.org> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-07Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: drbd: we should write meta data updates with FLUSH FUA drbd: fix limit define, we support 1 PiByte now drbd: when receive times out on meta socket, also check last receive time on data socket drbd: account bitmap IO during resync as resync-(related-)-io drbd: don't cond_resched_lock with IRQs disabled drbd: add missing spinlock to bitmap receive drbd: Use the correct max_bio_size when creating resync requests cfq-iosched: make code consistent cfq-iosched: fix a rcu warning
2011-07-07FS-Cache: Add a helper to bulk uncache pages on an inodeDavid Howells
Add an FS-Cache helper to bulk uncache pages on an inode. This will only work for the circumstance where the pages in the cache correspond 1:1 with the pages attached to an inode's page cache. This is required for CIFS and NFS: When disabling inode cookie, we were returning the cookie and setting cifsi->fscache to NULL but failed to invalidate any previously mapped pages. This resulted in "Bad page state" errors and manifested in other kind of errors when running fsstress. Fix it by uncaching mapped pages when we disable the inode cookie. This patch should fix the following oops and "Bad page state" errors seen during fsstress testing. ------------[ cut here ]------------ kernel BUG at fs/cachefiles/namei.c:201! invalid opcode: 0000 [#1] SMP Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles] RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282 RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282 RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300 R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840 R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0 FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0) Stack: 0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00 ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380 ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56 Call Trace: cachefiles_lookup_object+0x78/0xd4 [cachefiles] fscache_lookup_object+0x131/0x16d [fscache] fscache_object_work_func+0x1bc/0x669 [fscache] process_one_work+0x186/0x298 worker_thread+0xda/0x15d kthread+0x84/0x8c kernel_thread_helper+0x4/0x10 RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles] ---[ end trace 1d481c9af1804caa ]--- I tested the uncaching by the following means: (1) Create a big file on my NFS server (104857600 bytes). (2) Read the file into the cache with md5sum on the NFS client. Look in /proc/fs/fscache/stats: Pages : mrk=25601 unc=0 (3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc again: Pages : mrk=25601 unc=25601 Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de> cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-07Merge branches 'core-urgent-for-linus', 'perf-urgent-for-linus' and ↵Linus Torvalds
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: Fix boot crash when kmemleak and debugobjects enabled * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: jump_label: Fix jump_label update for modules oprofile, x86: Fix race in nmi handler while starting counters * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Disable (revert) SCHED_LOAD_SCALE increase sched, cgroups: Fix MIN_SHARES on 64-bit boxen
2011-07-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) sctp: fix missing send up SCTP_SENDER_DRY_EVENT when subscribe it net: refine {udp|tcp|sctp}_mem limits vmxnet3: round down # of queues to power of two net: sh_eth: fix the parameter for the ETHER of SH7757 net: sh_eth: fix cannot work half-duplex mode net: vlan: enable soft features regardless of underlying device vmxnet3: fix starving rx ring whenoc_skb kb fails bridge: Always flood broadcast packets greth: greth_set_mac_add would corrupt the MAC address. net: bind() fix error return on wrong address family natsemi: silence dma-debug warnings net: 8139too: Initial necessary vlan_features to support vlan Fix call trace when interrupts are disabled while sleeping function kzalloc is called qlge:Version change to v1.00.00.29 qlge: Fix printk priority so chip fatal errors are always reported. qlge:Fix crash caused by mailbox execution on wedged chip. xfrm4: Don't call icmp_send on local error ipv4: Don't use ufo handling on later transformed packets xfrm: Remove family arg from xfrm_bundle_ok ipv6: Don't put artificial limit on routing table size. ...
2011-07-07[media] tuner-core/v4l2-subdev: document that the type field has to be filled inHans Verkuil
The tuner ops g_frequency, g_tuner and s_tuner require that the tuner type field is filled in. Document this. The tuner-core doc is based on a patch from Mauro Carvalho Chehab <mchehab@redhat.com>. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-07[media] v4l2-subdev.h: remove unused s_mode tuner opHans Verkuil
s_mode is no longer used, so remove it. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-07genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd)Simon Guinot
This fixes a regression introduced by e59347a "arm: orion: Use generic irq chip". Depending on the device, interrupts acknowledgement is done by setting or by clearing a dedicated register. Replace irq_gc_ack() with some {set,clr}_bit variants allows to handle both cases. Note that this patch affects the following SoCs: Davinci, Samsung and Orion. Except for this last, the change is minor: irq_gc_ack() is just renamed into irq_gc_ack_set_bit(). For the Orion SoCs, the edge GPIO interrupts support is currently broken. irq_gc_ack() try to acknowledge a such interrupt by setting the corresponding cause register bit. The Orion GPIO device expect the opposite. To fix this issue, the irq_gc_ack_clr_bit() variant is used. Tested on Network Space v2. Reported-by: Joey Oravec <joravec@drewtech.com> Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-07-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits) [media] rc: call input_sync after scancode reports [media] imon: allow either proto on unknown 0xffdc [media] imon: auto-config ffdc 7e device [media] saa7134: fix raw IR timeout value [media] rc: fix ghost keypresses with certain hw [media] [staging] lirc_serial: allocate irq at init time [media] lirc_zilog: fix spinning rx thread [media] keymaps: fix table for pinnacle pctv hd devices [media] ite-cir: 8709 needs to use pnp resource 2 [media] V4L: mx1-camera: fix uninitialized variable [media] omap_vout: Added check in reqbuf & mmap for buf_size allocation [media] OMAP_VOUT: Change hardcoded device node number to -1 [media] OMAP_VOUTLIB: Fix wrong resizer calculation [media] uvcvideo: Disable the queue when failing to start [media] uvcvideo: Remove buffers from the queues when freeing [media] uvcvideo: Ignore entities for terminals with no supported format [media] v4l: Don't access media entity after is has been destroyed [media] media: omap3isp: fix a potential NULL deref [media] media: vb2: fix allocation failure check [media] media: vb2: reset queued_count value during queue reinitialization ... Fix up trivial conflict in MAINTAINERS as per Mauro
2011-07-05sched: Disable (revert) SCHED_LOAD_SCALE increasePeter Zijlstra
Alex reported that commit c8b281161df ("sched: Increase SCHED_LOAD_SCALE resolution") caused a power usage regression under light load as it increases the number of load-balance operations and keeps idle cpus from staying idle. Time has run out to find the root cause for this release so disable the feature for v3.0 until we can figure out what causes the problem. Reported-by: "Alex, Shi" <alex.shi@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nikhil Rao <ncrao@google.com> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-m4onxn0sxnyn5iz9o88eskc3@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-04Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x: vesafb: fix memory leak fbdev: amba: Link fb device to its parent fsl-diu-fb: remove check for pixel clock ranges udlfb: Correct sub-optimal resolution selection. hecubafb: add module_put on error path in hecubafb_probe() sm501fb: fix section mismatch warning gx1fb: Fix section mismatch warnings fbdev: sh_mobile_meram: Correct pointer check for YCbCr chroma plane
2011-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sb16 - Fix build errors on MIPS and others with 13bit ioctl size ALSA: hdspm - Fix compile warnings with PPC ALSA: cs5535 - Fix invalid big-endian conversions ALSA: HDMI - fix ELD monitor name length ALSA: atmel - update author email for ABDAC, AC97C and AT73C213 ALSA: HDA: Add model=auto quirk for Acer Aspire 3830TG ALSA: HDA: Add a new Conexant codec ID (506c)
2011-07-01ipv6: Don't put artificial limit on routing table size.David S. Miller
IPV6, unlike IPV4, doesn't have a routing cache. Routing table entries, as well as clones made in response to route lookup requests, all live in the same table. And all of these things are together collected in the destination cache table for ipv6. This means that routing table entries count against the garbage collection limits, even though such entries cannot ever be reclaimed and are added explicitly by the administrator (rather than being created in response to lookups). Therefore it makes no sense to count ipv6 routing table entries against the GC limits. Add a DST_NOCOUNT destination cache entry flag, and skip the counting if it is set. Use this flag bit in ipv6 when adding routing table entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01Merge branch 'for-davem' of ↵David S. Miller
2011-06-30Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-30ALSA: sb16 - Fix build errors on MIPS and others with 13bit ioctl sizeTakashi Iwai
One of ioctl definition in sound/sb16_csp.h contains the data size over 8kB, and this causes build errors on architectures like MIPS, which define _IOC_SIZEBITS=13. For avoiding this build errors but keeping the compatibility, manually expand with _IOC() instead of using _IOW() for the problematic ioctl. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-30Merge branch 'for-3.0-important' of git://git.drbd.org/linux-2.6-drbd into ↵Jens Axboe
for-linus
2011-06-30drbd: fix limit define, we support 1 PiByte nowLars Ellenberg
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-28Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Connector: Correctly set the error code in case of success when dispatching receive callbacks Connector: Set the CN_NETLINK_USERS correctly pti: PTI semantics fix in pti_tty_cleanup. pti: ENXIO error case memory leak PTI fix. pti: double-free security PTI fix drivers:misc: ti-st: fix skipping of change remote baud drivers/base/platform.c: don't mark platform_device_register_resndata() as __init_or_module st_kim: Handle case of no device found for ID 0 firmware: fix GOOGLE_SMI kconfig dependency warning
2011-06-28Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: serial: bcm63xx_uart: fix irq storm after rx fifo overrun. amba pl011: platform data for reg lockup and glitch v2 amba pl011: workaround for uart registers lockup tty: n_gsm: improper skb_pull() use was leaking framed data tty: n_gsm: Fixed logic to decode break signal from modem status TTY: ntty, add one more sanity check TTY: ldisc, do not close until there are readers 8250: Fix capabilities when changing the port type 8250_pci: Fix missing const from merges ARM: SAMSUNG: serial: Fix on handling of one clock source for UART serial: ioremap warning fix for jsm driver. 8250_pci: add -ENODEV code for Intel EG20T PCH
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27include/linux/compat.h: declare compat_sys_sendmmsg()Chris Metcalf
This is required for tilegx to be able to use the compat unistd.h header where compat_sys_sendmmsg() is now mentioned. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: add shmem_read_mapping_page_gfpHugh Dickins
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp() is unsuited to tmpfs, because it inserts a page into pagecache before calling the filesystem's ->readpage: tmpfs may have pages in swapcache which only it knows how to locate and switch to filecache. At present tmpfs provides a ->readpage method, and copes with this by copying pages; but soon we can simplify it by removing its ->readpage. Provide shmem_read_mapping_page_gfp() now, ready for that transition, Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h, with shmem_read_mapping_page() inline for the common mapping_gfp case. (shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the read_mapping_page functions use the mapping's ->readpage, and the read_cache_page functions use the supplied filler, so I think read_cache_page_gfp was slightly misnamed.) Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move shmem prototypes to shmem_fs.hHugh Dickins
Before adding any more global entry points into shmem.c, gather such prototypes into shmem_fs.h. Remove mm's own declarations from swap.h, but for now leave the ones in mm.h: because shmem_file_setup() and shmem_zero_setup() are called from various places, and we should not force other subsystems to update immediately. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Fix some kernel-doc warningsVitaliy Ivanov
Fix 'make htmldocs' warnings: Warning(/include/linux/hrtimer.h:153): No description found for parameter 'clockid' Warning(/include/linux/device.h:604): Excess struct/union/enum/typedef member 'of_match' description in 'device' Warning(/include/net/sock.h:349): Excess struct/union/enum/typedef member 'sk_rmem_alloc' description in 'sock' Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: queue: bring discard_granularity/alignment into line with SCSI mmc: queue: append partition subname to queue thread name mmc: core: make erase timeout calculation allow for gated clock mmc: block: switch card to User Data Area when removing the block driver mmc: sdio: reset card during power_restore mmc: cb710: fix #ifdef HAVE_EFFICIENT_UNALIGNED_ACCESS mmc: sdhi: DMA slave ID 0 is invalid mmc: tmio: fix regression in TMIO_MMC_WRPROTECT_DISABLE handling mmc: omap_hsmmc: use original sg_len for dma_unmap_sg mmc: omap_hsmmc: fix ocr mask usage mmc: sdio: fix runtime PM path during driver removal mmc: Add PCI fixup quirks for Ricoh 1180:e823 reader mmc: sdhi: fix module unloading mmc: of_mmc_spi: add NO_IRQ define to of_mmc_spi.c mmc: vub300: fix null dereferences in error handling
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mac80211: fix rx->key NULL dereference during mic failureArik Nemtsov
Sometimes when reporting a MIC failure rx->key may be unset. This code path is hit when receiving a packet meant for a multicast address, and decryption is performed in HW. Fortunately, the failing key_idx is not used for anything up to (and including) usermode, so we allow ourselves to drop it on the way up when a key cannot be retrieved. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: Remove unneeded version.h includes from sound/ ASoC: pxa-ssp: Correct check for stream presence ASoC: imx: add missing module informations ASoC: imx: Remove unused Kconfig SND_MXC_SOC_SSI entry ALSA: HDA: Pinfix quirk for HP Z200 Workstation ALSA: VIA HDA: Create a master amplifier control for VT1718S. ALSA: VIA HDA: Mute/unmute mixer conncted to Headphone for VT1718S. ALSA: VIA HDA: Modify initial verbs list for VT1718S. ALSA: hda - Remove ALC268 model override for CPR2000 ALSA: HDA: Remove quirk for an HP device ASoC: Remove unused and about to be broken SND_SOC_CUSTOM I/O bus
2011-06-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: add REQ_SECURE to REQ_COMMON_MASK block: use the passed in @bdev when claiming if partno is zero block: Add __attribute__((format(printf...) and fix fallout block: make disk_block_events() properly wait for work cancellation block: remove non-syncing __disk_block_events() and fold it into disk_block_events() block: don't use non-syncing event blocking in disk_check_events() cfq-iosched: fix locking around ioc->ioc_data assignment
2011-06-24Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-24fsl-diu-fb: remove check for pixel clock rangesTimur Tabi
The Freescale DIU framebuffer driver defines two constants, MIN_PIX_CLK and MAX_PIX_CLK, that are supposed to represent the lower and upper limits of the pixel clock. These values, however, are true only for one platform clock rate (533MHz) and only for the MPC8610. So the actual range for the pixel clock is chip-specific, which means the current values are almost always wrong. The chance of an out-of-range pixel clock being used are also remote. Rather than try to detect an out-of-range clock in the DIU driver, we depend on the board-specific pixel clock function (e.g. p1022ds_set_pixel_clock) to clamp the pixel clock to a supported value. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-22Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PCI / PM: Block races between runtime PM and system sleep PM / Domains: Update documentation PM / Runtime: Handle clocks correctly if CONFIG_PM_RUNTIME is unset PM: Fix async resume following suspend failure PM: Free memory bitmaps if opening /dev/snapshot fails PM: Rename dev_pm_info.in_suspend to is_prepared PM: Update documentation regarding sysdevs PM / Runtime: Update doc: usage count no longer incremented across system PM
2011-06-21Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Fix decode_secinfo_maxsz NFSv4.1: Fix an off-by-one error in pnfs_generic_pg_test NFSv4.1: Fix some issues with pnfs_generic_pg_test NFSv4.1: file layout must consider pg_bsize for coalescing pnfs-obj: No longer needed to take an extra ref at add_device SUNRPC: Ensure the RPC client only quits on fatal signals NFSv4: Fix a readdir regression nfs4.1: mark layout as bad on error path in _pnfs_return_layout nfs4.1: prevent race that allowed use of freed layout in _pnfs_return_layout NFSv4.1: need to put_layout_hdr on _pnfs_return_layout error path NFS: (d)printks should use %zd for ssize_t arguments NFSv4.1: fix break condition in pnfs_find_lseg nfs4.1: fix several problems with _pnfs_return_layout NFSv4.1: allow zero fh array in filelayout decode layout NFSv4.1: allow nfs_fhget to succeed with mounted on fileid NFSv4.1: Fix a refcounting issue in the pNFS device id cache NFSv4.1: deprecate headerpadsz in CREATE_SESSION NFS41: do not update isize if inode needs layoutcommit NLM: Don't hang forever on NLM unlock requests NFS: fix umount of pnfs filesystems
2011-06-21PM: Fix async resume following suspend failureAlan Stern
The PM core doesn't handle suspend failures correctly when it comes to asynchronously suspended devices. These devices are moved onto the dpm_suspended_list as soon as the corresponding async thread is started up, and they remain on the list even if they fail to suspend or the sleep transition is cancelled before they get suspended. As a result, when the PM core unwinds the transition, it tries to resume the devices even though they were never suspended. This patch (as1474) fixes the problem by adding a new "is_suspended" flag to dev_pm_info. Devices are resumed only if the flag is set. [rjw: * Moved the dev->power.is_suspended check into device_resume(), because we need to complete dev->power.completion and clear dev->power.is_prepared too for devices whose dev->power.is_suspended flags are unset. * Fixed __device_suspend() to avoid setting dev->power.is_suspended if async_error is different from zero.] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-06-21PM: Rename dev_pm_info.in_suspend to is_preparedAlan Stern
This patch (as1473) renames the "in_suspend" field in struct dev_pm_info to "is_prepared", in preparation for an upcoming change. The new name is more descriptive of what the field really means. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2011-06-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: jbd2: Fix oops in jbd2_journal_remove_journal_head() jbd2: Remove obsolete parameters in the comments for some jbd2 functions ext4: fixed tracepoints cleanup ext4: use FIEMAP_EXTENT_LAST flag for last extent in fiemap ext4: Fix max file size and logical block counting of extent format file ext4: correct comments for ext4_free_blocks()
2011-06-20vfs: i_state needs to be 'unsigned long' for nowLinus Torvalds
Commit 13e12d14e2dc ("vfs: reorganize 'struct inode' layout a bit") moved things around a bit changed i_state to be unsigned int instead of unsigned long. That was to help structure layout for the 64-bit case, and shrink 'struct inode' a bit (admittedly that only happened when spinlock debugging was on and i_flags didn't pack with i_lock). However, Meelis Roos reports that this results in unaligned exceptions on sprc, and it turns out that the bit-locking primitives that we use for the I_NEW bit want to use the bitops. Which want 'unsigned long', not 'unsigned int'. We really should fix the bit locking code to not have that kind of requirement, but that's a much bigger change. So for now, revert that field back to 'unsigned long' (but keep the other re-ordering changes from the commit that caused this). Andi points out that we have played games with this in 'struct page', so it's solvable with other hacks too, but since right now the struct inode size advantage only happens with some rare config options, it's not worth fighting. It _would_ be worth fixing the bitlocking code, though. Especially since there is no type safety in the bitlocking code (this never caused any warnings, and worked fine on x86-64, because the bitlocks take a 'void *' and x86-64 doesn't care that deeply about alignment). So it's currently a very easy problem to trigger by mistake and never notice. Reported-by: Meelis Roos <mroos@linux.ee> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
