path: root/include
2005-07-16Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-07-16[PATCH] ARM: 2815/1: Shark: new defconfig, fixes with __io and serial portsAlexander Schulz
Patch from Alexander Schulz This patch brings a new default config file for the shark and fixes a compilation issue with io addressing and a runtime problem with the serial ports, where I corrected a wrong regshift value. These are all shark specific files so I hope it is ok to put them in one patch. Signed-off-by: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-16[PATCH] Serial: Remove linux/version.hOlaf Hering
changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-16[PATCH] Serial: Move deprecation of register_serial forward to SeptemberRussell King
I think it's about time to make the build a little more vocal about the expiry of these functions. Due to recent discussions with problems in the console initialisation vs power manglement, I'd like to move the date forward to September. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-15[PATCH] md/raid1: clear bitmap when fullsync completesNeilBrown
We need to be careful differentiating between a resync of a complete array, in which we can clear the bitmap, and a resync of a degraded array, in which we cannot. This patch cleans all that up. Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] uml: consolidate modify_ldtPaolo 'Blaisorblade' Giarrusso
*) Reorganize the two cases of sys_modify_ldt to share all the reasonably common code. *) Avoid memory allocation when unneeded (i.e. when we are writing and the passed buffer size is known), thus not returning ENOMEM (which isn't allowed for this syscall, even if there is no strict "specification"). *) Add copy_{from,to}_user to modify_ldt for TT mode. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13Merge master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
2005-07-13Auto merge with /home/aegl/GIT/linusTony Luck
2005-07-13[PATCH] ppc64: kill bitfields in ppc64 hash codeDavid Gibson
This patch removes the use of bitfield types from the ppc64 hash table manipulation code. Signed-off-by: David Gibson <dwg@au1.ibm.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] s390: fadvise hint values.Martin Schwidefsky
Add special case for the POSIX_FADV_DONTNEED and POSIX_FADV_NOREUSE hint values for s390-64. The user space values in the s390-64 glibc headers for these two defines have always been 6 and 7 instead of 4 and 5. All 64 bit applications therefore use the "wrong" values. To get these applications working without recompiling the kernel needs to accept the "wrong" values. Since the values for s390-31 are 4 and 5 the compat wrapper for fadvise64 and fadvise64_64 need to rewrite the values for 31 bit system calls. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] ppc32: fix destroy_context() race conditionGuillaume Autran
Fix for a race condition when a task gets preempted by another task while executing the destroy_context(...) in a FEW_CONTEXTS environment. mm->context == NO_CONTEXT but the context_map may indicate all contexts are in use. The solution to this problem is to disable kernel preemption while destroying a MMU context. Signed-off-by: Guillaume Autran <gautran@mrv.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] Fix soft lockup due to NTFS: VFS part and explanationAnton Altaparmakov
Something has changed in the core kernel such that we now get concurrent inode write outs, one e.g via pdflush and one via sys_sync or whatever. This causes a nasty deadlock in ntfs. The only clean solution unfortunately requires a minor vfs api extension. First the deadlock analysis: Prerequisive knowledge: NTFS has a file $MFT (inode 0) loaded at mount time. The NTFS driver uses the page cache for storing the file contents as usual. More interestingly this file contains the table of on-disk inodes as a sequence of MFT_RECORDs. Thus NTFS driver accesses the on-disk inodes by accessing the MFT_RECORDs in the page cache pages of the loaded inode $MFT. The situation: VFS inode X on a mounted ntfs volume is dirty. For same inode X, the ntfs_inode is dirty and thus corresponding on-disk inode, which is as explained above in a dirty PAGE_CACHE_PAGE belonging to the table of inodes ($MFT, inode 0). What happens: Process 1: sys_sync()/umount()/whatever... calls __sync_single_inode() for $MFT -> do_writepages() -> write_page for the dirty page containing the on-disk inode X, the page is now locked -> ntfs_write_mst_block() which clears PageUptodate() on the page to prevent anyone else getting hold of it whilst it does the write out (this is necessary as the on-disk inode needs "fixups" applied before the write to disk which are removed again after the write and PageUptodate is then set again). It then analyses the page looking for dirty on-disk inodes and when it finds one it calls ntfs_may_write_mft_record() to see if it is safe to write this on-disk inode. This then calls ilookup5() to check if the corresponding VFS inode is in icache(). This in turn calls ifind() which waits on the inode lock via wait_on_inode whilst holding the global inode_lock. Process 2: pdflush results in a call to __sync_single_inode for the same VFS inode X on the ntfs volume. This locks the inode (I_LOCK) then calls write-inode -> ntfs_write_inode -> map_mft_record() -> read_cache_page() of the page (in page cache of table of inodes $MFT, inode 0) containing the on-disk inode. This page has PageUptodate() clear because of Process 1 (see above) so read_cache_page() blocks when tries to take the page lock for the page so it can call ntfs_read_page(). Thus Process 1 is holding the page lock on the page containing the on-disk inode X and it is waiting on the inode X to be unlocked in ifind() so it can write the page out and then unlock the page. And Process 2 is holding the inode lock on inode X and is waiting for the page to be unlocked so it can call ntfs_readpage() or discover that Process 1 set PageUptodate() again and use the page. Thus we have a deadlock due to ifind() waiting on the inode lock. The only sensible solution: NTFS does not care whether the VFS inode is locked or not when it calls ilookup5() (it doesn't use the VFS inode at all, it just uses it to find the corresponding ntfs_inode which is of course attached to the VFS inode (both are one single struct); and it uses the ntfs_inode which is subject to its own locking so I_LOCK is irrelevant) hence we want a modified ilookup5_nowait() which is the same as ilookup5() but it does not wait on the inode lock. Without such functionality I would have to keep my own ntfs_inode cache in the NTFS driver just so I can find ntfs_inodes independent of their VFS inodes which would be slow, memory and cpu cycle wasting, and incredibly stupid given the icache already exists in the VFS. Below is a patch that does the ilookup5_nowait() implementation in fs/inode.c and exports it. ilookup5_nowait.diff: Introduce ilookup5_nowait() which is basically the same as ilookup5() but it does not wait on the inode's lock (i.e. it omits the wait_on_inode() done in ifind()). This is needed to avoid a nasty deadlock in NTFS. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] inotify: event orderingRobert Love
This rearranges the event ordering for "open" to be consistent with the ordering of the other events. Signed-off-by: Robert Love <rml@novell.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13[PATCH] inotify: move sysctlRobert Love
This moves the inotify sysctl knobs to "/proc/sys/fs/inotify" from "/proc/sys/fs". Also some related cleanup. Signed-off-by: Robert Love <rml@novell.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13Merge /home/torvalds/linux-2.6-armLinus Torvalds
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[IA64] Altix pcibus_to_node implementationChristoph Lameter
The Altix subarch does not provide node information via ACPI. Instead hooks are used to fixup pci structures. This patch determines the nodes for Altix PCI busses. Remote Bridges: --------------- Altix supports remote I/O nodes without memory or processors but with bridges. The TIOCA type of bridge is an AGP bridge and the PROM provides information about the closest node. That information will be returned by pcibus_to_node. The TIOCP remote bridge type is a PCI bridge but the PROM does not provide a closest node id. pcibus_to_node will return -1 for devices on those bridges meaning that device control structures may be allocated on any node. Safeguard: ---------- Should the fixups result in invalid node information for a pci controller then a warning will be printed and pcibus_to_node will return -1. This patch also fixes the "FIXME" in sn_dma_alloc_coherent. This means that dma_alloc_coherent will now use alloc_pages_node to allocate memory local to the node that the PCI device is connected to. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/lenb/linux-2.6Linus Torvalds
2005-07-12[PATCH] v4l: I2C TunerMauro Carvalho Chehab
- Fixed a trouble on tuner-core that generates erros on computers with more than one TV card. - Rename tuner structures fields. - Tail spaces removed. - I2C cleanups and converged to a basic reference structure. - Removed unused structures. - Fix setting frequency on tda8290. - Added code for TEA5767 autodetection. - Standby mode support implemented. It is used to disable a non used tuner. Currenlty implemented on tea5767. - New macro: set_type disables other tuner when changing mode. - Some cleanups. - Use 50 kHz step when tunning radio for most tuners to improve precision. Signed-off-by: Fabien Perrot <perrot1983@yahoo.fr> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-By: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: I2C MiscelaneousMauro Carvalho Chehab
- Removed unused structures. - CodingStyle rules applied to comments. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: SAA7134 hybrid DVBMauro Carvalho Chehab
- Add new Typhoon DVB-T Cardbus. - DVB-T support for MD7134 cardbus and the PCI variants - initial DVB-T support for Lifeview Flydvb-t duo - DVB-T support for Philips TOUGH reference design - Don't turn off the xtal output of tda8274/75 in sleep mode - Let Kconfig decide whether to include frontend-specific code in saa7134-dvb. - Removed unused structures. Signed-off-by: Juergen Orschiedt <jorschiedt@web.de> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] hardirq uses preemptRandy Dunlap
hardirq.h uses preempt_count() from preempt.h Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] kexec-ppc: fix for ksysfs crash_notesAlbert Herranz
The following patch prevents the crash dump helper code found within kexec from breaking ppc which still lacks crash dump functionality. ksysfs crash_notes attribute handling was left under CONFIG_KEXEC for simplicity although it is not strictly kexec related. We provide here a dummy definition for crash_notes on ppc. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] tlb.h warning fixAndrew Morton
free_pages_and_swap_cache() and free_page_and_swap_cache() use release_pages() and page_cache_release() respectively, so make sure that we have the declarations in scope. Cc: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] ext3: fix options parsingJan Kara
Fix a problem with ext3 mount option parsing. When remount of a filesystem fails, old options are now restored. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] uml: tlb flushing fixBenjamin LaHaise
This patch fixes a fairly serious tlb flushing bug that makes aio use under uml very unreliable -- SEGVs, Oops and panic()s occur as a result of stale tlb entires being used by uml when aio switches mms due to the fact that uml does not implement the activate_mm() hook. This patch introduces a simple but correct approach (read: hammer) for implementing activate_mm() in uml by doing a force_flush_all() if the new mm is different from old. With this patch in place, uml is able to succeed at the aio test case that was randomly faulting for me before. Cc: Jeff Dike <jdike@addtoit.com> Cc: <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] alpha: pgprot_uncached() commentAndrew Morton
Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] pcmcia: fix pcmcia-cs compilationDominik Brodowski
Fix pcmcia-cs compilation with recent pcmcia kernel changes. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] name_to_dev_t warning fixAndrew Morton
kernel/power/disk.c needs a declaration of name_to_dev_t() in scope. mount.h seems like an appropriate choice. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[IA64] remove CONFIG_IA64_SGI_SN_SIMGreg Edwards
This patch removes the CONFIG_IA64_SGI_SN_SIM option entirely, allowing any kernel bootable on sn2 to also be booted in the simulator. Boot tested on Altix and HP rx2600. Signed-off-by: Greg Edwards <edwardsg@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[PATCH] USB: another cdc descriptordavid-b@pacbell.net
This adds another CDC descriptor type to <linux/usb_cdc.h>; the main claim to fame for this is that some Motorola phones include it. It's not currently needed by any driver code; included for completeness. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[PATCH] USB: Fix kmalloc's flags type in USBOlav Kongas
Greg, This patch fixes the kmalloc() flags argument type in USB subsystem; hopefully all of its occurences. The patch was made against patch-2.6.12-git2 from Jun 20. Cleanup of flags for kmalloc() in USB subsystem. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[IA64] pcibus_to_node implementation for IA64Christoph Lameter
pcibus_to_node provides a way for the Linux kernel to identify to which node a certain pcibus connects to. Allocations of control structures for devices can then be made on the node where the pci bus is located to allow local access during interrupt and other device manipulation. This patch provides a new "node" field in the the pci_controller structure. The node field will be set based on ACPI information (thanks to Alex Williamson <alex.williamson@hp.com for that piece). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-07-12[ACPI] increase MAX_IO_APICS to 64 on i386Len Brown
x86_64 was already 128 http://bugzilla.kernel.org/show_bug.cgi?id=3754 Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] enable C2 and C3 idle power states on SMPVenkatesh Pallipadi
http://bugzilla.kernel.org/show_bug.cgi?id=4401 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] Evaluate CPEI Processor Override flagAshok Raj
ACPI 3.0 added a Correctable Platform Error Interrupt (CPEI) Processor Overide flag to MADT.Platform_Interrupt_Source. Record the processor that was provided as hint from ACPI. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
2005-07-11[ACPI] Bind PCI devices with ACPI devicesDavid Shaohua Li
Implement the framework for binding physical devices with ACPI devices. A physical bus like PCI bus should create a 'acpi_bus_type', with: .find_device: For device which has parent such as normal PCI devices. .find_bridge: It's for special devices, such as PCI root bridge or IDE controller. Such devices generally haven't a parent or ->bus. We use the special method to get an ACPI handle. Uses new field in struct device: firmware_data http://bugzilla.kernel.org/show_bug.cgi?id=4277 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] generic Hot Key supportLuming Yu
See Documentation/acpi-hotkey.txt Use cmdline "acpi_specific_hotkey" to enable legacy platform specific drivers. http://bugzilla.kernel.org/show_bug.cgi?id=3887 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] ACPI poweroff fixAlexey Starikovskiy
Register an "acpi" system device to be notified of shutdown preparation. This depends on CONFIG_PM http://bugzilla.kernel.org/show_bug.cgi?id=4041 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2005-07-11[NETLINK]: Reserve NETLINK_NETFILTER.David S. Miller
2005-07-11Merge master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
2005-07-11[SPARC64]: Add missing asm-sparc64/seccomp.h file.David S. Miller
