Add the hypercall sub-ops and the structures for the shared data used
in the FIFO-based event channel ABI.
The design document for this new ABI is available here:
http://xenbits.xen.org/people/dvrabel/event-channels-H.pdf
In summary, events are reported using a per-domain shared event array
of event words. Each event word has PENDING, LINKED and MASKED bits
and a LINK field for pointing to the next event in the event queue.
There are 16 event queues (with different priorities) per-VCPU.
Key advantages of this new ABI include:
- Support for over 100,000 events (2^17).
- 16 different event priorities.
- Improved fairness in event latency through the use of FIFOs.
The ABI is available in Xen 4.4 and later.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Impact: cleanup
hypervisor.h had accumulated a lot of crud, including lots of spurious
#includes. Clean it all up, and go around fixing up everything else
accordingly.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Add Xen interface header files. These are taken fairly directly from
the Xen tree, but somewhat rearranged to suit the kernel's conventions.
Define macros and inline functions for doing hypercalls into the
hypervisor.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Ian Pratt <ian.pratt@xensource.com>
Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
