path: root/include/video
2011-03-22atmel_lcdfb: implement inverted contrast pwmAndreas Bießmann
This patch introduces lcdc->lcdcon_pol_negative which set CONTRAST_CTR register to inverted polarity. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-16fbdev: sh_mobile_lcdc: Add YUV framebuffer supportDamian Hobson-Garcia
Supports YCbCr420sp, YCbCr422sp, and YCbCr44sp, formats (bpp = 12, 16, and 24) respectively. When double-buffering both Y planes appear before the C planes (Y-Y-C-C), as opposed to Y-C-Y-C. Set .nonstd in struct sh_mobile_lcdc_chan_cfg to enable YUV mode, and use .bpp to distiguish between the 3 modes. The value of .nonstd is copied to bits 16-31 of LDDFR in the LCDC and should be set accordingly. .nonstd must be set to 0 for RGB mode. Due to the encoding of YUV data, the framebuffer will clear to green instead of black. In YUV 420 mode, panning is only possible in 2 line increments. Additionally in YUV 420 mode the vertical resolution of the framebuffer must be an even number. Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-10fbdev: sh_mobile_lcdcfb: add backlight supportAlexandre Courbot
Support for backlight devices controlled through board-specific routines. Backlights can be defined per-channel and follow fbdev directives to switch off as the LCD blanks or is turned on/off. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06Merge branch 'fbdev/udlfb'Paul Mundt
2011-01-06video: udlfb: Kill off special printk wrappers, use pr_fmt().Paul Mundt
This kills off all of the dl_xxx() printk wrappers and simply stubs in a pr_fmt() definition to accomplish the same thing. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06video: udlfb: Kill off some magic constants for EDID sizing.Paul Mundt
The edid length is fixed, so use the standard definition consistently. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-05Merge branch 'common/fbdev-mipi' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6
2011-01-05fbdev: sh_mipi_dsi: support different register layoutsGuennadi Liakhovetski
The register layout of the MIPI DSI unit on sh-mobile SoCs differ. Add platform parameters to support such variations. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-12-21s1d13xxxfb: drop unused codeAndres Salomon
Silence warnings such as - drivers/video/s1d13xxxfb.c:421: warning: ‘bltbit_wait_bitset’ defined but not used Just drop the unused code. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-16fbdev: move udlfb out of staging.Paul Mundt
udlfb has undergone a fair bit of cleanup recently and is effectively at the point where it can be liberated from staging purgatory and promoted to a real driver. The outstanding cleanups are all minor, with some of them dependent on drivers/video headers, so these will be done incrementally from udlfb's new home. Requested-by: Bernie Thompson <bernie@plugable.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-16fbdev: da8xx: punt duplicated FBIO_WAITFORVSYNC defineMike Frysinger
This is already defined by linux/fb.h now, so punt the duplicate definition from the driver header. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10fbdev: sh_mobile_hdmi: add support for more precise HDMI clock configurationGuennadi Liakhovetski
The HDMI clock has to be reconfigured for different video modes. However, the precision of the supplying SoC clock on SH-Mobile systems is often insufficient. This patch allows to additionally reconfigure the parent clock to achieve the optimal HDMI clock frequency, in case this is supported by the platform. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6 into ↵Russell King
devel-stable Conflicts: drivers/video/sh_mobile_hdmi.c
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-09-14fbdev: sh_mobile_hdmi: implement lockingGuennadi Liakhovetski
The SH-Mobile HDMI driver runs in several contexts: ISR, delayed work-queue, task context, when called from the sh_mobile_lcdc framebuffer driver. This creates ample race possibilities. Even though most these races are purely theoretical, it is better to close them. To trace fb_info validity we install a notification callback in the HDMI driver, and the only way for it to get to driver internal data is by using struct sh_mobile_lcdc_chan, therefore it had to be extracted into a separate common header. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: Support multiple video modes in platform dataGuennadi Liakhovetski
This is a preparation for HDMI hotplug support. This patch just moves all platform defined video modes for the sh_mobile_lcdcfb driver to separate arrays and switches all users to use element 0 of that array, so, this patch doesn't introduce any functional changes and as such should not cause any regressions. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-10fbdev: sh_mobile_hdmi: modify flags name to more specificKuninori Morimoto
This patch solve below report from Guennadi 1) > +/* Audio source select */ > +#define HDMI_SRC_MASK (0xF << 0) > +#define HDMI_SRC_I2S (0 << 0) /* default */ > +#define HDMI_SRC_SPDIF (1 << 0) > +#define HDMI_SRC_DSD (2 << 0) > +#define HDMI_SRC_HBR (3 << 0) I would be more specific with these macro names, i.e., include "AUDIO" or "SND" or something similar in them, e.g., HDMI_AUDIO_SRC_I2S. 2) > + case HDMI_SRC_I2S: > + data = (0x0 << 3); > + break; > + case HDMI_SRC_SPDIF: > + data = (0x1 << 3); > + break; > + case HDMI_SRC_DSD: > + data = (0x2 << 3); > + break; > + case HDMI_SRC_HBR: > + data = (0x3 << 3); In all above cases parenthesis are superfluous. Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-01fbdev: sh-mobile: Add HDMI sound type selectionKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-16include/video/vga.h: update web address.Justin P. Mattock
The below updates a broken web address to one(hopefully) thats the new correct address. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-14include: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y has same semantic. So there is no need to have both. Drop the unifdef-y variant and sort all lines again Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-04fbdev: sh-mobile: HDMI support for SH-Mobile SoCsGuennadi Liakhovetski
Some SH-Mobile SoCs have an HDMI controller and a PHY, attached to one of their LCDC interfaces. This patch adds a preliminary static support for such controllers, this means, that only the 720p mode is handled ATM. Support for more modes and a dynamic switching between them will be added by a follow up patch. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-08-04sh: add a parameter to LCDC driver's .display_on() callbackGuennadi Liakhovetski
HDMI support for the sh_mobile_lcdc framebuffer driver will require a 'struct fb_info *' pointer for its .display_on() callback. While at it fix kfr2r09 framebuffer modular build. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-31Merge branch 'master' of ↵Paul Mundt
2010-05-25fbdev: move FBIO_WAITFORVSYNC to linux/fb.hGrazvydas Ignotas
FBIO_WAITFORVSYNC is currently implemented by matroxfb, atyfb, intelfb and more. All of them keep redefining the same FBIO_WAITFORVSYNC macro over and over again, so move it to linux/fb.h and clean up those duplicate defines. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Maik Broemme <mbroemme@plusserver.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Hiremath, Vaibhav" <hvaibhav@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25fbdev: da8xx/omap-l1xx: implement double bufferingMartin Ambrose
This work includes the following: - Implement handler for FBIO_WAITFORVSYNC ioctl. - Allocate the data and palette buffers separately. A consequence of this is that the palette and data loading is now done in different phases. And that the LCD must be disabled temporarily after the palette is loaded but this will only happen once after init and each time the palette is changed. I think this is OK. - Allocate two (ping and pong) framebuffers from memory. - Add pan_display handler which toggles the LCDC DMA registers between the ping and pong buffers. Signed-off-by: Martin Ambrose <martin@ti.com> Cc: Chaithrika U S <chaithrika@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24sh-mobile: add support for displays, connected over the MIPI busGuennadi Liakhovetski
Some SH-mobile SoCs have a MIPI DSI controller, that can be used to connect MIPI displays to LCDC. This patch adds a platform driver for SH-mobile MIPI DSI unit. It uses existing hooks in the sh_mobile_lcdcfb.c driver for display activation and deactivation. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Tested-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-24sh: add a YUV422 output data format, that is also supported by LCDCGuennadi Liakhovetski
The LCDC block is allowed to use one of the two output data formats, when used with MIPI DSI: RGB24 and YUV422. YUV422 is not currently handled by the LCDC driver, but we have to add a define for it for MIPI. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-24fbdev: add a MIPI DSI headerGuennadi Liakhovetski
This header adds defines for MIPI DSI and DCS commands and data formats. See http://www.mipi.org/ for details. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-12broadsheetfb: support storing waveformJaya Kumar
This patch adds waveform storing capability to broadsheetfb. It uses the firmware class to retrieve the waveform, and the request to initiate the waveform storing is done via a driver sysfs entry, loadstore_waveform. Broadsheet is a framebuffer device. It is slightly different from a typical framebuffer controller that drives a normal TFT-LCD display. Most E-Ink display panels require a waveform in order to function. That is, in order to drive the state of a pixel to black, gray, or white, a specific waveform is utilized. Basically, that waveform represents the specific E-field wiggling needed to get the pixel to its optimal state given current temperature, and its previous state. TN/IPS-LCDs use a similar concept but the driving waveform is sufficiently simple that it is internalized in the TFT source/gate driver. These E-Ink waveforms are specific to a production batch. That is, a batch of display films are produced, then they get characterized and a waveform is generated for that batch. Broadsheet, typically, is attached to its private SPI flash which is then flashed with this waveform. Users won't be able to see the waveform and typically won't ever need to know about it. If however, the display panel attached to broadsheet is changed out, then they will need to update their waveform. That would typically be done at a factory or repair facility rather than by a user. [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12broadsheetfb: add MMIO hooksJaya Kumar
Allow boards with GP-MMIO controllers to provide hooks to broadsheetfb in order to offload cmd/data writes and data reads instead of relying only on host based GPIO wiggling. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12broadsheetfb: add multiple panel type supportJaya Kumar
Update broadsheetfb to add support for multiple panel types. The 3.7" and 6" are known to work but the 9.7" is untested due to lack of hardware. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-16video: sh_mobile_lcdcfb: Add wait for vsync.Phil Edworthy
Added FBIO_WAITFORVSYNC ioctl for SH-Mobile devices. Tested on MS7724 and MigoR boards against 2.6.33-rc7. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (33 commits) sh: Fix test of unsigned in se7722_irq_demux() sh: mach-ecovec24: Add FSI sound support sh: mach-ecovec24: Add mt9t112 camera support sh: mach-ecovec24: Add tw9910 support sh: MSIOF/mmc_spi platform data for the Ecovec24 board sh: ms7724se: Add ak4642 support sh: Fix up FPU build for SH5 sh: Remove old early serial console code V2 sh: sh5 scif pdata (sh5-101/sh5-103) sh: sh4a scif pdata (sh7757/sh7763/sh7770/sh7780/sh7785/sh7786/x3) sh: sh4a scif pdata (sh7343/sh7366/sh7722/sh7723/sh7724) sh: sh4 scif pdata (sh7750/sh7760/sh4-202) sh: sh3 scif pdata (sh7705/sh770x/sh7710/sh7720) sh: sh2a scif pdata (sh7201/sh7203/sh7206/mxg) sh: sh2 scif pdata (sh7616) sh-sci: Extend sh-sci driver with early console V2 sh: Stub in P3 ioremap support for nommu parts. sh: wire up vmallocinfo support in ioremap() implementations. sh: Make the unaligned trap handler always obey notification levels. sh: Couple kernel and user write page perm bits for CONFIG_X2TLB ...
2009-12-16davinci: fb: update the driver in preparation for addition of power ↵Chaithrika U S
management features Add a helper function to enable raster. Also add one member in the private data structure to track the current blank status, another function pointer which takes in the platform specific callback function to control panel power. These updates will help in adding suspend/resume and frame buffer blank operation features. Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into ↵Paul Mundt
sh/for-2.6.33
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09sh: add a start_transfer() callback to the LCDC driverMagnus Damm
This patch adds a ->start_transfer() callback to the driver sh_mobile_lcdcfb.c. The callback is used to program the LCDC panel in the case of one-shot mode. Needed by the LCD controller used on the KFR2R09 board. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-04sgivwfb: Make use of ARRAY_SIZE.Thiago Farina
Cleanup the usage of DBE_VT_SIZE since the kernel already defines the same macro for the same propose. Also clean up a surrounding whitespaces. Signed-off-by: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-01pxa168fb: remove useless vsync/hsync invert flagJun Nie
fb_var_screeninfo.var has already encoded this information. Signed-off-by: Jun Nie <njun@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-23davinci-fb-frame-buffer-driver-for-ti-da8xx-omap-l1xx-v4Sudhakar Rajashekhara
Since the previous version, return values in ioctl() function have been modified. [akpm@linux-foundation.org: simplify lcd_disable_raster()] Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Signed-off-by: Steve Chen <schen@mvista.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23davinci: fb: Frame Buffer driver for TI DA8xx/OMAP-L1xxSudhakar Rajashekhara
Add LCD controller (LCDC) driver for TI's DA8xx/OMAP-L1xx architecture. LCDC specifications can be found at http://www.ti.com/litv/pdf/sprufm0a. LCDC on DA8xx consists of two independent controllers, the Raster Controller and the LCD Interface Display Driver (LIDD) controller. LIDD further supports character and graphic displays. This patch adds support for the graphic display (Sharp LQ035Q3DG01) found on the DA830 based EVM. The EVM details can be found at: http://support.spectrumdigital.com/boards/dskda830/revc/. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Signed-off-by: Steve Chen <schen@mvista.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> DESC davinci-fb-frame-buffer-driver-for-ti-da8xx-omap-l1xx-fix EDESC From: Andrew Morton <akpm@linux-foundation.org> fix kconfig indenting Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Pavel Kiryukhin <pkiryukhin@ru.mvista.com> Cc: Steve Chen <schen@mvista.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: s1d13xxxfb: add accelerated bitblt functionsKristoffer Ericson
Add accelerated bitblt functions to s1d13xxx based video chipsets, more specificly functions copyarea and fillrect. It has only been tested and activated for 13506 chipsets but is expected to work for the majority of s1d13xxx based chips. This patch also cleans up the driver with respect of whitespaces and other formatting issues. We update the current status comments. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-13fb: add support of LCD display controller on pxa168/910 (base layer)Lennert Buytenhek
This driver is originally written by Lennert, modified by Green to be feature complete, and ported by Jun Nie and Kevin Liu for pxa168/910 processors. The patch adds support for the on-chip LCD display controller, it currently supports the base (graphics) layer only. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Green Wan <gwan@marvell.com> Cc: Peter Liao <pliao@marvell.com> Signed-off-by: Jun Nie <njun@marvell.com> Signed-off-by: Kevin Liu <kliu5@marvell.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-04-13include/video/cyblafb.h: remove it, it's unusedJoe Perches
commit ddb53d48da5b0e691f35e703ac29118747f86c99 ("fbdev: remove cyblafb driver") removed drivers/video/cyblafb.c, but not its .h file Signed-off-by: Joe Perches <joe@perches.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Jani Monoses" <jani@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: move I2C functionality into the tdfxfbKrzysztof Helt
The I2C functionality provided by the i2c-voodoo3 driver is moved into the tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no conflict between the i2c driver and the fb driver. The tdfxfb does not make use from the DDC functionality yet but provides all the functionality of the i2c-voodoo3 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fbdev: update s1d13xxxfb to differ between revisions and production idsKristoffer Ericson
The s1d13xxx chip provides two values of identification value: the Production id (e.g 13506/13505/13806..) and a revision number 0,1,2,3). Together these can help us to differentiate between similiar setups. This patch adds the proper way of grabbing both those values and save them for future reference (in order to decide what functions a card supports, e.g acceleration). We also move away from the concept of all s1d13xxx = s1d13806 when we really support alot more. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: simplify s1d13xxxfb_probe()] Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fbdev: newport: newport_*wait() return 0 on timeoutRoel Kluin
With a postfix decrement t reaches -1 on timeout which results in a return of 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: Laguna chipset 8bpp fixKrzysztof Helt
Fix 8bpp mode by adding handling of the Laguna chipsets to various places and stop trashing a HDR register which probably does not exist on the Laguna. Fix compilation warnings about uninitialized variables also. Finally, all 8bpp, 16bpp and 32bpp modes work on the Laguna chipset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
