commit a7cfebcb7594a24609268f91299ab85ba064bf82 upstream.
There's currently no limit on wiphy names, other than netlink
message size and memory limitations, but that causes issues when,
for example, the wiphy name is used in a uevent, e.g. in rfkill
where we use the same name for the rfkill instance, and then the
buffer there is "only" 2k for the environment variables.
This was reported by syzkaller, which used a 4k name.
Limit the name to something reasonable, I randomly picked 128.
Reported-by: syzbot+230d9e642a85d3fec29c@syzkaller.appspotmail.com
[ Upstream commit 35b3fde6203b932b2b1a5b53b3d8808abc9c4f60 ]
The new firmware interfaces for branch prediction behaviour changes
are transparently available for the guest. Nevertheless, there is
new state attached that should be migrated and properly resetted.
Provide a mechanism for handling reset, migration and VSIE.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
[Changed capability number to 152. - Radim]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 76dc52684d0f72971d9f6cc7d5ae198061b715bd upstream.
A 64-bit value is not needed since a PCI ROM address consists in 32 bits.
This fixes a clang warning about "implicit conversion from 'unsigned long'
to 'u32'".
Also remove now unnecessary casts to u32 from __pci_read_base() and
pci_std_update_resource().
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Nathan Chancellor <natechancellor@gmail.com>
commit a6618f4aedb2b60932d766bd82ae7ce866e842aa upstream.
Currently, the offsets in the UAC2 processing unit descriptor are
calculated incorrectly. It causes an issue when connecting the device which
provides such a feature:
[84126.724420] usb 1-1.3.1: invalid Processing Unit descriptor (id 18)
After this patch is applied, the UAC2 processing unit inits w/o this error.
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
Signed-off-by: Kirill Marinushkin <k.marinushkin@gmail.com>
Cc: <stable@vger.kernel.org>
commit 7e040726850a106587485c21bdacc0bfc8a0cbed upstream.
[resend due to me forgetting to cc: linux-api the first time around I
posted these back on Feb 23]
From: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
For some reason these values are not in the uapi header file, so any
libc has to define it themselves. To prevent them from needing to do
this, just have the kernel provide the correct values.
Reported-by: Elliott Hughes <enh@google.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
commit 81cf4a45360f70528f1f64ba018d61cb5767249a upstream.
As most of BOS descriptors are longer in length than their header
'struct usb_dev_cap_header', comparing solely with it is not sufficient
to avoid out-of-bounds access to BOS descriptors.
This patch adds descriptor type specific length check in
usb_get_bos_descriptor() to fix the issue.
Signed-off-by: Masakazu Mokuno <masakazu.mokuno@gmail.com>
commit 446fa3a95df1e8b78f25e1babc41e46edd200821 upstream.
The SuperspeedPlus Device Capability Descriptor has a variable size
depending on the number of sublink speed attributes.
This patch adds a macro to calculate that size. The macro takes one
argument, the Sublink Speed Attribute Count (SSAC) as reported by the
descriptor in bmAttributes[4:0].
See USB 3.1 9.6.2.5, Table 9-19.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit faee822c5a7ab99de25cd34fcde3f8d37b6b9923 upstream.
USB 3.1 devices that support precision time measurement have an
additional PTM cabaility descriptor as part of the full BOS descriptor
Look for this descriptor while parsing the BOS descriptor, and store it in
struct usb_hub_bos if it exists.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit cf33c1ee5254c6a430bc1538232b49c3ea13e613 upstream.
This patch try to fix the building error on MIPS. The reason is MIPS
has already defined the PTR macro, which conflicts with the PTR macro
in include/uapi/linux/bcache.h.
[fixed by mlyle: corrected a line-length issue]
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Michael Lyle <mlyle@lyle.org>
Signed-off-by: Michael Lyle <mlyle@lyle.org>
[ Upstream commit feb0869d90e51ce8b6fd8a46588465b1b5a26d09 ]
Consistently use types from linux/types.h to fix the following
linux/rds.h userspace compilation errors:
/usr/include/linux/rds.h:106:2: error: unknown type name 'uint8_t'
uint8_t name[32];
/usr/include/linux/rds.h:107:2: error: unknown type name 'uint64_t'
uint64_t value;
/usr/include/linux/rds.h:117:2: error: unknown type name 'uint64_t'
uint64_t next_tx_seq;
/usr/include/linux/rds.h:118:2: error: unknown type name 'uint64_t'
uint64_t next_rx_seq;
/usr/include/linux/rds.h:121:2: error: unknown type name 'uint8_t'
uint8_t transport[TRANSNAMSIZ]; /* null term ascii */
/usr/include/linux/rds.h:122:2: error: unknown type name 'uint8_t'
uint8_t flags;
/usr/include/linux/rds.h:129:2: error: unknown type name 'uint64_t'
uint64_t seq;
/usr/include/linux/rds.h:130:2: error: unknown type name 'uint32_t'
uint32_t len;
/usr/include/linux/rds.h:135:2: error: unknown type name 'uint8_t'
uint8_t flags;
/usr/include/linux/rds.h:139:2: error: unknown type name 'uint32_t'
uint32_t sndbuf;
/usr/include/linux/rds.h:144:2: error: unknown type name 'uint32_t'
uint32_t rcvbuf;
/usr/include/linux/rds.h:145:2: error: unknown type name 'uint64_t'
uint64_t inum;
/usr/include/linux/rds.h:153:2: error: unknown type name 'uint64_t'
uint64_t hdr_rem;
/usr/include/linux/rds.h:154:2: error: unknown type name 'uint64_t'
uint64_t data_rem;
/usr/include/linux/rds.h:155:2: error: unknown type name 'uint32_t'
uint32_t last_sent_nxt;
/usr/include/linux/rds.h:156:2: error: unknown type name 'uint32_t'
uint32_t last_expected_una;
/usr/include/linux/rds.h:157:2: error: unknown type name 'uint32_t'
uint32_t last_seen_una;
/usr/include/linux/rds.h:164:2: error: unknown type name 'uint8_t'
uint8_t src_gid[RDS_IB_GID_LEN];
/usr/include/linux/rds.h:165:2: error: unknown type name 'uint8_t'
uint8_t dst_gid[RDS_IB_GID_LEN];
/usr/include/linux/rds.h:167:2: error: unknown type name 'uint32_t'
uint32_t max_send_wr;
/usr/include/linux/rds.h:168:2: error: unknown type name 'uint32_t'
uint32_t max_recv_wr;
/usr/include/linux/rds.h:169:2: error: unknown type name 'uint32_t'
uint32_t max_send_sge;
/usr/include/linux/rds.h:170:2: error: unknown type name 'uint32_t'
uint32_t rdma_mr_max;
/usr/include/linux/rds.h:171:2: error: unknown type name 'uint32_t'
uint32_t rdma_mr_size;
/usr/include/linux/rds.h:212:9: error: unknown type name 'uint64_t'
typedef uint64_t rds_rdma_cookie_t;
/usr/include/linux/rds.h:215:2: error: unknown type name 'uint64_t'
uint64_t addr;
/usr/include/linux/rds.h:216:2: error: unknown type name 'uint64_t'
uint64_t bytes;
/usr/include/linux/rds.h:221:2: error: unknown type name 'uint64_t'
uint64_t cookie_addr;
/usr/include/linux/rds.h:222:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:228:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:229:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:234:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:240:2: error: unknown type name 'uint64_t'
uint64_t local_vec_addr;
/usr/include/linux/rds.h:241:2: error: unknown type name 'uint64_t'
uint64_t nr_local;
/usr/include/linux/rds.h:242:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:243:2: error: unknown type name 'uint64_t'
uint64_t user_token;
/usr/include/linux/rds.h:248:2: error: unknown type name 'uint64_t'
uint64_t local_addr;
/usr/include/linux/rds.h:249:2: error: unknown type name 'uint64_t'
uint64_t remote_addr;
/usr/include/linux/rds.h:252:4: error: unknown type name 'uint64_t'
uint64_t compare;
/usr/include/linux/rds.h:253:4: error: unknown type name 'uint64_t'
uint64_t swap;
/usr/include/linux/rds.h:256:4: error: unknown type name 'uint64_t'
uint64_t add;
/usr/include/linux/rds.h:259:4: error: unknown type name 'uint64_t'
uint64_t compare;
/usr/include/linux/rds.h:260:4: error: unknown type name 'uint64_t'
uint64_t swap;
/usr/include/linux/rds.h:261:4: error: unknown type name 'uint64_t'
uint64_t compare_mask;
/usr/include/linux/rds.h:262:4: error: unknown type name 'uint64_t'
uint64_t swap_mask;
/usr/include/linux/rds.h:265:4: error: unknown type name 'uint64_t'
uint64_t add;
/usr/include/linux/rds.h:266:4: error: unknown type name 'uint64_t'
uint64_t nocarry_mask;
/usr/include/linux/rds.h:269:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:270:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:274:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:275:2: error: unknown type name 'int32_t'
int32_t status;
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
[ Upstream commit 1786dbf3702e33ce3afd2d3dbe630bd04b1d2e58 ]
On the kernel side, sockaddr_storage is #define'd to
__kernel_sockaddr_storage. Replacing struct sockaddr_storage with
struct __kernel_sockaddr_storage defined by <linux/socket.h> fixes
the following linux/rds.h userspace compilation error:
/usr/include/linux/rds.h:226:26: error: field 'dest_addr' has incomplete type
struct sockaddr_storage dest_addr;
This reverts commit ad50561ba7a664bc581826c9d57d137fcf17bfa5.
There was a mixup with the commit message for two upstream commit
that have the same subject line.
This revert will be followed by the two commits with proper commit
messages.
commit a2b4a79b88b24c49d98d45a06a014ffd22ada1a4 upstream.
The SPI_IOC_MESSAGE() macro references _IOC_SIZEBITS. Add linux/ioctl.h
to make sure this macro is defined. This fixes the following build
failure of lcdproc with the musl libc:
In file included from .../sysroot/usr/include/sys/ioctl.h:7:0,
from hd44780-spi.c:31:
hd44780-spi.c: In function 'spi_transfer':
hd44780-spi.c:89:24: error: '_IOC_SIZEBITS' undeclared (first use in this function)
status = ioctl(p->fd, SPI_IOC_MESSAGE(1), &xfer);
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 72aa107df6a275cf03359934ca5799a2be7a1bf7 ]
Include <linux/in6.h> to fix the following linux/mroute6.h userspace
compilation errors:
/usr/include/linux/mroute6.h:80:22: error: field 'mf6cc_origin' has incomplete type
struct sockaddr_in6 mf6cc_origin; /* Origin of mcast */
/usr/include/linux/mroute6.h:81:22: error: field 'mf6cc_mcastgrp' has incomplete type
struct sockaddr_in6 mf6cc_mcastgrp; /* Group in question */
/usr/include/linux/mroute6.h:91:22: error: field 'src' has incomplete type
struct sockaddr_in6 src;
/usr/include/linux/mroute6.h:92:22: error: field 'grp' has incomplete type
struct sockaddr_in6 grp;
/usr/include/linux/mroute6.h:132:18: error: field 'im6_src' has incomplete type
struct in6_addr im6_src, im6_dst;
/usr/include/linux/mroute6.h:132:27: error: field 'im6_dst' has incomplete type
uint8_t name[32];
uint64_t value;
uint8_t flags;
uint64_t seq;
uint32_t len;
uint8_t flags;
uint32_t sndbuf;
uint32_t rcvbuf;
uint64_t inum;
uint64_t hdr_rem;
uint64_t data_rem;
uint64_t addr;
uint64_t bytes;
uint64_t flags;
uint64_t flags;
uint64_t flags;
uint64_t nr_local;
uint64_t flags;
uint64_t compare;
uint64_t swap;
uint64_t add;
uint64_t compare;
uint64_t swap;
uint64_t swap_mask;
uint64_t add;
uint64_t flags;
int32_t status;
commit bd7a3fe770ebd8391d1c7d072ff88e9e76d063eb upstream.
Andrey Konovalov reported a possible out-of-bounds problem for a USB interface
association descriptor. He writes:
It seems there's no proper size check of a USB_DT_INTERFACE_ASSOCIATION
descriptor. It's only checked that the size is >= 2 in
usb_parse_configuration(), so find_iad() might do out-of-bounds access
to intf_assoc->bInterfaceCount.
And he's right, we don't check for crazy descriptors of this type very well, so
resolve this problem. Yet another issue found by syzkaller...
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
commit 93491ced3c87c94b12220dbac0527e1356702179 upstream.
Add define for the maximum number of ports on a SuperSpeed hub as per
USB 3.1 spec Table 10-5, and use it when verifying the retrieved hub
descriptor.
This specifically avoids benign attempts to update the DeviceRemovable
mask for non-existing ports (should we get that far).
Fixes: dbe79bbe9dcb ("USB 3.0 Hub Changes")
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 557c44be917c322860665be3d28376afa84aa936 ]
Andrey reported a fault in the IPv6 route code:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 4035 Comm: a.out Not tainted 4.11.0-rc7+ #250
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff880069809600 task.stack: ffff880062dc8000
RIP: 0010:ip6_rt_cache_alloc+0xa6/0x560 net/ipv6/route.c:975
RSP: 0018:ffff880062dced30 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff8800670561c0 RCX: 0000000000000006
RDX: 0000000000000003 RSI: ffff880062dcfb28 RDI: 0000000000000018
RBP: ffff880062dced68 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880062dcfb28 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007feebe37e7c0(0000) GS:ffff88006cb00000(0000) knlGS:0000000000000000
CR2: 00000000205a0fe4 CR3: 000000006b5c9000 CR4: 00000000000006e0
Call Trace:
ip6_pol_route+0x1512/0x1f20 net/ipv6/route.c:1128
ip6_pol_route_output+0x4c/0x60 net/ipv6/route.c:1212
Andrey's syzkaller program passes rtmsg.rtmsg_flags with the RTF_PCPU bit
set. Flags passed to the kernel are blindly copied to the allocated
rt6_info by ip6_route_info_create making a newly inserted route appear
as though it is a per-cpu route. ip6_rt_cache_alloc sees the flag set
and expects rt->dst.from to be set - which it is not since it is not
really a per-cpu copy. The subsequent call to __ip6_dst_alloc then
generates the fault.
Fix by checking for the flag and failing with EINVAL.
Fixes: d52d3997f843f ("ipv6: Create percpu rt6_info")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 745cb7f8a5de0805cade3de3991b7a95317c7c73 ]
Replace MAX_ADDR_LEN with its numeric value to fix the following
linux/packet_diag.h userspace compilation error:
/usr/include/linux/packet_diag.h:67:17: error: 'MAX_ADDR_LEN' undeclared here (not in a function)
__u8 pdmc_addr[MAX_ADDR_LEN];
This is not the first case in the UAPI where the numeric value
of MAX_ADDR_LEN is used instead of symbolic one, uapi/linux/if_link.h
already does the same:
$ grep MAX_ADDR_LEN include/uapi/linux/if_link.h
__u8 mac[32]; /* MAX_ADDR_LEN */
There are no UAPI headers besides these two that use MAX_ADDR_LEN.
Acked-by: Pavel Emelyanov <xemul@virtuozzo.com>
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
commit 332b05ca7a438f857c61a3c21a88489a21532364 upstream.
This patch adds a check to limit the number of can_filters that can be
set via setsockopt on CAN_RAW sockets. Otherwise allocations > MAX_ORDER
are not prevented resulting in a warning.
Reference: https://lkml.org/lkml/2016/12/2/230
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 85dda4e5b0ee1f5b4e8cc93d39e475006bc61ccd ]
The offload flag is a status flag and should not be used by
FIB semantics for comparison.
Fixes: 37ed9493699c ("rtnetlink: add RTNH_F_EXTERNAL flag for fib offload")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Andy Gospodarek <andy@greyhouse.net>
[ Upstream commit 5d8d8db851ef81337e7026b32a9d5a9cfb2271d5 ]
Add support for Intel R200 depth camera in uvc driver.
This includes adding new uvc GUIDs for the new pixel formats,
adding new V4L pixel format definition to user api headers,
and updating the uvc driver GUID-to-4cc tables with the new formats.
Tested-by: Greenberg, Aviv D <aviv.d.greenberg@intel.com>
Signed-off-by: Aviv Greenberg <aviv.d.greenberg@intel.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
[ Upstream commit b4ed5d1682c6613988c2eb1de55df5ac9988afcc ]
Currently some "Unspecified error 0x80004005" is reported on the Windows
side if something fails. Handle the ENOSPC case and return
ERROR_DISK_FULL, which allows at least Copy-VMFile to report a meaning
full error.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 8a1b2725a60d3267135c15e80984b4406054f650 upstream.
Add a new USB_SPEED_SUPER_PLUS device speed, and make sure usb core can
handle the new speed.
In most cases the behaviour is the same as with USB_SPEED_SUPER SuperSpeed
devices. In a few places we add a "Plus" string to inform the user of the
new speed.
[ Upstream commit f0a3fdca794d1e68ae284ef4caefe681f7c18e89 ]
These structures are defined only if __USE_MISC is set in glibc net/if.h
headers, ie when _BSD_SOURCE or _SVID_SOURCE are defined.
CC: Jan Engelhardt <jengelh@inai.de>
CC: Josh Boyer <jwboyer@fedoraproject.org>
CC: Stephen Hemminger <shemming@brocade.com>
CC: Waldemar Brodkorb <mail@waldemar-brodkorb.de>
CC: Gabriel Laskar <gabriel@lse.epita.fr>
CC: Mikko Rapeli <mikko.rapeli@iki.fi>
Fixes: 4a91cb61bb99 ("uapi glibc compat: fix compile errors when glibc net/if.h included before linux/if.h")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
linux/if.h MIME-Version: 1.0
[ Upstream commit 4a91cb61bb995e5571098188092e296192309c77 ]
glibc's net/if.h contains copies of definitions from linux/if.h and these
conflict and cause build failures if both files are included by application
source code. Changes in uapi headers, which fixed header file dependencies to
include linux/if.h when it was needed, e.g. commit 1ffad83d, made the
net/if.h and linux/if.h incompatibilities visible as build failures for
userspace applications like iproute2 and xtables-addons.
This patch fixes compile errors when glibc net/if.h is included before
linux/if.h:
./linux/if.h:99:21: error: redeclaration of enumerator ‘IFF_NOARP’
./linux/if.h:98:23: error: redeclaration of enumerator ‘IFF_RUNNING’
./linux/if.h:97:26: error: redeclaration of enumerator ‘IFF_NOTRAILERS’
./linux/if.h:96:27: error: redeclaration of enumerator ‘IFF_POINTOPOINT’
./linux/if.h:95:24: error: redeclaration of enumerator ‘IFF_LOOPBACK’
./linux/if.h:94:21: error: redeclaration of enumerator ‘IFF_DEBUG’
./linux/if.h:93:25: error: redeclaration of enumerator ‘IFF_BROADCAST’
./linux/if.h:92:19: error: redeclaration of enumerator ‘IFF_UP’
./linux/if.h:252:8: error: redefinition of ‘struct ifconf’
./linux/if.h:203:8: error: redefinition of ‘struct ifreq’
./linux/if.h:169:8: error: redefinition of ‘struct ifmap’
./linux/if.h:107:23: error: redeclaration of enumerator ‘IFF_DYNAMIC’
./linux/if.h:106:25: error: redeclaration of enumerator ‘IFF_AUTOMEDIA’
./linux/if.h:105:23: error: redeclaration of enumerator ‘IFF_PORTSEL’
./linux/if.h:104:25: error: redeclaration of enumerator ‘IFF_MULTICAST’
./linux/if.h:103:21: error: redeclaration of enumerator ‘IFF_SLAVE’
./linux/if.h:102:22: error: redeclaration of enumerator ‘IFF_MASTER’
./linux/if.h:101:24: error: redeclaration of enumerator ‘IFF_ALLMULTI’
./linux/if.h:100:23: error: redeclaration of enumerator ‘IFF_PROMISC’
The cases where linux/if.h is included before net/if.h need a similar fix in
the glibc side, or the order of include files can be changed userspace
code as a workaround.
This change was tested in x86 userspace on Debian unstable with
scripts/headers_compile_test.sh:
$ make headers_install && \
cd usr/include && ../../scripts/headers_compile_test.sh -l -k
cc -Wall -c -nostdinc -I /usr/lib/gcc/i586-linux-gnu/5/include -I /usr/lib/gcc/i586-linux-gnu/5/include-fixed -I . -I /home/mcfrisk/src/linux-2.6/usr/headers_compile_test_include.2uX2zH -I /home/mcfrisk/src/linux-2.6/usr/headers_compile_test_include.2uX2zH/i586-linux-gnu -o /dev/null ./linux/if.h_libc_before_kernel.h
PASSED libc before kernel test: ./linux/if.h
Reported-by: Jan Engelhardt <jengelh@inai.de>
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Reported-by: Stephen Hemminger <shemming@brocade.com>
Reported-by: Waldemar Brodkorb <mail@waldemar-brodkorb.de>
Cc: Gabriel Laskar <gabriel@lse.epita.fr>
Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi>
commit 3020ca711871fdaf0c15c8bab677a6bc302e28fe upstream.
The VSync polarity was negative instead of positive for the 4k CEA formats.
I probably copy-and-pasted these from the DMT 4k format, which does have a
negative VSync polarity.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reported-by: Martin Bugge <marbugge@cisco.com>
commit a9cf8284b45110a4d98aea180a89c857e53bf850 upstream.
Commit 9d99a8dda154 ("nvme: move hardware structures out of the uapi
version of nvme.h") renamed nvme.h to nvme_ioctl.h, but the uapi list
still refers to nvme.h. People trying to install the headers hit a
failure as the header no longer exists.
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull networking fixes from David Miller:
1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of
people reported this... From Arnd Bergmann.
2) Don't init mutex twice in i40e driver, from Jesse Brandeburg.
3) Fix spurious EBUSY in rhashtable, from Herbert Xu.
4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas.
5) Fix race with work structure access in pppoe driver causing
corruptions, from Guillaume Nault.
6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb()
actually succeeded or not, from Sergei Shtylyov.
7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from
Bjørn Mork.
8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc.
9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo
Leitner.
10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven.
11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling
properly as well, from Jiri Benc.
12) Handle request sockets properly in xfrm layer, from Eric Dumazet.
13) Double stats update in ipv6 geneve transmit path, fix from Pravin B
Shelar.
14) sk->sk_policy[] needs RCU protection, and as a result
xfrm_policy_destroy() needs to free policies using an RCU grace
period, from Eric Dumazet.
15) SCTP needs to clone ipv6 tx options in order to avoid use after
free, from Eric Dumazet.
16) Missing kbuild export if ila.h, from Stephen Hemminger.
17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from
Tobias Klauser.
18) Validate protocol value range in ->create() methods, from Hannes
Frederic Sowa.
19) Fix early socket demux races that result in illegal dst reuse, from
Eric Dumazet.
20) Validate socket address length in pptp code, from WANG Cong.
21) skb_reorder_vlan_header() uses incorrect offset and can corrupt
packets, from Vlad Yasevich.
22) Fix memory leaks in nl80211 registry code, from Ola Olsson.
23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and
qlcnic. From Dan Carpenter.
24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for
example, AF_ALG will interpret it as an async call. From Tadeusz
Struk.
25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from
Eric Dumazet.
26) rhashtable enforces the minimum table size not early enough,
breaking how we calculate the per-cpu lock allocations. From
Herbert Xu.
27) Fix FCC port lockup in 82xx driver, from Martin Roth.
28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa.
29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and
sock_setsockopt() wrt. timestamp handling. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits)
net: check both type and procotol for tcp sockets
drivers: net: xgene: fix Tx flow control
tcp: restore fastopen with no data in SYN packet
af_unix: Revert 'lock_interruptible' in stream receive code
fou: clean up socket with kfree_rcu
82xx: FCC: Fixing a bug causing to FCC port lock-up
gianfar: Don't enable RX Filer if not supported
net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration
rhashtable: Fix walker list corruption
rhashtable: Enforce minimum size on initial hash table
inet: tcp: fix inetpeer_set_addr_v4()
ipv6: automatically enable stable privacy mode if stable_secret set
net: fix uninitialized variable issue
bluetooth: Validate socket address length in sco_sock_bind().
net_sched: make qdisc_tree_decrease_qlen() work for non mq
ser_gigaset: remove unnecessary kfree() calls from release method
ser_gigaset: fix deallocation of platform device structure
ser_gigaset: turn nonsense checks into WARN_ON
ser_gigaset: fix up NULL checks
qlcnic: fix a timeout loop
The commit 33db4125ec74 ("openvswitch: Rename LABEL->LABELS") left
over an old OVS_CT_ATTR_LABEL instance, fix it.
Fixes: 33db4125ec74 ("openvswitch: Rename LABEL->LABELS")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Joe Stringer <joe@ovn.org>
The file ila.h used for lightweight tunnels is being used by iproute2
but is not exported yet.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Pull VFIO fixes from Alex Williamson:
- Various fixes for removing redundancy, const'ifying structs, avoiding
stack usage, fixing WARN usage (Krzysztof Kozlowski, Julia Lawall,
Kees Cook, Dan Carpenter)
- Revert No-IOMMU mode as the intended user has not emerged (Alex
Williamson)
* tag 'vfio-v4.4-rc5' of git://github.com/awilliam/linux-vfio:
Revert: "vfio: Include No-IOMMU mode"
vfio: fix a warning message
vfio: platform: remove needless stack usage
vfio-pci: constify pci_error_handlers structures
vfio: Drop owner assignment from platform_driver
Revert commit 033291eccbdb ("vfio: Include No-IOMMU mode") due to lack
of a user. This was originally intended to fill a need for the DPDK
driver, but uptake has been slow so rather than support an unproven
kernel interface revert it and revisit when userspace catches up.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
The NFS CLONE_RANGE defintion was wrong and thus never worked. Fix this
by simply using the btrfs ioctl defintion.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Pull VFIO updates from Alex Williamson:
- Use kernel interfaces for VPD emulation (Alex Williamson)
- Platform fix for releasing IRQs (Eric Auger)
- Type1 IOMMU always advertises PAGE_SIZE support when smaller mapping
sizes are available (Eric Auger)
- Platform fixes for incorrectly using copies of structures rather than
pointers to structures (James Morse)
- Rework platform reset modules, fix leak, and add AMD xgbe reset
module (Eric Auger)
- Fix vfio_device_get_from_name() return value (Joerg Roedel)
- No-IOMMU interface (Alex Williamson)
- Fix potential out of bounds array access in PCI config handling (Dan
Carpenter)
* tag 'vfio-v4.4-rc1' of git://github.com/awilliam/linux-vfio:
vfio/pci: make an array larger
vfio: Fix bug in vfio_device_get_from_name()
VFIO: platform: reset: AMD xgbe reset module
vfio: platform: reset: calxedaxgmac: fix ioaddr leak
vfio: platform: add dev_info on device reset
vfio: platform: use list of registered reset function
vfio: platform: add compat in vfio_platform_device
vfio: platform: reset: calxedaxgmac: add reset function registration
vfio: platform: introduce module_vfio_reset_handler macro
vfio: platform: add capability to register a reset function
vfio: platform: introduce vfio-platform-base module
vfio/platform: store mapped memory in region, instead of an on-stack copy
vfio/type1: handle case where IOMMU does not support PAGE_SIZE size
VFIO: platform: clear IRQ_NOAUTOEN when de-assigning the IRQ
vfio/pci: Use kernel VPD access functions
vfio: Whitelist PCI bridges
Pull ARM SoC driver updates from Olof Johansson:
"As we've enabled multiplatform kernels on ARM, and greatly done away
with the contents under arch/arm/mach-*, there's still need for
SoC-related drivers to go somewhere.
Many of them go in through other driver trees, but we still have
drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code
that might be shared between ARM and ARM64 (or just in general makes
sense to not have under the architecture directory).
This branch contains mostly such code:
- Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to
communicate with power management blocks on these SoCs for use by
clock, regulator and bus frequency drivers.
- Allwinner Reduced Serial Bus driver, again used to communicate with
PMICs.
- Drivers for ARM's SCPI (System Control Processor). Not to be
confused with PSCI (Power State Coordination Interface). SCPI is
used to communicate with the assistant embedded cores doing power
management, and we have yet to see how many of them will implement
this for their hardware vs abstracting in other ways (or not at all
like in the past).
- To make confusion between SCPI and PSCI more likely, this release
also includes an update of PSCI to interface version 1.0.
- Rockchip support for power domains.
- A driver to talk to the firmware on Raspberry Pi"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits)
soc: qcom: smd-rpm: Correct size of outgoing message
bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus
bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings
ARM: bcm2835: add mutual inclusion protection
drivers: psci: make PSCI 1.0 functions initialization version dependent
dt-bindings: Correct paths in Rockchip power domains binding document
soc: rockchip: power-domain: don't try to print the clock name in error case
soc: qcom/smem: add HWSPINLOCK dependency
clk: berlin: add cpuclk
ARM: berlin: dts: add CLKID_CPU for BG2Q
ARM: bcm2835: Add the Raspberry Pi firmware driver
soc: qcom: smem: Move RPM message ram out of smem DT node
soc: qcom: smd-rpm: Correct the active vs sleep state flagging
soc: qcom: smd: delete unneeded of_node_put
firmware: qcom-scm: build for correct architecture level
soc: qcom: smd: Correct SMEM items for upper channels
qcom-scm: add missing prototype for qcom_scm_is_available()
qcom-scm: fix endianess issue in __qcom_scm_is_call_available
soc: qcom: smd: Reject send of too big packets
soc: qcom: smd: Handle big endian CPUs
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- New drivers: UniPhier (with and without FIFO)
- some drivers got some bigger rework: ismt, designware, img-scb (rcar
had to be reverted because issues were showing up just lately)
- ACPI: reworked the device scanning and added support for muxes
... and quite a lot of driver bugfixes and cleanups this time. All
files touched outside of the i2c realm have proper acks.
* 'i2c/for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (70 commits)
i2c: rcar: Revert the latest refactoring series
i2c: pnx: remove superfluous assignment
MAINTAINERS: i2c: drop i2c-pnx maintainer
MAINTAINERS: i2c: mark also subdirectories as maintained
i2c: cadence: enable driver for ARM64
i2c: i801: Document Intel DNV and Broxton
i2c: at91: manage unexpected RXRDY flag when starting a transfer
i2c: pnx: Use setup_timer instead of open coding it
i2c: add ACPI support for I2C mux ports
acpi: add acpi_preset_companion() stub
i2c: pxa: Add support for pxa910/988 & new configuration features
i2c: au1550: Convert to devm_kzalloc and devm_ioremap_resource
i2c-dev: Fix I2C_SLAVE ioctl comment
i2c-dev: Fix typo in ioctl name reference
i2c: sirf: tune the divider to make i2c bus freq more accurate
i2c: imx: Use -ENXIO as error in the NACK case
i2c: i801: Add support for Intel Broxton
i2c: i801: Add support for Intel DNV
i2c: mediatek: add i2c resume support
i2c: imx: implement bus recovery
Pull drm updates from Dave Airlie:
"I Was Almost Tempted To Capitalise Every Word, but then I decided I
couldn't read it myself!
I've also got one pull request for the sti driver outstanding. It
relied on a commit in Greg's tree and I didn't find out in time, that
commit is in your tree now so I might send that along once this is
merged.
I also had the accidental misfortune to have access to a Skylake on my
desk for a few days, and I've had to encourage Intel to try harder,
which seems to be happening now.
Here is the main drm-next pull request for 4.4.
Highlights:
New driver:
vc4 driver for the Rasberry Pi VPU.
(From Eric Anholt at Broadcom.)
Core:
Atomic fbdev support
Atomic helpers for runtime pm
dp/aux i2c STATUS_UPDATE handling
struct_mutex usage cleanups.
Generic of probing support.
Documentation:
Kerneldoc for VGA switcheroo code.
Rename to gpu instead of drm to reflect scope.
i915:
Skylake GuC firmware fixes
HPD A support
VBT backlight fallbacks
Fastboot by default for some systems
FBC work
BXT/SKL workarounds
Skylake deeper sleep state fixes
amdgpu:
Enable GPU scheduler by default
New atombios opcodes
GPUVM debugging options
Stoney support.
Fencing cleanups.
radeon:
More efficient CS checking
nouveau:
gk20a instance memory handling improvements.
Improved PGOB detection and GK107 support
Kepler GDDR5 PLL statbility improvement
G8x/GT2xx reclock improvements
new userspace API compatiblity fixes.
virtio-gpu:
Add 3D support - qemu 2.5 has it merged for it's gtk backend.
msm:
Initial msm88896 (snapdragon 8200)
exynos:
HDMI cleanups
Enable mixer driver byt default
Add DECON-TV support
vmwgfx:
Move to using memremap + fixes.
rcar-du:
Add support for R8A7793/4 DU
armada:
Remove support for non-component mode
Improved plane handling
Power savings while in DPMS off.
tda998x:
Remove unused slave encoder support
Use more HDMI helpers
Fix EDID read handling
dwhdmi:
Interlace video mode support for ipu-v3/dw_hdmi
Hotplug state fixes
Audio driver integration
imx:
More color formats support.
tegra:
Minor fixes/improvements"
[ Merge fixup: remove unused variable 'dev' that had all uses removed in
commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from
drm_gem_mmap_obj" ]
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits)
drm/vmwgfx: Relax irq locking somewhat
drm/vmwgfx: Properly flush cursor updates and page-flips
drm/i915/skl: disable display side power well support for now
drm/i915: Extend DSL readout fix to BDW and SKL.
drm/i915: Do graphics device reset under forcewake
drm/i915: Skip fence installation for objects with rotated views (v4)
vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT
drm/amdgpu: group together common fence implementation
drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE
drm/amdgpu: remove now unused fence functions
drm/amdgpu: fix fence fallback check
drm/amdgpu: fix stoping the scheduler timeout
drm/amdgpu: cleanup on error in amdgpu_cs_ioctl()
drm/i915: Fix locking around GuC firmware load
drm/amdgpu: update Fiji's Golden setting
drm/amdgpu: update Fiji's rev id
drm/amdgpu: extract common code in vi_common_early_init
drm/amd/scheduler: don't oops on failure to load
drm/amdgpu: don't oops on failure to load (v2)
drm/amdgpu: don't VT switch on suspend
Pull NFS client updates from Trond Myklebust:
"Highlights include:
New features:
- RDMA client backchannel from Chuck
- Support for NFSv4.2 file CLONE using the btrfs ioctl
Bugfixes + cleanups:
- Move socket data receive out of the bottom halves and into a
workqueue
- Refactor NFSv4 error handling so synchronous and asynchronous RPC
handles errors identically.
- Fix a panic when blocks or object layouts reads return a bad data
length
- Fix nfsroot so it can handle a 1024 byte long path.
- Fix bad usage of page offset in bl_read_pagelist
- Various NFSv4 callback cleanups+fixes
- Fix GETATTR bitmap verification
- Support hexadecimal number for sunrpc debug sysctl files"
* tag 'nfs-for-4.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (53 commits)
Sunrpc: Supports hexadecimal number for sysctl files of sunrpc debug
nfs: Fix GETATTR bitmap verification
nfs: Remove unused xdr page offsets in getacl/setacl arguments
fs/nfs: remove unnecessary new_valid_dev check
SUNRPC: fix variable type
NFS: Enable client side NFSv4.1 backchannel to use other transports
pNFS/flexfiles: Add support for FF_FLAGS_NO_IO_THRU_MDS
pNFS/flexfiles: When mirrored, retry failed reads by switching mirrors
SUNRPC: Remove the TCP-only restriction in bc_svc_process()
svcrdma: Add backward direction service for RPC/RDMA transport
xprtrdma: Handle incoming backward direction RPC calls
xprtrdma: Add support for sending backward direction RPC replies
xprtrdma: Pre-allocate Work Requests for backchannel
xprtrdma: Pre-allocate backward rpc_rqst and send/receive buffers
SUNRPC: Abstract backchannel operations
xprtrdma: Saving IRQs no longer needed for rb_lock
xprtrdma: Remove reply tasklet
xprtrdma: Use workqueue to process RPC/RDMA replies
xprtrdma: Replace send and receive arrays
xprtrdma: Refactor reply handler error handling
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"We have a lot of subvolume quota improvements in here, along with big
piles of cleanups from Dave Sterba and Anand Jain and others.
Josef pitched in a batch of allocator fixes based on production use
here at FB. We found that mount -o ssd_spread greatly improved our
performance on hardware raid5/6, but it exposed some CPU bottlenecks
in the allocator. These patches make a huge difference"
* 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (100 commits)
Btrfs: fix hole punching when using the no-holes feature
Btrfs: find_free_extent: Do not erroneously skip LOOP_CACHING_WAIT state
btrfs: Fix a data space underflow warning
btrfs: qgroup: Fix a rebase bug which will cause qgroup double free
btrfs: qgroup: Fix a race in delayed_ref which leads to abort trans
btrfs: clear PF_NOFREEZE in cleaner_kthread()
btrfs: qgroup: Don't copy extent buffer to do qgroup rescan
btrfs: add balance filters limits, stripes and usage to supported mask
btrfs: extend balance filter usage to take minimum and maximum
btrfs: add balance filter for stripes
btrfs: extend balance filter limit to take minimum and maximum
btrfs: fix use after free iterating extrefs
btrfs: check unsupported filters in balance arguments
Btrfs: fix regression running delayed references when using qgroups
Btrfs: fix regression when running delayed references
Btrfs: don't do extra bitmap search in one bit case
Btrfs: keep track of largest extent in bitmaps
Btrfs: don't keep trying to build clusters if we are fragmented
Btrfs: cut down on loops through the allocator
Btrfs: don't continue setting up space cache when enospc
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Add support for the CSUM_SEED feature which will allow future
userspace utilities to change the file system's UUID without rewriting
all of the file system metadata.
A number of miscellaneous fixes, the most significant of which are in
the ext4 encryption support. Anyone wishing to use the encryption
feature should backport all of the ext4 crypto patches up to 4.4 to
get fixes to a memory leak and file system corruption bug.
There are also cleanups in ext4's feature test macros and in ext4's
sysfs support code"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (26 commits)
fs/ext4: remove unnecessary new_valid_dev check
ext4: fix abs() usage in ext4_mb_check_group_pa
ext4: do not allow journal_opts for fs w/o journal
ext4: explicit mount options parsing cleanup
ext4, jbd2: ensure entering into panic after recording an error in superblock
[PATCH] fix calculation of meta_bg descriptor backups
ext4: fix potential use after free in __ext4_journal_stop
jbd2: fix checkpoint list cleanup
ext4: fix xfstest generic/269 double revoked buffer bug with bigalloc
ext4: make the bitmap read routines return real error codes
jbd2: clean up feature test macros with predicate functions
ext4: clean up feature test macros with predicate functions
ext4: call out CRC and corruption errors with specific error codes
ext4: store checksum seed in superblock
ext4: reserve code points for the project quota feature
ext4: promote ext4 over ext2 in the default probe order
jbd2: gate checksum calculations on crc driver presence, not sb flags
ext4: use private version of page_zero_new_buffers() for data=journal mode
ext4 crypto: fix bugs in ext4_encrypted_zeroout()
ext4 crypto: replace some BUG_ON()'s with error checks
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Items of note:
- evdev users can now limit or mask the kind of events they will
receive. This will allow applications such as power manager or
network manager to only be woken when user presses special keys
such as KEY_POWER or KEY_WIFI and not be bothered with ordinary
key presses coming from keyboard
- support for FocalTech FT6236 touchscreen controller
- support for ROHM BU21023/24 touchscreen controller
- edt-ft5x06 touchscreen driver got a face lift and can now be used
with FT5506
- support for Google Fiber TV Box remote controls
- improvements in xpad driver (with more to come)
- several parport-based drivers have been switched to the new device
model
- other miscellaneous driver improvements"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (70 commits)
HID: hid-gfrm: avoid warning for input_configured API change
HID: hid-input: allow input_configured callback return errors
Input: evdev - fix bug in checking duplicate clock change request
Input: add userio module
Input: evdev - add event-mask API
Input: snvs_pwrkey - remove duplicated semicolon
HID: hid-gfrm: Google Fiber TV Box remote controls
Input: e3x0-button - update Kconfig description
Input: tegra-kbc - drop use of IRQF_NO_SUSPEND flag
Input: tegra-kbc - enable support for the standard "wakeup-source" property
Input: xen - check return value of xenbus_printf
Input: hp_sdc_rtc - fix y2038 problem in proc_show
Input: nomadik-ske-keypad - fix a trivial typo
Input: xpad - fix clash of presence handling with LED setting
Input: edt-ft5x06 - work around FT5506 firmware bug
Input: edt-ft5x06 - add support for FT5506
Input: edt-ft5x06 - add support for different max support points
Input: edt-ft5x06 - use max support points to determine how much to read
Input: rotary-encoder - add support for quarter-period mode
Input: rotary-encoder - use of_property_read_bool
Pull MTD updates from Brian Norris:
"Core:
- WARN (in some cases) when a struct mtd_info is registered multiple
times; in the past this was "supported", but it's still error prone
for future development. There's only one ugly case of this left in
the tree (that we're aware of) and the owners are aware of the
problems there.
- fix potential deadlock in the blkdev removal path NOTE: the
(potential) deadlock was introduced in a for-stable patch. This
one is also marked for -stable.
- ioctl(BLKPG) compat_ioctl support; resolves issues with 32-bit user
space vs 64-bit kernel space
- Set MTD parent device correctly throughout the tree, so the tree
structure appears correctly in sysfs; many drivers were missing
this (soft) requirement
- Move device tree partitions (ofpart) into a dedicated 'partitions'
subnode; this helps to disambiguate whether a node is a partition
or some other auxiliary data
- Improve error handling for partitioning failures
NAND:
- General: Increase timeout period, for corner-case systems with
less-than-accurate jiffies
- Fix OF-based autoloading of several NAND drivers when built as
modules
- pxa3xx_nand:
- Rework timing configuration to be more dynamic
- Refactor PM support
- brcmnand: prepare for NorthStar 2 support (ARM64, 16-bit NAND
chips)
- sunxi_nand: refactoring and a few bug fixes
- vf610: new NAND driver
- FSMC: add SW BCH support; support common NAND DT bindings
- lpc32xx_slc: refactor and improve timing calculations logic
- denali: support for rev 5.1
SPI NOR:
- Layering improvements
- Added Winbond lock/unlock support
- Added mtd_is_locked() (i.e., ioctl(MEMISLOCKED)) support
- Increase full-chip-erase timeout linearly with flash size
- fsl-quadspi: fix compile for non-ARM architectures
- New flash support"
* tag 'for-linus-20151106' of git://git.infradead.org/linux-mtd: (169 commits)
mtd: don't WARN about overloaded users of mtd->reboot_notifier.notifier_call
mtd: nand: sunxi: avoid retrieving data before ECC pass
mtd: nand: sunxi: fix sunxi_nfc_hw_ecc_read/write_chunk()
mtd: blkdevs: fix potential deadlock + lockdep warnings
mtd: ofpart: move ofpart partitions to a dedicated dt node
doc: dt: mtd: support partitions in a special 'partitions' subnode
mtd: brcmnand: Force 8bit mode before doing nand_scan_ident()
mtd: brcmnand: factor out CFG and CFG_EXT bitfields
mtd: mtdpart: Do not fail mtd probe when parsing partitions fails
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
mtd: warn when registering the same master many times
mtd: fixup corner case error handling in mtd_device_parse_register()
mtd: tests: Replace timeval with ktime_t
mtd: fsmc_nand: Add BCH4 SW ECC support for SPEAr600
mtd: nand: vf610_nfc: use nand_check_erased_ecc_chunk() helper
mtd: nand: increase ready wait timeout and report timeouts
mtd: docg3: off by one in doc_register_sysfs()
mtd: pxa3xx_nand: clean up the pxa3xx timings
mtd: pxa3xx_nand: rework flash detection and timing setup
mtd: pxa3xx_nand: add helpers to setup the timings
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Resource management:
- Add support for Enhanced Allocation devices (Sean O. Stalley)
- Add Enhanced Allocation register entries (Sean O. Stalley)
- Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney)
- Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney)
- Handle Enhanced Allocation capability for SR-IOV devices (David Daney)
- Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas)
- Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas)
- Expand Enhanced Allocation BAR output (Bjorn Helgaas)
- Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier)
- Fix lookup of linux,pci-probe-only property (Marc Zyngier)
- Add sparc mem64 resource parsing for root bus (Yinghai Lu)
PCI device hotplug:
- pciehp: Queue power work requests in dedicated function (Guenter Roeck)
Driver binding:
- Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker)
Virtualization:
- Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck)
- Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck)
- Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck)
- Reorder pcibios_sriov_disable() (Alexander Duyck)
- Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck)
- Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck)
- Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton)
- Don't try to restore VF BARs (Wei Yang)
MSI:
- Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel)
- Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach)
- Export all remapped MSIs to sysfs attributes (Romain Bezut)
- Disable MSI on SiS 761 (Ondrej Zary)
AER:
- Clear error status registers during enumeration and restore (Taku Izumi)
Generic host bridge driver:
- Allow multiple hosts with different map_bus() methods (David Daney)
- Pass starting bus number to pci_scan_root_bus() (David Daney)
- Fix address window calculation for non-zero starting bus (David Daney)
Altera host bridge driver:
- Add msi.h to ARM Kbuild (Ley Foon Tan)
- Add Altera PCIe host controller driver (Ley Foon Tan)
- Add Altera PCIe MSI driver (Ley Foon Tan)
APM X-Gene host bridge driver:
- Remove msi_controller assignment (Duc Dang)
Broadcom iProc host bridge driver:
- Fix header comment "Corporation" misspelling (Florian Fainelli)
- Fix code comment to match code (Ray Jui)
- Remove unused struct iproc_pcie.irqs[] (Ray Jui)
- Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui)
- Fix PCIe reset logic (Ray Jui)
- Improve link detection logic (Ray Jui)
- Update PCIe device tree bindings (Ray Jui)
- Add outbound mapping support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Return real error code from imx6_add_pcie_port() (Fabio Estevam)
- Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam)
Freescale Layerscape host bridge driver:
- Remove ls_pcie_establish_link() (Minghuan Lian)
- Ignore PCIe controllers in Endpoint mode (Minghuan Lian)
- Factor out SCFG related function (Minghuan Lian)
- Update ls_add_pcie_port() (Minghuan Lian)
- Remove unused fields from struct ls_pcie (Minghuan Lian)
- Add support for LS1043a and LS2080a (Minghuan Lian)
- Add ls_pcie_msi_host_init() (Minghuan Lian)
HiSilicon host bridge driver:
- Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang)
Marvell MVEBU host bridge driver:
- Return zero for reserved or unimplemented config space (Russell King)
- Use exact config access size; don't read/modify/write (Russell King)
- Use of_get_available_child_count() (Russell King)
- Use for_each_available_child_of_node() to walk child nodes (Russell King)
- Report full node name when reporting a DT error (Russell King)
- Use port->name rather than "PCIe%d.%d" (Russell King)
- Move port parsing and resource claiming to separate function (Russell King)
- Fix memory leaks and refcount leaks (Russell King)
- Split port parsing and resource claiming from port setup (Russell King)
- Use gpio_set_value_cansleep() (Russell King)
- Use devm_kcalloc() to allocate an array (Russell King)
- Use gpio_desc to carry around gpio (Russell King)
- Improve clock/reset handling (Russell King)
- Add PCI Express root complex capability block (Russell King)
- Remove code restricting accesses to slot 0 (Russell King)
NVIDIA Tegra host bridge driver:
- Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel)
Renesas R-Car host bridge driver:
- Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven)
- Build pcie-rcar.c only on ARM (Geert Uytterhoeven)
- Make PCI aware of the I/O resources (Phil Edworthy)
- Remove dependency on ARM-specific struct hw_pci (Phil Edworthy)
- Set root bus nr to that provided in DT (Phil Edworthy)
- Fix I/O offset for multiple host bridges (Phil Edworthy)
ST Microelectronics SPEAr13xx host bridge driver:
- Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni)
Synopsys DesignWare host bridge driver:
- Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma)
- Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni)
- Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni)
- Require config accesses to be naturally aligned (Gabriele Paoloni)
- Make "num-lanes" an optional DT property (Gabriele Paoloni)
- Move calculation of bus addresses to DRA7xx (Gabriele Paoloni)
- Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni)
- Factor out MSI msg setup (Lucas Stach)
- Implement multivector MSI IRQ setup (Lucas Stach)
- Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach)
- Set up high part of MSI target address (Lucas Stach)
- Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang)
- Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang)
- Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang)
- Make driver arch-agnostic (Zhou Wang)
Miscellaneous:
- Make x86 pci_subsys_init() static (Alexander Kuleshov)
- Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)"
* tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: altera: Add Altera PCIe MSI driver
PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver
PCI: layerscape: Add ls_pcie_msi_host_init()
PCI: layerscape: Add support for LS1043a and LS2080a
PCI: layerscape: Remove unused fields from struct ls_pcie
PCI: layerscape: Update ls_add_pcie_port()
PCI: layerscape: Factor out SCFG related function
PCI: layerscape: Ignore PCIe controllers in Endpoint mode
PCI: layerscape: Remove ls_pcie_establish_link()
PCI: designware: Make "clocks" and "clock-names" optional DT properties
PCI: designware: Make driver arch-agnostic
ARM/PCI: Replace pci_sys_data->align_resource with global function pointer
PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT
PCI: designware: Move calculation of bus addresses to DRA7xx
PCI: designware: Make "num-lanes" an optional DT property
PCI: designware: Require config accesses to be naturally aligned
PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces
PCI: designware: Use exact access size in dw_pcie_cfg_read()
PCI: spear: Fix dw_pcie_cfg_read/write() usage
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.4.
s390:
A bunch of fixes and optimizations for interrupt and time handling.
PPC:
Mostly bug fixes.
ARM:
No big features, but many small fixes and prerequisites including:
- a number of fixes for the arch-timer
- introducing proper level-triggered semantics for the arch-timers
- a series of patches to synchronously halt a guest (prerequisite
for IRQ forwarding)
- some tracepoint improvements
- a tweak for the EL2 panic handlers
- some more VGIC cleanups getting rid of redundant state
x86:
Quite a few changes:
- support for VT-d posted interrupts (i.e. PCI devices can inject
interrupts directly into vCPUs). This introduces a new
component (in virt/lib/) that connects VFIO and KVM together.
The same infrastructure will be used for ARM interrupt
forwarding as well.
- more Hyper-V features, though the main one Hyper-V synthetic
interrupt controller will have to wait for 4.5. These will let
KVM expose Hyper-V devices.
- nested virtualization now supports VPID (same as PCID but for
vCPUs) which makes it quite a bit faster
- for future hardware that supports NVDIMM, there is support for
clflushopt, clwb, pcommit
- support for "split irqchip", i.e. LAPIC in kernel +
IOAPIC/PIC/PIT in userspace, which reduces the attack surface of
the hypervisor
- obligatory smattering of SMM fixes
- on the guest side, stable scheduler clock support was rewritten
to not require help from the hypervisor"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (123 commits)
KVM: VMX: Fix commit which broke PML
KVM: x86: obey KVM_X86_QUIRK_CD_NW_CLEARED in kvm_set_cr0()
KVM: x86: allow RSM from 64-bit mode
KVM: VMX: fix SMEP and SMAP without EPT
KVM: x86: move kvm_set_irq_inatomic to legacy device assignment
KVM: device assignment: remove pointless #ifdefs
KVM: x86: merge kvm_arch_set_irq with kvm_set_msi_inatomic
KVM: x86: zero apic_arb_prio on reset
drivers/hv: share Hyper-V SynIC constants with userspace
KVM: x86: handle SMBASE as physical address in RSM
KVM: x86: add read_phys to x86_emulate_ops
KVM: x86: removing unused variable
KVM: don't pointlessly leave KVM_COMPAT=y in non-KVM configs
KVM: arm/arm64: Merge vgic_set_lr() and vgic_sync_lr_elrsr()
KVM: arm/arm64: Clean up vgic_retire_lr() and surroundings
KVM: arm/arm64: Optimize away redundant LR tracking
KVM: s390: use simple switch statement as multiplexer
KVM: s390: drop useless newline in debugging data
KVM: s390: SCA must not cross page boundaries
KVM: arm: Do not indent the arguments of DECLARE_BITMAP
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"Media updates, including:
- Lots of improvements at the kABI documentation
- Split of Videobuf2 into a common part and a V4L2 specific one
- Split of the VB2 tracing events into a separate header file
- s5p-mfc got support for Exynos 5433
- v4l2 fixes for 64-bits alignment when running 32 bits userspace
on ARM
- Added support for SDR radio transmitter at core, vivid and hackrf
drivers
- Some y2038 fixups
- Some improvements at V4L2 colorspace support
- saa7164 converted to use the V4L2 core control framework
- several new boards additions, cleanups and fixups
PS: There are two patches for scripts/kernel-doc that are needed by
the documentation patches on Media. Jon is OK on merging those via
my tree"
* tag 'media/v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (146 commits)
[media] c8sectpfe: Remove select on CONFIG_FW_LOADER_USER_HELPER_FALLBACK
[media] DocBook media: update copyright/version numbers
[media] ivtv: Convert to get_user_pages_unlocked()
[media] media/v4l2-ctrls: fix setting autocluster to manual with VIDIOC_S_CTRL
[media] DocBook media: Fix a typo in encoder cmd
[media] DocBook: add SDR specific info to G_MODULATOR / S_MODULATOR
[media] DocBook: add SDR specific info to G_TUNER / S_TUNER
[media] hackrf: do not set human readable name for formats
[media] hackrf: add support for transmitter
[media] hackrf: switch to single function which configures everything
[media] hackrf: add control for RF amplifier
[media] DocBook: add modulator type field
[media] v4l: add type field to v4l2_modulator struct
[media] DocBook: document SDR transmitter
[media] v4l2: add support for SDR transmitter
[media] DocBook: document tuner RF gain control
[media] v4l2: add RF gain control
[media] v4l2: rename V4L2_TUNER_ADC to V4L2_TUNER_SDR
[media] media/vivid-osd: fix info leak in ioctl
[media] media: videobuf2: Move v4l2-specific stuff to videobuf2-v4l2
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big char/misc driver update for 4.4-rc1. Lots of
different driver and subsystem updates, hwtracing being the largest
with the addition of some new platforms that are now supported. Full
details in the shortlog.
All of these have been in linux-next for a long time with no reported
issues"
* tag 'char-misc-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (181 commits)
fpga: socfpga: Fix check of return value of devm_request_irq
lkdtm: fix ACCESS_USERSPACE test
mcb: Destroy IDA on module unload
mcb: Do not return zero on error path in mcb_pci_probe()
mei: bus: set the device name before running fixup
mei: bus: use correct lock ordering
mei: Fix debugfs filename in error output
char: ipmi: ipmi_ssif: Replace timeval with timespec64
fpga: zynq-fpga: Fix issue with drvdata being overwritten.
fpga manager: remove unnecessary null pointer checks
fpga manager: ensure lifetime with of_fpga_mgr_get
fpga: zynq-fpga: Change fw format to handle bin instead of bit.
fpga: zynq-fpga: Fix unbalanced clock handling
misc: sram: partition base address belongs to __iomem space
coresight: etm3x: adding documentation for sysFS's cpu interface
vme: 8-bit status/id takes 256 values, not 255
fpga manager: Adding FPGA Manager support for Xilinx Zynq 7000
ARM: zynq: dt: Updated devicetree for Zynq 7000 platform.
ARM: dt: fpga: Added binding docs for Xilinx Zynq FPGA manager.
ver_linux: proc/modules, limit text processing to 'sed'
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging driver update for 4.4-rc1. If you were
disappointed for 4.3-rc1 that we didn't contribute enough changesets,
you should be happy with this pull request of over 2400 patches.
But overall we removed more lines of code than we added, which is nice
to see. Full details in the shortlog.
All of these have been in linux-next for a while"
Greg, I've never been disappointed in how few commits Staging
contributes to the kernel.. Never.
* tag 'staging-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (2431 commits)
Staging: rtl8192u: ieee80211: added missing blank lines
Staging: rtl8192u: ieee80211: removed unnecessary braces
Staging: rtl8192u: ieee80211: corrected block comments
Staging: rtl8192u: ieee80211: corrected indent
Staging: rtl8192u: ieee80211: added missing spaces after if
Staging: rtl8192u: ieee80211: added missing space around '='
Staging: rtl8192u: ieee80211: fixed position of else statements
Staging: rtl8192u: ieee80211: fixed open brace positions
staging: rdma: ipath: Remove unneeded vairable.
staging: rtl8188eu: pwrGrpCnt variable removed in store_pwrindex_offset function
staging: rtl8188eu: new variable for hal_data->MCSTxPowerLevelOriginalOffset[pwrGrpCnt] in store_pwrindex_offset function
staging: rtl8188eu: checkpatch fixes: 'Avoid CamelCase' in hal/bb_cfg.c
staging: rtl8188eu: checkpatch fixes: line over 80 characters splited into two parts
staging: rtl8188eu: checkpatch fixes: alignment should match open parenthesis
staging: rtl8188eu: checkpatch fixes: unnecessary parentheses removed in hal/bb_cfg.c
staging: rtl8188eu: checkpatch fixes: spaces preferred around that '|' in hal/bb_cfg.c
staging: rtl8188eu: operator = replaced by += in loop increment
staging: rtl8188eu: occurrence of the 5 GHz code marked
staging: rtl8188eu: increment placed into for loop header
staging: rtl8188eu: while loop replaced by for loop in rtw_restruct_wmm_ie
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here is the big USB patchset for 4.4-rc1.
As usual, most of the changes are in the gadget subsystem, and we
removed a host controller for a device that is no longer in existance,
and probably never was even made public. There is also other minor
driver updates and new device ids, full details in the changelog.
* tag 'usb-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (233 commits)
USB: core: Codestyle fix in urb.c
usb: misc: usb3503: Use i2c_add_driver helper macro
usb: host: lpc32xx: don't unregister phy device
usb: host: lpc32xx: balance clk enable/disable on removal
usb: host: lpc32xx: fix warnings caused by enabling unprepared clock
uwb: drp: Use setup_timer
uwb: neh: Use setup_timer
uwb: rsv: Use setup_timer
USB: qcserial: add Sierra Wireless MC74xx/EM74xx
usb: chipidea: otg: don't wait vbus drops below BSV when starts host
chipidea: ci_hdrc_pci: use PCI_VDEVICE() instead of PCI_DEVICE()
doc: dt-binding: ci-hdrc-usb2: split vendor specific properties
usb: chipidea: imx: add imx6ul usb support
doc: dt-binding: ci-hdrc-usb2: improve property description
usb: chipidea: imx: add usb support for imx7d
Doc: usb: ci-hdrc-usb2: Add phy-clkgate-delay-us entry
usb: chipidea: Add support for 'phy-clkgate-delay-us' property
usb: chipidea: Use extcon framework for VBUS and ID detect
usb: gadget: net2280: restore ep_cfg after defect7374 workaround
usb: dwc2: host: Fix use after free w/ simultaneous irqs
