[ Upstream commit 6d08acd2d32e3e877579315dc3202d7a5f336d98 ]
Resolve conflicts between glibc definition of IPV6 socket options
and those defined in Linux headers. Looks like earlier efforts to
solve this did not cover all the definitions.
It resolves warnings during iproute2 build.
Please consider for stable as well.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit 42f74461a5b60cf6b42887e6d2ff5b7be4abf1ca upstream.
SFR reported this 2013-05-15:
> After merging the final tree, today's linux-next build (i386 defconfig)
> produced this warning:
> kernel/auditfilter.c: In function 'audit_data_to_entry':
> kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only
> in ISO C90 [enabled by default]
> Introduced by commit 780a7654cee8 ("audit: Make testing for a valid
> loginuid explicit") from Linus' tree.
Replace this decimal constant in the code with a macro to make it more readable
(add to the unsigned cast to quiet the warning).
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit f37c013409bb78ebb958821aa10d069e707cabac upstream.
On some newer laptops with a trackpoint the physical buttons for the
trackpoint have been removed to allow for a larger touchpad. On these
laptops the buttonpad has clearly marked areas on the top which are to be
used as trackpad buttons.
Users of the event device-node need to know about this, so that they can
properly interpret BTN_LEFT events as being a left / right / middle click
depending on where on the button pad the clicking finger is.
This commits adds a INPUT_PROP_TOPBUTTONPAD device property which drivers
for such buttonpads will use to signal to the user that this buttonpad not
only has the normal bottom button area, but also a top button area.
commit e10038a8ec06ac819b7552bb67aaa6d2d6f850c1 upstream.
This structure is not exposed to userspace, so fix this by defining
struct sk_filter; so we skip the casting in kernelspace. This is safe
since userspace has no way to lurk with that internal pointer.
Fixes: e6f30c7 ("netfilter: x_tables: add xt_bpf match")
Acked-by: Willem de Bruijn <willemb@google.com>
commit bfcfd44cce2774f19daeb59fb4e43fc9aa80e7b8 upstream.
The guard was introduced in commit ea1a8217b06b ("xattr: guard against
simultaneous glibc header inclusion") but it is using #ifdef to check
for a define that is either set to 1 or 0. Fix it to use #if instead.
* Without this patch:
$ { echo "#include <sys/xattr.h>"; echo "#include <linux/xattr.h>"; } | gcc -E -Iinclude/uapi - >/dev/null
include/uapi/linux/xattr.h:19:0: warning: "XATTR_CREATE" redefined [enabled by default]
#define XATTR_CREATE 0x1 /* set value, fail if attr already exists */
/usr/include/x86_64-linux-gnu/sys/xattr.h:32:0: note: this is the location of the previous definition
#define XATTR_CREATE XATTR_CREATE
* With this patch:
(no warnings)
Signed-off-by: Filipe Brandenburger <filbranden@google.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Allan McRae <allan@archlinux.org>
commit 7ac3764fcafc06e72e1a79a9d998b9fdd900b2a6 upstream.
The file include/uapi/linux/usb/cdc-wdm.h uses a __u16 so it needs to
include types.h as well to make the build system happy.
Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND")
Cc: Bjørn Mork <bjorn@mork.no>
commit 7d1896360f4d055d68565ef8ed56a677580f1a39 upstream.
The include/uapi/linux/usb/cdc-wdm.h header defines cdc-wdm
userspace APIs and should be exported by make headers_install.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit ea1a8217b06b41b31a2b60b0b83f75c77ef9c873 upstream.
If the glibc xattr.h header is included after the uapi header,
compilation fails due to an enum re-using a #define from the uapi
header.
Protect against this by guarding the define and enum inclusions against
each other.
(See https://lists.debian.org/debian-glibc/2014/03/msg00029.html
and https://sourceware.org/glibc/wiki/Synchronizing_Headers
for more information.)
Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com>
commit aee786acfc0a12bcd37a1c60f3198fb25cf7181a upstream.
bt->width should be (bt)->width, and same for the other fields.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 7b7b68bba5ef23734c35ffb0d8d82079ed604d33 upstream.
In case reading of block 0 during open() fails, it is not the right thing
to let open() succeed.
Fix this by introducing FD_OPEN_SHOULD_FAIL_BIT flag, and setting it in
case the bio callback encounters an error while trying to read block 0.
As a bonus, this works around certain broken userspace (blkid), which is
not able to properly handle read()s returning IO errors. Hence be nice to
those, and bail out during open() already; if block 0 is not readable,
read()s are not going to provide any meaningful data anyway.
[ Upstream commit f52ed89971adbe79b6438c459814034707b8ab91 ]
For performance reasons, sch_fq tried hard to not setup timers for every
sent packet, using a quantum based heuristic : A delay is setup only if
the flow exhausted its credit.
Problem is that application limited flows can refill their credit
for every queued packet, and they can evade pacing.
This problem can also be triggered when TCP flows use small MSS values,
as TSO auto sizing builds packets that are smaller than the default fq
quantum (3028 bytes)
This patch adds a 40 ms delay to guard flow credit refill.
Fixes: afe4fd062416 ("pkt_sched: fq: Fair Queue packet scheduler")
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 65c5189a2b57b9aa1d89e4b79da39928257c9505 ]
Commit 7eec4174ff29 ("pkt_sched: fq: fix non TCP flows pacing")
obsoleted TCA_FQ_FLOW_DEFAULT_RATE without notice for the users.
Suggested by David Miller
The PPC64 people noticed a missing memory barrier and crufty old
comments in the perf ring buffer code. So update all the comments and
add the missing barrier.
When the architecture implements local_t using atomic_long_t there
will be double barriers issued; but short of introducing more
conditional barrier primitives this is the best we can do.
Reported-by: Victor Kaplansky <victork@il.ibm.com>
Tested-by: Victor Kaplansky <victork@il.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: michael@ellerman.id.au
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: benh@kernel.crashing.org
Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan
Jamal sent patch to add tc user simple actions to iproute2
but required header was not being exported.
Solve the problems around the broken definition of perf_event_mmap_page::
cap_usr_time and cap_usr_rdpmc fields which used to overlap, partially
fixed by:
860f085b74e9 ("perf: Fix broken union in 'struct perf_event_mmap_page'")
The problem with the fix (merged in v3.12-rc1 and not yet released
officially), noticed by Vince Weaver is that the new behavior is
not detectable by new user-space, and that due to the reuse of the
field names it's easy to mis-compile a binary if old headers are used
on a new kernel or new headers are used on an old kernel.
To solve all that make this change explicit, detectable and self-contained,
by iterating the ABI the following way:
- Always clear bit 0, and rename it to usrpage->cap_bit0, to at least not
confuse old user-space binaries. RDPMC will be marked as unavailable
to old binaries but that's within the ABI, this is a capability bit.
- Rename bit 1 to ->cap_bit0_is_deprecated and always set it to 1, so new
libraries can reliably detect that bit 0 is deprecated and perma-zero
without having to check the kernel version.
- Use bits 2, 3, 4 for the newly defined, correct functionality:
cap_user_rdpmc : 1, /* The RDPMC instruction can be used to read counts */
cap_user_time : 1, /* The time_* fields are used */
cap_user_time_zero : 1, /* The time_zero field is used */
- Rename all the bitfield names in perf_event.h to be different from the
old names, to make sure it's not possible to mis-compile it
accidentally with old assumptions.
The 'size' field can then be used in the future to add new fields and it
will act as a natural ABI version indicator as well.
Also adjust tools/perf/ userspace for the new definitions, noticed by
Adrian Hunter.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Also-Fixed-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/n/tip-zr03yxjrpXesOzzupszqglbv@git.kernel.org
For some mysterious reason the sample_id field of PERF_RECORD_MMAP went AWOL.
Reported-by: Vince Weaver <vince@deater.net>
Pull perf fixes from Ingo Molnar:
"Two small fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Fix UAPI export of PERF_EVENT_IOC_ID
perf/x86/intel: Fix Silvermont offcore masks
Without the following patch I have problems compiling code using
the new PERF_EVENT_IOC_ID ioctl(). It looks like u64 was used
instead of __u64
Signed-off-by: Vince Weaver <vincent.weaver@maine.edu>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1309171450380.11444@vincent-weaver-1.um.maine.edu
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input update from Dmitry Torokhov:
"The only change is David Hermann's new EVIOCREVOKE evdev ioctl that
allows safely passing file descriptors to input devices to session
processes and later being able to stop delivery of events through
these fds so that inactive sessions will no longer receive user input
that does not belong to them"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: evdev - add EVIOCREVOKE ioctl
Pull vfs pile 4 from Al Viro:
"list_lru pile, mostly"
This came out of Andrew's pile, Al ended up doing the merge work so that
Andrew didn't have to.
Additionally, a few fixes.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (42 commits)
super: fix for destroy lrus
list_lru: dynamically adjust node arrays
shrinker: Kill old ->shrink API.
shrinker: convert remaining shrinkers to count/scan API
staging/lustre/libcfs: cleanup linux-mem.h
staging/lustre/ptlrpc: convert to new shrinker API
staging/lustre/obdclass: convert lu_object shrinker to count/scan API
staging/lustre/ldlm: convert to shrinkers to count/scan API
hugepage: convert huge zero page shrinker to new shrinker API
i915: bail out earlier when shrinker cannot acquire mutex
drivers: convert shrinkers to new count/scan API
fs: convert fs shrinkers to new scan/count API
xfs: fix dquot isolation hang
xfs-convert-dquot-cache-lru-to-list_lru-fix
xfs: convert dquot cache lru to list_lru
xfs: rework buffer dispose list tracking
xfs-convert-buftarg-lru-to-generic-code-fix
xfs: convert buftarg LRU to generic code
fs: convert inode and dentry shrinking to be node aware
vmscan: per-node deferred work
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"This is against 3.11-rc7, but was pulled and tested against your tree
as of yesterday. We do have two small incrementals queued up, but I
wanted to get this bunch out the door before I hop on an airplane.
This is a fairly large batch of fixes, performance improvements, and
cleanups from the usual Btrfs suspects.
We've included Stefan Behren's work to index subvolume UUIDs, which is
targeted at speeding up send/receive with many subvolumes or snapshots
in place. It closes a long standing performance issue that was built
in to the disk format.
Mark Fasheh's offline dedup work is also here. In this case offline
means the FS is mounted and active, but the dedup work is not done
inline during file IO. This is a building block where utilities are
able to ask the FS to dedup a series of extents. The kernel takes
care of verifying the data involved really is the same. Today this
involves reading both extents, but we'll continue to evolve the
patches"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (118 commits)
Btrfs: optimize key searches in btrfs_search_slot
Btrfs: don't use an async starter for most of our workers
Btrfs: only update disk_i_size as we remove extents
Btrfs: fix deadlock in uuid scan kthread
Btrfs: stop refusing the relocation of chunk 0
Btrfs: fix memory leak of uuid_root in free_fs_info
btrfs: reuse kbasename helper
btrfs: return btrfs error code for dev excl ops err
Btrfs: allow partial ordered extent completion
Btrfs: convert all bug_ons in free-space-cache.c
Btrfs: add support for asserts
Btrfs: adjust the fs_devices->missing count on unmount
Btrf: cleanup: don't check for root_refs == 0 twice
Btrfs: fix for patch "cleanup: don't check the same thing twice"
Btrfs: get rid of one BUG() in write_all_supers()
Btrfs: allocate prelim_ref with a slab allocater
Btrfs: pass gfp_t to __add_prelim_ref() to avoid always using GFP_ATOMIC
Btrfs: fix race conditions in BTRFS_IOC_FS_INFO ioctl
Btrfs: fix race between removing a dev and writing sbs
Btrfs: remove ourselves from the cluster list under lock
Pull CIFS fixes from Steve French:
"CIFS update including case insensitive file name matching improvements
for UTF-8 to Unicode, various small cifs fixes, SMB2/SMB3 leasing
improvements, support for following SMB2 symlinks, SMB3 packet signing
improvements"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6: (25 commits)
CIFS: Respect epoch value from create lease context v2
CIFS: Add create lease v2 context for SMB3
CIFS: Move parsing lease buffer to ops struct
CIFS: Move creating lease buffer to ops struct
CIFS: Store lease state itself rather than a mapped oplock value
CIFS: Replace clientCanCache* bools with an integer
[CIFS] quiet sparse compile warning
cifs: Start using per session key for smb2/3 for signature generation
cifs: Add a variable specific to NTLMSSP for key exchange.
cifs: Process post session setup code in respective dialect functions.
CIFS: convert to use le32_add_cpu()
CIFS: Fix missing lease break
CIFS: Fix a memory leak when a lease break comes
cifs: add winucase_convert.pl to Documentation/ directory
cifs: convert case-insensitive dentry ops to use new case conversion routines
cifs: add new case-insensitive conversion routines that are based on wchar_t's
[CIFS] Add Scott to list of cifs contributors
cifs: Move and expand MAX_SERVER_SIZE definition
cifs: Expand max share name length to 256
cifs: Move string length definitions to uapi
This series reworks our current object cache shrinking infrastructure in
two main ways:
* Noticing that a lot of users copy and paste their own version of LRU
lists for objects, we put some effort in providing a generic version.
It is modeled after the filesystem users: dentries, inodes, and xfs
(for various tasks), but we expect that other users could benefit in
the near future with little or no modification. Let us know if you
have any issues.
* The underlying list_lru being proposed automatically and
transparently keeps the elements in per-node lists, and is able to
manipulate the node lists individually. Given this infrastructure, we
are able to modify the up-to-now hammer called shrink_slab to proceed
with node-reclaim instead of always searching memory from all over like
it has been doing.
Per-node lru lists are also expected to lead to less contention in the lru
locks on multi-node scans, since we are now no longer fighting for a
global lock. The locks usually disappear from the profilers with this
change.
Although we have no official benchmarks for this version - be our guest to
independently evaluate this - earlier versions of this series were
performance tested (details at
http://permalink.gmane.org/gmane.linux.kernel.mm/100537) yielding no
visible performance regressions while yielding a better qualitative
behavior in NUMA machines.
With this infrastructure in place, we can use the list_lru entry point to
provide memcg isolation and per-memcg targeted reclaim. Historically,
those two pieces of work have been posted together. This version presents
only the infrastructure work, deferring the memcg work for a later time,
so we can focus on getting this part tested. You can see more about the
history of such work at http://lwn.net/Articles/552769/
Dave Chinner (18):
dcache: convert dentry_stat.nr_unused to per-cpu counters
dentry: move to per-sb LRU locks
dcache: remove dentries from LRU before putting on dispose list
mm: new shrinker API
shrinker: convert superblock shrinkers to new API
list: add a new LRU list type
inode: convert inode lru list to generic lru list code.
dcache: convert to use new lru list infrastructure
list_lru: per-node list infrastructure
shrinker: add node awareness
Glauber Costa (7):
fs: bump inode and dentry counters to long
super: fix calculation of shrinkable objects for small numbers
list_lru: per-node API
This patch:
There are situations in very large machines in which we can have a large
quantity of dirty inodes, unused dentries, etc. This is particularly true
when umounting a filesystem, where eventually since every live object will
eventually be discarded.
Dave Chinner reported a problem with this while experimenting with the
shrinker revamp patchset. So we believe it is time for a change. This
patch just moves int to longs. Machines where it matters should have a
big long anyway.
Signed-off-by: Glauber Costa <glommer@openvz.org>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Arve Hjønnevåg <arve@android.com>
Cc: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: J. Bruce Fields <bfields@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kent Overstreet <koverstreet@google.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device-mapper updates from Mike Snitzer:
"Add the ability to collect I/O statistics on user-defined regions of a
device-mapper device. This dm-stats code required the reintroduction
of a div64_u64_rem() helper, but as a separate method that doesn't
slow down div64_u64() -- especially on 32-bit systems.
Allow the error target to replace request-based DM devices (e.g.
multipath) in addition to bio-based DM devices.
Various other small code fixes and improvements to thin-provisioning,
DM cache and the DM ioctl interface"
* tag 'dm-3.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm stripe: silence a couple sparse warnings
dm: add statistics support
dm thin: always return -ENOSPC if no_free_space is set
dm ioctl: cleanup error handling in table_load
dm ioctl: increase granularity of type_lock when loading table
dm ioctl: prevent rename to empty name or uuid
dm thin: set pool read-only if breaking_sharing fails block allocation
dm thin: prefix pool error messages with pool device name
dm: allow error target to replace bio-based and request-based targets
math64: New separate div64_u64_rem helper
dm space map: optimise sm_ll_dec and sm_ll_inc
dm btree: prefetch child nodes when walking tree for a dm_btree_del
dm btree: use pop_frame in dm_btree_del to cleanup code
dm cache: eliminate holes in cache structure
dm cache: fix stacking of geometry limits
dm thin: fix stacking of geometry limits
dm thin: add data block size limits to Documentation
dm cache: add data block size limits to code and Documentation
dm cache: document metadata device is exclussive to a cache
dm: stop using WQ_NON_REENTRANT
Pull xfs updates from Ben Myers:
"For 3.12-rc1 there are a number of bugfixes in addition to work to
ease usage of shared code between libxfs and the kernel, the rest of
the work to enable project and group quotas to be used simultaneously,
performance optimisations in the log and the CIL, directory entry file
type support, fixes for log space reservations, some spelling/grammar
cleanups, and the addition of user namespace support.
- introduce readahead to log recovery
- add directory entry file type support
- fix a number of spelling errors in comments
- introduce new Q_XGETQSTATV quotactl for project quotas
- add USER_NS support
- log space reservation rework
- CIL optimisations
- kernel/userspace libxfs rework"
* tag 'xfs-for-linus-v3.12-rc1' of git://oss.sgi.com/xfs/xfs: (112 commits)
xfs: XFS_MOUNT_QUOTA_ALL needed by userspace
xfs: dtype changed xfs_dir2_sfe_put_ino to xfs_dir3_sfe_put_ino
Fix wrong flag ASSERT in xfs_attr_shortform_getvalue
xfs: finish removing IOP_* macros.
xfs: inode log reservations are too small
xfs: check correct status variable for xfs_inobt_get_rec() call
xfs: inode buffers may not be valid during recovery readahead
xfs: check LSN ordering for v5 superblocks during recovery
xfs: btree block LSN escaping to disk uninitialised
XFS: Assertion failed: first <= last && last < BBTOB(bp->b_length), file: fs/xfs/xfs_trans_buf.c, line: 568
xfs: fix bad dquot buffer size in log recovery readahead
xfs: don't account buffer cancellation during log recovery readahead
xfs: check for underflow in xfs_iformat_fork()
xfs: xfs_dir3_sfe_put_ino can be static
xfs: introduce object readahead to log recovery
xfs: Simplify xfs_ail_min() with list_first_entry_or_null()
xfs: Register hotcpu notifier after initialization
xfs: add xfs sb v4 support for dirent filetype field
xfs: Add write support for dirent filetype field
xfs: Add read-only support for dirent filetype field
Pull VFIO update from Alex Williamson:
"VFIO updates include safer default file flags for VFIO device fds, an
external user interface exported to allow other modules to hold
references to VFIO groups, a fix to test for extended config space on
PCIe and PCI-x, and new hot reset interfaces for PCI devices which
allows the user to do PCI bus/slot resets when all of the devices
affected by the reset are owned by the user.
For this last feature, the PCI bus reset interface, I depend on
changes already merged from Bjorn's PCI pull request. I therefore
merged my tree up to commit cb3e433, which I think was the correct
action, but as Stephen Rothwell noted, I failed to provide a commit
message indicating why the merge was required. Sorry for that.
Thanks, Alex"
* tag 'vfio-v3.12-rc0' of git://github.com/awilliam/linux-vfio:
vfio: fix documentation
vfio-pci: PCI hot reset interface
vfio-pci: Test for extended config space
vfio-pci: Use fdget() rather than eventfd_fget()
vfio: Add O_CLOEXEC flag to vfio device fd
vfio: use get_unused_fd_flags(0) instead of get_unused_fd()
vfio: add external user support
MAX_SERVER_SIZE has been moved to cifs_mount.h and renamed
CIFS_NI_MAXHOST for clarity. It has been expanded to 1024 as the
previous value of 16 was very short.
Signed-off-by: Scott Lovenberg <scott.lovenberg@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
The old max share name length limit was 80 due to Windows NET SHARE
command not allowing more than that. However, share names can be much
longer. This is a more reasonable maximum share name length.
The max string length definitions for user name, domain name, password,
and share name have been moved into their own header file in uapi so the
mount helper can use autoconf to define them instead of keeping the
kernel side and userland side definitions in sync manually. The names
have also been standardized with a "CIFS" prefix and "LEN" suffix.
Reviewed-by: Chen Gang <gang.chen@asianux.com>
Pull NVM Express driver update from Matthew Wilcox.
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Merge issue on character device bring-up
NVMe: Handle ioremap failure
NVMe: Add pci suspend/resume driver callbacks
NVMe: Use normal shutdown
NVMe: Separate controller init from disk discovery
NVMe: Separate queue alloc/free from create/delete
NVMe: Group pci related actions in functions
NVMe: Disk stats for read/write commands only
NVMe: Bring up cdev on set feature failure
NVMe: Fix checkpatch issues
NVMe: Namespace IDs are unsigned
NVMe: Update nvme_id_power_state with latest spec
NVMe: Split header file into user-visible and kernel-visible pieces
NVMe: Call nvme_process_cq from submission path
NVMe: Remove "process_cq did something" message
NVMe: Return correct value from interrupt handler
NVMe: Disk IO statistics
NVMe: Restructure MSI / MSI-X setup
NVMe: Use kzalloc instead of kmalloc+memset
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Nothing major for this kernel, just maintenance updates"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits)
apparmor: add the ability to report a sha1 hash of loaded policy
apparmor: export set of capabilities supported by the apparmor module
apparmor: add the profile introspection file to interface
apparmor: add an optional profile attachment string for profiles
apparmor: add interface files for profiles and namespaces
apparmor: allow setting any profile into the unconfined state
apparmor: make free_profile available outside of policy.c
apparmor: rework namespace free path
apparmor: update how unconfined is handled
apparmor: change how profile replacement update is done
apparmor: convert profile lists to RCU based locking
apparmor: provide base for multiple profiles to be replaced at once
apparmor: add a features/policy dir to interface
apparmor: enable users to query whether apparmor is enabled
apparmor: remove minimum size check for vmalloc()
Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes
Smack: network label match fix
security: smack: add a hash table to quicken smk_find_entry()
security: smack: fix memleak in smk_write_rules_list()
xattr: Constify ->name member of "struct xattr".
If we have multiple sessions on a system, we normally don't want
background sessions to read input events. Otherwise, it could capture
passwords and more entered by the user on the foreground session. This is
a real world problem as the recent XMir development showed:
http://mjg59.dreamwidth.org/27327.html
We currently rely on sessions to release input devices when being
deactivated. This relies on trust across sessions. But that's not given on
usual systems. We therefore need a way to control which processes have
access to input devices.
With VTs the kernel simply routed them through the active /dev/ttyX. This
is not possible with evdev devices, though. Moreover, we want to avoid
routing input-devices through some dispatcher-daemon in userspace (which
would add some latency).
This patch introduces EVIOCREVOKE. If called on an evdev fd, this revokes
device-access irrecoverably for that *single* open-file. Hence, once you
call EVIOCREVOKE on any dup()ed fd, all fds for that open-file will be
rather useless now (but still valid compared to close()!). This allows us
to pass fds directly to session-processes from a trusted source. The
source keeps a dup()ed fd and revokes access once the session-process is
no longer active.
Compared to the EVIOCMUTE proposal, we can avoid the CAP_SYS_ADMIN
restriction now as there is no way to revive the fd again. Hence, a user
is free to call EVIOCREVOKE themself to kill the fd.
Additionally, this ioctl allows multi-layer access-control (again compared
to EVIOCMUTE which was limited to one layer via CAP_SYS_ADMIN). A middle
layer can simply request a new open-file from the layer above and pass it
to the layer below. Now each layer can call EVIOCREVOKE on the fds to
revoke access for all layers below, at the expense of one fd per layer.
There's already ongoing experimental user-space work which demonstrates
how it can be used:
http://lists.freedesktop.org/archives/systemd-devel/2013-August/012897.html
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Pull input updates from Dmitry Torokhov:
"A new driver for slidebar on Ideapad laptops and a bunch of assorted
driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits)
Input: add SYN_MAX and SYN_CNT constants
Input: max11801_ts - convert to devm
Input: egalax-ts - fix typo and improve text
Input: MAINTAINERS - change maintainer for cyttsp driver
Input: cyttsp4 - kill 'defined but not used' compiler warnings
Input: add driver for slidebar on Lenovo IdeaPad laptops
Input: omap-keypad - set up irq type from DT
Input: omap-keypad - enable wakeup capability for keypad.
Input: omap-keypad - clear interrupts on open
Input: omap-keypad - convert to threaded IRQ
Input: omap-keypad - use bitfiled instead of hardcoded values
Input: cyttsp4 - remove useless NULL test from cyttsp4_watchdog_timer()
Input: wacom - fix error return code in wacom_probe()
Input: as5011 - fix error return code in as5011_probe()
Input: keyboard, serio - simplify use of devm_ioremap_resource
Input: tegra-kbc - simplify use of devm_ioremap_resource
Input: htcpen - fix incorrect placement of __initdata
Input: qt1070 - add power management ops
Input: wistron_btns - add MODULE_DEVICE_TABLE
Input: wistron_btns - mark the Medion MD96500 keymap as tested
This reverts commits 61e00655e9cb, 73f8645db191 and 8e22ecb603c8:
"Input: introduce BTN/ABS bits for drums and guitars"
"HID: wiimote: add support for Guitar-Hero drums"
"HID: wiimote: add support for Guitar-Hero guitars"
The extra new ABS_xx values resulted in ABS_MAX no longer being a
power-of-two, which broke the comparison logic. It also caused the
ioctl numbers to overflow into the next byte, causing problems for that.
We'll try again for 3.13.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Pull Tile arch updates from Chris Metcalf:
"These changes bring in a bunch of new functionality that has been
maintained internally at Tilera over the last year, plus other stray
bits of work that I've taken into the tile tree from other folks.
The changes include some PCI root complex work, interrupt-driven
console support, support for performing fast-path unaligned data
fixups by kernel-based JIT code generation, CONFIG_PREEMPT support,
vDSO support for gettimeofday(), a serial driver for the tilegx
on-chip UART, KGDB support, more optimized string routines, support
for ftrace and kprobes, improved ASLR, and many bug fixes.
We also remove support for the old TILE64 chip, which is no longer
buildable"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits)
tile: refresh tile defconfig files
tile: rework <asm/cmpxchg.h>
tile PCI RC: make default consistent DMA mask 32-bit
tile: add null check for kzalloc in tile/kernel/setup.c
tile: make __write_once a synonym for __read_mostly
tile: remove support for TILE64
tile: use asm-generic/bitops/builtin-*.h
tile: eliminate no-op "noatomichash" boot argument
tile: use standard tile_bundle_bits type in traps.c
tile: simplify code referencing hypervisor API addresses
tile: change <asm/system.h> to <asm/switch_to.h> in comments
tile: mark pcibios_init() as __init
tile: check for correct compiler earlier in asm-offsets.c
tile: use standard 'generic-y' model for <asm/hw_irq.h>
tile: use asm-generic version of <asm/local64.h>
tile PCI RC: add comment about "PCI hole" problem
tile: remove DEBUG_EXTRA_FLAGS kernel config option
tile: add virt_to_kpte() API and clean up and document behavior
tile: support FRAME_POINTER
tile: support reporting Tilera hypervisor statistics
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull ARM64 update from Catalin Marinas:
- User tagged pointers support (top 8-bit of user pointers
automatically ignored by the CPU).
- Kernel mode NEON (no users for arm64 yet but work in progress).
- arm64 kernel Image header extended to accommodate future EFI stub.
- Remove BogoMIPS reporting (not relevant, it's just the timer
frequency).
- Clean-up (EM_AARCH64/EM_ARM to elf-em.h, ELF notes in read-only
segment, unused variable).
- Bug-fixes (RAM boundaries not 2MB aligned, perf, includes).
* tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
Documentation/arm64: clarify requirements for DTB placement
arm64: mm: permit use of tagged pointers at EL0
Move the EM_ARM and EM_AARCH64 definitions to uapi/linux/elf-em.h
arm64: Remove unused cpu_name ascii in arch/arm64/mm/proc.S
arm64: delay: don't bother reporting bogomips in /proc/cpuinfo
arm64: Fix mapping of memory banks not ending on a PMD_SIZE boundary
arm64: move elf notes into readonly segment
arm64: Enable interrupts in the EL0 undef handler
arm64: Expand arm64 image header
ARM64: include: asm: include "asm/types.h" in "pgtable-2level-types.h" and "pgtable-3level-types.h"
arm64: add support for kernel mode NEON
arm64: perf: fix ARMv8 EVTYPE_MASK to include NSH bit
arm64: perf: fix group validation when using enable_on_exec
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
"Highlights:
- conversion of HID subsystem to use devm-based resource management,
from Benjamin Tissoires
- i2c-hid support for DT bindings, from Benjamin Tissoires
- much improved support for Win8-multitouch devices, from Benjamin
Tissoires
- cleanup of core code using common hidinput_input_event(), from
David Herrmann
- fix for bug in implement() access to the bit stream (causing oops)
that has been present in the code for ages, but devices that are
able to trigger it have started to appear only now, from Jiri
Kosina
- fixes for CVE-2013-2899, CVE-2013-2898, CVE-2013-2896,
CVE-2013-2892, CVE-2013-2888 (all triggerable only by specially
crafted malicious HW devices plugged into the system), from Kees
Cook
- hidraw oops fix, from Manoj Chourasia
- various smaller fixes here and there, support for a bunch of new
devices by various contributors"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (53 commits)
HID: MAINTAINERS: add roccat drivers
HID: hid-sensor-hub: change kmalloc + memcpy by kmemdup
HID: hid-sensor-hub: move to devm_kzalloc
HID: hid-sensor-hub: fix indentation accross the code
HID: move HID_REPORT_TYPES closer to the report-definitions
HID: check for NULL field when setting values
HID: picolcd_core: validate output report details
HID: sensor-hub: validate feature report details
HID: ntrig: validate feature report details
HID: pantherlord: validate output report details
HID: hid-wiimote: print small buffers via %*phC
HID: uhid: improve uhid example client
HID: Correct the USB IDs for the new Macbook Air 6
HID: battery: don't do DMA from stack
HID: roccat: add support for KonePureOptical v2
HID: picolcd: Prevent NULL pointer dereference on _remove()
HID: usbhid: quirk for N-Trig DuoSense Touch Screen
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
Support the collection of I/O statistics on user-defined regions of
a DM device. If no regions are defined no statistics are collected so
there isn't any performance impact. Only bio-based DM devices are
currently supported.
Each user-defined region specifies a starting sector, length and step.
Individual statistics will be collected for each step-sized area within
the range specified.
The I/O statistics counters for each step-sized area of a region are
in the same format as /sys/block/*/stat or /proc/diskstats but extra
counters (12 and 13) are provided: total time spent reading and
writing in milliseconds. All these counters may be accessed by sending
the @stats_print message to the appropriate DM device via dmsetup.
The creation of DM statistics will allocate memory via kmalloc or
fallback to using vmalloc space. At most, 1/4 of the overall system
memory may be allocated by DM statistics. The admin can see how much
memory is used by reading
/sys/module/dm_mod/parameters/stats_current_allocated_bytes
See Documentation/device-mapper/statistics.txt for more details.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Pull networking changes from David Miller:
"Noteworthy changes this time around:
1) Multicast rejoin support for team driver, from Jiri Pirko.
2) Centralize and simplify TCP RTT measurement handling in order to
reduce the impact of bad RTO seeding from SYN/ACKs. Also, when
both timestamps and local RTT measurements are available prefer
the later because there are broken middleware devices which
scramble the timestamp.
From Yuchung Cheng.
3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel
memory consumed to queue up unsend user data. From Eric Dumazet.
4) Add a "physical port ID" abstraction for network devices, from
Jiri Pirko.
5) Add a "suppress" operation to influence fib_rules lookups, from
Stefan Tomanek.
6) Add a networking development FAQ, from Paul Gortmaker.
7) Extend the information provided by tcp_probe and add ipv6 support,
from Daniel Borkmann.
8) Use RCU locking more extensively in openvswitch data paths, from
Pravin B Shelar.
9) Add SCTP support to openvswitch, from Joe Stringer.
10) Add EF10 chip support to SFC driver, from Ben Hutchings.
11) Add new SYNPROXY netfilter target, from Patrick McHardy.
12) Compute a rate approximation for sending in TCP sockets, and use
this to more intelligently coalesce TSO frames. Furthermore, add
a new packet scheduler which takes advantage of this estimate when
available. From Eric Dumazet.
13) Allow AF_PACKET fanouts with random selection, from Daniel
Borkmann.
14) Add ipv6 support to vxlan driver, from Cong Wang"
Resolved conflicts as per discussion.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits)
openvswitch: Fix alignment of struct sw_flow_key.
netfilter: Fix build errors with xt_socket.c
tcp: Add missing braces to do_tcp_setsockopt
caif: Add missing braces to multiline if in cfctrl_linkup_request
bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize
vxlan: Fix kernel panic on device delete.
net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls
net: mvneta: properly disable HW PHY polling and ensure adjust_link() works
icplus: Use netif_running to determine device state
ethernet/arc/arc_emac: Fix huge delays in large file copies
tuntap: orphan frags before trying to set tx timestamp
tuntap: purge socket error queue on detach
qlcnic: use standard NAPI weights
ipv6:introduce function to find route for redirect
bnx2x: VF RSS support - VF side
bnx2x: VF RSS support - PF side
vxlan: Notify drivers for listening UDP port changes
net: usbnet: update addr_assign_type if appropriate
driver/net: enic: update enic maintainers and driver
driver/net: enic: Exposing symbols for Cisco's low latency driver
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
net/bridge/br_multicast.c
net/ipv6/sit.c
The conflicts were minor:
1) sit.c changes overlap with change to ip_tunnel_xmit() signature.
2) br_multicast.c had an overlap between computing max_delay using
msecs_to_jiffies and turning MLDV2_MRC() into an inline function
with a name using lowercase instead of uppercase letters.
3) stmmac had two overlapping changes, one which conditionally allocated
and hooked up a dma_cfg based upon the presence of the pbl OF property,
and another one handling store-and-forward DMA made. The latter of
which should not go into the new of_find_property() basic block.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"This series contains:
- Exynos s5p-mfc driver got support for VP8 encoder
- Some SoC drivers gained support for asynchronous registration
(needed for DT)
- The RC subsystem gained support for RC activity LED;
- New drivers added: a video decoder(adv7842), a video encoder
(adv7511), a new GSPCA driver (stk1135) and support for Renesas
R-Car (vsp1)
- the first SDR kernel driver: mirics msi3101. Due to some troubles
with the driver, and because the API is still under discussion, it
will be merged at staging for 3.12. Need to rework on it
- usual new boards additions, fixes, cleanups and driver
improvements"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (242 commits)
[media] cx88: Fix regression: CX88_AUDIO_WM8775 can't be 0
[media] exynos4-is: Fix entity unregistration on error path
[media] exynos-gsc: Register v4l2 device
[media] exynos4-is: Fix fimc-lite bayer formats
[media] em28xx: fix assignment of the eeprom data
[media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe()
[media] usbtv: Throw corrupted frames away
[media] usbtv: Fix deinterlacing
[media] v4l2: added missing mutex.h include to v4l2-ctrls.h
[media] DocBook: upgrade media_api DocBook version to 4.2
[media] ml86v7667: fix compile warning: 'ret' set but not used
[media] s5p-g2d: Fix registration failure
[media] media: coda: Fix DT driver data pointer for i.MX27
[media] s5p-mfc: Fix input/output format reporting
[media] v4l: vsp1: Fix mutex double lock at streamon time
[media] v4l: vsp1: Add support for RT clock
[media] v4l: vsp1: Initialize media device bus_info field
[media] davinci: vpif_capture: fix error return code in vpif_probe()
[media] davinci: vpif_display: fix error return code in vpif_probe()
[media] MAINTAINERS: add entries for adv7511 and adv7842
Pull KVM updates from Gleb Natapov:
"The highlights of the release are nested EPT and pv-ticketlocks
support (hypervisor part, guest part, which is most of the code, goes
through tip tree). Apart of that there are many fixes for all arches"
Fix up semantic conflicts as discussed in the pull request thread..
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits)
ARM: KVM: Add newlines to panic strings
ARM: KVM: Work around older compiler bug
ARM: KVM: Simplify tracepoint text
ARM: KVM: Fix kvm_set_pte assignment
ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256
ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs
ARM: KVM: vgic: fix GICD_ICFGRn access
ARM: KVM: vgic: simplify vgic_get_target_reg
KVM: MMU: remove unused parameter
KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate()
KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls
KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX
KVM: x86: update masterclock when kvmclock_offset is calculated (v2)
KVM: PPC: Book3S: Fix compile error in XICS emulation
KVM: PPC: Book3S PR: return appropriate error when allocation fails
arch: powerpc: kvm: add signed type cast for comparation
KVM: x86: add comments where MMIO does not return to the emulator
KVM: vmx: count exits to userspace during invalid guest emulation
KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp
kvm: optimize away THP checks in kvm_is_mmio_pfn()
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"New features for 3.12:
- Added aggressive extent caching using the extent status tree. This
can actually decrease memory usage in read-mostly workloads since
the information is much more compactly stored in the extent status
tree than if we had to keep the extent tree metadata blocks in the
buffer cache. This also improves Asynchronous I/O since it is it
makes much less likely that we need to do metadata I/O to lookup
the extent tree information.
- Improve the recovery after corrupted allocation bitmaps are found
when running in errors=ignore mode.
Also fixed some writeback vs truncate races when using a blocksize
less than the page size"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (25 commits)
ext4: allow specifying external journal by pathname mount option
ext4: mark group corrupt on group descriptor checksum
ext4: mark block group as corrupt on inode bitmap error
ext4: mark block group as corrupt on block bitmap error
ext4: fix type declaration of ext4_validate_block_bitmap
ext4: error out if verifying the block bitmap fails
jbd2: Fix endian mixing problems in the checksumming code
ext4: isolate ext4_extents.h file
ext4: Fix misspellings using 'codespell' tool
ext4: convert write_begin methods to stable_page_writes semantics
ext4: fix use of potentially uninitialized variables in debugging code
ext4: fix lost truncate due to race with writeback
ext4: simplify truncation code in ext4_setattr()
ext4: fix ext4_writepages() in presence of truncate
ext4: move test whether extent to map can be extended to one place
ext4: fix warning in ext4_da_update_reserve_space()
quota: provide interface for readding allocated space into reserved space
ext4: avoid reusing recently deleted inodes in no journal mode
ext4: allocate delayed allocation blocks before rename
ext4: start handle at least possible moment when renaming files
Pull x86 spinlock changes from Ingo Molnar:
"The biggest change here are paravirtualized ticket spinlocks (PV
spinlocks), which bring a nice speedup on various benchmarks.
The KVM host side will come to you via the KVM tree"
* 'x86-spinlocks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/kvm/guest: Fix sparse warning: "symbol 'klock_waiting' was not declared as static"
kvm: Paravirtual ticketlocks support for linux guests running on KVM hypervisor
kvm guest: Add configuration support to enable debug information for KVM Guests
kvm uapi: Add KICK_CPU and PV_UNHALT definition to uapi
xen, pvticketlock: Allow interrupts to be enabled while blocking
x86, ticketlock: Add slowpath logic
jump_label: Split jumplabel ratelimit
x86, pvticketlock: When paravirtualizing ticket locks, increment by 2
x86, pvticketlock: Use callee-save for lock_spinning
xen, pvticketlocks: Add xen_nopvspin parameter to disable xen pv ticketlocks
xen, pvticketlock: Xen implementation for PV ticket locks
xen: Defer spinlock setup until boot CPU setup
x86, ticketlock: Collapse a layer of functions
x86, ticketlock: Don't inline _spin_unlock when using paravirt spinlocks
x86, spinlock: Replace pv spinlocks with pv ticketlocks
The current VFIO_DEVICE_RESET interface only maps to PCI use cases
where we can isolate the reset to the individual PCI function. This
means the device must support FLR (PCIe or AF), PM reset on D3hot->D0
transition, device specific reset, or be a singleton device on a bus
for a secondary bus reset. FLR does not have widespread support,
PM reset is not very reliable, and bus topology is dictated by the
system and device design. We need to provide a means for a user to
induce a bus reset in cases where the existing mechanisms are not
available or not reliable.
This device specific extension to VFIO provides the user with this
ability. Two new ioctls are introduced:
- VFIO_DEVICE_PCI_GET_HOT_RESET_INFO
- VFIO_DEVICE_PCI_HOT_RESET
The first provides the user with information about the extent of
devices affected by a hot reset. This is essentially a list of
devices and the IOMMU groups they belong to. The user may then
initiate a hot reset by calling the second ioctl. We must be
careful that the user has ownership of all the affected devices
found via the first ioctl, so the second ioctl takes a list of file
descriptors for the VFIO groups affected by the reset. Each group
must have IOMMU protection established for the ioctl to succeed.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Solution:
- Synchronize linux's `include/uapi/linux/in6.h'
with glibc's `inet/netinet/in.h'.
- Synchronize glibc's `inet/netinet/in.h with linux's
`include/uapi/linux/in6.h'.
- Allow including the headers in either other.
- First header included defines the structures and macros.
Details:
The kernel promises not to break the UAPI ABI so I don't
see why we can't just have the two userspace headers
coordinate?
If you include the kernel headers first you get those,
and if you include the glibc headers first you get those,
and the following patch arranges a coordination and
synchronization between the two.
Let's handle `include/uapi/linux/in6.h' from linux,
and `inet/netinet/in.h' from glibc and ensure they compile
in any order and preserve the required ABI.
These two patches pass the following compile tests:
cat >> test1.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test1.c
cat >> test2.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test2.c
One wrinkle is that the kernel has a different name for one of
the members in ipv6_mreq. In the kernel patch we create a macro
to cover the uses of the old name, and while that's not entirely
clean it's one of the best solutions (aside from an anonymous
union which has other issues).
I've reviewed the code and it looks to me like the ABI is
assured and everything matches on both sides.
Notes:
- You want netinet/in.h to include bits/in.h as early as possible,
but it needs in_addr so define in_addr early.
- You want bits/in.h included as early as possible so you can use
the linux specific code to define __USE_KERNEL_DEFS based on
the _UAPI_* macro definition and use those to cull in.h.
- glibc was missing IPPROTO_MH, added here.
Compile tested and inspected.
Reported-by: Thomas Backlund <tmb@mageia.org>
Cc: Thomas Backlund <tmb@mageia.org>
Cc: libc-alpha@sourceware.org
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Tested-by: Cong Wang <amwang@redhat.com>
Signed-off-by: Carlos O'Donell <carlos@redhat.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Pull perf changes from Ingo Molnar:
"As a first remark I'd like to point out that the obsolete '-f'
(--force) option, which has not done anything for several releases,
has been removed from 'perf record' and related utilities. Everyone
please update muscle memory accordingly! :-)
Main changes on the perf kernel side:
- Performance optimizations:
. for trace events, by Steve Rostedt.
. for time values, by Peter Zijlstra
- New hardware support:
. for Intel Silvermont (22nm Atom) CPUs, by Zheng Yan
. for Intel SNB-EP uncore PMUs, by Zheng Yan
- Enhanced hardware support:
. for Intel uncore PMUs: add filter support for QPI boxes, by Zheng Yan
- Core perf events code enhancements and fixes:
. for full-nohz feature handling, by Frederic Weisbecker
. for group events, by Jiri Olsa
. for call chains, by Frederic Weisbecker
. for event stream parsing, by Adrian Hunter
- New ABI details:
. Add attr->mmap2 attribute, by Stephane Eranian
. Add PERF_EVENT_IOC_ID ioctl to return event ID, by Jiri Olsa
. Export u64 time_zero on the mmap header page to allow TSC
calculation, by Adrian Hunter
. Add dummy software event, by Adrian Hunter.
. Add a new PERF_SAMPLE_IDENTIFIER to make samples always
parseable, by Adrian Hunter.
. Make Power7 events available via sysfs, by Runzhen Wang.
- Code cleanups and refactorings:
. for nohz-full, by Frederic Weisbecker
- Documentation updates:
. for perf_event_type, by Peter Zijlstra
Main changes on the perf tooling side (some of these tooling changes
utilize the above kernel side changes):
- Lots of 'perf trace' enhancements:
. Make 'perf trace' command line arguments consistent with
'perf record', by David Ahern.
. Allow specifying syscalls a la strace, by Arnaldo Carvalho de Melo.
. Add --verbose and -o/--output options, by Arnaldo Carvalho de Melo.
. Support ! in -e expressions, to filter a list of syscalls,
. Arg formatting improvements to allow masking arguments in
syscalls such as futex and open, where the some arguments are
ignored and thus should not be printed depending on other args,
. Beautify futex open, openat, open_by_handle_at, lseek and futex
syscalls, by Arnaldo Carvalho de Melo.
. Add option to analyze events in a file versus live, so that
one can do:
[root@zoo ~]# perf record -a -e raw_syscalls:* sleep 1
[ perf record: Woken up 0 times to write data ]
[ perf record: Captured and wrote 25.150 MB perf.data (~1098836 samples) ]
[root@zoo ~]# perf trace -i perf.data -e futex --duration 1
17.799 ( 1.020 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, ua
113.344 (95.429 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 4294967
133.778 ( 1.042 ms): 18004 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 429496
[root@zoo ~]#
By David Ahern.
. Honor target pid / tid options when analyzing a file, by David Ahern.
. Introduce better formatting of syscall arguments, including so
far beautifiers for mmap, madvise, syscall return values,
. Handle HUGEPAGE defines in the mmap beautifier, by David Ahern.
- 'perf report/top' enhancements:
. Do annotation using /proc/kcore and /proc/kallsyms when
available, removing the forced need for a vmlinux file kernel
assembly annotation. This also improves this use case because
vmlinux has just the initial kernel image, not what is actually
in use after various code patchings by things like alternatives.
By Adrian Hunter.
. Add --ignore-callees=<regex> option to collapse undesired parts
of call graphs, by Greg Price.
. Simplify symbol filtering by doing it at machine class level,
by Adrian Hunter.
. Add support for callchains in the gtk UI, by Namhyung Kim.
. Add --objdump option to 'perf top', by Sukadev Bhattiprolu.
- 'perf kvm' enhancements:
. Add option to print only events that exceed a specified time
duration, by David Ahern.
. Improve stack trace printing, by David Ahern.
. Update documentation of the live command, by David Ahern
. Add perf kvm stat live mode that combines aspects of 'perf kvm
stat' record and report, by David Ahern.
. Add option to analyze specific VM in perf kvm stat report, by
David Ahern.
. Do not require /lib/modules/* on a guest, by Jason Wessel.
- 'perf script' enhancements:
. Fix symbol offset computation for some dsos, by David Ahern.
. Fix named threads support, by David Ahern.
. Don't install scripting files files when perl/python support
is disabled, by Arnaldo Carvalho de Melo.
- 'perf test' enhancements:
. Add various improvements and fixes to the "vmlinux matches
kallsyms" 'perf test' entry, related to the /proc/kcore
annotation feature. By Adrian Hunter.
. Add sample parsing test, by Adrian Hunter.
. Add test for reading object code, by Adrian Hunter.
. Add attr record group sampling test, by Jiri Olsa.
. Misc testing infrastructure improvements and other details,
by Jiri Olsa.
- 'perf list' enhancements:
. Skip unsupported hardware events, by Namhyung Kim.
. List pmu events, by Andi Kleen.
- 'perf diff' enhancements:
. Add support for more than two files comparison, by Jiri Olsa.
- 'perf sched' enhancements:
. Various improvements, including removing reliance on some
scheduler tracepoints that provide the same information as the
PERF_RECORD_{FORK,EXIT} events. By David Ahern.
. Remove odd build stall by moving a large struct initialization
from a local variable to a global one, by Namhyung Kim.
- 'perf stat' enhancements:
. Add --initial-delay option to skip measuring for a defined
startup phase, by Andi Kleen.
- Generic perf tooling infrastructure/plumbing changes:
. Tidy up sample parsing validation, by Adrian Hunter.
. Fix up jobserver setup in libtraceevent Makefile.
. Debug improvements, by Adrian Hunter.
. Fix correlation of samples coming after PERF_RECORD_EXIT event,
by David Ahern.
. Improve robustness of the topology parsing code,
by Stephane Eranian.
. Add group leader sampling, that allows just one event in a group
to sample while the other events have just its values read,
by Jiri Olsa.
. Add support for a new modifier "D", which requests that the
event, or group of events, be pinned to the PMU.
By Michael Ellerman.
. Support callchain sorting based on addresses, by Andi Kleen
. Prep work for multi perf data file storage, by Jiri Olsa.
. libtraceevent cleanups, by Namhyung Kim.
And lots and lots of other fixes and code reorganizations that did not
make it into the list, see the shortlog, diffstat and the Git log for
details!"
[ Also merge a leftover from the 3.11 cycle ]
perf: Prevent race in unthrottling code
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (237 commits)
perf trace: Tell arg formatters the arg index
perf trace: Add beautifier for open's flags arg
perf trace: Add beautifier for lseek's whence arg
perf tools: Fix symbol offset computation for some dsos
perf list: Skip unsupported events
perf tests: Add 'keep tracking' test
perf tools: Add support for PERF_COUNT_SW_DUMMY
perf: Add a dummy software event to keep tracking
perf trace: Add beautifier for futex 'operation' parm
perf trace: Allow syscall arg formatters to mask args
perf: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node()
perf: Export struct perf_branch_entry to userspace
perf: Add attr->mmap2 attribute to an event
perf/x86: Add Silvermont (22nm Atom) support
perf/x86: use INTEL_UEVENT_EXTRA_REG to define MSR_OFFCORE_RSP_X
perf trace: Handle missing HUGEPAGE defines
perf trace: Honor target pid / tid options when analyzing a file
perf trace: Add option to analyze events in a file versus live
perf evlist: Add tracepoint lookup by name
perf tests: Add a sample parsing test
There are a bunch of guitar and drums devices out there that all report
similar data. To avoid reporting this as BTN_MISC or ABS_MISC, we
allocate some proper namespace for them. Note that most of these devices
are toys and we cannot report any sophisticated physics via this API.
I did some google-images research and tried to provide definitions that
work with all common devices. That's why I went with 4 toms, 4 cymbals,
one bass, one hi-hat. I haven't seen other drums and I doubt that we need
any additions to that. Anyway, the naming-scheme is intentionally done in
an extensible way.
For guitars, we support 5 frets (normally aligned vertically, compared to
the real horizontal layouts), a single strum-bar with up/down directions,
an optional fret-board and a whammy-bar.
Most of the devices provide pressure values so I went with ABS_* bits. If
we ever support devices which only provide digital input, we have to
decide whether to emulate pressure data or add additional BTN_* bits.
If someone is not familiar with these devices, here are two pictures which
provide almost all introduced interfaces (or try the given keywords
with a google-image search):
Guitar: ("guitar hero world tour guitar")
http://images1.wikia.nocookie.net/__cb20120911023442/applezone/es/images/f/f9/Wii_Guitar.jpg
Drums: ("guitar hero drums")
http://oyster.ignimgs.com/franchises/images/03/55/35526_band-hero-drum-set-hands-on-20090929040735768.jpg
RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination
unreachable) messages:
5 - Source address failed ingress/egress policy
6 - Reject route to destination
Now they are treated as protocol error and icmpv6_err_convert() converts them
to EPROTO.
RFC 4443 says:
"Codes 5 and 6 are more informative subsets of code 1."
Treat codes 5 and 6 as code 1 (EACCES)
Btw, connect() returning -EPROTO confuses firefox, so that fallback to
other/IPv4 addresses does not work:
https://bugzilla.mozilla.org/show_bug.cgi?id=910773
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
