path: root/include/sound/ymfpci.h
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-09[ALSA] Current driver does not utilize 44.1kHz high quality sampling rate ↵Teru KAMOGASHIRA
converter. Following patch will make the driver to use the 44.1kHz SRC automatically if the pcm source is 44.1kHz signed 16bit stereo. The SRC is available in YMF754 only. Signed-off-by: Teru KAMOGASHIRA <teru@sodan.ecc.u-tokyo.ac.jp> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ymfpci: add request_firmware()Clemens Ladisch
Load the DSP and controller microcode using request_firmware(), if possible, instead of using the built-in firmware. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Fix invalid assignment of PCI revisionTakashi Iwai
Fix the type of PCI revision to char from int and avoid invalid assignment with pointer cast. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] ymfpci: fix swap_rear for S/PDIF passthroughGlen Masgai
This patch fixes incorrect assignment of swap_rear, which was broken since patch 'ymfpci - make rear channel swap optional' It removes module_param rear_swap. Signed-off-by: Glen Masgai <mimosius@gmx.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] ymfpci - make rear channel swap optionalJaroslav Kysela
Modules: YMFPCI driver Added rear_swap module option / kernel parameter to configure the rear channel swapping. Default value is enable to make the AC3 passthrough working, but analog only users might revert the previous behaviour. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-03[ALSA] ymfpci - Fix PM supportTakashi Iwai
Modules: YMFPCI driver Fix PM support on YMFPCI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI YMFPCITakashi Iwai
Modules: YMFPCI driver Remove xxx_t typedefs from the PCI YMFPCI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] ymfpci: add per-voice volume controlsClemens Ladisch
YMFPCI driver Implements mixer controls for the volume of each playback substream of the main PCM device. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
