path: root/include/sound/soc.h
2011-03-08ASoC: Fix prefixing of DAPM controls by factoring prefix into snd_soc_cnew()Mark Brown
Currently will ignore prefixes when creating DAPM controls. Since currently all control creation goes through snd_soc_cnew() we can fix this by factoring the prefixing into that function. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-03-08ASoC: Provide CODEC clocking operations and API callsMark Brown
When multi component systems use DAIless amplifiers which require clocking configuration it is at best hard to use the current clocking API as this requires a DAI even though the device may not even have one. Address this by adding set_sysclk() and set_pll() operations and APIs for CODECs. In order to avoid issues with devices which could be used either with or without DAIs make the DAI variants call through to their CODEC counterparts if there is no DAI specific operation. Converting over entirely would create problems for multi-DAI devices which offer per-DAI clocking setup. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-03-08ASoC: Add DAPM widget and path data to CODEC driver structureMark Brown
Allow a slight simplification of CODEC drivers by allowing DAPM routes and widgets to be provided in a table. They will be instantiated at the end of CODEC probe. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-03-03ASoC: Add a late_probe() callback to cardsMark Brown
This is run after the DAPM widgets and routes are added, allowing setup of things like jacks using the routes. The main card probe() is run before anything else so can't be used for this purpose. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-03ASoC: Allow card DAPM widgets and routes to be set up at registrationMark Brown
These will be added after all devices are registered and allow most DAI init functions in machine drivers to be replaced by simple data. Regular controls are not supported as the registration function still works in terms of CODECs. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-03ASoC: Add a per-card DAPM contextMark Brown
This means that rather than adding the board specific DAPM widgets to a random CODEC DAPM context they can be added to the card itself which is a bit cleaner. Previously there only was one DAPM context and it was tied to the single supported CODEC. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-18ASoC: Add kerneldoc for jack_status_check callbackMark Brown
2011-02-18ASoC: Allow GPIO jack detection to be configured as a wake sourceMark Brown
Some systems wish to use jacks as wake sources. Provide a wake flag in the GPIO configuration which causes the driver to enable the IRQ as a wake source. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-09ASoC: add support for multiple jack typesVinod Koul
This patch adds soc-jack support for adding voltage zones and for detecting jack type Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Harsha Priya <priya.harsha@intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-28ASoC: Add card driver dataMark Brown
Provide driver data for cards within the card structure. To simplify the implementation of the PM operations we don't use the struct device driver data as this is used by the core to retrieve the card in callbacks from the device model and PM core. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27ASoC: Add subsequence information to seq_notify callbacksMark Brown
Allows drivers to distinguish which subsequence is being notified when they get called back. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27ASoC: Make cache status available via debugfsMark Brown
Could just as well live in sysfs but sysfs doesn't have the simple value export helpers debugfs does. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27ASoC: Export card PM callbacks for use in direct registered cardsMark Brown
Allow hookup of cards registered directly with the core to the PM operations by exporting the device power management operations to modules, also exporting the default PM operations since it is expected that most cards will end up using exactly the same setup. Note that the callbacks require that the driver data for the card be the snd_soc_card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27ASoC: Replace pdev with card in machine driver probe and removeMark Brown
In order to support cards instantiated without using soc-audio remove the use of the platform device in the card probe() and remove() ops. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27ASoC: Use card rather than soc-audio device to card PM functionsMark Brown
The platform device for the card is tied closely to the soc-audio implementation which we're currently trying to remove in favour of allowing cards to have their own devices. Begin removing it by replacing it with the card in the suspend and resume callbacks we give to cards, also taking the opportunity to remove the legacy suspend types which are currently hard coded anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-25ASoC: Fix type for snd_soc_volatile_register()Mark Brown
We generally refer to registers as unsigned ints (including in the underlying CODEC driver operation). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-20ASoC: soc-cache: Introduce the cache_bypass optionDimitris Papastamos
This is primarily needed to avoid writing back to the cache whenever we are syncing the cache with the hardware. This gives a performance benefit especially for large register maps. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-19ASoC: Provide per widget type callback when executing DAPM sequencesMark Brown
Many modern devices have features such as DC servos which take time to start. Currently these are handled by per-widget events but this makes it difficult to paralleise operations on multiple widgets, meaning delays can end up being needlessly serialised. By providing a callback to drivers when all widgets of a given type have been handled during a DAPM sequence the core allows drivers to start operations separately and wait for them to complete much more simply. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-17ASoC: soc core allow machine driver to register the cardVinod Koul
The machine driver can't register the card directly and need to do this thru soc-audio device creation This patch allows the register and unregister card to be directly called by machine drivers Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Harsha Priya <priya.harsha@intel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-13ASoC: soc core add inline to handle card list initialzationVinod Koul
Currently the soc_probe initializes the card hence it does the card list initialzation. But if machines directly register the card they would need to do these steps, so putting them as inline would save lot of code This patch adds an inline to do list initialzation Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Harsha Priya <harsha.priya@intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-13ASoC: Automatically assign the default readable()/volatile() functionsDimitris Papastamos
Ensure that all calls to readable_register()/volatile_register() go via the snd_soc_codec function pointers. If the default register access table has been given but no functions for handling readable()/volatile() registers, use the default ones provided by soc-cache. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-13ASoC: Update users of readable_register()/volatile_register()Dimitris Papastamos
2011-01-13ASoC: soc-cache: Add support for default readable()/volatile() functionsDimitris Papastamos
For common scenarios, device drivers can provide a table of all the registers that are at least either readable/writable/volatile. The idea is that if a register lookup fails, all of its read/write/vol members will be zero and will be treated as default. This also reduces the size of the register access array. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-12ASoC: soc-cache: Add reg_size as a member to snd_soc_codecDimitris Papastamos
Simplify the use of reg_size, by calculating it once and storing it in the codec structure for later reference. The value of reg_size is reg_cache_size * reg_word_size. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-10ASoC: Update name of debugfs root symbol to snd_soc_Mark Brown
Everything else is using snd_soc_ so we should use it here too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-10ASoC: Export debugfs root dentryStephen Warren
A couple Tegra ASoC drivers will create debugfs entries. Mark requested these by under debugfs/asoc/ not just debugfs/. To enable this, export the dentry representing debugfs/asoc/. Also, rename debugfs_root -> asoc_debugfs_root now it's exported to prevent potential symbol name clashes. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-15ASoC: Extend DAPM to handle power changes on cross-device pathsJarkko Nikula
Power change event like stream start/stop or kcontrol change in a cross-device path originates from one device but codec bias and widget power changes must be populated to another devices on that path as well. This patch modifies the dapm_power_widgets so that all the widgets on a sound card are checked for a power change, not just those that are specific to originating device. Also bias management is extended to check all the devices. Only exception in bias management are widgetless codecs whose bias state is changed only if power change is originating from that context. DAPM context test is added to dapm_seq_run to take care of if power sequence extends to an another device which requires separate register writes. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-15ASoC: Move widgets from DAPM context to snd_soc_cardJarkko Nikula
Decoupling widgets from DAPM context is required when extending the ASoC core to cross-device paths. Even the list of widgets are now kept in struct snd_soc_card, the widget listing in sysfs and debugs remain sorted per device. This patch makes possible to build cross-device paths but does not extend yet the DAPM to handle codec bias and widget power changes of an another device. Cross-device paths are registered by listing the widgets from device A in a map for device B. In case of conflicting widget names between the devices, a uniform name prefix is needed to separate them. See commit ead9b91 "ASoC: Add optional name_prefix for kcontrol, widget and route names" for help. An example below shows a path that connects MONO out of A into Line In of B: static const struct snd_soc_dapm_route mapA[] = { {"MONO", NULL, "DAC"}, }; static const struct snd_soc_dapm_route mapB[] = { {"Line In", NULL, "MONO"}, }; Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-15ASoC: Move DAPM paths from DAPM context to snd_soc_cardJarkko Nikula
Decoupling DAPM paths from DAPM context is a first prerequisite when extending ASoC core to cross-device paths. This patch is almost a nullop and does not allow to construct cross-device setup but the path clean-up part in dapm_free_widgets is prepared to remove cross-device paths between a device being removed and others. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-09ASoC: Remove unnecessary structure definitionsSeungwhan Youn
This patch removes some legacy structure definitions which are not using in current ASoC drivers. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: soc-cache: Add optional cache name member to snd_soc_cache_opsDimitris Papastamos
Added an optional name member to snd_soc_cache_ops to enable more sensible diagnostic messages during cache init, exit and sync. Remove redundant newline in source code. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: Add post-CODEC bias level callback for machine driverMark Brown
Currently the machine driver can only do bias level configuration before the CODEC bias level is brought up. This means that the machine cannot do any configuration which depends on the CODEC bias level being maintained. Provide a post-CODEC callback which allows the machine driver to do things like enable the FLL on a CODEC which is brought down to BIAS_OFF when idle. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-03ASoC: Constify struct snd_soc_codec_driverMark Brown
Allow the CODEC driver structure to be marked const by making all the APIs that use it do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-03ASoC: soc-core: Allow machine drivers to override compress_typeDimitris Papastamos
This patch allows machine drivers to override the compression type provided by the codec driver. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-03ASoC: soc-cache: Use reg_def_copy instead of reg_cache_defaultDimitris Papastamos
Make sure to use codec->reg_def_copy instead of codec_drv->reg_cache_default wherever necessary. This change is necessary because in the next patch we move the cache initialization code outside snd_soc_register_codec() and by that time any data marked as __devinitconst such as the original reg_cache_default array might have already been freed by the kernel. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-03ASoC: soc-core: Generalize snd_soc_prefix_map and rename to snd_soc_codec_confDimitris Papastamos
The snd_soc_codec_conf struct now holds codec specific configuration information. A new configuration option has been added to allow machine drivers to override the compression type set by the codec driver. In the absence of providing an snd_soc_codec_conf struct or when providing one but not setting the compress_type member to anything, the one supplied by the codec driver will be used instead. In all other cases the one set in the snd_soc_codec_conf struct takes effect. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-03ASoC: Change the base value of compress_typeDimitris Papastamos
Ensure that the base value of compress_type starts at 1 so that we know whether the machine driver has provided a compress_type for overriding the codec supplied one. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-03ASoC: Add compress_type as a member to snd_soc_codecDimitris Papastamos
We need to keep a copy of the compress_type supplied by the codec driver so that we can override it if necessary with whatever the machine driver has provided us with. The reason for not modifying the codec->driver struct directly is that ideally we'd like to keep it const. Adjust the code in soc-cache and soc-core to make use of the compress_type member in the snd_soc_codec struct. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-03ASoC: Move active copy of CODEC read and write into runtime structureMark Brown
We shouldn't be assigning to the driver structure (which really ought to be const, further patch to follow) though there's unlikely to be any actual problem except in the unlikely case that two devices with the same driver but different bus types appear in the same system. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-30ASoC: Add support for optional auxiliary dailess codecsJarkko Nikula
This makes possible to register auxiliary dailess codecs in a machine driver. Term dailess is used here for amplifiers and codecs without DAI or DAI being unused. Dailess auxiliary codecs are kept in struct snd_soc_aux_dev and those codecs are probed after initializing the DAI links. There are no major differences between DAI link codecs and dailess codecs in ASoC core point of view. DAPM handles them equally and sysfs and debugfs directories for dailess codecs are similar except the pmdown_time node is not created. Only suspend and resume functions are modified to traverse all probed codecs instead of DAI link codecs. Example below shows a dailess codec registration. struct snd_soc_aux_dev foo_aux_dev[] = { { .name = "Amp", .codec_name = "codec.2", .init = foo_init2, }, }; static struct snd_soc_card card = { ... .aux_dev = foo_aux_dev, .num_aux_devs = ARRAY_SIZE(foo_aux_dev), }; Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: soc-cache: Ensure consistent cache namingDimitris Papastamos
2010-11-15ASoC: Add optional name_prefix for codec kcontrol, widget and route namesJarkko Nikula
There is a need to prefix codec kcontrol, widget and internal route names in an ASoC machine that has multiple codecs with conflicting names. The name collision would occur when codec drivers try to registering kcontrols with the same name or when building audio paths. This patch introduces optional prefix_map into struct snd_soc_card. With it machine drivers can specify a unique name prefix to each codec that have conflicting names with anothers. Prefix to codec is matched with codec name. Following example illustrates a machine that has two same codec instances. Name collision from kcontrol registration is avoided by specifying a name prefix "foo" for the second codec. As the codec widget names are prefixed then second audio map for that codec shows a prefixed widget name. static const struct snd_soc_dapm_route map0[] = { {"Spk", NULL, "MONO"}, }; static const struct snd_soc_dapm_route map1[] = { {"Vibra", NULL, "foo MONO"}, }; static struct snd_soc_prefix_map codec_prefix[] = { { .dev_name = "codec.2", .name_prefix = "foo", }, }; static struct snd_soc_card card = { ... .prefix_map = codec_prefix, .num_prefixes = ARRAY_SIZE(codec_prefix), }; Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-11ASoC: soc-cache: Add support for rbtree based register cachingDimitris Papastamos
This patch adds support for rbtree compression when storing the register cache. It does this by not adding any uninitialized registers (those whose value is 0). If any of those registers is written with a nonzero value they get added into the rbtree. Consider a sample device with a large sparse register map. The register indices are between [0, 0x31ff]. An array of 12800 registers is thus created each of which is 2 bytes. This results in a 25kB region. This array normally lives outside soc-core, normally in the driver itself. The original soc-core code would kmemdup this region resulting in 50kB total memory. When using the rbtree compression technique and __devinitconst on the original array the figures are as follows. For this typical device, you might have 100 initialized registers, that is registers that are nonzero by default. We build an rbtree with 100 nodes, each of which is 24 bytes. This results in ~2kB of memory. Assuming that the target arch can freeup the memory used by the initial __devinitconst array, we end up using about ~2kB bytes of actual memory. The memory footprint will increase as uninitialized registers get written and thus new nodes created in the rbtree. In practice, most of those registers are never changed. If the target arch can't freeup the __devinitconst array, we end up using a total of ~27kB. The difference between the rbtree and the LZO caching techniques, is that if using the LZO technique the size of the cache will increase slower as more uninitialized registers get changed. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-11ASoC: soc-cache: Add support for LZO register cachingDimitris Papastamos
This patch adds support for LZO compression when storing the register cache. The initial register defaults cache is marked as __devinitconst and the only change required for a driver to use LZO compression is to set the compress_type member in codec->driver to SND_SOC_LZO_COMPRESSION. For a typical device whose register map would normally occupy 25kB or 50kB by using the LZO compression technique, one can get down to ~5-7kB. There might be a performance penalty associated with each individual read/write due to decompressing/compressing the underlying cache, however that should not be noticeable. These memory benefits depend on whether the target architecture can get rid of the memory occupied by the original register defaults cache which is marked as __devinitconst. Nevertheless there will be some memory gain even if the target architecture can't get rid of the original register map, this should be around ~30-32kB instead of 50kB. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-11ASoC: soc-cache: Add support for flat register cachingDimitris Papastamos
This patch introduces the new caching API and migrates the old caching interface into the new one. The flat register caching technique does not use compression at all and it is equivalent to the old caching technique. One can still access codec->reg_cache directly but this is not advised as that will not be portable across different caching strategies. None of the existing drivers need to be changed to adapt to this caching technique. There should be no noticeable overhead associated with using the new caching API. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Move pop time from DAPM context to sound cardJarkko Nikula
Based on discussion the dapm_pop_time in debugsfs should be per card rather than per device. Single pop time value for entire card is cleaner when the DAPM sequencing is extended to cross-device paths. debugfs/asoc/{card->name}/{codec dir}/dapm_pop_time -> debugfs/asoc/{card->name}/dapm_pop_time Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Add sound card directory under debugfs/asoc/Jarkko Nikula
There will be need to have sound card specific debugfs entries. This patch introduces a new debugfs/asoc/{card->name}/ directory but does not add yet any entries there. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-03ASoC: Push snd_soc_write() and snd_soc_read() into the source fileMark Brown
Facilitating adding trace type stuff. For a first pass add some dev_dbg() statements into them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-13ASoC: don't register AC97 devices twiceMika Westerberg
With generic AC97 ASoC glue driver (codec/ac97.c), we get following warning when the device is registered (slightly stripped the backtrace): kobject (c5a863e8): tried to init an initialized object, something is seriously wrong. [<c00254fc>] (unwind_backtrace+0x0/0xec) [<c014fad0>] (kobject_init+0x38/0x70) [<c0171e94>] (device_initialize+0x20/0x70) [<c017267c>] (device_register+0xc/0x18) [<bf20db70>] (snd_soc_instantiate_cards+0x924/0xacc [snd_soc_core]) [<bf20e0d0>] (snd_soc_register_platform+0x16c/0x198 [snd_soc_core]) [<c0175304>] (platform_drv_probe+0x18/0x1c) [<c0174454>] (driver_probe_device+0xb0/0x16c) [<c017456c>] (__driver_attach+0x5c/0x7c) [<c0173cec>] (bus_for_each_dev+0x48/0x78) [<c0173600>] (bus_add_driver+0x98/0x214) [<c0174834>] (driver_register+0xa4/0x130) [<c001f410>] (do_one_initcall+0xd0/0x1a4) [<c0062ddc>] (sys_init_module+0x12b0/0x1454) This happens because the generic AC97 glue driver creates its codec->ac97 via calling snd_ac97_mixer(). snd_ac97_mixer() provides own version of snd_device.register which handles the device registration when snd_card_register() is called. To avoid registering the AC97 device twice, we add a new flag to the snd_soc_codec: ac97_created which tells whether the AC97 device was created by SoC subsystem. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
