path: root/include/sound/core.h
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-10[PATCH] DocBook: fix kernel-doc commentsMartin Waitz
Fix typos in comments to remove kernel-doc warnings. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[ALSA] Revert the nested-device patchTakashi Iwai
Modules: ALSA Core Revert the nested-device patch to keep the compatibility with the current HAL configuration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Nest sound devicesClemens Ladisch
Modules: ALSA Core Make the control device parent of all other ALSA devices of a card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (3/6): store device-specific object pointers dynamicallyClemens Ladisch
Instead of storing the pointers to the device-specific structures in an array, put them into the struct snd_minor, and look them up dynamically. This makes the device type modules independent of the minor number encoding. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (2/6): simplify storage of snd_minor structuresClemens Ladisch
Modules: ALSA Core Store the snd_minor structure pointers in one array instead of using a separate list for each card. This simplifies the mapping from device files to minor struct by removing the need to know about the encoding of the card number in the minor number. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (1/6): store device type in struct snd_minorClemens Ladisch
Instead of a comment string, store the device type in the snd_minor structure. This makes snd_minor more flexible, and has the nice side effect that we don't need anymore to create a separate snd_minor template for registering a device but can pass the file_operations directly to snd_register_device(). Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Decentralize PM controlTakashi Iwai
Modules: ALSA Core,Control Midlevel,/oss/Makefile Remove the centralized PM control in the sound core. Each driver is responsible to get callbacks from bus/driver now. SND_GENERIC_DRIVER is removed together with this action. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Core componentTakashi Iwai
Modules: ALSA Core Remove xxx_t typedefs from the core component. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] fix improper CONFIG_SND_MAJOR usageClemens Ladisch
Modules: HWDEP Midlevel,PCM Midlevel,RawMidi Midlevel,ALSA Core Replace usage of CONFIG_SND_MAJOR with snd_major, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] Add the missing forward declrationTakashi Iwai
Modules: ALSA Core Added the missing forward declaration before function prototypes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove kmalloc wrappersTakashi Iwai
Modules: ALSA Core Remove kmalloc wrappers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Make snd_task_name() module localTakashi Iwai
Modules: ALSA Core,ALSA<-OSS emulation Remove a global function snd_task_name(), and move it local to snd-pcm-oss module. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Use getnstimeofday()Takashi Iwai
Modules: Documentation,PCM Midlevel,Timer Midlevel,ALSA Core Use the standard getnstimeofday() function instead of ALSA's own one. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove snd_runtime_check() macroTakashi Iwai
Remove snd_runtime_check() macro. This macro worsens the readability of codes. They should be either normal if() or removable asserts. Also, the assert displays stack-dump, instead of only the last caller pointer. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[ALSA] Introduce snd_card_set_generic_dev()Takashi Iwai
ALSA Core A new function snd_card_set_generic_dev() is introduced to add the 'generic device' support for devices without proper bus on sysfs. It's a last resort, and should be removed in future when they have a proper bus, instead. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-07[PATCH] ALSA: convert kcalloc to kzallocPekka Enberg
This patch introduces a memory-leak tracking version of kzalloc for ALSA. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (ISA_DMA_API and sound/*)Al Viro
fixed kconfig dependencies on ISA_DMA_API for parts of sound/* that rely on it. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[ALSA] sound/core Fix the sparse warning 'implicit cast to nocast type'Victor Fusco
Memalloc module,ALSA Core,Instrument layer Fix the sparse warning 'implicit cast to nocast type' File/Subsystem:sound/core Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-07-28[ALSA] cleanup and typo-correctionHenrik Kretzschmar
ALSA Core This patch changes, adds and remove some comments, which will make now more sense and fit on a 80-char line. It also changes the order of snd_power_wait() to make the file more readable. It removes the device.c comment in front of _snd_minor, cause snd_minor has nothing to do with device.c. The both typos in the kernel-docs were corrected too. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
