path: root/include/scsi
2006-04-13[SCSI] FC transport: fixes for workq deadlocksJames Smart
As previously reported via Michael Reed, the FC transport took a hit in 2.6.15 (perhaps a little earlier) when we solved a recursion error. There are 2 deadlocks occurring: - With scan and the delete items sharing the same workq, flushing the workq for the delete code was getting it stalled behind a very long running scan code path. - There's a deadlock where scsi_remove_target() has to sit behind scsi_scan_target() due to contention over the scan_lock(). This patch resolves the 1st deadlock and significantly reduces the odds of the second. So far, we have only replicated the 2nd deadlock on a highly-parallel SMP system. More on the 2nd deadlock in a following email. This patch reworks the transport to: - Only use the scsi host workq for scanning - Use 2 other workq's internally. One for deletions, the other for scheduled deletions. Originally, we tried this with a single workq, but the occassional flushes of the scheduled queues was hitting the second deadlock with a slightly higher frequency. In the future, we'll look at the LLDD's and the transport to see if we can get rid of this extra overhead. - When moving to the other workq's we tightened up some object states and some lock handling. - Properly syncs adds/deletes - minor code cleanups - directly reference fc_host_attrs, rather than through attribute macros - flush the right workq on delayed work cancel failures. Large kudos to Michael Reed who has been working this issue for the last month. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] add SCSI_UNKNOWN and LUN transfer limit restrictionsJames Bottomley
Original From: Ingo Flaschberger <if@xip.at> To support the RA4100 array from Compaq. This patch now correctly handles SCSI_UNKNOWN types with regard to BLIST_REPORTLUNS2 (allow it) and cdb[1] LUN inclusion (don't). It also allows a BLIST_MAX_512 flag to restrict the maximum transfer length to 512 blocks (apparently this is an RA4100 problem). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] unify SCSI_IOCTL_SEND_COMMAND implementationsChristoph Hellwig
We currently have two implementations of this obsolete ioctl, one in the block layer and one in the scsi code. Both of them have drawbacks. This patch kills the scsi layer version after updating the block version with the missing bits: - argument checking - use scatterlist I/O - set number of retries based on the submitted command This is the last user of non-S/G I/O except for the gdth driver, so getting this in ASAP and through the scsi tree would be nie to kill the non-S/G I/O path. Jens, what do you think about adding a check for non-S/G I/O in the midlayer? Thanks to Or Gerlitz for testing this patch. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-10[PATCH] move ->eh_strategy_handler to the transport classChristoph Hellwig
Overriding the whole EH code is a per-transport, not per-host thing. Move ->eh_strategy_handler to the transport class, same as ->eh_timed_out. Downside is that scsi_host_alloc can't check for the total lack of EH anymore, but the transition period from old EH where we needed it is long gone already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-24[PATCH] Make libata not powerdown drivers on PM_EVENT_FREEZE.Nigel Cunningham
At the moment libata doesn't pass pm_message_t down ata_device_suspend. This causes drives to be powered down when we just want a freeze, causing unnecessary wear and tear. This patch gets pm_message_t passed down so that it can be used to determine whether to power down the drive. Signed-off-by: Nigel Cunningham <nigel@suspend2.net> drivers/scsi/libata-core.c | 5 +++-- drivers/scsi/libata-scsi.c | 4 ++-- drivers/scsi/scsi_sysfs.c | 2 +- include/linux/libata.h | 4 ++-- include/scsi/scsi_host.h | 2 +- 5 files changed, 9 insertions(+), 8 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-21Merge ../linux-2.6James Bottomley
2006-03-19[SCSI] eliminate rphy allocation in favour of expander/end device allocationJames Bottomley
This allows the removal of the contained flag and also does a bit of class renaming (sas_rphy->sas_device). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-19[SCSI] add scsi_mode_select to scsi_lib.cJames Bottomley
This complements the scsi_mode_sense() function Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] add scsi_reprobe_deviceJames Bottomley
Original from Christoph Hellwig and Eric Moore. This version exports the scsi_reprobe_device() function as an inline. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] add preliminary expander support to the sas transport classJames Bottomley
This patch makes expanders appear as labelled objects with properties in the SAS tree. I've also modified the phy code to make expander phys appear labelled by host number, expander number and phy index. So, for my current config, you see something like this in sysfs: /sys/class/scsi_host/host1/device/phy-1:4/expander-1:0/phy-1-0:12/rphy-1:0-12/target1:0:1 And the expander properties are: jejb@sparkweed> cd /sys/class/sas_expander/expander-1\:0/ jejb@sparkweed> for f in *; do echo -n $f ": "; cat $f; done component_id : 29024 component_revision_id : 4 component_vendor_id : VITESSE device : cat: device: Is a directory level : 0 product_id : VSC7160 Eval Brd product_rev : 4 uevent : cat: uevent: Permission denied vendor_id : VITESSE Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-13[SCSI] FC transport : Avoid device offline cases by stalling aborts until ↵James Smart
device unblocked This moves the eh_timed_out functionality from the scsi_host_template to the transport_template. Given that this is now a transport function, the EH_RESET_TIMER case no longer caps the timer reschedulings. The transport guarantees that this is not an infinite condition. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-06[PATCH] convert aic94xx over to using the sas transport end deviceJames Bottomley
Begin introducing the concept of sas remote devices that have an rphy embedded. The first one (this) is a simple end device. All that an end device really does is have port mode page parameters contained. The next and more complex piece will be expander remote devices. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-02[SCSI] add 6.0 Gbit phy definitions to the sas transport classJames Bottomley
I don't think these exist in silicon yet, but the aic94xx driver has a register setting for them. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] fix scsi process problems and clean up the target reap issuesJames Bottomley
In order to use the new execute_in_process_context() API, you have to provide it with the work storage, which I do in SCSI in scsi_device and scsi_target, but which also means that we can no longer queue up the target reaps, so instead I moved the target to a state model which allows target_alloc to detect if we've received a dying target and wait for it to be gone. Hopefully, this should also solve the target namespace race. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Recognize missing LUNs for non-standard devicesAlan Stern
Some non-standard SCSI targets or protocols, such as USB UFI, report "no LUN present" by setting the Peripheral Device Type to 0x1f and the Peripheral Qualifier to 0 (not 3 as the standard requires) in the INQUIRY response. This patch (as650b) adds a new target flag and code to accomodate such targets. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] sas: add support for enclosure and bad ID rphy attributesChristoph Hellwig
2006-02-27[SCSI] Add spi_populate_*_msg functionsMatthew Wilcox
Introduce new helpers: - spi_populate_width_msg() - spi_populate_sync_msg() - spi_populate_ppr_msg() and use them in drivers which already enable the SPI transport. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Neaten comments in scsi_cmnd.hMatthew Wilcox
Wrap these two comments at 80 columns Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-20Merge branch 'master'Jeff Garzik
2006-02-14[PATCH] add scsi_execute_in_process_context() APIJames Bottomley
We have several points in the SCSI stack (primarily for our device functions) where we need to guarantee process context, but (given the place where the last reference was released) we cannot guarantee this. This API gets around the issue by executing the function directly if the caller has process context, but scheduling a workqueue to execute in process context if the caller doesn't have it. Unfortunately, it requires memory allocation in interrupt context, but it's better than what we have previously. The true solution will require a bit of re-engineering, so isn't appropriate for 2.6.16. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] iscsi update: cleanup iscsi class interfaceMike Christie
From: michaelc@cs.wisc.edu fujita.tomonori@lab.ntt.co.jp da-x@monatomic.org and err path fixup from: ogerlitz@voltaire.com This patch cleans up that interface by having the lld and class pass a iscsi_cls_session or iscsi_cls_conn between each other when the function is used by HW and SW iscsi llds. This way the lld does not have to remember if it has to send a handle or pointer and a handle or pointer to connection, session or host. This also has the class verify the session handle that gets passed from userspace instead of using the pointer passed into the kernel directly. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Alex Aizman <itn780@yahoo.com> Signed-off-by: Dmitry Yusupov <dmitry_yus@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-02Merge branch 'master'Jeff Garzik
2006-01-31Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2006-01-26[PATCH] SCSI: export scsi_eh_finish_cmd() and scsi_eh_flush_done_q()Tejun Heo
Export two SCSI EH command handling functions. To be used by libata EH. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-26[SCSI] Prevent scsi_execute_async from guessing cdb lengthbrking@us.ibm.com
When the scsi_execute_async interface was added it ended up reducing the flexibility of userspace to send arbitrary scsi commands through sg using SG_IO. The SG_IO interface allows userspace to specify the CDB length. This is now ignored in scsi_execute_async and it is guessed using the COMMAND_SIZE macro, which is not always correct, particularly for vendor specific commands. This patch adds a cmd_len parameter to the scsi_execute_async interface to allow the caller to specify the length of the CDB. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-25[SCSI] Remove host template ordered_flush variableTetsuo Takata
After the recent overhaul of the block layer the variable "ordered_flush" is no longer used. Signed-off-by: Tetsuo Takata <takatatt@intellilink.co.jp> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-18[PATCH] scsi_transport_spi build fixAndrew Morton
On alpha: In file included from drivers/scsi/sym53c8xx_2/sym_glue.h:59, from drivers/scsi/sym53c8xx_2/sym_fw.c:40: include/scsi/scsi_transport_spi.h:57: error: field `dv_mutex' has incomplete type Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] iscsi: seperate iscsi interface from setup functionsMike Christie
This is the second version of the patch to address Christoph's comments. Instead of doing the lib, I just kept everything in scsi_trnapsort_iscsi.c like the FC and SPI class. This was becuase the driver model and sysfs class is tied to the session and connection setup so separating did not buy very much at this time. The reason for this patch was becuase HW iscsi LLDs like qla4xxx cannot use the iscsi class becuase the scsi_host was tied to the interface and class code. This patch just seperates the session from scsi host so that LLDs that allocate the host per some resource like pci device can still use the class. This is also fixes a couple refcount bugs that can be triggered when users have a sysfs file open, close the session, then read or write to the file. Signed-off-by: Alex Aizman <itn780@yahoo.com> Signed-off-by: Dmitry Yusupov <dmitry_yus@yahoo.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] remove target parent limitiationChristoph Hellwig
When James Smart fixed the issue of the userspace scan atributes crashing the system with the FC transport class he added a patch to let the transport class check if the parent is valid for a given transport class. When adding support for the integrated raid of fusion sas devices we ran into a problem with that, as it didn't allow adding virtual raid volumes without the transport class knowing about it. So this patch adds a user_scan attribute instead, that takes over from scsi_scan_host_selected if the transport class sets it and thus lets the transport class control the user-initiated scanning. As this plugs the hole about user-initiated scanning the target_parent hook goes away and we rely on callers of the scanning routines to do something sensible. For SAS this meant I had to switch from a spinlock to a mutex to synchronize the topology linked lists, in FC they were completely unsynchronized which seems wrong. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] sem2mutex: scsi_transport_spi.cJes Sorensen
Convert the SCSI transport class code to use a mutex rather than a semaphore. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fc transport: add permanent_port_name fc_host attributeAndreas Herrmann
Add fc_host attribute permanent_port_name which is used to show the port name of the primary port - the port that initially logged into the fabric. For a virtual port (registered via the primary port with FDISC command) it is useful to know not only its (virtual) port name but also the permanent port name. Signed-off-by: Andreas Herrmann <aherrman@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] always handle REQ_BLOCK_PC requests in common codeChristoph Hellwig
LLDDs should never see REQ_BLOCK_PC requests, we can handle them just fine in the core code. There is a small behaviour change in that some check in sr's rw_intr are bypassed, but I consider the old behaviour a bug. Mike found this cleanup opportunity and provdided early patches, so all the credit goes to him, even if I redid the patches from scratch beause that was easier than forward-porting the old patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-06Merge branch 'post-2.6.15' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual fixup for merge with Jens' "Suspend support for libata", commit ID 9b847548663ef1039dd49f0eb4463d001e596bc3. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Suspend support for libataJens Axboe
This patch adds suspend patch to libata, and ata_piix in particular. For most low level drivers, they should just need to add the 4 hooks to work. As I can only test ata_piix, I didn't enable it for more though. Suspend support is the single most important feature on a notebook, and most new notebooks have sata drives. It's quite embarrassing that we _still_ do not support this. Right now, it's perfectly possible to suspend the drive in mid-transfer. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[BLOCK] update SCSI to use new blk_ordered for barriersTejun Heo
All ordered request related stuff delegated to HLD. Midlayer now doens't deal with ordered setting or prepare_flush callback. sd.c updated to deal with blk_queue_ordered setting. Currently, ordered tag isn't used as SCSI midlayer cannot guarantee request ordering. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
2005-12-15[SCSI] fix for fc transport recursion problem.James.Smart@Emulex.Com
In the scenario that a link was broken, the devloss timer for each rport was expire at roughly the same time, causing lots of "delete" workqueue items being queued. Depth is dependent upon the number of rports that were on the link. The rport target remove calls were calling flush_scheduled_work(), which would interrupt the stream, and start the next workqueue item, which did the same thing, and so on until recursion depth was large. This fix stops the recursion in the initial delete path, and pushes it off to a host-level work item that reaps the dead rports. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15Fix up SCSI mismergeJames Bottomley
I forgot to do a git-update-cache on the merged files ...
2005-12-15Merge by hand (conflicts in scsi_lib.c)James Bottomley
This merge is pretty extensive. The conflict is over the new req->retries parameter, so I had to change the prototype to scsi_setup_blk_pc_cmnd() and the usage in sd, sr and st. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-14[SCSI] Convert SCSI mid-layer to scsi_execute_asyncMike Christie
Add scsi helpers to create really-large-requests and convert scsi-ml to scsi_execute_async(). Per Jens's previous comments, I placed this function in scsi_lib.c. I made it follow all the queue's limits - I think I did at least :), so I removed the warning on the function header. I think the scsi_execute_* functions should eventually take a request_queue and be placed some place where the dm-multipath hw_handler can use them if that failover code is going to stay in the kernel. That conversion patch will be sent in another mail though. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Consolidate REQ_BLOCK_PC handling path (fix ipod panic)James Bottomley
This follows on from Jens' patch and consolidates all of the ULD separate handlers for REQ_BLOCK_PC into a single call which has his fix for our direction bug. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] Make scsi_transport_spi.h includable by itselfMatthew Wilcox
Add forward declarations to allow scsi_transport_spi.h to be compiled by itself. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] correct some dropped const compiler warningsJames Bottomley
Make the vendor, model and rev fields in scsi_device pointers to const and update a few prototypes of functions using them. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] use a completion in scsi_send_eh_cmndChristoph Hellwig
scsi_send_eh_cmnd currently uses a semaphore and an overload of eh_timer to either get a completion for a command for a timeout. Switch to using a completion and wait_for_completion_timeout to simply the code and not having to deal with the races ourselves. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] remove scsi_wait_reqChristoph Hellwig
This function has been superceeded by the block request based interfaces and is unused (except for the uncompilable cpqfc driver). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] remove Scsi_Host.eh_activeChristoph Hellwig
now that the abuse in qla2xxx is gone this field can be remove. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-04Merge by HandJames Bottomley
Conflicts in dec_esp.c (Thanks Bacchus), scsi_transport_iscsi.c and scsi_transport_fc.h Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
