Smack doesn't have the need to create a private copy of the LSM "domain" when
setting NetLabel security attributes like SELinux, however, the current
NetLabel code requires a private copy of the LSM "domain". This patches fixes
that by letting the LSM determine how it wants to pass the domain value.
* NETLBL_SECATTR_DOMAIN_CPY
The current behavior, NetLabel assumes that the domain value is a copy and
frees it when done
New, Smack-friendly behavior, NetLabel assumes that the domain value is a
reference to a string managed by the LSM and does not free it when done
Signed-off-by: Paul Moore <paul.moore@hp.com>
Acked-by: James Morris <jmorris@namei.org>
Allow the use of SACK and window scaling when syncookies are used
and the client supports tcp timestamps. Options are encoded into
the timestamp sent in the syn-ack and restored from the timestamp
echo when the ack is received.
Based on earlier work by Glenn Griffin.
This patch avoids increasing the size of structs by encoding TCP
options into the least significant bits of the timestamp and
by not using any 'timestamp offset'.
The downside is that the timestamp sent in the packet after the synack
will increase by several seconds.
changes since v1:
don't duplicate timestamp echo decoding function, put it into ipv4/syncookie.c
and have ipv6/syncookies.c use it.
Feedback from Glenn Griffin: fix line indented with spaces, kill redundant if ()
Reviewed-by: Hagen Paul Pfeifer <hagen@jauu.net>
1) Standlaone ip6_null_entry is no longer needed as it is replaced by
the ip6_null_entry member of ipv6 (instance of struct netns_ipv6) in
struct net (as a result of Network Namespaces patches).
2) These 3 methods from this same header are not defined anywhere:
ip6_rt_addr_add(), ip6_rt_addr_del(), rt6_sndmsg()
Signed-off-by: Rami Rosen <ramirose@gmail.com>
This patch removes two unused method declarations in
include/net/ndisc.h: ndisc_forwarding_on(void) and
ndisc_forwarding_off(void);
Also igmp6_cleanup(void) appears twice in this header, so one
igmp6_cleanup(void) declaration is removed.
The sk_filter function is too big to be inlined. This saves 2296 bytes
of text on allyesconfig.
Add new API to MAC80211 to allow low level driver to
notify MAC with driver status.
Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
This patch is necessary for the upcoming Accesspoint patch for p54.
Signed-off-by: Christian Lamparter <chunkeey@web.de>
This patch adds assocation capability, timestamp (tsf) and beacon interval
to bss_conf. This is required for successful assocation of iwlwifi drivers
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Gregory Greenman <gregory.greenman@intel.com>
This patch eliminates the use of conf_ht, replacing it with
bss_info_changed.
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-dev
Signed-off-by: Denis V. Lunev <den@openvz.org>
This is a generic requirement, so make inet_ctl_sock_create namespace
aware and create a inet_ctl_sock_destroy wrapper around
sk_release_kernel.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
All upper protocol layers are already use sock internally.
This call is nothing common with INET connection sockets code. It
simply creates an unhashes kernel sockets for protocol messages.
Move the new call into af_inet.c after the rename.
This does not look good, but there is no other choice. The compilation
without CONFIG_NET is broken and can not be fixed with ease.
After that there is no need for the following commits:
1567ca7eec7664b8be3b07755ac59dc1b1ec76cb
3edf8fa5ccf10688a9280b5cbca8ed3947c42866
2d38f9a4f8d2ebdc799f03eecf82345825495711
Revert them.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/s2io.c
Both are identical, let's create ipv6_chk_prefix() and use it
in both places.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch updates the Linux the Intra-Site Automatic Tunnel Addressing
Protocol (ISATAP) implementation. It places the ISATAP potential router
list (PRL) in the kernel and adds three new private ioctls for PRL
management.
[Add several changes of structure name, constant names etc. - yoshfuji]
Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com>
Allocate the skb for llc responses with the received packet size by
using the size adjustable llc_frame_alloc.
Don't allocate useless extra payload.
Cleanup magic numbers.
So, this fixes oops.
Reported by Jim Westfall:
kernel: skb_over_panic: text:c0541fc7 len:1000 put:997 head:c166ac00 data:c166ac2f tail:0xc166b017 end:0xc166ac80 dev:eth0
kernel: ------------[ cut here ]------------
kernel: kernel BUG at net/core/skbuff.c:95!
Signed-off-by: Joonwoo Park <joonwpark81@gmail.com>
Such an accounting would cost us two more dereferences to get the
percpu variable from the struct net, so I make sock_prot_inuse_get
and _add calls work differently depending on CONFIG_NET_NS - without
it old optimized routines are used.
The per-cpu counter for init_net is prepared in core_initcall, so
that even af_inet, that starts as fs_initcall, will already have the
init_net prepared.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This counter is about to become per-proto-and-per-net, so we'll need
two arguments to determine which cell in this "table" to work with.
All the places, but proc already pass proper net to it - proc will be
tuned a bit later.
Some indentation with spaces in proc files is done to keep the file
coding style consistent.
There's already some stuff on the struct net, that should better
be folded into netns_core structure. I'm making the per-proto inuse
counter be per-net also, which is also a candidate for this, so
introduce this structure and populate it a bit.
Move it to udp_seq_afinfo->seq_fops as should be.
No need to have separate never-used variable.
No need to create seq_operations for each instance of 'netstat'.
An uppercut - do not use the pcounter on struct proto.
Acked-by: Eric Dumazet <dada1@cosmosbay.com>
Constructive part of the set is finished here. We have to remove the
pcounter, so start with its init and free functions.
And redirect sock_prot_inuse_add and _get to use one.
As far as the dereferences are concerned. Before the patch we made
1 dereference to proto->inuse.add call, the call itself and then
called the __get_cpu_var() on a static variable. After the patch we
make a direct call, then one dereference to proto->inuse_idx and
then the same __get_cpu_var() on a still static variable. So this
patch doesn't seem to produce performance penalty on SMP.
This is not per-net yet, but I will deliberately make NET_NS=y case
separated from NET_NS=n one, since it'll cost us one-or-two more
dereferences to get the struct net and the inuse counter.
The inuse counters are going to become a per-cpu array. Introduce an
index for this array on the struct proto.
To handle the case of proto register-unregister-register loop the
bitmap is used. All its bits manipulations are protected with
proto_list_lock and a sanity check for the bitmap being exhausted is
also added.
On Fri, 2008-03-28 at 03:24 -0700, Andrew Morton wrote:
> they should all be renamed.
Done for include/net and net
kill unnecessary llc_station_mac_sa.
This patches removes unused declaration of addrconf_forwarding_on() method
in include/net/addrconf.h.
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6.26
With a was number of callsites sctp_add_cmd_sf wrapper bloats
kernel by some amount. Due to unlikely tracking allyesconfig,
with the initial result were around ~7kB (thus caught my
attention) while a non-debug config produced only ~2.3kB effect.
I (ij) proposed first a patch to uninline it but Vlad responded
with a patch that removed the only sctp_add_cmd call which is
wrapped by sctp_add_cmd_sf (I wasn't sure if I could do that).
I did minor cleanup to Vlad's patch.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Codiff stats (allyesconfig, v2.6.24-mm1):
-16420 187 funcs, 103 +, 16523 -, diff: -16420 --- dst_release
Without number of debug related CONFIGs (v2.6.25-rc2-mm1):
-7257 186 funcs, 70 +, 7327 -, diff: -7257 --- dst_release
dst_release | +40
This patch removes three unused method declarations in include/net/ipv6.h:
inet_getfrag_t(), ipv6_build_nfrag_opts() and ipv6_build_frag_opts().
This patch makes ieee80211_get_channel a static inline defined in
cfg80211's header file which simply calls __ieee80211_get_channel
to avoid symbol clashes with the ieee80211 code.
The problem was pointed out by David Miller, thanks!
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This patch introduces a new member, fl_net, in struct ip6_flowlabel.
This allows to create labels with the same value in different namespaces.
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Make use of the network namespace information to have this protocol to
handle several network namespace.
The IPv6 BEET output function is incorrectly including the inner
header in the payload to be protected. This causes a crash as
the packet doesn't actually have that many bytes for a second
header.
The IPv4 BEET output on the other hand is broken when it comes
to handling an inner IPv6 header since it always assumes an
inner IPv4 header.
This patch fixes both by making sure that neither BEET output
function touches the inner header at all. All access is now
done through the protocol-independent cb structure. Two new
attributes are added to make this work, the IP header length
and the IPv4 option length. They're filled in by the inner
mode's output function.
Thanks to Joakim Koskela for finding this problem.
Add some flesh to ipv4_sysctl_init_net and ipv4_sysctl_exit_net,
i.e. copy the table, alter .data pointers and register it per-net.
Other ipv4_table's sysctls are now global, but this is going to
change once sysctl permissions patches migrate from -mm tree to
mainline in 2.6.26 merge window :)
Initialization is moved to icmp_sk_init, all the places, that
refer to them use init_net for now.
Recent commits from YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
have been introduced a several compilation warnings
'assignment discards qualifiers from pointer target type'
due to extra const modifier in the inline call parameters of
{dev|sock|twsk}_net_set.
Drop it.
Add support for multiple media channels and use it to create
expectations for video streams when present.
