path: root/include/net
2013-05-20Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-05-16Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains three Netfilter fixes and update for the MAINTAINER file for your net tree, they are: * Fix crash if nf_log_packet is called from conntrack, in that case both interfaces are NULL, from Hans Schillstrom. This bug introduced with the logging netns support in the previous merge window. * Fix compilation of nf_log and nf_queue without CONFIG_PROC_FS, from myself. This bug was introduced in the previous merge window with the new netns support for the netfilter logging infrastructure. * Fix possible crash in xt_TCPOPTSTRIP due to missing sanity checkings to validate that the TCP header is well-formed, from myself. I can find this bug in 2.6.25, probably it's been there since the beginning. I'll pass this to -stable. * Update MAINTAINER file to point to new nf trees at git.kernel.org, remove Harald and use M: instead of P: (now obsolete tag) to keep Jozsef in the list of people. Please, consider pulling this. Thanks! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-16mac80211: fix spurious RCU warning and update documentationFelix Fietkau
Document rx vs tx status concurrency requirements. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-15netfilter: log: netns NULL ptr bug when calling from conntrackHans Schillstrom
Since (69b34fb netfilter: xt_LOG: add net namespace support for xt_LOG), we hit this: [ 4224.708977] BUG: unable to handle kernel NULL pointer dereference at 0000000000000388 [ 4224.709074] IP: [<ffffffff8147f699>] ipt_log_packet+0x29/0x270 when callling log functions from conntrack both in and out are NULL i.e. the net pointer is invalid. Adding struct net *net in call to nf_logfn() will secure that there always is a vaild net ptr. Reported as netfilter's bugzilla bug 818: https://bugzilla.netfilter.org/show_bug.cgi?id=818 Reported-by: Ronald <ronald645@gmail.com> Signed-off-by: Hans Schillstrom <hans@schillstrom.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-11ipv6: do not clear pinet6 fieldEric Dumazet
We have seen multiple NULL dereferences in __inet6_lookup_established() After analysis, I found that inet6_sk() could be NULL while the check for sk_family == AF_INET6 was true. Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP and TCP stacks. Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash table, we no longer can clear pinet6 field. This patch extends logic used in commit fcbdf09d9652c891 ("net: fix nulls list corruptions in sk_prot_alloc") TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method to make sure we do not clear pinet6 field. At socket clone phase, we do not really care, as cloning the parent (non NULL) pinet6 is not adding a fatal race. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06net: frag, fix race conditions in LRU list maintenanceKonstantin Khlebnikov
This patch fixes race between inet_frag_lru_move() and inet_frag_lru_add() which was introduced in commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206 ("net: frag, move LRU list maintenance outside of rwlock") One cpu already added new fragment queue into hash but not into LRU. Other cpu found it in hash and tries to move it to the end of LRU. This leads to NULL pointer dereference inside of list_move_tail(). Another possible race condition is between inet_frag_lru_move() and inet_frag_lru_del(): move can happens after deletion. This patch initializes LRU list head before adding fragment into hash and inet_frag_lru_move() doesn't touches it if it's empty. I saw this kernel oops two times in a couple of days. [119482.128853] BUG: unable to handle kernel NULL pointer dereference at (null) [119482.132693] IP: [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.136456] PGD 2148f6067 PUD 215ab9067 PMD 0 [119482.140221] Oops: 0000 [#1] SMP [119482.144008] Modules linked in: vfat msdos fat 8021q fuse nfsd auth_rpcgss nfs_acl nfs lockd sunrpc ppp_async ppp_generic bridge slhc stp llc w83627ehf hwmon_vid snd_hda_codec_hdmi snd_hda_codec_realtek kvm_amd k10temp kvm snd_hda_intel snd_hda_codec edac_core radeon snd_hwdep ath9k snd_pcm ath9k_common snd_page_alloc ath9k_hw snd_timer snd soundcore drm_kms_helper ath ttm r8169 mii [119482.152692] CPU 3 [119482.152721] Pid: 20, comm: ksoftirqd/3 Not tainted 3.9.0-zurg-00001-g9f95269 #132 To Be Filled By O.E.M. To Be Filled By O.E.M./RS880D [119482.161478] RIP: 0010:[<ffffffff812ede89>] [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.166004] RSP: 0018:ffff880216d5db58 EFLAGS: 00010207 [119482.170568] RAX: 0000000000000000 RBX: ffff88020882b9c0 RCX: dead000000200200 [119482.175189] RDX: 0000000000000000 RSI: 0000000000000880 RDI: ffff88020882ba00 [119482.179860] RBP: ffff880216d5db58 R08: ffffffff8155c7f0 R09: 0000000000000014 [119482.184570] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88020882ba00 [119482.189337] R13: ffffffff81c8d780 R14: ffff880204357f00 R15: 00000000000005a0 [119482.194140] FS: 00007f58124dc700(0000) GS:ffff88021fcc0000(0000) knlGS:0000000000000000 [119482.198928] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [119482.203711] CR2: 0000000000000000 CR3: 00000002155f0000 CR4: 00000000000007e0 [119482.208533] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [119482.213371] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [119482.218221] Process ksoftirqd/3 (pid: 20, threadinfo ffff880216d5c000, task ffff880216d3a9a0) [119482.223113] Stack: [119482.228004] ffff880216d5dbd8 ffffffff8155dcda 0000000000000000 ffff000200000001 [119482.233038] ffff8802153c1f00 ffff880000289440 ffff880200000014 ffff88007bc72000 [119482.238083] 00000000000079d5 ffff88007bc72f44 ffffffff00000002 ffff880204357f00 [119482.243090] Call Trace: [119482.248009] [<ffffffff8155dcda>] ip_defrag+0x8fa/0xd10 [119482.252921] [<ffffffff815a8013>] ipv4_conntrack_defrag+0x83/0xe0 [119482.257803] [<ffffffff8154485b>] nf_iterate+0x8b/0xa0 [119482.262658] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40 [119482.267527] [<ffffffff815448e4>] nf_hook_slow+0x74/0x130 [119482.272412] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40 [119482.277302] [<ffffffff8155d068>] ip_rcv+0x268/0x320 [119482.282147] [<ffffffff81519992>] __netif_receive_skb_core+0x612/0x7e0 [119482.286998] [<ffffffff81519b78>] __netif_receive_skb+0x18/0x60 [119482.291826] [<ffffffff8151a650>] process_backlog+0xa0/0x160 [119482.296648] [<ffffffff81519f29>] net_rx_action+0x139/0x220 [119482.301403] [<ffffffff81053707>] __do_softirq+0xe7/0x220 [119482.306103] [<ffffffff81053868>] run_ksoftirqd+0x28/0x40 [119482.310809] [<ffffffff81074f5f>] smpboot_thread_fn+0xff/0x1a0 [119482.315515] [<ffffffff81074e60>] ? lg_local_lock_cpu+0x40/0x40 [119482.320219] [<ffffffff8106d870>] kthread+0xc0/0xd0 [119482.324858] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40 [119482.329460] [<ffffffff816c32dc>] ret_from_fork+0x7c/0xb0 [119482.334057] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40 [119482.338661] Code: 00 00 55 48 8b 17 48 b9 00 01 10 00 00 00 ad de 48 8b 47 08 48 89 e5 48 39 ca 74 29 48 b9 00 02 20 00 00 00 ad de 48 39 c8 74 7a <4c> 8b 00 4c 39 c7 75 53 4c 8b 42 08 4c 39 c7 75 2b 48 89 42 08 [119482.343787] RIP [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.348675] RSP <ffff880216d5db58> [119482.353493] CR2: 0000000000000000 Oops happened on this path: ip_defrag() -> ip_frag_queue() -> inet_frag_lru_move() -> list_move_tail() -> __list_del_entry() Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Florian Westphal <fw@strlen.de> Cc: Eric Dumazet <edumazet@google.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-05-01af_unix: fix a fatal race with bit fieldsEric Dumazet
Using bit fields is dangerous on ppc64/sparc64, as the compiler [1] uses 64bit instructions to manipulate them. If the 64bit word includes any atomic_t or spinlock_t, we can lose critical concurrent changes. This is happening in af_unix, where unix_sk(sk)->gc_candidate/ gc_maybe_cycle/lock share the same 64bit word. This leads to fatal deadlock, as one/several cpus spin forever on a spinlock that will never be available again. A safer way would be to use a long to store flags. This way we are sure compiler/arch wont do bad things. As we own unix_gc_lock spinlock when clearing or setting bits, we can use the non atomic __set_bit()/__clear_bit(). recursion_level can share the same 64bit location with the spinlock, as it is set only with this spinlock held. [1] bug fixed in gcc-4.8.0 : http://gcc.gnu.org/bugzilla/show_bug.cgi?id=52080 Reported-by: Ambrose Feinstein <ambrose@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-29hostap: Don't use create_proc_read_entry()David Howells
Don't use create_proc_read_entry() as that is deprecated, but rather use proc_create_data() and seq_file instead. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Jouni Malinen <j@w1.fi> cc: John W. Linville <linville@tuxdriver.com> cc: Johannes Berg <johannes@sipsolutions.net> cc: linux-wireless@vger.kernel.org cc: netdev@vger.kernel.org cc: devel@driverdev.osuosl.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2013-04-29net: defer net_secret[] initializationEric Dumazet
Instead of feeding net_secret[] at boot time, defer the init at the point first socket is created. This permits some platforms to use better entropy sources than the ones available at boot time. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next Pablo Neira Ayuso says: ==================== The following patchset contains relevant updates for the Netfilter tree, they are: * Enhancements for ipset: Add the counter extension for sets, this information can be used from the iptables set match, to change the matching behaviour. Jozsef required to add the extension infrastructure and moved the existing timeout support upon it. This also includes a change in net/sched/em_ipset to adapt it to the new extension structure. * Enhancements for performance boosting in nfnetlink_queue: Add new configuration flags that allows user-space to receive big packets (GRO) and to disable checksumming calculation. This were proposed by Eric Dumazet during the Netfilter Workshop 2013 in Copenhagen. Florian Westphal was kind enough to find the time to materialize the proposal. * A sparse fix from Simon, he noticed it in the SCTP NAT helper, the fix required a change in the interface of sctp_end_cksum. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29sctp: Correct type and usage of sctp_end_cksum()Simon Horman
Change the type of the crc32 parameter of sctp_end_cksum() from __be32 to __u32 to reflect that fact that it is passed to cpu_to_le32(). There are five in-tree users of sctp_end_cksum(). The following four had warnings flagged by sparse which are no longer present with this change. net/netfilter/ipvs/ip_vs_proto_sctp.c:sctp_nat_csum() net/netfilter/ipvs/ip_vs_proto_sctp.c:sctp_csum_check() net/sctp/input.c:sctp_rcv_checksum() net/sctp/output.c:sctp_packet_transmit() The fifth user is net/netfilter/nf_nat_proto_sctp.c:sctp_manip_pkt(). It has been updated to pass a __u32 instead of a __be32, the value in question was already calculated in cpu byte-order. net/netfilter/nf_nat_proto_sctp.c:sctp_manip_pkt() has also been updated to assign the return value of sctp_end_cksum() directly to a variable of type __le32, matching the type of the return value. Previously the return value was assigned to a variable of type __be32 and then that variable was finally assigned to another variable of type __le32. Problems flagged by sparse. Compile and sparse tested only. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-04-29netfilter: move skb_gso_segment into nfnetlink_queue moduleFlorian Westphal
skb_gso_segment is expensive, so it would be nice if we could avoid it in the future. However, userspace needs to be prepared to receive larger-than-mtu-packets (which will also have incorrect l3/l4 checksums), so we cannot simply remove it. The plan is to add a per-queue feature flag that userspace can set when binding the queue. The problem is that in nf_queue, we only have a queue number, not the queue context/configuration settings. This patch should have no impact other than the skb_gso_segment call now being in a function that has access to the queue config data. A new size attribute in nf_queue_entry is needed so nfnetlink_queue can duplicate the entry of the gso skb when segmenting the skb while also copying the route key. The follow up patch adds switch to disable skb_gso_segment when queue config says so. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-04-29net: increase frag hash sizeJesper Dangaard Brouer
Increase fragmentation hash bucket size to 1024 from old 64 elems. After we increased the frag mem limits commit c2a93660 (net: increase fragment memory usage limits) the hash size of 64 elements is simply too small. Also considering the mem limit is per netns and the hash table is shared for all netns. For the embedded people, note that this increase will change the hash table/array from using approx 1 Kbytes to 16 Kbytes. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-26Merge branch 'for-upstream' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
2013-04-25genl: Allow concurrent genl callbacks.Pravin B Shelar
All genl callbacks are serialized by genl-mutex. This can become bottleneck in multi threaded case. Following patch adds an parameter to genl_family so that a particular family can get concurrent netlink callback without genl_lock held. New rw-sem is used to protect genl callback from genl family unregister. in case of parallel_ops genl-family read-lock is taken for callbacks and write lock is taken for register or unregistration for any family. In case of locked genl family semaphore and gel-mutex is locked for any openration. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-25Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next Pablo Neira Ayuso says: ==================== The following patchset contains fixes for recently applied Netfilter/IPVS updates to the net-next tree, most relevantly they are: * Fix sparse warnings introduced in the RCU conversion, from Julian Anastasov. * Fix wrong endianness in the size field of IPVS sync messages, from Simon Horman. * Fix missing if checking in nf_xfrm_me_harder, from Dan Carpenter. * Fix off by one access in the IPVS SCTP tracking code, again from Dan Carpenter. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-24Merge branch 'master' of ↵John W. Linville
2013-04-23caif: Remove my bouncing email address.sjur.brandeland@stericsson.com
Remove my soon bouncing email address. Also remove the "Contact:" line in file header. The MAINTAINERS file is a better place to find the contact person anyway. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-23ipvs: fix sparse warnings for some parametersJulian Anastasov
Some service fields are in network order: - netmask: used once in network order and also as prefix len for IPv6 - port Other parameters are in host order: - struct ip_vs_flags: flags and mask moved between user and kernel only - sync state: moved between user and kernel only - syncid: sent over network as single octet Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22net: sctp: minor: remove dead code from sctp_packetDaniel Borkmann
struct sctp_packet is currently embedded into sctp_transport or sits on the stack as 'singleton' in sctp_outq_flush(). Therefore, its member 'malloced' is always 0, thus a kfree() is never called. Because of that, we can just remove this code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22net: remove a stale comment for dl_nextEric Dumazet
dl_next member in struct request_sock doesn't need to be first. We expect to insert a "struct common_sock" or a subset of it, so this claim had to be verified. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2013-04-22Merge branch 'for-upstream' of ↵John W. Linville
2013-04-22mac80211: improve the rate control APIFelix Fietkau
Allow rate control modules to pass a rate selection table to mac80211 and the driver. This allows drivers to fetch the most recent rate selection from the sta pointer for already buffered frames. This allows rate control to respond faster to sudden link changes and it is also a step towards adding minstrel_ht support to drivers like iwlwifi. When a driver sets IEEE80211_HW_SUPPORTS_RC_TABLE, mac80211 will not fill info->control.rates with rates from the rate table (to preserve explicit overrides by the rate control module). The driver then explicitly calls ieee80211_get_tx_rates to merge overrides from info->control.rates with defaults from the sta rate table. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-22cfg80211: introduce critical protocol indication from user-spaceArend van Spriel
Some protocols need a more reliable connection to complete successful in reasonable time. This patch adds a user-space API to indicate the wireless driver that a critical protocol is about to commence and when it is done, using nl80211 primitives NL80211_CMD_CRIT_PROTOCOL_START and NL80211_CRIT_PROTOCOL_STOP. There can be only on critical protocol session started per registered cfg80211 device. The driver can support this by implementing the cfg80211 callbacks .crit_proto_start() and .crit_proto_stop(). Examples of protocols that can benefit from this are DHCP, EAPOL, APIPA. Exactly how the link can/should be made more reliable is up to the driver. Things to consider are avoid scanning, no multi-channel operations, and alter coexistence schemes. Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-22mac80211: indicate admission control in TX queue parametersAlexander Bondar
Some driver implementations need to know whether mandatory admission control is required by the AP for some ACs. Add a parameter to the TX queue parameters indicating this. As there's currently no support for admission control in mac80211's AP implementation, it's only ever set for the client implementation. Signed-off-by: Alexander Bondar <alexander.bondar@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-22Merge remote-tracking branch 'wireless-next/master' into mac80211-nextJohannes Berg
2013-04-20net: fix incorrect credentials passingLinus Torvalds
Commit 257b5358b32f ("scm: Capture the full credentials of the scm sender") changed the credentials passing code to pass in the effective uid/gid instead of the real uid/gid. Obviously this doesn't matter most of the time (since normally they are the same), but it results in differences for suid binaries when the wrong uid/gid ends up being used. This just undoes that (presumably unintentional) part of the commit. Reported-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: David S. Miller <davem@davemloft.net> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19irda: small read past the end of array in debug codeDan Carpenter
The "reason" can come from skb->data[] and it hasn't been capped so it can be from 0-255 instead of just 0-6. For example in irlmp_state_dtr() the code does: reason = skb->data[3]; ... irlmp_disconnect_indication(self, reason, skb); Also LMREASON has a couple other values which don't have entries in the irlmp_reasons[] array. And 0xff is a valid reason as well which means "unknown". So far as I can see we don't actually care about "reason" except for in the debug code. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19netfilter: rename netlink related "pid" variables to "portid"Patrick McHardy
Get rid of the confusing mix of pid and portid and use portid consistently for all netlink related socket identities. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19Bluetooth: Fix HCI command send functions to use const specifierJohan Hedberg
All HCI command send functions that take a pointer to the command parameters do not need to modify the content in any way (they merely copy the data to an skb). Therefore, the parameter type should be declared const. This also allows passing already const parameters to these APIs which previously would have generated a compiler warning. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Rename LE_SCANNING_* macrosAndre Guedes
This patch renames LE_SCANNING_ENABLED and LE_SCANNING_DISABLED macros to LE_SCAN_ENABLE and LE_SCAN_DISABLE in order to keep the same prefix others LE scan macros have. It also fixes le_scan_enable_req function so it uses the LE_SCAN_ ENABLE macro instead of a magic number. Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Add macros for filter duplicates valuesAndre Guedes
This patch adds macros for filter_duplicates parameter values from HCI LE Set Scan Enable command. It also fixes le_scan_enable_req function so it uses the LE_SCAN_FILTER_DUP_ENABLE macro instead of a magic number. The LE_SCAN_FILTER_DUP_DISABLE was also defined since it will be required to properly support the GAP Observer Role. Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Add LE scan type macrosAndre Guedes
This patch adds macros for active and passive LE scan type values. The LE_SCAN_PASSIVE was also defined since it will be used in future by LE connection routine and GAP Observer Role support. Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Add reading of all local feature pagesJohan Hedberg
With the introduction of CSA4 there is now also a features page number 2 available. This patch increments the maximum supported page number to 2 and adds code for reading all available pages (as long as we have support for them - indicated by HCI_MAX_PAGES). Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Track feature pages in a single tableJohan Hedberg
The local and remote features are organized by page number. Page 0 are the LMP features, page 1 the host features, and any pages beyond 1 features that future core specification versions may define. So far we've only had the first two pages and two separate variables has been convenient enough, however with the introduction of Core Specification Addendum 4 there are features defined on page 2. Instead of requiring the addition of a new variable each time a new page number is defined, this patch refactors the code to use a single table for the features. The patch needs to update both the hci_dev and hci_conn structures since there are macros that depend on the features being represented in the same way in both of them. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-18Bluetooth: Move and rename hci_conn_acceptFrédéric Dalleau
Since this function is only used by sco, move it from hci_event.c to sco.c and rename to sco_conn_defer_accept. Make it static. Signed-off-by: Frédéric Dalleau <frederic.dalleau@linux.intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-17net: sctp: sctp_ulpq: remove 'malloced' struct memberDaniel Borkmann
The structure sctp_ulpq is embedded into sctp_association and never separately allocated, also ulpq->malloced is always 0, so that kfree() is never called. Therefore, remove this code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_bind_addr: remove dead codeDaniel Borkmann
The sctp_bind_addr structure has a 'malloced' member that is always set to 0, thus in sctp_bind_addr_free() the kfree() part can never be called. This part is embedded into sctp_ep_common anyway and never alloced. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_transport: remove unused variableDaniel Borkmann
sctp_transport's member 'malloced' is set to 1, never evaluated and the structure is kfreed anyway. So just remove it. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_outq: remove 'malloced' from its structDaniel Borkmann
sctp_outq is embedded into sctp_association, and thus never kmalloced in any way. Also, malloced is always 0, thus kfree() is never called. Therefore, remove that dead piece of code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_inq: remove dead codeDaniel Borkmann
sctp_inq is never kmalloced, since it's integrated into sctp_ep_common and only initialized from eps and assocs. Therefore, remove the dead code from there. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: sctp: sctp_ssnmap: remove 'malloced' element from structDaniel Borkmann
sctp_ssnmap_init() can only be called from sctp_ssnmap_new() where malloced is always set to 1. Thus, when we call sctp_ssnmap_free() the test for map->malloced evaluates always to true. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17Bluetooth: l2cap: add l2cap_user sub-modulesDavid Herrmann
Several sub-modules like HIDP, rfcomm, ... need to track l2cap connections. The l2cap_conn->hcon->dev object is used as parent for sysfs devices so the sub-modules need to be notified when the hci_conn object is removed from sysfs. As submodules normally use the l2cap layer, the l2cap_user objects are registered there instead of on the underlying hci_conn object. This avoids any direct dependency on the HCI layer and lets the l2cap core handle any specifics. This patch introduces l2cap_user objects which contain a "probe" and "remove" callback. You can register them on any l2cap_conn object and if it is active, the "probe" callback will get called. Otherwise, an error is returned. The l2cap_conn object will call your "remove" callback directly before it is removed from user-space. This allows you to remove your submodules _before_ the parent l2cap_conn and hci_conn object is removed. At any time you can asynchronously unregister your l2cap_user object if your submodule vanishes before the l2cap_conn object does. There is no way around l2cap_user. If we want wire-protocols in the kernel, we always want the hci_conn object as parent in the sysfs tree. We cannot use a channel here since we might need multiple channels for a single protocol. But the problem is, we _must_ get notified when an l2cap_conn object is removed. We cannot use reference-counting for object-removal! This is not how it works. If a hardware is removed, we should immediately remove the object from sysfs. Any other behavior would be inconsistent with the rest of the system. Also note that device_del() might sleep, but it doesn't wait for user-space or block very long. It only _unlinks_ the object from sysfs and the whole device-tree. Everything else is handled by ref-counts! This is exactly what the other sub-modules must do: unlink their devices when the "remove" l2cap_user callback is called. They should not do any cleanup or synchronous shutdowns. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2013-04-17Bluetooth: l2cap: introduce l2cap_conn ref-countingDavid Herrmann
If we want to use l2cap_conn outside of l2cap_core.c, we need refcounting for these objects. Otherwise, we cannot synchronize l2cap locks with outside locks and end up with deadlocks. Hence, introduce ref-counting for l2cap_conn objects. This doesn't affect l2cap internals at all, as they use a direct synchronization. We also keep a reference to the parent hci_conn for locking purposes as l2cap_conn depends on this. This doesn't affect the connection itself but only the lifetime of the (dead) object. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
