Daniel Borkmann says:
pull-request: bpf-next 2018-09-25
The following pull-request contains BPF updates for your *net-next* tree.
The main changes are:
1) Allow for RX stack hardening by implementing the kernel's flow
dissector in BPF. Idea was originally presented at netconf 2017 [0].
Quote from merge commit:
[...] Because of the rigorous checks of the BPF verifier, this
provides significant security guarantees. In particular, the BPF
flow dissector cannot get inside of an infinite loop, as with
CVE-2013-4348, because BPF programs are guaranteed to terminate.
It cannot read outside of packet bounds, because all memory accesses
are checked. Also, with BPF the administrator can decide which
protocols to support, reducing potential attack surface. Rarely
encountered protocols can be excluded from dissection and the
program can be updated without kernel recompile or reboot if a
bug is discovered. [...]
Also, a sample flow dissector has been implemented in BPF as part
of this work, from Petar and Willem.
[0] http://vger.kernel.org/netconf2017_files/rx_hardening_and_udp_gso.pdf
2) Add support for bpftool to list currently active attachment
points of BPF networking programs providing a quick overview
similar to bpftool's perf subcommand, from Yonghong.
3) Fix a verifier pruning instability bug where a union member
from the register state was not cleared properly leading to
branches not being pruned despite them being valid candidates,
from Alexei.
4) Various smaller fast-path optimizations in XDP's map redirect
code, from Jesper.
5) Enable to recognize BPF_MAP_TYPE_REUSEPORT_SOCKARRAY maps
in bpftool, from Roman.
6) Remove a duplicate check in libbpf that probes for function
storage, from Taeung.
7) Fix an issue in test_progs by avoid checking for errno since
on success its value should not be checked, from Mauricio.
8) Fix unused variable warning in bpf_getsockopt() helper when
CONFIG_INET is not configured, from Anders.
9) Fix a compilation failure in the BPF sample code's use of
bpf_flow_keys, from Prashant.
10) Minor cleanups in BPF code, from Yue and Zhong.
Implement get/put function for blocks that only take/release the reference
and perform deallocation. These functions are intended to be used by
unlocked rules update path to always hold reference to block while working
with it. They use on new fine-grained locking mechanisms introduced in
previous patches in this set, instead of relying on global protection
provided by rtnl lock.
Extract code that is common with tcf_block_detach_ext() into common
function __tcf_block_put().
Extend tcf_block with rcu to allow safe deallocation when it is accessed
concurrently.
Signed-off-by: Vlad Buslov <vladbu@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
As a preparation for removing rtnl lock dependency from rules update path,
change tcf block reference counter type to refcount_t to allow modification
by concurrent users.
In block put function perform decrement and check reference counter once to
accommodate concurrent modification by unlocked users. After this change
tcf_chain_put at the end of block put function is called with
block->refcnt==0 and will deallocate block after the last chain is
released, so there is no need to manually deallocate block in this case.
However, if block reference counter reached 0 and there are no chains to
release, block must still be deallocated manually.
Implement function to take reference to Qdisc that relies on rcu read lock
instead of rtnl mutex. Function only takes reference to Qdisc if reference
counter isn't zero. Intended to be used by unlocked cls API.
Currently, Qdisc API functions assume that users have rtnl lock taken. To
implement rtnl unlocked classifiers update interface, Qdisc API must be
extended with functions that do not require rtnl lock.
Extend Qdisc structure with rcu. Implement special version of put function
qdisc_put_unlocked() that is called without rtnl lock taken. This function
only takes rtnl lock if Qdisc reference counter reached zero and is
intended to be used as optimization.
Current implementation of qdisc_destroy() decrements Qdisc reference
counter and only actually destroy Qdisc if reference counter value reached
zero. Rename qdisc_destroy() to qdisc_put() in order for it to better
describe the way in which this function currently implemented and used.
Extract code that deallocates Qdisc into new private qdisc_destroy()
function. It is intended to be shared between regular qdisc_put() and its
unlocked version that is introduced in next patch in this series.
Adds a hook for programs of type BPF_PROG_TYPE_FLOW_DISSECTOR and
attach type BPF_FLOW_DISSECTOR that is executed in the flow dissector
path. The BPF program is per-network namespace.
Signed-off-by: Petar Penkov <ppenkov@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Change flower in_hw_count type to fixed-size u32 and dump it as
TCA_FLOWER_IN_HW_COUNT. This change is necessary to properly test shared
blocks and re-offload functionality.
By hand copies of SKB list handlers do not belong in individual packet
schedulers.
Instead, adjust __qdisc_enqueue_tail() such that HTB can use it
instead.
The only other caller of __qdisc_enqueue_tail() is
qdisc_enqueue_tail() so we can move the backlog and return value
handling (which HTB doesn't need/want) to the latter.
This is similar TC_ACT_REDIRECT, but with a slightly different
semantic:
- on ingress the mirred skbs are passed to the target device
network stack without any additional check not scrubbing.
- the rcu-protected stats provided via the tcf_result struct
are updated on error conditions.
This new tcfa_action value is not exposed to the user-space
and can be used only internally by clsact.
v1 -> v2: do not touch TC_ACT_REDIRECT code path, introduce
a new action type instead
v2 -> v3:
- rename the new action value TC_ACT_REINJECT, update the
helper accordingly
- take care of uncloned reinjected packets in XDP generic
hook
v3 -> v4:
- renamed again the new action value (JiriP)
v4 -> v5:
- fix build error with !NET_CLS_ACT (kbuild bot)
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Each lockless action currently does its own RCU locking in ->act().
This allows using plain RCU accessor, even if the context
is really RCU BH.
This change drops the per action RCU lock, replace the accessors
with the _bh variant, cleans up a bit the surrounding code and
documents the RCU status in the relevant header.
No functional nor performance change is intended.
The goal of this patch is clarifying that the RCU critical section
used by the tc actions extends up to the classifier's caller.
v1 -> v2:
- preserve rcu lock in act_bpf: it's needed by eBPF helpers,
as pointed out by Daniel
v3 -> v4:
- fixed some typos in the commit message (JiriP)
In case a chain is empty and not explicitly created by a user,
such chain should not exist. The only exception is if there is
an action "goto chain" pointing to it. In that case, don't show the
chain in the dump. Track the chain references held by actions and
use them to find out if a chain should or should not be shown
in chain dump.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Allow user to set a template for newly created chains. Template lock
down the chain for particular classifier type/options combinations.
The classifier needs to support templates, otherwise kernel would
reply with error.
Allow user to create, destroy, get and dump chain objects. Do that by
extending rtnl commands by the chain-specific ones. User will now be
able to explicitly create or destroy chains (so far this was done only
automatically according the filter/act needs and refcounting). Also, the
user will receive notification about any chain creation or destuction.
Currently, chain 0 is implicitly created during block creation. However
that does not align with chain object exposure, creation and destruction
api introduced later on. So make the chain 0 behave the same way as any
other chain and only create it when it is needed. Since chain 0 is
somehow special as the qdiscs need to hold pointer to the first chain
tp, this requires to move the chain head change callback infra to the
block structure.
Add the reoffload tcf_proto_op in flower to generate an offload message
for each filter in the given tcf_proto. Call the specified callback with
this new offload message. The function only returns an error if the
callback rejects adding a 'hardware only' rule.
A filter contains a flag to indicate if it is in hardware or not. To
ensure the reoffload function properly maintains this flag, keep a
reference counter for the number of instances of the filter that are in
hardware. Only update the flag when this counter changes from or to 0. Add
a generic helper function to implement this behaviour.
Signed-off-by: John Hurley <john.hurley@netronome.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Create a new tcf_proto_op called 'reoffload' that generates a new offload
message for each node in a tcf_proto. Pointers to the tcf_proto and
whether the offload request is to add or delete the node are included.
Also included is a callback function to send the offload message to and
the option of priv data to go with the cb.
AFAICT struct gnet_stats_queue.qlen is not used in Qdiscs.
It may, however, be useful for offloads to report HW queue
length there. Add that value to the result of qdisc_qlen_sum().
The struct Qdisc has a lot of holes, especially after commit
a53851e2c321 ("net: sched: explicit locking in gso_cpu fallback"),
which as a side effect, moved the fields just after 'busylock'
on a new cacheline.
Since both 'padded' and 'refcnt' are not updated frequently, and
there is a hole before 'gso_skb', we can move such fields there,
saving a cacheline without any performance side effect.
Before this commit:
pahole -C Qdisc net/sche/sch_generic.o
/* size: 384, cachelines: 6, members: 25 */
/* sum members: 236, holes: 3, sum holes: 92 */
/* padding: 56 */
After this commit:
/* size: 320, cachelines: 5, members: 25 */
/* sum members: 236, holes: 2, sum holes: 28 */
/* padding: 56 */
So that we can use lockdep on it.
The newly introduced sequence lock has the same scope of busylock,
so it shares the same lockdep annotation, but it's only used for
NOLOCK qdiscs.
With this changeset we acquire such lock in the control path around
flushing operation (qdisc reset), to allow more NOLOCK qdisc perf
improvement in the next patch.
Currently NOLOCK qdiscs pay a measurable overhead to atomically
manipulate the __QDISC_STATE_RUNNING. Such bit is flipped twice per
packet in the uncontended scenario with packet rate below the
line rate: on packed dequeue and on the next, failing dequeue attempt.
This changeset moves the bit manipulation into the qdisc_run_{begin,end}
helpers, so that the bit is now flipped only once per packet, with
measurable performance improvement in the uncontended scenario.
This also allows simplifying the qdisc teardown code path - since
qdisc_is_running() is now effective for each qdisc type - and avoid a
possible race between qdisc_run() and dev_deactivate_many(), as now
the some_qdisc_is_busy() can properly detect NOLOCK qdiscs being busy
dequeuing packets.
Minor conflicts in drivers/net/ethernet/mellanox/mlx5/core/en_rep.c,
we had some overlapping changes:
1) In 'net' MLX5E_PARAMS_LOG_{SQ,RQ}_SIZE -->
MLX5E_REP_PARAMS_LOG_{SQ,RQ}_SIZE
2) In 'net-next' params->log_rq_size is renamed to be
params->log_rq_mtu_frames.
3) In 'net-next' params->hard_mtu is added.
After the qdisc lock was dropped in pfifo_fast we allow multiple
enqueue threads and dequeue threads to run in parallel. On the
enqueue side the skb bit ooo_okay is used to ensure all related
skbs are enqueued in-order. On the dequeue side though there is
no similar logic. What we observe is with fewer queues than CPUs
it is possible to re-order packets when two instances of
__qdisc_run() are running in parallel. Each thread will dequeue
a skb and then whichever thread calls the ndo op first will
be sent on the wire. This doesn't typically happen because
qdisc_run() is usually triggered by the same core that did the
enqueue. However, drivers will trigger __netif_schedule()
when queues are transitioning from stopped to awake using the
netif_tx_wake_* APIs. When this happens netif_schedule() calls
qdisc_run() on the same CPU that did the netif_tx_wake_* which
is usually done in the interrupt completion context. This CPU
is selected with the irq affinity which is unrelated to the
enqueue operations.
To resolve this we add a RUNNING bit to the qdisc to ensure
only a single dequeue per qdisc is running. Enqueue and dequeue
operations can still run in parallel and also on multi queue
NICs we can still have a dequeue in-flight per qdisc, which
is typically per CPU.
Fixes: c5ad119fb6c0 ("net: sched: pfifo_fast use skb_array")
Reported-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
Fun set of conflict resolutions here...
For the mac80211 stuff, these were fortunately just parallel
adds. Trivially resolved.
In drivers/net/phy/phy.c we had a bug fix in 'net' that moved the
function phy_disable_interrupts() earlier in the file, whilst in
'net-next' the phy_error() call from this function was removed.
In net/ipv4/xfrm4_policy.c, David Ahern's changes to remove the
'rt_table_id' member of rtable collided with a bug fix in 'net' that
added a new struct member "rt_mtu_locked" which needs to be copied
over here.
The mlxsw driver conflict consisted of net-next separating
the span code and definitions into separate files, whilst
a 'net' bug fix made some changes to that moved code.
The mlx5 infiniband conflict resolution was quite non-trivial,
the RDMA tree's merge commit was used as a guide here, and
here are their notes:
Due to bug fixes found by the syzkaller bot and taken into the for-rc
branch after development for the 4.17 merge window had already started
being taken into the for-next branch, there were fairly non-trivial
merge issues that would need to be resolved between the for-rc branch
and the for-next branch. This merge resolves those conflicts and
provides a unified base upon which ongoing development for 4.17 can
be based.
drivers/infiniband/hw/mlx5/main.c - Commit 42cea83f9524
(IB/mlx5: Fix cleanup order on unload) added to for-rc and
commit b5ca15ad7e61 (IB/mlx5: Add proper representors support)
add as part of the devel cycle both needed to modify the
init/de-init functions used by mlx5. To support the new
representors, the new functions added by the cleanup patch
needed to be made non-static, and the init/de-init list
added by the representors patch needed to be modified to
match the init/de-init list changes made by the cleanup
patch.
Updates:
drivers/infiniband/hw/mlx5/mlx5_ib.h - Update function
prototypes added by representors patch to reflect new function
names as changed by cleanup patch
drivers/infiniband/hw/mlx5/ib_rep.c - Update init/de-init
stage list to match new order from cleanup patch
When we exceed current packets limit and we have more than one
segment in the list returned by skb_gso_segment(), netem drops
only the first one, skipping the rest, hence kmemleak reports:
unreferenced object 0xffff880b5d23b600 (size 1024):
comm "softirq", pid 0, jiffies 4384527763 (age 2770.629s)
hex dump (first 32 bytes):
00 80 23 5d 0b 88 ff ff 00 00 00 00 00 00 00 00 ..#]............
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<00000000d8a19b9d>] __alloc_skb+0xc9/0x520
[<000000001709b32f>] skb_segment+0x8c8/0x3710
[<00000000c7b9bb88>] tcp_gso_segment+0x331/0x1830
[<00000000c921cba1>] inet_gso_segment+0x476/0x1370
[<000000008b762dd4>] skb_mac_gso_segment+0x1f9/0x510
[<000000002182660a>] __skb_gso_segment+0x1dd/0x620
[<00000000412651b9>] netem_enqueue+0x1536/0x2590 [sch_netem]
[<0000000005d3b2a9>] __dev_queue_xmit+0x1167/0x2120
[<00000000fc5f7327>] ip_finish_output2+0x998/0xf00
[<00000000d309e9d3>] ip_output+0x1aa/0x2c0
[<000000007ecbd3a4>] tcp_transmit_skb+0x18db/0x3670
[<0000000042d2a45f>] tcp_write_xmit+0x4d4/0x58c0
[<0000000056a44199>] tcp_tasklet_func+0x3d9/0x540
[<0000000013d06d02>] tasklet_action+0x1ca/0x250
[<00000000fcde0b8b>] __do_softirq+0x1b4/0x5a3
[<00000000e7ed027c>] irq_exit+0x1e2/0x210
Fix it by adding the rest of the segments, if any, to skb 'to_free'
list. Add new __qdisc_drop_all() and qdisc_drop_all() functions
because they can be useful in the future if we need to drop segmented
GSO packets in other places.
Fixes: 6071bd1aa13e ("netem: Segment GSO packets on enqueue")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Fix trivial spelling mistake "greater then" -> "greater than".
Signed-off-by: Gal Pressman <galp@mellanox.com>
Introduce a new qdisc ops ->change_tx_queue_len() so that
each qdisc could decide how to implement this if it wants.
Previously we simply read dev->tx_queue_len, after pfifo_fast
switches to skb array, we need this API to resize the skb array
when we change dev->tx_queue_len.
To avoid handling race conditions with TX BH, we need to
deactivate all TX queues before change the value and bring them
back after we are done, this also makes implementation easier.
Cc: John Fastabend <john.fastabend@gmail.com>
Propagate extack to cls->destroy callbacks when called from
non-error paths. On error paths pass NULL to avoid overwriting
the failure message.
Reviewed-by: Simon Horman <simon.horman@netronome.com>
This patch adds extack support for classifier delete callback api. This
prepares to handle extack support inside each specific classifier
implementation.
Cc: David Ahern <dsahern@gmail.com>
Signed-off-by: Alexander Aring <aring@mojatatu.com>
This patch adds extack support for classifier change callback api. This
implementation.
This patch changes some code style issues pointed out by checkpatch
inside the TC cls subsystem.
Introduce two new attributes to be used for qdisc creation and dumping.
One for ingress block, one for egress block. Introduce a set of ops that
qdisc which supports block sharing would implement.
Passing block indexes in qdisc change is not supported yet and it is
checked and forbidded.
In future, these attributes are to be reused for specifying block
indexes for classes as well. As of this moment however, it is not
supported so a check is in place to forbid it.
Suggested-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: David Ahern <dsahern@gmail.com>
During block bind, we need to check tc offload feature. If it is
disabled yet still the block contains offloaded filters, forbid the
bind. Also forbid to register callback for a block that already
contains offloaded filters, as the play back is not supported now.
For keeping track of offloaded filters there is a new counter
introduced, alongside with couple of helpers called from cls_* code.
These helpers set and clear TCA_CLS_FLAGS_IN_HW flag.
Both are no longer used, so remove them.
Couple of classifiers call netif_keep_dst directly on q->dev. That is
not possible to do directly for shared blocke where multiple qdiscs are
owning the block. So introduce a infrastructure to keep track of the
block owners in list and use this list to implement block variant of
netif_keep_dst.
Allow qdiscs to share filter blocks among them. Each qdisc type has to
use block get/put extended modifications that enable sharing.
Shared blocks are tracked within each net namespace and identified
by u32 index. This index is passed from user during the qdisc creation.
If user passes index that is not used by any other qdisc, new block
is created. If user passes index that is already used, the existing
block will be re-used.
So far, there was possible only to register a single filter chain
pointer to block->chain[0]. However, when the blocks will get shareable,
we need to allow multiple filter chain pointers registration.
Overlapping changes all over.
The mini-qdisc bits were a little bit tricky, however.
While working on fixing another bug, I ran into the following panic
on arm64 by simply attaching clsact qdisc, adding a filter and running
traffic on ingress to it:
[ 178.188591] Unable to handle kernel read from unreadable memory at virtual address 810fb501f000
[ 178.197314] Mem abort info:
[ 178.200121] ESR = 0x96000004
[ 178.203168] Exception class = DABT (current EL), IL = 32 bits
[ 178.209095] SET = 0, FnV = 0
[ 178.212157] EA = 0, S1PTW = 0
[ 178.215288] Data abort info:
[ 178.218175] ISV = 0, ISS = 0x00000004
[ 178.222019] CM = 0, WnR = 0
[ 178.224997] user pgtable: 4k pages, 48-bit VAs, pgd = 0000000023cb3f33
[ 178.231531] [0000810fb501f000] *pgd=0000000000000000
[ 178.236508] Internal error: Oops: 96000004 [#1] SMP
[ 178.311855] CPU: 73 PID: 2497 Comm: ping Tainted: G W 4.15.0-rc7+ #5
[ 178.319413] Hardware name: FOXCONN R2-1221R-A4/C2U4N_MB, BIOS G31FB18A 03/31/2017
[ 178.326887] pstate: 60400005 (nZCv daif +PAN -UAO)
[ 178.331685] pc : __netif_receive_skb_core+0x49c/0xac8
[ 178.336728] lr : __netif_receive_skb+0x28/0x78
[ 178.341161] sp : ffff00002344b750
[ 178.344465] x29: ffff00002344b750 x28: ffff810fbdfd0580
[ 178.349769] x27: 0000000000000000 x26: ffff000009378000
[ 178.418715] x1 : 0000000000000054 x0 : 0000000000000000
[ 178.424020] Process ping (pid: 2497, stack limit = 0x000000009f0a3ff4)
[ 178.430537] Call trace:
[ 178.432976] __netif_receive_skb_core+0x49c/0xac8
[ 178.437670] __netif_receive_skb+0x28/0x78
[ 178.441757] process_backlog+0x9c/0x160
[ 178.445584] net_rx_action+0x2f8/0x3f0
Reason is that sch_ingress and sch_clsact are doing mini_qdisc_pair_init()
which sets up miniq pointers to cpu_{b,q}stats from the underlying qdisc.
Problem is that this cannot work since they are actually set up right after
the qdisc ->init() callback in qdisc_create(), so first packet going into
sch_handle_ingress() tries to call mini_qdisc_bstats_cpu_update() and we
therefore panic.
In order to fix this, allocation of {b,q}stats needs to happen before we
call into ->init(). In net-next, there's already such option through commit
d59f5ffa59d8 ("net: sched: a dflt qdisc may be used with per cpu stats").
However, the bug needs to be fixed in net still for 4.15. Thus, include
these bits to reduce any merge churn and reuse the static_flags field to
set TCQ_F_CPUSTATS, and remove the allocation from qdisc_create() since
there is no other user left. Prashant Bhole ran into the same issue but
for net-next, thus adding him below as well as co-author. Same issue was
also reported by Sandipan Das when using bcc.
Fixes: 46209401f8f6 ("net: core: introduce mini_Qdisc and eliminate usage of tp->q for clsact fastpath")
Reference: https://lists.iovisor.org/pipermail/iovisor-dev/2018-January/001190.html
Reported-by: Sandipan Das <sandipan@linux.vnet.ibm.com>
Co-authored-by: Prashant Bhole <bhole_prashant_q7@lab.ntt.co.jp>
Co-authored-by: John Fastabend <john.fastabend@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Jiri Pirko <jiri@resnulli.us>
This patch adds extack support for the function qdisc_create_dflt which is
a common used function in the tc subsystem. Callers which are interested
in the receiving error can assign extack to get a more detailed
information why qdisc_create_dflt failed. The function qdisc_create_dflt
will also call an init callback which can fail by any per-qdisc specific
handling.
This patch adds extack support for the function qdisc_alloc which is
information why qdisc_alloc failed.
This patch adds extack support for graft callback to prepare per-qdisc
specific changes for extack.
This patch adds extack support for block callback to prepare per-qdisc
This patch adds extack support for class change callback api. This prepares
to handle extack support inside each specific class implementation.
This patch adds extack support for change callback for qdisc ops
structtur to prepare per-qdisc specific changes for extack.
This patch adds extack support for init callback to prepare per-qdisc
Three sets of overlapping changes, two in the packet scheduler
and one in the meson-gxl PHY driver.
Qdiscs can be offloaded to HW, but current implementation isn't uniform.
Instead, qdiscs either pass information about offload status via their
TCA_OPTIONS or omit it altogether.
Introduce a new attribute - TCA_HW_OFFLOAD that would form a uniform
uAPI for the offloading status of qdiscs.
Signed-off-by: Yuval Mintz <yuvalm@mellanox.com>
Add qdisc qlen helper routines for lockless qdiscs to use.
The qdisc qlen is no longer used in the hotpath but it is reported
via stats query on the qdisc so it still needs to be tracked. This
adds the per cpu operations needed along with a helper to return
the summation of per cpu stats.
